[U-Boot] [PATCH 1/1] igep0020: set OMAP MUX mcspi1_cs2 pin to GPIO 176 mode
According to the IGEPv2 Rev.C data-sheet the LAN9221i pin 14 (IRQ) is connected to the OMAP3730 mcspi1_cs2 pin. Since this omap mux pin acts as an IRQ line, it has to be configured as an input GPIO.
IGEPv2 platform code sets the smsc911x_cfg->gpio_irq to GPIO 176 but since the mux pin default mode is MODE7 (safe_mode) the driver fails when trying to register the IRQ:
[ 1.994598] smsc911x: Driver version 2008-10-21 [ 3.704162] irq 272: nobody cared (try booting with the "irqpoll" option) [ 3.711364] [<c001a114>] (unwind_backtrace+0x0/0xf0) from [<c009a0d4>] (__report_bad_irq+0x20/0xbc) [ 3.720916] [<c009a0d4>] (__report_bad_irq+0x20/0xbc) from [<c009a41c>] (note_interrupt+0x1d8/0x238) [ 3.730560] [<c009a41c>] (note_interrupt+0x1d8/0x238) from [<c0098234>] (handle_irq_event_percpu+0xc0/0x260) [ 3.740936] [<c0098234>] (handle_irq_event_percpu+0xc0/0x260) from [<c0098410>] (handle_irq_event+0x3c/0x5c) [ 3.751312] [<c0098410>] (handle_irq_event+0x3c/0x5c) from [<c009abe0>] (handle_level_irq+0xac/0x10c) [ 3.761047] [<c009abe0>] (handle_level_irq+0xac/0x10c) from [<c0097a34>] (generic_handle_irq+0x30/0x48) [ 3.770935] [<c0097a34>] (generic_handle_irq+0x30/0x48) from [<c02a6b74>] (gpio_irq_handler+0x180/0x1d4) [ 3.780944] [<c02a6b74>] (gpio_irq_handler+0x180/0x1d4) from [<c0097a34>] (generic_handle_irq+0x30/0x48) [ 3.790954] [<c0097a34>] (generic_handle_irq+0x30/0x48) from [<c0013e18>] (handle_IRQ+0x4c/0xac) [ 3.800231] [<c0013e18>] (handle_IRQ+0x4c/0xac) from [<c000858c>] (omap3_intc_handle_irq+0x60/0x74) [ 3.809783] [<c000858c>] (omap3_intc_handle_irq+0x60/0x74) from [<c04979e4>] (__irq_svc+0x44/0x60) [ 3.819213] Exception stack(0xee42fde0 to 0xee42fe28) [ 3.824554] fde0: 00000001 00000001 00000000 00000000 60000013 c06cce14 c06cce14 00000110 [ 3.833190] fe00: 00000000 c06ccdf4 60000013 ee41d000 fb058064 ee42fe28 c0089e08 c04976b4 [ 3.841796] fe20: 20000013 ffffffff [ 3.845489] [<c04979e4>] (__irq_svc+0x44/0x60) from [<c04976b4>] (_raw_spin_unlock_irqrestore+0x34/0x44) [ 3.855499] [<c04976b4>] (_raw_spin_unlock_irqrestore+0x34/0x44) from [<c0099744>] (__setup_irq+0x1b8/0x3f0) [ 3.865875] [<c0099744>] (__setup_irq+0x1b8/0x3f0) from [<c0099a34>] (request_threaded_irq+0xb8/0x140) [ 3.875701] [<c0099a34>] (request_threaded_irq+0xb8/0x140) from [<c0487950>] (smsc911x_drv_probe+0x75c/0x11a4) [ 3.886260] [<c0487950>] (smsc911x_drv_probe+0x75c/0x11a4) from [<c02e9bcc>] (platform_drv_probe+0x18/0x1c) [ 3.896545] [<c02e9bcc>] (platform_drv_probe+0x18/0x1c) from [<c02e89b8>] (driver_probe_device+0x90/0x210) [ 3.906707] [<c02e89b8>] (driver_probe_device+0x90/0x210) from [<c02e8bcc>] (__driver_attach+0x94/0x98) [ 3.916625] [<c02e8bcc>] (__driver_attach+0x94/0x98) from [<c02e7298>] (bus_for_each_dev+0x50/0x7c) [ 3.926177] [<c02e7298>] (bus_for_each_dev+0x50/0x7c) from [<c02e81d4>] (bus_add_driver+0x184/0x248) [ 3.935821] [<c02e81d4>] (bus_add_driver+0x184/0x248) from [<c02e909c>] (driver_register+0x78/0x12c) [ 3.945465] [<c02e909c>] (driver_register+0x78/0x12c) from [<c0008648>] (do_one_initcall+0x34/0x178) [ 3.955108] [<c0008648>] (do_one_initcall+0x34/0x178) from [<c066e8f4>] (kernel_init+0xfc/0x1c0) [ 3.964385] [<c066e8f4>] (kernel_init+0xfc/0x1c0) from [<c00140b0>] (kernel_thread_exit+0x0/0x8) [ 3.973632] handlers: [ 3.976043] [<c034e2cc>] smsc911x_irqhandler [ 3.980560] Disabling IRQ #272
