[U-Boot] [PATCH v2 0/4] ppc4xx: Overhaul for cmd reginfo
The command "reginfo" got an overhaul for the ppc4xx. It dumps all the relevant HW configuration registers (address, symbolic name, content). This allows to easily detect errors in *.h files and changes in the HW configuration.
It is split in the following parts: - Cleanup some HW register names: Here you find all the changes in the include directory for new register names and adapting other ones to the names used by AMCC in their manuals, e.g. For 440EPx/GRPPC440EPx/GRX, Revision 1.15 – September 22, 2008 For PPC405GP Embedded Processor, Revision 1.02 – March 22, 2006 - Apply new HW register names Modify all existing *.c files to use the new register names. - Rework cmd reginfo Here the real work done to improve the reginfo command. - respect 80-chars per line in ppc*.h files After running checkstyle.pl on the three previous patches I noted that in the *.h files there were a lot of long lines. This patch solves this problem.
I tested the changes on my PPC405GPr board HCU4 and PPC440EPx board HCU5.
Only ran MAKEALL 4xx as I have no other cross-compilers installed.
As I had not time to consult the documentation of all PPC440 variants (not have I boards to test it) the code in reginfo will probably dump less registers for none PPC440EPx variants.
The DMA-registers are not dumped for the PPC440.
I know that I could spend not only many hours but weeks to cleanup all the PPC4xx register naming conventions.
I did not feel it my responsability to bring the lines in all 4xx board specific code to fit into 80 chars. But I think I will have soon a look at all the common 4xx files to bring them in shape as I would really like that a tool like checkstyle.pl from the Linux kernel only reports my errors.
Niklaus Giger (4): ppc4xx: Cleanup some HW register names ppc_4xx: Apply new HW register names ppc4xx: Rework cmd reginfo ppc4xx: respect 80-chars per line in ppc*.h files
board/amcc/bamboo/bamboo.c | 32 +- board/amcc/canyonlands/canyonlands.c | 22 +- board/amcc/ebony/ebony.c | 22 +- board/amcc/katmai/katmai.c | 22 +- board/amcc/luan/epld.h | 22 +- board/amcc/luan/luan.c | 22 +- board/amcc/ocotea/ocotea.c | 22 +- board/amcc/sequoia/sequoia.c | 28 +- board/amcc/taishan/showinfo.c | 112 ++-- board/amcc/taishan/taishan.c | 22 +- board/amcc/yosemite/yosemite.c | 32 +- board/amcc/yucca/yucca.c | 22 +- board/esd/common/cmd_loadpci.c | 2 +- board/esd/du440/du440.c | 28 +- board/esd/pmc440/cmd_pmc440.c | 10 +- board/esd/pmc440/pmc440.c | 32 +- board/exbitgen/init.S | 4 +- board/gdsys/gdppc440etx/gdppc440etx.c | 32 +- board/gdsys/intip/intip.c | 22 +- board/korat/korat.c | 28 +- board/lwmon5/lwmon5.c | 32 +- board/netstal/hcu5/hcu5.c | 28 +- board/pcs440ep/pcs440ep.c | 32 +- board/prodrive/alpr/alpr.c | 52 +- board/prodrive/p3p440/p3p440.c | 22 +- board/sandburst/common/ppc440gx_i2c.h | 2 +- board/sandburst/common/sb_common.c | 22 +- board/xes/xpedite1000/xpedite1000.c | 24 +- common/cmd_reginfo.c | 158 +---- cpu/ppc4xx/4xx_pci.c | 48 +- cpu/ppc4xx/Makefile | 4 + cpu/ppc4xx/cpu_init.c | 4 +- cpu/ppc4xx/miiphy.c | 24 +- cpu/ppc4xx/reginfo.c | 370 +++++++++ cpu/ppc4xx/speed.c | 6 +- drivers/net/4xx_enet.c | 100 ++-- include/4xx_i2c.h | 2 +- include/ppc405.h | 530 +++++++------- include/ppc440.h | 1401 +++++++++++++++++++-------------- include/ppc4xx.h | 36 +- include/ppc4xx_enet.h | 314 ++++---- post/cpu/ppc4xx/ether.c | 50 +- 42 files changed, 2109 insertions(+), 1690 deletions(-) create mode 100644 cpu/ppc4xx/reginfo.c
*** BLURB HERE ***
Signed-off-by: Niklaus Giger niklaus.giger@member.fsf.org --- include/4xx_i2c.h | 2 +- include/ppc405.h | 4 +- include/ppc440.h | 179 ++++++++++++++++++++++------------------ include/ppc4xx_enet.h | 220 +++++++++++++++++++++++++------------------------ 4 files changed, 216 insertions(+), 189 deletions(-)
diff --git a/include/4xx_i2c.h b/include/4xx_i2c.h index f0e772c..070657f 100644 --- a/include/4xx_i2c.h +++ b/include/4xx_i2c.h @@ -63,7 +63,7 @@ #define IIC_EXTSTS (I2C_REGISTERS_BASE_ADDRESS+IICEXTSTS) #define IIC_LSADR (I2C_REGISTERS_BASE_ADDRESS+IICLSADR) #define IIC_HSADR (I2C_REGISTERS_BASE_ADDRESS+IICHSADR) -#define IIC_CLKDIV (I2C_REGISTERS_BASE_ADDRESS+IICCLKDIV) +#define IIC_CLKDIV (I2C_REGISTERS_BASE_ADDRESS+IIC0_CLKDIV) #define IIC_INTRMSK (I2C_REGISTERS_BASE_ADDRESS+IICINTRMSK) #define IIC_XFRCNT (I2C_REGISTERS_BASE_ADDRESS+IICXFRCNT) #define IIC_XTCNTLSS (I2C_REGISTERS_BASE_ADDRESS+IICXTCNTLSS) diff --git a/include/ppc405.h b/include/ppc405.h index 5e56897..4c62249 100644 --- a/include/ppc405.h +++ b/include/ppc405.h @@ -578,7 +578,7 @@ #define IICEXTSTS 0x09 #define IICLSADR 0x0A #define IICHSADR 0x0B -#define IICCLKDIV 0x0C +#define IIC0_CLKDIV 0x0C #define IICINTRMSK 0x0D #define IICXFRCNT 0x0E #define IICXTCNTLSS 0x0F @@ -760,7 +760,7 @@ #define CPR0_PLLD 0x060 #define CPR0_CPUD 0x080 #define CPR0_PLBD 0x0a0 -#define CPR0_OPBD 0x0c0 +#define CPR0_OPBD0 0x0c0 #define CPR0_PERD 0x0e0
#define SDR0_PINSTP 0x0040 diff --git a/include/ppc440.h b/include/ppc440.h index 378a9de..9299a71 100644 --- a/include/ppc440.h +++ b/include/ppc440.h @@ -60,9 +60,9 @@ /* values for clkcfga register - indirect addressing of these regs */ #define CPR0_PLLC 0x0040 #define CPR0_PLLD 0x0060 -#define CPR0_PRIMAD 0x0080 -#define CPR0_PRIMBD 0x00a0 -#define CPR0_OPBD 0x00c0 +#define CPR0_PRIMAD0 0x0080 +#define CPR0_PRIMBD0 0x00a0 +#define CPR0_OPBD0 0x00c0 #define CPR0_PERD 0x00e0 #define CPR0_MALD 0x0100 #define CPR0_SPCID 0x0120 @@ -100,7 +100,7 @@ #define SDR0_PFC1 0x4101 /* Pin Function 1 */ #define SDR0_MFR 0x4300 /* SDR0_MFR reg */
-#ifdef CONFIG_440GX +#if defined(CONFIG_440GX) #define SD0_AMP 0x0240 #define SDR0_XPLLC 0x01c1 #define SDR0_XPLLD 0x01c2 @@ -1319,6 +1319,19 @@ #define SDR0_MFR_PKT_REJ_POL 0x00080000 /* Packet Reject Polarity */ #endif
+ +#if defined(CONFIG_440EPX) +#define CPM0_ER 0x000000B0 +#define CPM1_ER 0x000000F0 +#define PLB4A0_ACR 0x00000081 +#define PLB4A1_ACR 0x00000089 +#define PLB3A0_ACR 0x00000077 +#define OPB2PLB40_BCTRL 0x00000350 +#define P4P3BO0_CFG 0x00000026 +#define SPI0_MODE 0xEF600090 /* SPI Mode Regsgiter */ + +#endif + #if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) #define SDR0_PFC1_EPS_ENCODE(n) ((((unsigned long)(n))&0x07)<<22) #define SDR0_PFC1_EPS_DECODE(n) ((((unsigned long)(n))>>22)&0x07) @@ -1385,6 +1398,12 @@ #define SDR0_SRST1_FPU 0x00004000 /* Floating Point Unit */ #define SDR0_SRST1_KASU0 0x00002000 /* Kasumi Engine */
+#define SDR0_EMAC0RXST 0x00004301 /* */ +#define SDR0_EMAC0TXST 0x00004302 /* */ +#define SDR0_CRYP0 0x00004500 +#define SDR0_EBC0 0x00000100 +#define SDR0_SDSTP2 0x00004001 +#define SDR0_SDSTP3 0x00004001 #elif defined(CONFIG_460EX) || defined(CONFIG_460GT)
#define SDR0_SRST0 SDR0_SRST /* for compatability reasons */ @@ -1586,7 +1605,7 @@ #define IICEXTSTS 0x09 #define IICLSADR 0x0A #define IICHSADR 0x0B -#define IICCLKDIV 0x0C +#define IIC0_CLKDIV 0x0C #define IICINTRMSK 0x0D #define IICXFRCNT 0x0E #define IICXTCNTLSS 0x0F @@ -1595,10 +1614,10 @@ /*----------------------------------------------------------------------------- | PCI Internal Registers et. al. (accessed via plb) +----------------------------------------------------------------------------*/ -#define PCIX0_CFGADR (CONFIG_SYS_PCI_BASE + 0x0ec00000) -#define PCIX0_CFGDATA (CONFIG_SYS_PCI_BASE + 0x0ec00004) -#define PCIX0_CFGBASE (CONFIG_SYS_PCI_BASE + 0x0ec80000) -#define PCIX0_IOBASE (CONFIG_SYS_PCI_BASE + 0x08000000) +#define PCIL0_CFGADR (CONFIG_SYS_PCI_BASE + 0x0ec00000) +#define PCIL0_CFGDATA (CONFIG_SYS_PCI_BASE + 0x0ec00004) +#define PCIL0_CFGBASE (CONFIG_SYS_PCI_BASE + 0x0ec80000) +#define PCIL0_IOBASE (CONFIG_SYS_PCI_BASE + 0x08000000)
#if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) @@ -1608,82 +1627,82 @@ #define PCI_MMIO_LCR_BASE (CONFIG_SYS_PCI_BASE + 0x0f400000) /* Real => 0x0EF400000 */
/* PCI Master Local Configuration Registers */ -#define PCIX0_PMM0LA (PCI_MMIO_LCR_BASE + 0x00) /* PMM0 Local Address */ -#define PCIX0_PMM0MA (PCI_MMIO_LCR_BASE + 0x04) /* PMM0 Mask/Attribute */ -#define PCIX0_PMM0PCILA (PCI_MMIO_LCR_BASE + 0x08) /* PMM0 PCI Low Address */ -#define PCIX0_PMM0PCIHA (PCI_MMIO_LCR_BASE + 0x0C) /* PMM0 PCI High Address */ -#define PCIX0_PMM1LA (PCI_MMIO_LCR_BASE + 0x10) /* PMM1 Local Address */ -#define PCIX0_PMM1MA (PCI_MMIO_LCR_BASE + 0x14) /* PMM1 Mask/Attribute */ -#define PCIX0_PMM1PCILA (PCI_MMIO_LCR_BASE + 0x18) /* PMM1 PCI Low Address */ -#define PCIX0_PMM1PCIHA (PCI_MMIO_LCR_BASE + 0x1C) /* PMM1 PCI High Address */ -#define PCIX0_PMM2LA (PCI_MMIO_LCR_BASE + 0x20) /* PMM2 Local Address */ -#define PCIX0_PMM2MA (PCI_MMIO_LCR_BASE + 0x24) /* PMM2 Mask/Attribute */ -#define PCIX0_PMM2PCILA (PCI_MMIO_LCR_BASE + 0x28) /* PMM2 PCI Low Address */ -#define PCIX0_PMM2PCIHA (PCI_MMIO_LCR_BASE + 0x2C) /* PMM2 PCI High Address */ +#define PCIL0_PMM0LA (PCI_MMIO_LCR_BASE + 0x00) /* PMM0 Local Address */ +#define PCIL0_PMM0MA (PCI_MMIO_LCR_BASE + 0x04) /* PMM0 Mask/Attribute */ +#define PCIL0_PMM0PCILA (PCI_MMIO_LCR_BASE + 0x08) /* PMM0 PCI Low Address */ +#define PCIL0_PMM0PCIHA (PCI_MMIO_LCR_BASE + 0x0C) /* PMM0 PCI High Address */ +#define PCIL0_PMM1LA (PCI_MMIO_LCR_BASE + 0x10) /* PMM1 Local Address */ +#define PCIL0_PMM1MA (PCI_MMIO_LCR_BASE + 0x14) /* PMM1 Mask/Attribute */ +#define PCIL0_PMM1PCILA (PCI_MMIO_LCR_BASE + 0x18) /* PMM1 PCI Low Address */ +#define PCIL0_PMM1PCIHA (PCI_MMIO_LCR_BASE + 0x1C) /* PMM1 PCI High Address */ +#define PCIL0_PMM2LA (PCI_MMIO_LCR_BASE + 0x20) /* PMM2 Local Address */ +#define PCIL0_PMM2MA (PCI_MMIO_LCR_BASE + 0x24) /* PMM2 Mask/Attribute */ +#define PCIL0_PMM2PCILA (PCI_MMIO_LCR_BASE + 0x28) /* PMM2 PCI Low Address */ +#define PCIL0_PMM2PCIHA (PCI_MMIO_LCR_BASE + 0x2C) /* PMM2 PCI High Address */
/* PCI Target Local Configuration Registers */ -#define PCIX0_PTM1MS (PCI_MMIO_LCR_BASE + 0x30) /* PTM1 Memory Size/Attribute */ -#define PCIX0_PTM1LA (PCI_MMIO_LCR_BASE + 0x34) /* PTM1 Local Addr. Reg */ -#define PCIX0_PTM2MS (PCI_MMIO_LCR_BASE + 0x38) /* PTM2 Memory Size/Attribute */ -#define PCIX0_PTM2LA (PCI_MMIO_LCR_BASE + 0x3C) /* PTM2 Local Addr. Reg */ +#define PCIL0_PTM1MS (PCI_MMIO_LCR_BASE + 0x30) /* PTM1 Memory Size/Attribute */ +#define PCIL0_PTM1LA (PCI_MMIO_LCR_BASE + 0x34) /* PTM1 Local Addr. Reg */ +#define PCIL0_PTM2MS (PCI_MMIO_LCR_BASE + 0x38) /* PTM2 Memory Size/Attribute */ +#define PCIL0_PTM2LA (PCI_MMIO_LCR_BASE + 0x3C) /* PTM2 Local Addr. Reg */
#else
-#define PCIX0_VENDID (PCIX0_CFGBASE + PCI_VENDOR_ID ) -#define PCIX0_DEVID (PCIX0_CFGBASE + PCI_DEVICE_ID ) -#define PCIX0_CMD (PCIX0_CFGBASE + PCI_COMMAND ) -#define PCIX0_STATUS (PCIX0_CFGBASE + PCI_STATUS ) -#define PCIX0_REVID (PCIX0_CFGBASE + PCI_REVISION_ID ) -#define PCIX0_CLS (PCIX0_CFGBASE + PCI_CLASS_CODE) -#define PCIX0_CACHELS (PCIX0_CFGBASE + PCI_CACHE_LINE_SIZE ) -#define PCIX0_LATTIM (PCIX0_CFGBASE + PCI_LATENCY_TIMER ) -#define PCIX0_HDTYPE (PCIX0_CFGBASE + PCI_HEADER_TYPE ) -#define PCIX0_BIST (PCIX0_CFGBASE + PCI_BIST ) -#define PCIX0_BAR0 (PCIX0_CFGBASE + PCI_BASE_ADDRESS_0 ) -#define PCIX0_BAR1 (PCIX0_CFGBASE + PCI_BASE_ADDRESS_1 ) -#define PCIX0_BAR2 (PCIX0_CFGBASE + PCI_BASE_ADDRESS_2 ) -#define PCIX0_BAR3 (PCIX0_CFGBASE + PCI_BASE_ADDRESS_3 ) -#define PCIX0_BAR4 (PCIX0_CFGBASE + PCI_BASE_ADDRESS_4 ) -#define PCIX0_BAR5 (PCIX0_CFGBASE + PCI_BASE_ADDRESS_5 ) -#define PCIX0_CISPTR (PCIX0_CFGBASE + PCI_CARDBUS_CIS ) -#define PCIX0_SBSYSVID (PCIX0_CFGBASE + PCI_SUBSYSTEM_VENDOR_ID ) -#define PCIX0_SBSYSID (PCIX0_CFGBASE + PCI_SUBSYSTEM_ID ) -#define PCIX0_EROMBA (PCIX0_CFGBASE + PCI_ROM_ADDRESS ) -#define PCIX0_CAP (PCIX0_CFGBASE + PCI_CAPABILITY_LIST ) -#define PCIX0_RES0 (PCIX0_CFGBASE + 0x0035 ) -#define PCIX0_RES1 (PCIX0_CFGBASE + 0x0036 ) -#define PCIX0_RES2 (PCIX0_CFGBASE + 0x0038 ) -#define PCIX0_INTLN (PCIX0_CFGBASE + PCI_INTERRUPT_LINE ) -#define PCIX0_INTPN (PCIX0_CFGBASE + PCI_INTERRUPT_PIN ) -#define PCIX0_MINGNT (PCIX0_CFGBASE + PCI_MIN_GNT ) -#define PCIX0_MAXLTNCY (PCIX0_CFGBASE + PCI_MAX_LAT ) - -#define PCIX0_BRDGOPT1 (PCIX0_CFGBASE + 0x0040) -#define PCIX0_BRDGOPT2 (PCIX0_CFGBASE + 0x0044) - -#define PCIX0_POM0LAL (PCIX0_CFGBASE + 0x0068) -#define PCIX0_POM0LAH (PCIX0_CFGBASE + 0x006c) -#define PCIX0_POM0SA (PCIX0_CFGBASE + 0x0070) -#define PCIX0_POM0PCIAL (PCIX0_CFGBASE + 0x0074) -#define PCIX0_POM0PCIAH (PCIX0_CFGBASE + 0x0078) -#define PCIX0_POM1LAL (PCIX0_CFGBASE + 0x007c) -#define PCIX0_POM1LAH (PCIX0_CFGBASE + 0x0080) -#define PCIX0_POM1SA (PCIX0_CFGBASE + 0x0084) -#define PCIX0_POM1PCIAL (PCIX0_CFGBASE + 0x0088) -#define PCIX0_POM1PCIAH (PCIX0_CFGBASE + 0x008c) -#define PCIX0_POM2SA (PCIX0_CFGBASE + 0x0090) - -#define PCIX0_PIM0SA (PCIX0_CFGBASE + 0x0098) -#define PCIX0_PIM0LAL (PCIX0_CFGBASE + 0x009c) -#define PCIX0_PIM0LAH (PCIX0_CFGBASE + 0x00a0) -#define PCIX0_PIM1SA (PCIX0_CFGBASE + 0x00a4) -#define PCIX0_PIM1LAL (PCIX0_CFGBASE + 0x00a8) -#define PCIX0_PIM1LAH (PCIX0_CFGBASE + 0x00ac) -#define PCIX0_PIM2SA (PCIX0_CFGBASE + 0x00b0) -#define PCIX0_PIM2LAL (PCIX0_CFGBASE + 0x00b4) -#define PCIX0_PIM2LAH (PCIX0_CFGBASE + 0x00b8) - -#define PCIX0_STS (PCIX0_CFGBASE + 0x00e0) +#define PCIL0_VENDID (PCIL0_CFGBASE + PCI_VENDOR_ID ) +#define PCIL0_DEVID (PCIL0_CFGBASE + PCI_DEVICE_ID ) +#define PCIL0_CMD (PCIL0_CFGBASE + PCI_COMMAND ) +#define PCIL0_STATUS (PCIL0_CFGBASE + PCI_STATUS ) +#define PCIL0_REVID (PCIL0_CFGBASE + PCI_REVISION_ID ) +#define PCIL0_CLS (PCIL0_CFGBASE + PCI_CLASS_CODE) +#define PCIL0_CACHELS (PCIL0_CFGBASE + PCI_CACHE_LINE_SIZE ) +#define PCIL0_LATTIM (PCIL0_CFGBASE + PCI_LATENCY_TIMER ) +#define PCIL0_HDTYPE (PCIL0_CFGBASE + PCI_HEADER_TYPE ) +#define PCIL0_BIST (PCIL0_CFGBASE + PCI_BIST ) +#define PCIL0_BAR0 (PCIL0_CFGBASE + PCI_BASE_ADDRESS_0 ) +#define PCIL0_BAR1 (PCIL0_CFGBASE + PCI_BASE_ADDRESS_1 ) +#define PCIL0_BAR2 (PCIL0_CFGBASE + PCI_BASE_ADDRESS_2 ) +#define PCIL0_BAR3 (PCIL0_CFGBASE + PCI_BASE_ADDRESS_3 ) +#define PCIL0_BAR4 (PCIL0_CFGBASE + PCI_BASE_ADDRESS_4 ) +#define PCIL0_BAR5 (PCIL0_CFGBASE + PCI_BASE_ADDRESS_5 ) +#define PCIL0_CISPTR (PCIL0_CFGBASE + PCI_CARDBUS_CIS ) +#define PCIL0_SBSYSVID (PCIL0_CFGBASE + PCI_SUBSYSTEM_VENDOR_ID ) +#define PCIL0_SBSYSID (PCIL0_CFGBASE + PCI_SUBSYSTEM_ID ) +#define PCIL0_EROMBA (PCIL0_CFGBASE + PCI_ROM_ADDRESS ) +#define PCIL0_CAP (PCIL0_CFGBASE + PCI_CAPABILITY_LIST ) +#define PCIL0_RES0 (PCIL0_CFGBASE + 0x0035 ) +#define PCIL0_RES1 (PCIL0_CFGBASE + 0x0036 ) +#define PCIL0_RES2 (PCIL0_CFGBASE + 0x0038 ) +#define PCIL0_INTLN (PCIL0_CFGBASE + PCI_INTERRUPT_LINE ) +#define PCIL0_INTPN (PCIL0_CFGBASE + PCI_INTERRUPT_PIN ) +#define PCIL0_MINGNT (PCIL0_CFGBASE + PCI_MIN_GNT ) +#define PCIL0_MAXLTNCY (PCIL0_CFGBASE + PCI_MAX_LAT ) + +#define PCIL0_BRDGOPT1 (PCIL0_CFGBASE + 0x0040) +#define PCIL0_BRDGOPT2 (PCIL0_CFGBASE + 0x0044) + +#define PCIL0_POM0LAL (PCIL0_CFGBASE + 0x0068) +#define PCIL0_POM0LAH (PCIL0_CFGBASE + 0x006c) +#define PCIL0_POM0SA (PCIL0_CFGBASE + 0x0070) +#define PCIL0_POM0PCIAL (PCIL0_CFGBASE + 0x0074) +#define PCIL0_POM0PCIAH (PCIL0_CFGBASE + 0x0078) +#define PCIL0_POM1LAL (PCIL0_CFGBASE + 0x007c) +#define PCIL0_POM1LAH (PCIL0_CFGBASE + 0x0080) +#define PCIL0_POM1SA (PCIL0_CFGBASE + 0x0084) +#define PCIL0_POM1PCIAL (PCIL0_CFGBASE + 0x0088) +#define PCIL0_POM1PCIAH (PCIL0_CFGBASE + 0x008c) +#define PCIL0_POM2SA (PCIL0_CFGBASE + 0x0090) + +#define PCIL0_PIM0SA (PCIL0_CFGBASE + 0x0098) +#define PCIL0_PIM0LAL (PCIL0_CFGBASE + 0x009c) +#define PCIL0_PIM0LAH (PCIL0_CFGBASE + 0x00a0) +#define PCIL0_PIM1SA (PCIL0_CFGBASE + 0x00a4) +#define PCIL0_PIM1LAL (PCIL0_CFGBASE + 0x00a8) +#define PCIL0_PIM1LAH (PCIL0_CFGBASE + 0x00ac) +#define PCIL0_PIM2SA (PCIL0_CFGBASE + 0x00b0) +#define PCIL0_PIM2LAL (PCIL0_CFGBASE + 0x00b4) +#define PCIL0_PIM2LAH (PCIL0_CFGBASE + 0x00b8) + +#define PCIL0_STS (PCIL0_CFGBASE + 0x00e0)
#endif /* !defined(CONFIG_440EP) !defined(CONFIG_440GR) */
diff --git a/include/ppc4xx_enet.h b/include/ppc4xx_enet.h index 7588e93..9be22e7 100644 --- a/include/ppc4xx_enet.h +++ b/include/ppc4xx_enet.h @@ -173,13 +173,13 @@ typedef struct emac_4xx_hw_st { #if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) -#define ZMII_BASE (CONFIG_SYS_PERIPHERAL_BASE + 0x0D00) +#define ZMII0_BASE (CONFIG_SYS_PERIPHERAL_BASE + 0x0D00) #else -#define ZMII_BASE (CONFIG_SYS_PERIPHERAL_BASE + 0x0780) +#define ZMII0_BASE (CONFIG_SYS_PERIPHERAL_BASE + 0x0780) #endif -#define ZMII_FER (ZMII_BASE) -#define ZMII_SSR (ZMII_BASE + 4) -#define ZMII_SMIISR (ZMII_BASE + 8) +#define ZMII0_FER (ZMII0_BASE) +#define ZMII0_SSR (ZMII0_BASE + 4) +#define ZMII0_SMIISR (ZMII0_BASE + 8)
/* ZMII FER Register Bit Definitions */ #define ZMII_FER_DIS (0x0) @@ -196,25 +196,25 @@ typedef struct emac_4xx_hw_st {
/* ZMII Speed Selection Register Bit Definitions */ -#define ZMII_SSR_SCI (0x4) -#define ZMII_SSR_FSS (0x2) -#define ZMII_SSR_SP (0x1) -#define ZMII_SSR_RSVD16_31 (0x0000FFFF) +#define ZMII0_SSR_SCI (0x4) +#define ZMII0_SSR_FSS (0x2) +#define ZMII0_SSR_SP (0x1) +#define ZMII0_SSR_RSVD16_31 (0x0000FFFF)
-#define ZMII_SSR_V(__x) (((3 - __x) * 4) + 16) +#define ZMII0_SSR_V(__x) (((3 - __x) * 4) + 16)
/* ZMII SMII Status Register Bit Definitions */ -#define ZMII_SMIISR_E1 (0x80) -#define ZMII_SMIISR_EC (0x40) -#define ZMII_SMIISR_EN (0x20) -#define ZMII_SMIISR_EJ (0x10) -#define ZMII_SMIISR_EL (0x08) -#define ZMII_SMIISR_ED (0x04) -#define ZMII_SMIISR_ES (0x02) -#define ZMII_SMIISR_EF (0x01) +#define ZMII0_SMIISR_E1 (0x80) +#define ZMII0_SMIISR_EC (0x40) +#define ZMII0_SMIISR_EN (0x20) +#define ZMII0_SMIISR_EJ (0x10) +#define ZMII0_SMIISR_EL (0x08) +#define ZMII0_SMIISR_ED (0x04) +#define ZMII0_SMIISR_ES (0x02) +#define ZMII0_SMIISR_EF (0x01)
-#define ZMII_SMIISR_V(__x) ((3 - __x) * 8) +#define ZMII0_SMIISR_V(__x) ((3 - __x) * 8)
/* RGMII Register Addresses */ #if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) @@ -328,41 +328,49 @@ typedef struct emac_4xx_hw_st { #if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) -#define EMAC_BASE (CONFIG_SYS_PERIPHERAL_BASE + 0x0E00) +#define EMAC0_BASE (CONFIG_SYS_PERIPHERAL_BASE + 0x0E00) #else -#define EMAC_BASE (CONFIG_SYS_PERIPHERAL_BASE + 0x0800) +#define EMAC0_BASE (CONFIG_SYS_PERIPHERAL_BASE + 0x0800) #endif #else #if defined(CONFIG_405EZ) || defined(CONFIG_405EX) -#define EMAC_BASE 0xEF600900 +#define EMAC0_BASE 0xEF600900 #else -#define EMAC_BASE 0xEF600800 +#define EMAC0_BASE 0xEF600800 #endif #endif
-#define EMAC_M0 (EMAC_BASE) -#define EMAC_M1 (EMAC_BASE + 4) -#define EMAC_TXM0 (EMAC_BASE + 8) -#define EMAC_TXM1 (EMAC_BASE + 12) -#define EMAC_RXM (EMAC_BASE + 16) -#define EMAC_ISR (EMAC_BASE + 20) -#define EMAC_IER (EMAC_BASE + 24) -#define EMAC_IAH (EMAC_BASE + 28) -#define EMAC_IAL (EMAC_BASE + 32) -#define EMAC_PAUSE_TIME_REG (EMAC_BASE + 44) -#define EMAC_I_FRAME_GAP_REG (EMAC_BASE + 88) -#define EMAC_STACR (EMAC_BASE + 92) -#define EMAC_TRTR (EMAC_BASE + 96) -#define EMAC_RX_HI_LO_WMARK (EMAC_BASE + 100) +#if defined(CONFIG_440EPX) +#define EMAC1_BASE 0xEF600F00 +#define EMAC1_MR1 (EMAC1_BASE + 0x04) +#endif + +#define EMAC0_MR0 (EMAC0_BASE) +#define EMAC0_MR1 (EMAC0_BASE + 0x04) +#define EMAC0_TMR0 (EMAC0_BASE + 0x08) +#define EMAC0_TMR1 (EMAC0_BASE + 0x0c) +#define EMAC0_RXM (EMAC0_BASE + 0x10) +#define EMAC0_ISR (EMAC0_BASE + 0x14) +#define EMAC0_IER (EMAC0_BASE + 0x18) +#define EMAC0_IAH (EMAC0_BASE + 0x1c) +#define EMAC0_IAL (EMAC0_BASE + 0x20) +#define EMAC0_PTR (EMAC0_BASE + 0x2c) +#define EMAC0_PAUSE_TIME_REG EMAC0_PTR +#define EMAC0_IPGVR (EMAC0_BASE + 0x58) +#define EMAC0_I_FRAME_GAP_REG EMAC0_IPGVR +#define EMAC0_STACR (EMAC0_BASE + 0x5c) +#define EMAC0_TRTR (EMAC0_BASE + 0x60) +#define EMAC0_RWMR (EMAC0_BASE + 0x64) +#define EMAC0_RX_HI_LO_WMARK EMAC0_RWMR
/* bit definitions */ /* MODE REG 0 */ -#define EMAC_M0_RXI (0x80000000) -#define EMAC_M0_TXI (0x40000000) -#define EMAC_M0_SRST (0x20000000) -#define EMAC_M0_TXE (0x10000000) -#define EMAC_M0_RXE (0x08000000) -#define EMAC_M0_WKE (0x04000000) +#define EMAC_MR0_RXI (0x80000000) +#define EMAC_MR0_TXI (0x40000000) +#define EMAC_MR0_SRST (0x20000000) +#define EMAC_MR0_TXE (0x10000000) +#define EMAC_MR0_RXE (0x08000000) +#define EMAC_MR0_WKE (0x04000000)
/* on 440GX EMAC_MR1 has a different layout! */ #if defined(CONFIG_440GX) || \ @@ -371,82 +379,82 @@ typedef struct emac_4xx_hw_st { defined(CONFIG_460EX) || defined(CONFIG_460GT) || \ defined(CONFIG_405EX) /* MODE Reg 1 */ -#define EMAC_M1_FDE (0x80000000) -#define EMAC_M1_ILE (0x40000000) -#define EMAC_M1_VLE (0x20000000) -#define EMAC_M1_EIFC (0x10000000) -#define EMAC_M1_APP (0x08000000) -#define EMAC_M1_RSVD (0x06000000) -#define EMAC_M1_IST (0x01000000) -#define EMAC_M1_MF_1000GPCS (0x00C00000) -#define EMAC_M1_MF_1000MBPS (0x00800000) /* 0's for 10MBPS */ -#define EMAC_M1_MF_100MBPS (0x00400000) -#define EMAC_M1_RFS_MASK (0x00380000) -#define EMAC_M1_RFS_16K (0x00280000) -#define EMAC_M1_RFS_8K (0x00200000) -#define EMAC_M1_RFS_4K (0x00180000) -#define EMAC_M1_RFS_2K (0x00100000) -#define EMAC_M1_RFS_1K (0x00080000) -#define EMAC_M1_TX_FIFO_MASK (0x00070000) -#define EMAC_M1_TX_FIFO_16K (0x00050000) -#define EMAC_M1_TX_FIFO_8K (0x00040000) -#define EMAC_M1_TX_FIFO_4K (0x00030000) -#define EMAC_M1_TX_FIFO_2K (0x00020000) -#define EMAC_M1_TX_FIFO_1K (0x00010000) -#define EMAC_M1_TR_MULTI (0x00008000) /* 0'x for single packet */ -#define EMAC_M1_MWSW (0x00007000) -#define EMAC_M1_JUMBO_ENABLE (0x00000800) -#define EMAC_M1_IPPA (0x000007c0) -#define EMAC_M1_IPPA_SET(id) (((id) & 0x1f) << 6) -#define EMAC_M1_IPPA_GET(id) (((id) >> 6) & 0x1f) -#define EMAC_M1_OBCI_GT100 (0x00000020) -#define EMAC_M1_OBCI_100 (0x00000018) -#define EMAC_M1_OBCI_83 (0x00000010) -#define EMAC_M1_OBCI_66 (0x00000008) -#define EMAC_M1_RSVD1 (0x00000007) +#define EMAC_MR1_FDE (0x80000000) +#define EMAC_MR1_ILE (0x40000000) +#define EMAC_MR1_VLE (0x20000000) +#define EMAC_MR1_EIFC (0x10000000) +#define EMAC_MR1_APP (0x08000000) +#define EMAC_MR1_RSVD (0x06000000) +#define EMAC_MR1_IST (0x01000000) +#define EMAC_MR1_MF_1000GPCS (0x00C00000) +#define EMAC_MR1_MF_1000MBPS (0x00800000) /* 0's for 10MBPS */ +#define EMAC_MR1_MF_100MBPS (0x00400000) +#define EMAC_MR1_RFS_MASK (0x00380000) +#define EMAC_MR1_RFS_16K (0x00280000) +#define EMAC_MR1_RFS_8K (0x00200000) +#define EMAC_MR1_RFS_4K (0x00180000) +#define EMAC_MR1_RFS_2K (0x00100000) +#define EMAC_MR1_RFS_1K (0x00080000) +#define EMAC_MR1_TX_FIFO_MASK (0x00070000) +#define EMAC_MR1_TX_FIFO_16K (0x00050000) +#define EMAC_MR1_TX_FIFO_8K (0x00040000) +#define EMAC_MR1_TX_FIFO_4K (0x00030000) +#define EMAC_MR1_TX_FIFO_2K (0x00020000) +#define EMAC_MR1_TX_FIFO_1K (0x00010000) +#define EMAC_MR1_TR_MULTI (0x00008000) /* 0'x for single packet */ +#define EMAC_MR1_MWSW (0x00007000) +#define EMAC_MR1_JUMBO_ENABLE (0x00000800) +#define EMAC_MR1_IPPA (0x000007c0) +#define EMAC_MR1_IPPA_SET(id) (((id) & 0x1f) << 6) +#define EMAC_MR1_IPPA_GET(id) (((id) >> 6) & 0x1f) +#define EMAC_MR1_OBCI_GT100 (0x00000020) +#define EMAC_MR1_OBCI_100 (0x00000018) +#define EMAC_MR1_OBCI_83 (0x00000010) +#define EMAC_MR1_OBCI_66 (0x00000008) +#define EMAC_MR1_RSVD1 (0x00000007) #else /* defined(CONFIG_440GX) */ /* EMAC_MR1 is the same on 405GP, 405GPr, 405EP, 440GP, 440EP */ -#define EMAC_M1_FDE 0x80000000 -#define EMAC_M1_ILE 0x40000000 -#define EMAC_M1_VLE 0x20000000 -#define EMAC_M1_EIFC 0x10000000 -#define EMAC_M1_APP 0x08000000 -#define EMAC_M1_AEMI 0x02000000 -#define EMAC_M1_IST 0x01000000 -#define EMAC_M1_MF_1000MBPS 0x00800000 /* 0's for 10MBPS */ -#define EMAC_M1_MF_100MBPS 0x00400000 -#define EMAC_M1_RFS_MASK 0x00300000 -#define EMAC_M1_RFS_4K 0x00300000 -#define EMAC_M1_RFS_2K 0x00200000 -#define EMAC_M1_RFS_1K 0x00100000 -#define EMAC_M1_RFS_512 0x00000000 -#define EMAC_M1_TX_FIFO_MASK 0x000c0000 -#define EMAC_M1_TX_FIFO_2K 0x00080000 -#define EMAC_M1_TX_FIFO_1K 0x00040000 -#define EMAC_M1_TX_FIFO_512 0x00000000 -#define EMAC_M1_TR0_DEPEND 0x00010000 /* 0'x for single packet */ -#define EMAC_M1_TR0_MULTI 0x00008000 -#define EMAC_M1_TR1_DEPEND 0x00004000 -#define EMAC_M1_TR1_MULTI 0x00002000 +#define EMAC_MR1_FDE 0x80000000 +#define EMAC_MR1_ILE 0x40000000 +#define EMAC_MR1_VLE 0x20000000 +#define EMAC_MR1_EIFC 0x10000000 +#define EMAC_MR1_APP 0x08000000 +#define EMAC_MR1_AEMI 0x02000000 +#define EMAC_MR1_IST 0x01000000 +#define EMAC_MR1_MF_1000MBPS 0x00800000 /* 0's for 10MBPS */ +#define EMAC_MR1_MF_100MBPS 0x00400000 +#define EMAC_MR1_RFS_MASK 0x00300000 +#define EMAC_MR1_RFS_4K 0x00300000 +#define EMAC_MR1_RFS_2K 0x00200000 +#define EMAC_MR1_RFS_1K 0x00100000 +#define EMAC_MR1_RFS_512 0x00000000 +#define EMAC_MR1_TX_FIFO_MASK 0x000c0000 +#define EMAC_MR1_TX_FIFO_2K 0x00080000 +#define EMAC_MR1_TX_FIFO_1K 0x00040000 +#define EMAC_MR1_TX_FIFO_512 0x00000000 +#define EMAC_MR1_TR0_DEPEND 0x00010000 /* 0'x for single packet */ +#define EMAC_MR1_TR0_MULTI 0x00008000 +#define EMAC_MR1_TR1_DEPEND 0x00004000 +#define EMAC_MR1_TR1_MULTI 0x00002000 #if defined(CONFIG_440EP) || defined(CONFIG_440GR) -#define EMAC_M1_JUMBO_ENABLE 0x00001000 +#define EMAC_MR1_JUMBO_ENABLE 0x00001000 #endif /* defined(CONFIG_440EP) || defined(CONFIG_440GR) */ #endif /* defined(CONFIG_440GX) */
-#define EMAC_MR1_FIFO_MASK (EMAC_M1_RFS_MASK | EMAC_M1_TX_FIFO_MASK) +#define EMAC_MR1_FIFO_MASK (EMAC_MR1_RFS_MASK | EMAC_MR1_TX_FIFO_MASK) #if defined(CONFIG_405EZ) /* 405EZ only supports 512 bytes fifos */ -#define EMAC_MR1_FIFO_SIZE (EMAC_M1_RFS_512 | EMAC_M1_TX_FIFO_512) +#define EMAC_MR1_FIFO_SIZE (EMAC_MR1_RFS_512 | EMAC_MR1_TX_FIFO_512) #else /* Set receive fifo to 4k and tx fifo to 2k */ -#define EMAC_MR1_FIFO_SIZE (EMAC_M1_RFS_4K | EMAC_M1_TX_FIFO_2K) +#define EMAC_MR1_FIFO_SIZE (EMAC_MR1_RFS_4K | EMAC_MR1_TX_FIFO_2K) #endif
/* Transmit Mode Register 0 */ -#define EMAC_TXM0_GNP0 (0x80000000) -#define EMAC_TXM0_GNP1 (0x40000000) -#define EMAC_TXM0_GNPD (0x20000000) -#define EMAC_TXM0_FC (0x10000000) +#define EMAC_TMR0_GNP0 (0x80000000) +#define EMAC_TMR0_GNP1 (0x40000000) +#define EMAC_TMR0_GNPD (0x20000000) +#define EMAC_TMR0_FC (0x10000000)
/* Receive Mode Register */ #define EMAC_RMR_SP (0x80000000)
Modify all existing *.c files to use the new register names as seen in the AMCC manuals.
