[PATCH 0/3] xilinx: Swith platforms to DM_ETH_PHY
This patch series adds support for shared MDIO by using generic phy framework. Also enable DM_ETH_PHY config for all xilinx platforms.
Thanks, Michal
T Karthik Reddy (3): net: xilinx: axi_emac: Use shared MDIO bus support for axi emac driver net: xilinx: axi_emaclite: Use shared MDIO bus support for axi emaclite driver xilinx: Add CONFIG_DM_ETH_PHY config
configs/microblaze-generic_defconfig | 1 + configs/xilinx_versal_virt_defconfig | 1 + configs/xilinx_zynq_virt_defconfig | 1 + configs/xilinx_zynqmp_virt_defconfig | 1 + drivers/net/xilinx_axi_emac.c | 38 ++++++++++++++++-------- drivers/net/xilinx_emaclite.c | 43 ++++++++++++++++++---------- 6 files changed, 58 insertions(+), 27 deletions(-)
CONFIG_DM_ETH_PHY enables support to utilize generic ethernet phy framework. Though if ethernet PHY node is in other ethernet node, it will use shared MDIO to access the PHY of other ethernet. Move ethernet print info statement from plat function to probe function, as phyaddr is not enumerated when CONFIG_DM_ETH_PHY is enabled.
Signed-off-by: T Karthik Reddy t.karthik.reddy@xilinx.com Signed-off-by: Michal Simek michal.simek@amd.com ---
drivers/net/xilinx_axi_emac.c | 38 ++++++++++++++++++++++++----------- 1 file changed, 26 insertions(+), 12 deletions(-)
diff --git a/drivers/net/xilinx_axi_emac.c b/drivers/net/xilinx_axi_emac.c index a4715735c3c4..04277b1269f3 100644 --- a/drivers/net/xilinx_axi_emac.c +++ b/drivers/net/xilinx_axi_emac.c @@ -19,6 +19,7 @@ #include <miiphy.h> #include <wait_bit.h> #include <linux/delay.h> +#include <eth_phy.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -295,6 +296,9 @@ static int axiemac_phy_init(struct udevice *dev) /* Set default MDIO divisor */ writel(XAE_MDIO_DIV_DFT | XAE_MDIO_MC_MDIOEN_MASK, ®s->mdio_mc);
+ if (IS_ENABLED(CONFIG_DM_ETH_PHY)) + priv->phyaddr = eth_phy_get_addr(dev); + if (priv->phyaddr == -1) { /* Detect the PHY address */ for (i = 31; i >= 0; i--) { @@ -778,18 +782,29 @@ static int axi_emac_probe(struct udevice *dev) priv->phy_of_handle = plat->phy_of_handle; priv->interface = pdata->phy_interface;
- priv->bus = mdio_alloc(); - priv->bus->read = axiemac_miiphy_read; - priv->bus->write = axiemac_miiphy_write; - priv->bus->priv = priv; + if (IS_ENABLED(CONFIG_DM_ETH_PHY)) + priv->bus = eth_phy_get_mdio_bus(dev);
- ret = mdio_register_seq(priv->bus, dev_seq(dev)); - if (ret) - return ret; + if (!priv->bus) { + priv->bus = mdio_alloc(); + priv->bus->read = axiemac_miiphy_read; + priv->bus->write = axiemac_miiphy_write; + priv->bus->priv = priv; + + ret = mdio_register_seq(priv->bus, dev_seq(dev)); + if (ret) + return ret; + } + + if (IS_ENABLED(CONFIG_DM_ETH_PHY)) + eth_phy_set_mdio_bus(dev, priv->bus);
axiemac_phy_init(dev); }
+ printf("AXI EMAC: %lx, phyaddr %d, interface %s\n", (ulong)pdata->iobase, + priv->phyaddr, phy_string_for_interface(pdata->phy_interface)); + return 0; }
@@ -844,8 +859,10 @@ static int axi_emac_of_to_plat(struct udevice *dev) offset = fdtdec_lookup_phandle(gd->fdt_blob, node, "phy-handle"); if (offset > 0) { - plat->phyaddr = fdtdec_get_int(gd->fdt_blob, offset, - "reg", -1); + if (!(IS_ENABLED(CONFIG_DM_ETH_PHY))) + plat->phyaddr = fdtdec_get_int(gd->fdt_blob, + offset, + "reg", -1); plat->phy_of_handle = offset; }
