[U-Boot] [PATCH] mpq101: initial support for Mercury Computer Systems MPQ101 board
Mpq101 is a RapidIO development board in AMC form factor, featuring MPC8548 processor, 512MB of hardwired DDR2 RAM and 128MB of hardwired NAND flash memory. USB controller is available, but not presently enabled.
Additional board information is available at: http://www.mc.com/products/boards/ensemble_mpq101_rapidio_powerquicc_iii.asp...
Signed-off-by: Alex Dubov oakad@yahoo.com --- board/mercury/mpq101/Makefile | 53 ++++++ board/mercury/mpq101/config.mk | 7 + board/mercury/mpq101/law.c | 54 ++++++ board/mercury/mpq101/mpq101.c | 167 ++++++++++++++++++ board/mercury/mpq101/tlb.c | 82 +++++++++ boards.cfg | 1 + include/configs/mpq101.h | 381 ++++++++++++++++++++++++++++++++++++++++ 7 files changed, 745 insertions(+), 0 deletions(-) create mode 100644 board/mercury/mpq101/Makefile create mode 100644 board/mercury/mpq101/config.mk create mode 100644 board/mercury/mpq101/law.c create mode 100644 board/mercury/mpq101/mpq101.c create mode 100644 board/mercury/mpq101/tlb.c create mode 100644 include/configs/mpq101.h
diff --git a/board/mercury/mpq101/Makefile b/board/mercury/mpq101/Makefile new file mode 100644 index 0000000..58bc1b3 --- /dev/null +++ b/board/mercury/mpq101/Makefile @@ -0,0 +1,53 @@ +# +# Copyright 2007 Freescale Semiconductor, Inc. +# (C) Copyright 2001-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += $(BOARD).o +COBJS-y += law.o +COBJS-y += tlb.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS)) + +clean: + rm -f $(OBJS) $(SOBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/mercury/mpq101/config.mk b/board/mercury/mpq101/config.mk new file mode 100644 index 0000000..1870680 --- /dev/null +++ b/board/mercury/mpq101/config.mk @@ -0,0 +1,7 @@ +# +# mpq101 board +# + +# Make room for environment at the beginning of flash sector +CONFIG_SYS_TEXT_BASE = 0xfffc0800 +LDFLAGS += --section-start=.ppcenv=$(CONFIG_ENV_ADDR) diff --git a/board/mercury/mpq101/law.c b/board/mercury/mpq101/law.c new file mode 100644 index 0000000..bc89bc5 --- /dev/null +++ b/board/mercury/mpq101/law.c @@ -0,0 +1,54 @@ +/* + * Copyright 2008 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/mmu.h> + +/* + * LAW(Local Access Window) configuration: + * + * 0x0000_0000 0x1fff_ffff DDR SYS_SDRAM_SIZE + * 0xc000_0000 0xdfff_ffff RapidIO 512M + * 0xe000_0000 0xe000_ffff CCSR 1M + * 0xf000_0000 0xffff_ffff LBC options + FLASH 256M + * + * Notes: + * CCSRBAR and L2-as-SRAM don't need a configured Local Access Window. + * If flash is 8M at default position (last 8M), no LAW needed. + * + * LAW 0 is reserved for boot mapping + */ + +struct law_entry law_table[] = { + SET_LAW(CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_SDRAM_SIZE_LOG - 1, + LAW_TRGT_IF_DDR_1), +#ifdef CONFIG_SYS_RIO_MEM_PHYS + SET_LAW(CONFIG_SYS_RIO_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_RIO), +#endif + SET_LAW(CONFIG_SYS_LBC_OPTION_BASE, LAW_SIZE_256M, LAW_TRGT_IF_LBC) +}; + +int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/mercury/mpq101/mpq101.c b/board/mercury/mpq101/mpq101.c new file mode 100644 index 0000000..18fb88e --- /dev/null +++ b/board/mercury/mpq101/mpq101.c @@ -0,0 +1,167 @@ +/* + * (C) Copyright 2010 Alex Dubov oakad@yahoo.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/processor.h> +#include <asm/mmu.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/io.h> +#include <miiphy.h> +#include <libfdt.h> +#include <fdt_support.h> + +void local_bus_init(void); +void sdram_init(void); + +unsigned long get_clock_freq(void) +{ + return 33000000; +} + +int checkboard (void) +{ + volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + volatile ccsr_local_ecm_t *ecm = (void *)(CONFIG_SYS_MPC85xx_ECM_ADDR); + + puts ("Board: Mercury Computer Systems, Inc. MPQ-101 "); +#ifdef CONFIG_PHYS_64BIT + puts ("(36-bit addrmap) "); +#endif + putc ('\n'); + + /* + * Initialize local bus. + */ + local_bus_init (); + + /* + * Hack TSEC 3 and 4 IO voltages. + */ + out_be32(&gur->tsec34ioovcr, 0xe7e0); /* 1110 0111 1110 0xxx */ + + out_be32(&ecm->eedr, 0xffffffff); /* clear ecm errors */ + out_be32(&ecm->eeer, 0xffffffff); /* enable ecm errors */ + return 0; +} + +phys_size_t +initdram (int board_type) +{ + volatile ccsr_ddr_t *ddr = (void *)(CONFIG_SYS_MPC85xx_DDR_ADDR); + phys_size_t dram_size = 0; + const char *p_mode = getenv("perf_mode"); + + puts("Initializing...."); + + ddr->cs0_bnds = CONFIG_SYS_DDR_CS0_BNDS; + ddr->cs0_config = CONFIG_SYS_DDR_CS0_CONFIG; + + ddr->timing_cfg_3 = CONFIG_SYS_DDR_TIMING_3; + ddr->timing_cfg_0 = CONFIG_SYS_DDR_TIMING_0; + + if (p_mode && !strcmp("performance", p_mode)) { + ddr->timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1_PERF; + ddr->timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2_PERF; + ddr->sdram_mode = CONFIG_SYS_DDR_MODE_1_PERF; + ddr->sdram_mode_2 = CONFIG_SYS_DDR_MODE_2_PERF; + ddr->sdram_interval = CONFIG_SYS_DDR_INTERVAL_PERF; + } else { + ddr->timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1; + ddr->timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2; + ddr->sdram_mode = CONFIG_SYS_DDR_MODE_1; + ddr->sdram_mode_2 = CONFIG_SYS_DDR_MODE_2; + ddr->sdram_interval = CONFIG_SYS_DDR_INTERVAL; + } + + ddr->sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CTRL; + ddr->sdram_cfg_2 = CONFIG_SYS_DDR_CONTROL2; + + asm("sync;isync"); + udelay(500); + + ddr->sdram_cfg = CONFIG_SYS_DDR_CONTROL; + asm("sync; isync"); + udelay(500); + + dram_size = setup_ddr_tlbs(1ull << (CONFIG_SYS_SDRAM_SIZE_LOG - 20)); + + puts(" DDR: "); + + return dram_size << 20; +} + +/* + * Initialize Local Bus + */ +void +local_bus_init(void) +{ + volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + volatile fsl_lbc_t *lbc = LBC_BASE_ADDR; + + uint clkdiv; + uint lbc_hz; + sys_info_t sysinfo; + + get_sys_info(&sysinfo); + clkdiv = (lbc->lcrr & LCRR_CLKDIV) * 2; + lbc_hz = sysinfo.freqSystemBus / 1000000 / clkdiv; + + gur->lbiuiplldcr1 = 0x00078080; + if (clkdiv == 16) { + gur->lbiuiplldcr0 = 0x7c0f1bf0; + } else if (clkdiv == 8) { + gur->lbiuiplldcr0 = 0x6c0f1bf0; + } else if (clkdiv == 4) { + gur->lbiuiplldcr0 = 0x5c0f1bf0; + } + + lbc->lcrr |= 0x00030000; + asm("sync;isync;msync"); + + lbc->ltesr = 0xffffffff; /* Clear LBC error interrupts */ + lbc->lteir = 0xffffffff; /* Enable LBC error interrupts */ +} + +void +pci_init_board(void) +{ + volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + + /* PCI is disabled */ + out_be32(&gur->devdisr, in_be32(&gur->devdisr) + | MPC85xx_DEVDISR_PCI1 + | MPC85xx_DEVDISR_PCI2 + | MPC85xx_DEVDISR_PCIE); +} + + +#if defined(CONFIG_OF_BOARD_SETUP) + +void +ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); +} + +#endif diff --git a/board/mercury/mpq101/tlb.c b/board/mercury/mpq101/tlb.c new file mode 100644 index 0000000..1f1c5b1 --- /dev/null +++ b/board/mercury/mpq101/tlb.c @@ -0,0 +1,82 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mmu.h> + +struct fsl_e_tlb_entry tlb_table[] = { + /* TLB 0 - for temp stack in cache */ + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, CONFIG_SYS_INIT_RAM_ADDR, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + /* + * TLB 0: 256M Non-cacheable, guarded + * 0xf0000000 256M LBC (FLASH included) + * Out of reset this entry is only 4K. + */ + SET_TLB_ENTRY(1, CONFIG_SYS_LBC_OPTION_BASE, + CONFIG_SYS_LBC_OPTION_BASE, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_256M, 1), + + /* + * TLB 1: 1M Non-cacheable, guarded + * 0xe000_0000 1M CCSRBAR + */ + SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 1, BOOKE_PAGESZ_1M, 1), + +#ifdef CONFIG_SYS_RIO_MEM_PHYS + /* + * TLB 2: 256M Non-cacheable, guarded + */ + SET_TLB_ENTRY(1, CONFIG_SYS_RIO_MEM_BASE, CONFIG_SYS_RIO_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 2, BOOKE_PAGESZ_256M, 1), + + /* + * TLB 3: 256M Non-cacheable, guarded + */ + SET_TLB_ENTRY(1, CONFIG_SYS_RIO_MEM_BASE + 0x10000000, + CONFIG_SYS_RIO_MEM_PHYS + 0x10000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 3, BOOKE_PAGESZ_256M, 1), + +#endif +}; + +int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/boards.cfg b/boards.cfg index 08e531e..a0baa4f 100644 --- a/boards.cfg +++ b/boards.cfg @@ -189,6 +189,7 @@ TQM834x powerpc mpc83xx tqm834x tqc sbc8349 powerpc mpc83xx sbc8349 - - sbc8349 caddy2 powerpc mpc83xx vme8349 esd - vme8349:CADDY2 vme8349 powerpc mpc83xx vme8349 esd - vme8349 +mpq101 powerpc mpc85xx mpq101 mercury - mpq101 PM854 powerpc mpc85xx pm854 PM856 powerpc mpc85xx pm856 P1022DS powerpc mpc85xx p1022ds freescale diff --git a/include/configs/mpq101.h b/include/configs/mpq101.h new file mode 100644 index 0000000..7f8c5c5 --- /dev/null +++ b/include/configs/mpq101.h @@ -0,0 +1,381 @@ +/* + * Copyright 2010 Alex Dubov oakad@yahoo.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Merury Computers MPQ101 board configuration file + * + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +#ifdef CONFIG_36BIT +#define CONFIG_PHYS_64BIT +#endif + +//#define DEBUG 5 +//#define CMD_MEM_DEBUG 1 + +/* High Level Configuration Options */ +#define CONFIG_BOOKE 1 /* BOOKE */ +#define CONFIG_E500 1 /* BOOKE e500 family */ +#define CONFIG_MPC85xx 1 /* MPC8540/60/55/41/48 */ +#define CONFIG_MPC8548 1 /* MPC8548 specific */ +#define CONFIG_MPQ101 1 /* MPQ101 board specific */ + +#define CONFIG_RIO + +#define CONFIG_TSEC_ENET 1 /* tsec ethernet support */ +#define CONFIG_ENV_OVERWRITE 1 +#define CONFIG_INTERRUPTS 1 /* enable pci, srio, ddr interrupts */ +#define CONFIG_FSL_LAW 1 /* Use common FSL init code */ + +/* + * When initializing flash, if we cannot find the manufacturer ID, + * assume this is the AMD flash. + */ +#define CONFIG_ASSUME_AMD_FLASH + +#ifndef __ASSEMBLY__ +extern unsigned long get_clock_freq(void); +#endif +#define CONFIG_SYS_CLK_FREQ get_clock_freq() /* sysclk for MPC85xx */ + +/* + * These can be toggled for performance analysis, otherwise use default. + */ +#define CONFIG_L2_CACHE 1 /* toggle L2 cache */ +#define CONFIG_BTB 1 /* toggle branch predition */ + +/* + * Only possible on E500 Version 2 or newer cores. + */ +#define CONFIG_ENABLE_36BIT_PHYS 1 + +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_ADDR_MAP 1 +#define CONFIG_SYS_NUM_ADDR_MAP 16 /* number of TLB1 entries */ +#endif + + +#define CONFIG_SYS_ALT_MEMTEST 1 +#define CONFIG_SYS_MEMTEST_START 0x0ff00000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x0ffffffc + +#define CONFIG_PANIC_HANG + +/* + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + */ +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 +#define CONFIG_SYS_CCSRBAR 0xe0000000 +#ifdef CONFIG_PHYS_64BIT +#define +#define CONFIG_SYS_CCSRBAR_PHYS 0xfe0000000ull +#else +#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR +#endif +#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR + +/* DDR Setup */ +#define CONFIG_FSL_DDR2 +#undef CONFIG_SPD_EEPROM +#undef CONFIG_DDR_SPD +#undef CONFIG_DDR_DLL + +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER 1 /* DDR controller or DMA? */ + +#define CONFIG_MEM_INIT_VALUE 0xDeadBeef +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 /* DDR is system memory*/ +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +#define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +#define CONFIG_CHIP_SELECTS_PER_CTRL (2 * CONFIG_DIMM_SLOTS_PER_CTLR) + +/* Fixed 512MB DDR2 parameters */ +#define CONFIG_SYS_SDRAM_SIZE_LOG 29 /* DDR is 512MB */ +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000001f +#define CONFIG_SYS_DDR_CS0_CONFIG 0x80014102 +#define CONFIG_SYS_DDR_TIMING_3 0x00010000 +#define CONFIG_SYS_DDR_TIMING_0 0x00260802 +#define CONFIG_SYS_DDR_TIMING_1 0x5c47a432 +#define CONFIG_SYS_DDR_TIMING_1_PERF 0x49352322 +#define CONFIG_SYS_DDR_TIMING_2 0x03984cce +#define CONFIG_SYS_DDR_TIMING_2_PERF 0x14904cca +#define CONFIG_SYS_DDR_MODE_1 0x00400442 +#define CONFIG_SYS_DDR_MODE_1_PERF 0x00480432 +#define CONFIG_SYS_DDR_MODE_2 0x00000000 +#define CONFIG_SYS_DDR_MODE_2_PERF 0x00000000 +#define CONFIG_SYS_DDR_INTERVAL 0x08200100 +#define CONFIG_SYS_DDR_INTERVAL_PERF 0x06180100 +#define CONFIG_SYS_DDR_CLK_CTRL 0x03800000 +#define CONFIG_SYS_DDR_CONTROL 0xc3008000 /* Type = DDR2 */ +#define CONFIG_SYS_DDR_CONTROL2 0x04400000 + +#undef CONFIG_CLOCKS_IN_MHZ + +/* + * Local Bus Definitions + */ + +/* + * FLASH on the Local Bus + * One bank, 128M, using the CFI driver. + */ + +#define CONFIG_SYS_BOOT_BLOCK 0xf8000000 /* boot TLB block */ +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_BOOT_BLOCK /* start of FLASH 128M */ + +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_FLASH_BASE_PHYS 0xff8000000ull +#else +#define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE +#endif + +/* 0xf8001801 */ +#define CONFIG_SYS_BR0_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) \ + | BR_PS_32 | BR_V) + +/* 0xf8006ff7 */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(128) | OR_GPCM_XAM | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 | OR_GPCM_TRLX \ + | OR_GPCM_EHTR | OR_GPCM_EAD) + +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS} +#undef CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 /* sectors per device */ +#undef CONFIG_SYS_FLASH_CHECKSUM + +//#define CONFIG_SYS_BR0_PRELIM 0xff001801 +//#define CONFIG_SYS_BR1_PRELIM 0xf0001001 + +//#define CONFIG_SYS_OR0_PRELIM 0xff006e65 +//#define CONFIG_SYS_OR1_PRELIM 0xff006e65 + +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ + +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_AMD_CHECK_DQ7 + +/* + * Local Bus + */ +#define CONFIG_SYS_LBC_OPTION_BASE 0xf0000000 +#define CONFIG_SYS_LBC_CACHE_BASE CONFIG_SYS_LBC_OPTION_BASE +#define CONFIG_SYS_LBC_CACHE_SIZE 64 +#define CONFIG_SYS_LBC_NONCACHE_BASE 0xf4000000 +#define CONFIG_SYS_LBC_NONCACHE_SIZE 64 + +#define CONFIG_SYS_LBC_LCRR 0x00000004 /* LB clock ratio reg */ +#define CONFIG_SYS_LBC_LBCR 0x00000000 /* LB config reg */ + +#define CONFIG_SYS_INIT_RAM_LOCK 1 +#define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */ + +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* Reserved for malloc */ + +/* Serial Port */ +#define CONFIG_CONS_INDEX 2 +#undef CONFIG_SERIAL_SOFTWARE_FIFO +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK get_bus_freq(0) + +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200} + +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600) + +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#endif + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 +#define CONFIG_OF_STDOUT_VIA_ALIAS 1 + +/* new uImage format support */ +#define CONFIG_FIT 1 +#define CONFIG_FIT_VERBOSE 1 /* enable fit_format_{error,warning}() */ + +//#define CONFIG_SYS_64BIT_VSPRINTF 1 +//#define CONFIG_SYS_64BIT_STRTOUL 1 + +/* + * I2C + */ +#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ +#define CONFIG_HARD_I2C /* I2C with hardware support*/ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SLAVE 0x7f +#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C2_OFFSET 0x3100 + +#ifdef CONFIG_RIO +/* + * RapidIO MMU + */ +#define CONFIG_SYS_RIO_MEM_BASE 0xc0000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_RIO_MEM_PHYS 0xfc0000000ull +#else +#define CONFIG_SYS_RIO_MEM_PHYS CONFIG_SYS_RIO_MEM_BASE +#endif +#define CONFIG_SYS_RIO_MEM_SIZE 0x20000000 /* 512M */ +#endif + +#if defined(CONFIG_TSEC_ENET) + +#ifndef CONFIG_NET_MULTI +#define CONFIG_NET_MULTI 1 +#endif + +#define CONFIG_MII 1 /* MII PHY management */ +#define CONFIG_MII_DEFAULT_TSEC 1 /* Allow unregistered phys */ +#define CONFIG_TSEC1 1 +#define CONFIG_TSEC1_NAME "eTSEC0" +#define CONFIG_TSEC2 1 +#define CONFIG_TSEC2_NAME "eTSEC1" +#define CONFIG_TSEC3 1 +#define CONFIG_TSEC3_NAME "eTSEC2" +#define CONFIG_TSEC4 1 +#define CONFIG_TSEC4_NAME "eTSEC3" +#undef CONFIG_MPC85XX_FEC + +#define TSEC1_PHY_ADDR 0x10 +#define TSEC2_PHY_ADDR 0x11 +#define TSEC3_PHY_ADDR 0x12 +#define TSEC4_PHY_ADDR 0x13 + +#define TSEC1_PHYIDX 0 +#define TSEC2_PHYIDX 0 +#define TSEC3_PHYIDX 0 +#define TSEC4_PHYIDX 0 + +#define TSEC1_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) +#define TSEC2_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) +#define TSEC3_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) +#define TSEC4_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +/* Options are: eTSEC[0-3] */ +#define CONFIG_ETHPRIME "eTSEC0" +#define CONFIG_PHY_GIGE 1 /* Include GbE speed/duplex detection */ +#endif /* CONFIG_TSEC_ENET */ + +/* + * Environment + */ +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_SYS_USE_PPCENV 1 +#define ENV_IS_EMBEDDED 1 +#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K */ +#define CONFIG_ENV_SIZE 0x800 +#define CONFIG_ENV_ADDR 0xfffc0000 + +#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_NFS +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MII +#define CONFIG_CMD_ELF +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_SETEXPR +#define CONFIG_CMD_JFFS2 + +#undef CONFIG_WATCHDOG /* watchdog disabled */ + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_CMDLINE_EDITING /* Command-line editing */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "MPQ-101=> " /* Monitor Command Prompt */ +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#endif + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT)+16) + +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 16 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (16 << 20) /* Initial Memory map for Linux*/ + +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Environment Configuration + */ + +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_LOADADDR 1000000 /*default location for tftp and bootm*/ + +#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ +#undef CONFIG_BOOTARGS /* the boot command will set bootargs*/ + +#endif /* __CONFIG_H */
Dear Alex Dubov,
Entry to MAINTAINERS missing.
Please mode defines to board config file and get rid of config.mk
- dram_size = setup_ddr_tlbs(1ull << (CONFIG_SYS_SDRAM_SIZE_LOG - 20));
- puts(" DDR: ");
- return dram_size << 20;
You should use get_ram_size().
- volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR);
- volatile fsl_lbc_t *lbc = LBC_BASE_ADDR;
- uint clkdiv;
- uint lbc_hz;
- sys_info_t sysinfo;
- get_sys_info(&sysinfo);
- clkdiv = (lbc->lcrr & LCRR_CLKDIV) * 2;
- lbc_hz = sysinfo.freqSystemBus / 1000000 / clkdiv;
- gur->lbiuiplldcr1 = 0x00078080;
- if (clkdiv == 16) {
- } else if (clkdiv == 8) {
- } else if (clkdiv == 4) {
- lbc->lcrr |= 0x00030000;
- asm("sync;isync;msync");
- lbc->ltesr = 0xffffffff; /* Clear LBC error interrupts */
- lbc->lteir = 0xffffffff; /* Enable LBC error interrupts */
NAK. Please use proper I/O accessors.
You probably want to make this consistent.
+ puts(" DDR: ");
I still need to call setup_ddr_tlbs because get_ram_size won't do it for me. So what get_ram_size actually does?
Do you mean out_be32 and friends? In which case, why are not these used when writing config values to DDR registers (for instance) even in some very recently added boards, such as p2020ds?