Signed-off-by: Niklaus Giger niklaus.giger@member.fsf.org --- board/amcc/bamboo/bamboo.c | 32 +++++----- board/amcc/canyonlands/canyonlands.c | 22 +++--- board/amcc/ebony/ebony.c | 22 +++--- board/amcc/katmai/katmai.c | 22 +++--- board/amcc/luan/epld.h | 22 +++--- board/amcc/luan/luan.c | 22 +++--- board/amcc/ocotea/ocotea.c | 22 +++--- board/amcc/sequoia/sequoia.c | 28 ++++---- board/amcc/taishan/showinfo.c | 112 ++++++++++++++++---------------- board/amcc/taishan/taishan.c | 22 +++--- board/amcc/yosemite/yosemite.c | 32 +++++----- board/amcc/yucca/yucca.c | 22 +++--- board/esd/common/cmd_loadpci.c | 2 +- board/esd/du440/du440.c | 28 ++++---- board/esd/pmc440/cmd_pmc440.c | 10 ++-- board/esd/pmc440/pmc440.c | 32 +++++----- board/exbitgen/init.S | 4 +- board/gdsys/gdppc440etx/gdppc440etx.c | 32 +++++----- board/gdsys/intip/intip.c | 22 +++--- board/korat/korat.c | 28 ++++---- board/lwmon5/lwmon5.c | 32 +++++----- board/netstal/hcu5/hcu5.c | 28 ++++---- board/pcs440ep/pcs440ep.c | 32 +++++----- board/prodrive/alpr/alpr.c | 52 ++++++++-------- board/prodrive/p3p440/p3p440.c | 22 +++--- board/sandburst/common/ppc440gx_i2c.h | 2 +- board/sandburst/common/sb_common.c | 22 +++--- board/xes/xpedite1000/xpedite1000.c | 24 ++++---- cpu/ppc4xx/4xx_pci.c | 48 +++++++------- cpu/ppc4xx/cpu_init.c | 4 +- cpu/ppc4xx/miiphy.c | 24 ++++---- cpu/ppc4xx/speed.c | 6 +- drivers/net/4xx_enet.c | 100 +++++++++++++++--------------- post/cpu/ppc4xx/ether.c | 50 +++++++------- 34 files changed, 492 insertions(+), 492 deletions(-)
diff --git a/board/amcc/bamboo/bamboo.c b/board/amcc/bamboo/bamboo.c index 38186a5..2598f2c 100644 --- a/board/amcc/bamboo/bamboo.c +++ b/board/amcc/bamboo/bamboo.c @@ -542,22 +542,22 @@ void pci_target_init(struct pci_controller *hose) | Use byte reversed out routines to handle endianess. | Make this region non-prefetchable. +--------------------------------------------------------------------------*/ - out32r(PCIX0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ - out32r(PCIX0_PMM0LA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 Local Address */ - out32r(PCIX0_PMM0PCILA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 PCI Low Address */ - out32r(PCIX0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ - out32r(PCIX0_PMM0MA, 0xE0000001); /* 512M + No prefetching, and enable region */ - - out32r(PCIX0_PMM1MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ - out32r(PCIX0_PMM1LA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 Local Address */ - out32r(PCIX0_PMM1PCILA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 PCI Low Address */ - out32r(PCIX0_PMM1PCIHA, 0x00000000); /* PMM0 PCI High Address */ - out32r(PCIX0_PMM1MA, 0xE0000001); /* 512M + No prefetching, and enable region */ - - out32r(PCIX0_PTM1MS, 0x00000001); /* Memory Size/Attribute */ - out32r(PCIX0_PTM1LA, 0); /* Local Addr. Reg */ - out32r(PCIX0_PTM2MS, 0); /* Memory Size/Attribute */ - out32r(PCIX0_PTM2LA, 0); /* Local Addr. Reg */ + out32r(PCIL0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ + out32r(PCIL0_PMM0LA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 Local Address */ + out32r(PCIL0_PMM0PCILA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 PCI Low Address */ + out32r(PCIL0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIL0_PMM0MA, 0xE0000001); /* 512M + No prefetching, and enable region */ + + out32r(PCIL0_PMM1MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ + out32r(PCIL0_PMM1LA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 Local Address */ + out32r(PCIL0_PMM1PCILA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 PCI Low Address */ + out32r(PCIL0_PMM1PCIHA, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIL0_PMM1MA, 0xE0000001); /* 512M + No prefetching, and enable region */ + + out32r(PCIL0_PTM1MS, 0x00000001); /* Memory Size/Attribute */ + out32r(PCIL0_PTM1LA, 0); /* Local Addr. Reg */ + out32r(PCIL0_PTM2MS, 0); /* Memory Size/Attribute */ + out32r(PCIL0_PTM2LA, 0); /* Local Addr. Reg */
/*--------------------------------------------------------------------------+ * Set up Configuration registers diff --git a/board/amcc/canyonlands/canyonlands.c b/board/amcc/canyonlands/canyonlands.c index f359d23..d96d2fd 100644 --- a/board/amcc/canyonlands/canyonlands.c +++ b/board/amcc/canyonlands/canyonlands.c @@ -338,27 +338,27 @@ void pci_target_init(struct pci_controller * hose ) /* * Disable everything */ - out_le32((void *)PCIX0_PIM0SA, 0); /* disable */ - out_le32((void *)PCIX0_PIM1SA, 0); /* disable */ - out_le32((void *)PCIX0_PIM2SA, 0); /* disable */ - out_le32((void *)PCIX0_EROMBA, 0); /* disable expansion rom */ + out_le32((void *)PCIL0_PIM0SA, 0); /* disable */ + out_le32((void *)PCIL0_PIM1SA, 0); /* disable */ + out_le32((void *)PCIL0_PIM2SA, 0); /* disable */ + out_le32((void *)PCIL0_EROMBA, 0); /* disable expansion rom */
/* * Map all of SDRAM to PCI address 0x0000_0000. Note that the 440 * strapping options to not support sizes such as 128/256 MB. */ - out_le32((void *)PCIX0_PIM0LAL, CONFIG_SYS_SDRAM_BASE); - out_le32((void *)PCIX0_PIM0LAH, 0); - out_le32((void *)PCIX0_PIM0SA, ~(gd->ram_size - 1) | 1); - out_le32((void *)PCIX0_BAR0, 0); + out_le32((void *)PCIL0_PIM0LAL, CONFIG_SYS_SDRAM_BASE); + out_le32((void *)PCIL0_PIM0LAH, 0); + out_le32((void *)PCIL0_PIM0SA, ~(gd->ram_size - 1) | 1); + out_le32((void *)PCIL0_BAR0, 0);
/* * Program the board's subsystem id/vendor id */ - out_le16((void *)PCIX0_SBSYSVID, CONFIG_SYS_PCI_SUBSYS_VENDORID); - out_le16((void *)PCIX0_SBSYSID, CONFIG_SYS_PCI_SUBSYS_DEVICEID); + out_le16((void *)PCIL0_SBSYSVID, CONFIG_SYS_PCI_SUBSYS_VENDORID); + out_le16((void *)PCIL0_SBSYSID, CONFIG_SYS_PCI_SUBSYS_DEVICEID);
- out_le16((void *)PCIX0_CMD, in16r(PCIX0_CMD) | PCI_COMMAND_MEMORY); + out_le16((void *)PCIL0_CMD, in16r(PCIL0_CMD) | PCI_COMMAND_MEMORY); } #endif /* defined(CONFIG_PCI) && defined(CONFIG_SYS_PCI_TARGET_INIT) */
diff --git a/board/amcc/ebony/ebony.c b/board/amcc/ebony/ebony.c index e61b5de..0ca1acc 100644 --- a/board/amcc/ebony/ebony.c +++ b/board/amcc/ebony/ebony.c @@ -210,28 +210,28 @@ void pci_target_init(struct pci_controller *hose) /*--------------------------------------------------------------------------+ * Disable everything *--------------------------------------------------------------------------*/ - out32r(PCIX0_PIM0SA, 0); /* disable */ - out32r(PCIX0_PIM1SA, 0); /* disable */ - out32r(PCIX0_PIM2SA, 0); /* disable */ - out32r(PCIX0_EROMBA, 0); /* disable expansion rom */ + out32r(PCIL0_PIM0SA, 0); /* disable */ + out32r(PCIL0_PIM1SA, 0); /* disable */ + out32r(PCIL0_PIM2SA, 0); /* disable */ + out32r(PCIL0_EROMBA, 0); /* disable expansion rom */
/*--------------------------------------------------------------------------+ * Map all of SDRAM to PCI address 0x0000_0000. Note that the 440 strapping * options to not support sizes such as 128/256 MB. *--------------------------------------------------------------------------*/ - out32r(PCIX0_PIM0LAL, CONFIG_SYS_SDRAM_BASE); - out32r(PCIX0_PIM0LAH, 0); - out32r(PCIX0_PIM0SA, ~(gd->ram_size - 1) | 1); + out32r(PCIL0_PIM0LAL, CONFIG_SYS_SDRAM_BASE); + out32r(PCIL0_PIM0LAH, 0); + out32r(PCIL0_PIM0SA, ~(gd->ram_size - 1) | 1);
- out32r(PCIX0_BAR0, 0); + out32r(PCIL0_BAR0, 0);
/*--------------------------------------------------------------------------+ * Program the board's subsystem id/vendor id *--------------------------------------------------------------------------*/ - out16r(PCIX0_SBSYSVID, CONFIG_SYS_PCI_SUBSYS_VENDORID); - out16r(PCIX0_SBSYSID, CONFIG_SYS_PCI_SUBSYS_DEVICEID); + out16r(PCIL0_SBSYSVID, CONFIG_SYS_PCI_SUBSYS_VENDORID); + out16r(PCIL0_SBSYSID, CONFIG_SYS_PCI_SUBSYS_DEVICEID);
- out16r(PCIX0_CMD, in16r(PCIX0_CMD) | PCI_COMMAND_MEMORY); + out16r(PCIL0_CMD, in16r(PCIL0_CMD) | PCI_COMMAND_MEMORY); } #endif /* defined(CONFIG_PCI) && defined(CONFIG_SYS_PCI_TARGET_INIT) */
diff --git a/board/amcc/katmai/katmai.c b/board/amcc/katmai/katmai.c index bcef707..6c54aa2 100644 --- a/board/amcc/katmai/katmai.c +++ b/board/amcc/katmai/katmai.c @@ -304,27 +304,27 @@ void pci_target_init(struct pci_controller * hose ) /*-------------------------------------------------------------------+ * Disable everything *-------------------------------------------------------------------*/ - out32r( PCIX0_PIM0SA, 0 ); /* disable */ - out32r( PCIX0_PIM1SA, 0 ); /* disable */ - out32r( PCIX0_PIM2SA, 0 ); /* disable */ - out32r( PCIX0_EROMBA, 0 ); /* disable expansion rom */ + out32r( PCIL0_PIM0SA, 0 ); /* disable */ + out32r( PCIL0_PIM1SA, 0 ); /* disable */ + out32r( PCIL0_PIM2SA, 0 ); /* disable */ + out32r( PCIL0_EROMBA, 0 ); /* disable expansion rom */
/*-------------------------------------------------------------------+ * Map all of SDRAM to PCI address 0x0000_0000. Note that the 440 * strapping options to not support sizes such as 128/256 MB. *-------------------------------------------------------------------*/ - out32r( PCIX0_PIM0LAL, CONFIG_SYS_SDRAM_BASE ); - out32r( PCIX0_PIM0LAH, 0 ); - out32r( PCIX0_PIM0SA, ~(gd->ram_size - 1) | 1 ); - out32r( PCIX0_BAR0, 0 ); + out32r( PCIL0_PIM0LAL, CONFIG_SYS_SDRAM_BASE ); + out32r( PCIL0_PIM0LAH, 0 ); + out32r( PCIL0_PIM0SA, ~(gd->ram_size - 1) | 1 ); + out32r( PCIL0_BAR0, 0 );
/*-------------------------------------------------------------------+ * Program the board's subsystem id/vendor id *-------------------------------------------------------------------*/ - out16r( PCIX0_SBSYSVID, CONFIG_SYS_PCI_SUBSYS_VENDORID ); - out16r( PCIX0_SBSYSID, CONFIG_SYS_PCI_SUBSYS_DEVICEID ); + out16r( PCIL0_SBSYSVID, CONFIG_SYS_PCI_SUBSYS_VENDORID ); + out16r( PCIL0_SBSYSID, CONFIG_SYS_PCI_SUBSYS_DEVICEID );
- out16r( PCIX0_CMD, in16r(PCIX0_CMD) | PCI_COMMAND_MEMORY ); + out16r( PCIL0_CMD, in16r(PCIL0_CMD) | PCI_COMMAND_MEMORY ); } #endif /* defined(CONFIG_PCI) && defined(CONFIG_SYS_PCI_TARGET_INIT) */
diff --git a/board/amcc/luan/epld.h b/board/amcc/luan/epld.h index 05362e0..569d78c 100644 --- a/board/amcc/luan/epld.h +++ b/board/amcc/luan/epld.h @@ -8,8 +8,8 @@ #define EPLD0_FLASH_SRAM_SEL_N 0x01 /* 0 SRAM at mem top, 1 small flash at mem top */
#define EPLD1_CLK_CNTL0 0x80 /* FSEL-FB1 of MPC9772 */ -#define EPLD1_PCIX0_CNTL1 0x40 /* S*0 of 9531 */ -#define EPLD1_PCIX0_CNTL2 0x20 /* S*1 of 9531 */ +#define EPLD1_PCIL0_CNTL1 0x40 /* S*0 of 9531 */ +#define EPLD1_PCIL0_CNTL2 0x20 /* S*1 of 9531 */ #define EPLD1_CLK_CNTL3 0x10 /* FSEL-B1 of MPC9772 */ #define EPLD1_CLK_CNTL4 0x08 /* FSEL-B0 of MPC9772 */ #define EPLD1_MASTER_CLOCK6 0x04 /* clock source select 6 */ @@ -29,25 +29,25 @@ #define EPLD3_STATUS_LED2 0x02 /* status LED 2 (1 = LED on) */ #define EPLD3_STATUS_LED1 0x01 /* status LED 1 (1 = LED on) */
-#define EPLD4_PCIX0_VTH1 0x80 /* PCI-X 0 VTH1 status */ -#define EPLD4_PCIX0_VTH2 0x40 /* PCI-X 0 VTH2 status */ -#define EPLD4_PCIX0_VTH3 0x20 /* PCI-X 0 VTH3 status */ -#define EPLD4_PCIX0_VTH4 0x10 /* PCI-X 0 VTH4 status */ +#define EPLD4_PCIL0_VTH1 0x80 /* PCI-X 0 VTH1 status */ +#define EPLD4_PCIL0_VTH2 0x40 /* PCI-X 0 VTH2 status */ +#define EPLD4_PCIL0_VTH3 0x20 /* PCI-X 0 VTH3 status */ +#define EPLD4_PCIL0_VTH4 0x10 /* PCI-X 0 VTH4 status */ #define EPLD4_PCIX1_VTH1 0x08 /* PCI-X 1 VTH1 status */ #define EPLD4_PCIX1_VTH2 0x04 /* PCI-X 1 VTH2 status */ #define EPLD4_PCIX1_VTH3 0x02 /* PCI-X 1 VTH3 status */ #define EPLD4_PCIX1_VTH4 0x01 /* PCI-X 1 VTH4 status */
-#define EPLD5_PCIX0_INT0 0x80 /* PCIX0 INT0 status, write 0 to reset */ -#define EPLD5_PCIX0_INT1 0x40 /* PCIX0 INT1 status, write 0 to reset */ -#define EPLD5_PCIX0_INT2 0x20 /* PCIX0 INT2 status, write 0 to reset */ -#define EPLD5_PCIX0_INT3 0x10 /* PCIX0 INT3 status, write 0 to reset */ +#define EPLD5_PCIL0_INT0 0x80 /* PCIX0 INT0 status, write 0 to reset */ +#define EPLD5_PCIL0_INT1 0x40 /* PCIX0 INT1 status, write 0 to reset */ +#define EPLD5_PCIL0_INT2 0x20 /* PCIX0 INT2 status, write 0 to reset */ +#define EPLD5_PCIL0_INT3 0x10 /* PCIX0 INT3 status, write 0 to reset */ #define EPLD5_PCIX1_INT0 0x08 /* PCIX1 INT0 status, write 0 to reset */ #define EPLD5_PCIX1_INT1 0x04 /* PCIX1 INT1 status, write 0 to reset */ #define EPLD5_PCIX1_INT2 0x02 /* PCIX1 INT2 status, write 0 to reset */ #define EPLD5_PCIX1_INT3 0x01 /* PCIX1 INT3 status, write 0 to reset */
-#define EPLD6_PCIX0_RESET_CTL 0x80 /* 0=enable slot reset, 1=disable slot reset */ +#define EPLD6_PCIL0_RESET_CTL 0x80 /* 0=enable slot reset, 1=disable slot reset */ #define EPLD6_PCIX1_RESET_CTL 0x40 /* 0=enable slot reset, 1=disable slot reset */ #define EPLD6_ETH_INT_MODE 0x20 /* 0=IRQ5 recv's external eth int */ #define EPLD6_PCIX2_RESET_CTL 0x10 /* 0=enable slot reset, 1=disable slot reset */ diff --git a/board/amcc/luan/luan.c b/board/amcc/luan/luan.c index 5f76672..a04f2af 100644 --- a/board/amcc/luan/luan.c +++ b/board/amcc/luan/luan.c @@ -173,28 +173,28 @@ void pci_target_init(struct pci_controller *hose) /*--------------------------------------------------------------------------+ * Disable everything *--------------------------------------------------------------------------*/ - out32r( PCIX0_PIM0SA, 0 ); /* disable */ - out32r( PCIX0_PIM1SA, 0 ); /* disable */ - out32r( PCIX0_PIM2SA, 0 ); /* disable */ - out32r( PCIX0_EROMBA, 0 ); /* disable expansion rom */ + out32r( PCIL0_PIM0SA, 0 ); /* disable */ + out32r( PCIL0_PIM1SA, 0 ); /* disable */ + out32r( PCIL0_PIM2SA, 0 ); /* disable */ + out32r( PCIL0_EROMBA, 0 ); /* disable expansion rom */
/*--------------------------------------------------------------------------+ * Map all of SDRAM to PCI address 0x0000_0000. Note that the 440 strapping * options to not support sizes such as 128/256 MB. *--------------------------------------------------------------------------*/ - out32r( PCIX0_PIM0LAL, CONFIG_SYS_SDRAM_BASE ); - out32r( PCIX0_PIM0LAH, 0 ); - out32r( PCIX0_PIM0SA, ~(gd->ram_size - 1) | 1 ); + out32r( PCIL0_PIM0LAL, CONFIG_SYS_SDRAM_BASE ); + out32r( PCIL0_PIM0LAH, 0 ); + out32r( PCIL0_PIM0SA, ~(gd->ram_size - 1) | 1 );
- out32r( PCIX0_BAR0, 0 ); + out32r( PCIL0_BAR0, 0 );
/*--------------------------------------------------------------------------+ * Program the board's subsystem id/vendor id *--------------------------------------------------------------------------*/ - out16r( PCIX0_SBSYSVID, CONFIG_SYS_PCI_SUBSYS_VENDORID ); - out16r( PCIX0_SBSYSID, CONFIG_SYS_PCI_SUBSYS_DEVICEID ); + out16r( PCIL0_SBSYSVID, CONFIG_SYS_PCI_SUBSYS_VENDORID ); + out16r( PCIL0_SBSYSID, CONFIG_SYS_PCI_SUBSYS_DEVICEID );
diff --git a/board/amcc/ocotea/ocotea.c b/board/amcc/ocotea/ocotea.c index d776eda..0aa317e 100644 --- a/board/amcc/ocotea/ocotea.c +++ b/board/amcc/ocotea/ocotea.c @@ -321,28 +321,28 @@ void pci_target_init(struct pci_controller * hose ) /*--------------------------------------------------------------------------+ * Disable everything *--------------------------------------------------------------------------*/ - out32r( PCIX0_PIM0SA, 0 ); /* disable */ - out32r( PCIX0_PIM1SA, 0 ); /* disable */ - out32r( PCIX0_PIM2SA, 0 ); /* disable */ - out32r( PCIX0_EROMBA, 0 ); /* disable expansion rom */ + out32r( PCIL0_PIM0SA, 0 ); /* disable */ + out32r( PCIL0_PIM1SA, 0 ); /* disable */ + out32r( PCIL0_PIM2SA, 0 ); /* disable */ + out32r( PCIL0_EROMBA, 0 ); /* disable expansion rom */
diff --git a/board/amcc/sequoia/sequoia.c b/board/amcc/sequoia/sequoia.c index 17f831c..d42c802 100644 --- a/board/amcc/sequoia/sequoia.c +++ b/board/amcc/sequoia/sequoia.c @@ -428,26 +428,26 @@ void pci_target_init(struct pci_controller *hose) * Use byte reversed out routines to handle endianess. * Make this region non-prefetchable. */ - out32r(PCIX0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute */ + out32r(PCIL0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute */ /* - disabled b4 setting */ - out32r(PCIX0_PMM0LA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 Local Address */ - out32r(PCIX0_PMM0PCILA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 PCI Low Address */ - out32r(PCIX0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ - out32r(PCIX0_PMM0MA, 0xE0000001); /* 512M + No prefetching, */ + out32r(PCIL0_PMM0LA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 Local Address */ + out32r(PCIL0_PMM0PCILA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 PCI Low Address */ + out32r(PCIL0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIL0_PMM0MA, 0xE0000001); /* 512M + No prefetching, */ /* and enable region */
- out32r(PCIX0_PMM1MA, 0x00000000); /* PMM0 Mask/Attribute */ + out32r(PCIL0_PMM1MA, 0x00000000); /* PMM0 Mask/Attribute */ /* - disabled b4 setting */ - out32r(PCIX0_PMM1LA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 Local Address */ - out32r(PCIX0_PMM1PCILA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 PCI Low Address */ - out32r(PCIX0_PMM1PCIHA, 0x00000000); /* PMM0 PCI High Address */ - out32r(PCIX0_PMM1MA, 0xE0000001); /* 512M + No prefetching, */ + out32r(PCIL0_PMM1LA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 Local Address */ + out32r(PCIL0_PMM1PCILA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 PCI Low Address */ + out32r(PCIL0_PMM1PCIHA, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIL0_PMM1MA, 0xE0000001); /* 512M + No prefetching, */ /* and enable region */
- out32r(PCIX0_PTM1MS, 0x00000001); /* Memory Size/Attribute */ - out32r(PCIX0_PTM1LA, 0); /* Local Addr. Reg */ - out32r(PCIX0_PTM2MS, 0); /* Memory Size/Attribute */ - out32r(PCIX0_PTM2LA, 0); /* Local Addr. Reg */ + out32r(PCIL0_PTM1MS, 0x00000001); /* Memory Size/Attribute */ + out32r(PCIL0_PTM1LA, 0); /* Local Addr. Reg */ + out32r(PCIL0_PTM2MS, 0); /* Memory Size/Attribute */ + out32r(PCIL0_PTM2LA, 0); /* Local Addr. Reg */
/* * Set up Configuration registers diff --git a/board/amcc/taishan/showinfo.c b/board/amcc/taishan/showinfo.c index e4e441b..a9a80e5 100644 --- a/board/amcc/taishan/showinfo.c +++ b/board/amcc/taishan/showinfo.c @@ -39,13 +39,13 @@ void show_reset_reg(void) mfcpr(CPR0_PLLD,reg); printf("cpr_plld = %#010lx\n",reg);
- mfcpr(CPR0_PRIMAD,reg); + mfcpr(CPR0_PRIMAD0,reg); printf("cpr_primad = %#010lx\n",reg);
- mfcpr(CPR0_PRIMBD,reg); + mfcpr(CPR0_PRIMBD0,reg); printf("cpr_primbd = %#010lx\n",reg);
- mfcpr(CPR0_OPBD,reg); + mfcpr(CPR0_OPBD0,reg); printf("cpr_opbd = %#010lx\n",reg);
mfcpr(CPR0_PERD,reg); @@ -106,59 +106,59 @@ void show_xbridge_info(void) printf("SDR0_XPLLD = %#010lx\n", reg);
printf("PCI-X Bridge Configure registers\n"); - printf("PCIX0_VENDID = %#06x\n", in16r(PCIX0_VENDID)); - printf("PCIX0_DEVID = %#06x\n", in16r(PCIX0_DEVID)); - printf("PCIX0_CMD = %#06x\n", in16r(PCIX0_CMD)); - printf("PCIX0_STATUS = %#06x\n", in16r(PCIX0_STATUS)); - printf("PCIX0_REVID = %#04x\n", in8(PCIX0_REVID)); - printf("PCIX0_CACHELS = %#04x\n", in8(PCIX0_CACHELS)); - printf("PCIX0_LATTIM = %#04x\n", in8(PCIX0_LATTIM)); - printf("PCIX0_HDTYPE = %#04x\n", in8(PCIX0_HDTYPE)); - printf("PCIX0_BIST = %#04x\n", in8(PCIX0_BIST)); - - printf("PCIX0_BAR0 = %#010lx\n", in32r(PCIX0_BAR0)); - printf("PCIX0_BAR1 = %#010lx\n", in32r(PCIX0_BAR1)); - printf("PCIX0_BAR2 = %#010lx\n", in32r(PCIX0_BAR2)); - printf("PCIX0_BAR3 = %#010lx\n", in32r(PCIX0_BAR3)); - printf("PCIX0_BAR4 = %#010lx\n", in32r(PCIX0_BAR4)); - printf("PCIX0_BAR5 = %#010lx\n", in32r(PCIX0_BAR5)); - - printf("PCIX0_CISPTR = %#010lx\n", in32r(PCIX0_CISPTR)); - printf("PCIX0_SBSSYSVID = %#010x\n", in16r(PCIX0_SBSYSVID)); - printf("PCIX0_SBSSYSID = %#010x\n", in16r(PCIX0_SBSYSID)); - printf("PCIX0_EROMBA = %#010lx\n", in32r(PCIX0_EROMBA)); - printf("PCIX0_CAP = %#04x\n", in8(PCIX0_CAP)); - printf("PCIX0_INTLN = %#04x\n", in8(PCIX0_INTLN)); - printf("PCIX0_INTPN = %#04x\n", in8(PCIX0_INTPN)); - printf("PCIX0_MINGNT = %#04x\n", in8(PCIX0_MINGNT)); - printf("PCIX0_MAXLTNCY = %#04x\n", in8(PCIX0_MAXLTNCY)); - - printf("PCIX0_BRDGOPT1 = %#010lx\n", in32r(PCIX0_BRDGOPT1)); - printf("PCIX0_BRDGOPT2 = %#010lx\n", in32r(PCIX0_BRDGOPT2)); - - printf("PCIX0_POM0LAL = %#010lx\n", in32r(PCIX0_POM0LAL)); - printf("PCIX0_POM0LAH = %#010lx\n", in32r(PCIX0_POM0LAH)); - printf("PCIX0_POM0SA = %#010lx\n", in32r(PCIX0_POM0SA)); - printf("PCIX0_POM0PCILAL = %#010lx\n", in32r(PCIX0_POM0PCIAL)); - printf("PCIX0_POM0PCILAH = %#010lx\n", in32r(PCIX0_POM0PCIAH)); - printf("PCIX0_POM1LAL = %#010lx\n", in32r(PCIX0_POM1LAL)); - printf("PCIX0_POM1LAH = %#010lx\n", in32r(PCIX0_POM1LAH)); - printf("PCIX0_POM1SA = %#010lx\n", in32r(PCIX0_POM1SA)); - printf("PCIX0_POM1PCILAL = %#010lx\n", in32r(PCIX0_POM1PCIAL)); - printf("PCIX0_POM1PCILAH = %#010lx\n", in32r(PCIX0_POM1PCIAH)); - printf("PCIX0_POM2SA = %#010lx\n", in32r(PCIX0_POM2SA)); - - printf("PCIX0_PIM0SA = %#010lx\n", in32r(PCIX0_PIM0SA)); - printf("PCIX0_PIM0LAL = %#010lx\n", in32r(PCIX0_PIM0LAL)); - printf("PCIX0_PIM0LAH = %#010lx\n", in32r(PCIX0_PIM0LAH)); - printf("PCIX0_PIM1SA = %#010lx\n", in32r(PCIX0_PIM1SA)); - printf("PCIX0_PIM1LAL = %#010lx\n", in32r(PCIX0_PIM1LAL)); - printf("PCIX0_PIM1LAH = %#010lx\n", in32r(PCIX0_PIM1LAH)); - printf("PCIX0_PIM2SA = %#010lx\n", in32r(PCIX0_PIM1SA)); - printf("PCIX0_PIM2LAL = %#010lx\n", in32r(PCIX0_PIM1LAL)); - printf("PCIX0_PIM2LAH = %#010lx\n", in32r(PCIX0_PIM1LAH)); - - printf("PCIX0_XSTS = %#010lx\n", in32r(PCIX0_STS)); + printf("PCIL0_VENDID = %#06x\n", in16r(PCIL0_VENDID)); + printf("PCIL0_DEVID = %#06x\n", in16r(PCIL0_DEVID)); + printf("PCIL0_CMD = %#06x\n", in16r(PCIL0_CMD)); + printf("PCIL0_STATUS = %#06x\n", in16r(PCIL0_STATUS)); + printf("PCIL0_REVID = %#04x\n", in8(PCIL0_REVID)); + printf("PCIL0_CACHELS = %#04x\n", in8(PCIL0_CACHELS)); + printf("PCIL0_LATTIM = %#04x\n", in8(PCIL0_LATTIM)); + printf("PCIL0_HDTYPE = %#04x\n", in8(PCIL0_HDTYPE)); + printf("PCIL0_BIST = %#04x\n", in8(PCIL0_BIST)); + + printf("PCIL0_BAR0 = %#010lx\n", in32r(PCIL0_BAR0)); + printf("PCIL0_BAR1 = %#010lx\n", in32r(PCIL0_BAR1)); + printf("PCIL0_BAR2 = %#010lx\n", in32r(PCIL0_BAR2)); + printf("PCIL0_BAR3 = %#010lx\n", in32r(PCIL0_BAR3)); + printf("PCIL0_BAR4 = %#010lx\n", in32r(PCIL0_BAR4)); + printf("PCIL0_BAR5 = %#010lx\n", in32r(PCIL0_BAR5)); + + printf("PCIL0_CISPTR = %#010lx\n", in32r(PCIL0_CISPTR)); + printf("PCIL0_SBSSYSVID = %#010x\n", in16r(PCIL0_SBSYSVID)); + printf("PCIL0_SBSSYSID = %#010x\n", in16r(PCIL0_SBSYSID)); + printf("PCIL0_EROMBA = %#010lx\n", in32r(PCIL0_EROMBA)); + printf("PCIL0_CAP = %#04x\n", in8(PCIL0_CAP)); + printf("PCIL0_INTLN = %#04x\n", in8(PCIL0_INTLN)); + printf("PCIL0_INTPN = %#04x\n", in8(PCIL0_INTPN)); + printf("PCIL0_MINGNT = %#04x\n", in8(PCIL0_MINGNT)); + printf("PCIL0_MAXLTNCY = %#04x\n", in8(PCIL0_MAXLTNCY)); + + printf("PCIL0_BRDGOPT1 = %#010lx\n", in32r(PCIL0_BRDGOPT1)); + printf("PCIL0_BRDGOPT2 = %#010lx\n", in32r(PCIL0_BRDGOPT2)); + + printf("PCIL0_POM0LAL = %#010lx\n", in32r(PCIL0_POM0LAL)); + printf("PCIL0_POM0LAH = %#010lx\n", in32r(PCIL0_POM0LAH)); + printf("PCIL0_POM0SA = %#010lx\n", in32r(PCIL0_POM0SA)); + printf("PCIL0_POM0PCILAL = %#010lx\n", in32r(PCIL0_POM0PCIAL)); + printf("PCIL0_POM0PCILAH = %#010lx\n", in32r(PCIL0_POM0PCIAH)); + printf("PCIL0_POM1LAL = %#010lx\n", in32r(PCIL0_POM1LAL)); + printf("PCIL0_POM1LAH = %#010lx\n", in32r(PCIL0_POM1LAH)); + printf("PCIL0_POM1SA = %#010lx\n", in32r(PCIL0_POM1SA)); + printf("PCIL0_POM1PCILAL = %#010lx\n", in32r(PCIL0_POM1PCIAL)); + printf("PCIL0_POM1PCILAH = %#010lx\n", in32r(PCIL0_POM1PCIAH)); + printf("PCIL0_POM2SA = %#010lx\n", in32r(PCIL0_POM2SA)); + + printf("PCIL0_PIM0SA = %#010lx\n", in32r(PCIL0_PIM0SA)); + printf("PCIL0_PIM0LAL = %#010lx\n", in32r(PCIL0_PIM0LAL)); + printf("PCIL0_PIM0LAH = %#010lx\n", in32r(PCIL0_PIM0LAH)); + printf("PCIL0_PIM1SA = %#010lx\n", in32r(PCIL0_PIM1SA)); + printf("PCIL0_PIM1LAL = %#010lx\n", in32r(PCIL0_PIM1LAL)); + printf("PCIL0_PIM1LAH = %#010lx\n", in32r(PCIL0_PIM1LAH)); + printf("PCIL0_PIM2SA = %#010lx\n", in32r(PCIL0_PIM1SA)); + printf("PCIL0_PIM2LAL = %#010lx\n", in32r(PCIL0_PIM1LAL)); + printf("PCIL0_PIM2LAH = %#010lx\n", in32r(PCIL0_PIM1LAH)); + + printf("PCIL0_XSTS = %#010lx\n", in32r(PCIL0_STS)); }
