[U-Boot] [PATCH v3] arm: add acpi support for the arm
This adds acpi code for arm and the acpi tables about Phytium Durian Board. The acpi table only support rsdp, rsdt, xsdt, fadt, dsdt, ssdt, gtdt, madt, mcfg, iort, spcr.
Signed-off-by: Steven Hao steven_hao5189@outlook.com --- Changes for v3: - modify arch/arm/Kconfig - modify lib/efi_loader/efi_setup.c
Changes for v2: - execute git pull --rebase --- MAINTAINERS | 3 + Makefile | 1 + arch/arm/Kconfig | 69 ++ arch/arm/include/asm/acpi_table.h | 39 ++ arch/arm/include/asm/acpi_table/acpi61.h | 755 +++++++++++++++++++++ arch/arm/include/asm/acpi_table/acpi_lib.h | 89 +++ arch/arm/include/asm/acpi_table/arm_platform.h | 93 +++ .../include/asm/acpi_table/io_remapping_table.h | 179 +++++ arch/arm/include/asm/acpi_table/spcr_table.h | 175 +++++ arch/arm/lib/Makefile | 1 + arch/arm/lib/acpi_table.c | 244 +++++++ board/phytium/durian/Makefile | 18 + board/phytium/durian/acpi_platform.h | 38 ++ board/phytium/durian/acpi_table.c | 53 ++ board/phytium/durian/acpi_table/dsdt.asl | 305 +++++++++ board/phytium/durian/acpi_table/fadt.c | 83 +++ board/phytium/durian/acpi_table/gtdt.c | 81 +++ board/phytium/durian/acpi_table/iort.c | 117 ++++ board/phytium/durian/acpi_table/madt.c | 69 ++ board/phytium/durian/acpi_table/mcfg.c | 68 ++ board/phytium/durian/acpi_table/rsdp.c | 25 + board/phytium/durian/acpi_table/rsdt.c | 28 + board/phytium/durian/acpi_table/spcr.c | 78 +++ board/phytium/durian/acpi_table/ssdt.asl | 190 ++++++ board/phytium/durian/acpi_table/xsdt.c | 31 + cmd/bootefi.c | 6 +- configs/durian_defconfig | 9 + include/configs/durian.h | 8 +- lib/efi_loader/Makefile | 1 + lib/efi_loader/efi_setup.c | 2 +- scripts/Makefile.lib | 8 + 31 files changed, 2860 insertions(+), 6 deletions(-) create mode 100644 arch/arm/include/asm/acpi_table.h create mode 100644 arch/arm/include/asm/acpi_table/acpi61.h create mode 100644 arch/arm/include/asm/acpi_table/acpi_lib.h create mode 100644 arch/arm/include/asm/acpi_table/arm_platform.h create mode 100644 arch/arm/include/asm/acpi_table/io_remapping_table.h create mode 100644 arch/arm/include/asm/acpi_table/spcr_table.h create mode 100644 arch/arm/lib/acpi_table.c create mode 100644 board/phytium/durian/acpi_platform.h create mode 100644 board/phytium/durian/acpi_table.c create mode 100644 board/phytium/durian/acpi_table/dsdt.asl create mode 100644 board/phytium/durian/acpi_table/fadt.c create mode 100644 board/phytium/durian/acpi_table/gtdt.c create mode 100644 board/phytium/durian/acpi_table/iort.c create mode 100644 board/phytium/durian/acpi_table/madt.c create mode 100644 board/phytium/durian/acpi_table/mcfg.c create mode 100644 board/phytium/durian/acpi_table/rsdp.c create mode 100644 board/phytium/durian/acpi_table/rsdt.c create mode 100644 board/phytium/durian/acpi_table/spcr.c create mode 100644 board/phytium/durian/acpi_table/ssdt.asl create mode 100644 board/phytium/durian/acpi_table/xsdt.c
diff --git a/MAINTAINERS b/MAINTAINERS index ef2cbb3..e338b62 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -487,6 +487,9 @@ M: shuyiqi shuyiqi@phytium.com.cn S: Maintained F: drivers/pci/pcie_phytium.c F: arch/arm/dts/phytium-durian.dts +F: arch/arm/include/asm/acpi_table.h +F: arch/arm/include/asm/acpi_table/* +F: arch/arm/lib/acpi_table.c
BINMAN M: Simon Glass sjg@chromium.org diff --git a/Makefile b/Makefile index 7485bc2..53ddae3 100644 --- a/Makefile +++ b/Makefile @@ -1953,6 +1953,7 @@ clean: $(clean-dirs) -o -name '*.symtypes' -o -name 'modules.order' \ -o -name modules.builtin -o -name '.tmp_*.o.*' \ -o -name 'dsdt.aml' -o -name 'dsdt.asl.tmp' -o -name 'dsdt.c' \ + -o -name 'ssdt.aml' -o -name 'ssdt.asl.tmp' -o -name 'ssdt.c' \ -o -name '*.efi' -o -name '*.gcno' -o -name '*.so' ) \ -type f -print | xargs rm -f \ bl31.c bl31.elf bl31_*.bin image.map tispl.bin* diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index f96841c..0cd187b 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -354,6 +354,75 @@ config ARM_SMCCC This should be enabled if U-Boot needs to communicate with system firmware (for example, PSCI) according to SMCCC.
+menuconfig ARM_ACPI_TABLE + bool "Support ACPI (Advanced Configuration and Power Interface) for ARM" + depends on ARM + help + The Advanced Configuration and Power Interface (ACPI) specification + provides an open standard for device configuration and management + by the operating system. It defines platform-independent interfaces + for configuration and power management monitoring. + +if ARM_ACPI_TABLE + +config DSDT_TABLE + bool "support DSDT (DIFFERENTIATED_SYSTEM_DESCRIPTION_TABLE) TABLE" + depends on ARM + help + DIFFERENTIATED_SYSTEM_DESCRIPTION_TABLE (DSDT) + Say Y here if you want to support dsdt table. + +config SSDT_TABLE + bool "support SSDT (SECONDARY_SYSTEM_DESCRIPTION_TABLE) TABLE" + depends on ARM + help + SECONDARY_SYSTEM_DESCRIPTION_TABLE (SSDT) + Say Y here if you want to support ssdt table. + +config FADT_TABLE + bool "support FADT (FIXED_ACPI_DESCRIPTION_TABLE) TABLE" + depends on ARM + help + FIXED_ACPI_DESCRIPTION_TABLE (FADT) + Say Y here if you want to support fadt table. + +config GTDT_TABLE + bool "support GTDT (GENERIC_TIMER_DESCRIPTION_TABLE) TABLE" + depends on ARM + help + GENERIC_TIMER_DESCRIPTION_TABLE (GTDT) + Say Y here if you want to support gtdt table. + +config MADT_TABLE + bool "support MADT (MULTIPLE_APIC_DESCRIPTION_TABLE) TABLE" + depends on ARM + help + MULTIPLE_APIC_DESCRIPTION_TABLE (MADT) + Say Y here if you want to support madt table. + +config MCFG_TABLE + bool "support MCFG (PCI_EXPRESS_MEMORY_MAPPED_ADDR_TABLE) TABLE" + depends on ARM + help + PCI_EXPRESS_MEMORY_MAPPED_ADDR_TABLE (MCFG) + Say Y here if you want to support mcfg table. + +config IORT_TABLE + bool "support IORT (IO_REMAPPING_TABLE) TABLE" + depends on ARM + help + IO_REMAPPING_TABLE (IORT) + Say Y here if you want to support iort table. + +config SPCR_TABLE + bool "support SPCR (SERIAL_PORT_CONSOLE_REDIRECTION_TABLE) TABLE" + depends on ARM + help + SERIAL_PORT_CONSOLE_REDIRECTION_TABLE (SPCR) + Say Y here if you want to support spcr table. + +endif + config SEMIHOSTING bool "support boot from semihosting" help diff --git a/arch/arm/include/asm/acpi_table.h b/arch/arm/include/asm/acpi_table.h new file mode 100644 index 0000000..ccd9b2c --- /dev/null +++ b/arch/arm/include/asm/acpi_table.h @@ -0,0 +1,39 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019, PHYTIUM <@phytium.com.cn> + * Steven Hao liuhao@phytium.com.cn + */ + +#ifndef __ASM_ACPI_TABLE_H__ +#define __ASM_ACPI_TABLE_H__ + +extern const unsigned char DsdtAmlCode[]; +extern const unsigned char SsdtAmlCode[]; + +extern unsigned char *rsdp_data; +extern unsigned char *rsdt_data; +extern unsigned char *xsdt_data; +extern unsigned char *fadt_data; +extern unsigned char *madt_data; +extern unsigned char *gtdt_data; +extern unsigned char *mcfg_data; +extern unsigned char *spcr_data; +extern unsigned char *iort_data; + +extern unsigned char *array_acpi_table_address[32]; +extern unsigned char acpi_table_count; + +/* These can be used by the target port */ +ulong write_acpi_tables(ulong start); + +void register_acpi_table_data(void); + +void dynamic_modify_fadt_table(void *table); +void dynamic_modify_gtdt_table(void *table); +void dynamic_modify_madt_table(void *table); +void dynamic_modify_mcfg_table(void *table); +void dynamic_modify_spcr_table(void *table); +void dynamic_modify_iort_table(void *table); + +#endif + diff --git a/arch/arm/include/asm/acpi_table/acpi61.h b/arch/arm/include/asm/acpi_table/acpi61.h new file mode 100644 index 0000000..daf715d --- /dev/null +++ b/arch/arm/include/asm/acpi_table/acpi61.h @@ -0,0 +1,755 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Based on acpi61.h from edk2 + * + * (C) Copyright 2019 + * Phytium Technology Ltd <www.phytium.com> + * Steven Hao liuhao@phytium.com.cn + */ + +#ifndef _ACPI_6_1_H_ +#define _ACPI_6_1_H_ + +#include <asm/acpi_table/arm_platform.h> + +/* + * Ensure proper structure formats + */ +#pragma pack(1) + +/* + * The common ACPI description table header. + * This structure prefaces most ACPI tables. + */ +struct efi_acpi_description_header { + u32 signature; + u32 length; + u8 revision; + u8 checksum; + u8 oem_id[6]; + u64 oem_table_id; + u32 oem_revision; + u32 creator_id; + u32 creator_revision; +}; + +/* + * General use definitions + */ +#define EFI_ACPI_RESERVED_BYTE 0x00 +#define EFI_ACPI_RESERVED_WORD 0x0000 +#define EFI_ACPI_RESERVED_DWORD 0x00000000 +#define EFI_ACPI_RESERVED_QWORD 0x0000000000000000 + +/* + * ACPI 6.1 Generic Address Space definition + */ +struct efi_acpi_6_1_generic_address_structure { + u8 address_space_id; + u8 register_bit_width; + u8 register_bit_offset; + u8 access_size; + u64 address; +}; + +/* + * Generic Address Space Address IDs + */ +#define EFI_ACPI_6_1_SYSTEM_MEMORY 0 +#define EFI_ACPI_6_1_SYSTEM_IO 1 +#define EFI_ACPI_6_1_PCI_CONFIGURATION_SPACE 2 +#define EFI_ACPI_6_1_EMBEDDED_CONTROLLER 3 +#define EFI_ACPI_6_1_SMBUS 4 +#define EFI_ACPI_6_1_PLATFORM_COMMUNICATION_CHANNEL 0x0A +#define EFI_ACPI_6_1_FUNCTIONAL_FIXED_HARDWARE 0x7F + +/* + * Generic Address Space Access Sizes + */ +#define EFI_ACPI_6_1_UNDEFINED 0 +#define EFI_ACPI_6_1_BYTE 1 +#define EFI_ACPI_6_1_WORD 2 +#define EFI_ACPI_6_1_DWORD 3 +#define EFI_ACPI_6_1_QWORD 4 + +/* + * ACPI 6.1 table structures + */ + +/* + * Root System Description Pointer Structure (RSDP) + */ +struct efi_acpi_6_1_root_system_description_pointer { + u64 signature; + u8 checksum; + u8 oem_id[6]; + u8 revision; + u32 rsdt_address; + u32 length; + u64 xsdt_address; + u8 extended_checksum; + u8 reserved[3]; +}; + +/* + * RSD_PTR Revision (as defined in ACPI 6.1 spec.) + */ + +/* < ACPISpec (Revision 6.1) says current value is 2 */ +#define EFI_ACPI_6_1_ROOT_SYSTEM_DESCRIPTION_POINTER_REVISION 0x02 + +/* + * Common table header, this prefaces all ACPI tables, including FACS, but + * excluding the RSD PTR structure + */ +struct efi_acpi_6_1_common_header { + u32 signature; + u32 length; +}; + +/* + * Root System Description Table + * No definition needed as it is a common description table header, + * the same with EFI_ACPI_DESCRIPTION_HEADER, + * followed by a variable number of UINT32 table pointers. + */ +#define MAX_ACPI_62_TABLES 32 + +struct efi_acpi_6_1_root_system_description_table { + struct efi_acpi_description_header header; + u32 entry[MAX_ACPI_62_TABLES]; +}; + +/* + * RSDT Revision (as defined in ACPI 6.1 spec.) + */ +#define EFI_ACPI_6_1_ROOT_SYSTEM_DESCRIPTION_TABLE_REVISION 0x01 + +/* + * Extended System Description Table + * No definition needed as it is a common description table header, + * the same with EFI_ACPI_DESCRIPTION_HEADER, + * followed by a variable number of UINT64 table pointers. + */ +struct efi_acpi_6_1_extended_system_description_table { + struct efi_acpi_description_header header; + u64 entry[MAX_ACPI_62_TABLES]; +}; + +/* + * XSDT Revision (as defined in ACPI 6.1 spec.) + */ +#define EFI_ACPI_6_1_EXTENDED_SYSTEM_DESCRIPTION_TABLE_REVISION 0x01 + +/* + * Fixed ACPI Description Table Structure (FADT) + */ +struct efi_acpi_6_1_fixed_acpi_description_table { + struct efi_acpi_description_header header; + u32 firmware_ctrl; + u32 dsdt; + u8 reserved0; + u8 preferred_pm_profile; + u16 sci_int; + u32 smi_cmd; + u8 acpi_enable; + u8 acpi_disable; + u8 s4_bios_req; + u8 pstate_cnt; + u32 pm1a_evt_blk; + u32 pm1b_evt_blk; + u32 pm1a_cnt_blk; + u32 pm1b_cnt_blk; + u32 pm2_cnt_blk; + u32 pm_tmr_blk; + u32 gpe0_blk; + u32 gpe1_blk; + u8 pm1_evt_len; + u8 pm1_cnt_len; + u8 pm2_cnt_len; + u8 pm_tmr_len; + u8 gpe0_blk_len; + u8 gpe1_blk_len; + u8 gpe1_base; + u8 cst_cnt; + u16 plvl2_lat; + u16 plvl3_lat; + u16 flush_size; + u16 flush_stride; + u8 duty_offset; + u8 duty_width; + u8 day_alrm; + u8 mon_alrm; + u8 century; + u16 ia_pc_boot_arch; + u8 reserved1; + u32 flags; + struct efi_acpi_6_1_generic_address_structure reset_reg; + u8 reset_value; + u16 