[PATCH] efi_loader: Fix buffer underflow If the array index 'i' < 128, the 'codepage' array is accessed using [-128...-1] in efi_unicode_collation.c:262. This can lead to a buffer overflow. Negative index in efi_unicode_collation.c:262. The index of the 'codepage' array should be c-0x80 instead of i-0x80.
Fixes: 0bc4b0da7b59 ("efi_loader: EFI_UNICODE_COLLATION_PROTOCOL") Signed-off-by: Mikhail Ilin ilin.mikhail.ol@gmail.com --- lib/efi_loader/efi_unicode_collation.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_unicode_collation.c b/lib/efi_loader/efi_unicode_collation.c index c700be8756..282045b556 100644 --- a/lib/efi_loader/efi_unicode_collation.c +++ b/lib/efi_loader/efi_unicode_collation.c @@ -259,7 +259,7 @@ static void EFIAPI efi_fat_to_str(struct efi_unicode_collation_protocol *this, for (i = 0; i < fat_size; ++i) { c = (unsigned char)fat[i]; if (c > 0x80) - c = codepage[i - 0x80]; + c = codepage[c - 0x80]; string[i] = c; if (!c) break;
Thank you for reporting the problem.
The commit message should not be in the title.
Otherwise: Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
string[i] = c; if (!c) break;c = codepage[c - 0x80];
Mikhail Ilin