int do_show_xbridge_info(cmd_tbl_t * cmdtp, int flag, int argc, char *argv[]) diff --git a/board/amcc/taishan/taishan.c b/board/amcc/taishan/taishan.c index 4a0573e..0c20faf 100644 --- a/board/amcc/taishan/taishan.c +++ b/board/amcc/taishan/taishan.c @@ -254,28 +254,28 @@ void pci_target_init(struct pci_controller * hose ) /*--------------------------------------------------------------------------+ * Disable everything *--------------------------------------------------------------------------*/ - out32r( PCIX0_PIM0SA, 0 ); /* disable */ - out32r( PCIX0_PIM1SA, 0 ); /* disable */ - out32r( PCIX0_PIM2SA, 0 ); /* disable */ - out32r( PCIX0_EROMBA, 0 ); /* disable expansion rom */ + out32r( PCIL0_PIM0SA, 0 ); /* disable */ + out32r( PCIL0_PIM1SA, 0 ); /* disable */ + out32r( PCIL0_PIM2SA, 0 ); /* disable */ + out32r( PCIL0_EROMBA, 0 ); /* disable expansion rom */
diff --git a/board/amcc/yosemite/yosemite.c b/board/amcc/yosemite/yosemite.c index 1ec13eb..7ceccfa 100644 --- a/board/amcc/yosemite/yosemite.c +++ b/board/amcc/yosemite/yosemite.c @@ -408,22 +408,22 @@ void pci_target_init(struct pci_controller *hose) | Use byte reversed out routines to handle endianess. | Make this region non-prefetchable. +--------------------------------------------------------------------------*/ - out32r(PCIX0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ - out32r(PCIX0_PMM0LA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 Local Address */ - out32r(PCIX0_PMM0PCILA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 PCI Low Address */ - out32r(PCIX0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ - out32r(PCIX0_PMM0MA, 0xE0000001); /* 512M + No prefetching, and enable region */ - - out32r(PCIX0_PMM1MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ - out32r(PCIX0_PMM1LA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 Local Address */ - out32r(PCIX0_PMM1PCILA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 PCI Low Address */ - out32r(PCIX0_PMM1PCIHA, 0x00000000); /* PMM0 PCI High Address */ - out32r(PCIX0_PMM1MA, 0xE0000001); /* 512M + No prefetching, and enable region */ - - out32r(PCIX0_PTM1MS, 0x00000001); /* Memory Size/Attribute */ - out32r(PCIX0_PTM1LA, 0); /* Local Addr. Reg */ - out32r(PCIX0_PTM2MS, 0); /* Memory Size/Attribute */ - out32r(PCIX0_PTM2LA, 0); /* Local Addr. Reg */ + out32r(PCIL0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ + out32r(PCIL0_PMM0LA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 Local Address */ + out32r(PCIL0_PMM0PCILA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 PCI Low Address */ + out32r(PCIL0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIL0_PMM0MA, 0xE0000001); /* 512M + No prefetching, and enable region */ + + out32r(PCIL0_PMM1MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ + out32r(PCIL0_PMM1LA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 Local Address */ + out32r(PCIL0_PMM1PCILA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 PCI Low Address */ + out32r(PCIL0_PMM1PCIHA, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIL0_PMM1MA, 0xE0000001); /* 512M + No prefetching, and enable region */ + + out32r(PCIL0_PTM1MS, 0x00000001); /* Memory Size/Attribute */ + out32r(PCIL0_PTM1LA, 0); /* Local Addr. Reg */ + out32r(PCIL0_PTM2MS, 0); /* Memory Size/Attribute */ + out32r(PCIL0_PTM2LA, 0); /* Local Addr. Reg */
/*--------------------------------------------------------------------------+ * Set up Configuration registers diff --git a/board/amcc/yucca/yucca.c b/board/amcc/yucca/yucca.c index 033bdd2..150bbcc 100644 --- a/board/amcc/yucca/yucca.c +++ b/board/amcc/yucca/yucca.c @@ -632,27 +632,27 @@ void pci_target_init(struct pci_controller * hose ) /*-------------------------------------------------------------------+ * Disable everything *-------------------------------------------------------------------*/ - out32r( PCIX0_PIM0SA, 0 ); /* disable */ - out32r( PCIX0_PIM1SA, 0 ); /* disable */ - out32r( PCIX0_PIM2SA, 0 ); /* disable */ - out32r( PCIX0_EROMBA, 0 ); /* disable expansion rom */ + out32r( PCIL0_PIM0SA, 0 ); /* disable */ + out32r( PCIL0_PIM1SA, 0 ); /* disable */ + out32r( PCIL0_PIM2SA, 0 ); /* disable */ + out32r( PCIL0_EROMBA, 0 ); /* disable expansion rom */
diff --git a/board/esd/common/cmd_loadpci.c b/board/esd/common/cmd_loadpci.c index 47e946f..eecae0a 100644 --- a/board/esd/common/cmd_loadpci.c +++ b/board/esd/common/cmd_loadpci.c @@ -48,7 +48,7 @@ int do_loadpci(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) u32 la, ptm1la;
#if defined(CONFIG_440) - ptm1la = in32r(PCIX0_PTM1LA); + ptm1la = in32r(PCIL0_PTM1LA); #else ptm1la = in32r(PTM1LA); #endif diff --git a/board/esd/du440/du440.c b/board/esd/du440/du440.c index 056f455..d0e52cb 100644 --- a/board/esd/du440/du440.c +++ b/board/esd/du440/du440.c @@ -435,26 +435,26 @@ void pci_target_init(struct pci_controller *hose) * Use byte reversed out routines to handle endianess. * Make this region non-prefetchable. */ - out32r(PCIX0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute */ + out32r(PCIL0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute */ /* - disabled b4 setting */ - out32r(PCIX0_PMM0LA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 Local Address */ - out32r(PCIX0_PMM0PCILA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 PCI Low Address */ - out32r(PCIX0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ - out32r(PCIX0_PMM0MA, 0xE0000001); /* 512M + No prefetching, */ + out32r(PCIL0_PMM0LA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 Local Address */ + out32r(PCIL0_PMM0PCILA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 PCI Low Address */ + out32r(PCIL0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIL0_PMM0MA, 0xE0000001); /* 512M + No prefetching, */ /* and enable region */
/* * Set up Configuration registers diff --git a/board/esd/pmc440/cmd_pmc440.c b/board/esd/pmc440/cmd_pmc440.c index 1af431b..476e940 100644 --- a/board/esd/pmc440/cmd_pmc440.c +++ b/board/esd/pmc440/cmd_pmc440.c @@ -497,15 +497,15 @@ int do_pmm(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) /* map PCI address at 0xc0000000 in PLB space */
/* PMM1 Mask/Attribute - disabled b4 setting */ - out32r(PCIX0_PMM1MA, 0x00000000); + out32r(PCIL0_PMM1MA, 0x00000000); /* PMM1 Local Address */ - out32r(PCIX0_PMM1LA, 0xc0000000); + out32r(PCIL0_PMM1LA, 0xc0000000); /* PMM1 PCI Low Address */ - out32r(PCIX0_PMM1PCILA, pciaddr); + out32r(PCIL0_PMM1PCILA, pciaddr); /* PMM1 PCI High Address */ - out32r(PCIX0_PMM1PCIHA, 0x00000000); + out32r(PCIL0_PMM1PCIHA, 0x00000000); /* 256MB + No prefetching, and enable region */ - out32r(PCIX0_PMM1MA, 0xf0000001); + out32r(PCIL0_PMM1MA, 0xf0000001); } else { printf("Usage:\npmm %s\n", cmdtp->help); } diff --git a/board/esd/pmc440/pmc440.c b/board/esd/pmc440/pmc440.c index f0f9bff..ec92552 100644 --- a/board/esd/pmc440/pmc440.c +++ b/board/esd/pmc440/pmc440.c @@ -208,7 +208,7 @@ int misc_init_f(void)
if (getenv("pciearly") && (!is_monarch())) { printf("PCI: early target init\n"); - pci_setup_indirect(&hose, PCIX0_CFGADR, PCIX0_CFGDATA); + pci_setup_indirect(&hose, PCIL0_CFGADR, PCIL0_CFGDATA); pci_target_init(&hose); } return 0; @@ -568,42 +568,42 @@ void pci_target_init(struct pci_controller *hose) * Use byte reversed out routines to handle endianess. * Make this region non-prefetchable. */ - out32r(PCIX0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute */ + out32r(PCIL0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute */ /* - disabled b4 setting */ - out32r(PCIX0_PMM0LA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 Local Address */ - out32r(PCIX0_PMM0PCILA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 PCI Low Address */ - out32r(PCIX0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ - out32r(PCIX0_PMM0MA, 0xc0000001); /* 1G + No prefetching, */ + out32r(PCIL0_PMM0LA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 Local Address */ + out32r(PCIL0_PMM0PCILA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 PCI Low Address */ + out32r(PCIL0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIL0_PMM0MA, 0xc0000001); /* 1G + No prefetching, */ /* and enable region */
if (!is_monarch()) { ptmla_str = getenv("ptm1la"); ptmms_str = getenv("ptm1ms"); if(NULL != ptmla_str && NULL != ptmms_str ) { - out32r(PCIX0_PTM1MS, + out32r(PCIL0_PTM1MS, simple_strtoul(ptmms_str, NULL, 16)); - out32r(PCIX0_PTM1LA, + out32r(PCIL0_PTM1LA, simple_strtoul(ptmla_str, NULL, 16)); } else { /* BAR1: default top 64MB of RAM */ - out32r(PCIX0_PTM1MS, 0xfc000001); - out32r(PCIX0_PTM1LA, 0x0c000000); + out32r(PCIL0_PTM1MS, 0xfc000001); + out32r(PCIL0_PTM1LA, 0x0c000000); } } else { /* BAR1: default: complete 256MB RAM */ - out32r(PCIX0_PTM1MS, 0xf0000001); - out32r(PCIX0_PTM1LA, 0x00000000); + out32r(PCIL0_PTM1MS, 0xf0000001); + out32r(PCIL0_PTM1LA, 0x00000000); }
ptmla_str = getenv("ptm2la"); /* Local Addr. Reg */ ptmms_str = getenv("ptm2ms"); /* Memory Size/Attribute */ if(NULL != ptmla_str && NULL != ptmms_str ) { - out32r(PCIX0_PTM2MS, simple_strtoul(ptmms_str, NULL, 16)); - out32r(PCIX0_PTM2LA, simple_strtoul(ptmla_str, NULL, 16)); + out32r(PCIL0_PTM2MS, simple_strtoul(ptmms_str, NULL, 16)); + out32r(PCIL0_PTM2LA, simple_strtoul(ptmla_str, NULL, 16)); } else { /* BAR2: default: 4MB FPGA */ - out32r(PCIX0_PTM2MS, 0xffc00001); /* Memory Size/Attribute */ - out32r(PCIX0_PTM2LA, 0xef000000); /* Local Addr. Reg */ + out32r(PCIL0_PTM2MS, 0xffc00001); /* Memory Size/Attribute */ + out32r(PCIL0_PTM2LA, 0xef000000); /* Local Addr. Reg */ }
if (is_monarch()) { diff --git a/board/exbitgen/init.S b/board/exbitgen/init.S index 7a9726f..721aaac 100644 --- a/board/exbitgen/init.S +++ b/board/exbitgen/init.S @@ -52,7 +52,7 @@ #define IIC_EXTSTS (I2C_REGISTERS_BASE_ADDRESS+IICEXTSTS) #define IIC_LSADR (I2C_REGISTERS_BASE_ADDRESS+IICLSADR) #define IIC_HSADR (I2C_REGISTERS_BASE_ADDRESS+IICHSADR) -#define IIC_CLKDIV (I2C_REGISTERS_BASE_ADDRESS+IICCLKDIV) +#define IIC_CLKDIV (I2C_REGISTERS_BASE_ADDRESS+IIC0_CLKDIV) #define IIC_INTRMSK (I2C_REGISTERS_BASE_ADDRESS+IICINTRMSK) #define IIC_XFRCNT (I2C_REGISTERS_BASE_ADDRESS+IICXFRCNT) #define IIC_XTCNTLSS (I2C_REGISTERS_BASE_ADDRESS+IICXTCNTLSS) @@ -537,7 +537,7 @@ read_spd: WRITE_I2C(IICHSADR, 0x00) /* clear hi slave address */ WRITE_I2C(IICSTS, 0x08) /* update status register */ WRITE_I2C(IICEXTSTS, 0x8f) - WRITE_I2C(IICCLKDIV, 0x05) + WRITE_I2C(IIC0_CLKDIV, 0x05) WRITE_I2C(IICINTRMSK, 0x00) /* no interrupts */ WRITE_I2C(IICXFRCNT, 0x00) /* clear transfer count */ WRITE_I2C(IICXTCNTLSS, 0xf0) /* clear extended control & stat */ diff --git a/board/gdsys/gdppc440etx/gdppc440etx.c b/board/gdsys/gdppc440etx/gdppc440etx.c index 7cc1bf2..90dbe52 100644 --- a/board/gdsys/gdppc440etx/gdppc440etx.c +++ b/board/gdsys/gdppc440etx/gdppc440etx.c @@ -239,22 +239,22 @@ void pci_target_init(struct pci_controller *hose) * Use byte reversed out routines to handle endianess. * Make this region non-prefetchable. */ - out32r(PCIX0_PMM0MA, 0x00000000); /* disabled b4 setting */ - out32r(PCIX0_PMM0LA, CONFIG_SYS_PCI_MEMBASE); - out32r(PCIX0_PMM0PCILA, CONFIG_SYS_PCI_MEMBASE); - out32r(PCIX0_PMM0PCIHA, 0x00000000); - out32r(PCIX0_PMM0MA, 0xE0000001); /* 512M, no prefetch, enable region */ - - out32r(PCIX0_PMM1MA, 0x00000000); /* disabled b4 setting */ - out32r(PCIX0_PMM1LA, CONFIG_SYS_PCI_MEMBASE2); - out32r(PCIX0_PMM1PCILA, CONFIG_SYS_PCI_MEMBASE2); - out32r(PCIX0_PMM1PCIHA, 0x00000000); - out32r(PCIX0_PMM1MA, 0xE0000001); /* 512M, no prefetch, enable region */ - - out32r(PCIX0_PTM1MS, 0x00000001); - out32r(PCIX0_PTM1LA, 0); - out32r(PCIX0_PTM2MS, 0); - out32r(PCIX0_PTM2LA, 0); + out32r(PCIL0_PMM0MA, 0x00000000); /* disabled b4 setting */ + out32r(PCIL0_PMM0LA, CONFIG_SYS_PCI_MEMBASE); + out32r(PCIL0_PMM0PCILA, CONFIG_SYS_PCI_MEMBASE); + out32r(PCIL0_PMM0PCIHA, 0x00000000); + out32r(PCIL0_PMM0MA, 0xE0000001); /* 512M, no prefetch, enable region */ + + out32r(PCIL0_PMM1MA, 0x00000000); /* disabled b4 setting */ + out32r(PCIL0_PMM1LA, CONFIG_SYS_PCI_MEMBASE2); + out32r(PCIL0_PMM1PCILA, CONFIG_SYS_PCI_MEMBASE2); + out32r(PCIL0_PMM1PCIHA, 0x00000000); + out32r(PCIL0_PMM1MA, 0xE0000001); /* 512M, no prefetch, enable region */ + + out32r(PCIL0_PTM1MS, 0x00000001); + out32r(PCIL0_PTM1LA, 0); + out32r(PCIL0_PTM2MS, 0); + out32r(PCIL0_PTM2LA, 0);
/* * Set up Configuration registers diff --git a/board/gdsys/intip/intip.c b/board/gdsys/intip/intip.c index 2cd2e6d..b42e908 100644 --- a/board/gdsys/intip/intip.c +++ b/board/gdsys/intip/intip.c @@ -154,27 +154,27 @@ void pci_target_init(struct pci_controller *hose) /* * Disable everything */ - out_le32((void *)PCIX0_PIM0SA, 0); /* disable */ - out_le32((void *)PCIX0_PIM1SA, 0); /* disable */ - out_le32((void *)PCIX0_PIM2SA, 0); /* disable */ - out_le32((void *)PCIX0_EROMBA, 0); /* disable expansion rom */ + out_le32((void *)PCIL0_PIM0SA, 0); /* disable */ + out_le32((void *)PCIL0_PIM1SA, 0); /* disable */ + out_le32((void *)PCIL0_PIM2SA, 0); /* disable */ + out_le32((void *)PCIL0_EROMBA, 0); /* disable expansion rom */
diff --git a/board/korat/korat.c b/board/korat/korat.c index 40a097c..8c674a2 100644 --- a/board/korat/korat.c +++ b/board/korat/korat.c @@ -679,29 +679,29 @@ void pci_target_init(struct pci_controller *hose) * Use byte reversed out routines to handle endianess. * Make this region non-prefetchable. */ - out32r(PCIX0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute */ + out32r(PCIL0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute */ /* - disabled b4 setting */ - out32r(PCIX0_PMM0LA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 Local Address */ - out32r(PCIX0_PMM0PCILA, + out32r(PCIL0_PMM0LA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 Local Address */ + out32r(PCIL0_PMM0PCILA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 PCI Low Address */ - out32r(PCIX0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ - out32r(PCIX0_PMM0MA, 0xE0000001); /* 512M + No prefetching, */ + out32r(PCIL0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIL0_PMM0MA, 0xE0000001); /* 512M + No prefetching, */ /* and enable region */
- out32r(PCIX0_PMM1MA, 0x00000000); /* PMM0 Mask/Attribute */ + out32r(PCIL0_PMM1MA, 0x00000000); /* PMM0 Mask/Attribute */ /* - disabled b4 setting */ - out32r(PCIX0_PMM1LA, + out32r(PCIL0_PMM1LA, CONFIG_SYS_PCI_MEMBASE + 0x20000000); /* PMM0 Local Address */ - out32r(PCIX0_PMM1PCILA, + out32r(PCIL0_PMM1PCILA, CONFIG_SYS_PCI_MEMBASE + 0x20000000); /* PMM0 PCI Low Address */ - out32r(PCIX0_PMM1PCIHA, 0x00000000); /* PMM0 PCI High Address */ - out32r(PCIX0_PMM1MA, 0xE0000001); /* 512M + No prefetching, */ + out32r(PCIL0_PMM1PCIHA, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIL0_PMM1MA, 0xE0000001); /* 512M + No prefetching, */ /* and enable region */
/* * Set up Configuration registers diff --git a/board/lwmon5/lwmon5.c b/board/lwmon5/lwmon5.c index f4090f4..ef7f2e8 100644 --- a/board/lwmon5/lwmon5.c +++ b/board/lwmon5/lwmon5.c @@ -351,22 +351,22 @@ void pci_target_init(struct pci_controller *hose) | Use byte reversed out routines to handle endianess. | Make this region non-prefetchable. +--------------------------------------------------------------------------*/ - out32r(PCIX0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ - out32r(PCIX0_PMM0LA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 Local Address */ - out32r(PCIX0_PMM0PCILA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 PCI Low Address */ - out32r(PCIX0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ - out32r(PCIX0_PMM0MA, 0xE0000001); /* 512M + No prefetching, and enable region */ - - out32r(PCIX0_PMM1MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ - out32r(PCIX0_PMM1LA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 Local Address */ - out32r(PCIX0_PMM1PCILA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 PCI Low Address */ - out32r(PCIX0_PMM1PCIHA, 0x00000000); /* PMM0 PCI High Address */ - out32r(PCIX0_PMM1MA, 0xE0000001); /* 512M + No prefetching, and enable region */ - - out32r(PCIX0_PTM1MS, 0x00000001); /* Memory Size/Attribute */ - out32r(PCIX0_PTM1LA, 0); /* Local Addr. Reg */ - out32r(PCIX0_PTM2MS, 0); /* Memory Size/Attribute */ - out32r(PCIX0_PTM2LA, 0); /* Local Addr. Reg */ + out32r(PCIL0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ + out32r(PCIL0_PMM0LA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 Local Address */ + out32r(PCIL0_PMM0PCILA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 PCI Low Address */ + out32r(PCIL0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIL0_PMM0MA, 0xE0000001); /* 512M + No prefetching, and enable region */ + + out32r(PCIL0_PMM1MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ + out32r(PCIL0_PMM1LA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 Local Address */ + out32r(PCIL0_PMM1PCILA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 PCI Low Address */ + out32r(PCIL0_PMM1PCIHA, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIL0_PMM1MA, 0xE0000001); /* 512M + No prefetching, and enable region */ + + out32r(PCIL0_PTM1MS, 0x00000001); /* Memory Size/Attribute */ + out32r(PCIL0_PTM1LA, 0); /* Local Addr. Reg */ + out32r(PCIL0_PTM2MS, 0); /* Memory Size/Attribute */ + out32r(PCIL0_PTM2LA, 0); /* Local Addr. Reg */
/*--------------------------------------------------------------------------+ * Set up Configuration registers diff --git a/board/netstal/hcu5/hcu5.c b/board/netstal/hcu5/hcu5.c index 4522612..946c3f3 100644 --- a/board/netstal/hcu5/hcu5.c +++ b/board/netstal/hcu5/hcu5.c @@ -398,27 +398,27 @@ void pci_target_init(struct pci_controller *hose) * Make this region non-prefetchable. */ /* PMM0 Mask/Attribute - disabled b4 setting */ - out32r(PCIX0_PMM0MA, 0x00000000); - out32r(PCIX0_PMM0LA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 Local Address */ + out32r(PCIL0_PMM0MA, 0x00000000); + out32r(PCIL0_PMM0LA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 Local Address */ /* PMM0 PCI Low Address */ - out32r(PCIX0_PMM0PCILA, CONFIG_SYS_PCI_MEMBASE); - out32r(PCIX0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIL0_PMM0PCILA, CONFIG_SYS_PCI_MEMBASE); + out32r(PCIL0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ /* 512M + No prefetching, and enable region */ - out32r(PCIX0_PMM0MA, 0xE0000001); + out32r(PCIL0_PMM0MA, 0xE0000001);
/* PMM0 Mask/Attribute - disabled b4 setting */ - out32r(PCIX0_PMM1MA, 0x00000000); - out32r(PCIX0_PMM1LA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 Local Address */ + out32r(PCIL0_PMM1MA, 0x00000000); + out32r(PCIL0_PMM1LA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 Local Address */ /* PMM0 PCI Low Address */ - out32r(PCIX0_PMM1PCILA, CONFIG_SYS_PCI_MEMBASE2); - out32r(PCIX0_PMM1PCIHA, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIL0_PMM1PCILA, CONFIG_SYS_PCI_MEMBASE2); + out32r(PCIL0_PMM1PCIHA, 0x00000000); /* PMM0 PCI High Address */ /* 512M + No prefetching, and enable region */ - out32r(PCIX0_PMM1MA, 0xE0000001); + out32r(PCIL0_PMM1MA, 0xE0000001);
/* * Set up Configuration registers diff --git a/board/pcs440ep/pcs440ep.c b/board/pcs440ep/pcs440ep.c index ac059a9..b70827e 100644 --- a/board/pcs440ep/pcs440ep.c +++ b/board/pcs440ep/pcs440ep.c @@ -626,22 +626,22 @@ void pci_target_init(struct pci_controller *hose) | Use byte reversed out routines to handle endianess. | Make this region non-prefetchable. +--------------------------------------------------------------------------*/ - out32r(PCIX0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ - out32r(PCIX0_PMM0LA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 Local Address */ - out32r(PCIX0_PMM0PCILA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 PCI Low Address */ - out32r(PCIX0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ - out32r(PCIX0_PMM0MA, 0xE0000001); /* 512M + No prefetching, and enable region */ - - out32r(PCIX0_PMM1MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ - out32r(PCIX0_PMM1LA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 Local Address */ - out32r(PCIX0_PMM1PCILA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 PCI Low Address */ - out32r(PCIX0_PMM1PCIHA, 0x00000000); /* PMM0 PCI High Address */ - out32r(PCIX0_PMM1MA, 0xE0000001); /* 512M + No prefetching, and enable region */ - - out32r(PCIX0_PTM1MS, 0x00000001); /* Memory Size/Attribute */ - out32r(PCIX0_PTM1LA, 0); /* Local Addr. Reg */ - out32r(PCIX0_PTM2MS, 0); /* Memory Size/Attribute */ - out32r(PCIX0_PTM2LA, 0); /* Local Addr. Reg */ + out32r(PCIL0_PMM0MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ + out32r(PCIL0_PMM0LA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 Local Address */ + out32r(PCIL0_PMM0PCILA, CONFIG_SYS_PCI_MEMBASE); /* PMM0 PCI Low Address */ + out32r(PCIL0_PMM0PCIHA, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIL0_PMM0MA, 0xE0000001); /* 512M + No prefetching, and enable region */ + + out32r(PCIL0_PMM1MA, 0x00000000); /* PMM0 Mask/Attribute - disabled b4 setting */ + out32r(PCIL0_PMM1LA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 Local Address */ + out32r(PCIL0_PMM1PCILA, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 PCI Low Address */ + out32r(PCIL0_PMM1PCIHA, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIL0_PMM1MA, 0xE0000001); /* 512M + No prefetching, and enable region */ + + out32r(PCIL0_PTM1MS, 0x00000001); /* Memory Size/Attribute */ + out32r(PCIL0_PTM1LA, 0); /* Local Addr. Reg */ + out32r(PCIL0_PTM2MS, 0); /* Memory Size/Attribute */ + out32r(PCIL0_PTM2LA, 0); /* Local Addr. Reg */
/*--------------------------------------------------------------------------+ * Set up Configuration registers diff --git a/board/prodrive/alpr/alpr.c b/board/prodrive/alpr/alpr.c index cdb91ac..51335c4 100644 --- a/board/prodrive/alpr/alpr.c +++ b/board/prodrive/alpr/alpr.c @@ -192,28 +192,28 @@ void pci_target_init(struct pci_controller * hose ) /*--------------------------------------------------------------------------+ * Disable everything *--------------------------------------------------------------------------*/ - out32r( PCIX0_PIM0SA, 0 ); /* disable */ - out32r( PCIX0_PIM1SA, 0 ); /* disable */ - out32r( PCIX0_PIM2SA, 0 ); /* disable */ - out32r( PCIX0_EROMBA, 0 ); /* disable expansion rom */ + out32r( PCIL0_PIM0SA, 0 ); /* disable */ + out32r( PCIL0_PIM1SA, 0 ); /* disable */ + out32r( PCIL0_PIM2SA, 0 ); /* disable */ + out32r( PCIL0_EROMBA, 0 ); /* disable expansion rom */
- out16r( PCIX0_CMD, in16r(PCIX0_CMD) | PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER); + out16r( PCIL0_CMD, in16r(PCIL0_CMD) | PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER); } #endif /* defined(CONFIG_PCI) && defined(CONFIG_SYS_PCI_TARGET_INIT) */
@@ -270,21 +270,21 @@ void pci_master_init(struct pci_controller *hose) | Use byte reversed out routines to handle endianess. | Make this region non-prefetchable. +--------------------------------------------------------------------------*/ - out32r( PCIX0_POM0SA, 0 ); /* disable */ - out32r( PCIX0_POM1SA, 0 ); /* disable */ - out32r( PCIX0_POM2SA, 0 ); /* disable */ - - out32r(PCIX0_POM0LAL, CONFIG_SYS_PCI_MEMBASE); /* PMM0 Local Address */ - out32r(PCIX0_POM0LAH, 0x00000003); /* PMM0 Local Address */ - out32r(PCIX0_POM0PCIAL, CONFIG_SYS_PCI_MEMBASE); /* PMM0 PCI Low Address */ - out32r(PCIX0_POM0PCIAH, 0x00000000); /* PMM0 PCI High Address */ - out32r(PCIX0_POM0SA, ~(0x10000000 - 1) | 1); /* 256MB + enable region */ - - out32r(PCIX0_POM1LAL, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 Local Address */ - out32r(PCIX0_POM1LAH, 0x00000003); /* PMM0 Local Address */ - out32r(PCIX0_POM1PCIAL, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 PCI Low Address */ - out32r(PCIX0_POM1PCIAH, 0x00000000); /* PMM0 PCI High Address */ - out32r(PCIX0_POM1SA, ~(0x10000000 - 1) | 1); /* 256MB + enable region */ + out32r( PCIL0_POM0SA, 0 ); /* disable */ + out32r( PCIL0_POM1SA, 0 ); /* disable */ + out32r( PCIL0_POM2SA, 0 ); /* disable */ + + out32r(PCIL0_POM0LAL, CONFIG_SYS_PCI_MEMBASE); /* PMM0 Local Address */ + out32r(PCIL0_POM0LAH, 0x00000003); /* PMM0 Local Address */ + out32r(PCIL0_POM0PCIAL, CONFIG_SYS_PCI_MEMBASE); /* PMM0 PCI Low Address */ + out32r(PCIL0_POM0PCIAH, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIL0_POM0SA, ~(0x10000000 - 1) | 1); /* 256MB + enable region */ + + out32r(PCIL0_POM1LAL, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 Local Address */ + out32r(PCIL0_POM1LAH, 0x00000003); /* PMM0 Local Address */ + out32r(PCIL0_POM1PCIAL, CONFIG_SYS_PCI_MEMBASE2); /* PMM0 PCI Low Address */ + out32r(PCIL0_POM1PCIAH, 0x00000000); /* PMM0 PCI High Address */ + out32r(PCIL0_POM1SA, ~(0x10000000 - 1) | 1); /* 256MB + enable region */ } #endif /* defined(CONFIG_PCI) && defined(CONFIG_SYS_PCI_MASTER_INIT) */
