[PATCH] CI: Pin pylint version to 2.12.2
For consistency in runs, we need to always use the same pylint version. Pin to 2.12.2 as this is what we have been using so far.
Signed-off-by: Tom Rini trini@konsulko.com --- .azure-pipelines.yml | 2 +- .gitlab-ci.yml | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 0f1a1bd86326..cd54688881d7 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -214,7 +214,7 @@ stages: cd ${WORK_DIR} export USER=azure pip install -r test/py/requirements.txt - pip install asteval pylint pyopenssl + pip install asteval pylint==2.12.2 pyopenssl export PATH=${PATH}:~/.local/bin echo "[MASTER]" >> .pylintrc echo "load-plugins=pylint.extensions.docparams" >> .pylintrc diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index 388e666ec9e3..7df7e939f542 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -220,7 +220,7 @@ Run pylint: stage: testsuites script: - pip install -r test/py/requirements.txt - - pip install asteval pylint pyopenssl + - pip install asteval pylint==2.12.2 pyopenssl - export PATH=${PATH}:~/.local/bin - echo "[MASTER]" >> .pylintrc - echo "load-plugins=pylint.extensions.docparams" >> .pylintrc
