[U-Boot] [PATCH 0/2] Add atomic write to fw_setenv for environments on filesystems
For environments stored on filesystems where you can't have a redundant configuration, rather than just over-writing the existing environment in fw_setenv, do the tradtional create temporary file, rename, sync, sync directory dance to achieve ACID semantics when writing through fw_setenv.
Note that this series triggers large numbers of checkpatch warnings because of the existing code style:
warning: space prohibited between function name and open parenthesis '(' check: Avoid CamelCase: <HaveRedundEnv>
Alex Kiernan (2): tools: env: Refactor write path of flash_io() tools: env: Implement atomic replace for filesystem
tools/env/fw_env.c | 159 ++++++++++++++++++++++++++++++++++++++++------------- 1 file changed, 121 insertions(+), 38 deletions(-)
Extract write path of flash_io() into a separate function. This patch should be a functional no-op.
Signed-off-by: Alex Kiernan alex.kiernan@gmail.com ---
tools/env/fw_env.c | 98 +++++++++++++++++++++++++++++------------------------- 1 file changed, 53 insertions(+), 45 deletions(-)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index 0e3e343..2df3504 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -1229,68 +1229,76 @@ static int flash_read (int fd) return 0; }
-static int flash_io (int mode) +static int flash_io_write (int fd_current) { - int fd_current, fd_target, rc, dev_target; + int fd_target, rc, dev_target;
- /* dev_current: fd_current, erase_current */ - fd_current = open (DEVNAME (dev_current), mode); - if (fd_current < 0) { - fprintf (stderr, - "Can't open %s: %s\n", - DEVNAME (dev_current), strerror (errno)); - return -1; + if (HaveRedundEnv) { + /* switch to next partition for writing */ + dev_target = !dev_current; + /* dev_target: fd_target, erase_target */ + fd_target = open (DEVNAME (dev_target), O_RDWR); + if (fd_target < 0) { + fprintf (stderr, + "Can't open %s: %s\n", + DEVNAME (dev_target), + strerror (errno)); + rc = -1; + goto exit; + } + } else { + dev_target = dev_current; + fd_target = fd_current; }
- if (mode == O_RDWR) { - if (HaveRedundEnv) { - /* switch to next partition for writing */ - dev_target = !dev_current; - /* dev_target: fd_target, erase_target */ - fd_target = open (DEVNAME (dev_target), mode); - if (fd_target < 0) { - fprintf (stderr, - "Can't open %s: %s\n", - DEVNAME (dev_target), - strerror (errno)); - rc = -1; - goto exit; - } - } else { - dev_target = dev_current; - fd_target = fd_current; - } + rc = flash_write (fd_current, fd_target, dev_target);
- rc = flash_write (fd_current, fd_target, dev_target); + if (fsync(fd_current) && + !(errno == EINVAL || errno == EROFS)) { + fprintf (stderr, + "fsync failed on %s: %s\n", + DEVNAME (dev_current), strerror (errno)); + }
- if (fsync(fd_current) && + if (HaveRedundEnv) { + if (fsync(fd_target) && !(errno == EINVAL || errno == EROFS)) { fprintf (stderr, "fsync failed on %s: %s\n", DEVNAME (dev_current), strerror (errno)); }
- if (HaveRedundEnv) { - if (fsync(fd_target) && - !(errno == EINVAL || errno == EROFS)) { - fprintf (stderr, - "fsync failed on %s: %s\n", - DEVNAME (dev_current), strerror (errno)); - } - - if (close (fd_target)) { - fprintf (stderr, - "I/O error on %s: %s\n", - DEVNAME (dev_target), - strerror (errno)); - rc = -1; - } + if (close (fd_target)) { + fprintf (stderr, + "I/O error on %s: %s\n", + DEVNAME (dev_target), + strerror (errno)); + rc = -1; } + } +exit: + return rc; +} + +static int flash_io (int mode) +{ + int fd_current, rc; + + /* dev_current: fd_current, erase_current */ + fd_current = open (DEVNAME (dev_current), mode); + if (fd_current < 0) { + fprintf (stderr, + "Can't open %s: %s\n", + DEVNAME (dev_current), strerror (errno)); + return -1; + } + + if (mode == O_RDWR) { + rc = flash_io_write(fd_current); } else { rc = flash_read (fd_current); }
-exit: if (close (fd_current)) { fprintf (stderr, "I/O error on %s: %s\n",
- int fd_target, rc, dev_target;
fprintf (stderr,
return -1;
fprintf (stderr,
strerror (errno));
rc = -1;
goto exit;
- } else {
}fd_target = fd_current;
fprintf (stderr,
strerror (errno));
rc = -1;
goto exit;
} else {
fprintf (stderr,
!(errno == EINVAL || errno == EROFS)) { fprintf (stderr, "fsync failed on %s: %s\n", DEVNAME (dev_current), strerror (errno)); }if (fsync(fd_target) &&
fprintf (stderr,
fprintf (stderr,
strerror (errno));
rc = -1;
fprintf (stderr,
strerror (errno));
}rc = -1;
+exit:
- return rc;
- int fd_current, rc;
fprintf (stderr,
return -1;
} else { rc = flash_read (fd_current); }rc = flash_io_write(fd_current);
Reviewed-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
If the U-Boot environment is stored in a regular file and redundant operation isn't set, then write to a temporary file and perform an atomic rename.