diff --git a/board/prodrive/p3p440/p3p440.c b/board/prodrive/p3p440/p3p440.c index 20fd4dc..9a07852 100644 --- a/board/prodrive/p3p440/p3p440.c +++ b/board/prodrive/p3p440/p3p440.c @@ -209,28 +209,28 @@ void pci_target_init(struct pci_controller *hose) /*--------------------------------------------------------------------------+ * Disable everything *--------------------------------------------------------------------------*/ - out32r(PCIX0_PIM0SA, 0); /* disable */ - out32r(PCIX0_PIM1SA, 0); /* disable */ - out32r(PCIX0_PIM2SA, 0); /* disable */ - out32r(PCIX0_EROMBA, 0); /* disable expansion rom */ + out32r(PCIL0_PIM0SA, 0); /* disable */ + out32r(PCIL0_PIM1SA, 0); /* disable */ + out32r(PCIL0_PIM2SA, 0); /* disable */ + out32r(PCIL0_EROMBA, 0); /* disable expansion rom */
diff --git a/board/sandburst/common/ppc440gx_i2c.h b/board/sandburst/common/ppc440gx_i2c.h index 328abd6..90f27ca 100644 --- a/board/sandburst/common/ppc440gx_i2c.h +++ b/board/sandburst/common/ppc440gx_i2c.h @@ -44,7 +44,7 @@ #define IIC_EXTSTS1 (I2C_REGISTERS_BUS1_BASE_ADDRESS+IICEXTSTS) #define IIC_LSADR1 (I2C_REGISTERS_BUS1_BASE_ADDRESS+IICLSADR) #define IIC_HSADR1 (I2C_REGISTERS_BUS1_BASE_ADDRESS+IICHSADR) -#define IIC_CLKDIV1 (I2C_REGISTERS_BUS1_BASE_ADDRESS+IICCLKDIV) +#define IIC_CLKDIV1 (I2C_REGISTERS_BUS1_BASE_ADDRESS+IIC0_CLKDIV) #define IIC_INTRMSK1 (I2C_REGISTERS_BUS1_BASE_ADDRESS+IICINTRMSK) #define IIC_XFRCNT1 (I2C_REGISTERS_BUS1_BASE_ADDRESS+IICXFRCNT) #define IIC_XTCNTLSS1 (I2C_REGISTERS_BUS1_BASE_ADDRESS+IICXTCNTLSS) diff --git a/board/sandburst/common/sb_common.c b/board/sandburst/common/sb_common.c index e1c6146..a484874 100644 --- a/board/sandburst/common/sb_common.c +++ b/board/sandburst/common/sb_common.c @@ -346,28 +346,28 @@ void pci_target_init(struct pci_controller * hose ) /*--------------------------------------------------------------------------+ * Disable everything *--------------------------------------------------------------------------*/ - out32r( PCIX0_PIM0SA, 0 ); /* disable */ - out32r( PCIX0_PIM1SA, 0 ); /* disable */ - out32r( PCIX0_PIM2SA, 0 ); /* disable */ - out32r( PCIX0_EROMBA, 0 ); /* disable expansion rom */ + out32r( PCIL0_PIM0SA, 0 ); /* disable */ + out32r( PCIL0_PIM1SA, 0 ); /* disable */ + out32r( PCIL0_PIM2SA, 0 ); /* disable */ + out32r( PCIL0_EROMBA, 0 ); /* disable expansion rom */
diff --git a/board/xes/xpedite1000/xpedite1000.c b/board/xes/xpedite1000/xpedite1000.c index 011fb94..04949bb 100644 --- a/board/xes/xpedite1000/xpedite1000.c +++ b/board/xes/xpedite1000/xpedite1000.c @@ -156,7 +156,7 @@ int pci_pre_init(struct pci_controller * hose) return 0;
#if defined(CONFIG_SYS_PCI_FORCE_PCI_CONV) - /* Setup System Device Register PCIX0_XCR */ + /* Setup System Device Register PCIL0_XCR */ mfsdr(SDR0_XCR, strap); strap &= 0x0f000000; mtsdr(SDR0_XCR, strap); @@ -175,26 +175,26 @@ int pci_pre_init(struct pci_controller * hose) void pci_target_init(struct pci_controller * hose) { /* Disable everything */ - out32r(PCIX0_PIM0SA, 0); - out32r(PCIX0_PIM1SA, 0); - out32r(PCIX0_PIM2SA, 0); - out32r(PCIX0_EROMBA, 0); /* disable expansion rom */ + out32r(PCIL0_PIM0SA, 0); + out32r(PCIL0_PIM1SA, 0); + out32r(PCIL0_PIM2SA, 0); + out32r(PCIL0_EROMBA, 0); /* disable expansion rom */
/* * Map all of SDRAM to PCI address 0x0000_0000. Note that the 440 strapping * options to not support sizes such as 128/256 MB. */ - out32r(PCIX0_PIM0LAL, CONFIG_SYS_SDRAM_BASE); - out32r(PCIX0_PIM0LAH, 0); - out32r(PCIX0_PIM0SA, ~(gd->ram_size - 1) | 1); + out32r(PCIL0_PIM0LAL, CONFIG_SYS_SDRAM_BASE); + out32r(PCIL0_PIM0LAH, 0); + out32r(PCIL0_PIM0SA, ~(gd->ram_size - 1) | 1);
/* Program the board's subsystem id/vendor id */ - out16r(PCIX0_SBSYSVID, CONFIG_SYS_PCI_SUBSYS_VENDORID); - out16r(PCIX0_SBSYSID, CONFIG_SYS_PCI_SUBSYS_DEVICEID); + out16r(PCIL0_SBSYSVID, CONFIG_SYS_PCI_SUBSYS_VENDORID); + out16r(PCIL0_SBSYSID, CONFIG_SYS_PCI_SUBSYS_DEVICEID);
diff --git a/cpu/ppc4xx/4xx_pci.c b/cpu/ppc4xx/4xx_pci.c index e97f32c..fa521f0 100644 --- a/cpu/ppc4xx/4xx_pci.c +++ b/cpu/ppc4xx/4xx_pci.c @@ -518,7 +518,7 @@ int pci_440_init (struct pci_controller *hose) /* PCI I/O space */ pci_set_region(hose->regions + reg_num++, 0x00000000, - PCIX0_IOBASE, + PCIL0_IOBASE, 0x10000, PCI_REGION_IO);
@@ -545,7 +545,7 @@ int pci_440_init (struct pci_controller *hose)
hose->region_count = reg_num;
- pci_setup_indirect(hose, PCIX0_CFGADR, PCIX0_CFGDATA); + pci_setup_indirect(hose, PCIL0_CFGADR, PCIL0_CFGDATA);
/* Let board change/modify hose & do initial checks */ if (pci_pre_init (hose) == 0) { @@ -562,18 +562,18 @@ int pci_440_init (struct pci_controller *hose) #if defined(CONFIG_SYS_PCI_TARGET_INIT) pci_target_init(hose); /* Let board setup pci target */ #else - out16r( PCIX0_SBSYSVID, CONFIG_SYS_PCI_SUBSYS_VENDORID ); - out16r( PCIX0_SBSYSID, CONFIG_SYS_PCI_SUBSYS_ID ); - out16r( PCIX0_CLS, 0x00060000 ); /* Bridge, host bridge */ + out16r( PCIL0_SBSYSVID, CONFIG_SYS_PCI_SUBSYS_VENDORID ); + out16r( PCIL0_SBSYSID, CONFIG_SYS_PCI_SUBSYS_ID ); + out16r( PCIL0_CLS, 0x00060000 ); /* Bridge, host bridge */ #endif
#if defined(CONFIG_440GX) || defined(CONFIG_440SPE) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) - out32r( PCIX0_BRDGOPT1, 0x04000060 ); /* PLB Rq pri highest */ - out32r( PCIX0_BRDGOPT2, in32(PCIX0_BRDGOPT2) | 0x83 ); /* Enable host config, clear Timeout, ensure int src1 */ -#elif defined(PCIX0_BRDGOPT1) - out32r( PCIX0_BRDGOPT1, 0x10000060 ); /* PLB Rq pri highest */ - out32r( PCIX0_BRDGOPT2, in32(PCIX0_BRDGOPT2) | 1 ); /* Enable host config */ + out32r( PCIL0_BRDGOPT1, 0x04000060 ); /* PLB Rq pri highest */ + out32r( PCIL0_BRDGOPT2, in32(PCIL0_BRDGOPT2) | 0x83 ); /* Enable host config, clear Timeout, ensure int src1 */ +#elif defined(PCIL0_BRDGOPT1) + out32r( PCIL0_BRDGOPT1, 0x10000060 ); /* PLB Rq pri highest */ + out32r( PCIL0_BRDGOPT2, in32(PCIL0_BRDGOPT2) | 1 ); /* Enable host config */ #endif
/*--------------------------------------------------------------------------+ @@ -583,23 +583,23 @@ int pci_440_init (struct pci_controller *hose) #if defined(CONFIG_SYS_PCI_MASTER_INIT) pci_master_init(hose); /* Let board setup pci master */ #else - out32r( PCIX0_POM0SA, 0 ); /* disable */ - out32r( PCIX0_POM1SA, 0 ); /* disable */ - out32r( PCIX0_POM2SA, 0 ); /* disable */ + out32r( PCIL0_POM0SA, 0 ); /* disable */ + out32r( PCIL0_POM1SA, 0 ); /* disable */ + out32r( PCIL0_POM2SA, 0 ); /* disable */ #if defined(CONFIG_440SPE) - out32r( PCIX0_POM0LAL, 0x10000000 ); - out32r( PCIX0_POM0LAH, 0x0000000c ); + out32r( PCIL0_POM0LAL, 0x10000000 ); + out32r( PCIL0_POM0LAH, 0x0000000c ); #elif defined(CONFIG_460EX) || defined(CONFIG_460GT) - out32r( PCIX0_POM0LAL, 0x20000000 ); - out32r( PCIX0_POM0LAH, 0x0000000c ); + out32r( PCIL0_POM0LAL, 0x20000000 ); + out32r( PCIL0_POM0LAH, 0x0000000c ); #else - out32r( PCIX0_POM0LAL, 0x00000000 ); - out32r( PCIX0_POM0LAH, 0x00000003 ); + out32r( PCIL0_POM0LAL, 0x00000000 ); + out32r( PCIL0_POM0LAH, 0x00000003 ); #endif - out32r( PCIX0_POM0PCIAL, CONFIG_SYS_PCI_MEMBASE ); - out32r( PCIX0_POM0PCIAH, 0x00000000 ); - out32r( PCIX0_POM0SA, 0xf0000001 ); /* 256MB, enabled */ - out32r( PCIX0_STS, in32r( PCIX0_STS ) & ~0x0000fff8 ); + out32r( PCIL0_POM0PCIAL, CONFIG_SYS_PCI_MEMBASE ); + out32r( PCIL0_POM0PCIAH, 0x00000000 ); + out32r( PCIL0_POM0SA, 0xf0000001 ); /* 256MB, enabled */ + out32r( PCIL0_STS, in32r( PCIL0_STS ) & ~0x0000fff8 ); #endif
/*--------------------------------------------------------------------------+ @@ -614,7 +614,7 @@ int pci_440_init (struct pci_controller *hose) #endif #if !defined(CONFIG_440EP) && !defined(CONFIG_440GR) && \ !defined(CONFIG_440EPX) && !defined(CONFIG_440GRX) - out16r( PCIX0_CMD, in16r( PCIX0_CMD ) | PCI_COMMAND_MASTER); + out16r( PCIL0_CMD, in16r( PCIL0_CMD ) | PCI_COMMAND_MASTER); #endif hose->last_busno = pci_hose_scan(hose); } diff --git a/cpu/ppc4xx/cpu_init.c b/cpu/ppc4xx/cpu_init.c index bd06b9b..a00da40 100644 --- a/cpu/ppc4xx/cpu_init.c +++ b/cpu/ppc4xx/cpu_init.c @@ -58,13 +58,13 @@ void reconfigure_pll(u32 new_cpu_freq) target_perdv0 = 4; target_spcid0 = 4;
- mfcpr(CPR0_PRIMBD, reg); + mfcpr(CPR0_PRIMBD0, reg); temp = (reg & PRBDV_MASK) >> 24; prbdv0 = temp ? temp : 8; if (prbdv0 != target_prbdv0) { reg &= ~PRBDV_MASK; reg |= ((target_prbdv0 == 8 ? 0 : target_prbdv0) << 24); - mtcpr(CPR0_PRIMBD, reg); + mtcpr(CPR0_PRIMBD0, reg); reset_needed = 1; }
diff --git a/cpu/ppc4xx/miiphy.c b/cpu/ppc4xx/miiphy.c index fa3bfc8..22ed5c2 100644 --- a/cpu/ppc4xx/miiphy.c +++ b/cpu/ppc4xx/miiphy.c @@ -195,7 +195,7 @@ unsigned int miiphy_getemac_offset(u8 addr) unsigned long eoffset;
/* Need to find out which mdi port we're using */ - zmii = in_be32((void *)ZMII_FER); + zmii = in_be32((void *)ZMII0_FER);
if (zmii & (ZMII_FER_MDI << ZMII_FER_V (0))) /* using port 0 */ @@ -217,12 +217,12 @@ unsigned int miiphy_getemac_offset(u8 addr) /* None of the mdi ports are enabled! */ /* enable port 0 */ zmii |= ZMII_FER_MDI << ZMII_FER_V (0); - out_be32((void *)ZMII_FER, zmii); + out_be32((void *)ZMII0_FER, zmii); eoffset = 0; /* need to soft reset port 0 */ - zmii = in_be32((void *)EMAC_M0); - zmii |= EMAC_M0_SRST; - out_be32((void *)EMAC_M0, zmii); + zmii = in_be32((void *)EMAC0_MR0); + zmii |= EMAC_MR0_SRST; + out_be32((void *)EMAC0_MR0, zmii); }
return (eoffset); @@ -243,19 +243,19 @@ unsigned int miiphy_getemac_offset(u8 addr) switch (addr) { #if defined(CONFIG_HAS_ETH1) && defined(CONFIG_GPCS_PHY1_ADDR) case CONFIG_GPCS_PHY1_ADDR: - if (addr == EMAC_M1_IPPA_GET(in_be32((void *)EMAC_M1 + 0x100))) + if (addr == EMAC_MR1_IPPA_GET(in_be32((void *)EMAC0_MR1 + 0x100))) eoffset = 0x100; break; #endif #if defined(CONFIG_HAS_ETH2) && defined(CONFIG_GPCS_PHY2_ADDR) case CONFIG_GPCS_PHY2_ADDR: - if (addr == EMAC_M1_IPPA_GET(in_be32((void *)EMAC_M1 + 0x300))) + if (addr == EMAC_MR1_IPPA_GET(in_be32((void *)EMAC0_MR1 + 0x300))) eoffset = 0x300; break; #endif #if defined(CONFIG_HAS_ETH3) && defined(CONFIG_GPCS_PHY3_ADDR) case CONFIG_GPCS_PHY3_ADDR: - if (addr == EMAC_M1_IPPA_GET(in_be32((void *)EMAC_M1 + 0x400))) + if (addr == EMAC_MR1_IPPA_GET(in_be32((void *)EMAC0_MR1 + 0x400))) eoffset = 0x400; break; #endif @@ -278,9 +278,9 @@ static int emac_miiphy_wait(u32 emac_reg) /* wait for completion */ i = 0; do { - sta_reg = in_be32((void *)EMAC_STACR + emac_reg); + sta_reg = in_be32((void *)EMAC0_STACR + emac_reg); if (i++ > 5) { - debug("%s [%d]: Timeout! EMAC_STACR=0x%0x\n", __func__, + debug("%s [%d]: Timeout! EMAC0_STACR=0x%0x\n", __func__, __LINE__, sta_reg); return -1; } @@ -324,7 +324,7 @@ static int emac_miiphy_command(u8 addr, u8 reg, int cmd, u16 value) if (cmd == EMAC_STACR_WRITE) memcpy(&sta_reg, &value, 2); /* put in data */
- out_be32((void *)EMAC_STACR + emac_reg, sta_reg); + out_be32((void *)EMAC0_STACR + emac_reg, sta_reg); debug("%s [%d]: sta_reg=%08x\n", __func__, __LINE__, sta_reg);
/* wait for completion */ @@ -349,7 +349,7 @@ int emac4xx_miiphy_read (char *devname, unsigned char addr, unsigned char reg, if (emac_miiphy_command(addr, reg, EMAC_STACR_READ, 0) != 0) return -1;
- sta_reg = in_be32((void *)EMAC_STACR + emac_reg); + sta_reg = in_be32((void *)EMAC0_STACR + emac_reg); *value = sta_reg >> 16;
return 0; diff --git a/cpu/ppc4xx/speed.c b/cpu/ppc4xx/speed.c index 988ba97..906face 100644 --- a/cpu/ppc4xx/speed.c +++ b/cpu/ppc4xx/speed.c @@ -334,7 +334,7 @@ void get_sys_info (sys_info_t *sysInfo) sysInfo->pllFbkDiv = temp ? temp : 32; lfdiv = reg & PLLD_LFBDV_MASK;
- mfcpr(CPR0_OPBD, reg); + mfcpr(CPR0_OPBD0, reg); temp = (reg & OPBDDV_MASK) >> 24; sysInfo->pllOpbDiv = temp ? temp : 4;
@@ -342,7 +342,7 @@ void get_sys_info (sys_info_t *sysInfo) temp = (reg & PERDV_MASK) >> 24; sysInfo->pllExtBusDiv = temp ? temp : 8;
@@ -1050,7 +1050,7 @@ void get_sys_info (sys_info_t * sysInfo) /* * Determine OPBDV0 */ - mfcpr(CPR0_OPBD, tmp); + mfcpr(CPR0_OPBD0, tmp); tmp = (tmp >> 24) & 0x03; sysInfo->pllOpbDiv = (tmp == 0) ? 4 : tmp;
diff --git a/drivers/net/4xx_enet.c b/drivers/net/4xx_enet.c index afd1084..312b25e 100644 --- a/drivers/net/4xx_enet.c +++ b/drivers/net/4xx_enet.c @@ -44,7 +44,7 @@ * RX descriptor address up to the next cache line boundary. * 16-Jan-00 Added support for booting with IP of 0x0 MKW * 15-Mar-00 Updated enetInit() to enable broadcast addresses in the - * EMAC_RXM register. JWB + * EMAC0_RXM register. JWB * 12-Mar-01 anne-sophie.harnois@nextream.fr * - Variables are compatible with those already defined in * include/net.h @@ -58,7 +58,7 @@ * 08-May-01 stefan.roese@esd-electronics.com * - MAL error handling added (eth_init called again) * 13-Nov-01 stefan.roese@esd-electronics.com - * - Set IST bit in EMAC_M1 reg upon 100MBit or full duplex + * - Set IST bit in EMAC0_MR1 reg upon 100MBit or full duplex * 04-Jan-02 stefan.roese@esd-electronics.com * - Wait for PHY auto negotiation to complete added * 06-Feb-02 stefan.roese@esd-electronics.com @@ -359,7 +359,7 @@ static void ppc_4xx_eth_halt (struct eth_device *dev) EMAC_4XX_HW_PST hw_p = dev->priv; u32 val = 10000;
- out_be32((void *)EMAC_IER + hw_p->hw_addr, 0x00000000); /* disable emac interrupts */ + out_be32((void *)EMAC0_IER + hw_p->hw_addr, 0x00000000); /* disable emac interrupts */
/* 1st reset MAL channel */ /* Note: writing a 0 to a channel has no effect */ @@ -382,7 +382,7 @@ static void ppc_4xx_eth_halt (struct eth_device *dev) emac_loopback_enable(hw_p);
/* EMAC RESET */ - out_be32((void *)EMAC_M0 + hw_p->hw_addr, EMAC_M0_SRST); + out_be32((void *)EMAC0_MR0 + hw_p->hw_addr, EMAC_MR0_SRST);
/* remove clocks for EMAC internal loopback */ emac_loopback_disable(hw_p); @@ -485,7 +485,7 @@ int ppc_4xx_eth_setup_bridge(int devnum, bd_t * bis) /* Ensure we setup mdio for this devnum and ONLY this devnum */ zmiifer |= (ZMII_FER_MDI) << ZMII_FER_V(devnum);
- out_be32((void *)ZMII_FER, zmiifer); + out_be32((void *)ZMII0_FER, zmiifer); out_be32((void *)RGMII_FER, rmiifer);
return ((int)pfc1); @@ -504,21 +504,21 @@ int ppc_4xx_eth_setup_bridge(int devnum, bd_t * bis) switch (pfc1) { case SDR0_PFC1_SELECT_CONFIG_2: /* 1 x GMII port */ - out_be32((void *)ZMII_FER, 0x00); + out_be32((void *)ZMII0_FER, 0x00); out_be32((void *)RGMII_FER, 0x00000037); bis->bi_phymode[0] = BI_PHYMODE_GMII; bis->bi_phymode[1] = BI_PHYMODE_NONE; break; case SDR0_PFC1_SELECT_CONFIG_4: /* 2 x RGMII ports */ - out_be32((void *)ZMII_FER, 0x00); + out_be32((void *)ZMII0_FER, 0x00); out_be32((void *)RGMII_FER, 0x00000055); bis->bi_phymode[0] = BI_PHYMODE_RGMII; bis->bi_phymode[1] = BI_PHYMODE_RGMII; break; case SDR0_PFC1_SELECT_CONFIG_6: /* 2 x SMII ports */ - out_be32((void *)ZMII_FER, + out_be32((void *)ZMII0_FER, ((ZMII_FER_SMII) << ZMII_FER_V(0)) | ((ZMII_FER_SMII) << ZMII_FER_V(1))); out_be32((void *)RGMII_FER, 0x00000000); @@ -527,7 +527,7 @@ int ppc_4xx_eth_setup_bridge(int devnum, bd_t * bis) break; case SDR0_PFC1_SELECT_CONFIG_1_2: /* only 1 x MII supported */ - out_be32((void *)ZMII_FER, (ZMII_FER_MII) << ZMII_FER_V(0)); + out_be32((void *)ZMII0_FER, (ZMII_FER_MII) << ZMII_FER_V(0)); out_be32((void *)RGMII_FER, 0x00000000); bis->bi_phymode[0] = BI_PHYMODE_MII; bis->bi_phymode[1] = BI_PHYMODE_NONE; @@ -537,9 +537,9 @@ int ppc_4xx_eth_setup_bridge(int devnum, bd_t * bis) }
/* Ensure we setup mdio for this devnum and ONLY this devnum */ - zmiifer = in_be32((void *)ZMII_FER); + zmiifer = in_be32((void *)ZMII0_FER); zmiifer |= (ZMII_FER_MDI) << ZMII_FER_V(devnum); - out_be32((void *)ZMII_FER, zmiifer); + out_be32((void *)ZMII0_FER, zmiifer);
return ((int)0x0); } @@ -953,18 +953,18 @@ static int ppc_4xx_eth_init (struct eth_device *dev, bd_t * bis) /* NOTE: Therefore, disable all other EMACS, since we handle */ /* NOTE: only one emac at a time */ reg = 0; - out_be32((void *)ZMII_FER, 0); + out_be32((void *)ZMII0_FER, 0); udelay (100);
#if defined(CONFIG_440GP) || defined(CONFIG_440EP) || defined(CONFIG_440GR) - out_be32((void *)ZMII_FER, (ZMII_FER_RMII | ZMII_FER_MDI) << ZMII_FER_V (devnum)); + out_be32((void *)ZMII0_FER, (ZMII_FER_RMII | ZMII_FER_MDI) << ZMII_FER_V (devnum)); #elif defined(CONFIG_440GX) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) ethgroup = ppc_4xx_eth_setup_bridge(devnum, bis); #endif
- out_be32((void *)ZMII_SSR, ZMII_SSR_SP << ZMII_SSR_V(devnum)); + out_be32((void *)ZMII0_SSR, ZMII0_SSR_SP << ZMII0_SSR_V(devnum)); #endif /* defined(CONFIG_440) && !defined(CONFIG_440SP) */ #if defined(CONFIG_405EX) ethgroup = ppc_4xx_eth_setup_bridge(devnum, bis); @@ -976,13 +976,13 @@ static int ppc_4xx_eth_init (struct eth_device *dev, bd_t * bis) emac_loopback_enable(hw_p);
failsafe = 1000; - while ((in_be32((void *)EMAC_M0 + hw_p->hw_addr) & (EMAC_M0_SRST)) && failsafe) { + while ((in_be32((void *)EMAC0_MR0 + hw_p->hw_addr) & (EMAC_MR0_SRST)) && failsafe) { udelay (1000); failsafe--; } @@ -1000,15 +1000,15 @@ static int ppc_4xx_eth_init (struct eth_device *dev, bd_t * bis) opbfreq = sysinfo.freqOPB / 1000000; if (opbfreq <= 50); else if (opbfreq <= 66) - mode_reg |= EMAC_M1_OBCI_66; + mode_reg |= EMAC_MR1_OBCI_66; else if (opbfreq <= 83) - mode_reg |= EMAC_M1_OBCI_83; + mode_reg |= EMAC_MR1_OBCI_83; else if (opbfreq <= 100) - mode_reg |= EMAC_M1_OBCI_100; + mode_reg |= EMAC_MR1_OBCI_100; else - mode_reg |= EMAC_M1_OBCI_GT100; + mode_reg |= EMAC_MR1_OBCI_GT100;
- out_be32((void *)EMAC_M1 + hw_p->hw_addr, mode_reg); + out_be32((void *)EMAC0_MR1 + hw_p->hw_addr, mode_reg); #endif /* defined(CONFIG_440GX) || defined(CONFIG_440SP) */
#if defined(CONFIG_GPCS_PHY_ADDR) || defined(CONFIG_GPCS_PHY1_ADDR) || \ @@ -1041,9 +1041,9 @@ static int ppc_4xx_eth_init (struct eth_device *dev, bd_t * bis) #endif }
- mode_reg = in_be32((void *)EMAC_M1 + hw_p->hw_addr); - mode_reg |= EMAC_M1_MF_1000GPCS | EMAC_M1_IPPA_SET(reg); - out_be32((void *)EMAC_M1 + hw_p->hw_addr, mode_reg); + mode_reg = in_be32((void *)EMAC0_MR1 + hw_p->hw_addr); + mode_reg |= EMAC_MR1_MF_1000GPCS | EMAC_MR1_IPPA_SET(reg); + out_be32((void *)EMAC0_MR1 + hw_p->hw_addr, mode_reg);
/* Configure GPCS interface to recommended setting for SGMII */ miiphy_reset(dev->name, reg); @@ -1250,11 +1250,11 @@ get_speed: #endif
/* Set ZMII/RGMII speed according to the phy link speed */ - reg = in_be32((void *)ZMII_SSR); + reg = in_be32((void *)ZMII0_SSR); if ( (speed == 100) || (speed == 1000) ) - out_be32((void *)ZMII_SSR, reg | (ZMII_SSR_SP << ZMII_SSR_V (devnum))); + out_be32((void *)ZMII0_SSR, reg | (ZMII0_SSR_SP << ZMII0_SSR_V (devnum))); else - out_be32((void *)ZMII_SSR, reg & (~(ZMII_SSR_SP << ZMII_SSR_V (devnum)))); + out_be32((void *)ZMII0_SSR, reg & (~(ZMII0_SSR_SP << ZMII0_SSR_V (devnum))));
if ((devnum == 2) || (devnum == 3)) { if (speed == 1000) @@ -1381,7 +1381,7 @@ get_speed: reg = reg << 8; reg |= dev->enetaddr[1];
- out_be32((void *)EMAC_IAH + hw_p->hw_addr, reg); + out_be32((void *)EMAC0_IAH + hw_p->hw_addr, reg);
reg = 0x00000000; reg |= dev->enetaddr[2]; /* set low address */ @@ -1392,7 +1392,7 @@ get_speed: reg = reg << 8; reg |= dev->enetaddr[5];
- out_be32((void *)EMAC_IAL + hw_p->hw_addr, reg); + out_be32((void *)EMAC0_IAL + hw_p->hw_addr, reg);
switch (devnum) { case 1: @@ -1480,9 +1480,9 @@ get_speed: mtdcr (MAL0_RXCASR, (MAL_TXRX_CASR >> hw_p->devnum));
/* set transmit enable & receive enable */ - out_be32((void *)EMAC_M0 + hw_p->hw_addr, EMAC_M0_TXE | EMAC_M0_RXE); + out_be32((void *)EMAC0_MR0 + hw_p->hw_addr, EMAC_MR0_TXE | EMAC_MR0_RXE);
- mode_reg = in_be32((void *)EMAC_M1 + hw_p->hw_addr); + mode_reg = in_be32((void *)EMAC0_MR1 + hw_p->hw_addr);
/* set rx-/tx-fifo size */ mode_reg = (mode_reg & ~EMAC_MR1_FIFO_MASK) | EMAC_MR1_FIFO_SIZE; @@ -1497,47 +1497,47 @@ get_speed: pfc1 |= SDR0_PFC1_EM_1000; mtsdr (SDR0_PFC1, pfc1); #endif - mode_reg = mode_reg | EMAC_M1_MF_1000MBPS | EMAC_M1_IST; + mode_reg = mode_reg | EMAC_MR1_MF_1000MBPS | EMAC_MR1_IST; } else if (speed == _100BASET) - mode_reg = mode_reg | EMAC_M1_MF_100MBPS | EMAC_M1_IST; + mode_reg = mode_reg | EMAC_MR1_MF_100MBPS | EMAC_MR1_IST; else mode_reg = mode_reg & ~0x00C00000; /* 10 MBPS */ if (duplex == FULL) - mode_reg = mode_reg | 0x80000000 | EMAC_M1_IST; + mode_reg = mode_reg | 0x80000000 | EMAC_MR1_IST;
/* Enable broadcast and indvidual address */ /* TBS: enabling runts as some misbehaved nics will send runts */ - out_be32((void *)EMAC_RXM + hw_p->hw_addr, EMAC_RMR_BAE | EMAC_RMR_IAE); + out_be32((void *)EMAC0_RXM + hw_p->hw_addr, EMAC_RMR_BAE | EMAC_RMR_IAE);
/* we probably need to set the tx mode1 reg? maybe at tx time */
/* set transmit request threshold register */ - out_be32((void *)EMAC_TRTR + hw_p->hw_addr, 0x18000000); /* 256 byte threshold */ + out_be32((void *)EMAC0_TRTR + hw_p->hw_addr, 0x18000000); /* 256 byte threshold */
/* set receive low/high water mark register */ #if defined(CONFIG_440) /* 440s has a 64 byte burst length */ - out_be32((void *)EMAC_RX_HI_LO_WMARK + hw_p->hw_addr, 0x80009000); + out_be32((void *)EMAC0_RX_HI_LO_WMARK + hw_p->hw_addr, 0x80009000); #else /* 405s have a 16 byte burst length */ - out_be32((void *)EMAC_RX_HI_LO_WMARK + hw_p->hw_addr, 0x0f002000); + out_be32((void *)EMAC0_RX_HI_LO_WMARK + hw_p->hw_addr, 0x0f002000); #endif /* defined(CONFIG_440) */ - out_be32((void *)EMAC_TXM1 + hw_p->hw_addr, 0xf8640000); + out_be32((void *)EMAC0_TMR1 + hw_p->hw_addr, 0xf8640000);
/* Set fifo limit entry in tx mode 0 */ - out_be32((void *)EMAC_TXM0 + hw_p->hw_addr, 0x00000003); + out_be32((void *)EMAC0_TMR0 + hw_p->hw_addr, 0x00000003); /* Frame gap set */ - out_be32((void *)EMAC_I_FRAME_GAP_REG + hw_p->hw_addr, 0x00000008); + out_be32((void *)EMAC0_I_FRAME_GAP_REG + hw_p->hw_addr, 0x00000008);
/* Set EMAC IER */ hw_p->emac_ier = EMAC_ISR_PTLE | EMAC_ISR_BFCS | EMAC_ISR_ORE | EMAC_ISR_IRE; if (speed == _100BASET) hw_p->emac_ier = hw_p->emac_ier | EMAC_ISR_SYE;
- out_be32((void *)EMAC_ISR + hw_p->hw_addr, 0xffffffff); /* clear pending interrupts */ - out_be32((void *)EMAC_IER + hw_p->hw_addr, hw_p->emac_ier); + out_be32((void *)EMAC0_ISR + hw_p->hw_addr, 0xffffffff); /* clear pending interrupts */ + out_be32((void *)EMAC0_IER + hw_p->hw_addr, hw_p->emac_ier);
if (hw_p->first_init == 0) { /* @@ -1596,8 +1596,8 @@ static int ppc_4xx_eth_send (struct eth_device *dev, volatile void *ptr,
sync();
- out_be32((void *)EMAC_TXM0 + hw_p->hw_addr, - in_be32((void *)EMAC_TXM0 + hw_p->hw_addr) | EMAC_TXM0_GNP0); + out_be32((void *)EMAC0_TMR0 + hw_p->hw_addr, + in_be32((void *)EMAC0_TMR0 + hw_p->hw_addr) | EMAC_TMR0_GNP0); #ifdef INFO_4XX_ENET hw_p->stats.pkts_tx++; #endif @@ -1607,9 +1607,9 @@ static int ppc_4xx_eth_send (struct eth_device *dev, volatile void *ptr, *-----------------------------------------------------------------------*/ time_start = get_timer (0); while (1) { - temp_txm0 = in_be32((void *)EMAC_TXM0 + hw_p->hw_addr); + temp_txm0 = in_be32((void *)EMAC0_TMR0 + hw_p->hw_addr); /* loop until either TINT turns on or 3 seconds elapse */ - if ((temp_txm0 & EMAC_TXM0_GNP0) != 0) { + if ((temp_txm0 & EMAC_TMR0_GNP0) != 0) { /* transmit is done, so now check for errors * If there is an error, an interrupt should * happen when we return @@ -1678,7 +1678,7 @@ int enetInt (struct eth_device *dev)
/* look for EMAC errors */ if ((uic_emac & UIC_ETHx) || (uic_emac_b & UIC_ETHxB)) { - emac_isr = in_be32((void *)EMAC_ISR + hw_p->hw_addr); + emac_isr = in_be32((void *)EMAC0_ISR + hw_p->hw_addr); emac_err(dev, emac_isr);
/* clear EMAC error interrupt status bits */ @@ -1752,7 +1752,7 @@ static void emac_err (struct eth_device *dev, unsigned long isr) EMAC_4XX_HW_PST hw_p = dev->priv;
