[PATCH 01/15] gpio: mpc8xxx_gpio: fix a bug on ls1046ardb
Fix a bug as belows, => gpio status -a "Synchronous Abort" handler, esr 0x96000061 elr: 0000000082047964 lr : 0000000082047960 (reloc) elr: 00000000fbd72964 lr : 00000000fbd72960 x0 : 00000000ffffffff x1 : 000000000000000a x2 : 0000000000000020 x3 : 0000000000000001 x4 : 0000000000000000 x5 : 0000000000000030 x6 : 0000000000000020 x7 : 0000000000000002 x8 : 00000000ffffffe0 x9 : 0000000000000008 x10: 0000000000000010 x11: 0000000000000006 x12: 000000000001869f x13: 0000000000000230 x14: 00000000fbc23e9c x15: 00000000ffffffff ... reseting
Signed-off-by: Biwen Li biwen.li@nxp.com --- .../asm/arch-fsl-layerscape/immap_lsch3.h | 10 +++++ drivers/gpio/mpc8xxx_gpio.c | 45 +++---------------- 2 files changed, 17 insertions(+), 38 deletions(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index baa9fa8529..3d02004036 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -589,5 +589,15 @@ struct ccsr_serdes { u8 res5[0x19fc - 0xa00]; };
+struct ccsr_gpio { + u32 gpdir; + u32 gpodr; + u32 gpdat; + u32 gpier; + u32 gpimr; + u32 gpicr; + u32 gpibe; +}; + #endif /*__ASSEMBLY__ */ #endif /* __ARCH_FSL_LSCH3_IMMAP_H_ */ diff --git a/drivers/gpio/mpc8xxx_gpio.c b/drivers/gpio/mpc8xxx_gpio.c index 27881a7322..e7fc45d4f5 100644 --- a/drivers/gpio/mpc8xxx_gpio.c +++ b/drivers/gpio/mpc8xxx_gpio.c @@ -16,16 +16,6 @@ #include <asm/io.h> #include <dm/of_access.h>
-struct ccsr_gpio { - u32 gpdir; - u32 gpodr; - u32 gpdat; - u32 gpier; - u32 gpimr; - u32 gpicr; - u32 gpibe; -}; - struct mpc8xxx_gpio_data { /* The bank's register base in memory */ struct ccsr_gpio __iomem *base; @@ -187,32 +177,11 @@ static int mpc8xxx_gpio_ofdata_to_platdata(struct udevice *dev) { struct mpc8xxx_gpio_plat *plat = dev_get_platdata(dev); struct mpc8xxx_gpio_data *data = dev_get_priv(dev); - fdt_addr_t addr; - u32 i; - u32 reg[4];
- if (ofnode_read_bool(dev->node, "little-endian")) + if (dev_read_bool(dev, "little-endian")) data->little_endian = true;
- if (data->little_endian) - dev_read_u32_array(dev, "reg", reg, 4); - else - dev_read_u32_array(dev, "reg", reg, 2); - - if (data->little_endian) { - for (i = 0; i < 2; i++) - reg[i] = be32_to_cpu(reg[i]); - } - - addr = dev_translate_address(dev, reg); - - plat->addr = addr; - - if (data->little_endian) - plat->size = reg[3]; - else - plat->size = reg[1]; - + plat->addr = (ulong)dev_read_addr_size_index(dev, 0 , (fdt_size_t *)&plat->size); plat->ngpios = dev_read_u32_default(dev, "ngpios", 32);
return 0; @@ -257,11 +226,11 @@ static int mpc8xxx_gpio_probe(struct udevice *dev) if (!str) return -ENOMEM;
- if (ofnode_device_is_compatible(dev->node, "fsl,qoriq-gpio")) { - unsigned long gpibe = data->addr + sizeof(struct ccsr_gpio) - - sizeof(u32); - - out_be32((unsigned int *)gpibe, 0xffffffff); + if (device_is_compatible(dev, "fsl,qoriq-gpio")) { + if (data->little_endian) + out_le32(&data->base->gpibe, 0xffffffff); + else + out_be32(&data->base->gpibe, 0xffffffff); }
uc_priv->bank_name = str;
Add gpio node for SoC LS1021A
Signed-off-by: Biwen Li biwen.li@nxp.com --- arch/arm/dts/ls1021a.dtsi | 40 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 40 insertions(+)
