[U-Boot] [PATCH] board: freescale: ls2080a: Intergrate and enable PPA on LS2080A
Integrate and enable PPA on LS2080ARDB, LS2080AQDS, LS2088ARDB and LS2088AQDS boards.
Signed-off-by: Abhimanyu Saini abhimanyu.saini@nxp.com --- board/freescale/ls2080aqds/ls2080aqds.c | 6 ++++++ board/freescale/ls2080ardb/ls2080ardb.c | 6 ++++++ include/configs/ls2080aqds.h | 10 ++++++++++ include/configs/ls2080ardb.h | 10 ++++++++++ 4 files changed, 32 insertions(+)
diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index 73a61fd..811b9a6 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -19,6 +19,9 @@ #include <asm/arch/soc.h> #include <hwconfig.h> #include <fsl_sec.h> +#ifdef CONFIG_FSL_LS_PPA +#include <asm/arch/ppa.h> +#endif
#include "../common/qixis.h" #include "ls2080aqds_qixis.h" @@ -223,6 +226,9 @@ int board_init(void) #endif select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); rtc_enable_32khz_output(); +#ifdef CONFIG_FSL_LS_PPA + ppa_init(); +#endif
return 0; } diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index 02954ef..339fa78 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -19,6 +19,9 @@ #include <i2c.h> #include <asm/arch/soc.h> #include <fsl_sec.h> +#ifdef CONFIG_FSL_LS_PPA +#include <asm/arch/ppa.h> +#endif
#include "../common/qixis.h" #include "ls2080ardb_qixis.h" @@ -184,6 +187,9 @@ int board_init(void) /* invert AQR405 IRQ pins polarity */ out_le32(irq_ccsr + IRQCR_OFFSET / 4, AQR405_IRQ_MASK); #endif +#ifdef CONFIG_FSL_LS_PPA + ppa_init(); +#endif
return 0; } diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 838568f..5573e94 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -14,6 +14,16 @@ unsigned long get_board_sys_clk(void); unsigned long get_board_ddr_clk(void); #endif
+#define CONFIG_FSL_LS_PPA +#if defined(CONFIG_FSL_LS_PPA) +#define CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT + +#define CONFIG_SYS_LS_PPA_FW_IN_XIP +#ifdef CONFIG_SYS_LS_PPA_FW_IN_XIP +#define CONFIG_SYS_LS_PPA_FW_ADDR 0x580a00000 +#endif +#endif + #define CONFIG_SYS_FSL_CLK
#ifdef CONFIG_FSL_QSPI diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 31df781..d411a4f 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -12,6 +12,16 @@ #undef CONFIG_CONS_INDEX #define CONFIG_CONS_INDEX 2
+#define CONFIG_FSL_LS_PPA +#if defined(CONFIG_FSL_LS_PPA) +#define CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT + +#define CONFIG_SYS_LS_PPA_FW_IN_XIP +#ifdef CONFIG_SYS_LS_PPA_FW_IN_XIP +#define CONFIG_SYS_LS_PPA_FW_ADDR 0x580a00000 +#endif +#endif + #define I2C_MUX_CH_VOL_MONITOR 0xa #define I2C_VOL_MONITOR_ADDR 0x38 #define CONFIG_VOL_MONITOR_IR36021_READ
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Abhimanyu Saini Sent: Thursday, December 29, 2016 9:52 AM To: york sun york.sun@nxp.com; u-boot@lists.denx.de Cc: Priyanka Jain priyanka.jain@nxp.com Subject: [U-Boot] [PATCH] board: freescale: ls2080a: Intergrate and enable PPA on LS2080A
- ppa_init();
- ppa_init();
I am not finding CONFIG_FSL_LS_PPA being defined in board header file. Please refer arch/arm/cpu/armv8/fsl-layerscape/Kconfig. Looks like its enablement is govern from here.
--prabhakar
- ppa_init();
- ppa_init();
Since this config option has been moved into Kconfig, we don't use board header file to define it any more. Actually, existing board don't enable this by default either. We can make it default after the PPA image is readily available to public.
This patch lacks modification of arch/arm/cpu/armv8/fsl-layerscape/Kconfig to enable FSL_LS_PPA for LS2080A. There are some floating patches to change the CONFIG_SYS_LS_PPA_FW_IN_XIP. Please work with Zhiqiang on this.
York
- ppa_init();
- ppa_init();
Abhimanyu,
Where are we on this patch? Please send an update ASAP.
York
Abhimanyu Saini
Prabhakar Kushwaha
york sun
