[U-Boot] [PATCH] Kconfig: mvebu: use SPL instead of SPL_BUILD
SPL_BUILD is defined by Makefile.spl when building the SPL part of the image. It can't be used by Kconfig. SPL is known to Kconfig and is defined if the target uses an SPL. Make the condition for BUILD_TARGET depend on ARCH_MVEBU && SPL so that the overall build produces u-boot-spl.kwb.
Fixes: commit dc146ca11187 ("Kconfig: Migrate CONFIG_BUILD_TARGET")
Cc: Jagan Teki jagan@amarulasolutions.com Signed-off-by: Chris Packham judge.packham@gmail.com ---
Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/Kconfig b/Kconfig index 2a48f5325663..512c7beb89f9 100644 --- a/Kconfig +++ b/Kconfig @@ -227,7 +227,7 @@ config BUILD_ROM config BUILD_TARGET string "Build target special images" default "u-boot-with-spl.sfp" if ARCH_SOCFPGA - default "u-boot-spl.kwb" if ARCH_MVEBU && SPL_BUILD + default "u-boot-spl.kwb" if ARCH_MVEBU && SPL default "u-boot-elf.srec" if RCAR_GEN3 default "u-boot.itb" if SPL_LOAD_FIT && ARCH_SUNXI default "u-boot.kwb" if KIRKWOOD
Chris Packham