diff --git a/arch/arm/dts/ls1021a.dtsi b/arch/arm/dts/ls1021a.dtsi index 0eeec43ccc..7b99ce02b3 100644 --- a/arch/arm/dts/ls1021a.dtsi +++ b/arch/arm/dts/ls1021a.dtsi @@ -98,6 +98,46 @@ bus-width = <4>; };
+ gpio0: gpio@2300000 { + compatible = "fsl,ls1021a-gpio", "fsl,qoriq-gpio"; + reg = <0x0 0x2300000 0x0 0x10000>; + interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio1: gpio@2310000 { + compatible = "fsl,ls1021a-gpio", "fsl,qoriq-gpio"; + reg = <0x0 0x2310000 0x0 0x10000>; + interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio2: gpio@2320000 { + compatible = "fsl,ls1021a-gpio", "fsl,qoriq-gpio"; + reg = <0x0 0x2320000 0x0 0x10000>; + interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio3: gpio@2330000 { + compatible = "fsl,ls1021a-gpio", "fsl,qoriq-gpio"; + reg = <0x0 0x2330000 0x0 0x10000>; + interrupts = <GIC_SPI 166 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + scfg: scfg@1570000 { compatible = "fsl,ls1021a-scfg", "syscon"; reg = <0x1570000 0x10000>;
Add gpio node for SoC LS1012A
Signed-off-by: Biwen Li biwen.li@nxp.com --- arch/arm/dts/fsl-ls1012a.dtsi | 20 ++++++++++++++++++++ 1 file changed, 20 insertions(+)
diff --git a/arch/arm/dts/fsl-ls1012a.dtsi b/arch/arm/dts/fsl-ls1012a.dtsi index 2d70c82a72..b1a616ed84 100644 --- a/arch/arm/dts/fsl-ls1012a.dtsi +++ b/arch/arm/dts/fsl-ls1012a.dtsi @@ -70,6 +70,26 @@ bus-width = <4>; };
+ gpio0: gpio@2300000 { + compatible = "fsl,qoriq-gpio"; + reg = <0x0 0x2300000 0x0 0x10000>; + interrupts = <0 66 0x4>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio1: gpio@2310000 { + compatible = "fsl,qoriq-gpio"; + reg = <0x0 0x2310000 0x0 0x10000>; + interrupts = <0 67 0x4>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + i2c0: i2c@2180000 { compatible = "fsl,vf610-i2c"; #address-cells = <1>;
Add gpio node for SoC LS1028A
Signed-off-by: Biwen Li biwen.li@nxp.com --- arch/arm/dts/fsl-ls1028a.dtsi | 33 +++++++++++++++++++++++++++++++++ 1 file changed, 33 insertions(+)
diff --git a/arch/arm/dts/fsl-ls1028a.dtsi b/arch/arm/dts/fsl-ls1028a.dtsi index bf6373d5ec..64e75c637d 100644 --- a/arch/arm/dts/fsl-ls1028a.dtsi +++ b/arch/arm/dts/fsl-ls1028a.dtsi @@ -380,6 +380,39 @@ status = "disabled"; };
+ gpio0: gpio@2300000 { + compatible = "fsl,ls1028a-gpio","fsl,qoriq-gpio"; + reg = <0x0 0x2300000 0x0 0x10000>; + interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + little-endian; + }; + + gpio1: gpio@2310000 { + compatible = "fsl,ls1028a-gpio","fsl,qoriq-gpio"; + reg = <0x0 0x2310000 0x0 0x10000>; + interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + little-endian; + }; + + gpio2: gpio@2320000 { + compatible = "fsl,ls1028a-gpio","fsl,qoriq-gpio"; + reg = <0x0 0x2320000 0x0 0x10000>; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + little-endian; + }; + sata: sata@3200000 { compatible = "fsl,ls1028a-ahci"; reg = <0x0 0x3200000 0x0 0x10000 /* ccsr sata base */
Add gpio node for SoC LS1043A
Signed-off-by: Biwen Li biwen.li@nxp.com --- arch/arm/dts/fsl-ls1043a.dtsi | 40 +++++++++++++++++++++++++++++++++++ 1 file changed, 40 insertions(+)
diff --git a/arch/arm/dts/fsl-ls1043a.dtsi b/arch/arm/dts/fsl-ls1043a.dtsi index f7db44c0fa..96286104f2 100644 --- a/arch/arm/dts/fsl-ls1043a.dtsi +++ b/arch/arm/dts/fsl-ls1043a.dtsi @@ -78,6 +78,46 @@ bus-width = <4>; };