arm_boot_arch; + u8 minor_version; + u64 x_firmware_ctrl; + u64 x_dsdt; + struct efi_acpi_6_1_generic_address_structure x_pm1a_evt_blk; + struct efi_acpi_6_1_generic_address_structure x_pm1b_evt_blk; + struct efi_acpi_6_1_generic_address_structure x_pm1a_cnt_blk; + struct efi_acpi_6_1_generic_address_structure x_pm1b_cnt_blk; + struct efi_acpi_6_1_generic_address_structure x_pm2_cnt_blk; + struct efi_acpi_6_1_generic_address_structure x_pm_tmr_blk; + struct efi_acpi_6_1_generic_address_structure x_gpe0_blk; + struct efi_acpi_6_1_generic_address_structure x_gpe1_blk; + struct efi_acpi_6_1_generic_address_structure sleep_control_reg; + struct efi_acpi_6_1_generic_address_structure sleep_status_reg; + u64 hypervisor_vendor_identity; +}; + +/* + * FADT Version (as defined in ACPI 6.1 spec.) + */ +#define EFI_ACPI_6_1_FIXED_ACPI_DESCRIPTION_TABLE_REVISION 0x06 +#define EFI_ACPI_6_1_FIXED_ACPI_DESCRIPTION_TABLE_MINOR_REVISION 0x01 + +/* + * Fixed ACPI Description Table Preferred Power Management Profile + */ +#define EFI_ACPI_6_1_PM_PROFILE_UNSPECIFIED 0 +#define EFI_ACPI_6_1_PM_PROFILE_DESKTOP 1 +#define EFI_ACPI_6_1_PM_PROFILE_MOBILE 2 +#define EFI_ACPI_6_1_PM_PROFILE_WORKSTATION 3 +#define EFI_ACPI_6_1_PM_PROFILE_ENTERPRISE_SERVER 4 +#define EFI_ACPI_6_1_PM_PROFILE_SOHO_SERVER 5 +#define EFI_ACPI_6_1_PM_PROFILE_APPLIANCE_PC 6 +#define EFI_ACPI_6_1_PM_PROFILE_PERFORMANCE_SERVER 7 +#define EFI_ACPI_6_1_PM_PROFILE_TABLET 8 + +/* + * Fixed ACPI Description Table Boot Architecture Flags + * All other bits are reserved and must be set to 0. + */ +#define EFI_ACPI_6_1_LEGACY_DEVICES BIT0 +#define EFI_ACPI_6_1_8042 BIT1 +#define EFI_ACPI_6_1_VGA_NOT_PRESENT BIT2 +#define EFI_ACPI_6_1_MSI_NOT_SUPPORTED BIT3 +#define EFI_ACPI_6_1_PCIE_ASPM_CONTROLS BIT4 +#define EFI_ACPI_6_1_CMOS_RTC_NOT_PRESENT BIT5 + +/* + * Fixed ACPI Description Table Arm Boot Architecture Flags + * All other bits are reserved and must be set to 0. + */ +#define EFI_ACPI_6_1_ARM_PSCI_COMPLIANT BIT0 +#define EFI_ACPI_6_1_ARM_PSCI_USE_HVC BIT1 + +/* + * Fixed ACPI Description Table Fixed Feature Flags + * All other bits are reserved and must be set to 0. + */ +#define EFI_ACPI_6_1_WBINVD BIT0 +#define EFI_ACPI_6_1_WBINVD_FLUSH BIT1 +#define EFI_ACPI_6_1_PROC_C1 BIT2 +#define EFI_ACPI_6_1_P_LVL2_UP BIT3 +#define EFI_ACPI_6_1_PWR_BUTTON BIT4 +#define EFI_ACPI_6_1_SLP_BUTTON BIT5 +#define EFI_ACPI_6_1_FIX_RTC BIT6 +#define EFI_ACPI_6_1_RTC_S4 BIT7 +#define EFI_ACPI_6_1_TMR_VAL_EXT BIT8 +#define EFI_ACPI_6_1_DCK_CAP BIT9 +#define EFI_ACPI_6_1_RESET_REG_SUP BIT10 +#define EFI_ACPI_6_1_SEALED_CASE BIT11 +#define EFI_ACPI_6_1_HEADLESS BIT12 +#define EFI_ACPI_6_1_CPU_SW_SLP BIT13 +#define EFI_ACPI_6_1_PCI_EXP_WAK BIT14 +#define EFI_ACPI_6_1_USE_PLATFORM_CLOCK BIT15 +#define EFI_ACPI_6_1_S4_RTC_STS_VALID BIT16 +#define EFI_ACPI_6_1_REMOTE_POWER_ON_CAPABLE BIT17 +#define EFI_ACPI_6_1_FORCE_APIC_CLUSTER_MODEL BIT18 +#define EFI_ACPI_6_1_FORCE_APIC_PHYSICAL_DESTINATION_MODE BIT19 +#define EFI_ACPI_6_1_HW_REDUCED_ACPI BIT20 +#define EFI_ACPI_6_1_LOW_POWER_S0_IDLE_CAPABLE BIT21 + +/* + * Multiple APIC Description Table header definition. The rest of the table + * must be defined in a platform specific manner. + */ +struct efi_acpi_6_1_multiple_apic_description_table_header { + struct efi_acpi_description_header header; + u32 local_apic_address; + u32 flags; +}; + +/* + * MADT Revision (as defined in ACPI 6.1 spec.) + */ +#define EFI_ACPI_6_1_MULTIPLE_APIC_DESCRIPTION_TABLE_REVISION 0x04 + +/* + * Multiple APIC Flags + * All other bits are reserved and must be set to 0. + */ +#define EFI_ACPI_6_1_PCAT_COMPAT BIT0 + +/* + * Multiple APIC Description Table APIC structure types + * All other values between 0x0D and 0x7F are reserved and + * will be ignored by OSPM. 0x80 ~ 0xFF are reserved for OEM. + */ +#define EFI_ACPI_6_1_PROCESSOR_LOCAL_APIC 0x00 +#define EFI_ACPI_6_1_IO_APIC 0x01 +#define EFI_ACPI_6_1_INTERRUPT_SOURCE_OVERRIDE 0x02 +#define EFI_ACPI_6_1_NON_MASKABLE_INTERRUPT_SOURCE 0x03 +#define EFI_ACPI_6_1_LOCAL_APIC_NMI 0x04 +#define EFI_ACPI_6_1_LOCAL_APIC_ADDRESS_OVERRIDE 0x05 +#define EFI_ACPI_6_1_IO_SAPIC 0x06 +#define EFI_ACPI_6_1_LOCAL_SAPIC 0x07 +#define EFI_ACPI_6_1_PLATFORM_INTERRUPT_SOURCES 0x08 +#define EFI_ACPI_6_1_PROCESSOR_LOCAL_X2APIC 0x09 +#define EFI_ACPI_6_1_LOCAL_X2APIC_NMI 0x0A +#define EFI_ACPI_6_1_GIC 0x0B +#define EFI_ACPI_6_1_GICD 0x0C +#define EFI_ACPI_6_1_GIC_MSI_FRAME 0x0D +#define EFI_ACPI_6_1_GICR 0x0E +#define EFI_ACPI_6_1_GIC_ITS 0x0F + +/* + * APIC Structure Definitions + */ + +/* + * Processor Local APIC Structure Definition + */ +struct efi_acpi_6_1_processor_local_apic_structure { + u8 type; + u8 length; + u8 acpi_processor_uid; + u8 apic_id; + u32 flags; +}; + +/* + * Local APIC Flags. All other bits are reserved and must be 0. + */ +#define EFI_ACPI_6_1_LOCAL_APIC_ENABLED BIT0 + +/* + * IO APIC Structure + */ +struct efi_acpi_6_1_io_apic_structure { + u8 type; + u8 length; + u8 io_apic_id; + u8 reserved; + u32 io_apic_address; + u32 global_system_interrupt_base; +}; + +/* + * Interrupt Source Override Structure + */ +struct efi_acpi_6_1_interrupt_source_override_structure { + u8 type; + u8 length; + u8 bus; + u8 source; + u32 global_system_interrupt; + u16 flags; +}; + +/* + * Platform Interrupt Sources Structure Definition + */ +struct efi_acpi_6_1_platform_interrupt_apic_structure { + u8 type; + u8 length; + u16 flags; + u8 interrupt_type; + u8 processor_id; + u8 processor_eid; + u8 io_sapic_vector; + u32 global_system_interrupt; + u32 platform_interrupt_source_flags; + u8 cpei_processor_override; + u8 reserved[31]; +}; + +/* + * MPS INTI flags. + * All other bits are reserved and must be set to 0. + */ +#define EFI_ACPI_6_1_POLARITY (3 << 0) +#define EFI_ACPI_6_1_TRIGGER_MODE (3 << 2) + +/* + * Non-Maskable Interrupt Source Structure + */ +struct efi_acpi_6_1_non_maskable_interrupt_source_structure { + u8 type; + u8 length; + u16 flags; + u32 global_system_interrupt; +}; + +/* + * Local APIC NMI Structure + */ +struct efi_acpi_6_1_local_apic_nmi_structure { + u8 type; + u8 length; + u8 acpi_processor_uid; + u16 flags; + u8 local_apic_lint; +}; + +/* + * Local APIC Address Override Structure + */ +struct efi_acpi_6_1_local_apic_address_override_structure { + u8 type; + u8 length; + u16 reserved; + u64 local_apic_address; +}; + +/* + * IO SAPIC Structure + */ +struct efi_acpi_6_1_io_sapic_structure { + u8 type; + u8 length; + u8 io_apic_id; + u8 reserved; + u32 global_system_interrupt_base; + u64 io_sapic_address; +}; + +/* + * Local SAPIC Structure + * This struct followed by a null-terminated ASCII string - + * ACPI Processor UID String + */ +struct efi_acpi_6_1_processor_local_sapic_structure { + u8 type; + u8 length; + u8 acpi_processor_id; + u8 local_sapic_id; + u8 local_sapic_eid; + u8 reserved[3]; + u32 flags; + u32 ACPI_processor_UID_value; +}; + +/* + * Platform Interrupt Sources Structure + */ +struct efi_acpi_6_1_platform_interrupt_sources_structure { + u8 type; + u8 length; + u16 flags; + u8 interrupt_type; + u8 processor_id; + u8 processor_eid; + u8 io_sapic_vector; + u32 global_system_interrupt; + u32 platform_interrupt_source_flags; +}; + +/* + * Platform Interrupt Source Flags. + * All other bits are reserved and must be set to 0. + */ +#define EFI_ACPI_6_1_CPEI_PROCESSOR_OVERRIDE BIT0 + +/* + * Processor Local x2APIC Structure Definition + */ +struct efi_acpi_6_1_processor_local_x2apic_structure { + u8 type; + u8 length; + u8 reserved[2]; + u32 x2_apic_id; + u32 flags; + u32 acpi_processor_uid; +}; + +/* + * Local x2APIC NMI Structure + */ +struct efi_acpi_6_1_local_x2apic_nmi_structure { + u8 type; + u8 length; + u16 flags; + u32 acpi_processor_uid; + u8 local_x2_apic_lint; + u8 reserved[3]; +}; + +/* + * GIC Structure + */ +struct efi_acpi_6_1_gic_structure { + u8 type; + u8 length; + u16 reserved; + u32 CPU_interface_number; + u32 acpi_processor_uid; + u32 flags; + u32 parking_protocol_version; + u32 performance_interrupt_gsiv; + u64 parked_address; + u64 physical_base_address; + u64 GICV; + u64 GICH; + u32 VGIC_maintenance_interrupt; + u64 GICR_base_address; + u64 MPIDR; + u8 processor_power_efficiency_class; + u8 reserved2[3]; +}; + +/* + * GIC Flags. All other bits are reserved and must be 0. + */ +#define EFI_ACPI_6_1_GIC_ENABLED BIT0 +#define EFI_ACPI_6_1_PERFORMANCE_INTERRUPT_MODEL BIT1 +#define EFI_ACPI_6_1_VGIC_MAINTENANCE_INTERRUPT_MODE_FLAGS BIT2 + +/* + * GIC Distributor Structure + */ +struct efi_acpi_6_1_gic_distributor_structure { + u8 type; + u8 length; + u16 reserved1; + u32 gic_id; + u64 physical_base_address; + u32 system_vector_base; + u8 gic_version; + u8 reserved2[3]; +}; + +/* + * GIC Version + */ +#define EFI_ACPI_6_1_GIC_V1 0x01 +#define EFI_ACPI_6_1_GIC_V2 0x02 +#define EFI_ACPI_6_1_GIC_V3 0x03 +#define EFI_ACPI_6_1_GIC_V4 0x04 + +/* + * GIC MSI Frame Structure + */ +struct efi_acpi_6_1_gic_msi_frame_structure { + u8 type; + u8 length; + u16 reserved1; + u32 gic_msi_frame_id; + u64 physical_base_address; + u32 flags; + u16 SPI_count; + u16 SPI_base; +}; + +/* + * GIC MSI Frame Flags. All other bits are reserved and must be 0. + */ +#define EFI_ACPI_6_1_SPI_COUNT_BASE_SELECT BIT0 + +/* + * GICR Structure + */ +struct efi_acpi_6_1_gicr_structure { + u8 type; + u8 length; + u16 reserved; + u64 discovery_range_base_address; + u32 discovery_range_length; +}; + +/* + * GIC Interrupt Translation Service Structure + */ +struct efi_acpi_6_1_gic_its_structure { + u8 type; + u8 length; + u16 reserved; + u32 gic_its_id; + u64 physical_base_address; + u32 reserved2; +}; + +/* + * Generic Timer Description Table definition. + */ +struct efi_acpi_6_1_generic_timer_description_table { + struct efi_acpi_description_header header; + u64 cnt_control_base_physical_address; + u32 reserved; + u32 secure_pl1_timer_GSIV; + u32 secure_pl1_timer_flags; + u32 non_secure_pl1_timer_GSIV; + u32 non_secure_pl1_timer_flags; + u32 virtual_timer_GSIV; + u32 virtual_timer_flags; + u32 non_secure_pl2_timer_GSIV; + u32 non_secure_pl2_timer_flags; + u64 cnt_read_base_physical_address; + u32 platform_timer_count; + u32 platform_timer_offset; +}; + +/* + * GTDT Version (as defined in ACPI 6.1 spec.) + */ +#define EFI_ACPI_6_1_GENERIC_TIMER_DESCRIPTION_TABLE_REVISION 0x02 + +/* + * Timer Flags. All other bits are reserved and must be 0. + */ +#define EFI_ACPI_6_1_GTDT_TIMER_FLAG_TIMER_INTERRUPT_MODE BIT0 +#define EFI_ACPI_6_1_GTDT_TIMER_FLAG_TIMER_INTERRUPT_POLARITY BIT1 +#define EFI_ACPI_6_1_GTDT_TIMER_FLAG_ALWAYS_ON_CAPABILITY BIT2 + +/* + * Platform Timer Type + */ +#define EFI_ACPI_6_1_GTDT_GT_BLOCK 0 +#define EFI_ACPI_6_1_GTDT_SBSA_GENERIC_WATCHDOG 1 + +/* + * GT Block Structure + */ +struct efi_acpi_6_1_gtdt_gt_block_structure { + u8 type; + u16 length; + u8 reserved; + u64 cnt_ctl_base; + u32 GT_block_timer_count; + u32 GT_block_timer_offset; +}; + +/* + * GT Block Timer Structure + */ +struct efi_acpi_6_1_gtdt_gt_block_timer_structure { + u8 GT_frame_number; + u8 reserved[3]; + u64 cnt_base_X; + u64 cnt_el0_base_X; + u32 GT_x_physical_timer_GSIV; + u32 GT_x_physical_timer_flags; + u32 GT_x_virtual_timer_GSIV; + u32 GT_x_virtual_timer_flags; + u32 GT_x_common_flags; +}; + +/* + * GT Block Physical Timers and Virtual Timers Flags. + * All other bits are reserved and must be 0. + */ +#define EFI_ACPI_6_1_GTDT_GT_BLOCK_TIMER_FLAG_TIMER_INTERRUPT_MODE BIT0 +#define EFI_ACPI_6_1_GTDT_GT_BLOCK_TIMER_FLAG_TIMER_INTERRUPT_POLARITY BIT1 + +/* + * Common Flags Flags. All other bits are reserved and must be 0. + */ +#define EFI_ACPI_6_1_GTDT_GT_BLOCK_COMMON_FLAG_SECURE_TIMER BIT0 +#define EFI_ACPI_6_1_GTDT_GT_BLOCK_COMMON_FLAG_ALWAYS_ON_CAPABILITY BIT1 + +/* + * SBSA Generic Watchdog Structure + */ +struct efi_acpi_6_1_gtdt_sbsa_generic_watchdog_structure { + u8 type; + u16 length; + u8 reserved; + u64 refresh_frame_physical_address; + u64 watchdog_control_frame_physical_address; + u32 watchdog_timer_GSIV; + u32 