Signed-off-by: Javier Martinez Canillas javier@dowhile0.org --- board/isee/igep0020/igep0020.h | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/board/isee/igep0020/igep0020.h b/board/isee/igep0020/igep0020.h index 3d6e15f..eb1aa30 100644 --- a/board/isee/igep0020/igep0020.h +++ b/board/isee/igep0020/igep0020.h @@ -143,5 +143,6 @@ static void setup_net_chip(void); MUX_VAL(CP(SYS_BOOT5), (IEN | PTD | DIS | M4)) /* GPIO_7 */\ MUX_VAL(CP(SYS_BOOT6), (IEN | PTD | DIS | M4)) /* GPIO_8 */\ MUX_VAL(CP(SDRC_CKE0), (IDIS | PTU | EN | M0)) /* SDRC_CKE0 */\ - MUX_VAL(CP(SDRC_CKE1), (IDIS | PTU | EN | M0)) /* SDRC_CKE1 */ + MUX_VAL(CP(SDRC_CKE1), (IDIS | PTU | EN | M0)) /* SDRC_CKE1 */\ + MUX_VAL(CP(MCSPI1_CS2), (IEN | PTD | DIS | M4)) /* GPIO_176-ETH IRQ */ #endif
Hi Javier,
2012/7/3 Javier Martinez Canillas javier@dowhile0.org
GPIO_176-ETH IRQ */
#endif
1.7.7.6
I'm not sure if this is the correct place to do this.
This was discussed for a long, the main question is who must set the pin muxer ?
In my opinion u-boot only should set mux for the pins that it is using and I think u-boot is not using this IRQ pin for ethernet driver (not sure, I need to check). At kernel level of course the driver uses this pin. In my opinion the kernel should guarantees that this pin is muxed correctly, not u-boot.
Any other opinion ? How this is solved in others boards ?
Cheers, Enric
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
On 07/09/2012 12:32 AM, Enric Balletbò i Serra wrote:
Hi Javier,
2012/7/3 Javier Martinez Canillas <javier@dowhile0.org mailto:javier@dowhile0.org>
Signed-off-by: Javier Martinez Canillas <javier@dowhile0.org mailto:javier@dowhile0.org> --- board/isee/igep0020/igep0020.h | 3 ++- 1 files changed, 2 insertions(+), 1 deletions(-)
diff --git a/board/isee/igep0020/igep0020.h b/board/isee/igep0020/igep0020.h index 3d6e15f..eb1aa30 100644 --- a/board/isee/igep0020/igep0020.h +++ b/board/isee/igep0020/igep0020.h @@ -143,5 +143,6 @@ static void setup_net_chip(void); MUX_VAL(CP(SYS_BOOT5), (IEN | PTD | DIS | M4)) /* GPIO_7 */\ MUX_VAL(CP(SYS_BOOT6), (IEN | PTD | DIS | M4)) /* GPIO_8 */\ MUX_VAL(CP(SDRC_CKE0), (IDIS | PTU | EN | M0)) /* SDRC_CKE0 */\ - MUX_VAL(CP(SDRC_CKE1), (IDIS | PTU | EN | M0)) /* SDRC_CKE1 */ + MUX_VAL(CP(SDRC_CKE1), (IDIS | PTU | EN | M0)) /* SDRC_CKE1 */\ + MUX_VAL(CP(MCSPI1_CS2), (IEN | PTD | DIS | M4)) /* GPIO_176-ETH IRQ */ #endif -- 1.7.7.6
The kernel must be ensuring the correct muxing. If we don't need something configured U-Boot should not configure it in general. In practice there is a lot of mux setup that has been done in U-Boot in the past. A quick read says we don't need the IRQ pin in U-Boot currently so we shouldn't set it, so barring a correction on that, NAK and correct the kernel. Thanks!
- -- Tom
Hi Javier,
Hi Enric and Tom,
Thanks a lot for the feedback.
You are right, since the IRQ pin is not used in U-Boot it is better to fix it on the kernel. For me it wasn't clear before when make sense to set the mux on U-Boot and when in the kernel, but now it is clear to me.
I'll cook a patch for the kernel then.
Best regards, Javier