printf ("EMAC%d error occured.... ISR = %lx\n", hw_p->devnum, isr); - out_be32((void *)EMAC_ISR + hw_p->hw_addr, isr); + out_be32((void *)EMAC0_ISR + hw_p->hw_addr, isr); }
/*-----------------------------------------------------------------------------+ diff --git a/post/cpu/ppc4xx/ether.c b/post/cpu/ppc4xx/ether.c index c3665da..a58db04 100644 --- a/post/cpu/ppc4xx/ether.c +++ b/post/cpu/ppc4xx/ether.c @@ -115,11 +115,11 @@ static void ether_post_init (int devnum, int hw_addr) sync (); #endif /* reset emac */ - out_be32 ((void*)(EMAC_M0 + hw_addr), EMAC_M0_SRST); + out_be32 ((void*)(EMAC0_MR0 + hw_addr), EMAC_MR0_SRST); sync ();
for (i = 0;; i++) { - if (!(in_be32 ((void*)(EMAC_M0 + hw_addr)) & EMAC_M0_SRST)) + if (!(in_be32 ((void*)(EMAC0_MR0 + hw_addr)) & EMAC_MR0_SRST)) break; if (i >= 1000) { printf ("Timeout resetting EMAC\n"); @@ -134,15 +134,15 @@ static void ether_post_init (int devnum, int hw_addr) mode_reg = 0x0; if (sysinfo.freqOPB <= 50000000); else if (sysinfo.freqOPB <= 66666667) - mode_reg |= EMAC_M1_OBCI_66; + mode_reg |= EMAC_MR1_OBCI_66; else if (sysinfo.freqOPB <= 83333333) - mode_reg |= EMAC_M1_OBCI_83; + mode_reg |= EMAC_MR1_OBCI_83; else if (sysinfo.freqOPB <= 100000000) - mode_reg |= EMAC_M1_OBCI_100; + mode_reg |= EMAC_MR1_OBCI_100; else - mode_reg |= EMAC_M1_OBCI_GT100; + mode_reg |= EMAC_MR1_OBCI_GT100;
- out_be32 ((void*)(EMAC_M1 + hw_addr), mode_reg); + out_be32 ((void*)(EMAC0_MR1 + hw_addr), mode_reg);
@@ -210,40 +210,40 @@ static void ether_post_init (int devnum, int hw_addr)
/* set internal loopback mode */ #ifdef CONFIG_SYS_POST_ETHER_EXT_LOOPBACK - out_be32 ((void*)(EMAC_M1 + hw_addr), EMAC_M1_FDE | 0 | - EMAC_M1_RFS_4K | EMAC_M1_TX_FIFO_2K | - EMAC_M1_MF_100MBPS | EMAC_M1_IST | - in_be32 ((void*)(EMAC_M1 + hw_addr))); + out_be32 ((void*)(EMAC0_MR1 + hw_addr), EMAC_MR1_FDE | 0 | + EMAC_MR1_RFS_4K | EMAC_MR1_TX_FIFO_2K | + EMAC_MR1_MF_100MBPS | EMAC_MR1_IST | + in_be32 ((void*)(EMAC0_MR1 + hw_addr))); #else - out_be32 ((void*)(EMAC_M1 + hw_addr), EMAC_M1_FDE | EMAC_M1_ILE | - EMAC_M1_RFS_4K | EMAC_M1_TX_FIFO_2K | - EMAC_M1_MF_100MBPS | EMAC_M1_IST | - in_be32 ((void*)(EMAC_M1 + hw_addr))); + out_be32 ((void*)(EMAC0_MR1 + hw_addr), EMAC_MR1_FDE | EMAC_MR1_ILE | + EMAC_MR1_RFS_4K | EMAC_MR1_TX_FIFO_2K | + EMAC_MR1_MF_100MBPS | EMAC_MR1_IST | + in_be32 ((void*)(EMAC0_MR1 + hw_addr))); #endif
/* set transmit enable & receive enable */ - out_be32 ((void*)(EMAC_M0 + hw_addr), EMAC_M0_TXE | EMAC_M0_RXE); + out_be32 ((void*)(EMAC0_MR0 + hw_addr), EMAC_MR0_TXE | EMAC_MR0_RXE);
/* enable broadcast address */ - out_be32 ((void*)(EMAC_RXM + hw_addr), EMAC_RMR_BAE); + out_be32 ((void*)(EMAC0_RXM + hw_addr), EMAC_RMR_BAE);
/* set transmit request threshold register */ - out_be32 ((void*)(EMAC_TRTR + hw_addr), 0x18000000); /* 256 byte threshold */ + out_be32 ((void*)(EMAC0_TRTR + hw_addr), 0x18000000); /* 256 byte threshold */
/* set receive low/high water mark register */ #if defined(CONFIG_440) /* 440s has a 64 byte burst length */ - out_be32 ((void*)(EMAC_RX_HI_LO_WMARK + hw_addr), 0x80009000); + out_be32 ((void*)(EMAC0_RX_HI_LO_WMARK + hw_addr), 0x80009000); #else /* 405s have a 16 byte burst length */ - out_be32 ((void*)(EMAC_RX_HI_LO_WMARK + hw_addr), 0x0f002000); + out_be32 ((void*)(EMAC0_RX_HI_LO_WMARK + hw_addr), 0x0f002000); #endif /* defined(CONFIG_440) */ - out_be32 ((void*)(EMAC_TXM1 + hw_addr), 0xf8640000); + out_be32 ((void*)(EMAC0_TMR1 + hw_addr), 0xf8640000);
/* Set fifo limit entry in tx mode 0 */ - out_be32 ((void*)(EMAC_TXM0 + hw_addr), 0x00000003); + out_be32 ((void*)(EMAC0_TMR0 + hw_addr), 0x00000003); /* Frame gap set */ - out_be32 ((void*)(EMAC_I_FRAME_GAP_REG + hw_addr), 0x00000008); + out_be32 ((void*)(EMAC0_I_FRAME_GAP_REG + hw_addr), 0x00000008); sync (); }
@@ -270,7 +270,7 @@ static void ether_post_halt (int devnum, int hw_addr) udelay (1000); } /* emac reset */ - out_be32 ((void*)(EMAC_M0 + hw_addr), EMAC_M0_SRST); + out_be32 ((void*)(EMAC0_MR0 + hw_addr), EMAC_MR0_SRST);
#if defined(CONFIG_440SPE) || defined(CONFIG_440EPX) || defined(CONFIG_440GRX) /* remove clocks for EMAC internal loopback */ @@ -300,7 +300,7 @@ static void ether_post_send (int devnum, int hw_addr, void *packet, int length) flush_dcache_range((u32)tx.data_ptr, (u32)tx.data_ptr + length); sync ();
- out_be32 ((void*)(EMAC_TXM0 + hw_addr), in_be32 ((void*)(EMAC_TXM0 + hw_addr)) | EMAC_TXM0_GNP0); + out_be32 ((void*)(EMAC0_TMR0 + hw_addr), in_be32 ((void*)(EMAC0_TMR0 + hw_addr)) | EMAC_TMR0_GNP0); sync (); }
The command "reginfo" got an overhaul for the ppc4xx. It dumps all the relevant HW configuration registers (address, symbolic name, content). This allows to easily detect errors in *.h files and changes in the HW configuration.
Signed-off-by: Niklaus Giger niklaus.giger@member.fsf.org --- common/cmd_reginfo.c | 158 +--------------------- cpu/ppc4xx/Makefile | 4 + cpu/ppc4xx/reginfo.c | 370 ++++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 378 insertions(+), 154 deletions(-) create mode 100644 cpu/ppc4xx/reginfo.c
diff --git a/common/cmd_reginfo.c b/common/cmd_reginfo.c index d0ebd0f..89fd9ec 100644 --- a/common/cmd_reginfo.c +++ b/common/cmd_reginfo.c @@ -25,8 +25,8 @@ #include <command.h> #if defined(CONFIG_8xx) #include <mpc8xx.h> -#elif defined (CONFIG_405GP) || defined(CONFIG_405EP) -#include <asm/processor.h> +#elif defined (CONFIG_4xx) +extern void ppc4xx_reginfo(void); #elif defined (CONFIG_5xx) #include <mpc5xx.h> #elif defined (CONFIG_MPC5200) @@ -90,158 +90,8 @@ int do_reginfo (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) * May be some CPM info here? */
-#elif defined (CONFIG_405GP) - printf ("\n405GP registers; MSR=%08x\n",mfmsr()); - printf ("\nUniversal Interrupt Controller Regs\n" - "UIC0SR UIC0ER UIC0CR UIC0PR UIC0TR UIC0MSR UIC0VR UIC0VCR" - "\n" - "%08x %08x %08x %08x %08x %08x %08x %08x\n", - mfdcr(UIC0SR), - mfdcr(UIC0ER), - mfdcr(UIC0CR), - mfdcr(UIC0PR), - mfdcr(UIC0TR), - mfdcr(UIC0MSR), - mfdcr(UIC0VR), - mfdcr(UIC0VCR)); - - puts ("\nMemory (SDRAM) Configuration\n" - "besra besrsa besrb besrsb bear mcopt1 rtr pmit\n"); - - mtdcr(SDRAM0_CFGADDR,SDRAM0_BESR0); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - mtdcr(SDRAM0_CFGADDR,SDRAM0_BESRS0); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - mtdcr(SDRAM0_CFGADDR,SDRAM0_BESR1); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - mtdcr(SDRAM0_CFGADDR,SDRAM0_BESRS1); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - mtdcr(SDRAM0_CFGADDR,SDRAM0_BEAR); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - mtdcr(SDRAM0_CFGADDR,SDRAM0_CFG); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - mtdcr(SDRAM0_CFGADDR,SDRAM0_RTR); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - mtdcr(SDRAM0_CFGADDR,SDRAM0_PMIT); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - - puts ("\n" - "mb0cf mb1cf mb2cf mb3cf sdtr1 ecccf eccerr\n"); - mtdcr(SDRAM0_CFGADDR,SDRAM0_B0CR); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - mtdcr(SDRAM0_CFGADDR,SDRAM0_B1CR); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - mtdcr(SDRAM0_CFGADDR,SDRAM0_B2CR); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - mtdcr(SDRAM0_CFGADDR,SDRAM0_B3CR); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - mtdcr(SDRAM0_CFGADDR,SDRAM0_TR); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - mtdcr(SDRAM0_CFGADDR,SDRAM0_ECCCFG); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - mtdcr(SDRAM0_CFGADDR,SDRAM0_ECCESR); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - - printf ("\n\n" - "DMA Channels\n" - "DMASR DMASGC DMAADR\n" - "%08x %08x %08x\n" - "dmacr_0 dmact_0 dmada_0 dmasa_0 dmasb_0\n" - "%08x %08x %08x %08x %08x\n" - "dmacr_1 dmact_1 dmada_1 dmasa_1 dmasb_1\n" - "%08x %08x %08x %08x %08x\n", - mfdcr(DMASR), mfdcr(DMASGC),mfdcr(DMAADR), - mfdcr(DMACR0), mfdcr(DMACT0),mfdcr(DMADA0), mfdcr(DMASA0), mfdcr(DMASB0), - mfdcr(DMACR1), mfdcr(DMACT1),mfdcr(DMADA1), mfdcr(DMASA1), mfdcr(DMASB1)); - - printf ( - "dmacr_2 dmact_2 dmada_2 dmasa_2 dmasb_2\n" "%08x %08x %08x %08x %08x\n" - "dmacr_3 dmact_3 dmada_3 dmasa_3 dmasb_3\n" "%08x %08x %08x %08x %08x\n", - mfdcr(DMACR2), mfdcr(DMACT2),mfdcr(DMADA2), mfdcr(DMASA2), mfdcr(DMASB2), - mfdcr(DMACR3), mfdcr(DMACT3),mfdcr(DMADA3), mfdcr(DMASA3), mfdcr(DMASB3) ); - - puts ("\n" - "External Bus\n" - "PBEAR PBESR0 PBESR1 EBC0_CFG\n"); - mtdcr(EBC0_CFGADDR,PBEAR); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PBESR0); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PBESR1); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,EBC0_CFG); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - - puts ("\n" - "PB0CR PB0AP PB1CR PB1AP PB2CR PB2AP PB3CR PB3AP\n"); - mtdcr(EBC0_CFGADDR,PB0CR); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB0AP); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB1CR); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB1AP); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB2CR); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB2AP); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB3CR); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB3AP); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - - puts ("\n" - "PB4CR PB4AP PB5CR bp5ap PB6CR PB6AP PB7CR PB7AP\n"); - mtdcr(EBC0_CFGADDR,PB4CR); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB4AP); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB5CR); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB5AP); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB6CR); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB6AP); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB7CR); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB7AP); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - - puts ("\n\n"); - -#elif defined(CONFIG_405EP) - printf ("\n405EP registers; MSR=%08x\n",mfmsr()); - printf ("\nUniversal Interrupt Controller Regs\n" - "UIC0SR UIC0ER UIC0CR UIC0PR UIC0TR UIC0MSR UIC0VR UIC0VCR" - "\n" - "%08x %08x %08x %08x %08x %08x %08x %08x\n", - mfdcr(UIC0SR), - mfdcr(UIC0ER), - mfdcr(UIC0CR), - mfdcr(UIC0PR), - mfdcr(UIC0TR), - mfdcr(UIC0MSR), - mfdcr(UIC0VR), - mfdcr(UIC0VCR)); - - puts ("\nMemory (SDRAM) Configuration\n" - "mcopt1 rtr pmit mb0cf mb1cf sdtr1\n"); - - mtdcr(SDRAM0_CFGADDR,SDRAM0_CFG); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - mtdcr(SDRAM0_CFGADDR,SDRAM0_RTR); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - mtdcr(SDRAM0_CFGADDR,SDRAM0_PMIT); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - mtdcr(SDRAM0_CFGADDR,SDRAM0_B0CR); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - mtdcr(SDRAM0_CFGADDR,SDRAM0_B1CR); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - mtdcr(SDRAM0_CFGADDR,SDRAM0_TR); printf ("%08x ", mfdcr(SDRAM0_CFGDATA)); - - printf ("\n\n" - "DMA Channels\n" - "DMASR DMASGC DMAADR\n" "%08x %08x %08x\n" - "dmacr_0 dmact_0 dmada_0 dmasa_0 dmasb_0\n" "%08x %08x %08x %08x %08x\n" - "dmacr_1 dmact_1 dmada_1 dmasa_1 dmasb_1\n" "%08x %08x %08x %08x %08x\n", - mfdcr(DMASR), mfdcr(DMASGC),mfdcr(DMAADR), - mfdcr(DMACR0), mfdcr(DMACT0),mfdcr(DMADA0), mfdcr(DMASA0), mfdcr(DMASB0), - mfdcr(DMACR1), mfdcr(DMACT1),mfdcr(DMADA1), mfdcr(DMASA1), mfdcr(DMASB1)); - - printf ( - "dmacr_2 dmact_2 dmada_2 dmasa_2 dmasb_2\n" "%08x %08x %08x %08x %08x\n" - "dmacr_3 dmact_3 dmada_3 dmasa_3 dmasb_3\n" "%08x %08x %08x %08x %08x\n", - mfdcr(DMACR2), mfdcr(DMACT2),mfdcr(DMADA2), mfdcr(DMASA2), mfdcr(DMASB2), - mfdcr(DMACR3), mfdcr(DMACT3),mfdcr(DMADA3), mfdcr(DMASA3), mfdcr(DMASB3) ); - - puts ("\n" - "External Bus\n" - "PBEAR PBESR0 PBESR1 EBC0_CFG\n"); - mtdcr(EBC0_CFGADDR,PBEAR); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PBESR0); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PBESR1); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,EBC0_CFG); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - - puts ("\n" - "PB0CR PB0AP PB1CR PB1AP PB2CR PB2AP PB3CR PB3AP\n"); - mtdcr(EBC0_CFGADDR,PB0CR); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB0AP); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB1CR); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB1AP); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB2CR); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB2AP); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB3CR); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB3AP); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - - puts ("\n" - "PB4CR PB4AP\n"); - mtdcr(EBC0_CFGADDR,PB4CR); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - mtdcr(EBC0_CFGADDR,PB4AP); printf ("%08x ", mfdcr(EBC0_CFGDATA)); - - puts ("\n\n"); +#elif defined (CONFIG_4xx) + ppc4xx_reginfo(); #elif defined(CONFIG_5xx)
volatile immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; diff --git a/cpu/ppc4xx/Makefile b/cpu/ppc4xx/Makefile index 2050b17..365f966 100644 --- a/cpu/ppc4xx/Makefile +++ b/cpu/ppc4xx/Makefile @@ -33,6 +33,7 @@ SOBJS += dcr.o SOBJS += kgdb.o
COBJS := 40x_spd_sdram.o + COBJS += 44x_spd_ddr.o COBJS += 44x_spd_ddr2.o ifdef CONFIG_PPC4xx_DDR_AUTOCALIBRATION @@ -54,6 +55,9 @@ COBJS += fdt.o COBJS += i2c.o COBJS += interrupts.o COBJS += iop480_uart.o +ifdef CONFIG_CMD_REGINFO +COBJS += reginfo.o +endif COBJS += sdram.o COBJS += speed.o COBJS += tlb.o diff --git a/cpu/ppc4xx/reginfo.c b/cpu/ppc4xx/reginfo.c new file mode 100644 index 0000000..a975667 --- /dev/null +++ b/cpu/ppc4xx/reginfo.c @@ -0,0 +1,370 @@ +/* + *(C) Copyright 2005-2009 Netstal Maschinen AG + * Bruno Hars (Bruno.Hars@netstal.com) + * Niklaus Giger (Niklaus.Giger@netstal.com) + * + * This source code is free software; you can redistribute it + * and/or modify it in source code form under the terms of the GNU + * General Public License as published by the Free Software + * Foundation; either version 2 of the License, or (at your option) + * any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA + */ + +/* + * reginfo.c - register dump of HW-configuratin register for PPC4xx based board + */ + +#include <common.h> +#include <command.h> +#include <asm/processor.h> +#include <asm/io.h> +#include <asm/ppc4xx-uic.h> +#include <ppc4xx_enet.h> + +enum REGISTER_TYPE { + IDCR1, /* Indirectly Accessed DCR via SDRAM0_CFGADDR/SDRAM0_CFGDATA */ + IDCR2, /* Indirectly Accessed DCR via EBC0_CFGADDR/EBC0_CFGDATA */ + IDCR3, /* Indirectly Accessed DCR via EBM0_CFGADDR/EBM0_CFGDATA */ + IDCR4, /* Indirectly Accessed DCR via PPM0_CFGADDR/PPM0_CFGDATA */ + IDCR5, /* Indirectly Accessed DCR via CPR0_CFGADDR/CPR0_CFGDATA */ + IDCR6, /* Indirectly Accessed DCR via SDR0_CFGADDR/SDR0_CFGDATA */ + MM /* Directly Accessed MMIO Register */ +}; + +struct cpu_register { + char *name; + enum REGISTER_TYPE type; + u32 address; +}; + +/* + * PPC440EPx registers ordered for output + * name type addr size + * ------------------------------------------- + */ + +const struct cpu_register ppc4xx_reg[] = { + {"PB0CR", IDCR2, PB0CR}, + {"PB0AP", IDCR2, PB0AP}, + {"PB1CR", IDCR2, PB1CR}, + {"PB1AP", IDCR2, PB1AP}, + {"PB2CR", IDCR2, PB2CR}, + {"PB2AP", IDCR2, PB2AP}, + {"PB3CR", IDCR2, PB3CR}, + {"PB3AP", IDCR2, PB3AP}, + + {"PB4CR", IDCR2, PB4CR}, + {"PB4AP", IDCR2, PB4AP}, +#if !defined(CONFIG_405EP) + {"PB5CR", IDCR2, PB5CR}, + {"PB5AP", IDCR2, PB5AP}, + {"PB6CR", IDCR2, PB6CR}, + {"PB6AP", IDCR2, PB6AP}, + {"PB7CR", IDCR2, PB7CR}, + {"PB7AP", IDCR2, PB7AP}, +#endif + + {"PBEAR", IDCR2, PBEAR}, +#if defined(CONFIG_405EP) || defined (CONFIG_405GP) + {"PBESR0", IDCR2, PBESR0}, + {"PBESR1", IDCR2, PBESR1}, +#endif + {"EBC0_CFG", IDCR2, EBC0_CFG}, + +#ifdef CONFIG_405GP + {"SDRAM0_BESR0", IDCR1, SDRAM0_BESR0}, + {"SDRAM0_BESRS0", IDCR1, SDRAM0_BESRS0}, + {"SDRAM0_BESR1", IDCR1, SDRAM0_BESR1}, + {"SDRAM0_BESRS1", IDCR1, SDRAM0_BESRS1}, + {"SDRAM0_BEAR", IDCR1, SDRAM0_BEAR}, + {"SDRAM0_CFG", IDCR1, SDRAM0_CFG}, + {"SDRAM0_RTR", IDCR1, SDRAM0_RTR}, + {"SDRAM0_PMIT", IDCR1, SDRAM0_PMIT}, + + {"SDRAM0_B0CR", IDCR1, SDRAM0_B0CR}, + {"SDRAM0_B1CR", IDCR1, SDRAM0_B1CR}, + {"SDRAM0_B2CR", IDCR1, SDRAM0_B2CR}, + {"SDRAM0_B3CR", IDCR1, SDRAM0_B1CR}, + {"SDRAM0_TR", IDCR1, SDRAM0_TR}, + {"SDRAM0_ECCCFG", IDCR1, SDRAM0_B1CR}, + {"SDRAM0_ECCESR", IDCR1, SDRAM0_ECCESR}, + + +#endif + +#ifdef CONFIG_440EPX + {"SDR0_SDSTP0", IDCR6, SDR0_SDSTP0}, + {"SDR0_SDSTP1", IDCR6, SDR0_SDSTP1}, + {"SDR0_SDSTP2", IDCR6, SDR0_SDSTP2}, + {"SDR0_SDSTP3", IDCR6, SDR0_SDSTP3}, + {"SDR0_CUST0", IDCR6, SDR0_CUST0}, + {"SDR0_CUST1", IDCR6, SDR0_CUST1}, + {"SDR0_EBC0", IDCR6, SDR0_EBC0}, + {"SDR0_AMP0", IDCR6, SD0_AMP0}, + {"SDR0_AMP1", IDCR6, SD0_AMP1}, + {"SDR0_CP440", IDCR6, SDR0_CP440}, + {"SDR0_CRYP0", IDCR6, SDR0_CRYP0}, + {"SDR0_DDRCFG", IDCR6, SDR0_DDRCFG}, + {"SDR0_EMAC0RXST", IDCR6, SDR0_EMAC0RXST}, + {"SDR0_EMAC0TXST", IDCR6, SDR0_EMAC0TXST}, + {"SDR0_MFR", IDCR6, SDR0_MFR}, + {"SDR0_PCI0", IDCR6, SDR0_PCI0}, + {"SDR0_PFC0", IDCR6, SDR0_PFC0}, + {"SDR0_PFC1", IDCR6, SDR0_PFC1}, + {"SDR0_PFC2", IDCR6, SDR0_PFC2}, + {"SDR0_PFC4", IDCR6, SDR0_PFC4}, + {"SDR0_UART0", IDCR6, SDR0_UART0}, + {"SDR0_UART1", IDCR6, SDR0_UART1}, + {"SDR0_UART2", IDCR6, SDR0_UART2}, + {"SDR0_UART3", IDCR6, SDR0_UART3}, + {"DDR0_02", IDCR1, DDR0_02}, + {"DDR0_00", IDCR1, DDR0_00}, + {"DDR0_01", IDCR1, DDR0_01}, + {"DDR0_03", IDCR1, DDR0_03}, + {"DDR0_04", IDCR1, DDR0_04}, + {"DDR0_05", IDCR1, DDR0_05}, + {"DDR0_06", IDCR1, DDR0_06}, + {"DDR0_07", IDCR1, DDR0_07}, + {"DDR0_08", IDCR1, DDR0_08}, + {"DDR0_09", IDCR1, DDR0_09}, + {"DDR0_10", IDCR1, DDR0_10}, + {"DDR0_11", IDCR1, DDR0_11}, + {"DDR0_12", IDCR1, DDR0_12}, + {"DDR0_14", IDCR1, DDR0_14}, + {"DDR0_17", IDCR1, DDR0_17}, + {"DDR0_18", IDCR1, DDR0_18}, + {"DDR0_19", IDCR1, DDR0_19}, + {"DDR0_20", IDCR1, DDR0_20}, + {"DDR0_21", IDCR1, DDR0_21}, + {"DDR0_22", IDCR1, DDR0_22}, + {"DDR0_23", IDCR1, DDR0_23}, + {"DDR0_24", IDCR1, DDR0_24}, + {"DDR0_25", IDCR1, DDR0_25}, + {"DDR0_26", IDCR1, DDR0_26}, + {"DDR0_27", IDCR1, DDR0_27}, + {"DDR0_28", IDCR1, DDR0_28}, + {"DDR0_31", IDCR1, DDR0_31}, + {"DDR0_32", IDCR1, DDR0_32}, + {"DDR0_33", IDCR1, DDR0_33}, + {"DDR0_34", IDCR1, DDR0_34}, + {"DDR0_35", IDCR1, DDR0_35}, + {"DDR0_36", IDCR1, DDR0_36}, + {"DDR0_37", IDCR1, DDR0_37}, + {"DDR0_38", IDCR1, DDR0_38}, + {"DDR0_39", IDCR1, DDR0_39}, + {"DDR0_40", IDCR1, DDR0_40}, + {"DDR0_41", IDCR1, DDR0_41}, + {"DDR0_42", IDCR1, DDR0_42}, + {"DDR0_43", IDCR1, DDR0_43}, + {"DDR0_44", IDCR1, DDR0_44}, + {"CPR0_ICFG", IDCR5, CPR0_ICFG}, + {"CPR0_MALD", IDCR5, CPR0_MALD}, + {"CPR0_OPBD00", IDCR5, CPR0_OPBD0}, + {"CPR0_PERD0", IDCR5, CPR0_PERD}, + {"CPR0_PLLC0", IDCR5, CPR0_PLLC}, + {"CPR0_PLLD0", IDCR5, CPR0_PLLD}, + {"CPR0_PRIMAD0", IDCR5, CPR0_PRIMAD0}, + {"CPR0_PRIMBD0", IDCR5, CPR0_PRIMBD0}, + {"CPR0_SPCID", IDCR5, CPR0_SPCID}, + {"SPI0_MODE", MM, SPI0_MODE}, + {"IIC0_CLKDIV", MM, PCIL0_PMM1MA}, + {"PCIL0_PMM0MA", MM, PCIL0_PMM0MA}, + {"PCIL0_PMM1MA", MM, PCIL0_PMM1MA}, + {"PCIL0_PTM1LA", MM, PCIL0_PMM1MA}, + {"PCIL0_PTM1MS", MM, PCIL0_PTM1MS}, + {"PCIL0_PTM2LA", MM, PCIL0_PMM1MA}, + {"PCIL0_PTM2MS", MM, PCIL0_PTM2MS}, + {"ZMII0_FER", MM, ZMII0_FER}, + {"ZMII0_SSR", MM, ZMII0_SSR}, + {"EMAC0_IPGVR", MM, EMAC0_IPGVR}, + {"EMAC0_MR1", MM, EMAC0_MR1}, + {"EMAC0_PTR", MM, EMAC0_PTR}, + {"EMAC0_RWMR", MM, EMAC0_RWMR}, + {"EMAC0_STACR", MM, EMAC0_STACR}, + {"EMAC0_TMR0", MM, EMAC0_TMR0}, + {"EMAC0_TMR1", MM, EMAC0_TMR1}, + {"EMAC0_TRTR", MM, EMAC0_TRTR}, + {"EMAC1_MR1", MM, EMAC1_MR1}, + {"GPIO0_OR", MM, GPIO0_OR}, + {"GPIO1_OR", MM, GPIO1_OR}, + {"GPIO0_TCR", MM, GPIO0_TCR}, + {"GPIO1_TCR", MM, GPIO1_TCR}, + {"GPIO0_ODR", MM, GPIO0_ODR}, + {"GPIO1_ODR", MM, GPIO1_ODR}, + {"GPIO0_OSRL", MM, GPIO0_OSRL}, + {"GPIO0_OSRH", MM, GPIO0_OSRH}, + {"GPIO1_OSRL", MM, GPIO1_OSRL}, + {"GPIO1_OSRH", MM, GPIO1_OSRH}, + {"GPIO0_TSRL", MM, GPIO0_TSRL}, + {"GPIO0_TSRH", MM, GPIO0_TSRH}, + {"GPIO1_TSRL", MM, GPIO1_TSRL}, + {"GPIO1_TSRH", MM, GPIO1_TSRH}, + {"GPIO0_IR", MM, GPIO0_IR}, + {"GPIO1_IR", MM, GPIO1_IR}, + {"GPIO0_ISR1L", MM, GPIO0_ISR1L}, + {"GPIO0_ISR1H", MM, GPIO0_ISR1H}, + {"GPIO1_ISR1L", MM, GPIO1_ISR1L}, + {"GPIO1_ISR1H", MM, GPIO1_ISR1H}, + {"GPIO0_ISR2L", MM, GPIO0_ISR2L}, + {"GPIO0_ISR2H", MM, GPIO0_ISR2H}, + {"GPIO1_ISR2L", MM, GPIO1_ISR2L}, + {"GPIO1_ISR2H", MM, GPIO1_ISR2H}, + {"GPIO0_ISR3L", MM, GPIO0_ISR3L}, + {"GPIO0_ISR3H", MM, GPIO0_ISR3H}, + {"GPIO1_ISR3L", MM, GPIO1_ISR3L}, + {"GPIO1_ISR3H", MM, GPIO1_ISR3H}, + {"SDR0_USB2PHY0CR", IDCR6, SDR0_USB2PHY0CR}, + {"SDR0_USB2H0CR", IDCR6, SDR0_USB2H0CR}, + {"SDR0_USB2D0CR", IDCR6, SDR0_USB2D0CR}, +#endif +}; + +/* + * CPU Register dump of PPC4xx HW configuration registers + * Output: first all DCR-registers, then in order of struct ppc4xx_reg + */ +#define PRINT_DCR(dcr) printf("0x%08x %-16s: 0x%08x\n", dcr,#dcr, mfdcr(dcr)); + +void ppc4xx_reginfo(void) +{ + unsigned int i; + unsigned int n; + u32 value; + enum REGISTER_TYPE type; +#if defined (CONFIG_405EP) + printf("Dump PPC405EP HW configuration registers\n\n"); +#elif CONFIG_405GP + printf ("Dump 405GP HW configuration registers\n\n"); +#elif CONFIG_440EPX + printf("Dump PPC440EPx HW configuration registers\n\n"); +#endif + printf("MSR: 0x%08x\n", mfmsr()); + + printf ("\nUniversal Interrupt Controller Regs\n"); + PRINT_DCR(UIC0SR); + PRINT_DCR(UIC0ER); + PRINT_DCR(UIC0CR); + PRINT_DCR(UIC0PR); + PRINT_DCR(UIC0TR); + PRINT_DCR(UIC0MSR); + PRINT_DCR(UIC0VR); + PRINT_DCR(UIC0VCR); + +#if (UIC_MAX > 1) + PRINT_DCR(UIC2SR); + PRINT_DCR(UIC2ER); + PRINT_DCR(UIC2CR); + PRINT_DCR(UIC2PR); + PRINT_DCR(UIC2TR); + PRINT_DCR(UIC2MSR); + PRINT_DCR(UIC2VR); + PRINT_DCR(UIC2VCR); +#endif + +#if (UIC_MAX > 2) + PRINT_DCR(UIC2SR); + PRINT_DCR(UIC2ER); + PRINT_DCR(UIC2CR); + PRINT_DCR(UIC2PR); + PRINT_DCR(UIC2TR); + PRINT_DCR(UIC2MSR); + PRINT_DCR(UIC2VR); + PRINT_DCR(UIC2VCR); +#endif + +#if (UIC_MAX > 3) + PRINT_DCR(UIC3SR); + PRINT_DCR(UIC3ER); + PRINT_DCR(UIC3CR); + PRINT_DCR(UIC3PR); + PRINT_DCR(UIC3TR); + PRINT_DCR(UIC3MSR); + PRINT_DCR(UIC3VR); + PRINT_DCR(UIC3VCR); +#endif + +#if defined (CONFIG_405EP) || defined (CONFIG_405GP) + printf ("\n\nDMA Channels\n"); + PRINT_DCR(DMASR); + PRINT_DCR(DMASGC); + PRINT_DCR(DMAADR); + + PRINT_DCR(DMACR0); + PRINT_DCR(DMACT0); + PRINT_DCR(DMADA0); + PRINT_DCR(DMASA0); + PRINT_DCR(DMASB0); + + PRINT_DCR(DMACR1); + PRINT_DCR(DMACT1); + PRINT_DCR(DMADA1); + PRINT_DCR(DMASA1); + PRINT_DCR(DMASB1); + + PRINT_DCR(DMACR2); + PRINT_DCR(DMACT2); + PRINT_DCR(DMADA2); + PRINT_DCR(DMASA2); + PRINT_DCR(DMASB2); + + PRINT_DCR(DMACR3); + PRINT_DCR(DMACT3); + PRINT_DCR(DMADA3); + PRINT_DCR(DMASA3); + PRINT_DCR(DMASB3); +#endif + + printf ("\n\nVarious HW-Configuration registers\n"); +#if defined (CONFIG_440EPX) + PRINT_DCR(MAL0_CFG); + PRINT_DCR(CPM0_ER); + PRINT_DCR(CPM1_ER); + PRINT_DCR(PLB4A0_ACR); + PRINT_DCR(PLB4A1_ACR); + PRINT_DCR(PLB3A0_ACR); + PRINT_DCR(OPB2PLB40_BCTRL); + PRINT_DCR(P4P3BO0_CFG); +#endif + n = sizeof(ppc4xx_reg) / sizeof(ppc4xx_reg[0]); + for (i = 0; i < n; i++) { + value = 0; + type = ppc4xx_reg[i].type; + switch (type) { + case IDCR1: /* Indirect via SDRAM0_CFGADDR/DDR0_CFGDATA */ + mtdcr(SDRAM0_CFGADDR, ppc4xx_reg[i].address); + value = mfdcr(SDRAM0_CFGDATA); + break; + case IDCR2: /* Indirect via EBC0_CFGADDR/EBC0_CFGDATA */ + mtdcr(EBC0_CFGADDR, ppc4xx_reg[i].address); + value = mfdcr(EBC0_CFGDATA); + break; + case IDCR5: /* Indirect via CPR0_CFGADDR/CPR0_CFGDATA */ + mtdcr(CPR0_CFGADDR, ppc4xx_reg[i].address); + value = mfdcr(CPR0_CFGDATA); + break; + case IDCR6: /* Indirect via SDR0_CFGADDR/SDR0_CFGDATA */ + mtdcr(SDR0_CFGADDR, ppc4xx_reg[i].address); + value = mfdcr(SDR0_CFGDATA); + break; + case MM: /* Directly Accessed MMIO Register */ + value = in_be32((const volatile unsigned __iomem *) + ppc4xx_reg[i].address); + break; + default: + printf("\nERROR: struct entry %d: unknown register" + "type\n", i); + break; + } + printf("0x%08x %-16s: 0x%08x\n",ppc4xx_reg[i].address, + ppc4xx_reg[i].name, value); + } +}
After running checkstyle.pl on the three previous patches I noted that in the *.h files there were a lot of long lines. This patch solves this problem.