watchdog_timer_flags; +}; + +/* + * SBSA Generic Watchdog Timer Flags. All other bits are reserved + * and must be 0. + */ +#define EFI_ACPI_6_1_GTDT_SBSA_GENERIC_WATCHDOG_FLAG_TIMER_INTERRUPT_MODE \ + BIT0 +#define EFI_ACPI_6_1_GTDT_SBSA_GENERIC_WATCHDOG_FLAG_TIMER_INTERRUPT_POLARITY\ + BIT1 +#define EFI_ACPI_6_1_GTDT_SBSA_GENERIC_WATCHDOG_FLAG_SECURE_TIMER \ + BIT2 + +/* + * table signatures + */ + +/* + * "RSD PTR " Root System Description Pointer + */ +#define EFI_ACPI_6_1_ROOT_SYSTEM_DESCRIPTION_POINTER_SIGNATURE \ + SIGNATURE_64('R', 'S', 'D', ' ', 'P', 'T', 'R', ' ') + +/* + * "APIC" Multiple APIC Description Table + */ +#define EFI_ACPI_6_1_MULTIPLE_APIC_DESCRIPTION_TABLE_SIGNATURE \ + SIGNATURE_32('A', 'P', 'I', 'C') + +/* + * "DSDT" Differentiated System Description Table + */ +#define EFI_ACPI_6_1_DIFFERENTIATED_SYSTEM_DESCRIPTION_TABLE_SIGNATURE \ + SIGNATURE_32('D', 'S', 'D', 'T') + +/* + * "FACP" Fixed ACPI Description Table + */ +#define EFI_ACPI_6_1_FIXED_ACPI_DESCRIPTION_TABLE_SIGNATURE \ + SIGNATURE_32('F', 'A', 'C', 'P') + +/* + * "GTDT" Generic Timer Description Table + */ +#define EFI_ACPI_6_1_GENERIC_TIMER_DESCRIPTION_TABLE_SIGNATURE \ + SIGNATURE_32('G', 'T', 'D', 'T') + +/* + * "RSDT" Root System Description Table + */ +#define EFI_ACPI_6_1_ROOT_SYSTEM_DESCRIPTION_TABLE_SIGNATURE \ + SIGNATURE_32('R', 'S', 'D', 'T') + +/* + * "SSDT" Secondary System Description Table + */ +#define EFI_ACPI_6_1_SECONDARY_SYSTEM_DESCRIPTION_TABLE_SIGNATURE \ + SIGNATURE_32('S', 'S', 'D', 'T') + +/* + * "XSDT" Extended System Description Table + */ +#define EFI_ACPI_6_1_EXTENDED_SYSTEM_DESCRIPTION_TABLE_SIGNATURE \ + SIGNATURE_32('X', 'S', 'D', 'T') + +/* + * "IORT" I/O Remapping Table + */ +#define EFI_ACPI_6_1_IO_REMAPPING_TABLE_SIGNATURE \ + SIGNATURE_32('I', 'O', 'R', 'T') + +/* + * "MCFG" PCI Express Memory Mapped + * Configuration Space Base Address Description Table + */ +#define EFI_ACPI_6_1_PCI_EXPRESS_MEMORY_MAPPED_ADDR_TABLE_SIGNATURE \ + SIGNATURE_32('M', 'C', 'F', 'G') + +/* + * "SPCR" Serial Port Concole Redirection Table + */ +#define EFI_ACPI_6_1_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_SIGNATURE \ + SIGNATURE_32('S', 'P', 'C', 'R') + +#pragma pack() + +#endif + diff --git a/arch/arm/include/asm/acpi_table/acpi_lib.h b/arch/arm/include/asm/acpi_table/acpi_lib.h new file mode 100644 index 0000000..f3404e9 --- /dev/null +++ b/arch/arm/include/asm/acpi_table/acpi_lib.h @@ -0,0 +1,89 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Based on acpi_lib.h from edk2 + * + * (C) Copyright 2019 + * Phytium Technology Ltd <www.phytium.com> + * Steven Hao liuhao@phytium.com.cn + */ + +#ifndef __ACPI_LIB_H__ +#define __ACPI_LIB_H__ + +#include <asm/acpi_table/acpi61.h> + +/* + * Macros for the Generic Address Space + */ +#define null_gas \ + { EFI_ACPI_6_1_SYSTEM_MEMORY, 0, 0, EFI_ACPI_6_1_UNDEFINED, 0L } +#define arm_gas8(address) \ + { EFI_ACPI_6_1_SYSTEM_MEMORY, 8, 0, EFI_ACPI_6_1_BYTE, address } +#define arm_gas16(address) \ + { EFI_ACPI_6_1_SYSTEM_MEMORY, 16, 0, EFI_ACPI_6_1_WORD, address } +#define arm_gas32(address) \ + { EFI_ACPI_6_1_SYSTEM_MEMORY, 32, 0, EFI_ACPI_6_1_DWORD, address } +#define arm_gasn(address) \ + { EFI_ACPI_6_1_SYSTEM_MEMORY, 0, 0, EFI_ACPI_6_1_DWORD, address } + +#define efi_acpi_6_1_gic_its_init(gic_its_hw_id, gic_its_base) {\ + EFI_ACPI_6_1_GIC_ITS,\ + sizeof(struct efi_acpi_6_1_gic_its_structure),\ + EFI_ACPI_RESERVED_WORD,\ + gic_its_hw_id, gic_its_base, EFI_ACPI_RESERVED_DWORD\ +} + +#define efi_acpi_6_1_gicc_affinity_structure_init(\ + proximity_domain, ACPI_processor_UID, flags, clock_domain) {\ + 3, sizeof(struct efi_acpi_6_1_gicc_affinity_structure),\ + proximity_domain,\ + ACPI_processor_UID, flags, clock_domain\ +} + +#define efi_acpi_6_1_processor_affinity_structure_init(\ + proximity_domain, apic_id, flags, clock_domain) {\ + 0,\ +sizeof(struct efi_acpi_6_1_processor_local_apic_sapic_affinity_structure),\ + proximity_domain, apic_id, flags, 0x00, {0, 0, 0}, clock_domain\ +} + +#define efi_acpi_6_1_memory_affinity_structure_init(\ + proximity_domain, address_base_low, address_base_high,\ + length_low, length_high, flags) {\ + 1, sizeof(struct efi_acpi_6_1_memory_affinity_structure),\ + proximity_domain, EFI_ACPI_RESERVED_WORD,\ + address_base_low, address_base_high, length_low, length_high,\ + EFI_ACPI_RESERVED_DWORD, flags,\ + EFI_ACPI_RESERVED_QWORD\ +} + +#define efi_acpi_6_1_gicc_structure_init(\ + gic_id, acpi_cpu_uid, mpidr, flags, pmu_irq,\ + gic_base, gicV_base, gicH_base, gsiv_id, gicR_base,\ + processor_power_efficiency_class) { \ + EFI_ACPI_6_1_GIC, sizeof(struct efi_acpi_6_1_gic_structure),\ + 0x0000, gic_id, acpi_cpu_uid, \ + flags, 0, pmu_irq, 0, gic_base, gicV_base, gicH_base,\ + gsiv_id, gicR_base, mpidr, processor_power_efficiency_class,\ + { \ + 0,\ + 0,\ + 0\ + } \ +} + +#define efi_acpi_6_1_gic_distributor_init(\ + gic_dist_hw_id, gic_dist_base, gic_dist_vector, gic_version) {\ + EFI_ACPI_6_1_GICD,\ + sizeof(struct efi_acpi_6_1_gic_distributor_structure),\ + EFI_ACPI_RESERVED_WORD,\ + gic_dist_hw_id, gic_dist_base, gic_dist_vector, gic_version,\ + { \ + EFI_ACPI_RESERVED_BYTE,\ + EFI_ACPI_RESERVED_BYTE,\ + EFI_ACPI_RESERVED_BYTE\ + } \ +} + +#endif + diff --git a/arch/arm/include/asm/acpi_table/arm_platform.h b/arch/arm/include/asm/acpi_table/arm_platform.h new file mode 100644 index 0000000..8009daf --- /dev/null +++ b/arch/arm/include/asm/acpi_table/arm_platform.h @@ -0,0 +1,93 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Based on arm_platform.h from edk2 + * + * (C) Copyright 2019 + * Phytium Technology Ltd <www.phytium.com> + * Steven Hao liuhao@phytium.com.cn + */ + +#ifndef __ARM_PLATFORM_H__ +#define __ARM_PLATFORM_H__ + +/* + * ACPI table information used to initialize tables. + */ +typedef unsigned long long u64; +typedef unsigned int u32; +typedef unsigned short u16; +typedef unsigned char u8; + +#define BIT0 0x00000001 +#define BIT1 0x00000002 +#define BIT2 0x00000004 +#define BIT3 0x00000008 +#define BIT4 0x00000010 +#define BIT5 0x00000020 +#define BIT6 0x00000040 +#define BIT7 0x00000080 +#define BIT8 0x00000100 +#define BIT9 0x00000200 +#define BIT10 0x00000400 +#define BIT11 0x00000800 +#define BIT12 0x00001000 +#define BIT13 0x00002000 +#define BIT14 0x00004000 +#define BIT15 0x00008000 +#define BIT16 0x00010000 +#define BIT17 0x00020000 +#define BIT18 0x00040000 +#define BIT19 0x00080000 +#define BIT20 0x00100000 +#define BIT21 0x00200000 +#define BIT22 0x00400000 +#define BIT23 0x00800000 +#define BIT24 0x01000000 +#define BIT25 0x02000000 +#define BIT26 0x04000000 +#define BIT27 0x08000000 +#define BIT28 0x10000000 +#define BIT29 0x20000000 +#define BIT30 0x40000000 +#define BIT31 0x80000000 +#define BIT32 0x0000000100000000ULL +#define BIT33 0x0000000200000000ULL +#define BIT34 0x0000000400000000ULL +#define BIT35 0x0000000800000000ULL +#define BIT36 0x0000001000000000ULL +#define BIT37 0x0000002000000000ULL +#define BIT38 0x0000004000000000ULL +#define BIT39 0x0000008000000000ULL +#define BIT40 0x0000010000000000ULL +#define BIT41 0x0000020000000000ULL +#define BIT42 0x0000040000000000ULL +#define BIT43 0x0000080000000000ULL +#define BIT44 0x0000100000000000ULL +#define BIT45 0x0000200000000000ULL +#define BIT46 0x0000400000000000ULL +#define BIT47 0x0000800000000000ULL +#define BIT48 0x0001000000000000ULL +#define BIT49 0x0002000000000000ULL +#define BIT50 0x0004000000000000ULL +#define BIT51 0x0008000000000000ULL +#define BIT52 0x0010000000000000ULL +#define BIT53 0x0020000000000000ULL +#define BIT54 0x0040000000000000ULL +#define BIT55 0x0080000000000000ULL +#define BIT56 0x0100000000000000ULL +#define BIT57 0x0200000000000000ULL +#define BIT58 0x0400000000000000ULL +#define BIT59 0x0800000000000000ULL +#define BIT60 0x1000000000000000ULL +#define BIT61 0x2000000000000000ULL +#define BIT62 0x4000000000000000ULL +#define BIT63 0x8000000000000000ULL + +#define SIGNATURE_16(A, B) ((A) | ((B) << 8)) +#define SIGNATURE_32(A, B, C, D) \ + (SIGNATURE_16(A, B) | (SIGNATURE_16(C, D) << 16)) +#define SIGNATURE_64(A, B, C, D, E, F, G, H) \ + (SIGNATURE_32(A, B, C, D) | ((u64)(SIGNATURE_32(E, F, G, H)) << 32)) + +#endif + diff --git a/arch/arm/include/asm/acpi_table/io_remapping_table.h b/arch/arm/include/asm/acpi_table/io_remapping_table.h new file mode 100644 index 0000000..9899cfe --- /dev/null +++ b/arch/arm/include/asm/acpi_table/io_remapping_table.h @@ -0,0 +1,179 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Based on io_remapping_table.h from edk2 + * + * (C) Copyright 2019 + * Phytium Technology Ltd <www.phytium.com> + * Steven Hao liuhao@phytium.com.cn + */ + +#ifndef __IO_REMAPPING_TABLE_H__ +#define __IO_REMAPPING_TABLE_H__ + +#include <asm/acpi_table/acpi61.h> + +#define EFI_ACPI_IO_REMAPPING_TABLE_REVISION 0x0 + +#define EFI_ACPI_IORT_TYPE_ITS_GROUP 0x0 +#define EFI_ACPI_IORT_TYPE_NAMED_COMP 0x1 +#define EFI_ACPI_IORT_TYPE_ROOT_COMPLEX 0x2 +#define EFI_ACPI_IORT_TYPE_SMMUV1V2 0x3 +#define EFI_ACPI_IORT_TYPE_SMMUV3 0x4 +#define EFI_ACPI_IORT_TYPE_PMCG 0x5 + +#define EFI_ACPI_IORT_MEM_ACCESS_PROP_CCA BIT0 + +#define EFI_ACPI_IORT_MEM_ACCESS_PROP_AH_TR BIT0 +#define EFI_ACPI_IORT_MEM_ACCESS_PROP_AH_WA BIT1 +#define EFI_ACPI_IORT_MEM_ACCESS_PROP_AH_RA BIT2 +#define EFI_ACPI_IORT_MEM_ACCESS_PROP_AH_AHO BIT3 + +#define EFI_ACPI_IORT_MEM_ACCESS_FLAGS_CPM BIT0 +#define EFI_ACPI_IORT_MEM_ACCESS_FLAGS_DACS BIT1 + +#define EFI_ACPI_IORT_SMMUV1V2_MODEL_V1 0x0 +#define EFI_ACPI_IORT_SMMUV1V2_MODEL_V2 0x1 +#define EFI_ACPI_IORT_SMMUV1V2_MODEL_MMU400 0x2 +#define EFI_ACPI_IORT_SMMUV1V2_MODEL_MMU500 0x3 +#define EFI_ACPI_IORT_SMMUV1V2_MODEL_MMU401 0x4 +#define EFI_ACPI_IORT_SMMUV1V2_MODEL_CAVIUM_THX_V2 0x5 + +#define EFI_ACPI_IORT_SMMUV1V2_FLAG_DVM BIT0 +#define EFI_ACPI_IORT_SMMUV1V2_FLAG_COH_WALK BIT1 + +#define EFI_ACPI_IORT_SMMUV1V2_INT_FLAG_LEVEL 0x0 +#define EFI_ACPI_IORT_SMMUV1V2_INT_FLAG_EDGE 0x1 + +#define EFI_ACPI_IORT_SMMUV3_FLAG_COHAC_OVERRIDE BIT0 +#define EFI_ACPI_IORT_SMMUV3_FLAG_HTTU_OVERRIDE BIT1 + +#define EFI_ACPI_IORT_ROOT_COMPLEX_ATS_UNSUPPORTED 0x0 +#define EFI_ACPI_IORT_ROOT_COMPLEX_ATS_SUPPORTED 0x1 + +#define EFI_ACPI_IORT_ID_MAPPING_FLAGS_SINGLE BIT0 + +#pragma pack(1) + +/* + * Table header + */ +struct efi_acpi_6_0_io_remapping_table { + struct efi_acpi_description_header header; + u32 num_nodes; + u32 node_offset; + u32 reserved; +}; + +/* + * Definition for ID mapping table shared by all node types + */ +struct efi_acpi_6_0_io_remapping_id_table { + u32 input_base; + u32 num_ids; + u32 output_base; + u32 output_reference; + u32 flags; +}; + +/* + * Node header definition shared by all node types + */ +struct efi_acpi_6_0_io_remapping_node { + u8 type; + u16 length; + u8 revision; + u32 reserved; + u32 num_id_mappings; + u32 id_reference; +}; + +/* + * Node type 0: ITS node + */ +struct efi_acpi_6_0_io_remapping_its_node { + struct efi_acpi_6_0_io_remapping_node node; + u32 num_its_identifiers; +}; + +/* + * Node type 1: root complex node + */ +struct efi_acpi_6_0_io_remapping_rc_node { + struct efi_acpi_6_0_io_remapping_node node; + u32 cache_coherent; + u8 allocation_hints; + u16 reserved; + u8 memory_access_flags; + u32 ats_attribute; + u32 pci_segment_number; +}; + +/* + * Node type 2: named component node + */ +struct efi_acpi_6_0_io_remapping_named_comp_node { + struct efi_acpi_6_0_io_remapping_node node; + u32 flags; + u32 cache_coherent; + u8 allocation_hints; + u16 reserved; + u8 memory_access_flags; + u8 address_size_limit; +}; + +/* + * Node type 3: SMMUv1 or SMMUv2 node + */ +struct efi_acpi_6_0_io_remapping_smmu_int { + u32 interrupt; + u32 interrupt_flags; +}; + +struct efi_acpi_6_0_io_remapping_smmu_node { + struct efi_acpi_6_0_io_remapping_node node; + u64 base; + u64 span; + u32 model; + u32 flags; + u32 global_interrupt_array_ref; + u32 num_context_interrupts; + u32 context_interrupt_array_ref; + u32 num_pmu_interrupts; + u32 pmu_interrupta_array_ref; + + u32 