Hi Tom,
This series has the potential for breakage due to badly written drivers, so I'd like to get it in early in the merge window.
Tests here:
https://gitlab.denx.de/u-boot/custodians/u-boot-dm/pipelines/1790
The following changes since commit d8a3f5259a36e76d1de127f65714c40918e8ee4c:
Merge tag 'u-boot-imx-20200107' of https://gitlab.denx.de/u-boot/custodians/u-boot-imx (2020-01-07 08:45:43 -0500)
git://git.denx.de/u-boot-dm.git tags/dm-pull-8jan20
for you to fetch changes up to aaa05deb1283b6beb7334adfa4094fb6bd4ab750:
log: Include missing header for log.h (2020-01-07 16:03:01 -0700)
---------------------------------------------------------------- dm: Increased separation of ofdata_to_platdata() and probe methods
---------------------------------------------------------------- Masahiro Yamada (1): binman: fix default filename of u-boot-with-ucode-ptr in documentation
Sean Anderson (3): Include missing headers for fdt_support.h dm: Add a debug message when devices are skipped pre-reloc log: Include missing header for log.h
Simon Glass (19): common: Add a noisy assert() dm: core: Use assert_noisy() in devres usb: Drop use of BUG_ON() and WARN_ON() x86: apl: Avoid accessing the PCI bus before it is probed pci: Print a warning if the bus is accessed before probing aspeed: ast2500: Read clock ofdata in the correct method dm: core: Don't clear active flag twice when probe() fails dm: core: Move ofdata_to_platdata() call earlier dm: core: Allocate parent data separate from probing parent dm: core: Add a comment for DM_FLAG_OF_PLATDATA dm: core: Export a new function to read platdata dm: core: Add a new flag to track platform data dm: devres: Create a new devres header file test: Add functions to find the amount of allocated memory dm: devres: Convert to use logging dm: test: Add a test driver for devres dm: devres: Add tests dm: devres: Use an enum for the allocation phase dm: devres: Add a new OFDATA phase
arch/sandbox/dts/test.dts | 4 + arch/x86/cpu/apollolake/p2sb.c | 20 ++- arch/x86/cpu/apollolake/pmc.c | 20 ++- drivers/clk/aspeed/clk_ast2500.c | 4 +- drivers/core/device-remove.c | 1 + drivers/core/device.c | 56 +++++-- drivers/core/devres.c | 57 +++++-- drivers/core/lists.c | 4 +- drivers/pci/pci-uclass.c | 13 ++ drivers/usb/gadget/composite.c | 4 + drivers/usb/gadget/f_mass_storage.c | 4 + drivers/usb/musb-new/musb_core.c | 4 + drivers/usb/musb-new/musb_gadget_ep0.c | 2 +- include/dm/device-internal.h | 16 ++ include/dm/device.h | 259 +----------------------------- include/dm/devres.h | 289 ++++++++++++++++++++++++++++++++++ include/dm/uclass-id.h | 1 + include/fdt_support.h | 1 + include/log.h | 16 ++ include/test/test.h | 10 ++ include/test/ut.h | 16 ++ test/dm/Makefile | 1 + test/dm/devres.c | 186 ++++++++++++++++++++++ test/dm/test-fdt.c | 58 +++++++ test/ut.c | 14 ++ tools/binman/README.entries | 2 +- tools/binman/etype/u_boot_with_ucode_ptr.py | 2 +- 27 files changed, 767 insertions(+), 297 deletions(-) create mode 100644 include/dm/devres.h create mode 100644 test/dm/devres.c
On Wed, Jan 08, 2020 at 11:04:50AM -0700, Simon Glass wrote:
Hi Tom,
Tests here:
