[PATCH] imx8m: lock id_swap_bypass bit in tzc380 enable
According to TRM for i.MX8M Nano and Plus, GPR10 register contains lock bit for TZASC_ID_SWAP_BYPASS bit. This bit is required to be set in order to avoid AXI bus errors when GPU is enabled on the platform. TZASC_ID_SWAP_BYPASS bit is alread set for all imx8m applicable derivatives, but is missing a lock settings to be applied.
Set the TZASC_ID_SWAP_BYPASS_LOCK bit for those derivatives which have it implemented.
Since we're here, provide also names to bits from TRM instead of using BIT() macro in the code.
Fixes: deca6cfbf5d7 ("imx8mn: set BYPASS ID SWAP to avoid AXI bus errors") Fixes: a07c7181296f ("imx8mp: set BYPASS ID SWAP to avoid AXI bus errors") Signed-off-by: Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com Cc: Peng Fan peng.fan@nxp.com --- arch/arm/include/asm/arch-imx8m/imx-regs.h | 6 ++++-- arch/arm/mach-imx/imx8m/soc.c | 15 ++++++++++++++- 2 files changed, 18 insertions(+), 3 deletions(-)
diff --git a/arch/arm/include/asm/arch-imx8m/imx-regs.h b/arch/arm/include/asm/arch-imx8m/imx-regs.h index b800da13a1..45d95a7c19 100644 --- a/arch/arm/include/asm/arch-imx8m/imx-regs.h +++ b/arch/arm/include/asm/arch-imx8m/imx-regs.h @@ -80,8 +80,10 @@ #include <linux/bitops.h> #include <stdbool.h>
-#define GPR_TZASC_EN BIT(0) -#define GPR_TZASC_EN_LOCK BIT(16) +#define GPR_TZASC_EN BIT(0) +#define GPR_TZASC_ID_SWAP_BYPASS BIT(1) +#define GPR_TZASC_EN_LOCK BIT(16) +#define GPR_TZASC_ID_SWAP_BYPASS_LOCK BIT(17)
#define SRC_SCR_M4_ENABLE_OFFSET 3 #define SRC_SCR_M4_ENABLE_MASK BIT(3) diff --git a/arch/arm/mach-imx/imx8m/soc.c b/arch/arm/mach-imx/imx8m/soc.c index 863508776d..5f5175b4dd 100644 --- a/arch/arm/mach-imx/imx8m/soc.c +++ b/arch/arm/mach-imx/imx8m/soc.c @@ -66,8 +66,21 @@ void enable_tzc380(void) /* Enable TZASC and lock setting */ setbits_le32(&gpr->gpr[10], GPR_TZASC_EN); setbits_le32(&gpr->gpr[10], GPR_TZASC_EN_LOCK); + + /* + * According to TRM, TZASC_ID_SWAP_BYPASS should be set in + * order to avoid AXI Bus errors when GPU is in use + */ if (is_imx8mm() || is_imx8mn() || is_imx8mp()) - setbits_le32(&gpr->gpr[10], BIT(1)); + setbits_le32(&gpr->gpr[10], GPR_TZASC_ID_SWAP_BYPASS); + + /* + * imx8mn and imx8mp implements the lock bit for + * TZASC_ID_SWAP_BYPASS, enable it to lock settings + */ + if (is_imx8mn() || is_imx8mp()) + setbits_le32(&gpr->gpr[10], GPR_TZASC_ID_SWAP_BYPASS_LOCK); + /* * set Region 0 attribute to allow secure and non-secure * read/write permission. Found some masters like usb dwc3
base-commit: 21a1439d986a889cefbc2ed785c3f592fc9266de
According to TRM for i.MX8M Nano and Plus, GPR10 register contains lock bit for TZASC_ID_SWAP_BYPASS bit. This bit is required to be set in order to avoid AXI bus errors when GPU is enabled on the platform. TZASC_ID_SWAP_BYPASS bit is alread set for all imx8m applicable derivatives, but is missing a lock settings to be applied. Set the TZASC_ID_SWAP_BYPASS_LOCK bit for those derivatives which have it implemented. Since we're here, provide also names to bits from TRM instead of using BIT() macro in the code. Fixes: deca6cfbf5d7 ("imx8mn: set BYPASS ID SWAP to avoid AXI bus errors") Fixes: a07c7181296f ("imx8mp: set BYPASS ID SWAP to avoid AXI bus errors") Signed-off-by: Andrey Zhizhikin andrey.zhizhikin@leica-geosystems.com Cc: Peng Fan peng.fan@nxp.com
Best regards, Stefano Babic
Andrey Zhizhikin
sbabic@denx.de