Signed-off-by: Niklaus Giger niklaus.giger@member.fsf.org --- include/ppc405.h | 526 +++++++++++----------- include/ppc440.h | 1252 ++++++++++++++++++++++++++++--------------------- include/ppc4xx.h | 36 +- include/ppc4xx_enet.h | 94 ++-- 4 files changed, 1038 insertions(+), 870 deletions(-)
diff --git a/include/ppc405.h b/include/ppc405.h index 4c62249..508c77b 100644 --- a/include/ppc405.h +++ b/include/ppc405.h @@ -29,9 +29,9 @@ #define PPC_128MB_SACR_VALUE(addr) PPC_REG_VAL(PPC_128MB_SACR_BIT(addr),1)
#ifndef CONFIG_IOP480 -#define CONFIG_SYS_DCACHE_SIZE (16 << 10) /* For AMCC 405 CPUs */ +#define CONFIG_SYS_DCACHE_SIZE (16 << 10) /* For AMCC 405 CPUs */ #else -#define CONFIG_SYS_DCACHE_SIZE (2 << 10) /* For PLX IOP480 (403) */ +#define CONFIG_SYS_DCACHE_SIZE (2 << 10) /* For PLX IOP480(403)*/ #endif
/****************************************************************************** @@ -71,10 +71,10 @@ * Decompression Controller ******************************************************************************/ #define DECOMP_DCR_BASE 0x14 -#define KIAR (DECOMP_DCR_BASE+0x0) /* Decompression controller addr reg */ -#define KIDR (DECOMP_DCR_BASE+0x1) /* Decompression controller data reg */ +#define KIAR (DECOMP_DCR_BASE+0x0) /* Decompression controller addr reg */ +#define KIDR (DECOMP_DCR_BASE+0x1) /* Decompression controller data reg */ /* values for kiar register - indirect addressing of these regs */ -#define KCONF 0x40 /* decompression core config register */ +#define KCONF 0x40 /* decompression core config register */ #endif
/****************************************************************************** @@ -85,61 +85,61 @@ #else #define POWERMAN_DCR_BASE 0xb8 #endif -#define CPMSR (POWERMAN_DCR_BASE+0x0) /* Power management status */ -#define CPMER (POWERMAN_DCR_BASE+0x1) /* Power management enable */ -#define CPMFR (POWERMAN_DCR_BASE+0x2) /* Power management force */ +#define CPMSR (POWERMAN_DCR_BASE+0x0) /* Power management status */ +#define CPMER (POWERMAN_DCR_BASE+0x1) /* Power management enable */ +#define CPMFR (POWERMAN_DCR_BASE+0x2) /* Power management force */
/****************************************************************************** * Extrnal Bus Controller ******************************************************************************/ /* values for EBC0_CFGADDR register - indirect addressing of these regs */ - #define PB0CR 0x00 /* periph bank 0 config reg */ - #define PB1CR 0x01 /* periph bank 1 config reg */ - #define PB2CR 0x02 /* periph bank 2 config reg */ - #define PB3CR 0x03 /* periph bank 3 config reg */ - #define PB4CR 0x04 /* periph bank 4 config reg */ + #define PB0CR 0x00 /* periph bank 0 config reg */ + #define PB1CR 0x01 /* periph bank 1 config reg */ + #define PB2CR 0x02 /* periph bank 2 config reg */ + #define PB3CR 0x03 /* periph bank 3 config reg */ + #define PB4CR 0x04 /* periph bank 4 config reg */ #ifndef CONFIG_405EP - #define PB5CR 0x05 /* periph bank 5 config reg */ - #define PB6CR 0x06 /* periph bank 6 config reg */ - #define PB7CR 0x07 /* periph bank 7 config reg */ + #define PB5CR 0x05 /* periph bank 5 config reg */ + #define PB6CR 0x06 /* periph bank 6 config reg */ + #define PB7CR 0x07 /* periph bank 7 config reg */ #endif - #define PB0AP 0x10 /* periph bank 0 access parameters */ - #define PB1AP 0x11 /* periph bank 1 access parameters */ - #define PB2AP 0x12 /* periph bank 2 access parameters */ - #define PB3AP 0x13 /* periph bank 3 access parameters */ - #define PB4AP 0x14 /* periph bank 4 access parameters */ + #define PB0AP 0x10 /* periph bank 0 access parameters */ + #define PB1AP 0x11 /* periph bank 1 access parameters */ + #define PB2AP 0x12 /* periph bank 2 access parameters */ + #define PB3AP 0x13 /* periph bank 3 access parameters */ + #define PB4AP 0x14 /* periph bank 4 access parameters */ #ifndef CONFIG_405EP - #define PB5AP 0x15 /* periph bank 5 access parameters */ - #define PB6AP 0x16 /* periph bank 6 access parameters */ - #define PB7AP 0x17 /* periph bank 7 access parameters */ + #define PB5AP 0x15 /* periph bank 5 access parameters */ + #define PB6AP 0x16 /* periph bank 6 access parameters */ + #define PB7AP 0x17 /* periph bank 7 access parameters */ #endif - #define PBEAR 0x20 /* periph bus error addr reg */ - #define PBESR0 0x21 /* periph bus error status reg 0 */ - #define PBESR1 0x22 /* periph bus error status reg 1 */ -#define EBC0_CFG 0x23 /* external bus configuration reg */ + #define PBEAR 0x20 /* periph bus error addr reg */ + #define PBESR0 0x21 /* periph bus error status reg 0 */ + #define PBESR1 0x22 /* periph bus error status reg 1 */ +#define EBC0_CFG 0x23 /* external bus configuration reg */
#ifdef CONFIG_405EP /****************************************************************************** * Control ******************************************************************************/ #define CNTRL_DCR_BASE 0x0f0 -#define CPC0_PLLMR0 (CNTRL_DCR_BASE+0x0) /* PLL mode register 0 */ -#define CPC0_BOOT (CNTRL_DCR_BASE+0x1) /* Clock status register */ -#define CPC0_EPCTL (CNTRL_DCR_BASE+0x3) /* EMAC to PHY control register */ -#define CPC0_PLLMR1 (CNTRL_DCR_BASE+0x4) /* PLL mode register 1 */ -#define CPC0_UCR (CNTRL_DCR_BASE+0x5) /* UART control register */ -#define CPC0_PCI (CNTRL_DCR_BASE+0x9) /* PCI control register */ - -#define CPC0_PLLMR0 (CNTRL_DCR_BASE+0x0) /* PLL mode 0 register */ -#define CPC0_BOOT (CNTRL_DCR_BASE+0x1) /* Chip Clock Status register */ -#define CPC0_CR1 (CNTRL_DCR_BASE+0x2) /* Chip Control 1 register */ -#define CPC0_EPRCSR (CNTRL_DCR_BASE+0x3) /* EMAC PHY Rcv Clk Src register*/ -#define CPC0_PLLMR1 (CNTRL_DCR_BASE+0x4) /* PLL mode 1 register */ -#define CPC0_UCR (CNTRL_DCR_BASE+0x5) /* UART Control register */ -#define CPC0_SRR (CNTRL_DCR_BASE+0x6) /* Soft Reset register */ -#define CPC0_JTAGID (CNTRL_DCR_BASE+0x7) /* JTAG ID register */ -#define CPC0_SPARE (CNTRL_DCR_BASE+0x8) /* Spare DCR */ -#define CPC0_PCI (CNTRL_DCR_BASE+0x9) /* PCI Control register */ +#define CPC0_PLLMR0 (CNTRL_DCR_BASE+0x0) /* PLL mode register 0 */ +#define CPC0_BOOT (CNTRL_DCR_BASE+0x1) /* Clock status register */ +#define CPC0_EPCTL (CNTRL_DCR_BASE+0x3) /* EMAC to PHY control register */ +#define CPC0_PLLMR1 (CNTRL_DCR_BASE+0x4) /* PLL mode register 1 */ +#define CPC0_UCR (CNTRL_DCR_BASE+0x5) /* UART control register */ +#define CPC0_PCI (CNTRL_DCR_BASE+0x9) /* PCI control register */ + +#define CPC0_PLLMR0 (CNTRL_DCR_BASE+0x0) /* PLL mode 0 register */ +#define CPC0_BOOT (CNTRL_DCR_BASE+0x1) /* Chip Clock Status register */ +#define CPC0_CR1 (CNTRL_DCR_BASE+0x2) /* Chip Control 1 register */ +#define CPC0_EPRCSR (CNTRL_DCR_BASE+0x3) /* EMAC PHY Rcv Clk Src register */ +#define CPC0_PLLMR1 (CNTRL_DCR_BASE+0x4) /* PLL mode 1 register */ +#define CPC0_UCR (CNTRL_DCR_BASE+0x5) /* UART Control register */ +#define CPC0_SRR (CNTRL_DCR_BASE+0x6) /* Soft Reset register */ +#define CPC0_JTAGID (CNTRL_DCR_BASE+0x7) /* JTAG ID register */ +#define CPC0_SPARE (CNTRL_DCR_BASE+0x8) /* Spare DCR */ +#define CPC0_PCI (CNTRL_DCR_BASE+0x9) /* PCI Control register */
/* Bit definitions */ #define PLLMR0_CPU_DIV_MASK 0x00300000 /* CPU clock divider */ @@ -160,13 +160,13 @@ #define PLLMR0_OPB_PLB_DIV_3 0x00002000 #define PLLMR0_OPB_PLB_DIV_4 0x00003000
-#define PLLMR0_EXB_TO_PLB_MASK 0x00000300 /* External Bus:PLB Divisor */ +#define PLLMR0_EXB_TO_PLB_MASK 0x00000300 /* External Bus:PLB Divisor */ #define PLLMR0_EXB_PLB_DIV_2 0x00000000 #define PLLMR0_EXB_PLB_DIV_3 0x00000100 #define PLLMR0_EXB_PLB_DIV_4 0x00000200 #define PLLMR0_EXB_PLB_DIV_5 0x00000300
-#define PLLMR0_MAL_TO_PLB_MASK 0x00000030 /* MAL:PLB Divisor */ +#define PLLMR0_MAL_TO_PLB_MASK 0x00000030 /* MAL:PLB Divisor */ #define PLLMR0_MAL_PLB_DIV_1 0x00000000 #define PLLMR0_MAL_PLB_DIV_2 0x00000010 #define PLLMR0_MAL_PLB_DIV_3 0x00000020 @@ -180,7 +180,7 @@
#define PLLMR1_SSCS_MASK 0x80000000 /* Select system clock source */ #define PLLMR1_PLLR_MASK 0x40000000 /* PLL reset */ -#define PLLMR1_FBMUL_MASK 0x00F00000 /* PLL feedback multiplier value */ +#define PLLMR1_FBMUL_MASK 0x00F00000 /* PLL feedback multiplier value */ #define PLLMR1_FBMUL_DIV_16 0x00000000 #define PLLMR1_FBMUL_DIV_1 0x00100000 #define PLLMR1_FBMUL_DIV_2 0x00200000 @@ -198,7 +198,7 @@ #define PLLMR1_FBMUL_DIV_14 0x00E00000 #define PLLMR1_FBMUL_DIV_15 0x00F00000
-#define PLLMR1_FWDVA_MASK 0x00070000 /* PLL forward divider A value */ +#define PLLMR1_FWDVA_MASK 0x00070000 /* PLL forward divider A value */ #define PLLMR1_FWDVA_DIV_8 0x00000000 #define PLLMR1_FWDVA_DIV_7 0x00010000 #define PLLMR1_FWDVA_DIV_6 0x00020000 @@ -207,132 +207,132 @@ #define PLLMR1_FWDVA_DIV_3 0x00050000 #define PLLMR1_FWDVA_DIV_2 0x00060000 #define PLLMR1_FWDVA_DIV_1 0x00070000 -#define PLLMR1_FWDVB_MASK 0x00007000 /* PLL forward divider B value */ -#define PLLMR1_TUNING_MASK 0x000003FF /* PLL tune bits */ +#define PLLMR1_FWDVB_MASK 0x00007000 /* PLL forward divider B value */ +#define PLLMR1_TUNING_MASK 0x000003FF /* PLL tune bits */
/* Defines for CPC0_EPRCSR register */ -#define CPC0_EPRCSR_E0NFE 0x80000000 -#define CPC0_EPRCSR_E1NFE 0x40000000 -#define CPC0_EPRCSR_E1RPP 0x00000080 -#define CPC0_EPRCSR_E0RPP 0x00000040 -#define CPC0_EPRCSR_E1ERP 0x00000020 -#define CPC0_EPRCSR_E0ERP 0x00000010 -#define CPC0_EPRCSR_E1PCI 0x00000002 -#define CPC0_EPRCSR_E0PCI 0x00000001 +#define CPC0_EPRCSR_E0NFE 0x80000000 +#define CPC0_EPRCSR_E1NFE 0x40000000 +#define CPC0_EPRCSR_E1RPP 0x00000080 +#define CPC0_EPRCSR_E0RPP 0x00000040 +#define CPC0_EPRCSR_E1ERP 0x00000020 +#define CPC0_EPRCSR_E0ERP 0x00000010 +#define CPC0_EPRCSR_E1PCI 0x00000002 +#define CPC0_EPRCSR_E0PCI 0x00000001
/* Defines for CPC0_PCI Register */ -#define CPC0_PCI_SPE 0x00000010 /* PCIINT/WE select */ -#define CPC0_PCI_HOST_CFG_EN 0x00000008 /* PCI host config Enable */ -#define CPC0_PCI_ARBIT_EN 0x00000001 /* PCI Internal Arb Enabled*/ +#define CPC0_PCI_SPE 0x00000010 /* PCIINT/WE select */ +#define CPC0_PCI_HOST_CFG_EN 0x00000008 /* PCI host config Enable */ +#define CPC0_PCI_ARBIT_EN 0x00000001 /* PCI Internal Arb Enabled */
/* Defines for CPC0_BOOR Register */ -#define CPC0_BOOT_SEP 0x00000002 /* serial EEPROM present */ +#define CPC0_BOOT_SEP 0x00000002 /* serial EEPROM present */
/* Defines for CPC0_PLLMR1 Register fields */ -#define PLL_ACTIVE 0x80000000 -#define CPC0_PLLMR1_SSCS 0x80000000 -#define PLL_RESET 0x40000000 -#define CPC0_PLLMR1_PLLR 0x40000000 - /* Feedback multiplier */ -#define PLL_FBKDIV 0x00F00000 -#define CPC0_PLLMR1_FBDV 0x00F00000 -#define PLL_FBKDIV_16 0x00000000 -#define PLL_FBKDIV_1 0x00100000 -#define PLL_FBKDIV_2 0x00200000 -#define PLL_FBKDIV_3 0x00300000 -#define PLL_FBKDIV_4 0x00400000 -#define PLL_FBKDIV_5 0x00500000 -#define PLL_FBKDIV_6 0x00600000 -#define PLL_FBKDIV_7 0x00700000 -#define PLL_FBKDIV_8 0x00800000 -#define PLL_FBKDIV_9 0x00900000 -#define PLL_FBKDIV_10 0x00A00000 -#define PLL_FBKDIV_11 0x00B00000 -#define PLL_FBKDIV_12 0x00C00000 -#define PLL_FBKDIV_13 0x00D00000 -#define PLL_FBKDIV_14 0x00E00000 -#define PLL_FBKDIV_15 0x00F00000 - /* Forward A divisor */ -#define PLL_FWDDIVA 0x00070000 -#define CPC0_PLLMR1_FWDVA 0x00070000 -#define PLL_FWDDIVA_8 0x00000000 -#define PLL_FWDDIVA_7 0x00010000 -#define PLL_FWDDIVA_6 0x00020000 -#define PLL_FWDDIVA_5 0x00030000 -#define PLL_FWDDIVA_4 0x00040000 -#define PLL_FWDDIVA_3 0x00050000 -#define PLL_FWDDIVA_2 0x00060000 -#define PLL_FWDDIVA_1 0x00070000 - /* Forward B divisor */ -#define PLL_FWDDIVB 0x00007000 -#define CPC0_PLLMR1_FWDVB 0x00007000 -#define PLL_FWDDIVB_8 0x00000000 -#define PLL_FWDDIVB_7 0x00001000 -#define PLL_FWDDIVB_6 0x00002000 -#define PLL_FWDDIVB_5 0x00003000 -#define PLL_FWDDIVB_4 0x00004000 -#define PLL_FWDDIVB_3 0x00005000 -#define PLL_FWDDIVB_2 0x00006000 -#define PLL_FWDDIVB_1 0x00007000 - /* PLL tune bits */ +#define PLL_ACTIVE 0x80000000 +#define CPC0_PLLMR1_SSCS 0x80000000 +#define PLL_RESET 0x40000000 +#define CPC0_PLLMR1_PLLR 0x40000000 + /* Feedback multiplier */ +#define PLL_FBKDIV 0x00F00000 +#define CPC0_PLLMR1_FBDV 0x00F00000 +#define PLL_FBKDIV_16 0x00000000 +#define PLL_FBKDIV_1 0x00100000 +#define PLL_FBKDIV_2 0x00200000 +#define PLL_FBKDIV_3 0x00300000 +#define PLL_FBKDIV_4 0x00400000 +#define PLL_FBKDIV_5 0x00500000 +#define PLL_FBKDIV_6 0x00600000 +#define PLL_FBKDIV_7 0x00700000 +#define PLL_FBKDIV_8 0x00800000 +#define PLL_FBKDIV_9 0x00900000 +#define PLL_FBKDIV_10 0x00A00000 +#define PLL_FBKDIV_11 0x00B00000 +#define PLL_FBKDIV_12 0x00C00000 +#define PLL_FBKDIV_13 0x00D00000 +#define PLL_FBKDIV_14 0x00E00000 +#define PLL_FBKDIV_15 0x00F00000 + /* Forward A divisor */ +#define PLL_FWDDIVA 0x00070000 +#define CPC0_PLLMR1_FWDVA 0x00070000 +#define PLL_FWDDIVA_8 0x00000000 +#define PLL_FWDDIVA_7 0x00010000 +#define PLL_FWDDIVA_6 0x00020000 +#define PLL_FWDDIVA_5 0x00030000 +#define PLL_FWDDIVA_4 0x00040000 +#define PLL_FWDDIVA_3 0x00050000 +#define PLL_FWDDIVA_2 0x00060000 +#define PLL_FWDDIVA_1 0x00070000 + /* Forward B divisor */ +#define PLL_FWDDIVB 0x00007000 +#define CPC0_PLLMR1_FWDVB 0x00007000 +#define PLL_FWDDIVB_8 0x00000000 +#define PLL_FWDDIVB_7 0x00001000 +#define PLL_FWDDIVB_6 0x00002000 +#define PLL_FWDDIVB_5 0x00003000 +#define PLL_FWDDIVB_4 0x00004000 +#define PLL_FWDDIVB_3 0x00005000 +#define PLL_FWDDIVB_2 0x00006000 +#define PLL_FWDDIVB_1 0x00007000 + /* PLL tune bits */ #define PLL_TUNE_MASK 0x000003FF -#define PLL_TUNE_2_M_3 0x00000133 /* 2 <= M <= 3 */ -#define PLL_TUNE_4_M_6 0x00000134 /* 3 < M <= 6 */ -#define PLL_TUNE_7_M_10 0x00000138 /* 6 < M <= 10 */ -#define PLL_TUNE_11_M_14 0x0000013C /* 10 < M <= 14 */ -#define PLL_TUNE_15_M_40 0x0000023E /* 14 < M <= 40 */ -#define PLL_TUNE_VCO_LOW 0x00000000 /* 500MHz <= VCO <= 800MHz */ -#define PLL_TUNE_VCO_HI 0x00000080 /* 800MHz < VCO <= 1000MHz */ +#define PLL_TUNE_2_M_3 0x00000133 /* 2 <= M <= 3 */ +#define PLL_TUNE_4_M_6 0x00000134 /* 3 < M <= 6 */ +#define PLL_TUNE_7_M_10 0x00000138 /* 6 < M <= 10 */ +#define PLL_TUNE_11_M_14 0x0000013C /* 10 < M <= 14 */ +#define PLL_TUNE_15_M_40 0x0000023E /* 14 < M <= 40 */ +#define PLL_TUNE_VCO_LOW 0x00000000 /* 500MHz <= VCO <= 800MHz */ +#define PLL_TUNE_VCO_HI 0x00000080 /* 800MHz < VCO <= 1000MHz */
/* Defines for CPC0_PLLMR0 Register fields */ - /* CPU divisor */ -#define PLL_CPUDIV 0x00300000 -#define CPC0_PLLMR0_CCDV 0x00300000 -#define PLL_CPUDIV_1 0x00000000 -#define PLL_CPUDIV_2 0x00100000 -#define PLL_CPUDIV_3 0x00200000 -#define PLL_CPUDIV_4 0x00300000 - /* PLB divisor */ -#define PLL_PLBDIV 0x00030000 -#define CPC0_PLLMR0_CBDV 0x00030000 -#define PLL_PLBDIV_1 0x00000000 -#define PLL_PLBDIV_2 0x00010000 -#define PLL_PLBDIV_3 0x00020000 -#define PLL_PLBDIV_4 0x00030000 - /* OPB divisor */ -#define PLL_OPBDIV 0x00003000 -#define CPC0_PLLMR0_OPDV 0x00003000 -#define PLL_OPBDIV_1 0x00000000 -#define PLL_OPBDIV_2 0x00001000 -#define PLL_OPBDIV_3 0x00002000 -#define PLL_OPBDIV_4 0x00003000 - /* EBC divisor */ -#define PLL_EXTBUSDIV 0x00000300 -#define CPC0_PLLMR0_EPDV 0x00000300 -#define PLL_EXTBUSDIV_2 0x00000000 -#define PLL_EXTBUSDIV_3 0x00000100 -#define PLL_EXTBUSDIV_4 0x00000200 -#define PLL_EXTBUSDIV_5 0x00000300 - /* MAL divisor */ -#define PLL_MALDIV 0x00000030 -#define CPC0_PLLMR0_MPDV 0x00000030 -#define PLL_MALDIV_1 0x00000000 -#define PLL_MALDIV_2 0x00000010 -#define PLL_MALDIV_3 0x00000020 -#define PLL_MALDIV_4 0x00000030 - /* PCI divisor */ -#define PLL_PCIDIV 0x00000003 -#define CPC0_PLLMR0_PPFD 0x00000003 -#define PLL_PCIDIV_1 0x00000000 -#define PLL_PCIDIV_2 0x00000001 -#define PLL_PCIDIV_3 0x00000002 -#define PLL_PCIDIV_4 0x00000003 + /* CPU divisor */ +#define PLL_CPUDIV 0x00300000 +#define CPC0_PLLMR0_CCDV 0x00300000 +#define PLL_CPUDIV_1 0x00000000 +#define PLL_CPUDIV_2 0x00100000 +#define PLL_CPUDIV_3 0x00200000 +#define PLL_CPUDIV_4 0x00300000 + /* PLB divisor */ +#define PLL_PLBDIV 0x00030000 +#define CPC0_PLLMR0_CBDV 0x00030000 +#define PLL_PLBDIV_1 0x00000000 +#define PLL_PLBDIV_2 0x00010000 +#define PLL_PLBDIV_3 0x00020000 +#define PLL_PLBDIV_4 0x00030000 + /* OPB divisor */ +#define PLL_OPBDIV 0x00003000 +#define CPC0_PLLMR0_OPDV 0x00003000 +#define PLL_OPBDIV_1 0x00000000 +#define PLL_OPBDIV_2 0x00001000 +#define PLL_OPBDIV_3 0x00002000 +#define PLL_OPBDIV_4 0x00003000 + /* EBC divisor */ +#define PLL_EXTBUSDIV 0x00000300 +#define CPC0_PLLMR0_EPDV 0x00000300 +#define PLL_EXTBUSDIV_2 0x00000000 +#define PLL_EXTBUSDIV_3 0x00000100 +#define PLL_EXTBUSDIV_4 0x00000200 +#define PLL_EXTBUSDIV_5 0x00000300 + /* MAL divisor */ +#define PLL_MALDIV 0x00000030 +#define CPC0_PLLMR0_MPDV 0x00000030 +#define PLL_MALDIV_1 0x00000000 +#define PLL_MALDIV_2 0x00000010 +#define PLL_MALDIV_3 0x00000020 +#define PLL_MALDIV_4 0x00000030 + /* PCI divisor */ +#define PLL_PCIDIV 0x00000003 +#define CPC0_PLLMR0_PPFD 0x00000003 +#define PLL_PCIDIV_1 0x00000000 +#define PLL_PCIDIV_2 0x00000001 +#define PLL_PCIDIV_3 0x00000002 +#define PLL_PCIDIV_4 0x00000003
/* - *------------------------------------------------------------------------------- + *------------------------------------------------------------------------------ * PLL settings for 266MHz CPU, 133MHz PLB/SDRAM, 66MHz EBC, 33MHz PCI, * assuming a 33.3MHz input clock to the 405EP. - *------------------------------------------------------------------------------- + *------------------------------------------------------------------------------ */ #define PLLMR0_266_133_66 (PLL_CPUDIV_1 | PLL_PLBDIV_2 | \ PLL_OPBDIV_2 | PLL_EXTBUSDIV_2 | \ @@ -427,25 +427,25 @@ #define CPC0_PERD1 0x0e1 /* CPR_PERD1 */ #define CPC0_PERC0 0x180 /* CPR_PERC0 */
-#define CPR_CLKUPD_ENPLLCH_EN 0x40000000 /* Enable CPR PLL Changes */ -#define CPR_CLKUPD_ENDVCH_EN 0x20000000 /* Enable CPR Sys. Div. Changes */ -#define CPR_PERD0_SPIDV_MASK 0x000F0000 /* SPI Clock Divider */ +#define CPR_CLKUPD_ENPLLCH_EN 0x40000000 /* Enable CPR PLL Changes */ +#define CPR_CLKUPD_ENDVCH_EN 0x20000000 /* Enable CPR Sys. Div. Changes */ +#define CPR_PERD0_SPIDV_MASK 0x000F0000 /* SPI Clock Divider */
-#define PLLC_SRC_MASK 0x20000000 /* PLL feedback source */ +#define PLLC_SRC_MASK 0x20000000 /* PLL feedback source */
-#define PLLD_FBDV_MASK 0x1F000000 /* PLL feedback divider value */ -#define PLLD_FWDVA_MASK 0x000F0000 /* PLL forward divider A value */ -#define PLLD_FWDVB_MASK 0x00000700 /* PLL forward divider B value */ +#define PLLD_FBDV_MASK 0x1F000000 /* PLL feedback divider value */ +#define PLLD_FWDVA_MASK 0x000F0000 /* PLL forward divider A value */ +#define PLLD_FWDVB_MASK 0x00000700 /* PLL forward divider B value */
-#define PRIMAD_CPUDV_MASK 0x0F000000 /* CPU Clock Divisor Mask */ -#define PRIMAD_PLBDV_MASK 0x000F0000 /* PLB Clock Divisor Mask */ -#define PRIMAD_OPBDV_MASK 0x00000F00 /* OPB Clock Divisor Mask */ -#define PRIMAD_EBCDV_MASK 0x0000000F /* EBC Clock Divisor Mask */ +#define PRIMAD_CPUDV_MASK 0x0F000000 /* CPU Clock Divisor Mask */ +#define PRIMAD_PLBDV_MASK 0x000F0000 /* PLB Clock Divisor Mask */ +#define PRIMAD_OPBDV_MASK 0x00000F00 /* OPB Clock Divisor Mask */ +#define PRIMAD_EBCDV_MASK 0x0000000F /* EBC Clock Divisor Mask */
-#define PERD0_PWMDV_MASK 0xFF000000 /* PWM Divider Mask */ -#define PERD0_SPIDV_MASK 0x000F0000 /* SPI Divider Mask */ -#define PERD0_U0DV_MASK 0x0000FF00 /* UART 0 Divider Mask */ -#define PERD0_U1DV_MASK 0x000000FF /* UART 1 Divider Mask */ +#define PERD0_PWMDV_MASK 0xFF000000 /* PWM Divider Mask */ +#define PERD0_SPIDV_MASK 0x000F0000 /* SPI Divider Mask */ +#define PERD0_U0DV_MASK 0x0000FF00 /* UART 0 Divider Mask */ +#define PERD0_U1DV_MASK 0x000000FF /* UART 1 Divider Mask */
#else /* #ifdef CONFIG_405EP */ /****************************************************************************** @@ -462,13 +462,13 @@ #define CPC0_ECR 0xaa /* edge conditioner register */
/* Bit definitions */ -#define PLLMR_FWD_DIV_MASK 0xE0000000 /* Forward Divisor */ +#define PLLMR_FWD_DIV_MASK 0xE0000000 /* Forward Divisor */ #define PLLMR_FWD_DIV_BYPASS 0xE0000000 #define PLLMR_FWD_DIV_3 0xA0000000 #define PLLMR_FWD_DIV_4 0x80000000 #define PLLMR_FWD_DIV_6 0x40000000
-#define PLLMR_FB_DIV_MASK 0x1E000000 /* Feedback Divisor */ +#define PLLMR_FB_DIV_MASK 0x1E000000 /* Feedback Divisor */ #define PLLMR_FB_DIV_1 0x02000000 #define PLLMR_FB_DIV_2 0x04000000 #define PLLMR_FB_DIV_3 0x06000000 @@ -476,32 +476,32 @@