smmu_nsg_irpt; + u32 smmu_nsg_irpt_flags; + u32 smmu_nsg_cfg_irpt; + u32 smmu_nsg_cfg_irpt_flags; +}; + +/* + * Node type 4: SMMUv4 node + */ +struct efi_acpi_6_0_io_remapping_smmu3_node { + struct efi_acpi_6_0_io_remapping_node node; + u64 base; + u32 flags; + u32 reserved; + u64 vatos_address; + u32 model; + u32 event; + u32 pri; + u32 gerr; + u32 sync; +}; + +/* + * Node type 5: PMCG node + */ +struct efi_acpi_6_0_io_remapping_pmcg_node { + struct efi_acpi_6_0_io_remapping_node node; + u64 base; + u32 overflow_interrupt_gsiv; + u32 node_reference; +}; + +#pragma pack() + +#endif + diff --git a/arch/arm/include/asm/acpi_table/spcr_table.h b/arch/arm/include/asm/acpi_table/spcr_table.h new file mode 100644 index 0000000..eac5f15 --- /dev/null +++ b/arch/arm/include/asm/acpi_table/spcr_table.h @@ -0,0 +1,175 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Based on serial_port_console_redirection.h from edk2 + * + * (C) Copyright 2019 + * Phytium Technology Ltd <www.phytium.com> + * Steven Hao liuhao@phytium.com.cn + */ + +#ifndef _SPCR_TABLE_H_ +#define _SPCR_TABLE_H_ + +#include <asm/acpi_table/acpi61.h> + +/* + * Ensure proper structure formats + */ +#pragma pack(1) + +/* + * SPCR Revision (defined in spec) + */ +#define EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_REVISION 0x02 + +/* + * Serial Port Console Redirection Table Format + */ +struct efi_acpi_serial_port_console_redirection_table { + struct efi_acpi_description_header header; + u8 interface_type; + u8 reserved1[3]; + struct efi_acpi_6_1_generic_address_structure base_address; + u8 interrupt_type; + u8 irq; + u32 global_system_interrupt; + u8 baud_rate; + u8 parity; + u8 stop_bits; + u8 flow_control; + u8 terminal_type; + u8 reserved2; + u16 pci_device_id; + u16 pci_vendor_id; + u8 pci_bus_number; + u8 pci_device_number; + u8 pci_function_number; + u32 pci_flags; + u8 pci_segment; + u32 reserved3; +}; + +#pragma pack() + +/* + * SPCR Definitions + */ + +/* + * Interface Type + */ + +/* + * Full 16550 interface + */ +#define EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_INTERFACE_TYPE_16550\ + 0 +/* + * Full 16450 interface + */ +#define EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_INTERFACE_TYPE_16450\ + 1 + +/* + * The Serial Port Subtypes for ARM are documented in Table 3 of + * the DBG2 Specification + */ + +/* + * ARM PL011 UART + */ +#define \ +EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_INTERFACE_TYPE_ARM_PL011_UART\ + 0x03 + +/* + * ARM SBSA Generic UART (2.x) supporting 32-bit only accesses [deprecated] + */ +#define EFI_ACPI_SERIAL_TABLE_INTERFACE_TYPE_ARM_SBSA_UART_2X 0x0d + +/* + * ARM SBSA Generic UART + */ +#define EFI_ACPI_SERIAL_TABLE_INTERFACE_TYPE_ARM_SBSA_UART 0x0e + +/* + * Interrupt Type + */ + +/* + * PC-AT-compatible dual-8259 IRQ interrupt + */ +#define EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_INTERRUPT_TYPE_8259\ + 0x1 +/* + * I/O APIC interrupt (Global System Interrupt) + */ +#define EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_INTERRUPT_TYPE_APIC\ + 0x2 +/* + * I/O SAPIC interrupt (Global System Interrupt) + */ +#define EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_INTERRUPT_TYPE_SAPIC\ + 0x4 +/* + * ARMH GIC interrupt (Global System Interrupt) + */ +#define EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_INTERRUPT_TYPE_GIC\ + 0x8 + +/* + * Baud Rate + */ +#define EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_BAUD_RATE_9600 3 +#define EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_BAUD_RATE_19200 4 +#define EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_BAUD_RATE_57600 6 +#define EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_BAUD_RATE_115200 7 + +/* + * Parity + */ +#define EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_PARITY_NO_PARITY 0 + +/* + * Stop Bits + */ +#define EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_STOP_BITS_1 1 + +/* + * Flow Control + */ + +/* + * DCD required for transmit + */ +#define EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_FLOW_CONTROL_DCD\ + 0x1 +/* + * RTS/CTS hardware flow control + */ +#define EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_FLOW_CONTROL_RTS_CTS\ + 0x2 +/* + * XON/XOFF software control + */ +#define EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_FLOW_CONTROL_XON_XOFF\ + 0x4 + +/* + * Terminal Type + */ +#define \ +EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_TERMINAL_TYPE_VT100\ + 0 +#define \ +EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_TERMINAL_TYPE_VT100_PLUS\ + 1 +#define \ +EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_TERMINAL_TYPE_VT_UTF8\ + 2 +#define \ +EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_TERMINAL_TYPE_ANSI\ + 3 + +#endif + diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index 9de9a9a..39bb105 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -28,6 +28,7 @@ else obj-y += relocate.o endif
+obj-$(CONFIG_ARM_ACPI_TABLE) += acpi_table.o obj-$(CONFIG_CPU_V7M) += cmd_boot.o obj-$(CONFIG_OF_LIBFDT) += bootm-fdt.o obj-$(CONFIG_CMD_BOOTI) += bootm.o image.o diff --git a/arch/arm/lib/acpi_table.c b/arch/arm/lib/acpi_table.c new file mode 100644 index 0000000..9401955 --- /dev/null +++ b/arch/arm/lib/acpi_table.c @@ -0,0 +1,244 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Based on acpi.c from coreboot + * + * Copyright (C) 2019 + * Steven Hao liuhao@phytium.com.cn + */ + +#include <common.h> +#include <cpu.h> +#include <dm.h> +#include <dm/uclass-internal.h> +#include <serial.h> +#include <version.h> +#include <tables_csum.h> +#include <asm/acpi_table.h> +#include <asm/acpi_table/acpi61.h> +#include <asm/acpi_table/spcr_table.h> +#include <asm/acpi_table/acpi_lib.h> +#include <asm/acpi_table/arm_platform.h> +#include <asm/acpi_table/io_remapping_table.h> + +/* record the acpi_table data and count */ +__weak void register_acpi_table_data(void) {} + +static void acpi_write_rsdp + (struct efi_acpi_6_1_root_system_description_pointer *rsdp, + struct efi_acpi_6_1_root_system_description_table *rsdt, + struct efi_acpi_6_1_extended_system_description_table *xsdt) +{ + u16 rsdp_size = + sizeof(struct efi_acpi_6_1_root_system_description_pointer); + memcpy(rsdp, rsdp_data, rsdp_size); + rsdp->rsdt_address = (u32)(uintptr_t)rsdt; + rsdp->xsdt_address = (u64)(u32)(uintptr_t)xsdt; + + /* Calculate checksums */ + rsdp->checksum = 0; + rsdp->extended_checksum = 0; + rsdp->checksum = table_compute_checksum((void *)rsdp, 20); + rsdp->extended_checksum = + table_compute_checksum((void *)rsdp, rsdp_size); +} + +static void +acpi_write_rsdt(struct efi_acpi_6_1_root_system_description_table *rsdt) +{ + memcpy(rsdt, rsdt_data, sizeof(struct efi_acpi_description_header)); +} + +static void +acpi_write_xsdt(struct efi_acpi_6_1_extended_system_description_table *xsdt) +{ + memcpy(xsdt, xsdt_data, sizeof(struct efi_acpi_description_header)); +} + +/* + * Add an ACPI table to the RSDT (and XSDT) structure, recalculate length + * and checksum. + */ +static void acpi_add_table + (struct efi_acpi_6_1_root_system_description_pointer *rsdp, + void *table) +{ + int i, entries_num; + struct efi_acpi_6_1_root_system_description_table *rsdt; + struct efi_acpi_6_1_extended_system_description_table *xsdt = NULL; + + /* The RSDT is mandatory while the XSDT is not */ + rsdt = (struct efi_acpi_6_1_root_system_description_table *) + (uintptr_t)rsdp->rsdt_address; + + if (rsdp->xsdt_address) { + xsdt = + (struct efi_acpi_6_1_extended_system_description_table *) + (uintptr_t)((u32)rsdp->xsdt_address); + } + /* This should always be MAX_ACPI_TABLES */ + entries_num = ARRAY_SIZE(rsdt->entry); + + for (i = 0; i < entries_num; i++) { + if (rsdt->entry[i] == 0) + break; + } + + if (i >= entries_num) { + debug("ACPI: Error: too many tables\n"); + return; + } + + /* Add table to the RSDT */ + rsdt->entry[i] = (u32)(uintptr_t)table; + + /* Fix RSDT length or the kernel will assume invalid entries */ + rsdt->header.length = sizeof(struct efi_acpi_description_header) + + (sizeof(u32) * (i + 1)); + + /* Re-calculate checksum */ + rsdt->header.checksum = 0; + rsdt->header.checksum = + table_compute_checksum((u8 *)rsdt, rsdt->header.length); + + /* + * And now the same thing for the XSDT. We use the same index as for + * now we want the XSDT and RSDT to always be in sync in U-Boot + */ + if (xsdt) { + /* Add table to the XSDT */ + xsdt->entry[i] = (u64)(u32)(uintptr_t)table; + + /* Fix XSDT length */ + xsdt->header.length = + sizeof(struct efi_acpi_description_header) + + (sizeof(u64) * (i + 1)); + + /* Re-calculate checksum */ + xsdt->header.checksum = 0; + xsdt->header.checksum = + table_compute_checksum((u8 *)xsdt, xsdt->header.length); + } +} + +__weak void dynamic_modify_fadt_table(void *table) {} +__weak void dynamic_modify_gtdt_table(void *table) {} +__weak void dynamic_modify_madt_table(void *table) {} +__weak void dynamic_modify_mcfg_table(void *table) {} +__weak void dynamic_modify_spcr_table(void *table) {} +__weak void dynamic_modify_iort_table(void *table) {} + +ulong write_acpi_tables(ulong start) +{ + u32 current; + u8 i; + ulong dsdt_address = 0xFFFFFFFF; + u16 head_size = + sizeof(struct efi_acpi_description_header); + + struct efi_acpi_description_header *p_head; + struct efi_acpi_6_1_root_system_description_pointer *ft_rsdp; + struct efi_acpi_6_1_root_system_description_table *ft_rsdt; + struct efi_acpi_6_1_extended_system_description_table *ft_xsdt; + struct efi_acpi_6_1_fixed_acpi_description_table *ft_fadt; + + current = start; + + debug("ACPI: Writing ACPI tables at %lx\n", start); + /* We need at least an RSDP and an RSDT Table */ + ft_rsdp = (struct efi_acpi_6_1_root_system_description_pointer *) + (uintptr_t)current; + current += + sizeof(struct efi_acpi_6_1_root_system_description_pointer); + ft_rsdt = (struct efi_acpi_6_1_root_system_description_table *) + (uintptr_t)current; + current += + sizeof(struct efi_acpi_6_1_root_system_description_table); + ft_xsdt = (struct efi_acpi_6_1_extended_system_description_table *) + (uintptr_t)current; + current += + sizeof(struct efi_acpi_6_1_extended_system_description_table); + + /* clear all table memory */ + memset((void *)start, 0, current - start); + + acpi_write_rsdp(ft_rsdp, ft_rsdt, ft_xsdt); + acpi_write_rsdt(ft_rsdt); + acpi_write_xsdt(ft_xsdt); + + register_acpi_table_data(); + if (acpi_table_count) { + for (i = 0; i < acpi_table_count; i++) { + debug("ACPI: * table\n"); + p_head = (struct efi_acpi_description_header *) + (uintptr_t)current; + memcpy(p_head, array_acpi_table_address[i], head_size); + current += sizeof(struct efi_acpi_description_header); + memcpy((char *)(uintptr_t)current, + (char *)array_acpi_table_address[i] + + sizeof(struct efi_acpi_description_header), + p_head->length - + sizeof(struct efi_acpi_description_header)); + current += p_head->length - + sizeof(struct efi_acpi_description_header); + + /* only dsdt not add to rsdp,it is connect to fadt */ + /* is not dsdt table */ + if (p_head->signature != + SIGNATURE_32('D', 'S', 'D', 'T')) { + acpi_add_table(ft_rsdp, p_head); + } else { + debug("this is dsdt table\n"); + dsdt_address = (ulong)(uintptr_t)p_head; + } + + /* fadt table need to add dsdt table */ + /* is fadt table */ + if (p_head->signature == + SIGNATURE_32('F', 'A', 'C', 'P')) { + debug("this is fadt table\n"); + dynamic_modify_fadt_table(p_head); + ft_fadt = + (struct efi_acpi_6_1_fixed_acpi_description_table *) + p_head; + ft_fadt->x_dsdt = (u64)dsdt_address; + } + + /* dynamic modify the tables */ + switch (p_head->signature) { + /* gtdt */ + case SIGNATURE_32('G', 'T', 'D', 'T'): + dynamic_modify_gtdt_table(p_head); + break; + /* mcfg*/ + case SIGNATURE_32('M', 'C', 'F', 'G'): + dynamic_modify_mcfg_table(p_head); + break; + /* madt*/ + case SIGNATURE_32('A', 'P', 'I', 'C'): + dynamic_modify_madt_table(p_head); + break; + /* iort*/ + case SIGNATURE_32('F', 'A', 'C', 'P'): + dynamic_modify_iort_table(p_head); + break; + /* spcr*/ + case SIGNATURE_32('S', 'P', 'C', 'R'): + dynamic_modify_spcr_table(p_head); + break; + default: + break; + } + + /* add checksum for table */ + p_head->checksum = 0; + p_head->checksum = + table_compute_checksum((void *)p_head, p_head->length); + } + } + + debug("current = %x\n", current); + debug("ACPI: done\n"); + + return current; +} + diff --git a/board/phytium/durian/Makefile b/board/phytium/durian/Makefile index c2fbf19..e673b67 100644 --- a/board/phytium/durian/Makefile +++ b/board/phytium/durian/Makefile @@ -7,3 +7,21 @@