@@ -857,9 +874,6 @@ static int axi_emac_of_to_plat(struct udevice *dev) "xlnx,eth-hasnobuf"); }
- printf("AXI EMAC: %lx, phyaddr %d, interface %s\n", (ulong)pdata->iobase, - plat->phyaddr, phy_string_for_interface(pdata->phy_interface)); - return 0; }
if (ret)
return ret;
if (!priv->bus) {
if (ret)
return ret;
eth_phy_set_mdio_bus(dev, priv->bus); axiemac_phy_init(dev); }
"reg", -1);
offset,
-- 2.36.0
Reviewed-by: Ramon Fried rfried.dev@gmail.com
drivers/net/xilinx_emaclite.c | 43 +++++++++++++++++++++++------------ 1 file changed, 28 insertions(+), 15 deletions(-)
diff --git a/drivers/net/xilinx_emaclite.c b/drivers/net/xilinx_emaclite.c index 43fc36dc6a82..6c9f1f7c2728 100644 --- a/drivers/net/xilinx_emaclite.c +++ b/drivers/net/xilinx_emaclite.c @@ -22,6 +22,7 @@ #include <linux/errno.h> #include <linux/kernel.h> #include <asm/io.h> +#include <eth_phy.h>
@@ -564,14 +565,27 @@ static int emaclite_probe(struct udevice *dev) struct xemaclite *emaclite = dev_get_priv(dev); int ret;
- emaclite->bus = mdio_alloc(); - emaclite->bus->read = emaclite_miiphy_read; - emaclite->bus->write = emaclite_miiphy_write; - emaclite->bus->priv = emaclite; + if (IS_ENABLED(CONFIG_DM_ETH_PHY)) + emaclite->bus = eth_phy_get_mdio_bus(dev);
- ret = mdio_register_seq(emaclite->bus, dev_seq(dev)); - if (ret) - return ret; + if (!emaclite->bus) { + emaclite->bus = mdio_alloc(); + emaclite->bus->read = emaclite_miiphy_read; + emaclite->bus->write = emaclite_miiphy_write; + emaclite->bus->priv = emaclite; + + ret = mdio_register_seq(emaclite->bus, dev_seq(dev)); + if (ret) + return ret; + } + + if (IS_ENABLED(CONFIG_DM_ETH_PHY)) { + eth_phy_set_mdio_bus(dev, emaclite->bus); + emaclite->phyaddr = eth_phy_get_addr(dev); + } + + printf("EMACLITE: %lx, phyaddr %d, %d/%d\n", (ulong)emaclite->regs, + emaclite->phyaddr, emaclite->txpp, emaclite->rxpp);
return 0; } @@ -606,20 +620,19 @@ static int emaclite_of_to_plat(struct udevice *dev)
emaclite->phyaddr = -1;
- offset = fdtdec_lookup_phandle(gd->fdt_blob, dev_of_offset(dev), - "phy-handle"); - if (offset > 0) - emaclite->phyaddr = fdtdec_get_int(gd->fdt_blob, offset, - "reg", -1); + if (!(IS_ENABLED(CONFIG_DM_ETH_PHY))) { + offset = fdtdec_lookup_phandle(gd->fdt_blob, dev_of_offset(dev), + "phy-handle"); + if (offset > 0) + emaclite->phyaddr = fdtdec_get_int(gd->fdt_blob, + offset, "reg", -1); + }
emaclite->txpp = fdtdec_get_int(gd->fdt_blob, dev_of_offset(dev), "xlnx,tx-ping-pong", 0); emaclite->rxpp = fdtdec_get_int(gd->fdt_blob, dev_of_offset(dev), "xlnx,rx-ping-pong", 0);
- printf("EMACLITE: %lx, phyaddr %d, %d/%d\n", (ulong)emaclite->regs, - emaclite->phyaddr, emaclite->txpp, emaclite->rxpp); - return 0; }
if (ret)
return ret;
if (ret)
return ret;
emaclite->phyaddr, emaclite->txpp, emaclite->rxpp); return 0;
"phy-handle");
if (offset > 0)
"reg", -1);
"phy-handle");
if (offset > 0)
offset, "reg", -1);
} emaclite->txpp = fdtdec_get_int(gd->fdt_blob, dev_of_offset(dev), "xlnx,tx-ping-pong", 0); emaclite->rxpp = fdtdec_get_int(gd->fdt_blob, dev_of_offset(dev), "xlnx,rx-ping-pong", 0);
-- 2.36.0
Enable CONFIG_DM_ETH_PHY to utilize shared MDIO bus support on all xilinx platforms.