#define PLLMR_TUNING_MASK 0x01F80000
-#define PLLMR_CPU_TO_PLB_MASK 0x00060000 /* CPU:PLB Frequency Divisor */ +#define PLLMR_CPU_TO_PLB_MASK 0x00060000 /* CPU:PLB Frequency Divisor */ #define PLLMR_CPU_PLB_DIV_1 0x00000000 #define PLLMR_CPU_PLB_DIV_2 0x00020000 #define PLLMR_CPU_PLB_DIV_3 0x00040000 #define PLLMR_CPU_PLB_DIV_4 0x00060000
-#define PLLMR_OPB_TO_PLB_MASK 0x00018000 /* OPB:PLB Frequency Divisor */ +#define PLLMR_OPB_TO_PLB_MASK 0x00018000 /* OPB:PLB Frequency Divisor */ #define PLLMR_OPB_PLB_DIV_1 0x00000000 #define PLLMR_OPB_PLB_DIV_2 0x00008000 #define PLLMR_OPB_PLB_DIV_3 0x00010000 #define PLLMR_OPB_PLB_DIV_4 0x00018000
-#define PLLMR_PCI_TO_PLB_MASK 0x00006000 /* PCI:PLB Frequency Divisor */ +#define PLLMR_PCI_TO_PLB_MASK 0x00006000 /* PCI:PLB Frequency Divisor */ #define PLLMR_PCI_PLB_DIV_1 0x00000000 #define PLLMR_PCI_PLB_DIV_2 0x00002000 #define PLLMR_PCI_PLB_DIV_3 0x00004000 #define PLLMR_PCI_PLB_DIV_4 0x00006000
-#define PLLMR_EXB_TO_PLB_MASK 0x00001800 /* External Bus:PLB Divisor */ +#define PLLMR_EXB_TO_PLB_MASK 0x00001800 /* External Bus:PLB Divisor */ #define PLLMR_EXB_PLB_DIV_2 0x00000000 #define PLLMR_EXB_PLB_DIV_3 0x00000800 #define PLLMR_EXB_PLB_DIV_4 0x00001000 #define PLLMR_EXB_PLB_DIV_5 0x00001800
/* definitions for PPC405GPr (new mode strapping) */ -#define PLLMR_FWDB_DIV_MASK 0x00000007 /* Forward Divisor B */ +#define PLLMR_FWDB_DIV_MASK 0x00000007 /* Forward Divisor B */
#define PSR_PLL_FWD_MASK 0xC0000000 #define PSR_PLL_FDBACK_MASK 0x30000000 @@ -513,15 +513,15 @@ #define PSR_ROM_WIDTH_MASK 0x00018000 #define PSR_ROM_LOC 0x00004000 #define PSR_PCI_ASYNC_EN 0x00001000 -#define PSR_PERCLK_SYNC_MODE_EN 0x00000800 /* PPC405GPr only */ +#define PSR_PERCLK_SYNC_MODE_EN 0x00000800 /* PPC405GPr only */ #define PSR_PCI_ARBIT_EN 0x00000400 -#define PSR_NEW_MODE_EN 0x00000020 /* PPC405GPr only */ +#define PSR_NEW_MODE_EN 0x00000020 /* PPC405GPr only */
#ifndef CONFIG_IOP480 /* * PLL Voltage Controlled Oscillator (VCO) definitions * Maximum and minimum values (in MHz) for correct PLL operation. - */ +*/ #define VCO_MIN 400 #define VCO_MAX 800 #endif /* #ifndef CONFIG_IOP480 */ @@ -535,35 +535,35 @@ #else #define MAL_DCR_BASE 0x180 #endif -#define MAL0_CFG (MAL_DCR_BASE + 0x00) /* MAL Config reg */ -#define MAL0_ESR (MAL_DCR_BASE + 0x01) /* Err Status (Read/Clear)*/ -#define MAL0_IER (MAL_DCR_BASE + 0x02) /* Interrupt enable */ -#define MAL0_TXCASR (MAL_DCR_BASE + 0x04) /* TX Channel active (set)*/ -#define MAL0_TXCARR (MAL_DCR_BASE + 0x05) /* TX Channel active (reset)*/ -#define MAL0_TXEOBISR (MAL_DCR_BASE + 0x06) /* TX End of buffer int status*/ -#define MAL0_TXDEIR (MAL_DCR_BASE + 0x07) /* TX Descr. Error Int reg */ -#define MAL0_RXCASR (MAL_DCR_BASE + 0x10) /* RX Channel active (set) */ -#define MAL0_RXCARR (MAL_DCR_BASE + 0x11) /* RX Channel active (reset) */ -#define MAL0_RXEOBISR (MAL_DCR_BASE + 0x12) /* RX End of buffer int status*/ -#define MAL0_RXDEIR (MAL_DCR_BASE + 0x13) /* RX Descr. Error Int reg */ -#define MAL0_TXCTP0R (MAL_DCR_BASE + 0x20) /* TX 0 Channel table ptr */ -#define MAL0_TXCTP1R (MAL_DCR_BASE + 0x21) /* TX 1 Channel table ptr */ -#define MAL0_TXCTP2R (MAL_DCR_BASE + 0x22) /* TX 2 Channel table ptr */ -#define MAL0_TXCTP3R (MAL_DCR_BASE + 0x23) /* TX 3 Channel table ptr */ -#define MAL0_RXCTP0R (MAL_DCR_BASE + 0x40) /* RX 0 Channel table ptr */ -#define MAL0_RXCTP1R (MAL_DCR_BASE + 0x41) /* RX 1 Channel table ptr */ -#define MAL0_RXCTP2R (MAL_DCR_BASE + 0x42) /* RX 2 Channel table ptr */ -#define MAL0_RXCTP3R (MAL_DCR_BASE + 0x43) /* RX 3 Channel table ptr */ -#define MAL0_RXCTP8R (MAL_DCR_BASE + 0x48) /* RX 8 Channel table ptr */ -#define MAL0_RXCTP16R (MAL_DCR_BASE + 0x50) /* RX 16 Channel table ptr */ -#define MAL0_RXCTP24R (MAL_DCR_BASE + 0x58) /* RX 24 Channel table ptr */ -#define MAL0_RCBS0 (MAL_DCR_BASE + 0x60) /* RX 0 Channel buffer size */ -#define MAL0_RCBS1 (MAL_DCR_BASE + 0x61) /* RX 1 Channel buffer size */ -#define MAL0_RCBS2 (MAL_DCR_BASE + 0x62) /* RX 2 Channel buffer size */ -#define MAL0_RCBS3 (MAL_DCR_BASE + 0x63) /* RX 3 Channel buffer size */ -#define MAL0_RCBS8 (MAL_DCR_BASE + 0x68) /* RX 8 Channel buffer size */ -#define MAL0_RCBS16 (MAL_DCR_BASE + 0x70) /* RX 16 Channel buffer size */ -#define MAL0_RCBS24 (MAL_DCR_BASE + 0x78) /* RX 24 Channel buffer size */ +#define MAL0_CFG (MAL_DCR_BASE + 0x00) /* MAL Config reg */ +#define MAL0_ESR (MAL_DCR_BASE + 0x01) /* Err Status (Read/Clear) */ +#define MAL0_IER (MAL_DCR_BASE + 0x02) /* Interrupt enable */ +#define MAL0_TXCASR (MAL_DCR_BASE + 0x04) /* TX Channel active (set) */ +#define MAL0_TXCARR (MAL_DCR_BASE + 0x05) /* TX Channel active (reset) */ +#define MAL0_TXEOBISR (MAL_DCR_BASE + 0x06) /* TX End of buffer int status */ +#define MAL0_TXDEIR (MAL_DCR_BASE + 0x07) /* TX Descr. Error Int reg */ +#define MAL0_RXCASR (MAL_DCR_BASE + 0x10) /* RX Channel active (set) */ +#define MAL0_RXCARR (MAL_DCR_BASE + 0x11) /* RX Channel active (reset) */ +#define MAL0_RXEOBISR (MAL_DCR_BASE + 0x12) /* RX End of buffer int status */ +#define MAL0_RXDEIR (MAL_DCR_BASE + 0x13) /* RX Descr. Error Int reg */ +#define MAL0_TXCTP0R (MAL_DCR_BASE + 0x20) /* TX 0 Channel table ptr */ +#define MAL0_TXCTP1R (MAL_DCR_BASE + 0x21) /* TX 1 Channel table ptr */ +#define MAL0_TXCTP2R (MAL_DCR_BASE + 0x22) /* TX 2 Channel table ptr */ +#define MAL0_TXCTP3R (MAL_DCR_BASE + 0x23) /* TX 3 Channel table ptr */ +#define MAL0_RXCTP0R (MAL_DCR_BASE + 0x40) /* RX 0 Channel table ptr */ +#define MAL0_RXCTP1R (MAL_DCR_BASE + 0x41) /* RX 1 Channel table ptr */ +#define MAL0_RXCTP2R (MAL_DCR_BASE + 0x42) /* RX 2 Channel table ptr */ +#define MAL0_RXCTP3R (MAL_DCR_BASE + 0x43) /* RX 3 Channel table ptr */ +#define MAL0_RXCTP8R (MAL_DCR_BASE + 0x48) /* RX 8 Channel table ptr */ +#define MAL0_RXCTP16R (MAL_DCR_BASE + 0x50) /* RX 16 Channel table ptr */ +#define MAL0_RXCTP24R (MAL_DCR_BASE + 0x58) /* RX 24 Channel table ptr */ +#define MAL0_RCBS0 (MAL_DCR_BASE + 0x60) /* RX 0 Channel buffer size */ +#define MAL0_RCBS1 (MAL_DCR_BASE + 0x61) /* RX 1 Channel buffer size */ +#define MAL0_RCBS2 (MAL_DCR_BASE + 0x62) /* RX 2 Channel buffer size */ +#define MAL0_RCBS3 (MAL_DCR_BASE + 0x63) /* RX 3 Channel buffer size */ +#define MAL0_RCBS8 (MAL_DCR_BASE + 0x68) /* RX 8 Channel buffer size */ +#define MAL0_RCBS16 (MAL_DCR_BASE + 0x70) /* RX 16 Channel buffer size */ +#define MAL0_RCBS24 (MAL_DCR_BASE + 0x78) /* RX 24 Channel buffer size */
/*----------------------------------------------------------------------------- | IIC Register Offsets @@ -610,7 +610,7 @@ #define OCM0_DSRC2 (OCM_DCR_BASE + 0x09) /* OCM D-side Bank 2 Config */ #define OCM0_ISRC1 (OCM_DCR_BASE + 0x0A) /* OCM I-side Bank 1Config */ #define OCM0_ISRC2 (OCM_DCR_BASE + 0x0B) /* OCM I-side Bank 2 Config */ -#define OCM0_DISDPC (OCM_DCR_BASE + 0x0C) /* OCM D-/I-side Data Par Chk*/ +#define OCM0_DISDPC (OCM_DCR_BASE + 0x0C) /* OCM D-/I-side Data Par Chk */ #else #define OCM_DCR_BASE 0x018 #define OCM0_ISCNTL (OCM_DCR_BASE+0x01) /* OCM I-side control reg */ @@ -746,14 +746,14 @@ #define SDR0_MFR 0x4300 /* SDR0_MFR reg */
#define CPR0_CLKUPD 0x020 #define CPR0_PLLC 0x040 @@ -770,46 +770,46 @@
/* CUST0 Customer Configuration Register0 */ #define SDR0_CUST0 0x4000 -#define SDR0_CUST0_MUX_E_N_G_MASK 0xC0000000 /* Mux_Emac_NDFC_GPIO */ -#define SDR0_CUST0_MUX_EMAC_SEL 0x40000000 /* Emac Selection */ -#define SDR0_CUST0_MUX_NDFC_SEL 0x80000000 /* NDFC Selection */ -#define SDR0_CUST0_MUX_GPIO_SEL 0xC0000000 /* GPIO Selection */ - -#define SDR0_CUST0_NDFC_EN_MASK 0x20000000 /* NDFC Enable Mask */ -#define SDR0_CUST0_NDFC_ENABLE 0x20000000 /* NDFC Enable */ -#define SDR0_CUST0_NDFC_DISABLE 0x00000000 /* NDFC Disable */ - -#define SDR0_CUST0_NDFC_BW_MASK 0x10000000 /* NDFC Boot Width */ -#define SDR0_CUST0_NDFC_BW_16_BIT 0x10000000 /* NDFC Boot Width = 16 Bit */ -#define SDR0_CUST0_NDFC_BW_8_BIT 0x00000000 /* NDFC Boot Width = 8 Bit */ - -#define SDR0_CUST0_NDFC_BP_MASK 0x0F000000 /* NDFC Boot Page */ -#define SDR0_CUST0_NDFC_BP_ENCODE(n) ((((unsigned long)(n))&0xF)<<24) -#define SDR0_CUST0_NDFC_BP_DECODE(n) ((((unsigned long)(n))>>24)&0x0F) - -#define SDR0_CUST0_NDFC_BAC_MASK 0x00C00000 /* NDFC Boot Address Cycle */ -#define SDR0_CUST0_NDFC_BAC_ENCODE(n) ((((unsigned long)(n))&0x3)<<22) -#define SDR0_CUST0_NDFC_BAC_DECODE(n) ((((unsigned long)(n))>>22)&0x03) - -#define SDR0_CUST0_NDFC_ARE_MASK 0x00200000 /* NDFC Auto Read Enable */ -#define SDR0_CUST0_NDFC_ARE_ENABLE 0x00200000 /* NDFC Auto Read Enable */ -#define SDR0_CUST0_NDFC_ARE_DISABLE 0x00000000 /* NDFC Auto Read Disable */ - -#define SDR0_CUST0_NRB_MASK 0x00100000 /* NDFC Ready / Busy */ -#define SDR0_CUST0_NRB_BUSY 0x00100000 /* Busy */ -#define SDR0_CUST0_NRB_READY 0x00000000 /* Ready */ - -#define SDR0_CUST0_NDRSC_MASK 0x0000FFF0 /* NDFC Device Reset Count Mask */ -#define SDR0_CUST0_NDRSC_ENCODE(n) ((((unsigned long)(n))&0xFFF)<<4) -#define SDR0_CUST0_NDRSC_DECODE(n) ((((unsigned long)(n))>>4)&0xFFF) - -#define SDR0_CUST0_CHIPSELGAT_MASK 0x0000000F /* Chip Select Gating Mask */ -#define SDR0_CUST0_CHIPSELGAT_DIS 0x00000000 /* Chip Select Gating Disable */ -#define SDR0_CUST0_CHIPSELGAT_ENALL 0x0000000F /* All Chip Select Gating Enable */ -#define SDR0_CUST0_CHIPSELGAT_EN0 0x00000008 /* Chip Select0 Gating Enable */ -#define SDR0_CUST0_CHIPSELGAT_EN1 0x00000004 /* Chip Select1 Gating Enable */ -#define SDR0_CUST0_CHIPSELGAT_EN2 0x00000002 /* Chip Select2 Gating Enable */ -#define SDR0_CUST0_CHIPSELGAT_EN3 0x00000001 /* Chip Select3 Gating Enable */ +#define SDR0_CUST0_MUX_E_N_G_MASK 0xC0000000 /* Mux_Emac_NDFC_GPIO */ +#define SDR0_CUST0_MUX_EMAC_SEL 0x40000000 /* Emac Selection */ +#define SDR0_CUST0_MUX_NDFC_SEL 0x80000000 /* NDFC Selection */ +#define SDR0_CUST0_MUX_GPIO_SEL 0xC0000000 /* GPIO Selection */ + +#define SDR0_CUST0_NDFC_EN_MASK 0x20000000 /* NDFC Enable Mask */ +#define SDR0_CUST0_NDFC_ENABLE 0x20000000 /* NDFC Enable */ +#define SDR0_CUST0_NDFC_DISABLE 0x00000000 /* NDFC Disable */ + +#define SDR0_CUST0_NDFC_BW_MASK 0x10000000 /* NDFC Boot Width */ +#define SDR0_CUST0_NDFC_BW_16_BIT 0x10000000 /* NDFC Boot Width= 16 Bit */ +#define SDR0_CUST0_NDFC_BW_8_BIT 0x00000000 /* NDFC Boot Width= 8 Bit */ + +#define SDR0_CUST0_NDFC_BP_MASK 0x0F000000 /* NDFC Boot Page */ +#define SDR0_CUST0_NDFC_BP_ENCODE(n) ((((unsigned long)(n))&0xF)<<24) +#define SDR0_CUST0_NDFC_BP_DECODE(n) ((((unsigned long)(n))>>24)&0x0F) + +#define SDR0_CUST0_NDFC_BAC_MASK 0x00C00000 /* NDFC Boot Address Cycle */ +#define SDR0_CUST0_NDFC_BAC_ENCODE(n) ((((unsigned long)(n))&0x3)<<22) +#define SDR0_CUST0_NDFC_BAC_DECODE(n) ((((unsigned long)(n))>>22)&0x03) + +#define SDR0_CUST0_NDFC_ARE_MASK 0x00200000 /* NDFC Auto Read Enable */ +#define SDR0_CUST0_NDFC_ARE_ENABLE 0x00200000 /* NDFC Auto Read Enable */ +#define SDR0_CUST0_NDFC_ARE_DISABLE 0x00000000 /* NDFC Auto Read Disable */ + +#define SDR0_CUST0_NRB_MASK 0x00100000 /* NDFC Ready / Busy */ +#define SDR0_CUST0_NRB_BUSY 0x00100000 /* Busy */ +#define SDR0_CUST0_NRB_READY 0x00000000 /* Ready */ + +#define SDR0_CUST0_NDRSC_MASK 0x0000FFF0 /* NDFC Device Reset Count Mask */ +#define SDR0_CUST0_NDRSC_ENCODE(n) ((((unsigned long)(n))&0xFFF)<<4) +#define SDR0_CUST0_NDRSC_DECODE(n) ((((unsigned long)(n))>>4)&0xFFF) + +#define SDR0_CUST0_CHIPSELGAT_MASK 0x0000000F /* Chip Sel Gating Mask */ +#define SDR0_CUST0_CHIPSELGAT_DIS 0x00000000 /* Chip Sel Gating Disable */ +#define SDR0_CUST0_CHIPSELGAT_ENALL 0x0000000F /* All Chip Sel Gating Enable */ +#define SDR0_CUST0_CHIPSELGAT_EN0 0x00000008 /* Chip Sel0 Gating Enable */ +#define SDR0_CUST0_CHIPSELGAT_EN1 0x00000004 /* Chip Sel1 Gating Enable */ +#define SDR0_CUST0_CHIPSELGAT_EN2 0x00000002 /* Chip Sel2 Gating Enable */ +#define SDR0_CUST0_CHIPSELGAT_EN3 0x00000001 /* Chip Sel3 Gating Enable */
#define SDR0_PFC0 0x4100 #define SDR0_PFC1 0x4101 diff --git a/include/ppc440.h b/include/ppc440.h index 9299a71..fe0db93 100644 --- a/include/ppc440.h +++ b/include/ppc440.h @@ -48,7 +48,7 @@ #ifndef __PPC440_H__ #define __PPC440_H__
-#define CONFIG_SYS_DCACHE_SIZE (32 << 10) /* For AMCC 440 CPUs */ +#define CONFIG_SYS_DCACHE_SIZE (32 << 10) /* For AMCC 440 CPUs */
/****************************************************************************** * DCRs & Related @@ -86,8 +86,8 @@ #define SDR0_XPLLC 0x01c1 #define SDR0_XPLLD 0x01c2 #define SDR0_SRST 0x0200 -#define SD0_AMP0 0x0240 /* Override PLB4 prioritiy for up to 8 masters */ -#define SD0_AMP1 0x0241 /* Override PLB3 prioritiy for up to 8 masters */ +#define SD0_AMP0 0x0240 /* Override PLB4 prioritiy for up to 8 masters */ +#define SD0_AMP1 0x0241 /* Override PLB3 prioritiy for up to 8 masters */ #if defined(CONFIG_460EX) || defined(CONFIG_460GT) #define SDR0_PCI0 0x01c0 #else @@ -145,10 +145,10 @@ #define SDR0_XCR2 0x01c6 #define SDR0_XPLLC0 0x01c1 #define SDR0_XPLLD0 0x01c2 -#define SDR0_XPLLC1 0x01c4 /*notRCW - SG */ -#define SDR0_XPLLD1 0x01c5 /*notRCW - SG */ -#define SDR0_XPLLC2 0x01c7 /*notRCW - SG */ -#define SDR0_XPLLD2 0x01c8 /*notRCW - SG */ +#define SDR0_XPLLC1 0x01c4 /* notRCW - SG */ +#define SDR0_XPLLD1 0x01c5 /* notRCW - SG */ +#define SDR0_XPLLC2 0x01c7 /* notRCW - SG */ +#define SDR0_XPLLD2 0x01c8 /* dnotRCW - SG */ #define SD0_AMP0 0x0240 #define SD0_AMP1 0x0241 #define SDR0_CUST2 0x4004 @@ -187,80 +187,91 @@ #if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX)
-/* PLB3 Arbiter */ + /* PLB3 Arbiter */ #define PLB3_DCR_BASE 0x070 #define PLB3_ACR (PLB3_DCR_BASE + 0x7)
-/* PLB4 Arbiter - PowerPC440EP Pass1 */ + /* PLB4 Arbiter - PowerPC440EP Pass1 */ #define PLB4_DCR_BASE 0x080 #define PLB4_ACR (PLB4_DCR_BASE + 0x1)
#define PLB4_ACR_WRP (0x80000000 >> 7)
-/* Pin Function Control Register 1 */ + /* Pin Function Control Register 1 */ #define SDR0_PFC1 0x4101 -#define SDR0_PFC1_U1ME_MASK 0x02000000 /* UART1 Mode Enable */ -#define SDR0_PFC1_U1ME_DSR_DTR 0x00000000 /* UART1 in DSR/DTR Mode */ -#define SDR0_PFC1_U1ME_CTS_RTS 0x02000000 /* UART1 in CTS/RTS Mode */ -#define SDR0_PFC1_U0ME_MASK 0x00080000 /* UART0 Mode Enable */ -#define SDR0_PFC1_U0ME_DSR_DTR 0x00000000 /* UART0 in DSR/DTR Mode */ -#define SDR0_PFC1_U0ME_CTS_RTS 0x00080000 /* UART0 in CTS/RTS Mode */ -#define SDR0_PFC1_U0IM_MASK 0x00040000 /* UART0 Interface Mode */ -#define SDR0_PFC1_U0IM_8PINS 0x00000000 /* UART0 Interface Mode 8 pins */ -#define SDR0_PFC1_U0IM_4PINS 0x00040000 /* UART0 Interface Mode 4 pins */ -#define SDR0_PFC1_SIS_MASK 0x00020000 /* SCP or IIC1 Selection */ -#define SDR0_PFC1_SIS_SCP_SEL 0x00000000 /* SCP Selected */ -#define SDR0_PFC1_SIS_IIC1_SEL 0x00020000 /* IIC1 Selected */ -#define SDR0_PFC1_UES_MASK 0x00010000 /* USB2D_RX_Active / EBC_Hold Req Selection */ -#define SDR0_PFC1_UES_USB2D_SEL 0x00000000 /* USB2D_RX_Active Selected */ -#define SDR0_PFC1_UES_EBCHR_SEL 0x00010000 /* EBC_Hold Req Selected */ -#define SDR0_PFC1_DIS_MASK 0x00008000 /* DMA_Req(1) / UIC_IRQ(5) Selection */ -#define SDR0_PFC1_DIS_DMAR_SEL 0x00000000 /* DMA_Req(1) Selected */ -#define SDR0_PFC1_DIS_UICIRQ5_SEL 0x00008000 /* UIC_IRQ(5) Selected */ -#define SDR0_PFC1_ERE_MASK 0x00004000 /* EBC Mast.Ext.Req.En./GPIO0(27) Selection */ -#define SDR0_PFC1_ERE_EXTR_SEL 0x00000000 /* EBC Mast.Ext.Req.En. Selected */ -#define SDR0_PFC1_ERE_GPIO0_27_SEL 0x00004000 /* GPIO0(27) Selected */ -#define SDR0_PFC1_UPR_MASK 0x00002000 /* USB2 Device Packet Reject Selection */ -#define SDR0_PFC1_UPR_DISABLE 0x00000000 /* USB2 Device Packet Reject Disable */ -#define SDR0_PFC1_UPR_ENABLE 0x00002000 /* USB2 Device Packet Reject Enable */ - -#define SDR0_PFC1_PLB_PME_MASK 0x00001000 /* PLB3/PLB4 Perf. Monitor En. Selection */ -#define SDR0_PFC1_PLB_PME_PLB3_SEL 0x00000000 /* PLB3 Performance Monitor Enable */ -#define SDR0_PFC1_PLB_PME_PLB4_SEL 0x00001000 /* PLB3 Performance Monitor Enable */ -#define SDR0_PFC1_GFGGI_MASK 0x0000000F /* GPT Frequency Generation Gated In */ - -/* USB Control Register */ +#define SDR0_PFC1_U1ME_MASK 0x02000000 /* UART1 Mode Enable */ +#define SDR0_PFC1_U1ME_DSR_DTR 0x00000000 /* UART1 in DSR/DTR Mode */ +#define SDR0_PFC1_U1ME_CTS_RTS 0x02000000 /* UART1 in CTS/RTS Mode */ +#define SDR0_PFC1_U0ME_MASK 0x00080000 /* UART0 Mode Enable */ +#define SDR0_PFC1_U0ME_DSR_DTR 0x00000000 /* UART0 in DSR/DTR Mode */ +#define SDR0_PFC1_U0ME_CTS_RTS 0x00080000 /* UART0 in CTS/RTS Mode */ +#define SDR0_PFC1_U0IM_MASK 0x00040000 /* UART0 Interface Mode */ +#define SDR0_PFC1_U0IM_8PINS 0x00000000 /* UART0 Interface Mode 8 pins */ +#define SDR0_PFC1_U0IM_4PINS 0x00040000 /* UART0 Interface Mode 4 pins */ +#define SDR0_PFC1_SIS_MASK 0x00020000 /* SCP or IIC1 Selection */ +#define SDR0_PFC1_SIS_SCP_SEL 0x00000000 /* SCP Selected */ +#define SDR0_PFC1_SIS_IIC1_SEL 0x00020000 /* IIC1 Selected */ +#define SDR0_PFC1_UES_MASK 0x00010000 /* USB2D_RX_Active / EBC_Hold + Req Selection */ +#define SDR0_PFC1_UES_USB2D_SEL 0x00000000 /* USB2D_RX_Active Selected */ +#define SDR0_PFC1_UES_EBCHR_SEL 0x00010000 /* EBC_Hold Req Selected */ +#define SDR0_PFC1_DIS_MASK 0x00008000 /* DMA_Req(1) / UIC_IRQ(5) + Selection */ +#define SDR0_PFC1_DIS_DMAR_SEL 0x00000000 /* DMA_Req(1) Selected */ +#define SDR0_PFC1_DIS_UICIRQ5_SEL 0x00008000 /* UIC_IRQ(5) Selected */ +#define SDR0_PFC1_ERE_MASK 0x00004000 /* EBC Mast.Ext.Req.En./GPIO0(27) + Selection */ +#define SDR0_PFC1_ERE_EXTR_SEL 0x00000000 /* EBC Mast.Ext.Req.En. + Selected */ +#define SDR0_PFC1_ERE_GPIO0_27_SEL 0x00004000 /* GPIO0(27) Selected */ +#define SDR0_PFC1_UPR_MASK 0x00002000 /* USB2 Device Packet Reject + Selection */ +#define SDR0_PFC1_UPR_DISABLE 0x00000000 /* USB2 Device Packet Reject + Disable */ +#define SDR0_PFC1_UPR_ENABLE 0x00002000 /* USB2 Device Packet Reject + Enable */ + +#define SDR0_PFC1_PLB_PME_MASK 0x00001000 /* PLB3/PLB4 Perf. Monitor Enable + Selection */ +#define SDR0_PFC1_PLB_PME_PLB3_SEL 0x00000000 /* PLB3 Performance Monitor + Enable */ +#define SDR0_PFC1_PLB_PME_PLB4_SEL 0x00001000 /* PLB3 Performance Monitor + Enable */ +#define SDR0_PFC1_GFGGI_MASK 0x0000000F /* GPT Frequency Generation + Gated In */ + + /* USB Control Register */ #define SDR0_USB0 0x0320 -#define SDR0_USB0_USB_DEVSEL_MASK 0x00000002 /* USB Device Selection */ -#define SDR0_USB0_USB20D_DEVSEL 0x00000000 /* USB2.0 Device Selected */ -#define SDR0_USB0_USB11D_DEVSEL 0x00000002 /* USB1.1 Device Selected */ -#define SDR0_USB0_LEEN_MASK 0x00000001 /* Little Endian selection */ -#define SDR0_USB0_LEEN_DISABLE 0x00000000 /* Little Endian Disable */ -#define SDR0_USB0_LEEN_ENABLE 0x00000001 /* Little Endian Enable */ - -/* Miscealleneaous Function Reg. */ +#define SDR0_USB0_USB_DEVSEL_MASK 0x00000002 /* USB Device Selection */ +#define SDR0_USB0_USB20D_DEVSEL 0x00000000 /* USB2.0 Device Selected */ +#define SDR0_USB0_USB11D_DEVSEL 0x00000002 /* USB1.1 Device Selected */ +#define SDR0_USB0_LEEN_MASK 0x00000001 /* Little Endian selection */ +#define SDR0_USB0_LEEN_DISABLE 0x00000000 /* Little Endian Disable */ +#define SDR0_USB0_LEEN_ENABLE 0x00000001 /* Little Endian Enable */ + + /* Miscealleneaous Function Reg. */ #define SDR0_MFR 0x4300 -#define SDR0_MFR_ETH0_CLK_SEL_MASK 0x08000000 /* Ethernet0 Clock Select */ -#define SDR0_MFR_ETH0_CLK_SEL_EXT 0x00000000 -#define SDR0_MFR_ETH1_CLK_SEL_MASK 0x04000000 /* Ethernet1 Clock Select */ -#define SDR0_MFR_ETH1_CLK_SEL_EXT 0x00000000 -#define SDR0_MFR_ZMII_MODE_MASK 0x03000000 /* ZMII Mode Mask */ -#define SDR0_MFR_ZMII_MODE_MII 0x00000000 /* ZMII Mode MII */ -#define SDR0_MFR_ZMII_MODE_SMII 0x01000000 /* ZMII Mode SMII */ -#define SDR0_MFR_ZMII_MODE_RMII_10M 0x02000000 /* ZMII Mode RMII - 10 Mbs */ -#define SDR0_MFR_ZMII_MODE_RMII_100M 0x03000000 /* ZMII Mode RMII - 100 Mbs */ -#define SDR0_MFR_ZMII_MODE_BIT0 0x02000000 /* ZMII Mode Bit0 */ -#define SDR0_MFR_ZMII_MODE_BIT1 0x01000000 /* ZMII Mode Bit1 */ -#define SDR0_MFR_ZM_ENCODE(n) ((((unsigned long)(n))&0x3)<<24) -#define SDR0_MFR_ZM_DECODE(n) ((((unsigned long)(n))<<24)&0x3) - -#define SDR0_MFR_ERRATA3_EN0 0x00800000 -#define SDR0_MFR_ERRATA3_EN1 0x00400000 -#define SDR0_MFR_PKT_REJ_MASK 0x00180000 /* Pkt Rej. Enable Mask */ -#define SDR0_MFR_PKT_REJ_EN 0x00180000 /* Pkt Rej. Enable on both EMAC3 0-1 */ -#define SDR0_MFR_PKT_REJ_EN0 0x00100000 /* Pkt Rej. Enable on EMAC3(0) */ -#define SDR0_MFR_PKT_REJ_EN1 0x00080000 /* Pkt Rej. Enable on EMAC3(1) */ -#define SDR0_MFR_PKT_REJ_POL 0x00200000 /* Packet Reject Polarity */ +#define SDR0_MFR_ETH0_CLK_SEL_MASK 0x08000000 /* Ethernet0 Clock Select */ +#define SDR0_MFR_ETH0_CLK_SEL_EXT 0x00000000 +#define SDR0_MFR_ETH1_CLK_SEL_MASK 0x04000000 /* Ethernet1 Clock Select */ +#define SDR0_MFR_ETH1_CLK_SEL_EXT 0x00000000 +#define SDR0_MFR_ZMII_MODE_MASK 0x03000000 /* ZMII Mode Mask */ +#define SDR0_MFR_ZMII_MODE_MII 0x00000000 /* ZMII Mode MII */ +#define SDR0_MFR_ZMII_MODE_SMII 0x01000000 /* ZMII Mode SMII */ +#define SDR0_MFR_ZMII_MODE_RMII_10M 0x02000000 /* ZMII Mode RMII - 10 Mbs */ +#define SDR0_MFR_ZMII_MODE_RMII_100M 0x03000000 /* ZMII Mode RMII - 100 Mbs */ +#define SDR0_MFR_ZMII_MODE_BIT0 0x02000000 /* ZMII Mode Bit0 */ +#define SDR0_MFR_ZMII_MODE_BIT1 0x01000000 /* ZMII Mode Bit1 */ +#define SDR0_MFR_ZM_ENCODE(n) ((((unsigned long)(n))&0x3)<<24) +#define SDR0_MFR_ZM_DECODE(n) ((((unsigned long)(n))<<24)&0x3) + +#define SDR0_MFR_ERRATA3_EN0 0x00800000 +#define SDR0_MFR_ERRATA3_EN1 0x00400000 +#define SDR0_MFR_PKT_REJ_MASK 0x00180000 /* Pkt Rej. Enable Mask */ +#define SDR0_MFR_PKT_REJ_EN 0x00180000 /* Pkt Rej. Ena. on both EMAC3 0-1 */ +#define SDR0_MFR_PKT_REJ_EN0 0x00100000 /* Pkt Rej. Enable on EMAC3(0) */ +#define SDR0_MFR_PKT_REJ_EN1 0x00080000 /* Pkt Rej. Enable on EMAC3(1) */ +#define SDR0_MFR_PKT_REJ_POL 0x00200000 /* Packet Reject Polarity */