obj-y += durian.o
+ifdef CONFIG_ARM_ACPI_TABLE + obj-y +=acpi_table.o + +obj-$(CONFIG_DSDT_TABLE) += acpi_table/dsdt.o +obj-$(CONFIG_SSDT_TABLE) += acpi_table/ssdt.o + +obj-y += acpi_table/rsdp.o +obj-y += acpi_table/rsdt.o +obj-y += acpi_table/xsdt.o +obj-$(CONFIG_FADT_TABLE) += acpi_table/fadt.o +obj-$(CONFIG_MADT_TABLE) += acpi_table/madt.o +obj-$(CONFIG_MCFG_TABLE) += acpi_table/mcfg.o +obj-$(CONFIG_GTDT_TABLE) += acpi_table/gtdt.o +obj-$(CONFIG_IORT_TABLE) += acpi_table/iort.o +obj-$(CONFIG_SPCR_TABLE) += acpi_table/spcr.o +obj-$(CONFIG_SRAT_TABLE) += acpi_table/srat.o +obj-$(CONFIG_SLIT_TABLE) += acpi_table/slit.o +endif diff --git a/board/phytium/durian/acpi_platform.h b/board/phytium/durian/acpi_platform.h new file mode 100644 index 0000000..bff7fb9 --- /dev/null +++ b/board/phytium/durian/acpi_platform.h @@ -0,0 +1,38 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Based on acpi61.h from edk2 + * + * (C) Copyright 2019 + * Phytium Technology Ltd <www.phytium.com> + * Steven Hao liuhao@phytium.com.cn + */ + +#ifndef __ARM_PHYT_BOARD_H__ +#define __ARM_PHYT_BOARD_H__ +/* + * ACPI table information used to initialize tables. + */ +#define EFI_ACPI_ARM_OEM_ID { 'A', 'R', 'M', 'L', 'T', 'D' } +#define EFI_ACPI_ARM_OEM_TABLE_ID \ + SIGNATURE_64('A', 'R', 'M', '-', 'P', 'H', 'Y', 'T') +#define EFI_ACPI_ARM_OEM_REVISION 0x20180509 +#define EFI_ACPI_ARM_CREATOR_ID SIGNATURE_32('A', 'R', 'M', ' ') +#define EFI_ACPI_ARM_CREATOR_REVISION 0x00000099 + +/* + * A macro to initialise the common header part of EFI ACPI tables + * as defined by EFI_ACPI_DESCRIPTION_HEADER structure. + */ +#define arm_acpi_header(signature, type, revision) { \ + signature, /* u32 signature */ \ + sizeof(type), /* u32 length */ \ + revision, /* u8 revision */ \ + 0, /* u8 checksum */ \ + EFI_ACPI_ARM_OEM_ID, /* u8 oem_id[6] */ \ + EFI_ACPI_ARM_OEM_TABLE_ID, /* u64 oem_table_id */ \ + EFI_ACPI_ARM_OEM_REVISION, /* u32 oem_revision */ \ + EFI_ACPI_ARM_CREATOR_ID, /* u32 creator_id */ \ + EFI_ACPI_ARM_CREATOR_REVISION /* u32 creator_revision */ \ +} +#endif + diff --git a/board/phytium/durian/acpi_table.c b/board/phytium/durian/acpi_table.c new file mode 100644 index 0000000..5897f87 --- /dev/null +++ b/board/phytium/durian/acpi_table.c @@ -0,0 +1,53 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019, PHYTIUM bmeng.cn@gmail.com + * Steven Hao liuhao@phytium.com.cn + */ + +#include <common.h> +#include <asm/acpi_table.h> + +unsigned char *array_acpi_table_address[32]; +unsigned char acpi_table_count; + +/* record the acpi_table data and count */ +void register_acpi_table_data(void) +{ + acpi_table_count = 0; + + #ifdef CONFIG_DSDT_TABLE + array_acpi_table_address[acpi_table_count] = + (unsigned char *)&DsdtAmlCode; + acpi_table_count++; + #endif + #ifdef CONFIG_FADT_TABLE + array_acpi_table_address[acpi_table_count] = fadt_data; + acpi_table_count++; + #endif + #ifdef CONFIG_SSDT_TABLE + array_acpi_table_address[acpi_table_count] = + (unsigned char *)&SsdtAmlCode; + acpi_table_count++; + #endif + #ifdef CONFIG_MADT_TABLE + array_acpi_table_address[acpi_table_count] = madt_data; + acpi_table_count++; + #endif + #ifdef CONFIG_GTDT_TABLE + array_acpi_table_address[acpi_table_count] = gtdt_data; + acpi_table_count++; + #endif + #ifdef CONFIG_MCFG_TABLE + array_acpi_table_address[acpi_table_count] = mcfg_data; + acpi_table_count++; + #endif + #ifdef CONFIG_SPCR_TABLE + array_acpi_table_address[acpi_table_count] = spcr_data; + acpi_table_count++; + #endif + #ifdef CONFIG_IORT_TABLE + array_acpi_table_address[acpi_table_count] = iort_data; + acpi_table_count++; + #endif +} + diff --git a/board/phytium/durian/acpi_table/dsdt.asl b/board/phytium/durian/acpi_table/dsdt.asl new file mode 100644 index 0000000..f789524 --- /dev/null +++ b/board/phytium/durian/acpi_table/dsdt.asl @@ -0,0 +1,305 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2019 + * Steven Hao liuhao@phytium.com.cn + */ + +DefinitionBlock("dsdt.aml", "DSDT", 2, "U-BOOT", "U-BOOTBL", 0x00010000){ + Scope(_SB) { + Method (_OSC, 4, Serialized) { + CreateDWordField (Arg3, 0x00, STS0) + CreateDWordField (Arg3, 0x04, CAP0) + If (Arg0 == ToUUID ("0811b06e-4a27-44f9-8d60-3cbbc22e7b48")) { + DBGC(2, "_OSC OSPM Arg1:", Arg1) + DBGC(2, "CAP0:", CAP0) + DBGC(2, "STS0:", STS0) + If (!(Arg1 == One)) { + STS0 &= ~0x1F + STS0 |= 0x0A + } Else { + If ((CAP0 & 0x100)) { + CAP0 &= ~0x100 + STS0 &= ~0x1F + STS0 |= 0x12 + } + } + } Else { + STS0 &= ~0x1F + STS0 |= 0x06 + } + Return (Arg3) + } + + Device (CLU0) { /* Cluster0 state */ + Name(_HID, "ACPI0010") + Name(_UID, 1) + + Device(CPU0) { /* Cluster 0, Cpu 0 */ + Name(_HID, "ACPI0007") + Name(_UID, 0) + Name (_DSD, Package () { + ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), + Package () { + Package () {"clock-name","c0"}, + Package () {"clock-domain",0}, + } + }) + } + + Device(CPU1) { /* Cluster 0, Cpu 1 */ + Name(_HID, "ACPI0007") + Name(_UID, 1) + Name (_DSD, Package () { + ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), + Package () { + Package () {"clock-name","c0"}, + Package () {"clock-domain",0}, + } + }) + } + } + + Device (CLU1) { /* Cluster1 state */ + Name(_HID, "ACPI0010") + Name(_UID, 2) + + Device(CPU2) { /* Cluster 0, Cpu 2 */ + Name(_HID, "ACPI0007") + Name(_UID, 2) + Name (_DSD, Package () { + ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), + Package () { + Package () {"clock-name","c1"}, + Package () {"clock-domain",1}, + } + }) + } + + Device(CPU3) { /* Cluster 0, Cpu 3 */ + Name(_HID, "ACPI0007") + Name(_UID, 3) + Name (_DSD, Package () { + ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), + Package () { + Package () {"clock-name","c1"}, + Package () {"clock-domain",1}, + } + }) + } + } + + /* UART 1 */ + Device(UAR1) { + Name(_HID, "ARMH0011") + Name(_UID, 1) + Name(_CRS, ResourceTemplate() { + Memory32Fixed(ReadWrite, 0x28001000, 0x1000) + Interrupt(ResourceConsumer, Level, ActiveHigh, Exclusive) {39} + }) + } + + Device(KBC) { + Name(_HID, "KBCI8042") + Name(_UID, 0) + Name(_CRS, ResourceTemplate() { + Memory32Fixed(ReadWrite, 0x20000000, 0x100) + Interrupt(ResourceConsumer, Level, ActiveHigh, Exclusive) {37} + }) + } + + Device (ETH0) { + Name (_HID, "FTGM0001") + Name (_UID, 0) + Name (_CRS, ResourceTemplate () { + Memory32Fixed (ReadWrite, 0x2820c000, 0x2000) + Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) {81} + }) + Name (_DSD, Package () { + ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), + Package () { + Package () {"interrupt-names", "macirq"}, + Package () {"clocks", 3}, + Package () {"clock-names", "stmmaceth"}, + Package () {"snps,pbl", 0x10}, + Package () {"snps,abl", 0x20}, + Package () {"snps,burst_len", 0x0e}, + Package () {"snps,multicast-filter-bins", 0x40}, + Package () {"snps,perfect-filter-entries", 0x41}, + Package () {"max-frame-size", 0x2328}, + Package () {"phy-mode", "rgmii"}, + Package () {"clock-frequency",250000000}, + Package () {"bus_id",0}, + Package () {"txc-skew-ps", 0x3e8}, + Package () {"rxc-skew-ps", 0x3e8}, + } + }) + } + + Device (ETH1) { + Name (_HID, "FTGM0001") + Name (_UID, 1) + Name (_CRS, ResourceTemplate () { + Memory32Fixed (ReadWrite, 0x28210000, 0x2000) + Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) {82} + }) + Name (_DSD, Package () { + ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), + Package () { + Package () {"interrupt-names", "macirq"}, + Package () {"clocks", 3}, + Package () {"clock-names", "stmmaceth"}, + Package () {"snps,pbl", 0x10}, + Package () {"snps,abl", 0x20}, + Package () {"snps,burst_len", 0x0e}, + Package () {"snps,multicast-filter-bins", 0x40}, + Package () {"snps,perfect-filter-entries", 0x41}, + Package () {"max-frame-size", 0x2328}, + Package () {"phy-mode", "rgmii"}, + Package () {"clock-frequency",250000000}, + Package () {"bus_id",1}, + Package () {"txc-skew-ps", 0x3e8}, + Package () {"rxc-skew-ps", 0x3e8}, + } + }) + } + + Device(GPI0) { + Name(_HID, "FTGP0001") //FTGPIO01 + Name(_ADR, 0) + Name(_UID, 0) + Name (_CRS, ResourceTemplate () { + Memory32Fixed (ReadWrite, 0x28004000, 0x1000) + Interrupt(ResourceConsumer, Level, ActiveHigh, Exclusive) {42} + }) + + Device(GP00) { + Name(_HID, "FTGP0001") //FTGPIO01 + Name(_ADR, 0) + Name (_DSD, Package () { + ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), + Package () { + Package () {"reg",0}, + Package () {"snps,nr-gpios",8}, + } + }) + } + + Device(GP01) { + Name(_HID, "FTGP0001") //FTGPIO01 + Name(_ADR, 1) + Name (_DSD, Package () { + ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), + Package () { + Package () {"reg",1}, + Package () {"snps,nr-gpios",8}, + } + }) + } + } + + Device(GPI1) { + Name(_HID, "FTGP0001") //FTGPIO01 + Name(_ADR, 1) + Name(_UID, 1) + Name (_CRS, ResourceTemplate () { + Memory32Fixed (ReadWrite, 0x28005000, 0x1000) + Interrupt(ResourceConsumer, Level, ActiveHigh, Exclusive) {43} + }) + + Device(GP00) { + Name(_HID, "FTGP0001") //FTGPIO01 + Name(_ADR, 0) + Name (_DSD, Package () { + ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), + Package () { + Package () {"reg",0}, + Package () {"snps,nr-gpios",8}, + } + }) + } + + Device(GP01) { + Name(_HID, "FTGP0001") + Name(_ADR, 1) + Name (_DSD, Package () { + ToUUID("daffd814-6eba-4d8c-8a91-bc9bbf4aa301"), + Package () { + Package () {"reg",1}, + Package () {"snps,nr-gpios",8}, + } + }) + } + } + + /* SD controller */ + Device (SDC0) { + Name (_HID, "FTSD0001") + Name (_UID, 0) + Name (_CRS, ResourceTemplate () { + Memory32Fixed (ReadWrite, 0x28207C00, 0x100) + Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) {52, 53, 54} + }) + } + + /* HDAudio device */ + Device (HDA0) { + Name (_HID, "FTHD0001") + Name (_UID, 0) + Name (_CRS, ResourceTemplate () { + Memory32Fixed (ReadWrite, 0x28206000, 0x1000) + Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) {55} + }) + } + + /* RAS */ + Device (RAS0) { + Name (_HID, "FTRA0001") + Name (_UID, 0) + Name (_CRS, ResourceTemplate () { + Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive) {32,33} + }) + } + + Method(TCOM, 1, Serialized) { + OperationRegion(COM0, SystemMemory, 0x28001000, 0x1000) + Field(COM0, DWordAcc, NoLock, Preserve) { + DAT8, 8, + Offset(5), + , 5, + TRDY, 1, + } + + Add(SizeOf(Arg0), One, Local0) + Name(BUF0, Buffer(Local0){}) + Store(Arg0, BUF0) + store(0, Local1) + Decrement(Local0) + While(LNotEqual(Local1, Local0)){ + while(LEqual(TRDY, ONE)){} + Store(DerefOf(Index(BUF0, Local1)), DAT8) + Increment(Local1) + } + } + + Method(DBGC, 3, Serialized) { + Name(CRLF, Buffer(2) {0x0D, 0x0A}) + TCOM(Arg1) + if(LEqual(Arg0, 2)){ + TCOM(ToHexString(Arg2)) + } + TCOM(CRLF) + } + + Device (RTC0) { + Name (_HID, "FTRT0001") + Name (_UID, Zero) + Name (_CRS, ResourceTemplate () { + Memory32Fixed (ReadWrite, + 0x2800d000, // Address Base + 0x00001000, // Address Length + ) + Interrupt (ResourceConsumer, Level, ActiveHigh, Exclusive, , , ) {36,} + }) + } + } /* Scope(_SB) */ +} diff --git a/board/phytium/durian/acpi_table/fadt.c b/board/phytium/durian/acpi_table/fadt.c new file mode 100644 index 0000000..cc5f1c2 --- /dev/null +++ b/board/phytium/durian/acpi_table/fadt.c @@ -0,0 +1,83 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2019 + * Steven Hao liuhao@phytium.com.cn + */ + +#include <common.h> +#include <asm/acpi_table.h> +#include <asm/acpi_table/acpi61.h> +#include <asm/acpi_table/spcr_table.h> +#include <asm/acpi_table/acpi_lib.h> +#include <asm/acpi_table/arm_platform.h> +#include <asm/acpi_table/io_remapping_table.h> +#include "../acpi_platform.h" + +#define PHYTIUM_FADT_SIGNATURE \ + EFI_ACPI_6_1_FIXED_ACPI_DESCRIPTION_TABLE_SIGNATURE + +struct efi_acpi_6_1_fixed_acpi_description_table phy_fadt = { + arm_acpi_header + (PHYTIUM_FADT_SIGNATURE, + struct efi_acpi_6_1_fixed_acpi_description_table, + EFI_ACPI_6_1_FIXED_ACPI_DESCRIPTION_TABLE_REVISION + ), + 0, + 0, + 0x00, + EFI_ACPI_6_1_PM_PROFILE_ENTERPRISE_SERVER, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + 0, + EFI_ACPI_6_1_HW_REDUCED_ACPI | EFI_ACPI_6_1_LOW_POWER_S0_IDLE_CAPABLE, + null_gas, + 0, + EFI_ACPI_6_1_ARM_PSCI_COMPLIANT, + EFI_ACPI_6_1_FIXED_ACPI_DESCRIPTION_TABLE_MINOR_REVISION, + 0, + 0, + null_gas, + null_gas, + null_gas, + null_gas, + null_gas, + null_gas, + null_gas, + null_gas, + null_gas, + null_gas, + 0 +}; + +unsigned char *fadt_data = (unsigned char *)&phy_fadt; + diff --git a/board/phytium/durian/acpi_table/gtdt.c b/board/phytium/durian/acpi_table/gtdt.c new file mode 100644 index 0000000..294389c --- /dev/null +++ b/board/phytium/durian/acpi_table/gtdt.c @@ -0,0 +1,81 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2019 + * Steven Hao liuhao@phytium.com.cn + */ + +#include <common.h> +#include <asm/acpi_table.h> +#include <asm/acpi_table/acpi61.h> +#include <asm/acpi_table/arm_platform.h> +#include "../acpi_platform.h" + +#define GTDT_TIMER_EDGE_TRIGGERED \ + EFI_ACPI_6_1_GTDT_TIMER_FLAG_TIMER_INTERRUPT_MODE +#define GTDT_TIMER_LEVEL_TRIGGERED 0 +#define GTDT_TIMER_ACTIVE_LOW \ + EFI_ACPI_6_1_GTDT_TIMER_FLAG_TIMER_INTERRUPT_POLARITY +#define GTDT_TIMER_ACTIVE_HIGH 0 +#define GTDT_TIMER_ALWAYS_ON_CAPABILITY \ + EFI_ACPI_6_1_GTDT_TIMER_FLAG_ALWAYS_ON_CAPABILITY + +#define GTDT_GTIMER_FLAGS \ + (GTDT_TIMER_ACTIVE_LOW | GTDT_TIMER_LEVEL_TRIGGERED) + +#define PHYTIUM_GTDT_SIGNATURE \ + EFI_ACPI_6_1_GENERIC_TIMER_DESCRIPTION_TABLE_SIGNATURE + +#pragma pack(1) + +struct efi_acpi_6_1_generic_timer_description_tables { + struct efi_acpi_6_1_generic_timer_description_table gtdt; + struct efi_acpi_6_1_gtdt_sbsa_generic_watchdog_structure + watchdogs[2]; +}; + +#pragma pack() + +struct efi_acpi_6_1_generic_timer_description_tables phy_gtdt = { + { + arm_acpi_header + (PHYTIUM_GTDT_SIGNATURE, + struct efi_acpi_6_1_generic_timer_description_tables, + EFI_ACPI_6_1_GENERIC_TIMER_DESCRIPTION_TABLE_REVISION + ), + 0xFFFFFFFFFFFFFFFF, /* physical_address */ + 0, /* reserved */ + 29, /* secure_pl1_timer_GSIV */ + GTDT_GTIMER_FLAGS, /* secure_pl1_timer_flags */ + 30, /* non_secure_pl1_timer_GSIV */ + GTDT_GTIMER_FLAGS, /* non_secure_pl1_timer_flags */ + 27, /* virtual_timer_GSIV */ + GTDT_GTIMER_FLAGS, /* virtual_timer_flags */ + 26, /* non_secure_pl2_timer_GSIV */ + GTDT_GTIMER_FLAGS, /* non_secure_pl2_timer_flags */ + 0xFFFFFFFFFFFFFFFF, /* cnt_read_base_physical_address */ + 2, + sizeof(struct efi_acpi_6_1_generic_timer_description_table) + }, + { + { + 1, /* type */ + 28, /* size of this structure */ + 0, /* reserved */ + 0x2800a000, /* refresh_frame physical address */ + 0x2800b000, /* watchdog_control_frame phy_address */ + 48, /* watchdog timer GSIV */ + 0, /* watchdog timer flags high_l*/ + }, + { + 1, + 28, + 0, + 0x28016000, + 0x28017000, + 49, + 0, + } + } +}; + +unsigned char *gtdt_data = (unsigned char *)&phy_gtdt; diff --git a/board/phytium/durian/acpi_table/iort.c b/board/phytium/durian/acpi_table/iort.c new file mode 100644 index 0000000..e813bac --- /dev/null +++ b/board/phytium/durian/acpi_table/iort.c @@ -0,0 +1,117 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2019 + * Steven Hao liuhao@phytium.com.cn + */ + +#include <common.h> +#include <asm/acpi_table.h> +#include <asm/acpi_table/acpi61.h> +#include <asm/acpi_table/arm_platform.h> +#include <asm/acpi_table/io_remapping_table.h> +#include "../acpi_platform.h" + +#define FIELD_OFFSET(type, name) __builtin_offsetof(type, name) + +#define PHYTIUM_IORT_SIGNATURE \ + EFI_ACPI_6_1_IO_REMAPPING_TABLE_SIGNATURE + +#pragma pack(1) +struct phytium_its_node { + struct efi_acpi_6_0_io_remapping_its_node node; + u32 identifiers[1]; +}; + +struct phytium_rc_node { + struct efi_acpi_6_0_io_remapping_rc_node node; + struct efi_acpi_6_0_io_remapping_id_table rc_id_mapping; +}; + +struct phytium_io_remapping_structure { + struct efi_acpi_6_0_io_remapping_table iort; + struct phytium_its_node its_node; + struct phytium_rc_node rc_node[1]; +}; + +#define __phytium_id_mapping(in, num, out, ref, flags)\ +{ \ + in, \ + num, \ + out, \ + FIELD_OFFSET(struct phytium_io_remapping_structure, ref),\ + flags \ +} + +struct phytium_io_remapping_structure phy_iort = { + { + arm_acpi_header + (PHYTIUM_IORT_SIGNATURE, + struct phytium_io_remapping_structure, + EFI_ACPI_IO_REMAPPING_TABLE_REVISION + ), + 2, /* num_nodes */ + /* node_offset */ + sizeof(struct efi_acpi_6_0_io_remapping_table), + 0 /* reserved */ + }, + { + /* + * its_node + */ + { + { + EFI_ACPI_IORT_TYPE_ITS_GROUP, /* type */ + sizeof(struct phytium_its_node),/* length */ + 0x0, /* revision */ + 0x0, /* reserved */ + 0x0, /* num_id_mappings */ + 0x0, /* id_reference */ + }, + 1, + }, + { + 0x0 + }, + }, + { + /* + * pci_rc_node + */ + { + { + { + /* type */ + EFI_ACPI_IORT_TYPE_ROOT_COMPLEX, + /* length */ + sizeof(struct phytium_rc_node), + /* revision */ + 0x0, + /* reserved */ + 0x0, + /* num_id_mappings */ + 0x1, + /* _id_reference */ + FIELD_OFFSET(struct phytium_rc_node, rc_id_mapping), + }, + /* cache_coherent */ + EFI_ACPI_IORT_MEM_ACCESS_PROP_CCA, + /* allocation_hints */ + 0x0, + /* reserved */ + 0x0, + /* memory_access_flags */ + EFI_ACPI_IORT_MEM_ACCESS_FLAGS_CPM, + /* ats_attribute */ + EFI_ACPI_IORT_ROOT_COMPLEX_ATS_UNSUPPORTED, + /* pci_segment_number */ + 0x0, + }, + __phytium_id_mapping(0x0, 0xffff, 0x0, its_node, 0), + } + } +}; + +#pragma pack() + +unsigned char *iort_data = (unsigned char *)&phy_iort; + diff --git a/board/phytium/durian/acpi_table/madt.c b/board/phytium/durian/acpi_table/madt.c new file mode 100644 index 0000000..b7dd1c7 --- /dev/null +++ b/board/phytium/durian/acpi_table/madt.c @@ -0,0 +1,69 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2019 + * Steven Hao liuhao@phytium.com.cn + */ + +#include <common.h> +#include <asm/acpi_table.h> +#include <asm/acpi_table/acpi61.h> +#include <asm/acpi_table/acpi_lib.h> +#include <asm/acpi_table/arm_platform.h> +#include "../acpi_platform.h" + +#define platform_get_mpid(cluster_id, core_id) (((cluster_id) << 8) | \ + (core_id)) + +#define PHYTIUM_MADT_SIGNATURE \ + EFI_ACPI_6_1_MULTIPLE_APIC_DESCRIPTION_TABLE_SIGNATURE + +/* + * Multiple APIC Description Table + */ +#pragma pack(1) + +struct efi_acpi_6_1_multiple_apic_description_table { + struct efi_acpi_6_1_multiple_apic_description_table_header header; + struct efi_acpi_6_1_gic_structure gic_interfaces[4]; + struct efi_acpi_6_1_gic_distributor_structure gic_distributor; + struct efi_acpi_6_1_gic_its_structure gic_its[1]; +}; + +#pragma pack() + +#define efi_gicc_structure(acpi_cpu_uid, mpidr, gicr_base_offset) \ + efi_acpi_6_1_gicc_structure_init(0, acpi_cpu_uid, mpidr,\ + EFI_ACPI_6_1_GIC_ENABLED, 23, \ + 0x29c00000, (0x29c00000 + 0x20000), \ + (0x29c00000 + 0x10000), 25, \ + (0x29980000 + (gicr_base_offset)), 0) + +/* + * Multiple APIC Description Table + */ +struct efi_acpi_6_1_multiple_apic_description_table phy_madt = { + { + arm_acpi_header + (PHYTIUM_MADT_SIGNATURE, + struct efi_acpi_6_1_multiple_apic_description_table, + EFI_ACPI_6_1_MULTIPLE_APIC_DESCRIPTION_TABLE_REVISION + ), + /* + * MADT specific fields + */ + 0, /* LocalApicAddress */ + 0, /* Flags */ + }, + { + efi_gicc_structure(0x00, platform_get_mpid(0x00, 0), 0x000000), + efi_gicc_structure(0x01, platform_get_mpid(0x00, 1), 0x020000), + efi_gicc_structure(0x02, platform_get_mpid(0x01, 0), 0x040000), + efi_gicc_structure(0x03, platform_get_mpid(0x01, 1), 0x060000), + }, + efi_acpi_6_1_gic_distributor_init(0, 0x29900000, 0, 0x3), + { + efi_acpi_6_1_gic_its_init(0, 0x29900000 + 0x20000), + } +}; + +unsigned char *madt_data = (unsigned char *)&phy_madt; diff --git a/board/phytium/durian/acpi_table/mcfg.c b/board/phytium/durian/acpi_table/mcfg.c new file mode 100644 index 0000000..69a0081 --- /dev/null +++ b/board/phytium/durian/acpi_table/mcfg.c @@ -0,0 +1,68 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2019 + * Steven Hao liuhao@phytium.com.cn + */ + +#include <common.h> +#include <asm/acpi_table.h> +#include <asm/acpi_table/acpi61.h> +#include <asm/acpi_table/arm_platform.h> +#include "../acpi_platform.h" + +#define PHYTIUM_MCFG_SIGNATURE \ + EFI_ACPI_6_1_PCI_EXPRESS_MEMORY_MAPPED_ADDR_TABLE_SIGNATURE +#define PHYTIM_MCFG_STRUCTURE_SIZE \ +(sizeof(struct efi_acpi_6_1_pci_express_memory_mapped_conf_space_table)) +#define ACPI_6_1_MCFG_VERSION 0x1 + +#pragma pack(1) + +struct efi_acpi_6_1_mcfg_config_structure { + u64 ull_base_address; + u16 us_seg_group_num; + u8 uc_start_bus_num; + u8 uc_end_bus_num; + u32 reserved2; +}; + +struct efi_acpi_6_1_mcfg_table_config { + struct efi_acpi_description_header header; + u64 reserved1; +}; + +struct efi_acpi_6_1_pci_express_memory_mapped_conf_space_table { + struct efi_acpi_6_1_mcfg_table_config acpi_table_mcfg; + struct efi_acpi_6_1_mcfg_config_structure config_structure[1]; +}; + +#pragma pack() + +struct +efi_acpi_6_1_pci_express_memory_mapped_conf_space_table phy_mcfg = { + { + { + PHYTIUM_MCFG_SIGNATURE, + PHYTIM_MCFG_STRUCTURE_SIZE, + ACPI_6_1_MCFG_VERSION, + 0x00, + EFI_ACPI_ARM_OEM_ID, + EFI_ACPI_ARM_OEM_TABLE_ID, + EFI_ACPI_ARM_OEM_REVISION, + EFI_ACPI_ARM_CREATOR_ID, + EFI_ACPI_ARM_CREATOR_REVISION + }, + 0x0000000000000000, /* reserved */ + }, + { + { + 0x40000000, /* base address */ + 0, /* segment group number */ + 0, /* start bus number */ + 0xff, /* end bus number */ + 0x00000000, /* reserved */ + }, + } +}; + +unsigned char *mcfg_data = (unsigned char *)&phy_mcfg; diff --git a/board/phytium/durian/acpi_table/rsdp.c b/board/phytium/durian/acpi_table/rsdp.c new file mode 100644 index 0000000..8b3a4e9 --- /dev/null +++ b/board/phytium/durian/acpi_table/rsdp.c @@ -0,0 +1,25 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2019 + * Steven Hao liuhao@phytium.com.cn + */ + +#include <common.h> +#include <asm/acpi_table.h> +#include <asm/acpi_table/acpi61.h> +#include <asm/acpi_table/arm_platform.h> +#include "../acpi_platform.h" + +struct efi_acpi_6_1_root_system_description_pointer phy_rsdp = { + EFI_ACPI_6_1_ROOT_SYSTEM_DESCRIPTION_POINTER_SIGNATURE, + 0, + EFI_ACPI_ARM_OEM_ID, + 2, + 0, + sizeof(struct efi_acpi_6_1_root_system_description_pointer), + 0, + 0, + {0, 0, 0} +}; + +unsigned char *rsdp_data = (unsigned char *)&phy_rsdp; diff --git a/board/phytium/durian/acpi_table/rsdt.c b/board/phytium/durian/acpi_table/rsdt.c new file mode 100644 index 0000000..c5cfd1c --- /dev/null +++ b/board/phytium/durian/acpi_table/rsdt.c @@ -0,0 +1,28 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2019 + * Steven Hao liuhao@phytium.com.cn + */ + +#include <common.h> +#include <asm/acpi_table.h> +#include <asm/acpi_table/acpi61.h> +#include <asm/acpi_table/arm_platform.h> +#include "../acpi_platform.h" + +#define PHYTIUM_RSDT_SIGNATURE \ + EFI_ACPI_6_1_ROOT_SYSTEM_DESCRIPTION_TABLE_SIGNATURE + +struct efi_acpi_6_1_root_system_description_table phy_rsdt = { + arm_acpi_header + (PHYTIUM_RSDT_SIGNATURE, + struct efi_acpi_6_1_root_system_description_table, + EFI_ACPI_6_1_ROOT_SYSTEM_DESCRIPTION_TABLE_REVISION + ), + { + 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 + } +}; + +unsigned char *rsdt_data = (unsigned char *)&phy_rsdt; diff --git a/board/phytium/durian/acpi_table/spcr.c b/board/phytium/durian/acpi_table/spcr.c new file mode 100644 index 0000000..1b3ecc7 --- /dev/null +++ b/board/phytium/durian/acpi_table/spcr.c @@ -0,0 +1,78 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2019 + * Steven Hao liuhao@phytium.com.cn + */ + +#include <common.h> +#include <asm/acpi_table.h> +#include <asm/acpi_table/acpi61.h> +#include <asm/acpi_table/acpi_lib.h> +#include <asm/acpi_table/spcr_table.h> +#include <asm/acpi_table/arm_platform.h> +#include "../acpi_platform.h" + +/* + * References: + * Serial Port Console Redirection Table Specification Version 1.03 + * - August 10, 2015 + */ + +#define SPCR_FLOW_CONTROL_NONE 0 + +#define PHYTIUM_SPCR_SIGNATURE \ + EFI_ACPI_6_1_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_SIGNATURE + +struct efi_acpi_serial_port_console_redirection_table phy_spcr = { + arm_acpi_header + (PHYTIUM_SPCR_SIGNATURE, + struct efi_acpi_serial_port_console_redirection_table, + EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_REVISION + ), + /* u8 interface_type */ + EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_INTERFACE_TYPE_16550, + /* u8 reserved1[3] */ + { + EFI_ACPI_RESERVED_BYTE, + EFI_ACPI_RESERVED_BYTE, + EFI_ACPI_RESERVED_BYTE + }, + /* struct efi_acpi_6_0_generic_address_structure base_address */ + arm_gas32(0x28001000), + /* u8 InterruptType */ + EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_INTERRUPT_TYPE_GIC, + /* u8 irq */ + 0, /* not used on ARM */ + /* u32 global_system_interrupt */ + 67, + /* u8 baud_rate */ + EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_BAUD_RATE_115200, + /* u8 parity */ + EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_PARITY_NO_PARITY, + /* u8 stop_bits */ + EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_STOP_BITS_1, + /* u8 flow_control */ + SPCR_FLOW_CONTROL_NONE, + /* u8 terminal_type */ + EFI_ACPI_SERIAL_PORT_CONSOLE_REDIRECTION_TABLE_TERMINAL_TYPE_ANSI, + /* u8 reserved2 */ + EFI_ACPI_RESERVED_BYTE, + /* u16 pci_device_id */ + 0xFFFF, + /* u16 pci_vendor_id */ + 0xFFFF, + /* u8 pci_bus_number */ + 0x00, + /* u8 pci_device_number */ + 0x00, + /* u8 pci_function_number */ + 0x00, + /* u32 pci_flags */ + 0x00000000, + /* u8 pci_segment */ + 0x00, + /* u32 reserved3 */ + EFI_ACPI_RESERVED_DWORD +}; + +unsigned char *spcr_data = (unsigned char *)&phy_spcr; diff --git a/board/phytium/durian/acpi_table/ssdt.asl b/board/phytium/durian/acpi_table/ssdt.asl new file mode 100644 index 0000000..218cddd --- /dev/null +++ b/board/phytium/durian/acpi_table/ssdt.asl @@ -0,0 +1,190 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2019 + * Steven Hao liuhao@phytium.com.cn + */ + +#define LNK_DEVICE(Unique_Id, Link_Name, irq)\ + Device(Link_Name) { \ + Name(_HID, EISAID("PNP0C0F")) \ + Name(_UID, Unique_Id) \ + Name(_PRS, ResourceTemplate() { \ + Interrupt(ResourceProducer, Level, ActiveHigh, Exclusive) {irq}\ + }) \ + Method (_CRS, 0) { Return (_PRS) } \ + Method (_SRS, 1) { } \ + Method (_DIS) { } \ + } + +/* + * Address: uses the same format as _ADR + * Pin: The PCI pin number of the device (0-INTA, 1-INTB, 2-INTC, 3-INTD). + * Link: Interrupt allocated via Link device. + * Zero: global system interrupt number (no used) + */ + +#define PRT_ENTRY(Address, Pin, Link) \ + Package (4) { \ + Address, \ + Pin, \ + Link, \ + Zero \ + } + +#define ROOT_PRT_ENTRY(Dev, Pin, Link) \ + PRT_ENTRY(Dev * 0x10000 + 0xFFFF, Pin, Link) + +DefinitionBlock("ssdt.aml", "SSDT", 1, "ARMLTD", "PHYTIUM", 0x20190901){ + Scope(_SB) { + External (_SB.DBGC, MethodObj) + /* + * PCI Root Complex + */ + LNK_DEVICE(1, LNKA, 60) + LNK_DEVICE(2, LNKB, 61) + LNK_DEVICE(3, LNKC, 62) + LNK_DEVICE(4, LNKD, 63) + + Device(PCI0) + { + Name(_HID, EISAID("PNP0A08")) /* PCI Express Root Bridge */ + Name(_CID, EISAID("PNP0A03")) /* Compatible PCI Root Bridge */ + Name(_SEG, Zero) /* PCI Segment Group number */ + Name(_BBN, 0) /* PCI Base Bus Number */ + Name(_CCA, 1) /* Initially mark the PCI coherent (for JunoR1) */ + + /* Root Complex */ + Device (RP0) { + Name(_ADR, 0x00000000) /* Dev 0, Func 0 */ + } + /* PCI Routing Table */ + Name(_PRT, Package() { + ROOT_PRT_ENTRY(0, 0, LNKA), /* INTA */ + ROOT_PRT_ENTRY(0, 1, LNKB), /* INTB */ + ROOT_PRT_ENTRY(0, 2, LNKC), /* INTC */ + ROOT_PRT_ENTRY(0, 3, LNKD), /* INTD */ + + ROOT_PRT_ENTRY(1, 0, LNKA), /* INTA */ + ROOT_PRT_ENTRY(1, 1, LNKB), /* INTB */ + ROOT_PRT_ENTRY(1, 2, LNKC), /* INTC */ + ROOT_PRT_ENTRY(1, 3, LNKD), /* INTD */ + + ROOT_PRT_ENTRY(2, 0, LNKA), /* INTA */ + ROOT_PRT_ENTRY(2, 1, LNKB), /* INTB */ + ROOT_PRT_ENTRY(2, 2, LNKC), /* INTC */ + ROOT_PRT_ENTRY(2, 3, LNKD), /* INTD */ + + ROOT_PRT_ENTRY(3, 0, LNKA), /* INTA */ + ROOT_PRT_ENTRY(3, 1, LNKB), /* INTB */ + ROOT_PRT_ENTRY(3, 2, LNKC), /* INTC */ + ROOT_PRT_ENTRY(3, 3, LNKD), /* INTD */ + + ROOT_PRT_ENTRY(4, 0, LNKA), /* INTA */ + ROOT_PRT_ENTRY(4, 1, LNKB), /* INTB */ + ROOT_PRT_ENTRY(4, 2, LNKC), /* INTC */ + ROOT_PRT_ENTRY(4, 3, LNKD), /* INTD */ + + ROOT_PRT_ENTRY(5, 0, LNKA), /* INTA */ + ROOT_PRT_ENTRY(5, 1, LNKB), /* INTB */ + ROOT_PRT_ENTRY(5, 2, LNKC), /* INTC */ + ROOT_PRT_ENTRY(5, 3, LNKD), /* INTD */ + }) + + /* Root complex resources */ + Method (_CRS, 0, Serialized) { + Name (RBUF, ResourceTemplate () { + WordBusNumber ( /* Bus numbers assigned to this root */ + ResourceProducer, + MinFixed, MaxFixed, PosDecode, + 0, /* AddressGranularity */ + 0, /* AddressMinimum - Minimum Bus Number */ + 255, /* AddressMaximum - Maximum Bus Number */ + 0, /* AddressTranslation - Set to 0 */ + 256 /* RangeLength - Number of Busses */ + ) + + DWordMemory ( /* 32-bit BAR Windows */ + ResourceProducer, PosDecode, + MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, /* Granularity */ + 0x58000000, /* Min Base Address */ + 0x7FFFFFFF, /* Max Base Address */ + 0x00000000, /* Translate */ + 0x28000000 /* Length */ + ) + + QWordMemory ( /* 64-bit BAR Windows */ + ResourceProducer, PosDecode, + MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, /* Granularity */ + 0x1000000000, /* Min Base Address */ + 0x1FFFFFFFFF, /* Max Base Address */ + 0x0000000000, /* Translate */ + 0x1000000000 /* Length */ + ) + + DWordIo ( // IO window + ResourceProducer, + MinFixed, + MaxFixed, + PosDecode, + EntireRange, + 0x00000000, /* Granularity */ + 0x00000000, /* Min Base Address */ + 0x00efffff, /* Max Base Address */ + 0x50000000, /* Translate */ + 0x00f00000, /* Length */ + ,,,TypeTranslation + ) + }) /* Name(RBUF) */ + + Return (RBUF) + } /* Method(_CRS) */ + + /* + * OS Control Handoff + */ + Name(SUPP, Zero) /* PCI _OSC Support Field value */ + Name(CTRL, Zero) /* PCI _OSC Control Field value */ + + Method(_OSC,4) { + /* Check for proper UUID */ + If (LEqual(Arg0,ToUUID("33DB4D5B-1FF7-401C-9657-7441C03DD766"))) { + CreateDWordField(Arg3,0,CDW1) + CreateDWordField(Arg3,4,CDW2) + CreateDWordField(Arg3,8,CDW3) + + /* Save Capabilities DWord2 & 3 */ + Store(CDW2,SUPP) + Store(CDW3,CTRL) + + If (LNotEqual(And(SUPP, 0x16), 0x16)) { + And(CTRL,0x1E,CTRL) /* Mask bit 0 (and undefined bits) */ + } + + /* + * Do not allow native PME, AER (no dependencies) + * Never allow SHPC (no SHPC controller in this system) + */ + And(CTRL,0x10,CTRL) + + If (LNotEqual(Arg1,One)) { /* Unknown revision */ + Or(CDW1,0x08,CDW1) + } + + If (LNotEqual(CDW3,CTRL)) { /* Capabilities bits were masked */ + Or(CDW1,0x10,CDW1) + } + /* Update DWORD3 in the buffer */ + Store(CTRL,CDW3) + Return(Arg3) + } Else { + Or(CDW1,4,CDW1) /* Unrecognized UUID */ + Return(Arg3) + } + } /* End _OSC */ + } /* PCI0 */ + } +} diff --git a/board/phytium/durian/acpi_table/xsdt.c b/board/phytium/durian/acpi_table/xsdt.c new file mode 100644 index 0000000..25959d6 --- /dev/null +++ b/board/phytium/durian/acpi_table/xsdt.c @@ -0,0 +1,31 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2019 + * Steven Hao liuhao@phytium.com.cn + */ + +#include <common.h> +#include <asm/acpi_table.h> +#include <asm/acpi_table/acpi61.h> +#include <asm/acpi_table/arm_platform.h> +#include "../acpi_platform.h" + +#define PHYTIUM_XSDT_SIGNATURE \ + EFI_ACPI_6_1_EXTENDED_SYSTEM_DESCRIPTION_TABLE_SIGNATURE + +/* + * XSDT table + */ +struct efi_acpi_6_1_extended_system_description_table phy_xsdt = { + arm_acpi_header + (PHYTIUM_XSDT_SIGNATURE, + struct efi_acpi_6_1_extended_system_description_table, + EFI_ACPI_6_1_EXTENDED_SYSTEM_DESCRIPTION_TABLE_REVISION + ), + { + 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, + 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 + } +}; + +unsigned char *xsdt_data = (unsigned char *)&phy_xsdt; diff --git a/cmd/bootefi.c b/cmd/bootefi.c index f613cce..d2e15db 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -73,7 +73,8 @@ out: efi_root, NULL)); }
-#if !CONFIG_IS_ENABLED(GENERATE_ACPI_TABLE) +#if (!CONFIG_IS_ENABLED(GENERATE_ACPI_TABLE) && \ + !CONFIG_IS_ENABLED(ARM_ACPI_TABLE))
/** * copy_fdt() - Copy the device tree to a new location available to EFI @@ -214,7 +215,8 @@ static efi_status_t efi_install_fdt(const char *fdt_opt) * The EBBR spec requires that we have either an FDT or an ACPI table * but not both. */ -#if CONFIG_IS_ENABLED(GENERATE_ACPI_TABLE) +#if (CONFIG_IS_ENABLED(GENERATE_ACPI_TABLE) || \ + CONFIG_IS_ENABLED(ARM_ACPI_TABLE)) if (fdt_opt) { printf("ERROR: can't have ACPI table and device tree.\n"); return EFI_LOAD_ERROR; diff --git a/configs/durian_defconfig b/configs/durian_defconfig index 20177e4..1164a85 100644 --- a/configs/durian_defconfig +++ b/configs/durian_defconfig @@ -1,5 +1,14 @@ CONFIG_ARM=y CONFIG_ARM_SMCCC=y +CONFIG_ARM_ACPI_TABLE=y +CONFIG_DSDT_TABLE=y +CONFIG_SSDT_TABLE=y +CONFIG_FADT_TABLE=y +CONFIG_GTDT_TABLE=y +CONFIG_MADT_TABLE=y +CONFIG_MCFG_TABLE=y +CONFIG_IORT_TABLE=y +CONFIG_SPCR_TABLE=y CONFIG_TARGET_DURIAN=y CONFIG_SYS_TEXT_BASE=0x500000 CONFIG_NR_DRAM_BANKS=1 diff --git a/include/configs/durian.h b/include/configs/durian.h index c42a98b..41347ac 100644 --- a/include/configs/durian.h +++ b/include/configs/durian.h @@ -36,9 +36,11 @@ #define CONFIG_SYS_BOOTM_LEN (60 * 1024 * 1024)
#define CONFIG_EXTRA_ENV_SETTINGS \ - "load_kernel=ext4load scsi 0:1 0x90100000 uImage-2004\0" \ - "load_fdt=ext4load scsi 0:1 0x95000000 ft2004-pci-64.dtb\0"\ + "load_kernel=ext4load scsi 0:1 0x90100000 uImage-durian\0" \ + "load_fdt=ext4load scsi 0:1 0x95000000 phytium-durian.dtb\0"\ "boot_fdt=bootm 0x90100000 -:- 0x95000000\0" \ - "distro_bootcmd=run load_kernel; run load_fdt; run boot_fdt" + "distro_bootcmd=run load_kernel; run load_fdt; run boot_fdt\0"\ + "load_acpi_kernel=ext4load scsi 0:1 0x90100000 Image-durian\0"\ + "acpi_boot=bootefi 0x90100000\0"
#endif diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index 7db4060..fc91a55 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -42,3 +42,4 @@ obj-$(CONFIG_PARTITIONS) += efi_disk.o obj-$(CONFIG_NET) += efi_net.o obj-$(CONFIG_GENERATE_ACPI_TABLE) += efi_acpi.o obj-$(CONFIG_GENERATE_SMBIOS_TABLE) += efi_smbios.o +obj-$(CONFIG_ARM_ACPI_TABLE) += efi_acpi.o diff --git a/lib/efi_loader/efi_setup.c b/lib/efi_loader/efi_setup.c index de7b616..1971f8f 100644 --- a/lib/efi_loader/efi_setup.c +++ b/lib/efi_loader/efi_setup.c @@ -160,7 +160,7 @@ efi_status_t efi_init_obj_list(void) if (ret != EFI_SUCCESS) goto out; #endif -#ifdef CONFIG_GENERATE_ACPI_TABLE +#if defined(CONFIG_GENERATE_ACPI_TABLE) || defined(CONFIG_ARM_ACPI_TABLE) ret = efi_acpi_register(); if (ret != EFI_SUCCESS) goto out; diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index ef116e0..34ffec9 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -416,6 +416,14 @@ $(obj)/dsdt.c: $(src)/dsdt.asl $(call cmd,acpi_c_asl) $(Q)sed -i -e "s,dsdt_aml_code,AmlCode," $@
+$(obj)/acpi_table/dsdt.c: $(src)/acpi_table/dsdt.asl + $(call cmd,acpi_c_asl) + $(Q)sed -i -e "s,dsdt_aml_code,DsdtAmlCode," $@ + +$(obj)/acpi_table/ssdt.c: $(src)/acpi_table/ssdt.asl + $(call cmd,acpi_c_asl) + $(Q)sed -i -e "s,ssdt_aml_code,SsdtAmlCode," $@ + # Bzip2 # ---------------------------------------------------------------------------
Hi Steven,
On Wed, Nov 20, 2019 at 4:41 PM Steven Hao steven_hao5189@outlook.com wrote:
This adds acpi code for arm and the acpi tables about Phytium Durian Board. The acpi table only support rsdp, rsdt, xsdt, fadt, dsdt, ssdt, gtdt, madt, mcfg, iort, spcr.