+#define
CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ ...
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de You can only live once, but if you do it right, once is enough.
Dear Alex Dubov,
It checks the size of available memory and performs a simple, fast and non-destuctive memory test on the way.
Right.
Because this escaped review?
Can you please point out where this was missed, so it can be fixed?
p2020ds?
Some of the boards in question:
atum8548 mpc8540 pm854/6 sbc8560 sbc8641d socrates mpc8536ds mpc8540ads mpc8560ads mpc8572ds mpc8610hpdc mpc8641hpcn p2020ds tqm85xx
Dear Alex Dubov,
Could you please be a bit more specific, i. e. like quoting file names and line numbers?
Thanks.
These were produced by grep -nr ddr-> board/ | grep -v out_be
I can attach a listing, but it should be quicker this way. Up until now it seemed a rather common practice to initialize ddr controllers directly, bypassing io accessors.
Dear Alex Dubov,
Indeed. Even after the recent removal of some boards this list remains:
board/freescale/mpc8349itx/mpc8349itx.c board/freescale/mpc8536ds/mpc8536ds.c board/freescale/mpc8540ads/mpc8540ads.c board/freescale/mpc8560ads/mpc8560ads.c board/freescale/mpc8569mds/mpc8569mds.c board/freescale/mpc8572ds/mpc8572ds.c board/freescale/mpc8610hpcd/mpc8610hpcd.c board/freescale/mpc8641hpcn/mpc8641hpcn.c board/freescale/p2020ds/p2020ds.c board/sbc8560/sbc8560.c board/sbc8641d/sbc8641d.c board/socrates/sdram.c board/tqc/tqm85xx/sdram.c
Kumar, Andy - do you have any plans to fix this for the freescale boards?
On Jan 17, 2011, at 4:38 PM, Wolfgang Denk wrote:
Dear Alex Dubov,
I don't have an plans to fix this, however we can add it to the TODO list. Just isn't high priority at this point.
- k
And another question: how am I supposed to specify linker flags in the board config file (I suppose, you mean boards.cfg). There's no examples throughout the u-boot tree where it is done and Makefile do not seem to peek those either (they just end up in autoconf.mk).
Dear Alex Dubov,
No, I mean include/configs/<name>.h
...which then gets included.
Anyway - maybe you should ponder why you need to do something nobody else needs, and then fix the code.
Mpq101 is a RapidIO development board in AMC form factor, featuring MPC8548 processor, 512MB of hardwired DDR2 RAM, 128MB of hardwired NAND flash memory, real time clock and additional serial EEPROM on i2c bus (enabled). USB controller is available, but not presently enabled.
Environment is configured to preceed the actual u-boot image so that it's located at the beginning of flash erase block (made necessary by the recent changes to the embedded environment handling).
Signed-off-by: Alex Dubov oakad@yahoo.com --- MAINTAINERS | 3 + board/mercury/mpq101/Makefile | 53 +++++ board/mercury/mpq101/config.mk | 6 + board/mercury/mpq101/law.c | 55 ++++++ board/mercury/mpq101/mpq101.c | 146 ++++++++++++++ board/mercury/mpq101/tlb.c | 82 ++++++++ boards.cfg | 1 + include/configs/mpq101.h | 410 ++++++++++++++++++++++++++++++++++++++++ 8 files changed, 756 insertions(+), 0 deletions(-) create mode 100644 board/mercury/mpq101/Makefile create mode 100644 board/mercury/mpq101/config.mk create mode 100644 board/mercury/mpq101/law.c create mode 100644 board/mercury/mpq101/mpq101.c create mode 100644 board/mercury/mpq101/tlb.c create mode 100644 include/configs/mpq101.h
diff --git a/MAINTAINERS b/MAINTAINERS index 9258cb1..e31fc5e 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -138,6 +138,9 @@ Jon Diekema jon.diekema@smiths-aerospace.com
sbc8260 MPC8260
+Alex Dubov oakad@yahoo.com + mpq101 MPC8548 + Dirk Eibach eibach@gdsys.de
devconcenter PPC460EX diff --git a/board/mercury/mpq101/Makefile b/board/mercury/mpq101/Makefile new file mode 100644 index 0000000..58bc1b3 --- /dev/null +++ b/board/mercury/mpq101/Makefile @@ -0,0 +1,53 @@ +# +# Copyright 2007 Freescale Semiconductor, Inc. +# (C) Copyright 2001-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += $(BOARD).o +COBJS-y += law.o +COBJS-y += tlb.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS)) + +clean: + rm -f $(OBJS) $(SOBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/mercury/mpq101/config.mk b/board/mercury/mpq101/config.mk new file mode 100644 index 0000000..1d83f9a --- /dev/null +++ b/board/mercury/mpq101/config.mk @@ -0,0 +1,6 @@ +# +# mpq101 board +# + +# Make room for environment at the beginning of flash sector +LDFLAGS += --section-start=.ppcenv=$(CONFIG_ENV_ADDR) diff --git a/board/mercury/mpq101/law.c b/board/mercury/mpq101/law.c new file mode 100644 index 0000000..726b5c2 --- /dev/null +++ b/board/mercury/mpq101/law.c @@ -0,0 +1,55 @@ +/* + * Copyright 2008 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/mmu.h> + +/* + * LAW(Local Access Window) configuration: + * + * 0x0000_0000 0x1fff_ffff DDR SYS_SDRAM_SIZE + * 0xc000_0000 0xdfff_ffff RapidIO 512M + * 0xe000_0000 0xe000_ffff CCSR 1M + * 0xf000_0000 0xffff_ffff LBC options + FLASH 256M + * + * Notes: + * CCSRBAR and L2-as-SRAM don't need a configured Local Access Window. + * If flash is 8M at default position (last 8M), no LAW needed. + * + * LAW 0 is reserved for boot mapping + */ + +struct law_entry law_table[] = { + SET_LAW(CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_SDRAM_SIZE_LOG - 1, + LAW_TRGT_IF_DDR_1), +#ifdef CONFIG_SYS_RIO_MEM_PHYS + SET_LAW(CONFIG_SYS_RIO_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_RIO), +#endif + SET_LAW(CONFIG_SYS_LBC_OPTION_BASE_PHYS, LAW_SIZE_256M, + LAW_TRGT_IF_LBC) +}; + +int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/mercury/mpq101/mpq101.c b/board/mercury/mpq101/mpq101.c new file mode 100644 index 0000000..87b2ca0 --- /dev/null +++ b/board/mercury/mpq101/mpq101.c @@ -0,0 +1,146 @@ +/* + * (C) Copyright 2010 Alex Dubov oakad@yahoo.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/processor.h> +#include <asm/mmu.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/io.h> +#include <miiphy.h> +#include <libfdt.h> +#include <fdt_support.h> + +void local_bus_init(void); +void sdram_init(void); + +unsigned long get_clock_freq(void) +{ + return 33000000; +} + +int checkboard (void) +{ + volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + volatile ccsr_local_ecm_t *ecm = (void *)(CONFIG_SYS_MPC85xx_ECM_ADDR); + + puts ("Board: Mercury Computer Systems, Inc. MPQ-101 "); +#ifdef CONFIG_PHYS_64BIT + puts ("(36-bit addrmap) "); +#endif + putc ('\n'); + + /* + * Initialize local bus. + */ + local_bus_init (); + + /* + * Hack TSEC 3 and 4 IO voltages. + */ + out_be32(&gur->tsec34ioovcr, 0xe7e0); /* 1110 0111 1110 0xxx */ + + out_be32(&ecm->eedr, 0xffffffff); /* clear ecm errors */ + out_be32(&ecm->eeer, 0xffffffff); /* enable ecm errors */ + return 0; +} + +phys_size_t +initdram (int board_type) +{ + volatile ccsr_ddr_t *ddr = (void *)(CONFIG_SYS_MPC85xx_DDR_ADDR); + phys_size_t dram_size = 0; + const char *p_mode = getenv("perf_mode"); + + puts("Initializing...."); + + out_be32(&ddr->cs0_bnds, CONFIG_SYS_DDR_CS0_BNDS); + out_be32(&ddr->cs0_config, CONFIG_SYS_DDR_CS0_CONFIG); + + out_be32(&ddr->timing_cfg_3, CONFIG_SYS_DDR_TIMING_3); + out_be32(&ddr->timing_cfg_0, CONFIG_SYS_DDR_TIMING_0); + + if (p_mode && !strcmp("performance", p_mode)) { + out_be32(&ddr->timing_cfg_1, CONFIG_SYS_DDR_TIMING_1_PERF); + out_be32(&ddr->timing_cfg_2, CONFIG_SYS_DDR_TIMING_2_PERF); + out_be32(&ddr->sdram_mode, CONFIG_SYS_DDR_MODE_1_PERF); + out_be32(&ddr->sdram_mode_2, CONFIG_SYS_DDR_MODE_2_PERF); + out_be32(&ddr->sdram_interval, CONFIG_SYS_DDR_INTERVAL_PERF); + } else { + out_be32(&ddr->timing_cfg_1, CONFIG_SYS_DDR_TIMING_1); + out_be32(&ddr->timing_cfg_2, CONFIG_SYS_DDR_TIMING_2); + out_be32(&ddr->sdram_mode, CONFIG_SYS_DDR_MODE_1); + out_be32(&ddr->sdram_mode_2, CONFIG_SYS_DDR_MODE_2); + out_be32(&ddr->sdram_interval, CONFIG_SYS_DDR_INTERVAL); + } + + out_be32(&ddr->sdram_clk_cntl, CONFIG_SYS_DDR_CLK_CTRL); + out_be32(&ddr->sdram_cfg_2, CONFIG_SYS_DDR_CONTROL2); + + asm("sync;isync"); + udelay(500); + + out_be32(&ddr->sdram_cfg, CONFIG_SYS_DDR_CONTROL); + asm("sync; isync"); + udelay(500); + + dram_size = setup_ddr_tlbs(1ull << (CONFIG_SYS_SDRAM_SIZE_LOG - 20)); + + puts(" DDR: "); + + return get_ram_size(0, dram_size << 20); +} + +/* + * Initialize Local Bus + */ +void +local_bus_init(void) +{ + volatile fsl_lbc_t *lbc = LBC_BASE_ADDR; + + out_be32(&lbc->ltesr, 0xffffffff); /* Clear LBC error interrupts */ + out_be32(&lbc->lteir, 0xffffffff); /* Enable LBC error interrupts */ +} + +void +pci_init_board(void) +{ + volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + + /* PCI is disabled */ + out_be32(&gur->devdisr, in_be32(&gur->devdisr) + | MPC85xx_DEVDISR_PCI1 + | MPC85xx_DEVDISR_PCI2 + | MPC85xx_DEVDISR_PCIE); +} + + +#if defined(CONFIG_OF_BOARD_SETUP) + +void +ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); +} + +#endif diff --git a/board/mercury/mpq101/tlb.c b/board/mercury/mpq101/tlb.c new file mode 100644 index 0000000..3e3d280 --- /dev/null +++ b/board/mercury/mpq101/tlb.c @@ -0,0 +1,82 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mmu.h> + +struct fsl_e_tlb_entry tlb_table[] = { + /* TLB 0 - for temp stack in cache */ + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, CONFIG_SYS_INIT_RAM_ADDR, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + /* + * TLB 0: 256M Non-cacheable, guarded + * 0xf0000000 256M LBC (FLASH included) + * Out of reset this entry is only 4K. + */ + SET_TLB_ENTRY(1, CONFIG_SYS_LBC_OPTION_BASE, + CONFIG_SYS_LBC_OPTION_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_256M, 1), + + /* + * TLB 1: 1M Non-cacheable, guarded + * 0xe000_0000 1M CCSRBAR + */ + SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 1, BOOKE_PAGESZ_1M, 1), + +#ifdef CONFIG_SYS_RIO_MEM_PHYS + /* + * TLB 2: 256M Non-cacheable, guarded + */ + SET_TLB_ENTRY(1, CONFIG_SYS_RIO_MEM_BASE, CONFIG_SYS_RIO_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 2, BOOKE_PAGESZ_256M, 1), + + /* + * TLB 3: 256M Non-cacheable, guarded + */ + SET_TLB_ENTRY(1, CONFIG_SYS_RIO_MEM_BASE + 0x10000000, + CONFIG_SYS_RIO_MEM_PHYS + 0x10000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 3, BOOKE_PAGESZ_256M, 1), + +#endif +}; + +int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/boards.cfg b/boards.cfg index 08e531e..a0baa4f 100644 --- a/boards.cfg +++ b/boards.cfg @@ -189,6 +189,7 @@ TQM834x powerpc mpc83xx tqm834x tqc sbc8349 powerpc mpc83xx sbc8349 - - sbc8349 caddy2 powerpc mpc83xx vme8349 esd - vme8349:CADDY2 vme8349 powerpc mpc83xx vme8349 esd - vme8349 +mpq101 powerpc mpc85xx mpq101 mercury - mpq101 PM854 powerpc mpc85xx pm854 PM856 powerpc mpc85xx pm856 P1022DS powerpc mpc85xx p1022ds freescale diff --git a/include/configs/mpq101.h b/include/configs/mpq101.h new file mode 100644 index 0000000..8522b0a --- /dev/null +++ b/include/configs/mpq101.h @@ -0,0 +1,410 @@ +/* + * Copyright 2010 Alex Dubov oakad@yahoo.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Merury Computers MPQ101 board configuration file + * + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +#ifdef CONFIG_36BIT +#define CONFIG_PHYS_64BIT +#endif + +//#define DEBUG 5 + +/* High Level Configuration Options */ +#define CONFIG_BOOKE 1 /* BOOKE */ +#define CONFIG_E500 1 /* BOOKE e500 family */ +#define CONFIG_MPC85xx 1 /* MPC8540/60/55/41/48 */ +#define CONFIG_MPC8548 1 /* MPC8548 specific */ +#define CONFIG_MPQ101 1 /* MPQ101 board specific */ + +#define CONFIG_RIO + +#define CONFIG_TSEC_ENET 1 /* tsec ethernet support */ +#define CONFIG_ENV_OVERWRITE 1 +#define CONFIG_INTERRUPTS 1 /* enable pci, srio, ddr interrupts */ +#define CONFIG_FSL_LAW 1 /* Use common FSL init code */ + +/* + * When initializing flash, if we cannot find the manufacturer ID, + * assume this is the AMD flash. + */ +#define CONFIG_ASSUME_AMD_FLASH + +#ifndef __ASSEMBLY__ +extern unsigned long get_clock_freq(void); +#endif +#define CONFIG_SYS_CLK_FREQ get_clock_freq() /* sysclk for MPC85xx */ + +/* + * These can be toggled for performance analysis, otherwise use default. + */ +#define CONFIG_L2_CACHE 1 /* toggle L2 cache */ +#define CONFIG_BTB 1 /* toggle branch predition */ + +/* + * Only possible on E500 Version 2 or newer cores. + */ +#define CONFIG_ENABLE_36BIT_PHYS 1 + +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_ADDR_MAP 1 +#define CONFIG_SYS_NUM_ADDR_MAP 16 /* number of TLB1 entries */ +#endif + + +#define CONFIG_SYS_ALT_MEMTEST 1 +#define CONFIG_SYS_MEMTEST_START 0x0ff00000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x0ffffffc + +#define CONFIG_PANIC_HANG + +/* + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + */ +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 +#define CONFIG_SYS_CCSRBAR 0xe0000000 +#ifdef CONFIG_PHYS_64BIT +#define +#define CONFIG_SYS_CCSRBAR_PHYS 0xfe0000000ull +#else +#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR +#endif +#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR + +/* DDR Setup */ +#define CONFIG_FSL_DDR2 +#undef CONFIG_SPD_EEPROM +#undef CONFIG_DDR_SPD +#undef CONFIG_DDR_DLL + +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER 1 /* DDR controller or DMA? */ + +#define CONFIG_MEM_INIT_VALUE 0xDeadBeef +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 /* DDR is system memory*/ +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +#define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +#define CONFIG_CHIP_SELECTS_PER_CTRL (2 * CONFIG_DIMM_SLOTS_PER_CTLR) + +/* Fixed 512MB DDR2 parameters */ +#define CONFIG_SYS_SDRAM_SIZE_LOG 29 /* DDR is 512MB */ +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000001f +#define CONFIG_SYS_DDR_CS0_CONFIG 0x80014102 +#define CONFIG_SYS_DDR_TIMING_3 0x00010000 +#define CONFIG_SYS_DDR_TIMING_0 0x00260802 +#define CONFIG_SYS_DDR_TIMING_1 0x5c47a432 +#define CONFIG_SYS_DDR_TIMING_1_PERF 0x49352322 +#define CONFIG_SYS_DDR_TIMING_2 0x03984cce +#define CONFIG_SYS_DDR_TIMING_2_PERF 0x14904cca +#define CONFIG_SYS_DDR_MODE_1 0x00400442 +#define CONFIG_SYS_DDR_MODE_1_PERF 0x00480432 +#define CONFIG_SYS_DDR_MODE_2 0x00000000 +#define CONFIG_SYS_DDR_MODE_2_PERF 0x00000000 +#define CONFIG_SYS_DDR_INTERVAL 0x08200100 +#define CONFIG_SYS_DDR_INTERVAL_PERF 0x06180100 +#define CONFIG_SYS_DDR_CLK_CTRL 0x03800000 +#define CONFIG_SYS_DDR_CONTROL 0xc3008000 /* Type = DDR2 */ +#define CONFIG_SYS_DDR_CONTROL2 0x04400000 + +#undef CONFIG_CLOCKS_IN_MHZ + +/* + * Local Bus Definitions + */ + +/* + * FLASH on the Local Bus + * One bank, 128M, using the CFI driver. + */ + +#define CONFIG_SYS_BOOT_BLOCK 0xf8000000 /* boot TLB block */ +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_BOOT_BLOCK /* start of FLASH 128M */ + +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_FLASH_BASE_PHYS 0xff8000000ull +#else +#define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE +#endif + +/* 0xf8001801 */ +#define CONFIG_SYS_BR0_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) \ + | BR_PS_32 | BR_V) + +/* 0xf8006ff7 */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(128) | OR_GPCM_XAM | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 | OR_GPCM_TRLX \ + | OR_GPCM_EHTR | OR_GPCM_EAD) + +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS} +#undef CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 /* sectors per device */ +#undef CONFIG_SYS_FLASH_CHECKSUM + +//#define CONFIG_SYS_BR0_PRELIM 0xff001801 +//#define CONFIG_SYS_BR1_PRELIM 0xf0001001 + +//#define CONFIG_SYS_OR0_PRELIM 0xff006e65 +//#define CONFIG_SYS_OR1_PRELIM 0xff006e65 + +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ + +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_AMD_CHECK_DQ7 + +/* + * 16b peripherals on the Local Bus + * 64k + */ +#define CONFIG_SYS_LBC_OPTION_BASE 0xf0000000 + +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_LBC_OPTION_BASE_PHYS 0xff0000000ull +#else +#define CONFIG_SYS_LBC_OPTION_BASE_PHYS CONFIG_SYS_LBC_OPTION_BASE +#endif + + +/* 0xf0001001 */ +#define CONFIG_SYS_BR1_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_LBC_OPTION_BASE_PHYS) \ + | BR_PS_16 | BR_V) + +/* ffff7002 */ +#define CONFIG_SYS_OR1_PRELIM (P2SZ_TO_AM(0x10000) | OR_GPCM_XAM \ + | OR_GPCM_BCTLD | OR_GPCM_EHTR) + +#define CONFIG_SYS_LBC_LCRR 0x00000004 /* LB clock ratio reg */ +#define CONFIG_SYS_LBC_LBCR 0x00000000 /* LB config reg */ + +#define CONFIG_SYS_INIT_RAM_LOCK 1 +#define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */ + +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* Reserved for malloc */ + +/* Serial Port */ +#define CONFIG_CONS_INDEX 2 +#undef CONFIG_SERIAL_SOFTWARE_FIFO +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK get_bus_freq(0) + +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200} + +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600) + +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER +#ifdef CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#endif + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 +#define CONFIG_OF_STDOUT_VIA_ALIAS 1 + +/* new uImage format support */ +#define CONFIG_FIT 1 +#define CONFIG_FIT_VERBOSE 1 /* enable fit_format_{error,warning}() */ + +//#define CONFIG_SYS_64BIT_VSPRINTF 1 +//#define CONFIG_SYS_64BIT_STRTOUL 1 + +/* + * I2C + */ +#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ +#define CONFIG_HARD_I2C /* I2C with hardware support*/ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SLAVE 0x7f +#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C2_OFFSET 0x3100 + +/* I2C RTC - M41T81 */ +#define CONFIG_RTC_M41T62 1 +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 +#define CONFIG_SYS_M41T11_BASE_YEAR 2000 + +/* I2C EEPROM - 24C256 */ +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 12 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +#define CONFIG_SYS_EEPROM_BUS_NUM 1 + +#ifdef CONFIG_RIO +/* + * RapidIO MMU + */ +#define CONFIG_SYS_RIO_MEM_BASE 0xc0000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_RIO_MEM_PHYS 0xfc0000000ull +#else +#define CONFIG_SYS_RIO_MEM_PHYS CONFIG_SYS_RIO_MEM_BASE +#endif +#define CONFIG_SYS_RIO_MEM_SIZE 0x20000000 /* 512M */ +#endif + +#if defined(CONFIG_TSEC_ENET) + +#ifndef CONFIG_NET_MULTI +#define CONFIG_NET_MULTI 1 +#endif + +#define CONFIG_MII 1 /* MII PHY management */ +#define CONFIG_MII_DEFAULT_TSEC 1 /* Allow unregistered phys */ +#define CONFIG_TSEC1 1 +#define CONFIG_TSEC1_NAME "eTSEC0" +#define CONFIG_TSEC2 1 +#define CONFIG_TSEC2_NAME "eTSEC1" +#define CONFIG_TSEC3 1 +#define CONFIG_TSEC3_NAME "eTSEC2" +#define CONFIG_TSEC4 1 +#define CONFIG_TSEC4_NAME "eTSEC3" +#undef CONFIG_MPC85XX_FEC + +#define TSEC1_PHY_ADDR 0x10 +#define TSEC2_PHY_ADDR 0x11 +#define TSEC3_PHY_ADDR 0x12 +#define TSEC4_PHY_ADDR 0x13 + +#define TSEC1_PHYIDX 0 +#define TSEC2_PHYIDX 0 +#define TSEC3_PHYIDX 0 +#define TSEC4_PHYIDX 0 + +#define TSEC1_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) +#define TSEC2_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) +#define TSEC3_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) +#define TSEC4_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +/* Options are: eTSEC[0-3] */ +#define CONFIG_ETHPRIME "eTSEC0" +#define CONFIG_PHY_GIGE 1 /* Include GbE speed/duplex detection */ +#endif /* CONFIG_TSEC_ENET */ + +/* + * Environment + */ +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_SYS_USE_PPCENV 1 +#define ENV_IS_EMBEDDED 1 +#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K */ +#define CONFIG_ENV_SIZE 0x800 + +/*Environment at the start of flash sector, before text. */ +#define CONFIG_ENV_ADDR 0xfffc0000 +#define CONFIG_SYS_TEXT_BASE 0xfffc0800 + +#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_NFS +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_CMD_SNTP +#define CONFIG_CMD_I2C +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_MII +#define CONFIG_CMD_ELF +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_SETEXPR +#define CONFIG_CMD_JFFS2 + +#undef CONFIG_WATCHDOG /* watchdog disabled */ + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_CMDLINE_EDITING /* Command-line editing */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "MPQ-101=> " /* Monitor Command Prompt */ +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#endif + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT)+16) + +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 16 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (16 << 20) /* Initial Memory map for Linux*/ + +#if defined(CONFIG_CMD_KGDB) +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Environment Configuration + */ + +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_LOADADDR CONFIG_SYS_LOAD_ADDR /*default location for tftp and bootm*/ + +#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ +#undef CONFIG_BOOTARGS /* the boot command will set bootargs*/ + +#endif /* __CONFIG_H */
Dear Alex Dubov,
I'm not going to review this again. Why don't you explain what was changed compared to the previous version? Please see the second bullet at http://www.denx.de/wiki/view/U-Boot/Patches#Sending_updated_patch_versions for a detailed explanation.