configs/microblaze-generic_defconfig | 1 + configs/xilinx_versal_virt_defconfig | 1 + configs/xilinx_zynq_virt_defconfig | 1 + configs/xilinx_zynqmp_virt_defconfig | 1 + 4 files changed, 4 insertions(+)
diff --git a/configs/microblaze-generic_defconfig b/configs/microblaze-generic_defconfig index 3142b469c26b..7994110b28a7 100644 --- a/configs/microblaze-generic_defconfig +++ b/configs/microblaze-generic_defconfig @@ -76,6 +76,7 @@ CONFIG_PHY_NATSEMI=y CONFIG_PHY_REALTEK=y CONFIG_PHY_VITESSE=y CONFIG_DM_ETH=y +CONFIG_DM_ETH_PHY=y CONFIG_XILINX_AXIEMAC=y CONFIG_XILINX_EMACLITE=y CONFIG_SYS_NS16550=y diff --git a/configs/xilinx_versal_virt_defconfig b/configs/xilinx_versal_virt_defconfig index 38747ffd02cb..c9ae0185f8ad 100644 --- a/configs/xilinx_versal_virt_defconfig +++ b/configs/xilinx_versal_virt_defconfig @@ -92,6 +92,7 @@ CONFIG_PHY_REALTEK=y CONFIG_PHY_TI_DP83867=y CONFIG_PHY_VITESSE=y CONFIG_PHY_FIXED=y +CONFIG_DM_ETH_PHY=y CONFIG_PHY_GIGE=y CONFIG_XILINX_AXIEMAC=y CONFIG_XILINX_AXIMRMAC=y diff --git a/configs/xilinx_zynq_virt_defconfig b/configs/xilinx_zynq_virt_defconfig index 1f3e6a42a146..120bc29393d8 100644 --- a/configs/xilinx_zynq_virt_defconfig +++ b/configs/xilinx_zynq_virt_defconfig @@ -111,6 +111,7 @@ CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_PHY_REALTEK=y CONFIG_PHY_XILINX=y +CONFIG_DM_ETH_PHY=y CONFIG_MII=y CONFIG_ZYNQ_GEM=y CONFIG_ARM_DCC=y diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index 35894076c52f..abaebb8edaf2 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -160,6 +160,7 @@ CONFIG_PHY_TI_DP83867=y CONFIG_PHY_VITESSE=y CONFIG_PHY_XILINX_GMII2RGMII=y CONFIG_PHY_FIXED=y +CONFIG_DM_ETH_PHY=y CONFIG_XILINX_AXIEMAC=y CONFIG_ZYNQ_GEM=y CONFIG_DM_REGULATOR=y
Acked-for-series: Ashok Reddy Soma ashok.reddy.soma@xilinx.com
Thanks, Ashok
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Michal Simek Sent: Tuesday, May 10, 2022 4:56 PM To: u-boot@lists.denx.de; git git@xilinx.com Cc: Joe Hershberger joe.hershberger@ni.com; Ramon Fried rfried.dev@gmail.com Subject: [PATCH 0/3] xilinx: Swith platforms to DM_ETH_PHY
Thanks, Michal
-- 2.36.0
Ășt 10. 5. 2022 v 13:26 odesĂlatel Michal Simek monstr@monstr.eu napsal:
Thanks, Michal
-- 2.36.0
applied. M
Ashok Reddy Soma
Michal Simek
Ramon Fried