+ gpio0: gpio@2300000 { + compatible = "fsl,ls1043a-gpio", "fsl,qoriq-gpio"; + reg = <0x0 0x2300000 0x0 0x10000>; + interrupts = <0 66 0x4>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio1: gpio@2310000 { + compatible = "fsl,ls1043a-gpio", "fsl,qoriq-gpio"; + reg = <0x0 0x2310000 0x0 0x10000>; + interrupts = <0 67 0x4>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio2: gpio@2320000 { + compatible = "fsl,ls1043a-gpio", "fsl,qoriq-gpio"; + reg = <0x0 0x2320000 0x0 0x10000>; + interrupts = <0 68 0x4>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio3: gpio@2330000 { + compatible = "fsl,ls1043a-gpio", "fsl,qoriq-gpio"; + reg = <0x0 0x2330000 0x0 0x10000>; + interrupts = <0 134 0x4>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + ifc: ifc@1530000 { compatible = "fsl,ifc", "simple-bus"; reg = <0x0 0x1530000 0x0 0x10000>;
Add gpio node for SoC LS1046A
Signed-off-by: Biwen Li biwen.li@nxp.com --- arch/arm/dts/fsl-ls1046a.dtsi | 40 +++++++++++++++++++++++++++++++++++ 1 file changed, 40 insertions(+)
diff --git a/arch/arm/dts/fsl-ls1046a.dtsi b/arch/arm/dts/fsl-ls1046a.dtsi index 3f11d6cd18..bffa6d1469 100644 --- a/arch/arm/dts/fsl-ls1046a.dtsi +++ b/arch/arm/dts/fsl-ls1046a.dtsi @@ -78,6 +78,46 @@ bus-width = <4>; };
+ gpio0: gpio@2300000 { + compatible = "fsl,qoriq-gpio"; + reg = <0x0 0x2300000 0x0 0x10000>; + interrupts = <0 66 4>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio1: gpio@2310000 { + compatible = "fsl,qoriq-gpio"; + reg = <0x0 0x2310000 0x0 0x10000>; + interrupts = <0 67 4>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio2: gpio@2320000 { + compatible = "fsl,qoriq-gpio"; + reg = <0x0 0x2320000 0x0 0x10000>; + interrupts = <0 68 4>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio3: gpio@2330000 { + compatible = "fsl,qoriq-gpio"; + reg = <0x0 0x2330000 0x0 0x10000>; + interrupts = <0 134 4>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + ifc: ifc@1530000 { compatible = "fsl,ifc", "simple-bus"; reg = <0x0 0x1530000 0x0 0x10000>;
Add gpio node for SoC LS1088A
Signed-off-by: Biwen Li biwen.li@nxp.com --- arch/arm/dts/fsl-ls1088a.dtsi | 46 +++++++++++++++++++++++++++++++++++ 1 file changed, 46 insertions(+)
diff --git a/arch/arm/dts/fsl-ls1088a.dtsi b/arch/arm/dts/fsl-ls1088a.dtsi index 6653794d1c..3e5b310437 100644 --- a/arch/arm/dts/fsl-ls1088a.dtsi +++ b/arch/arm/dts/fsl-ls1088a.dtsi @@ -3,7 +3,9 @@ * NXP ls1088a SOC common device tree source * * Copyright 2017 NXP + * Copyright 2020 NXP */ +#include <dt-bindings/interrupt-controller/arm-gic.h>
/ { compatible = "fsl,ls1088a"; @@ -115,6 +117,50 @@ bus-width = <4>; };
+ gpio0: gpio@2300000 { + compatible = "fsl,ls1088a-gpio", "fsl,qoriq-gpio"; + reg = <0x0 0x2300000 0x0 0x10000>; + interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; + little-endian; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio1: gpio@2310000 { + compatible = "fsl,ls1088a-gpio", "fsl,qoriq-gpio"; + reg = <0x0 0x2310000 0x0 0x10000>; + interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; + little-endian; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio2: gpio@2320000 { + compatible = "fsl,ls1088a-gpio", "fsl,qoriq-gpio"; + reg = <0x0 0x2320000 0x0 0x10000>; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; + little-endian; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio3: gpio@2330000 { + compatible = "fsl,ls1088a-gpio", "fsl,qoriq-gpio"; + reg = <0x0 0x2330000 0x0 0x10000>; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; + little-endian; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + ifc: ifc@1530000 { compatible = "fsl,ifc", "simple-bus"; reg = <0x0 0x2240000 0x0 0x20000>;
Add gpio node for SoC LS208xA
Signed-off-by: Biwen Li biwen.li@nxp.com --- arch/arm/dts/fsl-ls2080a.dtsi | 45 +++++++++++++++++++++++++++++++++++ 1 file changed, 45 insertions(+)
diff --git a/arch/arm/dts/fsl-ls2080a.dtsi b/arch/arm/dts/fsl-ls2080a.dtsi index 6b7bf8eb16..155caf4721 100644 --- a/arch/arm/dts/fsl-ls2080a.dtsi +++ b/arch/arm/dts/fsl-ls2080a.dtsi @@ -3,6 +3,7 @@ * Freescale ls2080a SOC common device tree source * * Copyright 2013-2015 Freescale Semiconductor, Inc. + * Copyright 2020 NXP */
/ { @@ -119,6 +120,50 @@ bus-width = <4>; };
+ gpio0: gpio@2300000 { + compatible = "fsl,ls2080a-gpio", "fsl,qoriq-gpio"; + reg = <0x0 0x2300000 0x0 0x10000>; + interrupts = <0 36 0x4>; /* Level high type */ + gpio-controller; + little-endian; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio1: gpio@2310000 { + compatible = "fsl,ls2080a-gpio", "fsl,qoriq-gpio"; + reg = <0x0 0x2310000 0x0 0x10000>; + interrupts = <0 36 0x4>; /* Level high type */ + gpio-controller; + little-endian; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio2: gpio@2320000 { + compatible = "fsl,ls2080a-gpio", "fsl,qoriq-gpio"; + reg = <0x0 0x2320000 0x0 0x10000>; + interrupts = <0 37 0x4>; /* Level high type */ + gpio-controller; + little-endian; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio3: gpio@2330000 { + compatible = "fsl,ls2080a-gpio", "fsl,qoriq-gpio"; + reg = <0x0 0x2330000 0x0 0x10000>; + interrupts = <0 37 0x4>; /* Level high type */ + gpio-controller; + little-endian; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + usb0: usb3@3100000 { compatible = "fsl,layerscape-dwc3"; reg = <0x0 0x3100000 0x0 0x10000>;
Enable CONFIG_MPC8XXX_GPIO for SoC LS1012A
Signed-off-by: Biwen Li biwen.li@nxp.com --- include/configs/ls1012a_common.h | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index 6cf6a31d76..5105f00992 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -62,6 +62,16 @@ #define CONFIG_I2C_DEFAULT_BUS_NUMBER 0 #endif
+/* GPIO */ +#ifdef CONFIG_DM_GPIO +#ifndef CONFIG_MPC8XXX_GPIO +#define CONFIG_MPC8XXX_GPIO +#endif +#ifndef CONFIG_CMD_GPIO +#define CONFIG_CMD_GPIO +#endif +#endif + #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK (get_serial_clock())
Enable CONFIG_MPC8XXX_GPIO for SoC LS1043A
Signed-off-by: Biwen Li biwen.li@nxp.com --- include/configs/ls1043a_common.h | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 96fdd6417e..76252a5c67 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -119,6 +119,16 @@
#endif
+/* GPIO */ +#ifdef CONFIG_DM_GPIO +#ifndef CONFIG_MPC8XXX_GPIO +#define CONFIG_MPC8XXX_GPIO +#endif +#ifndef CONFIG_CMD_GPIO +#define CONFIG_CMD_GPIO +#endif +#endif + /* IFC */ #ifndef SPL_NO_IFC #if defined(CONFIG_TFABOOT) || \