Signed-off-by: Steven Hao steven_hao5189@outlook.com
Changes for v3:
- modify arch/arm/Kconfig
- modify lib/efi_loader/efi_setup.c
Changes for v2:
- execute git pull --rebase
MAINTAINERS | 3 + Makefile | 1 + arch/arm/Kconfig | 69 ++ arch/arm/include/asm/acpi_table.h | 39 ++ arch/arm/include/asm/acpi_table/acpi61.h | 755 +++++++++++++++++++++ arch/arm/include/asm/acpi_table/acpi_lib.h | 89 +++ arch/arm/include/asm/acpi_table/arm_platform.h | 93 +++ .../include/asm/acpi_table/io_remapping_table.h | 179 +++++ arch/arm/include/asm/acpi_table/spcr_table.h | 175 +++++ arch/arm/lib/Makefile | 1 + arch/arm/lib/acpi_table.c | 244 +++++++ board/phytium/durian/Makefile | 18 + board/phytium/durian/acpi_platform.h | 38 ++ board/phytium/durian/acpi_table.c | 53 ++ board/phytium/durian/acpi_table/dsdt.asl | 305 +++++++++ board/phytium/durian/acpi_table/fadt.c | 83 +++ board/phytium/durian/acpi_table/gtdt.c | 81 +++ board/phytium/durian/acpi_table/iort.c | 117 ++++ board/phytium/durian/acpi_table/madt.c | 69 ++ board/phytium/durian/acpi_table/mcfg.c | 68 ++ board/phytium/durian/acpi_table/rsdp.c | 25 + board/phytium/durian/acpi_table/rsdt.c | 28 + board/phytium/durian/acpi_table/spcr.c | 78 +++ board/phytium/durian/acpi_table/ssdt.asl | 190 ++++++ board/phytium/durian/acpi_table/xsdt.c | 31 + cmd/bootefi.c | 6 +- configs/durian_defconfig | 9 + include/configs/durian.h | 8 +- lib/efi_loader/Makefile | 1 + lib/efi_loader/efi_setup.c | 2 +- scripts/Makefile.lib | 8 + 31 files changed, 2860 insertions(+), 6 deletions(-) create mode 100644 arch/arm/include/asm/acpi_table.h create mode 100644 arch/arm/include/asm/acpi_table/acpi61.h create mode 100644 arch/arm/include/asm/acpi_table/acpi_lib.h create mode 100644 arch/arm/include/asm/acpi_table/arm_platform.h create mode 100644 arch/arm/include/asm/acpi_table/io_remapping_table.h create mode 100644 arch/arm/include/asm/acpi_table/spcr_table.h create mode 100644 arch/arm/lib/acpi_table.c create mode 100644 board/phytium/durian/acpi_platform.h create mode 100644 board/phytium/durian/acpi_table.c create mode 100644 board/phytium/durian/acpi_table/dsdt.asl create mode 100644 board/phytium/durian/acpi_table/fadt.c create mode 100644 board/phytium/durian/acpi_table/gtdt.c create mode 100644 board/phytium/durian/acpi_table/iort.c create mode 100644 board/phytium/durian/acpi_table/madt.c create mode 100644 board/phytium/durian/acpi_table/mcfg.c create mode 100644 board/phytium/durian/acpi_table/rsdp.c create mode 100644 board/phytium/durian/acpi_table/rsdt.c create mode 100644 board/phytium/durian/acpi_table/spcr.c create mode 100644 board/phytium/durian/acpi_table/ssdt.asl create mode 100644 board/phytium/durian/acpi_table/xsdt.c
As discussed in the v1 thread, please consider the existing x86 ACPI support. Also, please try to split this single patch into various small, independent patches.
Regards, Bin
Dear Bin:
Firstly: I know that acpi about x86 is existing. And it is usefull for x86 platfporm. If it is used to arm platform,some modification may have to do. For example,facs table is useless for arm.
In adition,The acpi table is writed statically and then modified dynamically in my patch. It is a new method.
I want to consult that whether my method is helpful or not.
Secondly: If i want to reuse the x86-acpi. I will overwrite the write_acpi_tables function. But the definition about acpi strcuture is placed in arch/x86/include/asm directory. It can not be used to arm plateform. If the acpi library need to surport for all platform,i think it should move to /include directory.
Thank you Steven Hao
获取 Outlook for iOShttps://aka.ms/o0ukef ________________________________ 发件人: Bin Meng bmeng.cn@gmail.com 发送时间: Thursday, November 21, 2019 11:18:24 PM 收件人: Steven Hao steven_hao5189@outlook.com 抄送: xypron.glpk@gmx.de xypron.glpk@gmx.de; liuhao@phytium.com.cn liuhao@phytium.com.cn; agraf@csgraf.de agraf@csgraf.de; jagan@amarulasolutions.com jagan@amarulasolutions.com; marek.vasut@gmail.com marek.vasut@gmail.com; sr@denx.de sr@denx.de; patrice.chotard@st.com patrice.chotard@st.com; afd@ti.com afd@ti.com; horatiu.vultur@microchip.com horatiu.vultur@microchip.com; narmstrong@baylibre.com narmstrong@baylibre.com; ryder.lee@mediatek.com ryder.lee@mediatek.com; igor.opaniuk@gmail.com igor.opaniuk@gmail.com; patrick.delaunay@st.com patrick.delaunay@st.com; eugen.hristev@microchip.com eugen.hristev@microchip.com; sjg@chromium.org sjg@chromium.org; judge.packham@gmail.com judge.packham@gmail.com; yamada.masahiro@socionext.com yamada.masahiro@socionext.com; swarren@nvidia.com swarren@nvidia.com; michal.simek@xilinx.com michal.simek@xilinx.com; u-boot@lists.denx.de u-boot@lists.denx.de; Andy Shevchenko andriy.shevchenko@linux.intel.com 主题: Re: [PATCH v3] arm: add acpi support for the arm
Hi Steven,
Changes for v3:
Changes for v2:
Regards, Bin
Hi Steven,
On Mon, Nov 25, 2019 at 10:09 AM Steven Hao steven_hao5189@outlook.com wrote:
Dear Bin:
Yes, we all are aware that modifications are needed to the existing x86 ACPI support to support ARM. We don't want to create 2 ACP implementation in U-Boot.
Regards, Bin
Dear Bin:
I have a suggetion that the acpi specification definition such as all acpi table structure definition should be place in /include directory. and write_acpi_tables function can be placed in platform directory. Creating acpi table mothod can be diffrent between x86 and arm.
获取 Outlook for iOShttps://aka.ms/o0ukef ________________________________ 发件人: Bin Meng bmeng.cn@gmail.com 发送时间: Monday, November 25, 2019 10:13:40 AM 收件人: Steven Hao steven_hao5189@outlook.com 抄送: xypron.glpk@gmx.de xypron.glpk@gmx.de; liuhao@phytium.com.cn liuhao@phytium.com.cn; agraf@csgraf.de agraf@csgraf.de; jagan@amarulasolutions.com jagan@amarulasolutions.com; marek.vasut@gmail.com marek.vasut@gmail.com; sr@denx.de sr@denx.de; patrice.chotard@st.com patrice.chotard@st.com; afd@ti.com afd@ti.com; horatiu.vultur@microchip.com horatiu.vultur@microchip.com; narmstrong@baylibre.com narmstrong@baylibre.com; ryder.lee@mediatek.com ryder.lee@mediatek.com; igor.opaniuk@gmail.com igor.opaniuk@gmail.com; patrick.delaunay@st.com patrick.delaunay@st.com; eugen.hristev@microchip.com eugen.hristev@microchip.com; sjg@chromium.org sjg@chromium.org; judge.packham@gmail.com judge.packham@gmail.com; yamada.masahiro@socionext.com yamada.masahiro@socionext.com; swarren@nvidia.com swarren@nvidia.com; michal.simek@xilinx.com michal.simek@xilinx.com; u-boot@lists.denx.de u-boot@lists.denx.de; Andy Shevchenko andriy.shevchenko@linux.intel.com 主题: Re: [PATCH v3] arm: add acpi support for the arm
Hi Steven,
Dear Bin:
Regards, Bin
On 11/25/19 3:42 AM, Steven Hao wrote:> 获取 Outlook for iOS https://aka.ms/o0ukef
*发件人:* Bin Meng bmeng.cn@gmail.com *发送时间:* Monday, November 25, 2019 10:13:40 AM *收件人:* Steven Hao steven_hao5189@outlook.com *抄送:* xypron.glpk@gmx.de xypron.glpk@gmx.de; liuhao@phytium.com.cn liuhao@phytium.com.cn; agraf@csgraf.de agraf@csgraf.de; jagan@amarulasolutions.com jagan@amarulasolutions.com; marek.vasut@gmail.com marek.vasut@gmail.com; sr@denx.de sr@denx.de; patrice.chotard@st.com patrice.chotard@st.com; afd@ti.com afd@ti.com; horatiu.vultur@microchip.com horatiu.vultur@microchip.com; narmstrong@baylibre.com narmstrong@baylibre.com; ryder.lee@mediatek.com ryder.lee@mediatek.com; igor.opaniuk@gmail.com igor.opaniuk@gmail.com; patrick.delaunay@st.com patrick.delaunay@st.com; eugen.hristev@microchip.com eugen.hristev@microchip.com; sjg@chromium.org sjg@chromium.org; judge.packham@gmail.com judge.packham@gmail.com; yamada.masahiro@socionext.com yamada.masahiro@socionext.com; swarren@nvidia.com swarren@nvidia.com; michal.simek@xilinx.com michal.simek@xilinx.com; u-boot@lists.denx.de u-boot@lists.denx.de; Andy Shevchenko andriy.shevchenko@linux.intel.com *主题:* Re: [PATCH v3] arm: add acpi support for the arm Hi Steven,
Dear Bin:
Regards, Bin> Dear Bin:
Currently we are using CPU specific C files generating ACPI tables, e.g. arch/x86/cpu/tangier/acpi.c.
I would prefer if we would generate the ACPI tables and definition blocks completely from text files instead of using C code. This would avoid any architecture specific code.
Such table generation is already in use in the Windows world. See: https://docs.microsoft.com/en-us/windows-hardware/drivers/bringup/generate-a...
Best regards
Heinrich
Dear Bin:
I am finding with Apollo Lake that this isn't possible - we need to insert run-time information into the tables set up with .asl files.
That looks like a programmatic way to create ACPI tables. If so, I'm trying to bring something similar over from coreboot.
Dear Bin:
For device trees we generate the binary form with a compiler. Then we patch the device tree with runtime information in image_setup_libfdt().
Couldn't we go a similar way for ACPI?
Best regards
Heinrich
It seems like a hard thing that how to support arm apci. ________________________________ 发件人: Heinrich Schuchardt xypron.glpk@gmx.de 发送时间: 2019年11月26日 8:58 收件人: Simon Glass sjg@chromium.org 抄送: Steven Hao steven_hao5189@outlook.com; Bin Meng bmeng.cn@gmail.com; liuhao@phytium.com.cn liuhao@phytium.com.cn; agraf@csgraf.de agraf@csgraf.de; jagan@amarulasolutions.com jagan@amarulasolutions.com; marek.vasut@gmail.com marek.vasut@gmail.com; sr@denx.de sr@denx.de; patrice.chotard@st.com patrice.chotard@st.com; afd@ti.com afd@ti.com; horatiu.vultur@microchip.com horatiu.vultur@microchip.com; narmstrong@baylibre.com narmstrong@baylibre.com; ryder.lee@mediatek.com ryder.lee@mediatek.com; igor.opaniuk@gmail.com igor.opaniuk@gmail.com; patrick.delaunay@st.com patrick.delaunay@st.com; eugen.hristev@microchip.com eugen.hristev@microchip.com; judge.packham@gmail.com judge.packham@gmail.com; yamada.masahiro@socionext.com yamada.masahiro@socionext.com; swarren@nvidia.com swarren@nvidia.com; michal.simek@xilinx.com michal.simek@xilinx.com; u-boot@lists.denx.de u-boot@lists.denx.de; Andy Shevchenko andriy.shevchenko@linux.intel.com 主题: Re: [PATCH v3] arm: add acpi support for the arm
Dear Bin:
Best regards
Heinrich
Hi Heinrich,
Dear Bin:
Yes that's my goal, except that some tables are generated wholesale from code (equivalent to entire nodes in DT).
I had a bit of a look at how this is done in coreboot. It is pretty hard to follow as there are weak functions and the code jumps back and forth between generic code and SoC-specific code. But every device has ACPI operation and I think that makes sense.
My current idea is to add a new optional acpi_ops struct pointer into each struct driver, to handle the ACPI table generation and other things needed by ACPI. Then devices that want to do ACPI things can do so. Then we need a new drivers/core/acpi.c file to handle things.
Hi Simon,
On Wed, Nov 27, 2019 at 11:42 AM Simon Glass sjg@chromium.org wrote:
Hi Heinrich,
Dear Bin:
Yes, this approach makes sense to me, for dynamic ACPI table generation.
Regards, Bin
This problem seems like lay aside.
________________________________ 发件人: Bin Meng bmeng.cn@gmail.com 发送时间: 2019年11月27日 14:04 收件人: Simon Glass sjg@chromium.org 抄送: Heinrich Schuchardt xypron.glpk@gmx.de; Steven Hao steven_hao5189@outlook.com; liuhao@phytium.com.cn liuhao@phytium.com.cn; agraf@csgraf.de agraf@csgraf.de; jagan@amarulasolutions.com jagan@amarulasolutions.com; marek.vasut@gmail.com marek.vasut@gmail.com; sr@denx.de sr@denx.de; patrice.chotard@st.com patrice.chotard@st.com; afd@ti.com afd@ti.com; horatiu.vultur@microchip.com horatiu.vultur@microchip.com; narmstrong@baylibre.com narmstrong@baylibre.com; ryder.lee@mediatek.com ryder.lee@mediatek.com; igor.opaniuk@gmail.com igor.opaniuk@gmail.com; patrick.delaunay@st.com patrick.delaunay@st.com; eugen.hristev@microchip.com eugen.hristev@microchip.com; judge.packham@gmail.com judge.packham@gmail.com; yamada.masahiro@socionext.com yamada.masahiro@socionext.com; swarren@nvidia.com swarren@nvidia.com; michal.simek@xilinx.com michal.simek@xilinx.com; u-boot@lists.denx.de u-boot@lists.denx.de; Andy Shevchenko andriy.shevchenko@linux.intel.com 主题: Re: [PATCH v3] arm: add acpi support for the arm
Hi Simon,
Hi Heinrich,
Dear Bin:
Regards, Bin
Hi Simon,
Hi Heinrich,
On Mon, Nov 25, 2019 at 10:09 AM Steven Hao steven_hao5189@outlook.com wrote: > > Dear Bin: > > Firstly: > I know that acpi about x86 is existing. And it is usefull for x86
> > I want to consult that whether my method is helpful or not. > > Secondly: > If i want to reuse the x86-acpi. I will overwrite the
Just an update on this...I have some basic code for APL and am making progress. I expect to send patches by the end of January.
Dear Simon:
I am expecting it.
Regards, Steven Hao
获取 Outlook for iOShttps://aka.ms/o0ukef ________________________________ 发件人: Simon Glass sjg@chromium.org 发送时间: Saturday, December 28, 2019 12:41:59 AM 收件人: Steven Hao steven_hao5189@outlook.com 抄送: Bin Meng bmeng.cn@gmail.com; Heinrich Schuchardt xypron.glpk@gmx.de; liuhao@phytium.com.cn liuhao@phytium.com.cn; agraf@csgraf.de agraf@csgraf.de; jagan@amarulasolutions.com jagan@amarulasolutions.com; marek.vasut@gmail.com marek.vasut@gmail.com; sr@denx.de sr@denx.de; patrice.chotard@st.com patrice.chotard@st.com; afd@ti.com afd@ti.com; horatiu.vultur@microchip.com horatiu.vultur@microchip.com; narmstrong@baylibre.com narmstrong@baylibre.com; ryder.lee@mediatek.com ryder.lee@mediatek.com; igor.opaniuk@gmail.com igor.opaniuk@gmail.com; patrick.delaunay@st.com patrick.delaunay@st.com; eugen.hristev@microchip.com eugen.hristev@microchip.com; judge.packham@gmail.com judge.packham@gmail.com; yamada.masahiro@socionext.com yamada.masahiro@socionext.com; swarren@nvidia.com swarren@nvidia.com; michal.simek@xilinx.com michal.simek@xilinx.com; u-boot@lists.denx.de u-boot@lists.denx.de; Andy Shevchenko andriy.shevchenko@linux.intel.com 主题: Re: [PATCH v3] arm: add acpi support for the arm
Hi Simon,
Hi Heinrich,
On Mon, Nov 25, 2019 at 4:09 AM Steven Hao steven_hao5189@outlook.com wrote:
Please, avoid using top-posting.
Dear Bin:
That's exactly what refactoring means: move the stuff to be used in generic fashion.
participants (5)
Andy Shevchenko
Bin Meng
Steven Hao
