[U-Boot] [PATCH] powerpc/b4860: Updated default hwconfig so as to enable only CPC2
CPC1 is not being enabled by default as powerpc is supposed to use only CPC2.
Signed-off-by: Shaveta Leekha shaveta@freescale.com Signed-off-by: Sandeep Singh Sandeep@freescale.com --- include/configs/B4860QDS.h | 8 +++++++- 1 files changed, 7 insertions(+), 1 deletions(-)
diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 1af9ba6..53fdac7 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -820,8 +820,14 @@ unsigned long get_board_ddr_clk(void);
#define __USB_PHY_TYPE ulpi
+#ifdef CONFIG_PPC_B4860 +#define HWCONFIG "hwconfig=fsl_ddr:ctlr_intlv=null,en_cpc:cpc2," +#else +#define HWCONFIG "hwconfig=fsl_ddr:ctlr_intlv=null," +#endif + #define CONFIG_EXTRA_ENV_SETTINGS \ - "hwconfig=fsl_ddr:ctlr_intlv=null," \ + HWCONFIG \ "bank_intlv=cs0_cs1;" \ "usb1:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) "\0"\ "netdev=eth0\0" \
- HWCONFIG \ "bank_intlv=cs0_cs1;" \ "usb1:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) "\0"\ "netdev=eth0\0" \
Did you try this patch on a board? You inserted "en_cpc:cpc2" at a wrong place. You actually broke into the setting for DDR. When you move out hwconfig string, you only removed partially.
York
Shaveta Leekha
York Sun