-----Original Message----- From: Biwen Li biwen.li@oss.nxp.com Sent: Friday, October 16, 2020 2:42 PM To: Priyanka Jain priyanka.jain@nxp.com Cc: Jiafei Pan jiafei.pan@nxp.com; u-boot@lists.denx.de; Xiaobo Xie xiaobo.xie@nxp.com; Biwen Li biwen.li@nxp.com Subject: [PATCH 10/15] configs: ls1043a: enable CONFIG_MPC8XXX_GPIO
#endif
2.17.1
Kindly fix below checkpatch error and similar error in other patches of this series:
ERROR: All commands are managed by Kconfig #27: FILE: include/configs/ls1043a_common.h:128: +#define CONFIG_CMD_GPIO
total: 1 errors, 0 warnings, 0 checks, 16 lines checked
Regards Priyanka
Enable CONFIG_MPC8XXX_GPIO for SoC LS1028A
Signed-off-by: Biwen Li biwen.li@nxp.com --- include/configs/ls1028a_common.h | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/include/configs/ls1028a_common.h b/include/configs/ls1028a_common.h index 8345cd7acf..c89e7b5f3d 100644 --- a/include/configs/ls1028a_common.h +++ b/include/configs/ls1028a_common.h @@ -36,6 +36,16 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2048 * 1024)
+/* GPIO */ +#ifdef CONFIG_DM_GPIO +#ifndef CONFIG_MPC8XXX_GPIO +#define CONFIG_MPC8XXX_GPIO +#endif +#ifndef CONFIG_CMD_GPIO +#define CONFIG_CMD_GPIO +#endif +#endif + /* I2C */ #ifndef CONFIG_DM_I2C #define CONFIG_SYS_I2C
-----Original Message----- From: Biwen Li biwen.li@oss.nxp.com Sent: Friday, October 16, 2020 2:42 PM To: Priyanka Jain priyanka.jain@nxp.com Cc: Jiafei Pan jiafei.pan@nxp.com; u-boot@lists.denx.de; Xiaobo Xie xiaobo.xie@nxp.com; Biwen Li biwen.li@nxp.com Subject: [PATCH 11/15] configs: ls1028a: enable CONFIG_MPC8XXX_GPIO
2.17.1
Kindly fix below checkpatch error:
ERROR: All commands are managed by Kconfig #27: FILE: include/configs/ls1028a_common.h:45: +#define CONFIG_CMD_GPIO
Regards Priyanka
Enable CONFIG_MPC8XXX_GPIO for LS1088A
Signed-off-by: Biwen Li biwen.li@nxp.com --- include/configs/ls1088a_common.h | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index f9e349871c..4ef840d89e 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -53,6 +53,16 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2048 * 1024)
-----Original Message----- From: Biwen Li biwen.li@oss.nxp.com Sent: Friday, October 16, 2020 2:42 PM To: Priyanka Jain priyanka.jain@nxp.com Cc: Jiafei Pan jiafei.pan@nxp.com; u-boot@lists.denx.de; Xiaobo Xie xiaobo.xie@nxp.com; Biwen Li biwen.li@nxp.com Subject: [PATCH 12/15] configs: ls1088a: enable CONFIG_MPC8XXX_GPIO
2.17.1
Kindly fix below checkpatch error: ERROR: All commands are managed by Kconfig #29: FILE: include/configs/ls1088a_common.h:62: +#define CONFIG_CMD_GPIO
Regards Priyanka
Enable CONFIG_MPC8XXX_GPIO for LS208xA
Signed-off-by: Biwen Li biwen.li@nxp.com --- include/configs/ls2080a_common.h | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 444bb8c3b5..3631418f29 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -66,6 +66,16 @@ /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2048 * 1024)
-----Original Message----- From: Biwen Li biwen.li@oss.nxp.com Sent: Friday, October 16, 2020 2:42 PM To: Priyanka Jain priyanka.jain@nxp.com Cc: Jiafei Pan jiafei.pan@nxp.com; u-boot@lists.denx.de; Xiaobo Xie xiaobo.xie@nxp.com; Biwen Li biwen.li@nxp.com Subject: [PATCH 13/15] configs: ls208xa: enable CONFIG_MPC8XXX_GPIO