tools/env/fw_env.c | 81 ++++++++++++++++++++++++++++++++++++++++++++++++++++-- 1 file changed, 78 insertions(+), 3 deletions(-)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index 2df3504..b814c4e 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -14,6 +14,7 @@ #include <errno.h> #include <env_flags.h> #include <fcntl.h> +#include <libgen.h> #include <linux/fs.h> #include <linux/stringify.h> #include <ctype.h> @@ -1229,9 +1230,46 @@ static int flash_read (int fd) return 0; }
+static int flash_open_tempfile(const char **dname, const char **target_temp) +{ + char *dup_name = strdup(DEVNAME (dev_current)); + char *temp_name = NULL; + int rc = -1; + + if (!dup_name) + return -1; + + *dname = dirname(dup_name); + if (!*dname) + goto err; + + rc = asprintf(&temp_name, "%s/uboot.tmp", *dname); + if (rc == -1) + goto err; + + rc = open(temp_name, O_RDWR | O_CREAT | O_TRUNC, 0700); + if (rc == -1) { + /* fall back to in place write */ + free(temp_name); + } else { + *target_temp = temp_name; + /* deliberately leak dup_name as dname /might/ point into + * it and we need it for our caller + */ + dup_name = NULL; + } + +err: + if (dup_name) + free(dup_name); + + return rc; +} + static int flash_io_write (int fd_current) { - int fd_target, rc, dev_target; + int fd_target = -1, rc, dev_target; + const char *dname, *target_temp = NULL;
if (HaveRedundEnv) { /* switch to next partition for writing */ @@ -1247,8 +1285,17 @@ static int flash_io_write (int fd_current) goto exit; } } else { + struct stat sb; + + if (fstat(fd_current, &sb) == 0 && S_ISREG(sb.st_mode)) { + /* if any part of flash_open_tempfile() fails we fall + * back to in-place writes + */ + fd_target = flash_open_tempfile(&dname, &target_temp); + } dev_target = dev_current; - fd_target = fd_current; + if (fd_target == -1) + fd_target = fd_current; }
rc = flash_write (fd_current, fd_target, dev_target); @@ -1260,7 +1307,7 @@ static int flash_io_write (int fd_current) DEVNAME (dev_current), strerror (errno)); }
- if (HaveRedundEnv) { + if (fd_current != fd_target) { if (fsync(fd_target) && !(errno == EINVAL || errno == EROFS)) { fprintf (stderr, @@ -1275,6 +1322,34 @@ static int flash_io_write (int fd_current) strerror (errno)); rc = -1; } + + if (target_temp) { + int dir_fd; + + dir_fd = open(dname, O_DIRECTORY | O_RDONLY); + if (dir_fd == -1) + fprintf (stderr, + "Can't open %s: %s\n", + dname, strerror (errno)); + + if (rename(target_temp, DEVNAME(dev_target))) { + fprintf (stderr, + "rename failed %s => %s: %s\n", + target_temp, DEVNAME(dev_target), + strerror (errno)); + rc = -1; + } + + if (dir_fd != -1 && fsync(dir_fd)) + fprintf (stderr, + "fsync failed on %s: %s\n", + dname, strerror (errno)); + + if (dir_fd != -1 && close(dir_fd)) + fprintf (stderr, + "I/O error on %s: %s\n", + dname, strerror (errno)); + } } exit: return rc;
Hi alex,
Even if it is not explicitely set (IMHO it should), this code can be used as library and linked to own application. That means that concurrency can happens. I mean:
- char *dup_name = strdup(DEVNAME (dev_current));
- char *temp_name = NULL;
- int rc = -1;
- if (!dup_name)
return -1;
- *dname = dirname(dup_name);
- if (!*dname)
goto err;
- rc = asprintf(&temp_name, "%s/uboot.tmp", *dname);
Filename is fixed - should we not use mkstemp ?
- if (rc == -1)
goto err;
- rc = open(temp_name, O_RDWR | O_CREAT | O_TRUNC, 0700);
- if (rc == -1) {
free(temp_name);
- } else {
dup_name = NULL;
+err:
- if (dup_name)
free(dup_name);
- return rc;
struct stat sb;
dev_target = dev_current;}
- if (fd_current != fd_target) { if (fsync(fd_target) && !(errno == EINVAL || errno == EROFS)) { fprintf (stderr,
if (target_temp) {
int dir_fd;
if (dir_fd == -1)
fprintf (stderr,
fprintf (stderr,
strerror (errno));
rc = -1;
fprintf (stderr,
fprintf (stderr,
exit: return rc;
On Thu, Mar 8, 2018 at 5:04 PM, Stefano Babic sbabic@denx.de wrote:
Hi alex,
At this point you're writing the new environment, so we should hold a lock to avoid concurrent writes.
int rc = -1;
if (!dup_name)
return -1;
if (!*dname)
goto err;
I went round all the temp functions before in the end deciding to fix it. However it looks like I totally misread the contract that mkstemp delivers - I'd thought it didn't pass you the name back, but it clearly does; I'll go update it.
Hi alex,
This is already done, even if not in the way I like. tools/env/fw_env_main.c calls flock() to acquire the resource. This works using fw_printenv / fw_setenv, but not as library. Library's users as me have to provide themselves a lock before calling the fw_* functions.
int rc = -1;
if (!dup_name)
return -1;
if (!*dname)
goto err;
Hi alex,
True... that particular implementation also causes me a different problem in that it fails on a read-only fs and I have a need for a call to fw_printenv before the filesystem has gone read-write.
So, please, change the patches to match the U-Boot coding style.
Regards
Heinrich
Alex Kiernan
Stefano Babic