And you still have a board/mercury/mpq101/config.mk even though I asked you to get rid of it.
Please also run your patch through checkpatch.pl, remove C++ comments, remove deads code, do not #undef variables that are not #defined, use TAB for vertical alignment and fix other Coding Style issues.
1. I want to fit an environment and the bootloader into a single flash sector. 2. Environment must be on the sector boundary, otherwise saveenv won't rewrite it. 3. If I don't fix up the ppcenv starting address, the resulting u-boot image will shrink by the environment size and won't start on sector boundary itself. 4. Other boards use handcrafted ld scripts to fit environments at right boundaries.
That's why I need the LDFLAGS in question. If not in config.mk, where am I supposed to put them? Custom ld script is definitely an overshoot in this and other similar cases.
Dear Alex Dubov,
In message 546160.74882.qm@web37605.mail.mud.yahoo.com you wrote:
- I want to fit an environment and the bootloader into a single flash
sector.
This is a very bad idea as it will open a window brick your system at each and every "saveenv" command.
I strongly recommend not to do that.
- If I don't fix up the ppcenv starting address, the resulting u-boot
If you stop doing 1., all other problems will just disappear.
If you really insist in such an unreliablke configuration, a custom linker script would IMO be better, as it would make the image layout more visible.
into a single flash
sector.
This issue is well understood. Yet, we are talking an industrial mezzanine card here, of variety which is put into the (ups-backed in most cases) rack once and forgotten.
If it was a consumer or developer oriented device, I, of course, would use a safer approach. From what I've seen, this is more or less in line with many other boards already supported by u-boot.
Unfortunately, these boards have flash chips without small boot blocks, and considering the nature of typical board usage (as described) vs value of some additional flash space, I see it as a reasonable trade-off.
Typical ld script is rather largish with many details of no direct relevance to any specific board. Single flag modifying the section offset has the advantage of being concise and immediately visible.
I will, of course, look at it again.
Environment is configured to precede the actual u-boot image so that it's located at the beginning of flash erase block (made necessary by the recent changes to the embedded environment handling).
Signed-off-by: Alex Dubov oakad@yahoo.com --- Changes for v4: - Replace config.mk supplied linker flags with custom linker script. - Fix checkpatch errors. Changes for v3: - Use io accessor functions for all mmio accesses. - Add configuration options for RTC and EEPROM on I2C buses. Changes for v2: - Remove some stale configuration code from board initialization functions.
MAINTAINERS | 3 + board/mercury/mpq101/Makefile | 53 +++++ board/mercury/mpq101/law.c | 55 ++++++ board/mercury/mpq101/mpq101.c | 140 ++++++++++++++ board/mercury/mpq101/tlb.c | 82 ++++++++ board/mercury/mpq101/u-boot.lds | 132 +++++++++++++ boards.cfg | 1 + include/configs/mpq101.h | 398 +++++++++++++++++++++++++++++++++++++++ 8 files changed, 864 insertions(+), 0 deletions(-) create mode 100644 board/mercury/mpq101/Makefile create mode 100644 board/mercury/mpq101/law.c create mode 100644 board/mercury/mpq101/mpq101.c create mode 100644 board/mercury/mpq101/tlb.c create mode 100644 board/mercury/mpq101/u-boot.lds create mode 100644 include/configs/mpq101.h
diff --git a/MAINTAINERS b/MAINTAINERS index d7cd09c..220c39d 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -138,6 +138,9 @@ Jon Diekema jon.diekema@smiths-aerospace.com
sbc8260 MPC8260
devconcenter PPC460EX diff --git a/board/mercury/mpq101/Makefile b/board/mercury/mpq101/Makefile new file mode 100644 index 0000000..58bc1b3 --- /dev/null +++ b/board/mercury/mpq101/Makefile @@ -0,0 +1,53 @@ +# +# Copyright 2007 Freescale Semiconductor, Inc. +# (C) Copyright 2001-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += $(BOARD).o +COBJS-y += law.o +COBJS-y += tlb.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS)) + +clean: + rm -f $(OBJS) $(SOBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/mercury/mpq101/law.c b/board/mercury/mpq101/law.c new file mode 100644 index 0000000..726b5c2 --- /dev/null +++ b/board/mercury/mpq101/law.c @@ -0,0 +1,55 @@ +/* + * Copyright 2008 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/mmu.h> + +/* + * LAW(Local Access Window) configuration: + * + * 0x0000_0000 0x1fff_ffff DDR SYS_SDRAM_SIZE + * 0xc000_0000 0xdfff_ffff RapidIO 512M + * 0xe000_0000 0xe000_ffff CCSR 1M + * 0xf000_0000 0xffff_ffff LBC options + FLASH 256M + * + * Notes: + * CCSRBAR and L2-as-SRAM don't need a configured Local Access Window. + * If flash is 8M at default position (last 8M), no LAW needed. + * + * LAW 0 is reserved for boot mapping + */ + +struct law_entry law_table[] = { + SET_LAW(CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_SDRAM_SIZE_LOG - 1, + LAW_TRGT_IF_DDR_1), +#ifdef CONFIG_SYS_RIO_MEM_PHYS + SET_LAW(CONFIG_SYS_RIO_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_RIO), +#endif + SET_LAW(CONFIG_SYS_LBC_OPTION_BASE_PHYS, LAW_SIZE_256M, + LAW_TRGT_IF_LBC) +}; + +int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/mercury/mpq101/mpq101.c b/board/mercury/mpq101/mpq101.c new file mode 100644 index 0000000..8d9b518 --- /dev/null +++ b/board/mercury/mpq101/mpq101.c @@ -0,0 +1,140 @@ +/* + * (C) Copyright 2011 Alex Dubov oakad@yahoo.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/processor.h> +#include <asm/mmu.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/io.h> +#include <miiphy.h> +#include <libfdt.h> +#include <fdt_support.h> + +unsigned long get_clock_freq(void) +{ + return 33000000; +} + +/* + * Initialize Local Bus + */ +void local_bus_init(void) +{ + fsl_lbc_t *lbc = LBC_BASE_ADDR; + + out_be32(&lbc->ltesr, 0xffffffff); /* Clear LBC error interrupts */ + out_be32(&lbc->lteir, 0xffffffff); /* Enable LBC error interrupts */ +} + +int checkboard(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + ccsr_local_ecm_t *ecm = (void *)(CONFIG_SYS_MPC85xx_ECM_ADDR); + + puts("Board: Mercury Computer Systems, Inc. MPQ-101 "); +#ifdef CONFIG_PHYS_64BIT + puts("(36-bit addrmap) "); +#endif + putc('\n'); + + /* + * Initialize local bus. + */ + local_bus_init(); + + /* + * Hack TSEC 3 and 4 IO voltages. + */ + out_be32(&gur->tsec34ioovcr, 0xe7e0); /* 1110 0111 1110 0xxx */ + + out_be32(&ecm->eedr, 0xffffffff); /* clear ecm errors */ + out_be32(&ecm->eeer, 0xffffffff); /* enable ecm errors */ + return 0; +} + +phys_size_t initdram(int board_type) +{ + ccsr_ddr_t *ddr = (void *)(CONFIG_SYS_MPC85xx_DDR_ADDR); + phys_size_t dram_size = 0; + const char *p_mode = getenv("perf_mode"); + + puts("Initializing...."); + + out_be32(&ddr->cs0_bnds, CONFIG_SYS_DDR_CS0_BNDS); + out_be32(&ddr->cs0_config, CONFIG_SYS_DDR_CS0_CONFIG); + + out_be32(&ddr->timing_cfg_3, CONFIG_SYS_DDR_TIMING_3); + out_be32(&ddr->timing_cfg_0, CONFIG_SYS_DDR_TIMING_0); + + if (p_mode && !strcmp("performance", p_mode)) { + out_be32(&ddr->timing_cfg_1, CONFIG_SYS_DDR_TIMING_1_PERF); + out_be32(&ddr->timing_cfg_2, CONFIG_SYS_DDR_TIMING_2_PERF); + out_be32(&ddr->sdram_mode, CONFIG_SYS_DDR_MODE_1_PERF); + out_be32(&ddr->sdram_mode_2, CONFIG_SYS_DDR_MODE_2_PERF); + out_be32(&ddr->sdram_interval, CONFIG_SYS_DDR_INTERVAL_PERF); + } else { + out_be32(&ddr->timing_cfg_1, CONFIG_SYS_DDR_TIMING_1); + out_be32(&ddr->timing_cfg_2, CONFIG_SYS_DDR_TIMING_2); + out_be32(&ddr->sdram_mode, CONFIG_SYS_DDR_MODE_1); + out_be32(&ddr->sdram_mode_2, CONFIG_SYS_DDR_MODE_2); + out_be32(&ddr->sdram_interval, CONFIG_SYS_DDR_INTERVAL); + } + + out_be32(&ddr->sdram_clk_cntl, CONFIG_SYS_DDR_CLK_CTRL); + out_be32(&ddr->sdram_cfg_2, CONFIG_SYS_DDR_CONTROL2); + + asm("sync;isync"); + udelay(500); + + out_be32(&ddr->sdram_cfg, CONFIG_SYS_DDR_CONTROL); + asm("sync; isync"); + udelay(500); + + dram_size = setup_ddr_tlbs(1ull << (CONFIG_SYS_SDRAM_SIZE_LOG - 20)); + + puts(" DDR: "); + + return get_ram_size(0, dram_size << 20); +} + + +void pci_init_board(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + + /* PCI is disabled */ + out_be32(&gur->devdisr, in_be32(&gur->devdisr) + | MPC85xx_DEVDISR_PCI1 + | MPC85xx_DEVDISR_PCI2 + | MPC85xx_DEVDISR_PCIE); +} + + +#if defined(CONFIG_OF_BOARD_SETUP) + +void ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); +} + +#endif diff --git a/board/mercury/mpq101/tlb.c b/board/mercury/mpq101/tlb.c new file mode 100644 index 0000000..3e3d280 --- /dev/null +++ b/board/mercury/mpq101/tlb.c @@ -0,0 +1,82 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mmu.h> + +struct fsl_e_tlb_entry tlb_table[] = { + /* TLB 0 - for temp stack in cache */ + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, CONFIG_SYS_INIT_RAM_ADDR, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + /* + * TLB 0: 256M Non-cacheable, guarded + * 0xf0000000 256M LBC (FLASH included) + * Out of reset this entry is only 4K. + */ + SET_TLB_ENTRY(1, CONFIG_SYS_LBC_OPTION_BASE, + CONFIG_SYS_LBC_OPTION_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_256M, 1), + + /* + * TLB 1: 1M Non-cacheable, guarded + * 0xe000_0000 1M CCSRBAR + */ + SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 1, BOOKE_PAGESZ_1M, 1), + +#ifdef CONFIG_SYS_RIO_MEM_PHYS + /* + * TLB 2: 256M Non-cacheable, guarded + */ + SET_TLB_ENTRY(1, CONFIG_SYS_RIO_MEM_BASE, CONFIG_SYS_RIO_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 2, BOOKE_PAGESZ_256M, 1), + + /* + * TLB 3: 256M Non-cacheable, guarded + */ + SET_TLB_ENTRY(1, CONFIG_SYS_RIO_MEM_BASE + 0x10000000, + CONFIG_SYS_RIO_MEM_PHYS + 0x10000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 3, BOOKE_PAGESZ_256M, 1), + +#endif +}; + +int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/board/mercury/mpq101/u-boot.lds b/board/mercury/mpq101/u-boot.lds new file mode 100644 index 0000000..5b668b0 --- /dev/null +++ b/board/mercury/mpq101/u-boot.lds @@ -0,0 +1,132 @@ +/* + * Copyright 2007-2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef RESET_VECTOR_ADDRESS +#define RESET_VECTOR_ADDRESS 0xfffffffc +#endif + +#include <config.h> + +OUTPUT_ARCH(powerpc) + +PHDRS +{ + text PT_LOAD; + bss PT_LOAD; +} + +SECTIONS +{ + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .interp : { *(.interp) } + /* To simplify mass deployment, environment precedes the monitor text in the + * same flash sector. + */ + .ppcenv CONFIG_ENV_ADDR : { *(.ppcenv) } + .text : + { + *(.text*) + } :text + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + } :text + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + .reloc : + { + _GOT2_TABLE_ = .; + KEEP(*(.got2)) + KEEP(*(.got)) + PROVIDE(_GLOBAL_OFFSET_TABLE_ = . + 4); + _FIXUP_TABLE_ = .; + KEEP(*(.fixup)) + } + __got2_entries = ((_GLOBAL_OFFSET_TABLE_ - _GOT2_TABLE_) >> 2) - 1; + __fixup_entries = (. - _FIXUP_TABLE_) >> 2; + + .data : + { + *(.data*) + *(.sdata*) + } + _edata = .; + PROVIDE (edata = .); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + .bootpg RESET_VECTOR_ADDRESS - 0xffc : + { + arch/powerpc/cpu/mpc85xx/start.o (.bootpg) + } :text = 0xffff + + .resetvec RESET_VECTOR_ADDRESS : + { + KEEP(*(.resetvec)) + } :text = 0xffff + + . = RESET_VECTOR_ADDRESS + 0x4; + + /* + * Make sure that the bss segment isn't linked at 0x0, otherwise its + * address won't be updated during relocation fixups. Note that + * this is a temporary fix. Code to dynamically the fixup the bss + * location will be added in the future. When the bss relocation + * fixup code is present this workaround should be removed. + */ +#if (RESET_VECTOR_ADDRESS == 0xfffffffc) + . |= 0x10; +#endif + + __bss_start = .; + .bss (NOLOAD) : + { + *(.sbss*) + *(.bss*) + *(COMMON) + } :bss + + . = ALIGN(4); + _end = . ; + PROVIDE (end = .); +} diff --git a/boards.cfg b/boards.cfg index 0574bb2..7d7814f 100644 --- a/boards.cfg +++ b/boards.cfg @@ -502,6 +502,7 @@ P2020RDB_NAND powerpc mpc85xx p1_p2_rdb freesca P2020RDB_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020,SDCARD P2020RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020,SPIFLASH P4080DS powerpc mpc85xx corenet_ds freescale +mpq101 powerpc mpc85xx mpq101 mercury - mpq101:SYS_LDSCRIPT=board/mercury/mpq101/u-boot.lds stxgp3 powerpc mpc85xx stxgp3 stx stxssa powerpc mpc85xx stxssa stx - stxssa stxssa_4M powerpc mpc85xx stxssa stx - stxssa:STXSSA_4M diff --git a/include/configs/mpq101.h b/include/configs/mpq101.h new file mode 100644 index 0000000..33d6b69 --- /dev/null +++ b/include/configs/mpq101.h @@ -0,0 +1,398 @@ +/* + * Copyright 2011 Alex Dubov oakad@yahoo.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Merury Computers MPQ101 board configuration file + * + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +#ifdef CONFIG_36BIT +# define CONFIG_PHYS_64BIT 1 +#endif + +/* High Level Configuration Options */ +#define CONFIG_BOOKE 1 /* BOOKE */ +#define CONFIG_E500 1 /* BOOKE e500 family */ +#define CONFIG_MPC85xx 1 /* MPC8540/60/55/41/48 */ +#define CONFIG_MPC8548 1 /* MPC8548 specific */ +#define CONFIG_MPQ101 1 /* MPQ101 board specific */ + +#define CONFIG_RIO 1 +#define CONFIG_TSEC_ENET 1 /* tsec ethernet support */ +#define CONFIG_INTERRUPTS 1 /* enable pci, srio, ddr interrupts */ +#define CONFIG_FSL_LAW 1 /* Use common FSL init code */ + +/* + * These can be toggled for performance analysis, otherwise use default. + */ +#define CONFIG_L2_CACHE 1 /* toggle L2 cache */ +#define CONFIG_BTB 1 /* toggle branch predition */ + +#define CONFIG_PANIC_HANG 1 + +/* + * Only possible on E500 Version 2 or newer cores. + */ +#define CONFIG_ENABLE_36BIT_PHYS 1 + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_ADDR_MAP 1 +# define CONFIG_SYS_NUM_ADDR_MAP 16 /* number of TLB1 entries */ +#endif + +#ifndef __ASSEMBLY__ +extern unsigned long get_clock_freq(void); +#endif + +#define CONFIG_SYS_CLK_FREQ get_clock_freq() /* sysclk for MPC85xx */ + +/* + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + */ +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 +#define CONFIG_SYS_CCSRBAR 0xe0000000 + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_SYS_CCSRBAR_PHYS 0xfe0000000ull +#else +# define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR +#endif + +#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR + +/* DDR Setup */ +#define CONFIG_FSL_DDR2 + +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER 1 /* DDR controller or DMA? */ + +#define CONFIG_MEM_INIT_VALUE 0xDeadBeef +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 /* DDR is system memory*/ +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +#define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +#define CONFIG_CHIP_SELECTS_PER_CTRL (2 * CONFIG_DIMM_SLOTS_PER_CTLR) + +/* Fixed 512MB DDR2 parameters */ +#define CONFIG_SYS_SDRAM_SIZE_LOG 29 /* DDR is 512MB */ +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000001f +#define CONFIG_SYS_DDR_CS0_CONFIG 0x80014102 +#define CONFIG_SYS_DDR_TIMING_3 0x00010000 +#define CONFIG_SYS_DDR_TIMING_0 0x00260802 +#define CONFIG_SYS_DDR_TIMING_1 0x5c47a432 +#define CONFIG_SYS_DDR_TIMING_1_PERF 0x49352322 +#define CONFIG_SYS_DDR_TIMING_2 0x03984cce +#define CONFIG_SYS_DDR_TIMING_2_PERF 0x14904cca +#define CONFIG_SYS_DDR_MODE_1 0x00400442 +#define CONFIG_SYS_DDR_MODE_1_PERF 0x00480432 +#define CONFIG_SYS_DDR_MODE_2 0x00000000 +#define CONFIG_SYS_DDR_MODE_2_PERF 0x00000000 +#define CONFIG_SYS_DDR_INTERVAL 0x08200100 +#define CONFIG_SYS_DDR_INTERVAL_PERF 0x06180100 +#define CONFIG_SYS_DDR_CLK_CTRL 0x03800000 +#define CONFIG_SYS_DDR_CONTROL 0xc3008000 /* Type = DDR2 */ +#define CONFIG_SYS_DDR_CONTROL2 0x04400000 + +#define CONFIG_SYS_ALT_MEMTEST 1 +#define CONFIG_SYS_MEMTEST_START 0x0ff00000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x0ffffffc + +/* + * RAM definitions + */ +#define CONFIG_SYS_INIT_RAM_LOCK 1 +#define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */ + +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE \ + - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* Reserved for malloc */ + +/* + * Local Bus Definitions + */ +#define CONFIG_SYS_LBC_LCRR 0x00000004 /* LB clock ratio reg */ +#define CONFIG_SYS_LBC_LBCR 0x00000000 /* LB config reg */ + + +/* + * FLASH on the Local Bus + * One bank, 128M, using the CFI driver. + */ +#define CONFIG_SYS_BOOT_BLOCK 0xf8000000 /* boot TLB block */ +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_BOOT_BLOCK /* start of FLASH 128M */ + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_SYS_FLASH_BASE_PHYS 0xff8000000ull +#else +# define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE +#endif + +/* 0xf8001801 */ +#define CONFIG_SYS_BR0_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) \ + | BR_PS_32 | BR_V) + +/* 0xf8006ff7 */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(128) | OR_GPCM_XAM | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 | OR_GPCM_TRLX \ + | OR_GPCM_EHTR | OR_GPCM_EAD) + +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS} +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 /* sectors per device */ + +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_CFI 1 +#define CONFIG_SYS_FLASH_EMPTY_INFO 1 +#define CONFIG_SYS_FLASH_AMD_CHECK_DQ7 1 +/* + * When initializing flash, if we cannot find the manufacturer ID, + * assume this is the AMD flash. + */ +#define CONFIG_ASSUME_AMD_FLASH 1 + +/* + * Environment parameters + */ +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_OVERWRITE 1 +#define CONFIG_SYS_USE_PPCENV 1 +#define ENV_IS_EMBEDDED 1 +#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K */ +#define CONFIG_ENV_SIZE 0x800 + +/* Environment at the start of flash sector, before text. */ +#define CONFIG_ENV_ADDR (CONFIG_SYS_TEXT_BASE - CONFIG_ENV_SIZE) +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ +#define CONFIG_SYS_TEXT_BASE 0xfffc0800 + +/* + * Cypress CY7C67200 USB controller on the Local Bus. + * Not supported by u-boot at present. + */ +#define CONFIG_SYS_LBC_OPTION_BASE 0xf0000000 + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_SYS_LBC_OPTION_BASE_PHYS 0xff0000000ull +#else +# define CONFIG_SYS_LBC_OPTION_BASE_PHYS CONFIG_SYS_LBC_OPTION_BASE +#endif + +/* 0xf0001001 */ +#define CONFIG_SYS_BR1_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_LBC_OPTION_BASE_PHYS) \ + | BR_PS_16 | BR_V) + +/* fffff002 */ +#define CONFIG_SYS_OR1_PRELIM (P2SZ_TO_AM(0x8000) | OR_GPCM_XAM \ + | OR_GPCM_BCTLD | OR_GPCM_EHTR) + +/* + * Serial Ports + */ +#define CONFIG_CONS_INDEX 2 +#define CONFIG_SYS_NS16550 1 +#define CONFIG_SYS_NS16550_SERIAL 1 +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK get_bus_freq(0) + +#define CONFIG_SYS_BAUDRATE_TABLE {300, 600, 1200, 2400, 4800, 9600, \ + 19200, 38400, 115200} + +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600) + +/* + * I2C buses and peripherals + */ +#define CONFIG_FSL_I2C 1 /* Use FSL common I2C driver */ +#define CONFIG_HARD_I2C 1 /* I2C with hardware support*/ +#define CONFIG_I2C_MULTI_BUS 1 +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SLAVE 0x7f +#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C2_OFFSET 0x3100 + +/* I2C RTC - M41T81 */ +#define CONFIG_RTC_M41T62 1 +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 +#define CONFIG_SYS_M41T11_BASE_YEAR 2000 + +/* I2C EEPROM - 24C256 */ +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 12 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +#define CONFIG_SYS_EEPROM_BUS_NUM 1 + +/* + * RapidIO MMU + */ +#ifdef CONFIG_RIO + +# define CONFIG_SYS_RIO_MEM_BASE 0xc0000000 + +# ifdef CONFIG_PHYS_64BIT +# define CONFIG_SYS_RIO_MEM_PHYS 0xfc0000000ull +# else +# define CONFIG_SYS_RIO_MEM_PHYS CONFIG_SYS_RIO_MEM_BASE +# endif + +# define CONFIG_SYS_RIO_MEM_SIZE 0x20000000 /* 512M */ + +#endif + +/* + * Ethernet + */ +#ifdef CONFIG_TSEC_ENET + +# ifndef CONFIG_NET_MULTI +# define CONFIG_NET_MULTI 1 +# endif + +# define CONFIG_MII 1 /* MII PHY management */ +# define CONFIG_MII_DEFAULT_TSEC 1 /* Allow unregistered phys */ + +# define CONFIG_TSEC1 1 +# define CONFIG_TSEC1_NAME "eTSEC0" +# define TSEC1_PHY_ADDR 0x10 +# define TSEC1_PHYIDX 0 +# define TSEC1_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +# define CONFIG_TSEC2 1 +# define CONFIG_TSEC2_NAME "eTSEC1" +# define TSEC2_PHY_ADDR 0x11 +# define TSEC2_PHYIDX 0 +# define TSEC2_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +# define CONFIG_TSEC3 1 +# define CONFIG_TSEC3_NAME "eTSEC2" +# define TSEC3_PHY_ADDR 0x12 +# define TSEC3_PHYIDX 0 +# define TSEC3_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +# define CONFIG_TSEC4 1 +# define CONFIG_TSEC4_NAME "eTSEC3" +# define TSEC4_PHY_ADDR 0x13 +# define TSEC4_PHYIDX 0 +# define TSEC4_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +/* Options are: eTSEC[0-3] */ +# define CONFIG_ETHPRIME "eTSEC0" +# define CONFIG_PHY_GIGE 1 /* Include GbE speed/duplex detection */ +#endif + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_CMD_SNTP +#define CONFIG_CMD_I2C +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_MII +#define CONFIG_CMD_ELF +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_SETEXPR +#define CONFIG_CMD_JFFS2 + +/* + * Miscellaneous configurable options + */ + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 +#define CONFIG_OF_STDOUT_VIA_ALIAS 1 + +/* new uImage format support */ +#define CONFIG_FIT 1 +#define CONFIG_FIT_VERBOSE 1 /* enable fit_format_{error,warning}() */ + +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER 1 + +#ifdef CONFIG_SYS_HUSH_PARSER +# define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#endif + +#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ + +#define CONFIG_SYS_LONGHELP 1 /* undef to save memory */ +#define CONFIG_CMDLINE_EDITING 1 /* Command-line editing */ +#define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */ + +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "MPQ-101=> " /* Monitor Command Prompt */ + +/* Console I/O Buffer Size */ +#ifdef CONFIG_CMD_KGDB +# define CONFIG_SYS_CBSIZE 1024 +#else +# define CONFIG_SYS_CBSIZE 256 +#endif + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT)+16) + +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 16 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (16 << 20) /* Initial Memory map for Linux*/ + +#ifdef CONFIG_CMD_KGDB +# define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +# define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Basic Environment Configuration + */ +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTDELAY 5 /* -1 disables auto-boot */ + +/*default location for tftp and bootm*/ +#define CONFIG_LOADADDR CONFIG_SYS_LOAD_ADDR + +#endif /* __CONFIG_H */
Additional board information is available at: http://www.mc.com/products/boards/ensemble_mpq101_rapidio_powerquicc_iii.asp...