2.17.1
Kindly fix below checkpatch error: ERROR: All commands are managed by Kconfig #29: FILE: include/configs/ls2080a_common.h:75: +#define CONFIG_CMD_GPIO
Regards Priyanka
Enable CONFIG_MPC8XXX_GPIO for SoC LX2160A
Signed-off-by: Biwen Li biwen.li@nxp.com --- include/configs/lx2160a_common.h | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/include/configs/lx2160a_common.h b/include/configs/lx2160a_common.h index 0017ac5773..fe79d91f33 100644 --- a/include/configs/lx2160a_common.h +++ b/include/configs/lx2160a_common.h @@ -158,6 +158,16 @@ #define NXP_FSPI_FLASH_NUM 1 #endif
+/* GPIO */ +#ifdef CONFIG_DM_GPIO +#ifndef CONFIG_MPC8XXX_GPIO +#define CONFIG_MPC8XXX_GPIO +#endif +#ifndef CONFIG_CMD_GPIO +#define CONFIG_CMD_GPIO +#endif +#endif + #ifndef __ASSEMBLY__ unsigned long get_board_sys_clk(void); unsigned long get_board_ddr_clk(void);
-----Original Message----- From: Biwen Li biwen.li@oss.nxp.com Sent: Friday, October 16, 2020 2:42 PM To: Priyanka Jain priyanka.jain@nxp.com Cc: Jiafei Pan jiafei.pan@nxp.com; u-boot@lists.denx.de; Xiaobo Xie xiaobo.xie@nxp.com; Biwen Li biwen.li@nxp.com Subject: [PATCH 14/15] configs: lx2160a: enable CONFIG_MPC8XXX_GPIO
#ifndef __ASSEMBLY__ unsigned long get_board_sys_clk(void); unsigned long get_board_ddr_clk(void); -- 2.17.1
ERROR: All commands are managed by Kconfig #27: FILE: include/configs/lx2160a_common.h:169: +#define CONFIG_CMD_GPIO
Regards Priyanka
Enable MPC8XXX_GPIO for SoC LS1046A
Signed-off-by: Biwen Li biwen.li@nxp.com --- include/configs/ls1046a_common.h | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index d44a7f105e..06b4d91676 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -126,6 +126,16 @@ #define CONFIG_SYS_MONITOR_LEN 0xa0000 #endif
-----Original Message----- From: Biwen Li biwen.li@oss.nxp.com Sent: Friday, October 16, 2020 2:42 PM To: Priyanka Jain priyanka.jain@nxp.com Cc: Jiafei Pan jiafei.pan@nxp.com; u-boot@lists.denx.de; Xiaobo Xie xiaobo.xie@nxp.com; Biwen Li biwen.li@nxp.com Subject: [PATCH 15/15] configs: ls1046a: enable MPC8XXX_GPIO
2.17.1
ERROR: All commands are managed by Kconfig #27: FILE: include/configs/ls1046a_common.h:135: +#define CONFIG_CMD_GPIO
Regards Priyanka
Hi Priyanka,
These patches depend on the patch("[V3] gpio: mpc8xxx: support fsl-layerscape platform" , https://patchwork.ozlabs.org/project/uboot/patch/20200924134050.8618-1-hui.s...),
Best Regads, Biwen Li
To: Priyanka Jain priyanka.jain@nxp.com Cc: Jiafei Pan jiafei.pan@nxp.com; u-boot@lists.denx.de; Xiaobo Xie xiaobo.xie@nxp.com; Biwen Li biwen.li@nxp.com Subject: [PATCH 01/15] gpio: mpc8xxx_gpio: fix a bug on ls1046ardb
+struct ccsr_gpio {
- u32 gpdir;
- u32 gpodr;
- u32 gpdat;
- u32 gpier;
- u32 gpimr;
- u32 gpicr;
- u32 gpibe;
-struct ccsr_gpio {
- u32 gpdir;
- u32 gpodr;
- u32 gpdat;
- u32 gpier;
- u32 gpimr;
- u32 gpicr;
- u32 gpibe;
fdt_addr_t addr;
u32 i;
u32 reg[4];
- if (dev_read_bool(dev, "little-endian")) data->little_endian = true;
- else
- else
- plat->addr = (ulong)dev_read_addr_size_index(dev, 0 , (fdt_size_t
+*)&plat->size); plat->ngpios = dev_read_u32_default(dev, "ngpios", 32);
- sizeof(u32);
else
-- 2.17.1
Biwen Li
Biwen Li
Priyanka Jain
