[U-Boot] [PATCH v4 3/3] odroid-c2: enable new Meson GX MMC driver in board defconfig
Enable new Meson GX MMC driver in Odroid C2 defconfig.
Signed-off-by: Heiner Kallweit hkallweit1@gmail.com --- v4: - move GXBB_PINMUX definition from patch 3 to this one - remove pinmux configuration in board init and use pinctrl driver instead - rebased --- configs/odroid-c2_defconfig | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/configs/odroid-c2_defconfig b/configs/odroid-c2_defconfig index 62b7627..6de712a 100644 --- a/configs/odroid-c2_defconfig +++ b/configs/odroid-c2_defconfig @@ -3,7 +3,9 @@ CONFIG_ARCH_MESON=y CONFIG_MESON_GXBB=y CONFIG_TARGET_ODROID_C2=y CONFIG_IDENT_STRING=" odroid-c2" -# CONFIG_MMC is not set +CONFIG_MMC=y +CONFIG_DM_MMC=y +CONFIG_MMC_MESON_GX=y CONFIG_DEFAULT_DEVICE_TREE="meson-gxbb-odroidc2" # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set @@ -14,6 +16,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_MMC=y CONFIG_DOS_PARTITION=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y
Heiner Kallweit