Changes for v4:
Changes for v3:
Changes for v2:
Can you update this against the u-boot-mpc85xx.git and use the new common SRIO init code
I assume customer linker script is because of where you have the environment. If so might be useful to add that to the commit comment.
- k
image so that it's
I was under impression that commit message and comment in the linker script make it rather clear.
Environment is configured to precede the actual u-boot image so that it's located at the beginning of flash erase block (made necessary by the recent changes to the embedded environment handling). This is achieved by means of custom ld script.
Signed-off-by: Alex Dubov oakad@yahoo.com --- Changes for v5: - Use new common SRIO configuration definitions. - Replace initdram() with platform required fixed_sdram(). - Don't use get_ram_size() in fixed_sdram() as TLBs are set after it exits by common platform code. Changes for v4: - Replace config.mk supplied linker flags with custom linker script. - Fix checkpatch errors. Changes for v3: - Use io accessor functions for all mmio accesses. - Add configuration options for RTC and EEPROM on I2C buses. Changes for v2: - Remove some stale configuration code from board initialization functions.
MAINTAINERS | 3 + board/mercury/mpq101/Makefile | 53 ++++++ board/mercury/mpq101/law.c | 52 +++++ board/mercury/mpq101/mpq101.c | 129 +++++++++++++ board/mercury/mpq101/tlb.c | 82 ++++++++ board/mercury/mpq101/u-boot.lds | 132 +++++++++++++ boards.cfg | 1 + include/configs/mpq101.h | 391 +++++++++++++++++++++++++++++++++++++++ 8 files changed, 843 insertions(+), 0 deletions(-) create mode 100644 board/mercury/mpq101/Makefile create mode 100644 board/mercury/mpq101/law.c create mode 100644 board/mercury/mpq101/mpq101.c create mode 100644 board/mercury/mpq101/tlb.c create mode 100644 board/mercury/mpq101/u-boot.lds create mode 100644 include/configs/mpq101.h
diff --git a/MAINTAINERS b/MAINTAINERS index a799037..d0fc7dc 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -138,6 +138,9 @@ Jon Diekema jon.diekema@smiths-aerospace.com
sbc8260 MPC8260
devconcenter PPC460EX diff --git a/board/mercury/mpq101/Makefile b/board/mercury/mpq101/Makefile new file mode 100644 index 0000000..58bc1b3 --- /dev/null +++ b/board/mercury/mpq101/Makefile @@ -0,0 +1,53 @@ +# +# Copyright 2007 Freescale Semiconductor, Inc. +# (C) Copyright 2001-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += $(BOARD).o +COBJS-y += law.o +COBJS-y += tlb.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS)) + +clean: + rm -f $(OBJS) $(SOBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/mercury/mpq101/law.c b/board/mercury/mpq101/law.c new file mode 100644 index 0000000..0e23a6a --- /dev/null +++ b/board/mercury/mpq101/law.c @@ -0,0 +1,52 @@ +/* + * Copyright 2008 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/mmu.h> + +/* + * LAW(Local Access Window) configuration: + * + * 0x0000_0000 0x1fff_ffff DDR SYS_SDRAM_SIZE + * 0xc000_0000 0xdfff_ffff RapidIO (set elsewhere) 512M + * 0xe000_0000 0xe000_ffff CCSR (set elsewhere) 1M + * 0xf000_0000 0xffff_ffff LBC options + FLASH 256M + * + * Notes: + * CCSRBAR and L2-as-SRAM don't need a configured Local Access Window. + * If flash is 8M at default position (last 8M), no LAW needed. + * + * LAW 0 is reserved for boot mapping + */ + +struct law_entry law_table[] = { + SET_LAW(CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_SDRAM_SIZE_LOG - 1, + LAW_TRGT_IF_DDR_1), + SET_LAW(CONFIG_SYS_LBC_OPTION_BASE_PHYS, LAW_SIZE_256M, + LAW_TRGT_IF_LBC) +}; + +int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/mercury/mpq101/mpq101.c b/board/mercury/mpq101/mpq101.c new file mode 100644 index 0000000..e02e87f --- /dev/null +++ b/board/mercury/mpq101/mpq101.c @@ -0,0 +1,129 @@ +/* + * (C) Copyright 2011 Alex Dubov oakad@yahoo.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/processor.h> +#include <asm/mmu.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/io.h> +#include <miiphy.h> +#include <libfdt.h> +#include <fdt_support.h> + +/* + * Initialize Local Bus + */ +void local_bus_init(void) +{ + fsl_lbc_t *lbc = LBC_BASE_ADDR; + + out_be32(&lbc->ltesr, 0xffffffff); /* Clear LBC error interrupts */ + out_be32(&lbc->lteir, 0xffffffff); /* Enable LBC error interrupts */ +} + +int checkboard(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + ccsr_local_ecm_t *ecm = (void *)(CONFIG_SYS_MPC85xx_ECM_ADDR); + + puts("Board: Mercury Computer Systems, Inc. MPQ-101 "); +#ifdef CONFIG_PHYS_64BIT + puts("(36-bit addrmap) "); +#endif + putc('\n'); + + /* + * Initialize local bus. + */ + local_bus_init(); + + /* + * Hack TSEC 3 and 4 IO voltages. + */ + out_be32(&gur->tsec34ioovcr, 0xe7e0); /* 1110 0111 1110 0xxx */ + + out_be32(&ecm->eedr, 0xffffffff); /* clear ecm errors */ + out_be32(&ecm->eeer, 0xffffffff); /* enable ecm errors */ + return 0; +} + +phys_size_t fixed_sdram(void) +{ + ccsr_ddr_t *ddr = (void *)(CONFIG_SYS_MPC85xx_DDR_ADDR); + const char *p_mode = getenv("perf_mode"); + + puts("Initializing...."); + + out_be32(&ddr->cs0_bnds, CONFIG_SYS_DDR_CS0_BNDS); + out_be32(&ddr->cs0_config, CONFIG_SYS_DDR_CS0_CONFIG); + + out_be32(&ddr->timing_cfg_3, CONFIG_SYS_DDR_TIMING_3); + out_be32(&ddr->timing_cfg_0, CONFIG_SYS_DDR_TIMING_0); + + if (p_mode && !strcmp("performance", p_mode)) { + out_be32(&ddr->timing_cfg_1, CONFIG_SYS_DDR_TIMING_1_PERF); + out_be32(&ddr->timing_cfg_2, CONFIG_SYS_DDR_TIMING_2_PERF); + out_be32(&ddr->sdram_mode, CONFIG_SYS_DDR_MODE_1_PERF); + out_be32(&ddr->sdram_mode_2, CONFIG_SYS_DDR_MODE_2_PERF); + out_be32(&ddr->sdram_interval, CONFIG_SYS_DDR_INTERVAL_PERF); + } else { + out_be32(&ddr->timing_cfg_1, CONFIG_SYS_DDR_TIMING_1); + out_be32(&ddr->timing_cfg_2, CONFIG_SYS_DDR_TIMING_2); + out_be32(&ddr->sdram_mode, CONFIG_SYS_DDR_MODE_1); + out_be32(&ddr->sdram_mode_2, CONFIG_SYS_DDR_MODE_2); + out_be32(&ddr->sdram_interval, CONFIG_SYS_DDR_INTERVAL); + } + + out_be32(&ddr->sdram_clk_cntl, CONFIG_SYS_DDR_CLK_CTRL); + out_be32(&ddr->sdram_cfg_2, CONFIG_SYS_DDR_CONTROL2); + + asm("sync;isync"); + udelay(500); + + out_be32(&ddr->sdram_cfg, CONFIG_SYS_DDR_CONTROL); + asm("sync; isync"); + udelay(500); + + return ((phys_size_t)1) << CONFIG_SYS_SDRAM_SIZE_LOG; +} + +void pci_init_board(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + + /* PCI is disabled */ + out_be32(&gur->devdisr, in_be32(&gur->devdisr) + | MPC85xx_DEVDISR_PCI1 + | MPC85xx_DEVDISR_PCI2 + | MPC85xx_DEVDISR_PCIE); +} + + +#if defined(CONFIG_OF_BOARD_SETUP) + +void ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); +} + +#endif diff --git a/board/mercury/mpq101/tlb.c b/board/mercury/mpq101/tlb.c new file mode 100644 index 0000000..3e3d280 --- /dev/null +++ b/board/mercury/mpq101/tlb.c @@ -0,0 +1,82 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mmu.h> + +struct fsl_e_tlb_entry tlb_table[] = { + /* TLB 0 - for temp stack in cache */ + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, CONFIG_SYS_INIT_RAM_ADDR, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + /* + * TLB 0: 256M Non-cacheable, guarded + * 0xf0000000 256M LBC (FLASH included) + * Out of reset this entry is only 4K. + */ + SET_TLB_ENTRY(1, CONFIG_SYS_LBC_OPTION_BASE, + CONFIG_SYS_LBC_OPTION_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_256M, 1), + + /* + * TLB 1: 1M Non-cacheable, guarded + * 0xe000_0000 1M CCSRBAR + */ + SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 1, BOOKE_PAGESZ_1M, 1), + +#ifdef CONFIG_SYS_RIO_MEM_PHYS + /* + * TLB 2: 256M Non-cacheable, guarded + */ + SET_TLB_ENTRY(1, CONFIG_SYS_RIO_MEM_BASE, CONFIG_SYS_RIO_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 2, BOOKE_PAGESZ_256M, 1), + + /* + * TLB 3: 256M Non-cacheable, guarded + */ + SET_TLB_ENTRY(1, CONFIG_SYS_RIO_MEM_BASE + 0x10000000, + CONFIG_SYS_RIO_MEM_PHYS + 0x10000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 3, BOOKE_PAGESZ_256M, 1), + +#endif +}; + +int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/board/mercury/mpq101/u-boot.lds b/board/mercury/mpq101/u-boot.lds new file mode 100644 index 0000000..3af0274 --- /dev/null +++ b/board/mercury/mpq101/u-boot.lds @@ -0,0 +1,132 @@ +/* + * Copyright 2007-2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef RESET_VECTOR_ADDRESS +#define RESET_VECTOR_ADDRESS 0xfffffffc +#endif + +#include <config.h> + +OUTPUT_ARCH(powerpc) + +PHDRS +{ + text PT_LOAD; + bss PT_LOAD; +} + +SECTIONS +{ + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .interp : { *(.interp) } + /* To simplify mass deployment, environment precedes the monitor text in the + * same flash sector. + */ + .ppcenv CONFIG_ENV_ADDR : { *(.ppcenv) } + .text : + { + *(.text*) + } :text + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + } :text + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + .reloc : + { + _GOT2_TABLE_ = .; + KEEP(*(.got2)) + KEEP(*(.got)) + PROVIDE(_GLOBAL_OFFSET_TABLE_ = . + 4); + _FIXUP_TABLE_ = .; + KEEP(*(.fixup)) + } + __got2_entries = ((_GLOBAL_OFFSET_TABLE_ - _GOT2_TABLE_) >> 2) - 1; + __fixup_entries = (. - _FIXUP_TABLE_) >> 2; + + .data : + { + *(.data*) + *(.sdata*) + } + _edata = .; + PROVIDE (edata = .); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + .bootpg RESET_VECTOR_ADDRESS - 0xffc : + { + arch/powerpc/cpu/mpc85xx/start.o (.bootpg) + } :text = 0xffff + + .resetvec RESET_VECTOR_ADDRESS : + { + KEEP(*(.resetvec)) + } :text = 0xffff + + . = RESET_VECTOR_ADDRESS + 0x4; + + /* + * Make sure that the bss segment isn't linked at 0x0, otherwise its + * address won't be updated during relocation fixups. Note that + * this is a temporary fix. Code to dynamically the fixup the bss + * location will be added in the future. When the bss relocation + * fixup code is present this workaround should be removed. + */ +#if (RESET_VECTOR_ADDRESS == 0xfffffffc) + . |= 0x10; +#endif + + __bss_start = .; + .bss (NOLOAD) : + { + *(.sbss*) + *(.bss*) + *(COMMON) + } :bss + + . = ALIGN(4); + _end = . ; + PROVIDE (end = .); +} diff --git a/boards.cfg b/boards.cfg index 3497408..0f94969 100644 --- a/boards.cfg +++ b/boards.cfg @@ -495,6 +495,7 @@ P2020RDB_NAND powerpc mpc85xx p1_p2_rdb freesca P2020RDB_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020,SDCARD P2020RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020,SPIFLASH P4080DS powerpc mpc85xx corenet_ds freescale +mpq101 powerpc mpc85xx mpq101 mercury - mpq101:SYS_LDSCRIPT=board/mercury/mpq101/u-boot.lds stxgp3 powerpc mpc85xx stxgp3 stx stxssa powerpc mpc85xx stxssa stx - stxssa stxssa_4M powerpc mpc85xx stxssa stx - stxssa:STXSSA_4M diff --git a/include/configs/mpq101.h b/include/configs/mpq101.h new file mode 100644 index 0000000..4996c89 --- /dev/null +++ b/include/configs/mpq101.h @@ -0,0 +1,391 @@ +/* + * Copyright 2011 Alex Dubov oakad@yahoo.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Merury Computers MPQ101 board configuration file + * + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +#ifdef CONFIG_36BIT +# define CONFIG_PHYS_64BIT 1 +#endif + +/* High Level Configuration Options */ +#define CONFIG_BOOKE 1 /* BOOKE */ +#define CONFIG_E500 1 /* BOOKE e500 family */ +#define CONFIG_MPC85xx 1 /* MPC8540/60/55/41/48 */ +#define CONFIG_MPC8548 1 /* MPC8548 specific */ +#define CONFIG_MPQ101 1 /* MPQ101 board specific */ + +#define CONFIG_SYS_SRIO 1 /* enable serial RapidIO */ +#define CONFIG_TSEC_ENET 1 /* tsec ethernet support */ +#define CONFIG_INTERRUPTS 1 /* enable pci, srio, ddr interrupts */ +#define CONFIG_FSL_LAW 1 /* Use common FSL init code */ + +/* + * These can be toggled for performance analysis, otherwise use default. + */ +#define CONFIG_L2_CACHE 1 /* toggle L2 cache */ +#define CONFIG_BTB 1 /* toggle branch predition */ + +#define CONFIG_PANIC_HANG 1 + +/* + * Only possible on E500 Version 2 or newer cores. + */ +#define CONFIG_ENABLE_36BIT_PHYS 1 + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_ADDR_MAP 1 +# define CONFIG_SYS_NUM_ADDR_MAP 16 /* number of TLB1 entries */ +#endif + + +#define CONFIG_SYS_CLK_FREQ 33000000 /* sysclk for MPC85xx */ + +/* + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + */ +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 +#define CONFIG_SYS_CCSRBAR 0xe0000000 + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_SYS_CCSRBAR_PHYS 0xfe0000000ull +#else +# define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR +#endif + +#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR + +/* DDR Setup */ +#define CONFIG_FSL_DDR2 + +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER 1 /* DDR controller or DMA? */ + +#define CONFIG_MEM_INIT_VALUE 0xDeadBeef +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 /* DDR is system memory*/ +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +#define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +#define CONFIG_CHIP_SELECTS_PER_CTRL (2 * CONFIG_DIMM_SLOTS_PER_CTLR) + +/* Fixed 512MB DDR2 parameters */ +#define CONFIG_SYS_SDRAM_SIZE_LOG 29 /* DDR is 512MB */ +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000001f +#define CONFIG_SYS_DDR_CS0_CONFIG 0x80014102 +#define CONFIG_SYS_DDR_TIMING_3 0x00010000 +#define CONFIG_SYS_DDR_TIMING_0 0x00260802 +#define CONFIG_SYS_DDR_TIMING_1 0x5c47a432 +#define CONFIG_SYS_DDR_TIMING_1_PERF 0x49352322 +#define CONFIG_SYS_DDR_TIMING_2 0x03984cce +#define CONFIG_SYS_DDR_TIMING_2_PERF 0x14904cca +#define CONFIG_SYS_DDR_MODE_1 0x00400442 +#define CONFIG_SYS_DDR_MODE_1_PERF 0x00480432 +#define CONFIG_SYS_DDR_MODE_2 0x00000000 +#define CONFIG_SYS_DDR_MODE_2_PERF 0x00000000 +#define CONFIG_SYS_DDR_INTERVAL 0x08200100 +#define CONFIG_SYS_DDR_INTERVAL_PERF 0x06180100 +#define CONFIG_SYS_DDR_CLK_CTRL 0x03800000 +#define CONFIG_SYS_DDR_CONTROL 0xc3008000 /* Type = DDR2 */ +#define CONFIG_SYS_DDR_CONTROL2 0x04400000 + +#define CONFIG_SYS_ALT_MEMTEST 1 +#define CONFIG_SYS_MEMTEST_START 0x0ff00000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x0ffffffc + +/* + * RAM definitions + */ +#define CONFIG_SYS_INIT_RAM_LOCK 1 +#define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */ + +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE \ + - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* Reserved for malloc */ + +/* + * Local Bus Definitions + */ +#define CONFIG_SYS_LBC_LCRR 0x00000004 /* LB clock ratio reg */ +#define CONFIG_SYS_LBC_LBCR 0x00000000 /* LB config reg */ + + +/* + * FLASH on the Local Bus + * One bank, 128M, using the CFI driver. + */ +#define CONFIG_SYS_BOOT_BLOCK 0xf8000000 /* boot TLB block */ +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_BOOT_BLOCK /* start of FLASH 128M */ + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_SYS_FLASH_BASE_PHYS 0xff8000000ull +#else +# define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE +#endif + +/* 0xf8001801 */ +#define CONFIG_SYS_BR0_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) \ + | BR_PS_32 | BR_V) + +/* 0xf8006ff7 */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(128) | OR_GPCM_XAM | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 | OR_GPCM_TRLX \ + | OR_GPCM_EHTR | OR_GPCM_EAD) + +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS} +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 /* sectors per device */ + +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_CFI 1 +#define CONFIG_SYS_FLASH_EMPTY_INFO 1 +#define CONFIG_SYS_FLASH_AMD_CHECK_DQ7 1 +/* + * When initializing flash, if we cannot find the manufacturer ID, + * assume this is the AMD flash. + */ +#define CONFIG_ASSUME_AMD_FLASH 1 + +/* + * Environment parameters + */ +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_OVERWRITE 1 +#define CONFIG_SYS_USE_PPCENV 1 +#define ENV_IS_EMBEDDED 1 +#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K */ +#define CONFIG_ENV_SIZE 0x800 + +/* Environment at the start of flash sector, before text. */ +#define CONFIG_ENV_ADDR (CONFIG_SYS_TEXT_BASE - CONFIG_ENV_SIZE) +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ +#define CONFIG_SYS_TEXT_BASE 0xfffc0800 + +/* + * Cypress CY7C67200 USB controller on the Local Bus. + * Not supported by u-boot at present. + */ +#define CONFIG_SYS_LBC_OPTION_BASE 0xf0000000 + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_SYS_LBC_OPTION_BASE_PHYS 0xff0000000ull +#else +# define CONFIG_SYS_LBC_OPTION_BASE_PHYS CONFIG_SYS_LBC_OPTION_BASE +#endif + +/* 0xf0001001 */ +#define CONFIG_SYS_BR1_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_LBC_OPTION_BASE_PHYS) \ + | BR_PS_16 | BR_V) + +/* fffff002 */ +#define CONFIG_SYS_OR1_PRELIM (P2SZ_TO_AM(0x8000) | OR_GPCM_XAM \ + | OR_GPCM_BCTLD | OR_GPCM_EHTR) + +/* + * Serial Ports + */ +#define CONFIG_CONS_INDEX 2 +#define CONFIG_SYS_NS16550 1 +#define CONFIG_SYS_NS16550_SERIAL 1 +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK get_bus_freq(0) + +#define CONFIG_SYS_BAUDRATE_TABLE {300, 600, 1200, 2400, 4800, 9600, \ + 19200, 38400, 115200} + +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600) + +/* + * I2C buses and peripherals + */ +#define CONFIG_FSL_I2C 1 /* Use FSL common I2C driver */ +#define CONFIG_HARD_I2C 1 /* I2C with hardware support*/ +#define CONFIG_I2C_MULTI_BUS 1 +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SLAVE 0x7f +#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C2_OFFSET 0x3100 + +/* I2C RTC - M41T81 */ +#define CONFIG_RTC_M41T62 1 +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 +#define CONFIG_SYS_M41T11_BASE_YEAR 2000 + +/* I2C EEPROM - 24C256 */ +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 12 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +#define CONFIG_SYS_EEPROM_BUS_NUM 1 + +/* + * RapidIO MMU + */ +#define CONFIG_SRIO1 1 +#define CONFIG_SYS_SRIO1_MEM_VIRT 0xc0000000 +#define CONFIG_SYS_SRIO1_MEM_SIZE 0x20000000 /* 512M */ + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_SYS_SRIO1_MEM_PHYS 0xfc0000000ull +#else +# define CONFIG_SYS_SRIO1_MEM_PHYS CONFIG_SYS_SRIO1_MEM_VIRT +#endif + +/* + * Ethernet + */ +#ifdef CONFIG_TSEC_ENET + +# ifndef CONFIG_NET_MULTI +# define CONFIG_NET_MULTI 1 +# endif + +# define CONFIG_MII 1 /* MII PHY management */ +# define CONFIG_MII_DEFAULT_TSEC 1 /* Allow unregistered phys */ + +# define CONFIG_TSEC1 1 +# define CONFIG_TSEC1_NAME "eTSEC0" +# define TSEC1_PHY_ADDR 0x10 +# define TSEC1_PHYIDX 0 +# define TSEC1_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +# define CONFIG_TSEC2 1 +# define CONFIG_TSEC2_NAME "eTSEC1" +# define TSEC2_PHY_ADDR 0x11 +# define TSEC2_PHYIDX 0 +# define TSEC2_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +# define CONFIG_TSEC3 1 +# define CONFIG_TSEC3_NAME "eTSEC2" +# define TSEC3_PHY_ADDR 0x12 +# define TSEC3_PHYIDX 0 +# define TSEC3_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +# define CONFIG_TSEC4 1 +# define CONFIG_TSEC4_NAME "eTSEC3" +# define TSEC4_PHY_ADDR 0x13 +# define TSEC4_PHYIDX 0 +# define TSEC4_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +/* Options are: eTSEC[0-3] */ +# define CONFIG_ETHPRIME "eTSEC0" +# define CONFIG_PHY_GIGE 1 /* Include GbE speed/duplex detection */ +#endif + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_CMD_SNTP +#define CONFIG_CMD_I2C +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_MII +#define CONFIG_CMD_ELF +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_SETEXPR +#define CONFIG_CMD_JFFS2 + +/* + * Miscellaneous configurable options + */ + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT 1 +#define CONFIG_OF_BOARD_SETUP 1 +#define CONFIG_OF_STDOUT_VIA_ALIAS 1 + +/* new uImage format support */ +#define CONFIG_FIT 1 +#define CONFIG_FIT_VERBOSE 1 /* enable fit_format_{error,warning}() */ + +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER 1 + +#ifdef CONFIG_SYS_HUSH_PARSER +# define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#endif + +#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ + +#define CONFIG_SYS_LONGHELP 1 /* undef to save memory */ +#define CONFIG_CMDLINE_EDITING 1 /* Command-line editing */ +#define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */ + +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "MPQ-101=> " /* Monitor Command Prompt */ + +/* Console I/O Buffer Size */ +#ifdef CONFIG_CMD_KGDB +# define CONFIG_SYS_CBSIZE 1024 +#else +# define CONFIG_SYS_CBSIZE 256 +#endif + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT)+16) + +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 16 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (16 << 20) /* Initial Memory map for Linux*/ + +#ifdef CONFIG_CMD_KGDB +# define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +# define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Basic Environment Configuration + */ +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTDELAY 5 /* -1 disables auto-boot */ + +/*default location for tftp and bootm*/ +#define CONFIG_LOADADDR CONFIG_SYS_LOAD_ADDR + +#endif /* __CONFIG_H */
On Jan 17, 2011, at 1:26 AM, Alex Dubov wrote:
- Merury Computers MPQ101 board configuration file
Remove all the '1'. Yes a ton of config.h do this and its not needed. We need to clean them up but haven't gotten around to it.
- These can be toggled for performance analysis, otherwise use default.
- Only possible on E500 Version 2 or newer cores.
- Base addresses -- Note these are effective addresses where the
- actual resources get mapped (not physical addresses)
- RAM definitions
- Local Bus Definitions
- FLASH on the Local Bus
- One bank, 128M, using the CFI driver.
| BR_PS_32 | BR_V)
- When initializing flash, if we cannot find the manufacturer ID,
- assume this is the AMD flash.
- Environment parameters
- Cypress CY7C67200 USB controller on the Local Bus.
- Not supported by u-boot at present.
| BR_PS_16 | BR_V)
- Serial Ports
- I2C buses and peripherals
- RapidIO MMU
- Ethernet
- Command line configuration.
- Miscellaneous configurable options
- For booting Linux, the board info and command line data
- have to be in the first 16 MB of memory, since this is
- the maximum mapped by the Linux kernel during initialization.
- Basic Environment Configuration
1.7.3.2
Mpq101 is a RapidIO development board in AMC form factor, featuring MPC8548 processor, 512MB of hardwired DDR2 RAM, 128MB of hardwired NAND flash memory, real time clock and additional serial EEPROM on i2c bus (enabled). USB controller is available, but not presently enabled.
Signed-off-by: Alex Dubov oakad@yahoo.com --- Changes for v6: - Remove "1"s from feature defines and fix a SRIO ifdef in tlb.c Changes for v5: - Use new common SRIO configuration definitions. - Replace initdram() with platform required fixed_sdram(). - Don't use get_ram_size() in fixed_sdram() as TLBs are set after it exits by common platform code. Changes for v4: - Replace config.mk supplied linker flags with custom linker script. - Fix checkpatch errors. Changes for v3: - Use io accessor functions for all mmio accesses. - Add configuration options for RTC and EEPROM on I2C buses. Changes for v2: - Remove some stale configuration code from board initialization functions.
MAINTAINERS | 3 + board/mercury/mpq101/Makefile | 53 ++++++ board/mercury/mpq101/law.c | 52 +++++ board/mercury/mpq101/mpq101.c | 129 +++++++++++++ board/mercury/mpq101/tlb.c | 82 ++++++++ board/mercury/mpq101/u-boot.lds | 132 +++++++++++++ boards.cfg | 1 + include/configs/mpq101.h | 392 +++++++++++++++++++++++++++++++++++++++ 8 files changed, 844 insertions(+), 0 deletions(-) create mode 100644 board/mercury/mpq101/Makefile create mode 100644 board/mercury/mpq101/law.c create mode 100644 board/mercury/mpq101/mpq101.c create mode 100644 board/mercury/mpq101/tlb.c create mode 100644 board/mercury/mpq101/u-boot.lds create mode 100644 include/configs/mpq101.h
sbc8260 MPC8260
+Alex Dubov oakad@yahoo.com + mpq101 MPC8548 + Dirk Eibach eibach@gdsys.de
devconcenter PPC460EX diff --git a/board/mercury/mpq101/Makefile b/board/mercury/mpq101/Makefile new file mode 100644 index 0000000..58bc1b3 --- /dev/null +++ b/board/mercury/mpq101/Makefile @@ -0,0 +1,53 @@ +# +# Copyright 2007 Freescale Semiconductor, Inc. +# (C) Copyright 2001-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += $(BOARD).o +COBJS-y += law.o +COBJS-y += tlb.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS)) + +clean: + rm -f $(OBJS) $(SOBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/mercury/mpq101/law.c b/board/mercury/mpq101/law.c new file mode 100644 index 0000000..0e23a6a --- /dev/null +++ b/board/mercury/mpq101/law.c @@ -0,0 +1,52 @@ +/* + * Copyright 2008 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/mmu.h> + +/* + * LAW(Local Access Window) configuration: + * + * 0x0000_0000 0x1fff_ffff DDR SYS_SDRAM_SIZE + * 0xc000_0000 0xdfff_ffff RapidIO (set elsewhere) 512M + * 0xe000_0000 0xe000_ffff CCSR (set elsewhere) 1M + * 0xf000_0000 0xffff_ffff LBC options + FLASH 256M + * + * Notes: + * CCSRBAR and L2-as-SRAM don't need a configured Local Access Window. + * If flash is 8M at default position (last 8M), no LAW needed. + * + * LAW 0 is reserved for boot mapping + */ + +struct law_entry law_table[] = { + SET_LAW(CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_SDRAM_SIZE_LOG - 1, + LAW_TRGT_IF_DDR_1), + SET_LAW(CONFIG_SYS_LBC_OPTION_BASE_PHYS, LAW_SIZE_256M, + LAW_TRGT_IF_LBC) +}; + +int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/mercury/mpq101/mpq101.c b/board/mercury/mpq101/mpq101.c new file mode 100644 index 0000000..e02e87f --- /dev/null +++ b/board/mercury/mpq101/mpq101.c @@ -0,0 +1,129 @@ +/* + * (C) Copyright 2011 Alex Dubov oakad@yahoo.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/processor.h> +#include <asm/mmu.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/io.h> +#include <miiphy.h> +#include <libfdt.h> +#include <fdt_support.h> + +/* + * Initialize Local Bus + */ +void local_bus_init(void) +{ + fsl_lbc_t *lbc = LBC_BASE_ADDR; + + out_be32(&lbc->ltesr, 0xffffffff); /* Clear LBC error interrupts */ + out_be32(&lbc->lteir, 0xffffffff); /* Enable LBC error interrupts */ +} + +int checkboard(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + ccsr_local_ecm_t *ecm = (void *)(CONFIG_SYS_MPC85xx_ECM_ADDR); + + puts("Board: Mercury Computer Systems, Inc. MPQ-101 "); +#ifdef CONFIG_PHYS_64BIT + puts("(36-bit addrmap) "); +#endif + putc('\n'); + + /* + * Initialize local bus. + */ + local_bus_init(); + + /* + * Hack TSEC 3 and 4 IO voltages. + */ + out_be32(&gur->tsec34ioovcr, 0xe7e0); /* 1110 0111 1110 0xxx */ + + out_be32(&ecm->eedr, 0xffffffff); /* clear ecm errors */ + out_be32(&ecm->eeer, 0xffffffff); /* enable ecm errors */ + return 0; +} + +phys_size_t fixed_sdram(void) +{ + ccsr_ddr_t *ddr = (void *)(CONFIG_SYS_MPC85xx_DDR_ADDR); + const char *p_mode = getenv("perf_mode"); + + puts("Initializing...."); + + out_be32(&ddr->cs0_bnds, CONFIG_SYS_DDR_CS0_BNDS); + out_be32(&ddr->cs0_config, CONFIG_SYS_DDR_CS0_CONFIG); + + out_be32(&ddr->timing_cfg_3, CONFIG_SYS_DDR_TIMING_3); + out_be32(&ddr->timing_cfg_0, CONFIG_SYS_DDR_TIMING_0); + + if (p_mode && !strcmp("performance", p_mode)) { + out_be32(&ddr->timing_cfg_1, CONFIG_SYS_DDR_TIMING_1_PERF); + out_be32(&ddr->timing_cfg_2, CONFIG_SYS_DDR_TIMING_2_PERF); + out_be32(&ddr->sdram_mode, CONFIG_SYS_DDR_MODE_1_PERF); + out_be32(&ddr->sdram_mode_2, CONFIG_SYS_DDR_MODE_2_PERF); + out_be32(&ddr->sdram_interval, CONFIG_SYS_DDR_INTERVAL_PERF); + } else { + out_be32(&ddr->timing_cfg_1, CONFIG_SYS_DDR_TIMING_1); + out_be32(&ddr->timing_cfg_2, CONFIG_SYS_DDR_TIMING_2); + out_be32(&ddr->sdram_mode, CONFIG_SYS_DDR_MODE_1); + out_be32(&ddr->sdram_mode_2, CONFIG_SYS_DDR_MODE_2); + out_be32(&ddr->sdram_interval, CONFIG_SYS_DDR_INTERVAL); + } + + out_be32(&ddr->sdram_clk_cntl, CONFIG_SYS_DDR_CLK_CTRL); + out_be32(&ddr->sdram_cfg_2, CONFIG_SYS_DDR_CONTROL2); + + asm("sync;isync"); + udelay(500); + + out_be32(&ddr->sdram_cfg, CONFIG_SYS_DDR_CONTROL); + asm("sync; isync"); + udelay(500); + + return ((phys_size_t)1) << CONFIG_SYS_SDRAM_SIZE_LOG; +} + +void pci_init_board(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + + /* PCI is disabled */ + out_be32(&gur->devdisr, in_be32(&gur->devdisr) + | MPC85xx_DEVDISR_PCI1 + | MPC85xx_DEVDISR_PCI2 + | MPC85xx_DEVDISR_PCIE); +} + + +#if defined(CONFIG_OF_BOARD_SETUP) + +void ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); +} + +#endif diff --git a/board/mercury/mpq101/tlb.c b/board/mercury/mpq101/tlb.c new file mode 100644 index 0000000..fd2eaec --- /dev/null +++ b/board/mercury/mpq101/tlb.c @@ -0,0 +1,82 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mmu.h> + +struct fsl_e_tlb_entry tlb_table[] = { + /* TLB 0 - for temp stack in cache */ + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, CONFIG_SYS_INIT_RAM_ADDR, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + /* + * TLB 0: 256M Non-cacheable, guarded + * 0xf0000000 256M LBC (FLASH included) + * Out of reset this entry is only 4K. + */ + SET_TLB_ENTRY(1, CONFIG_SYS_LBC_OPTION_BASE, + CONFIG_SYS_LBC_OPTION_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_256M, 1), + + /* + * TLB 1: 1M Non-cacheable, guarded + * 0xe000_0000 1M CCSRBAR + */ + SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 1, BOOKE_PAGESZ_1M, 1), + +#ifdef CONFIG_SYS_SRIO1_MEM_PHYS + /* + * TLB 2: 256M Non-cacheable, guarded + */ + SET_TLB_ENTRY(1, CONFIG_SYS_SRIO1_MEM_VIRT, CONFIG_SYS_SRIO1_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 2, BOOKE_PAGESZ_256M, 1), + + /* + * TLB 3: 256M Non-cacheable, guarded + */ + SET_TLB_ENTRY(1, CONFIG_SYS_SRIO1_MEM_VIRT + 0x10000000, + CONFIG_SYS_SRIO1_MEM_PHYS + 0x10000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 3, BOOKE_PAGESZ_256M, 1), + +#endif +}; + +int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/board/mercury/mpq101/u-boot.lds b/board/mercury/mpq101/u-boot.lds new file mode 100644 index 0000000..3af0274 --- /dev/null +++ b/board/mercury/mpq101/u-boot.lds @@ -0,0 +1,132 @@ +/* + * Copyright 2007-2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef RESET_VECTOR_ADDRESS +#define RESET_VECTOR_ADDRESS 0xfffffffc +#endif + +#include <config.h> + +OUTPUT_ARCH(powerpc) + +PHDRS +{ + text PT_LOAD; + bss PT_LOAD; +} + +SECTIONS +{ + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .interp : { *(.interp) } + /* To simplify mass deployment, environment precedes the monitor text in the + * same flash sector. + */ + .ppcenv CONFIG_ENV_ADDR : { *(.ppcenv) } + .text : + { + *(.text*) + } :text + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + } :text + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + .reloc : + { + _GOT2_TABLE_ = .; + KEEP(*(.got2)) + KEEP(*(.got)) + PROVIDE(_GLOBAL_OFFSET_TABLE_ = . + 4); + _FIXUP_TABLE_ = .; + KEEP(*(.fixup)) + } + __got2_entries = ((_GLOBAL_OFFSET_TABLE_ - _GOT2_TABLE_) >> 2) - 1; + __fixup_entries = (. - _FIXUP_TABLE_) >> 2; + + .data : + { + *(.data*) + *(.sdata*) + } + _edata = .; + PROVIDE (edata = .); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + .bootpg RESET_VECTOR_ADDRESS - 0xffc : + { + arch/powerpc/cpu/mpc85xx/start.o (.bootpg) + } :text = 0xffff + + .resetvec RESET_VECTOR_ADDRESS : + { + KEEP(*(.resetvec)) + } :text = 0xffff + + . = RESET_VECTOR_ADDRESS + 0x4; + + /* + * Make sure that the bss segment isn't linked at 0x0, otherwise its + * address won't be updated during relocation fixups. Note that + * this is a temporary fix. Code to dynamically the fixup the bss + * location will be added in the future. When the bss relocation + * fixup code is present this workaround should be removed. + */ +#if (RESET_VECTOR_ADDRESS == 0xfffffffc) + . |= 0x10; +#endif + + __bss_start = .; + .bss (NOLOAD) : + { + *(.sbss*) + *(.bss*) + *(COMMON) + } :bss + + . = ALIGN(4); + _end = . ; + PROVIDE (end = .); +} diff --git a/boards.cfg b/boards.cfg index 3497408..0f94969 100644 --- a/boards.cfg +++ b/boards.cfg @@ -495,6 +495,7 @@ P2020RDB_NAND powerpc mpc85xx p1_p2_rdb freesca P2020RDB_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020,SDCARD P2020RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020,SPIFLASH P4080DS powerpc mpc85xx corenet_ds freescale +mpq101 powerpc mpc85xx mpq101 mercury - mpq101:SYS_LDSCRIPT=board/mercury/mpq101/u-boot.lds stxgp3 powerpc mpc85xx stxgp3 stx stxssa powerpc mpc85xx stxssa stx - stxssa stxssa_4M powerpc mpc85xx stxssa stx - stxssa:STXSSA_4M diff --git a/include/configs/mpq101.h b/include/configs/mpq101.h new file mode 100644 index 0000000..9b30ed4 --- /dev/null +++ b/include/configs/mpq101.h @@ -0,0 +1,392 @@ +/* + * Copyright 2011 Alex Dubov oakad@yahoo.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Merury Computers MPQ101 board configuration file + * + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +#ifdef CONFIG_36BIT +# define CONFIG_PHYS_64BIT +#endif + +/* High Level Configuration Options */ +#define CONFIG_BOOKE /* BOOKE */ +#define CONFIG_E500 /* BOOKE e500 family */ +#define CONFIG_MPC85xx /* MPC8540/60/55/41/48 */ +#define CONFIG_MPC8548 /* MPC8548 specific */ +#define CONFIG_MPQ101 /* MPQ101 board specific */ + +#define CONFIG_SYS_SRIO /* enable serial RapidIO */ +#define CONFIG_TSEC_ENET /* tsec ethernet support */ +#define CONFIG_INTERRUPTS /* enable pci, srio, ddr interrupts */ +#define CONFIG_FSL_LAW /* Use common FSL init code */ + +/* + * These can be toggled for performance analysis, otherwise use default. + */ +#define CONFIG_L2_CACHE /* toggle L2 cache */ +#define CONFIG_BTB /* toggle branch predition */ + +#define CONFIG_PANIC_HANG + +/* + * Only possible on E500 Version 2 or newer cores. + */ +#define CONFIG_ENABLE_36BIT_PHYS + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_ADDR_MAP +# define CONFIG_SYS_NUM_ADDR_MAP 16 /* number of TLB1 entries */ +#endif + + +#define CONFIG_SYS_CLK_FREQ 33000000 /* sysclk for MPC85xx */ + +/* + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + */ +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 +#define CONFIG_SYS_CCSRBAR 0xe0000000 + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_SYS_CCSRBAR_PHYS 0xfe0000000ull +#else +# define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR +#endif + +#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR + +/* DDR Setup */ +#define CONFIG_FSL_DDR2 + +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER /* DDR controller or DMA? */ + +#define CONFIG_MEM_INIT_VALUE 0xDeadBeef +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 /* DDR is system memory*/ +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +#define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +#define CONFIG_CHIP_SELECTS_PER_CTRL (2 * CONFIG_DIMM_SLOTS_PER_CTLR) + +/* Fixed 512MB DDR2 parameters */ +#define CONFIG_SYS_SDRAM_SIZE_LOG 29 /* DDR is 512MB */ +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000001f +#define CONFIG_SYS_DDR_CS0_CONFIG 0x80014102 +#define CONFIG_SYS_DDR_TIMING_3 0x00010000 +#define CONFIG_SYS_DDR_TIMING_0 0x00260802 +#define CONFIG_SYS_DDR_TIMING_1 0x5c47a432 +#define CONFIG_SYS_DDR_TIMING_1_PERF 0x49352322 +#define CONFIG_SYS_DDR_TIMING_2 0x03984cce +#define CONFIG_SYS_DDR_TIMING_2_PERF 0x14904cca +#define CONFIG_SYS_DDR_MODE_1 0x00400442 +#define CONFIG_SYS_DDR_MODE_1_PERF 0x00480432 +#define CONFIG_SYS_DDR_MODE_2 0x00000000 +#define CONFIG_SYS_DDR_MODE_2_PERF 0x00000000 +#define CONFIG_SYS_DDR_INTERVAL 0x08200100 +#define CONFIG_SYS_DDR_INTERVAL_PERF 0x06180100 +#define CONFIG_SYS_DDR_CLK_CTRL 0x03800000 +#define CONFIG_SYS_DDR_CONTROL 0xc3008000 /* Type = DDR2 */ +#define CONFIG_SYS_DDR_CONTROL2 0x04400000 + +#define CONFIG_SYS_ALT_MEMTEST +#define CONFIG_SYS_MEMTEST_START 0x0ff00000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x0ffffffc + +/* + * RAM definitions + */ +#define CONFIG_SYS_INIT_RAM_LOCK +#define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */ + +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE \ + - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* Reserved for malloc */ + +/* + * Local Bus Definitions + */ +#define CONFIG_SYS_LBC_LCRR 0x00000004 /* LB clock ratio reg */ +#define CONFIG_SYS_LBC_LBCR 0x00000000 /* LB config reg */ + + +/* + * FLASH on the Local Bus + * One bank, 128M, using the CFI driver. + */ +#define CONFIG_SYS_BOOT_BLOCK 0xf8000000 /* boot TLB block */ +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_BOOT_BLOCK /* start of FLASH 128M */ + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_SYS_FLASH_BASE_PHYS 0xff8000000ull +#else +# define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE +#endif + +/* 0xf8001801 */ +#define CONFIG_SYS_BR0_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) \ + | BR_PS_32 | BR_V) + +/* 0xf8006ff7 */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(128) | OR_GPCM_XAM | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 | OR_GPCM_TRLX \ + | OR_GPCM_EHTR | OR_GPCM_EAD) + +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS} +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 /* sectors per device */ + +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_AMD_CHECK_DQ7 +/* + * When initializing flash, if we cannot find the manufacturer ID, + * assume this is the AMD flash. + */ +#define CONFIG_ASSUME_AMD_FLASH + +/* + * Environment parameters + */ +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_USE_PPCENV +#define ENV_IS_EMBEDDED +#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K */ +#define CONFIG_ENV_SIZE 0x800 + +/* Environment at the start of flash sector, before text. */ +#define CONFIG_ENV_ADDR (CONFIG_SYS_TEXT_BASE - CONFIG_ENV_SIZE) +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ +#define CONFIG_SYS_TEXT_BASE 0xfffc0800 + +/* + * Cypress CY7C67200 USB controller on the Local Bus. + * Not supported by u-boot at present. + */ +#define CONFIG_SYS_LBC_OPTION_BASE 0xf0000000 + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_SYS_LBC_OPTION_BASE_PHYS 0xff0000000ull +#else +# define CONFIG_SYS_LBC_OPTION_BASE_PHYS CONFIG_SYS_LBC_OPTION_BASE +#endif + +/* 0xf0001001 */ +#define CONFIG_SYS_BR1_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_LBC_OPTION_BASE_PHYS) \ + | BR_PS_16 | BR_V) + +/* fffff002 */ +#define CONFIG_SYS_OR1_PRELIM (P2SZ_TO_AM(0x8000) | OR_GPCM_XAM \ + | OR_GPCM_BCTLD | OR_GPCM_EHTR) + +/* + * Serial Ports + */ +#define CONFIG_CONS_INDEX 2 +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK get_bus_freq(0) + +#define CONFIG_SYS_BAUDRATE_TABLE {300, 600, 1200, 2400, 4800, 9600, \ + 19200, 38400, 115200} + +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600) + +/* + * I2C buses and peripherals + */ +#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ +#define CONFIG_HARD_I2C /* I2C with hardware support*/ +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SLAVE 0x7f +#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C2_OFFSET 0x3100 + +/* I2C RTC - M41T81 */ +#define CONFIG_RTC_M41T62 +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 +#define CONFIG_SYS_M41T11_BASE_YEAR 2000 + +/* I2C EEPROM - 24C256 */ +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 12 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +#define CONFIG_SYS_EEPROM_BUS_NUM 1 + +/* + * RapidIO MMU + */ +#ifdef CONFIG_SYS_SRIO +# define CONFIG_SRIO1 +# define CONFIG_SYS_SRIO1_MEM_VIRT 0xc0000000 +# define CONFIG_SYS_SRIO1_MEM_SIZE 0x20000000 /* 512M */ + +# ifdef CONFIG_PHYS_64BIT +# define CONFIG_SYS_SRIO1_MEM_PHYS 0xfc0000000ull +# else +# define CONFIG_SYS_SRIO1_MEM_PHYS CONFIG_SYS_SRIO1_MEM_VIRT +# endif +#endif + +/* + * Ethernet + */ +#ifdef CONFIG_TSEC_ENET + +# ifndef CONFIG_NET_MULTI +# define CONFIG_NET_MULTI +# endif + +# define CONFIG_MII /* MII PHY management */ +# define CONFIG_MII_DEFAULT_TSEC 1 /* Allow unregistered phys */ + +# define CONFIG_TSEC1 +# define CONFIG_TSEC1_NAME "eTSEC0" +# define TSEC1_PHY_ADDR 0x10 +# define TSEC1_PHYIDX 0 +# define TSEC1_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +# define CONFIG_TSEC2 +# define CONFIG_TSEC2_NAME "eTSEC1" +# define TSEC2_PHY_ADDR 0x11 +# define TSEC2_PHYIDX 0 +# define TSEC2_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +# define CONFIG_TSEC3 +# define CONFIG_TSEC3_NAME "eTSEC2" +# define TSEC3_PHY_ADDR 0x12 +# define TSEC3_PHYIDX 0 +# define TSEC3_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +# define CONFIG_TSEC4 +# define CONFIG_TSEC4_NAME "eTSEC3" +# define TSEC4_PHY_ADDR 0x13 +# define TSEC4_PHYIDX 0 +# define TSEC4_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +/* Options are: eTSEC[0-3] */ +# define CONFIG_ETHPRIME "eTSEC0" +# define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ +#endif + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_CMD_SNTP +#define CONFIG_CMD_I2C +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_MII +#define CONFIG_CMD_ELF +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_SETEXPR +#define CONFIG_CMD_JFFS2 + +/* + * Miscellaneous configurable options + */ + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP +#define CONFIG_OF_STDOUT_VIA_ALIAS + +#define CONFIG_FIT /* new uImage format support */ +#define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ + +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER + +#ifdef CONFIG_SYS_HUSH_PARSER +# define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#endif + +#define CONFIG_LOADS_ECHO /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_CMDLINE_EDITING /* Command-line editing */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ + +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "MPQ-101=> " /* Monitor Command Prompt */ + +/* Console I/O Buffer Size */ +#ifdef CONFIG_CMD_KGDB +# define CONFIG_SYS_CBSIZE 1024 +#else +# define CONFIG_SYS_CBSIZE 256 +#endif + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT)+16) + +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 16 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (16 << 20) /* Initial Memory map for Linux*/ + +#ifdef CONFIG_CMD_KGDB +# define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +# define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Basic Environment Configuration + */ +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTDELAY 5 /* -1 disables auto-boot */ + +/*default location for tftp and bootm*/ +#define CONFIG_LOADADDR CONFIG_SYS_LOAD_ADDR + +#endif /* __CONFIG_H */
You might also want to set:
#define CONFIG_SYS_BOOTM_LEN (16 << 20) /* Increase max gunzip size */
to match BOOTMAPSZ.
Sorry, I keep nit picking ;)
- k
data
this is
initialization.
to match BOOTMAPSZ.
Can you, please, assure me, that when this particular line is corrected the patch will be accepted? If not, what possible additional problems do you see there?
Signed-off-by: Alex Dubov oakad@yahoo.com --- Cahnges for v7: - Add CONFIG_SYS_BOOTM_LEN define Changes for v6: - Remove "1"s from feature defines and fix a SRIO ifdef in tlb.c Changes for v5: - Use new common SRIO configuration definitions. - Replace initdram() with platform required fixed_sdram(). - Don't use get_ram_size() in fixed_sdram() as TLBs are set after it exits by common platform code. Changes for v4: - Replace config.mk supplied linker flags with custom linker script. - Fix checkpatch errors. Changes for v3: - Use io accessor functions for all mmio accesses. - Add configuration options for RTC and EEPROM on I2C buses. Changes for v2: - Remove some stale configuration code from board initialization functions.
MAINTAINERS | 3 + board/mercury/mpq101/Makefile | 53 ++++++ board/mercury/mpq101/law.c | 52 +++++ board/mercury/mpq101/mpq101.c | 129 +++++++++++++ board/mercury/mpq101/tlb.c | 82 ++++++++ board/mercury/mpq101/u-boot.lds | 132 +++++++++++++ boards.cfg | 1 + include/configs/mpq101.h | 393 +++++++++++++++++++++++++++++++++++++++ 8 files changed, 845 insertions(+), 0 deletions(-) create mode 100644 board/mercury/mpq101/Makefile create mode 100644 board/mercury/mpq101/law.c create mode 100644 board/mercury/mpq101/mpq101.c create mode 100644 board/mercury/mpq101/tlb.c create mode 100644 board/mercury/mpq101/u-boot.lds create mode 100644 include/configs/mpq101.h
sbc8260 MPC8260
devconcenter PPC460EX diff --git a/board/mercury/mpq101/Makefile b/board/mercury/mpq101/Makefile new file mode 100644 index 0000000..58bc1b3 --- /dev/null +++ b/board/mercury/mpq101/Makefile @@ -0,0 +1,53 @@ +# +# Copyright 2007 Freescale Semiconductor, Inc. +# (C) Copyright 2001-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += $(BOARD).o +COBJS-y += law.o +COBJS-y += tlb.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS)) + +clean: + rm -f $(OBJS) $(SOBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/mercury/mpq101/law.c b/board/mercury/mpq101/law.c new file mode 100644 index 0000000..0e23a6a --- /dev/null +++ b/board/mercury/mpq101/law.c @@ -0,0 +1,52 @@ +/* + * Copyright 2008 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/mmu.h> + +/* + * LAW(Local Access Window) configuration: + * + * 0x0000_0000 0x1fff_ffff DDR SYS_SDRAM_SIZE + * 0xc000_0000 0xdfff_ffff RapidIO (set elsewhere) 512M + * 0xe000_0000 0xe000_ffff CCSR (set elsewhere) 1M + * 0xf000_0000 0xffff_ffff LBC options + FLASH 256M + * + * Notes: + * CCSRBAR and L2-as-SRAM don't need a configured Local Access Window. + * If flash is 8M at default position (last 8M), no LAW needed. + * + * LAW 0 is reserved for boot mapping + */ + +struct law_entry law_table[] = { + SET_LAW(CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_SDRAM_SIZE_LOG - 1, + LAW_TRGT_IF_DDR_1), + SET_LAW(CONFIG_SYS_LBC_OPTION_BASE_PHYS, LAW_SIZE_256M, + LAW_TRGT_IF_LBC) +}; + +int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/mercury/mpq101/mpq101.c b/board/mercury/mpq101/mpq101.c new file mode 100644 index 0000000..e02e87f --- /dev/null +++ b/board/mercury/mpq101/mpq101.c @@ -0,0 +1,129 @@ +/* + * (C) Copyright 2011 Alex Dubov oakad@yahoo.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/processor.h> +#include <asm/mmu.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/io.h> +#include <miiphy.h> +#include <libfdt.h> +#include <fdt_support.h> + +/* + * Initialize Local Bus + */ +void local_bus_init(void) +{ + fsl_lbc_t *lbc = LBC_BASE_ADDR; + + out_be32(&lbc->ltesr, 0xffffffff); /* Clear LBC error interrupts */ + out_be32(&lbc->lteir, 0xffffffff); /* Enable LBC error interrupts */ +} + +int checkboard(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + ccsr_local_ecm_t *ecm = (void *)(CONFIG_SYS_MPC85xx_ECM_ADDR); + + puts("Board: Mercury Computer Systems, Inc. MPQ-101 "); +#ifdef CONFIG_PHYS_64BIT + puts("(36-bit addrmap) "); +#endif + putc('\n'); + + /* + * Initialize local bus. + */ + local_bus_init(); + + /* + * Hack TSEC 3 and 4 IO voltages. + */ + out_be32(&gur->tsec34ioovcr, 0xe7e0); /* 1110 0111 1110 0xxx */ + + out_be32(&ecm->eedr, 0xffffffff); /* clear ecm errors */ + out_be32(&ecm->eeer, 0xffffffff); /* enable ecm errors */ + return 0; +} + +phys_size_t fixed_sdram(void) +{ + ccsr_ddr_t *ddr = (void *)(CONFIG_SYS_MPC85xx_DDR_ADDR); + const char *p_mode = getenv("perf_mode"); + + puts("Initializing...."); + + out_be32(&ddr->cs0_bnds, CONFIG_SYS_DDR_CS0_BNDS); + out_be32(&ddr->cs0_config, CONFIG_SYS_DDR_CS0_CONFIG); + + out_be32(&ddr->timing_cfg_3, CONFIG_SYS_DDR_TIMING_3); + out_be32(&ddr->timing_cfg_0, CONFIG_SYS_DDR_TIMING_0); + + if (p_mode && !strcmp("performance", p_mode)) { + out_be32(&ddr->timing_cfg_1, CONFIG_SYS_DDR_TIMING_1_PERF); + out_be32(&ddr->timing_cfg_2, CONFIG_SYS_DDR_TIMING_2_PERF); + out_be32(&ddr->sdram_mode, CONFIG_SYS_DDR_MODE_1_PERF); + out_be32(&ddr->sdram_mode_2, CONFIG_SYS_DDR_MODE_2_PERF); + out_be32(&ddr->sdram_interval, CONFIG_SYS_DDR_INTERVAL_PERF); + } else { + out_be32(&ddr->timing_cfg_1, CONFIG_SYS_DDR_TIMING_1); + out_be32(&ddr->timing_cfg_2, CONFIG_SYS_DDR_TIMING_2); + out_be32(&ddr->sdram_mode, CONFIG_SYS_DDR_MODE_1); + out_be32(&ddr->sdram_mode_2, CONFIG_SYS_DDR_MODE_2); + out_be32(&ddr->sdram_interval, CONFIG_SYS_DDR_INTERVAL); + } + + out_be32(&ddr->sdram_clk_cntl, CONFIG_SYS_DDR_CLK_CTRL); + out_be32(&ddr->sdram_cfg_2, CONFIG_SYS_DDR_CONTROL2); + + asm("sync;isync"); + udelay(500); + + out_be32(&ddr->sdram_cfg, CONFIG_SYS_DDR_CONTROL); + asm("sync; isync"); + udelay(500); + + return ((phys_size_t)1) << CONFIG_SYS_SDRAM_SIZE_LOG; +} + +void pci_init_board(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + + /* PCI is disabled */ + out_be32(&gur->devdisr, in_be32(&gur->devdisr) + | MPC85xx_DEVDISR_PCI1 + | MPC85xx_DEVDISR_PCI2 + | MPC85xx_DEVDISR_PCIE); +} + + +#if defined(CONFIG_OF_BOARD_SETUP) + +void ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); +} + +#endif diff --git a/board/mercury/mpq101/tlb.c b/board/mercury/mpq101/tlb.c new file mode 100644 index 0000000..fd2eaec --- /dev/null +++ b/board/mercury/mpq101/tlb.c @@ -0,0 +1,82 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mmu.h> + +struct fsl_e_tlb_entry tlb_table[] = { + /* TLB 0 - for temp stack in cache */ + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, CONFIG_SYS_INIT_RAM_ADDR, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + /* + * TLB 0: 256M Non-cacheable, guarded + * 0xf0000000 256M LBC (FLASH included) + * Out of reset this entry is only 4K. + */ + SET_TLB_ENTRY(1, CONFIG_SYS_LBC_OPTION_BASE, + CONFIG_SYS_LBC_OPTION_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_256M, 1), + + /* + * TLB 1: 1M Non-cacheable, guarded + * 0xe000_0000 1M CCSRBAR + */ + SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 1, BOOKE_PAGESZ_1M, 1), + +#ifdef CONFIG_SYS_SRIO1_MEM_PHYS + /* + * TLB 2: 256M Non-cacheable, guarded + */ + SET_TLB_ENTRY(1, CONFIG_SYS_SRIO1_MEM_VIRT, CONFIG_SYS_SRIO1_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 2, BOOKE_PAGESZ_256M, 1), + + /* + * TLB 3: 256M Non-cacheable, guarded + */ + SET_TLB_ENTRY(1, CONFIG_SYS_SRIO1_MEM_VIRT + 0x10000000, + CONFIG_SYS_SRIO1_MEM_PHYS + 0x10000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 3, BOOKE_PAGESZ_256M, 1), + +#endif +}; + +int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/board/mercury/mpq101/u-boot.lds b/board/mercury/mpq101/u-boot.lds new file mode 100644 index 0000000..3af0274 --- /dev/null +++ b/board/mercury/mpq101/u-boot.lds @@ -0,0 +1,132 @@ +/* + * Copyright 2007-2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef RESET_VECTOR_ADDRESS +#define RESET_VECTOR_ADDRESS 0xfffffffc +#endif + +#include <config.h> + +OUTPUT_ARCH(powerpc) + +PHDRS +{ + text PT_LOAD; + bss PT_LOAD; +} + +SECTIONS +{ + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .interp : { *(.interp) } + /* To simplify mass deployment, environment precedes the monitor text in the + * same flash sector. + */ + .ppcenv CONFIG_ENV_ADDR : { *(.ppcenv) } + .text : + { + *(.text*) + } :text + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + } :text + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + .reloc : + { + _GOT2_TABLE_ = .; + KEEP(*(.got2)) + KEEP(*(.got)) + PROVIDE(_GLOBAL_OFFSET_TABLE_ = . + 4); + _FIXUP_TABLE_ = .; + KEEP(*(.fixup)) + } + __got2_entries = ((_GLOBAL_OFFSET_TABLE_ - _GOT2_TABLE_) >> 2) - 1; + __fixup_entries = (. - _FIXUP_TABLE_) >> 2; + + .data : + { + *(.data*) + *(.sdata*) + } + _edata = .; + PROVIDE (edata = .); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + .bootpg RESET_VECTOR_ADDRESS - 0xffc : + { + arch/powerpc/cpu/mpc85xx/start.o (.bootpg) + } :text = 0xffff + + .resetvec RESET_VECTOR_ADDRESS : + { + KEEP(*(.resetvec)) + } :text = 0xffff + + . = RESET_VECTOR_ADDRESS + 0x4; + + /* + * Make sure that the bss segment isn't linked at 0x0, otherwise its + * address won't be updated during relocation fixups. Note that + * this is a temporary fix. Code to dynamically the fixup the bss + * location will be added in the future. When the bss relocation + * fixup code is present this workaround should be removed. + */ +#if (RESET_VECTOR_ADDRESS == 0xfffffffc) + . |= 0x10; +#endif + + __bss_start = .; + .bss (NOLOAD) : + { + *(.sbss*) + *(.bss*) + *(COMMON) + } :bss + + . = ALIGN(4); + _end = . ; + PROVIDE (end = .); +} diff --git a/boards.cfg b/boards.cfg index 3497408..0f94969 100644 --- a/boards.cfg +++ b/boards.cfg @@ -495,6 +495,7 @@ P2020RDB_NAND powerpc mpc85xx p1_p2_rdb freesca P2020RDB_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020,SDCARD P2020RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020,SPIFLASH P4080DS powerpc mpc85xx corenet_ds freescale +mpq101 powerpc mpc85xx mpq101 mercury - mpq101:SYS_LDSCRIPT=board/mercury/mpq101/u-boot.lds stxgp3 powerpc mpc85xx stxgp3 stx stxssa powerpc mpc85xx stxssa stx - stxssa stxssa_4M powerpc mpc85xx stxssa stx - stxssa:STXSSA_4M diff --git a/include/configs/mpq101.h b/include/configs/mpq101.h new file mode 100644 index 0000000..1b4137e --- /dev/null +++ b/include/configs/mpq101.h @@ -0,0 +1,393 @@ +/* + * Copyright 2011 Alex Dubov oakad@yahoo.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Merury Computers MPQ101 board configuration file + * + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +#ifdef CONFIG_36BIT +# define CONFIG_PHYS_64BIT +#endif + +/* High Level Configuration Options */ +#define CONFIG_BOOKE /* BOOKE */ +#define CONFIG_E500 /* BOOKE e500 family */ +#define CONFIG_MPC85xx /* MPC8540/60/55/41/48 */ +#define CONFIG_MPC8548 /* MPC8548 specific */ +#define CONFIG_MPQ101 /* MPQ101 board specific */ + +#define CONFIG_SYS_SRIO /* enable serial RapidIO */ +#define CONFIG_TSEC_ENET /* tsec ethernet support */ +#define CONFIG_INTERRUPTS /* enable pci, srio, ddr interrupts */ +#define CONFIG_FSL_LAW /* Use common FSL init code */ + +/* + * These can be toggled for performance analysis, otherwise use default. + */ +#define CONFIG_L2_CACHE /* toggle L2 cache */ +#define CONFIG_BTB /* toggle branch predition */ + +#define CONFIG_PANIC_HANG + +/* + * Only possible on E500 Version 2 or newer cores. + */ +#define CONFIG_ENABLE_36BIT_PHYS + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_ADDR_MAP +# define CONFIG_SYS_NUM_ADDR_MAP 16 /* number of TLB1 entries */ +#endif + + +#define CONFIG_SYS_CLK_FREQ 33000000 /* sysclk for MPC85xx */ + +/* + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + */ +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 +#define CONFIG_SYS_CCSRBAR 0xe0000000 + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_SYS_CCSRBAR_PHYS 0xfe0000000ull +#else +# define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR +#endif + +#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR + +/* DDR Setup */ +#define CONFIG_FSL_DDR2 + +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER /* DDR controller or DMA? */ + +#define CONFIG_MEM_INIT_VALUE 0xDeadBeef +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 /* DDR is system memory*/ +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +#define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +#define CONFIG_CHIP_SELECTS_PER_CTRL (2 * CONFIG_DIMM_SLOTS_PER_CTLR) + +/* Fixed 512MB DDR2 parameters */ +#define CONFIG_SYS_SDRAM_SIZE_LOG 29 /* DDR is 512MB */ +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000001f +#define CONFIG_SYS_DDR_CS0_CONFIG 0x80014102 +#define CONFIG_SYS_DDR_TIMING_3 0x00010000 +#define CONFIG_SYS_DDR_TIMING_0 0x00260802 +#define CONFIG_SYS_DDR_TIMING_1 0x5c47a432 +#define CONFIG_SYS_DDR_TIMING_1_PERF 0x49352322 +#define CONFIG_SYS_DDR_TIMING_2 0x03984cce +#define CONFIG_SYS_DDR_TIMING_2_PERF 0x14904cca +#define CONFIG_SYS_DDR_MODE_1 0x00400442 +#define CONFIG_SYS_DDR_MODE_1_PERF 0x00480432 +#define CONFIG_SYS_DDR_MODE_2 0x00000000 +#define CONFIG_SYS_DDR_MODE_2_PERF 0x00000000 +#define CONFIG_SYS_DDR_INTERVAL 0x08200100 +#define CONFIG_SYS_DDR_INTERVAL_PERF 0x06180100 +#define CONFIG_SYS_DDR_CLK_CTRL 0x03800000 +#define CONFIG_SYS_DDR_CONTROL 0xc3008000 /* Type = DDR2 */ +#define CONFIG_SYS_DDR_CONTROL2 0x04400000 + +#define CONFIG_SYS_ALT_MEMTEST +#define CONFIG_SYS_MEMTEST_START 0x0ff00000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x0ffffffc + +/* + * RAM definitions + */ +#define CONFIG_SYS_INIT_RAM_LOCK +#define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */ + +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE \ + - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* Reserved for malloc */ + +/* + * Local Bus Definitions + */ +#define CONFIG_SYS_LBC_LCRR 0x00000004 /* LB clock ratio reg */ +#define CONFIG_SYS_LBC_LBCR 0x00000000 /* LB config reg */ + + +/* + * FLASH on the Local Bus + * One bank, 128M, using the CFI driver. + */ +#define CONFIG_SYS_BOOT_BLOCK 0xf8000000 /* boot TLB block */ +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_BOOT_BLOCK /* start of FLASH 128M */ + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_SYS_FLASH_BASE_PHYS 0xff8000000ull +#else +# define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE +#endif + +/* 0xf8001801 */ +#define CONFIG_SYS_BR0_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) \ + | BR_PS_32 | BR_V) + +/* 0xf8006ff7 */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(128) | OR_GPCM_XAM | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 | OR_GPCM_TRLX \ + | OR_GPCM_EHTR | OR_GPCM_EAD) + +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS} +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 /* sectors per device */ + +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_AMD_CHECK_DQ7 +/* + * When initializing flash, if we cannot find the manufacturer ID, + * assume this is the AMD flash. + */ +#define CONFIG_ASSUME_AMD_FLASH + +/* + * Environment parameters + */ +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_USE_PPCENV +#define ENV_IS_EMBEDDED +#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K */ +#define CONFIG_ENV_SIZE 0x800 + +/* Environment at the start of flash sector, before text. */ +#define CONFIG_ENV_ADDR (CONFIG_SYS_TEXT_BASE - CONFIG_ENV_SIZE) +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ +#define CONFIG_SYS_TEXT_BASE 0xfffc0800 + +/* + * Cypress CY7C67200 USB controller on the Local Bus. + * Not supported by u-boot at present. + */ +#define CONFIG_SYS_LBC_OPTION_BASE 0xf0000000 + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_SYS_LBC_OPTION_BASE_PHYS 0xff0000000ull +#else +# define CONFIG_SYS_LBC_OPTION_BASE_PHYS CONFIG_SYS_LBC_OPTION_BASE +#endif + +/* 0xf0001001 */ +#define CONFIG_SYS_BR1_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_LBC_OPTION_BASE_PHYS) \ + | BR_PS_16 | BR_V) + +/* fffff002 */ +#define CONFIG_SYS_OR1_PRELIM (P2SZ_TO_AM(0x8000) | OR_GPCM_XAM \ + | OR_GPCM_BCTLD | OR_GPCM_EHTR) + +/* + * Serial Ports + */ +#define CONFIG_CONS_INDEX 2 +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK get_bus_freq(0) + +#define CONFIG_SYS_BAUDRATE_TABLE {300, 600, 1200, 2400, 4800, 9600, \ + 19200, 38400, 115200} + +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600) + +/* + * I2C buses and peripherals + */ +#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ +#define CONFIG_HARD_I2C /* I2C with hardware support*/ +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SLAVE 0x7f +#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C2_OFFSET 0x3100 + +/* I2C RTC - M41T81 */ +#define CONFIG_RTC_M41T62 +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 +#define CONFIG_SYS_M41T11_BASE_YEAR 2000 + +/* I2C EEPROM - 24C256 */ +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 12 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +#define CONFIG_SYS_EEPROM_BUS_NUM 1 + +/* + * RapidIO MMU + */ +#ifdef CONFIG_SYS_SRIO +# define CONFIG_SRIO1 +# define CONFIG_SYS_SRIO1_MEM_VIRT 0xc0000000 +# define CONFIG_SYS_SRIO1_MEM_SIZE 0x20000000 /* 512M */ + +# ifdef CONFIG_PHYS_64BIT +# define CONFIG_SYS_SRIO1_MEM_PHYS 0xfc0000000ull +# else +# define CONFIG_SYS_SRIO1_MEM_PHYS CONFIG_SYS_SRIO1_MEM_VIRT +# endif +#endif + +/* + * Ethernet + */ +#ifdef CONFIG_TSEC_ENET + +# ifndef CONFIG_NET_MULTI +# define CONFIG_NET_MULTI +# endif + +# define CONFIG_MII /* MII PHY management */ +# define CONFIG_MII_DEFAULT_TSEC 1 /* Allow unregistered phys */ + +# define CONFIG_TSEC1 +# define CONFIG_TSEC1_NAME "eTSEC0" +# define TSEC1_PHY_ADDR 0x10 +# define TSEC1_PHYIDX 0 +# define TSEC1_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +# define CONFIG_TSEC2 +# define CONFIG_TSEC2_NAME "eTSEC1" +# define TSEC2_PHY_ADDR 0x11 +# define TSEC2_PHYIDX 0 +# define TSEC2_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +# define CONFIG_TSEC3 +# define CONFIG_TSEC3_NAME "eTSEC2" +# define TSEC3_PHY_ADDR 0x12 +# define TSEC3_PHYIDX 0 +# define TSEC3_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +# define CONFIG_TSEC4 +# define CONFIG_TSEC4_NAME "eTSEC3" +# define TSEC4_PHY_ADDR 0x13 +# define TSEC4_PHYIDX 0 +# define TSEC4_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +/* Options are: eTSEC[0-3] */ +# define CONFIG_ETHPRIME "eTSEC0" +# define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ +#endif + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_CMD_SNTP +#define CONFIG_CMD_I2C +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_MII +#define CONFIG_CMD_ELF +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_SETEXPR +#define CONFIG_CMD_JFFS2 + +/* + * Miscellaneous configurable options + */ + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP +#define CONFIG_OF_STDOUT_VIA_ALIAS + +#define CONFIG_FIT /* new uImage format support */ +#define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ + +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER + +#ifdef CONFIG_SYS_HUSH_PARSER +# define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#endif + +#define CONFIG_LOADS_ECHO /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_CMDLINE_EDITING /* Command-line editing */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ + +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "MPQ-101=> " /* Monitor Command Prompt */ + +/* Console I/O Buffer Size */ +#ifdef CONFIG_CMD_KGDB +# define CONFIG_SYS_CBSIZE 1024 +#else +# define CONFIG_SYS_CBSIZE 256 +#endif + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT)+16) + +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 16 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (16 << 20) /* Initial Memory map for Linux*/ +#define CONFIG_SYS_BOOTM_LEN (16 << 20) /* Increase max gunzip size */ + +#ifdef CONFIG_CMD_KGDB +# define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +# define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Basic Environment Configuration + */ +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTDELAY 5 /* -1 disables auto-boot */ + +/*default location for tftp and bootm*/ +#define CONFIG_LOADADDR CONFIG_SYS_LOAD_ADDR + +#endif /* __CONFIG_H */
Additional board information is available at: http://www.mc.com/products/boards/ensemble_mpq101_rapidio_powerquicc_iii.asp...
Environment is configured to precede the actual u-boot image so that it's located at the beginning of flash erase block (made necessary by the recent changes to the embedded environment handling). This is achieved by means of custom ld script.
Cahnges for v7:
Changes for v6:
Changes for v5:
Changes for v4:
Changes for v3:
Changes for v2:
Doesn't build for me:
common/libcommon.o:(.sdata.env_ptr+0x0): undefined reference to `environment' make: *** [u-boot] Error 1 [galak@right u-boot-85xx]$
- k
Signed-off-by: Alex Dubov oakad@yahoo.com --- Changes for v8: - Move CONFIG_SYS_LDSCRIPT to board config file - Explicitly refer to env_embedded.o in ld script, as this object is no longer linked into libcommon.o Changes for v7: - Add CONFIG_SYS_BOOTM_LEN define Changes for v6: - Remove "1"s from feature defines and fix a SRIO ifdef in tlb.c Changes for v5: - Use new common SRIO configuration definitions. - Replace initdram() with platform required fixed_sdram(). - Don't use get_ram_size() in fixed_sdram() as TLBs are set after it exits by common platform code. Changes for v4: - Replace config.mk supplied linker flags with custom linker script. - Fix checkpatch errors. Changes for v3: - Use io accessor functions for all mmio accesses. - Add configuration options for RTC and EEPROM on I2C buses. Changes for v2: - Remove some stale configuration code from board initialization functions.
MAINTAINERS | 4 + board/mercury/mpq101/Makefile | 53 ++++++ board/mercury/mpq101/law.c | 52 +++++ board/mercury/mpq101/mpq101.c | 129 +++++++++++++ board/mercury/mpq101/tlb.c | 82 ++++++++ board/mercury/mpq101/u-boot.lds | 132 +++++++++++++ boards.cfg | 1 + include/configs/mpq101.h | 394 +++++++++++++++++++++++++++++++++++++++ 8 files changed, 847 insertions(+), 0 deletions(-) create mode 100644 board/mercury/mpq101/Makefile create mode 100644 board/mercury/mpq101/law.c create mode 100644 board/mercury/mpq101/mpq101.c create mode 100644 board/mercury/mpq101/tlb.c create mode 100644 board/mercury/mpq101/u-boot.lds create mode 100644 include/configs/mpq101.h
diff --git a/MAINTAINERS b/MAINTAINERS index a799037..ab215c6 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -138,6 +138,10 @@ Jon Diekema jon.diekema@smiths-aerospace.com
sbc8260 MPC8260
+Alex Dubov oakad@yahoo.com + + mpq101 MPC8548 + Dirk Eibach eibach@gdsys.de
devconcenter PPC460EX diff --git a/board/mercury/mpq101/Makefile b/board/mercury/mpq101/Makefile new file mode 100644 index 0000000..58bc1b3 --- /dev/null +++ b/board/mercury/mpq101/Makefile @@ -0,0 +1,53 @@ +# +# Copyright 2007 Freescale Semiconductor, Inc. +# (C) Copyright 2001-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += $(BOARD).o +COBJS-y += law.o +COBJS-y += tlb.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS)) + +clean: + rm -f $(OBJS) $(SOBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/mercury/mpq101/law.c b/board/mercury/mpq101/law.c new file mode 100644 index 0000000..0e23a6a --- /dev/null +++ b/board/mercury/mpq101/law.c @@ -0,0 +1,52 @@ +/* + * Copyright 2008 Freescale Semiconductor, Inc. + * + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/mmu.h> + +/* + * LAW(Local Access Window) configuration: + * + * 0x0000_0000 0x1fff_ffff DDR SYS_SDRAM_SIZE + * 0xc000_0000 0xdfff_ffff RapidIO (set elsewhere) 512M + * 0xe000_0000 0xe000_ffff CCSR (set elsewhere) 1M + * 0xf000_0000 0xffff_ffff LBC options + FLASH 256M + * + * Notes: + * CCSRBAR and L2-as-SRAM don't need a configured Local Access Window. + * If flash is 8M at default position (last 8M), no LAW needed. + * + * LAW 0 is reserved for boot mapping + */ + +struct law_entry law_table[] = { + SET_LAW(CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_SDRAM_SIZE_LOG - 1, + LAW_TRGT_IF_DDR_1), + SET_LAW(CONFIG_SYS_LBC_OPTION_BASE_PHYS, LAW_SIZE_256M, + LAW_TRGT_IF_LBC) +}; + +int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/mercury/mpq101/mpq101.c b/board/mercury/mpq101/mpq101.c new file mode 100644 index 0000000..e02e87f --- /dev/null +++ b/board/mercury/mpq101/mpq101.c @@ -0,0 +1,129 @@ +/* + * (C) Copyright 2011 Alex Dubov oakad@yahoo.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/processor.h> +#include <asm/mmu.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/io.h> +#include <miiphy.h> +#include <libfdt.h> +#include <fdt_support.h> + +/* + * Initialize Local Bus + */ +void local_bus_init(void) +{ + fsl_lbc_t *lbc = LBC_BASE_ADDR; + + out_be32(&lbc->ltesr, 0xffffffff); /* Clear LBC error interrupts */ + out_be32(&lbc->lteir, 0xffffffff); /* Enable LBC error interrupts */ +} + +int checkboard(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + ccsr_local_ecm_t *ecm = (void *)(CONFIG_SYS_MPC85xx_ECM_ADDR); + + puts("Board: Mercury Computer Systems, Inc. MPQ-101 "); +#ifdef CONFIG_PHYS_64BIT + puts("(36-bit addrmap) "); +#endif + putc('\n'); + + /* + * Initialize local bus. + */ + local_bus_init(); + + /* + * Hack TSEC 3 and 4 IO voltages. + */ + out_be32(&gur->tsec34ioovcr, 0xe7e0); /* 1110 0111 1110 0xxx */ + + out_be32(&ecm->eedr, 0xffffffff); /* clear ecm errors */ + out_be32(&ecm->eeer, 0xffffffff); /* enable ecm errors */ + return 0; +} + +phys_size_t fixed_sdram(void) +{ + ccsr_ddr_t *ddr = (void *)(CONFIG_SYS_MPC85xx_DDR_ADDR); + const char *p_mode = getenv("perf_mode"); + + puts("Initializing...."); + + out_be32(&ddr->cs0_bnds, CONFIG_SYS_DDR_CS0_BNDS); + out_be32(&ddr->cs0_config, CONFIG_SYS_DDR_CS0_CONFIG); + + out_be32(&ddr->timing_cfg_3, CONFIG_SYS_DDR_TIMING_3); + out_be32(&ddr->timing_cfg_0, CONFIG_SYS_DDR_TIMING_0); + + if (p_mode && !strcmp("performance", p_mode)) { + out_be32(&ddr->timing_cfg_1, CONFIG_SYS_DDR_TIMING_1_PERF); + out_be32(&ddr->timing_cfg_2, CONFIG_SYS_DDR_TIMING_2_PERF); + out_be32(&ddr->sdram_mode, CONFIG_SYS_DDR_MODE_1_PERF); + out_be32(&ddr->sdram_mode_2, CONFIG_SYS_DDR_MODE_2_PERF); + out_be32(&ddr->sdram_interval, CONFIG_SYS_DDR_INTERVAL_PERF); + } else { + out_be32(&ddr->timing_cfg_1, CONFIG_SYS_DDR_TIMING_1); + out_be32(&ddr->timing_cfg_2, CONFIG_SYS_DDR_TIMING_2); + out_be32(&ddr->sdram_mode, CONFIG_SYS_DDR_MODE_1); + out_be32(&ddr->sdram_mode_2, CONFIG_SYS_DDR_MODE_2); + out_be32(&ddr->sdram_interval, CONFIG_SYS_DDR_INTERVAL); + } + + out_be32(&ddr->sdram_clk_cntl, CONFIG_SYS_DDR_CLK_CTRL); + out_be32(&ddr->sdram_cfg_2, CONFIG_SYS_DDR_CONTROL2); + + asm("sync;isync"); + udelay(500); + + out_be32(&ddr->sdram_cfg, CONFIG_SYS_DDR_CONTROL); + asm("sync; isync"); + udelay(500); + + return ((phys_size_t)1) << CONFIG_SYS_SDRAM_SIZE_LOG; +} + +void pci_init_board(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + + /* PCI is disabled */ + out_be32(&gur->devdisr, in_be32(&gur->devdisr) + | MPC85xx_DEVDISR_PCI1 + | MPC85xx_DEVDISR_PCI2 + | MPC85xx_DEVDISR_PCIE); +} + + +#if defined(CONFIG_OF_BOARD_SETUP) + +void ft_board_setup(void *blob, bd_t *bd) +{ + ft_cpu_setup(blob, bd); +} + +#endif diff --git a/board/mercury/mpq101/tlb.c b/board/mercury/mpq101/tlb.c new file mode 100644 index 0000000..fd2eaec --- /dev/null +++ b/board/mercury/mpq101/tlb.c @@ -0,0 +1,82 @@ +/* + * (C) Copyright 2000 + * Wolfgang Denk, DENX Software Engineering, wd@denx.de. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mmu.h> + +struct fsl_e_tlb_entry tlb_table[] = { + /* TLB 0 - for temp stack in cache */ + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, CONFIG_SYS_INIT_RAM_ADDR, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + /* + * TLB 0: 256M Non-cacheable, guarded + * 0xf0000000 256M LBC (FLASH included) + * Out of reset this entry is only 4K. + */ + SET_TLB_ENTRY(1, CONFIG_SYS_LBC_OPTION_BASE, + CONFIG_SYS_LBC_OPTION_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_256M, 1), + + /* + * TLB 1: 1M Non-cacheable, guarded + * 0xe000_0000 1M CCSRBAR + */ + SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 1, BOOKE_PAGESZ_1M, 1), + +#ifdef CONFIG_SYS_SRIO1_MEM_PHYS + /* + * TLB 2: 256M Non-cacheable, guarded + */ + SET_TLB_ENTRY(1, CONFIG_SYS_SRIO1_MEM_VIRT, CONFIG_SYS_SRIO1_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 2, BOOKE_PAGESZ_256M, 1), + + /* + * TLB 3: 256M Non-cacheable, guarded + */ + SET_TLB_ENTRY(1, CONFIG_SYS_SRIO1_MEM_VIRT + 0x10000000, + CONFIG_SYS_SRIO1_MEM_PHYS + 0x10000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 3, BOOKE_PAGESZ_256M, 1), + +#endif +}; + +int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/board/mercury/mpq101/u-boot.lds b/board/mercury/mpq101/u-boot.lds new file mode 100644 index 0000000..4f4dda5 --- /dev/null +++ b/board/mercury/mpq101/u-boot.lds @@ -0,0 +1,132 @@ +/* + * Copyright 2007-2009 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef RESET_VECTOR_ADDRESS +#define RESET_VECTOR_ADDRESS 0xfffffffc +#endif + +#include <config.h> + +OUTPUT_ARCH(powerpc) + +PHDRS +{ + text PT_LOAD; + bss PT_LOAD; +} + +SECTIONS +{ + /* Read-only sections, merged into text segment: */ + . = + SIZEOF_HEADERS; + .interp : { *(.interp) } + /* To simplify mass deployment, environment precedes the monitor text in the + * same flash sector. + */ + .ppcenv CONFIG_ENV_ADDR : { common/env_embedded.o (.ppcenv) } + .text : + { + *(.text*) + } :text + _etext = .; + PROVIDE (etext = .); + .rodata : + { + *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) + } :text + + /* Read-write section, merged into data segment: */ + . = (. + 0x00FF) & 0xFFFFFF00; + _erotext = .; + PROVIDE (erotext = .); + .reloc : + { + _GOT2_TABLE_ = .; + KEEP(*(.got2)) + KEEP(*(.got)) + PROVIDE(_GLOBAL_OFFSET_TABLE_ = . + 4); + _FIXUP_TABLE_ = .; + KEEP(*(.fixup)) + } + __got2_entries = ((_GLOBAL_OFFSET_TABLE_ - _GOT2_TABLE_) >> 2) - 1; + __fixup_entries = (. - _FIXUP_TABLE_) >> 2; + + .data : + { + *(.data*) + *(.sdata*) + } + _edata = .; + PROVIDE (edata = .); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + + . = ALIGN(256); + __init_begin = .; + .text.init : { *(.text.init) } + .data.init : { *(.data.init) } + . = ALIGN(256); + __init_end = .; + + .bootpg RESET_VECTOR_ADDRESS - 0xffc : + { + arch/powerpc/cpu/mpc85xx/start.o (.bootpg) + } :text = 0xffff + + .resetvec RESET_VECTOR_ADDRESS : + { + KEEP(*(.resetvec)) + } :text = 0xffff + + . = RESET_VECTOR_ADDRESS + 0x4; + + /* + * Make sure that the bss segment isn't linked at 0x0, otherwise its + * address won't be updated during relocation fixups. Note that + * this is a temporary fix. Code to dynamically the fixup the bss + * location will be added in the future. When the bss relocation + * fixup code is present this workaround should be removed. + */ +#if (RESET_VECTOR_ADDRESS == 0xfffffffc) + . |= 0x10; +#endif + + __bss_start = .; + .bss (NOLOAD) : + { + *(.sbss*) + *(.bss*) + *(COMMON) + } :bss + + . = ALIGN(4); + _end = . ; + PROVIDE (end = .); +} diff --git a/boards.cfg b/boards.cfg index 3497408..356acab 100644 --- a/boards.cfg +++ b/boards.cfg @@ -495,6 +495,7 @@ P2020RDB_NAND powerpc mpc85xx p1_p2_rdb freesca P2020RDB_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020,SDCARD P2020RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020,SPIFLASH P4080DS powerpc mpc85xx corenet_ds freescale +mpq101 powerpc mpc85xx mpq101 mercury - mpq101 stxgp3 powerpc mpc85xx stxgp3 stx stxssa powerpc mpc85xx stxssa stx - stxssa stxssa_4M powerpc mpc85xx stxssa stx - stxssa:STXSSA_4M diff --git a/include/configs/mpq101.h b/include/configs/mpq101.h new file mode 100644 index 0000000..e76ca73 --- /dev/null +++ b/include/configs/mpq101.h @@ -0,0 +1,394 @@ +/* + * Copyright 2011 Alex Dubov oakad@yahoo.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * Merury Computers MPQ101 board configuration file + * + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +#ifdef CONFIG_36BIT +# define CONFIG_PHYS_64BIT +#endif + +/* High Level Configuration Options */ +#define CONFIG_BOOKE /* BOOKE */ +#define CONFIG_E500 /* BOOKE e500 family */ +#define CONFIG_MPC85xx /* MPC8540/60/55/41/48 */ +#define CONFIG_MPC8548 /* MPC8548 specific */ +#define CONFIG_MPQ101 /* MPQ101 board specific */ + +#define CONFIG_SYS_SRIO /* enable serial RapidIO */ +#define CONFIG_TSEC_ENET /* tsec ethernet support */ +#define CONFIG_INTERRUPTS /* enable pci, srio, ddr interrupts */ +#define CONFIG_FSL_LAW /* Use common FSL init code */ + +/* + * These can be toggled for performance analysis, otherwise use default. + */ +#define CONFIG_L2_CACHE /* toggle L2 cache */ +#define CONFIG_BTB /* toggle branch predition */ + +#define CONFIG_PANIC_HANG + +/* + * Only possible on E500 Version 2 or newer cores. + */ +#define CONFIG_ENABLE_36BIT_PHYS + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_ADDR_MAP +# define CONFIG_SYS_NUM_ADDR_MAP 16 /* number of TLB1 entries */ +#endif + + +#define CONFIG_SYS_CLK_FREQ 33000000 /* sysclk for MPC85xx */ + +/* + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + */ +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xff700000 +#define CONFIG_SYS_CCSRBAR 0xe0000000 + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_SYS_CCSRBAR_PHYS 0xfe0000000ull +#else +# define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR +#endif + +#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR + +/* DDR Setup */ +#define CONFIG_FSL_DDR2 + +#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER /* DDR controller or DMA? */ + +#define CONFIG_MEM_INIT_VALUE 0xDeadBeef +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 /* DDR is system memory*/ +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +#define CONFIG_NUM_DDR_CONTROLLERS 1 +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +#define CONFIG_CHIP_SELECTS_PER_CTRL (2 * CONFIG_DIMM_SLOTS_PER_CTLR) + +/* Fixed 512MB DDR2 parameters */ +#define CONFIG_SYS_SDRAM_SIZE_LOG 29 /* DDR is 512MB */ +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000001f +#define CONFIG_SYS_DDR_CS0_CONFIG 0x80014102 +#define CONFIG_SYS_DDR_TIMING_3 0x00010000 +#define CONFIG_SYS_DDR_TIMING_0 0x00260802 +#define CONFIG_SYS_DDR_TIMING_1 0x5c47a432 +#define CONFIG_SYS_DDR_TIMING_1_PERF 0x49352322 +#define CONFIG_SYS_DDR_TIMING_2 0x03984cce +#define CONFIG_SYS_DDR_TIMING_2_PERF 0x14904cca +#define CONFIG_SYS_DDR_MODE_1 0x00400442 +#define CONFIG_SYS_DDR_MODE_1_PERF 0x00480432 +#define CONFIG_SYS_DDR_MODE_2 0x00000000 +#define CONFIG_SYS_DDR_MODE_2_PERF 0x00000000 +#define CONFIG_SYS_DDR_INTERVAL 0x08200100 +#define CONFIG_SYS_DDR_INTERVAL_PERF 0x06180100 +#define CONFIG_SYS_DDR_CLK_CTRL 0x03800000 +#define CONFIG_SYS_DDR_CONTROL 0xc3008000 /* Type = DDR2 */ +#define CONFIG_SYS_DDR_CONTROL2 0x04400000 + +#define CONFIG_SYS_ALT_MEMTEST +#define CONFIG_SYS_MEMTEST_START 0x0ff00000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x0ffffffc + +/* + * RAM definitions + */ +#define CONFIG_SYS_INIT_RAM_LOCK +#define CONFIG_SYS_INIT_RAM_ADDR 0xe4010000 /* Initial RAM address */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x4000 /* Size of used area in RAM */ + +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE \ + - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024) /* Reserved for malloc */ + +/* + * Local Bus Definitions + */ +#define CONFIG_SYS_LBC_LCRR 0x00000004 /* LB clock ratio reg */ +#define CONFIG_SYS_LBC_LBCR 0x00000000 /* LB config reg */ + + +/* + * FLASH on the Local Bus + * One bank, 128M, using the CFI driver. + */ +#define CONFIG_SYS_BOOT_BLOCK 0xf8000000 /* boot TLB block */ +#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_BOOT_BLOCK /* start of FLASH 128M */ + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_SYS_FLASH_BASE_PHYS 0xff8000000ull +#else +# define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE +#endif + +/* 0xf8001801 */ +#define CONFIG_SYS_BR0_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) \ + | BR_PS_32 | BR_V) + +/* 0xf8006ff7 */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(128) | OR_GPCM_XAM | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 | OR_GPCM_TRLX \ + | OR_GPCM_EHTR | OR_GPCM_EAD) + +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS} +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 /* sectors per device */ + +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ + +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_AMD_CHECK_DQ7 +/* + * When initializing flash, if we cannot find the manufacturer ID, + * assume this is the AMD flash. + */ +#define CONFIG_ASSUME_AMD_FLASH + +/* + * Environment parameters + */ +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_OVERWRITE +#define CONFIG_SYS_USE_PPCENV +#define ENV_IS_EMBEDDED +#define CONFIG_ENV_SECT_SIZE 0x40000 /* 256K */ +#define CONFIG_ENV_SIZE 0x800 + +/* Environment at the start of flash sector, before text. */ +#define CONFIG_ENV_ADDR (CONFIG_SYS_TEXT_BASE - CONFIG_ENV_SIZE) +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ +#define CONFIG_SYS_TEXT_BASE 0xfffc0800 +#define CONFIG_SYS_LDSCRIPT "board/mercury/mpq101/u-boot.lds" + +/* + * Cypress CY7C67200 USB controller on the Local Bus. + * Not supported by u-boot at present. + */ +#define CONFIG_SYS_LBC_OPTION_BASE 0xf0000000 + +#ifdef CONFIG_PHYS_64BIT +# define CONFIG_SYS_LBC_OPTION_BASE_PHYS 0xff0000000ull +#else +# define CONFIG_SYS_LBC_OPTION_BASE_PHYS CONFIG_SYS_LBC_OPTION_BASE +#endif + +/* 0xf0001001 */ +#define CONFIG_SYS_BR1_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_LBC_OPTION_BASE_PHYS) \ + | BR_PS_16 | BR_V) + +/* fffff002 */ +#define CONFIG_SYS_OR1_PRELIM (P2SZ_TO_AM(0x8000) | OR_GPCM_XAM \ + | OR_GPCM_BCTLD | OR_GPCM_EHTR) + +/* + * Serial Ports + */ +#define CONFIG_CONS_INDEX 2 +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK get_bus_freq(0) + +#define CONFIG_SYS_BAUDRATE_TABLE {300, 600, 1200, 2400, 4800, 9600, \ + 19200, 38400, 115200} + +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600) + +/* + * I2C buses and peripherals + */ +#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ +#define CONFIG_HARD_I2C /* I2C with hardware support*/ +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SLAVE 0x7f +#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C2_OFFSET 0x3100 + +/* I2C RTC - M41T81 */ +#define CONFIG_RTC_M41T62 +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 +#define CONFIG_SYS_M41T11_BASE_YEAR 2000 + +/* I2C EEPROM - 24C256 */ +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 12 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +#define CONFIG_SYS_EEPROM_BUS_NUM 1 + +/* + * RapidIO MMU + */ +#ifdef CONFIG_SYS_SRIO +# define CONFIG_SRIO1 +# define CONFIG_SYS_SRIO1_MEM_VIRT 0xc0000000 +# define CONFIG_SYS_SRIO1_MEM_SIZE 0x20000000 /* 512M */ + +# ifdef CONFIG_PHYS_64BIT +# define CONFIG_SYS_SRIO1_MEM_PHYS 0xfc0000000ull +# else +# define CONFIG_SYS_SRIO1_MEM_PHYS CONFIG_SYS_SRIO1_MEM_VIRT +# endif +#endif + +/* + * Ethernet + */ +#ifdef CONFIG_TSEC_ENET + +# ifndef CONFIG_NET_MULTI +# define CONFIG_NET_MULTI +# endif + +# define CONFIG_MII /* MII PHY management */ +# define CONFIG_MII_DEFAULT_TSEC 1 /* Allow unregistered phys */ + +# define CONFIG_TSEC1 +# define CONFIG_TSEC1_NAME "eTSEC0" +# define TSEC1_PHY_ADDR 0x10 +# define TSEC1_PHYIDX 0 +# define TSEC1_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +# define CONFIG_TSEC2 +# define CONFIG_TSEC2_NAME "eTSEC1" +# define TSEC2_PHY_ADDR 0x11 +# define TSEC2_PHYIDX 0 +# define TSEC2_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +# define CONFIG_TSEC3 +# define CONFIG_TSEC3_NAME "eTSEC2" +# define TSEC3_PHY_ADDR 0x12 +# define TSEC3_PHYIDX 0 +# define TSEC3_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +# define CONFIG_TSEC4 +# define CONFIG_TSEC4_NAME "eTSEC3" +# define TSEC4_PHY_ADDR 0x13 +# define TSEC4_PHYIDX 0 +# define TSEC4_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) + +/* Options are: eTSEC[0-3] */ +# define CONFIG_ETHPRIME "eTSEC0" +# define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ +#endif + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DATE +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_CMD_SNTP +#define CONFIG_CMD_I2C +#define CONFIG_CMD_EEPROM +#define CONFIG_CMD_MII +#define CONFIG_CMD_ELF +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_SETEXPR +#define CONFIG_CMD_JFFS2 + +/* + * Miscellaneous configurable options + */ + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP +#define CONFIG_OF_STDOUT_VIA_ALIAS + +#define CONFIG_FIT /* new uImage format support */ +#define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ + +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER + +#ifdef CONFIG_SYS_HUSH_PARSER +# define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#endif + +#define CONFIG_LOADS_ECHO /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_CMDLINE_EDITING /* Command-line editing */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ + +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "MPQ-101=> " /* Monitor Command Prompt */ + +/* Console I/O Buffer Size */ +#ifdef CONFIG_CMD_KGDB +# define CONFIG_SYS_CBSIZE 1024 +#else +# define CONFIG_SYS_CBSIZE 256 +#endif + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT)+16) + +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 16 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (16 << 20) /* Initial Memory map for Linux*/ +#define CONFIG_SYS_BOOTM_LEN (16 << 20) /* Increase max gunzip size */ + +#ifdef CONFIG_CMD_KGDB +# define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +# define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Basic Environment Configuration + */ +#define CONFIG_BAUDRATE 115200 +#define CONFIG_BOOTDELAY 5 /* -1 disables auto-boot */ + +/*default location for tftp and bootm*/ +#define CONFIG_LOADADDR CONFIG_SYS_LOAD_ADDR + +#endif /* __CONFIG_H */
On Jan 23, 2011, at 11:59 PM, Alex Dubov wrote:
Mpq101 is a RapidIO development board in AMC form factor, featuring MPC8548 processor, 512MB of hardwired DDR2 RAM, 128MB of hardwired NAND flash memory, real time clock and additional serial EEPROM on i2c bus (enabled). USB controller is available, but not presently enabled.
Changes for v8:
Changes for v7:
Changes for v6:
Changes for v5:
Changes for v4:
Changes for v3:
Changes for v2:
applied
- k
Dear Alex Dubov,
Please keep the boards.cfg clean from configuration settings. Move the definition of CONFIG_SYS_LDSCRIPT into your board config header file.
[Kumar also reported that this does not even build. I confirm this.]
That's because of the relatively recent change to how the env_embedded.o is treated by the build system, so I need to refer to it explicitly, rather then by wildcard.
Shall I send a whole patch again or incremental fix will do?
Changes for v4:
Changes for v3:
Changes for v2:
MAINTAINERS | 3 + board/mercury/mpq101/Makefile | 53 +++++ board/mercury/mpq101/law.c | 55 ++++++ board/mercury/mpq101/mpq101.c | 140 ++++++++++++++ board/mercury/mpq101/tlb.c | 82 ++++++++ board/mercury/mpq101/u-boot.lds | 132 +++++++++++++ boards.cfg | 1 + include/configs/mpq101.h | 398 +++++++++++++++++++++++++++++++++++++++ 8 files changed, 864 insertions(+), 0 deletions(-) create mode 100644 board/mercury/mpq101/Makefile create mode 100644 board/mercury/mpq101/law.c create mode 100644 board/mercury/mpq101/mpq101.c create mode 100644 board/mercury/mpq101/tlb.c create mode 100644 board/mercury/mpq101/u-boot.lds create mode 100644 include/configs/mpq101.h
diff --git a/MAINTAINERS b/MAINTAINERS index d7cd09c..220c39d 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -138,6 +138,9 @@ Jon Diekema jon.diekema@smiths-aerospace.com
sbc8260 MPC8260
- mpq101 MPC8548
- $(call cmd_link_o_target, $(OBJS))
+clean:
- rm -f $(OBJS) $(SOBJS)
+distclean: clean
- rm -f $(LIB) core *.bak .depend
+######################################################################### diff --git a/board/mercury/mpq101/law.c b/board/mercury/mpq101/law.c new file mode 100644 index 0000000..726b5c2 --- /dev/null +++ b/board/mercury/mpq101/law.c @@ -0,0 +1,55 @@ +/*
- Copyright 2008 Freescale Semiconductor, Inc.
- (C) Copyright 2000
- Wolfgang Denk, DENX Software Engineering, wd@denx.de.
- project.
- MA 02111-1307 USA
- LAW(Local Access Window) configuration:
- 0x0000_0000 0x1fff_ffff DDR SYS_SDRAM_SIZE
- 0xc000_0000 0xdfff_ffff RapidIO 512M
- 0xe000_0000 0xe000_ffff CCSR 1M
- 0xf000_0000 0xffff_ffff LBC options + FLASH 256M
- Notes:
- CCSRBAR and L2-as-SRAM don't need a configured Local Access Window.
- If flash is 8M at default position (last 8M), no LAW needed.
- LAW 0 is reserved for boot mapping
- SET_LAW(CONFIG_SYS_SDRAM_BASE, CONFIG_SYS_SDRAM_SIZE_LOG - 1,
LAW_TRGT_IF_DDR_1),
+#ifdef CONFIG_SYS_RIO_MEM_PHYS
- SET_LAW(CONFIG_SYS_RIO_MEM_PHYS, LAW_SIZE_512M, LAW_TRGT_IF_RIO),
- SET_LAW(CONFIG_SYS_LBC_OPTION_BASE_PHYS, LAW_SIZE_256M,
LAW_TRGT_IF_LBC)
+int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/mercury/mpq101/mpq101.c b/board/mercury/mpq101/mpq101.c new file mode 100644 index 0000000..8d9b518 --- /dev/null +++ b/board/mercury/mpq101/mpq101.c @@ -0,0 +1,140 @@ +/*
- (C) Copyright 2011 Alex Dubov oakad@yahoo.com
- project.
- MA 02111-1307 USA
+unsigned long get_clock_freq(void) +{
- return 33000000;
- Initialize Local Bus
- fsl_lbc_t *lbc = LBC_BASE_ADDR;
- out_be32(&lbc->ltesr, 0xffffffff); /* Clear LBC error interrupts */
- out_be32(&lbc->lteir, 0xffffffff); /* Enable LBC error interrupts */
- ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR);
- ccsr_local_ecm_t *ecm = (void *)(CONFIG_SYS_MPC85xx_ECM_ADDR);
- puts("Board: Mercury Computer Systems, Inc. MPQ-101 ");
- puts("(36-bit addrmap) ");
- putc('\n');
- local_bus_init();
- out_be32(&gur->tsec34ioovcr, 0xe7e0); /* 1110 0111 1110 0xxx */
- out_be32(&ecm->eedr, 0xffffffff); /* clear ecm errors */
- out_be32(&ecm->eeer, 0xffffffff); /* enable ecm errors */
+phys_size_t initdram(int board_type) +{
- ccsr_ddr_t *ddr = (void *)(CONFIG_SYS_MPC85xx_DDR_ADDR);
- phys_size_t dram_size = 0;
- const char *p_mode = getenv("perf_mode");
- puts("Initializing....");
- out_be32(&ddr->cs0_bnds, CONFIG_SYS_DDR_CS0_BNDS);
- out_be32(&ddr->cs0_config, CONFIG_SYS_DDR_CS0_CONFIG);
- out_be32(&ddr->timing_cfg_3, CONFIG_SYS_DDR_TIMING_3);
- out_be32(&ddr->timing_cfg_0, CONFIG_SYS_DDR_TIMING_0);
- if (p_mode && !strcmp("performance", p_mode)) {
- } else {
- out_be32(&ddr->sdram_clk_cntl, CONFIG_SYS_DDR_CLK_CTRL);
- out_be32(&ddr->sdram_cfg_2, CONFIG_SYS_DDR_CONTROL2);
- asm("sync;isync");
- udelay(500);
- out_be32(&ddr->sdram_cfg, CONFIG_SYS_DDR_CONTROL);
- asm("sync; isync");
- udelay(500);
- dram_size = setup_ddr_tlbs(1ull << (CONFIG_SYS_SDRAM_SIZE_LOG - 20));
- puts(" DDR: ");
- return get_ram_size(0, dram_size << 20);
- /* PCI is disabled */
- out_be32(&gur->devdisr, in_be32(&gur->devdisr)
diff --git a/include/configs/mpq101.h b/include/configs/mpq101.h new file mode 100644 index 0000000..33d6b69 --- /dev/null +++ b/include/configs/mpq101.h @@ -0,0 +1,398 @@ +/*
- Copyright 2011 Alex Dubov oakad@yahoo.com
- project.
- MA 02111-1307 USA
- Merury Computers MPQ101 board configuration file
+#ifdef CONFIG_36BIT +# define CONFIG_PHYS_64BIT 1 +#endif
+/* High Level Configuration Options */ +#define CONFIG_BOOKE 1 /* BOOKE */ +#define CONFIG_E500 1 /* BOOKE e500 family */ +#define CONFIG_MPC85xx 1 /* MPC8540/60/55/41/48 */ +#define CONFIG_MPC8548 1 /* MPC8548 specific */ +#define CONFIG_MPQ101 1 /* MPQ101 board specific */
+#define CONFIG_RIO 1 +#define CONFIG_TSEC_ENET 1 /* tsec ethernet support */ +#define CONFIG_INTERRUPTS 1 /* enable pci, srio, ddr interrupts */ +#define CONFIG_FSL_LAW 1 /* Use common FSL init code */
- These can be toggled for performance analysis, otherwise use default.
+#define CONFIG_L2_CACHE 1 /* toggle L2 cache */ +#define CONFIG_BTB 1 /* toggle branch predition */
+#define CONFIG_PANIC_HANG 1
- Only possible on E500 Version 2 or newer cores.
+#define CONFIG_ENABLE_36BIT_PHYS 1
+#ifdef CONFIG_PHYS_64BIT +# define CONFIG_ADDR_MAP 1 +# define CONFIG_SYS_NUM_ADDR_MAP 16 /* number of TLB1 entries */ +#endif
+#ifndef __ASSEMBLY__ +extern unsigned long get_clock_freq(void); +#endif
+#define CONFIG_SYS_CLK_FREQ get_clock_freq() /* sysclk for MPC85xx */
You don't really need a function here for get_clock_freq() you can just:
- k
Alex Dubov
Kumar Gala