#define GPT0_COMP6 0x00000098 #define GPT0_COMP5 0x00000094 @@ -278,245 +289,296 @@
#if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) #define SDR0_USB2D0CR 0x0320 -#define SDR0_USB2D0CR_USB2DEV_EBC_SEL_MASK 0x00000004 /* USB 2.0 Device/EBC Master Selection */ -#define SDR0_USB2D0CR_USB2DEV_SELECTION 0x00000004 /* USB 2.0 Device Selection */ -#define SDR0_USB2D0CR_EBC_SELECTION 0x00000000 /* EBC Selection */ - -#define SDR0_USB2D0CR_USB_DEV_INT_SEL_MASK 0x00000002 /* USB Device Interface Selection */ -#define SDR0_USB2D0CR_USB20D_DEVSEL 0x00000000 /* USB2.0 Device Selected */ -#define SDR0_USB2D0CR_USB11D_DEVSEL 0x00000002 /* USB1.1 Device Selected */ - -#define SDR0_USB2D0CR_LEEN_MASK 0x00000001 /* Little Endian selection */ -#define SDR0_USB2D0CR_LEEN_DISABLE 0x00000000 /* Little Endian Disable */ -#define SDR0_USB2D0CR_LEEN_ENABLE 0x00000001 /* Little Endian Enable */ - -/* USB2 Host Control Register */ -#define SDR0_USB2H0CR 0x0340 -#define SDR0_USB2H0CR_WDINT_MASK 0x00000001 /* Host UTMI Word Interface */ -#define SDR0_USB2H0CR_WDINT_8BIT_60MHZ 0x00000000 /* 8-bit/60MHz */ -#define SDR0_USB2H0CR_WDINT_16BIT_30MHZ 0x00000001 /* 16-bit/30MHz */ -#define SDR0_USB2H0CR_EFLADJ_MASK 0x0000007e /* EHCI Frame Length Adjustment */ - -/* Pin Function Control Register 1 */ -#define SDR0_PFC1 0x4101 -#define SDR0_PFC1_U1ME_MASK 0x02000000 /* UART1 Mode Enable */ -#define SDR0_PFC1_U1ME_DSR_DTR 0x00000000 /* UART1 in DSR/DTR Mode */ -#define SDR0_PFC1_U1ME_CTS_RTS 0x02000000 /* UART1 in CTS/RTS Mode */ - -#define SDR0_PFC1_SELECT_MASK 0x01C00000 /* Ethernet Pin Select EMAC 0 */ -#define SDR0_PFC1_SELECT_CONFIG_1_1 0x00C00000 /* 1xMII using RGMII bridge */ -#define SDR0_PFC1_SELECT_CONFIG_1_2 0x00000000 /* 1xMII using ZMII bridge */ -#define SDR0_PFC1_SELECT_CONFIG_2 0x00C00000 /* 1xGMII using RGMII bridge */ -#define SDR0_PFC1_SELECT_CONFIG_3 0x01000000 /* 1xTBI using RGMII bridge */ -#define SDR0_PFC1_SELECT_CONFIG_4 0x01400000 /* 2xRGMII using RGMII bridge */ -#define SDR0_PFC1_SELECT_CONFIG_5 0x01800000 /* 2xRTBI using RGMII bridge */ -#define SDR0_PFC1_SELECT_CONFIG_6 0x00800000 /* 2xSMII using ZMII bridge */ - -#define SDR0_PFC1_U0ME_MASK 0x00080000 /* UART0 Mode Enable */ -#define SDR0_PFC1_U0ME_DSR_DTR 0x00000000 /* UART0 in DSR/DTR Mode */ -#define SDR0_PFC1_U0ME_CTS_RTS 0x00080000 /* UART0 in CTS/RTS Mode */ -#define SDR0_PFC1_U0IM_MASK 0x00040000 /* UART0 Interface Mode */ -#define SDR0_PFC1_U0IM_8PINS 0x00000000 /* UART0 Interface Mode 8 pins */ -#define SDR0_PFC1_U0IM_4PINS 0x00040000 /* UART0 Interface Mode 4 pins */ -#define SDR0_PFC1_SIS_MASK 0x00020000 /* SCP or IIC1 Selection */ -#define SDR0_PFC1_SIS_SCP_SEL 0x00000000 /* SCP Selected */ -#define SDR0_PFC1_SIS_IIC1_SEL 0x00020000 /* IIC1 Selected */ -#define SDR0_PFC1_UES_MASK 0x00010000 /* USB2D_RX_Active / EBC_Hold Req Selection */ -#define SDR0_PFC1_UES_USB2D_SEL 0x00000000 /* USB2D_RX_Active Selected */ -#define SDR0_PFC1_UES_EBCHR_SEL 0x00010000 /* EBC_Hold Req Selected */ -#define SDR0_PFC1_DIS_MASK 0x00008000 /* DMA_Req(1) / UIC_IRQ(5) Selection */ -#define SDR0_PFC1_DIS_DMAR_SEL 0x00000000 /* DMA_Req(1) Selected */ -#define SDR0_PFC1_DIS_UICIRQ5_SEL 0x00008000 /* UIC_IRQ(5) Selected */ -#define SDR0_PFC1_ERE_MASK 0x00004000 /* EBC Mast.Ext.Req.En./GPIO0(27) Selection */ -#define SDR0_PFC1_ERE_EXTR_SEL 0x00000000 /* EBC Mast.Ext.Req.En. Selected */ -#define SDR0_PFC1_ERE_GPIO0_27_SEL 0x00004000 /* GPIO0(27) Selected */ -#define SDR0_PFC1_UPR_MASK 0x00002000 /* USB2 Device Packet Reject Selection */ -#define SDR0_PFC1_UPR_DISABLE 0x00000000 /* USB2 Device Packet Reject Disable */ -#define SDR0_PFC1_UPR_ENABLE 0x00002000 /* USB2 Device Packet Reject Enable */ - -#define SDR0_PFC1_PLB_PME_MASK 0x00001000 /* PLB3/PLB4 Perf. Monitor En. Selection */ -#define SDR0_PFC1_PLB_PME_PLB3_SEL 0x00000000 /* PLB3 Performance Monitor Enable */ -#define SDR0_PFC1_PLB_PME_PLB4_SEL 0x00001000 /* PLB3 Performance Monitor Enable */ -#define SDR0_PFC1_GFGGI_MASK 0x0000000F /* GPT Frequency Generation Gated In */ - -/* Ethernet PLL Configuration Register */ -#define SDR0_PFC2 0x4102 -#define SDR0_PFC2_TUNE_MASK 0x01FF8000 /* Loop stability tuning bits */ -#define SDR0_PFC2_MULTI_MASK 0x00007C00 /* Frequency multiplication selector */ -#define SDR0_PFC2_RANGEB_MASK 0x00000380 /* PLLOUTB/C frequency selector */ -#define SDR0_PFC2_RANGEA_MASK 0x00000071 /* PLLOUTA frequency selector */ - -#define SDR0_PFC2_SELECT_MASK 0xE0000000 /* Ethernet Pin select EMAC1 */ -#define SDR0_PFC2_SELECT_CONFIG_1_1 0x60000000 /* 1xMII using RGMII bridge */ -#define SDR0_PFC2_SELECT_CONFIG_1_2 0x00000000 /* 1xMII using ZMII bridge */ -#define SDR0_PFC2_SELECT_CONFIG_2 0x60000000 /* 1xGMII using RGMII bridge */ -#define SDR0_PFC2_SELECT_CONFIG_3 0x80000000 /* 1xTBI using RGMII bridge */ -#define SDR0_PFC2_SELECT_CONFIG_4 0xA0000000 /* 2xRGMII using RGMII bridge */ -#define SDR0_PFC2_SELECT_CONFIG_5 0xC0000000 /* 2xRTBI using RGMII bridge */ -#define SDR0_PFC2_SELECT_CONFIG_6 0x40000000 /* 2xSMII using ZMII bridge */ +#define SDR0_USB2D0CR_USB2DEV_EBC_SEL_MASK 0x00000004 /* USB 2.0 Device/EBC + Master Selection */ +#define SDR0_USB2D0CR_USB2DEV_SELECTION 0x00000004 /* USB 2.0 Device Selection*/ +#define SDR0_USB2D0CR_EBC_SELECTION 0x00000000 /* EBC Selection */ + +#define SDR0_USB2D0CR_USB_DEV_INT_SEL_MASK 0x00000002 /* USB Device Interface + Selection */ +#define SDR0_USB2D0CR_USB20D_DEVSEL 0x00000000 /* USB2.0 Device Selected */ +#define SDR0_USB2D0CR_USB11D_DEVSEL 0x00000002 /* USB1.1 Device Selected */ + +#define SDR0_USB2D0CR_LEEN_MASK 0x00000001 /* Little Endian selection */ +#define SDR0_USB2D0CR_LEEN_DISABLE 0x00000000 /* Little Endian Disable */ +#define SDR0_USB2D0CR_LEEN_ENABLE 0x00000001 /* Little Endian Enable */ + + /* USB2 Host Control Register */ +#define SDR0_USB2H0CR 0x0340 +#define SDR0_USB2H0CR_WDINT_MASK 0x00000001 /* Host UTMI Word Interface*/ +#define SDR0_USB2H0CR_WDINT_8BIT_60MHZ 0x00000000 /* 8-bit/60MHz */ +#define SDR0_USB2H0CR_WDINT_16BIT_30MHZ 0x00000001 /* 16-bit/30MHz */ +#define SDR0_USB2H0CR_EFLADJ_MASK 0x0000007e /* EHCI Frame Length + Adjustment */ + + /* Pin Function Control Register 1 */ +#define SDR0_PFC1 0x4101 +#define SDR0_PFC1_U1ME_MASK 0x02000000 /* UART1 Mode Enable */ +#define SDR0_PFC1_U1ME_DSR_DTR 0x00000000 /* UART1 in DSR/DTR Mode */ +#define SDR0_PFC1_U1ME_CTS_RTS 0x02000000 /* UART1 in CTS/RTS Mode */ + +#define SDR0_PFC1_SELECT_MASK 0x01C00000 /* Ethernet Pin Select + EMAC 0 */ +#define SDR0_PFC1_SELECT_CONFIG_1_1 0x00C00000 /* 1xMII using RGMII + bridge */ +#define SDR0_PFC1_SELECT_CONFIG_1_2 0x00000000 /* 1xMII using ZMII + bridge */ +#define SDR0_PFC1_SELECT_CONFIG_2 0x00C00000 /* 1xGMII using RGMII + bridge */ +#define SDR0_PFC1_SELECT_CONFIG_3 0x01000000 /* 1xTBI using RGMII + bridge */ +#define SDR0_PFC1_SELECT_CONFIG_4 0x01400000 /* 2xRGMII using RGMII + bridge */ +#define SDR0_PFC1_SELECT_CONFIG_5 0x01800000 /* 2xRTBI using RGMII + bridge */ +#define SDR0_PFC1_SELECT_CONFIG_6 0x00800000 /* 2xSMII using ZMII + bridge */ + +#define SDR0_PFC1_U0ME_MASK 0x00080000 /* UART0 Mode Enable */ +#define SDR0_PFC1_U0ME_DSR_DTR 0x00000000 /* UART0 in DSR/DTR Mode */ +#define SDR0_PFC1_U0ME_CTS_RTS 0x00080000 /* UART0 in CTS/RTS Mode */ +#define SDR0_PFC1_U0IM_MASK 0x00040000 /* UART0 Interface Mode */ +#define SDR0_PFC1_U0IM_8PINS 0x00000000 /* UART0 Interface Mode 8 pins */ +#define SDR0_PFC1_U0IM_4PINS 0x00040000 /* UART0 Interface Mode 4 pins */ +#define SDR0_PFC1_SIS_MASK 0x00020000 /* SCP or IIC1 Selection */ +#define SDR0_PFC1_SIS_SCP_SEL 0x00000000 /* SCP Selected */ +#define SDR0_PFC1_SIS_IIC1_SEL 0x00020000 /* IIC1 Selected */ +#define SDR0_PFC1_UES_MASK 0x00010000 /* USB2D_RX_Active / EBC_Hold Req + Selection */ +#define SDR0_PFC1_UES_USB2D_SEL 0x00000000 /* USB2D_RX_Active Selected */ +#define SDR0_PFC1_UES_EBCHR_SEL 0x00010000 /* EBC_Hold Req Selected */ +#define SDR0_PFC1_DIS_MASK 0x00008000 /* DMA_Req(1) / UIC_IRQ(5) + Selection */ +#define SDR0_PFC1_DIS_DMAR_SEL 0x00000000 /* DMA_Req(1) Selected */ +#define SDR0_PFC1_DIS_UICIRQ5_SEL 0x00008000 /* UIC_IRQ(5) Selected */ +#define SDR0_PFC1_ERE_MASK 0x00004000 /* EBC Mast.Ext.Req.En./GPIO0(27) + Selection */ +#define SDR0_PFC1_ERE_EXTR_SEL 0x00000000 /* EBC Mast.Ext.Req.En. Selected */ +#define SDR0_PFC1_ERE_GPIO0_27_SEL 0x00004000 /* GPIO0(27) Selected */ +#define SDR0_PFC1_UPR_MASK 0x00002000 /* USB2 Device Packet Reject + Selection */ +#define SDR0_PFC1_UPR_DISABLE 0x00000000 /* USB2 Device Packet Reject + Disable */ +#define SDR0_PFC1_UPR_ENABLE 0x00002000 /* USB2 Device Packet Reject + Enable */ + +#define SDR0_PFC1_PLB_PME_MASK 0x00001000 + /* PLB3/PLB4 Perf. Monitor En. Selection */ +#define SDR0_PFC1_PLB_PME_PLB3_SEL 0x00000000 + /* PLB3 Performance Monitor Enable */ +#define SDR0_PFC1_PLB_PME_PLB4_SEL 0x00001000 + /* PLB3 Performance Monitor Enable */ +#define SDR0_PFC1_GFGGI_MASK 0x0000000F /* GPT Frequency Generation + Gated In */ + + /* Ethernet PLL Configuration Register */ +#define SDR0_PFC2 0x4102 +#define SDR0_PFC2_TUNE_MASK 0x01FF8000 /* Loop stability tuning bits */ +#define SDR0_PFC2_MULTI_MASK 0x00007C00 /* Frequency multiplication + selector */ +#define SDR0_PFC2_RANGEB_MASK 0x00000380 /* PLLOUTB/C frequency selector */ +#define SDR0_PFC2_RANGEA_MASK 0x00000071 /* PLLOUTA frequency selector */ + +#define SDR0_PFC2_SELECT_MASK 0xE0000000 /* Ethernet Pin select EMAC1 */ +#define SDR0_PFC2_SELECT_CONFIG_1_1 0x60000000 /* 1xMII using RGMII bridge */ +#define SDR0_PFC2_SELECT_CONFIG_1_2 0x00000000 /* 1xMII using ZMII bridge */ +#define SDR0_PFC2_SELECT_CONFIG_2 0x60000000 /* 1xGMII using RGMII bridge */ +#define SDR0_PFC2_SELECT_CONFIG_3 0x80000000 /* 1xTBI using RGMII bridge */ +#define SDR0_PFC2_SELECT_CONFIG_4 0xA0000000 /* 2xRGMII using RGMII bridge */ +#define SDR0_PFC2_SELECT_CONFIG_5 0xC0000000 /* 2xRTBI using RGMII bridge */ +#define SDR0_PFC2_SELECT_CONFIG_6 0x40000000 /* 2xSMII using ZMII bridge */
#define SDR0_PFC4 0x4104
-/* USB2PHY0 Control Register */ -#define SDR0_USB2PHY0CR 0x4103 -#define SDR0_USB2PHY0CR_UTMICN_MASK 0x00100000 /* PHY UTMI interface connection */ -#define SDR0_USB2PHY0CR_UTMICN_DEV 0x00000000 /* Device support */ -#define SDR0_USB2PHY0CR_UTMICN_HOST 0x00100000 /* Host support */ - -#define SDR0_USB2PHY0CR_DWNSTR_MASK 0x00400000 /* Select downstream port mode */ -#define SDR0_USB2PHY0CR_DWNSTR_DEV 0x00000000 /* Device */ -#define SDR0_USB2PHY0CR_DWNSTR_HOST 0x00400000 /* Host */ - -#define SDR0_USB2PHY0CR_DVBUS_MASK 0x00800000 /* VBus detect (Device mode only) */ -#define SDR0_USB2PHY0CR_DVBUS_PURDIS 0x00000000 /* Pull-up resistance on D+ is disabled */ -#define SDR0_USB2PHY0CR_DVBUS_PUREN 0x00800000 /* Pull-up resistance on D+ is enabled */ - -#define SDR0_USB2PHY0CR_WDINT_MASK 0x01000000 /* PHY UTMI data width and clock select */ -#define SDR0_USB2PHY0CR_WDINT_8BIT_60MHZ 0x00000000 /* 8-bit data/60MHz */ -#define SDR0_USB2PHY0CR_WDINT_16BIT_30MHZ 0x01000000 /* 16-bit data/30MHz */ - -#define SDR0_USB2PHY0CR_LOOPEN_MASK 0x02000000 /* Loop back test enable */ -#define SDR0_USB2PHY0CR_LOOP_ENABLE 0x00000000 /* Loop back disabled */ -#define SDR0_USB2PHY0CR_LOOP_DISABLE 0x02000000 /* Loop back enabled (only test purposes) */ - -#define SDR0_USB2PHY0CR_XOON_MASK 0x04000000 /* Force XO block on during a suspend */ -#define SDR0_USB2PHY0CR_XO_ON 0x00000000 /* PHY XO block is powered-on */ -#define SDR0_USB2PHY0CR_XO_OFF 0x04000000 /* PHY XO block is powered-off when all ports are suspended */ - -#define SDR0_USB2PHY0CR_PWRSAV_MASK 0x08000000 /* Select PHY power-save mode */ -#define SDR0_USB2PHY0CR_PWRSAV_OFF 0x00000000 /* Non-power-save mode */ -#define SDR0_USB2PHY0CR_PWRSAV_ON 0x08000000 /* Power-save mode. Valid only for full-speed operation */ - -#define SDR0_USB2PHY0CR_XOREF_MASK 0x10000000 /* Select reference clock source */ -#define SDR0_USB2PHY0CR_XOREF_INTERNAL 0x00000000 /* PHY PLL uses chip internal 48M clock as a reference */ -#define SDR0_USB2PHY0CR_XOREF_XO 0x10000000 /* PHY PLL uses internal XO block output as a reference */ - -#define SDR0_USB2PHY0CR_XOCLK_MASK 0x20000000 /* Select clock for XO block */ -#define SDR0_USB2PHY0CR_XOCLK_EXTERNAL 0x00000000 /* PHY macro used an external clock */ -#define SDR0_USB2PHY0CR_XOCLK_CRYSTAL 0x20000000 /* PHY macro uses the clock from a crystal */ - -#define SDR0_USB2PHY0CR_CLKSEL_MASK 0xc0000000 /* Select ref clk freq */ -#define SDR0_USB2PHY0CR_CLKSEL_12MHZ 0x00000000 /* Select ref clk freq = 12 MHz*/ -#define SDR0_USB2PHY0CR_CLKSEL_48MHZ 0x40000000 /* Select ref clk freq = 48 MHz*/ -#define SDR0_USB2PHY0CR_CLKSEL_24MHZ 0x80000000 /* Select ref clk freq = 24 MHz*/ - -/* Miscealleneaous Function Reg. */ -#define SDR0_MFR 0x4300 -#define SDR0_MFR_ETH0_CLK_SEL_MASK 0x08000000 /* Ethernet0 Clock Select */ -#define SDR0_MFR_ETH0_CLK_SEL_EXT 0x00000000 -#define SDR0_MFR_ETH1_CLK_SEL_MASK 0x04000000 /* Ethernet1 Clock Select */ -#define SDR0_MFR_ETH1_CLK_SEL_EXT 0x00000000 -#define SDR0_MFR_ZMII_MODE_MASK 0x03000000 /* ZMII Mode Mask */ -#define SDR0_MFR_ZMII_MODE_MII 0x00000000 /* ZMII Mode MII */ -#define SDR0_MFR_ZMII_MODE_SMII 0x01000000 /* ZMII Mode SMII */ -#define SDR0_MFR_ZMII_MODE_BIT0 0x02000000 /* ZMII Mode Bit0 */ -#define SDR0_MFR_ZMII_MODE_BIT1 0x01000000 /* ZMII Mode Bit1 */ -#define SDR0_MFR_ZM_ENCODE(n) ((((unsigned long)(n))&0x3)<<24) -#define SDR0_MFR_ZM_DECODE(n) ((((unsigned long)(n))<<24)&0x3) - -#define SDR0_MFR_ERRATA3_EN0 0x00800000 -#define SDR0_MFR_ERRATA3_EN1 0x00400000 -#define SDR0_MFR_PKT_REJ_MASK 0x00180000 /* Pkt Rej. Enable Mask */ -#define SDR0_MFR_PKT_REJ_EN 0x00180000 /* Pkt Rej. Enable on both EMAC3 0-1 */ -#define SDR0_MFR_PKT_REJ_EN0 0x00100000 /* Pkt Rej. Enable on EMAC3(0) */ -#define SDR0_MFR_PKT_REJ_EN1 0x00080000 /* Pkt Rej. Enable on EMAC3(1) */ -#define SDR0_MFR_PKT_REJ_POL 0x00200000 /* Packet Reject Polarity */ + /* USB2PHY0 Control Register */ +#define SDR0_USB2PHY0CR 0x4103 +#define SDR0_USB2PHY0CR_UTMICN_MASK 0x00100000 + + /* PHY UTMI interface connection */ +#define SDR0_USB2PHY0CR_UTMICN_DEV 0x00000000 /* Device support */ +#define SDR0_USB2PHY0CR_UTMICN_HOST 0x00100000 /* Host support */ + +#define SDR0_USB2PHY0CR_DWNSTR_MASK 0x00400000 /* Select downstream port mode */ +#define SDR0_USB2PHY0CR_DWNSTR_DEV 0x00000000 /* Device */ +#define SDR0_USB2PHY0CR_DWNSTR_HOST 0x00400000 /* Host */ + +#define SDR0_USB2PHY0CR_DVBUS_MASK 0x00800000 + /* VBus detect (Device mode only) */ +#define SDR0_USB2PHY0CR_DVBUS_PURDIS 0x00000000 + /* Pull-up resistance on D+ is disabled */ +#define SDR0_USB2PHY0CR_DVBUS_PUREN 0x00800000 + /* Pull-up resistance on D+ is enabled */ + +#define SDR0_USB2PHY0CR_WDINT_MASK 0x01000000 + /* PHY UTMI data width and clock select */ +#define SDR0_USB2PHY0CR_WDINT_8BIT_60MHZ 0x00000000 /* 8-bit data/60MHz */ +#define SDR0_USB2PHY0CR_WDINT_16BIT_30MHZ 0x01000000 /* 16-bit data/30MHz */ + +#define SDR0_USB2PHY0CR_LOOPEN_MASK 0x02000000 /* Loop back test enable */ +#define SDR0_USB2PHY0CR_LOOP_ENABLE 0x00000000 /* Loop back disabled */ +#define SDR0_USB2PHY0CR_LOOP_DISABLE 0x02000000 + /* Loop back enabled (only test purposes) */ + +#define SDR0_USB2PHY0CR_XOON_MASK 0x04000000 + /* Force XO block on during a suspend */ +#define SDR0_USB2PHY0CR_XO_ON 0x00000000 /* PHY XO block is powered-on */ +#define SDR0_USB2PHY0CR_XO_OFF 0x04000000 + /* PHY XO block is powered-off when all ports are suspended */ + +#define SDR0_USB2PHY0CR_PWRSAV_MASK 0x08000000 /* Select PHY power-save mode */ +#define SDR0_USB2PHY0CR_PWRSAV_OFF 0x00000000 /* Non-power-save mode */ +#define SDR0_USB2PHY0CR_PWRSAV_ON 0x08000000 /* Power-save mode. Valid only + for full-speed operation */ + +#define SDR0_USB2PHY0CR_XOREF_MASK 0x10000000 /* Select reference clock + source */ +#define SDR0_USB2PHY0CR_XOREF_INTERNAL 0x00000000 /* PHY PLL uses chip internal + 48M clock as a reference */ +#define SDR0_USB2PHY0CR_XOREF_XO 0x10000000 /* PHY PLL uses internal XO + block output as a reference */ + +#define SDR0_USB2PHY0CR_XOCLK_MASK 0x20000000 /* Select clock for XO + block*/ +#define SDR0_USB2PHY0CR_XOCLK_EXTERNAL 0x00000000 /* PHY macro used an external + clock */ +#define SDR0_USB2PHY0CR_XOCLK_CRYSTAL 0x20000000 /* PHY macro uses the clock + from a crystal */ + +#define SDR0_USB2PHY0CR_CLKSEL_MASK 0xc0000000 /* Select ref clk freq */ +#define SDR0_USB2PHY0CR_CLKSEL_12MHZ 0x00000000 /* Select ref clk freq + = 12 MHz */ +#define SDR0_USB2PHY0CR_CLKSEL_48MHZ 0x40000000 /* Select ref clk freq + = 48 MHz */ +#define SDR0_USB2PHY0CR_CLKSEL_24MHZ 0x80000000 /* Select ref clk freq + = 24 MHz */ + + /* Miscealleneaous Function Reg. */ +#define SDR0_MFR 0x4300 +#define SDR0_MFR_ETH0_CLK_SEL_MASK 0x08000000 /* Ethernet0 Clock Select */ +#define SDR0_MFR_ETH0_CLK_SEL_EXT 0x00000000 +#define SDR0_MFR_ETH1_CLK_SEL_MASK 0x04000000 /* Ethernet1 Clock Select */ +#define SDR0_MFR_ETH1_CLK_SEL_EXT 0x00000000 +#define SDR0_MFR_ZMII_MODE_MASK 0x03000000 /* ZMII Mode Mask */ +#define SDR0_MFR_ZMII_MODE_MII 0x00000000 /* ZMII Mode MII */ +#define SDR0_MFR_ZMII_MODE_SMII 0x01000000 /* ZMII Mode SMII */ +#define SDR0_MFR_ZMII_MODE_BIT0 0x02000000 /* ZMII Mode Bit0 */ +#define SDR0_MFR_ZMII_MODE_BIT1 0x01000000 /* ZMII Mode Bit1 */ +#define SDR0_MFR_ZM_ENCODE(n) ((((unsigned long)(n))&0x3)<<24) +#define SDR0_MFR_ZM_DECODE(n) ((((unsigned long)(n))<<24)&0x3) + +#define SDR0_MFR_ERRATA3_EN0 0x00800000 +#define SDR0_MFR_ERRATA3_EN1 0x00400000 +#define SDR0_MFR_PKT_REJ_MASK 0x00180000 /* Pkt Rej. Enable Mask */ +#define SDR0_MFR_PKT_REJ_EN 0x00180000 /* Pkt Rej. Ena. on both EMAC3 0-1 */ +#define SDR0_MFR_PKT_REJ_EN0 0x00100000 /* Pkt Rej. Enable on EMAC3(0) */ +#define SDR0_MFR_PKT_REJ_EN1 0x00080000 /* Pkt Rej. Enable on EMAC3(1) */ +#define SDR0_MFR_PKT_REJ_POL 0x00200000 /* Packet Reject Polarity */
#endif /* defined(CONFIG_440EPX) || defined(CONFIG_440GRX) */
-/* CUST1 Customer Configuration Register1 */ -#define SDR0_CUST1 0x4002 -#define SDR0_CUST1_NDRSC_MASK 0xFFFF0000 /* NDRSC Device Read Count */ -#define SDR0_CUST1_NDRSC_ENCODE(n) ((((unsigned long)(n))&0xFFFF)<<16) -#define SDR0_CUST1_NDRSC_DECODE(n) ((((unsigned long)(n))>>16)&0xFFFF) - -/* Pin Function Control Register 0 */ -#define SDR0_PFC0 0x4100 -#define SDR0_PFC0_CPU_TR_EN_MASK 0x00000100 /* CPU Trace Enable Mask */ -#define SDR0_PFC0_CPU_TRACE_EN 0x00000100 /* CPU Trace Enable */ -#define SDR0_PFC0_CPU_TRACE_DIS 0x00000100 /* CPU Trace Disable */ -#define SDR0_PFC0_CTE_ENCODE(n) ((((unsigned long)(n))&0x01)<<8) -#define SDR0_PFC0_CTE_DECODE(n) ((((unsigned long)(n))>>8)&0x01) - -/* Pin Function Control Register 1 */ -#define SDR0_PFC1 0x4101 -#define SDR0_PFC1_U1ME_MASK 0x02000000 /* UART1 Mode Enable */ -#define SDR0_PFC1_U1ME_DSR_DTR 0x00000000 /* UART1 in DSR/DTR Mode */ -#define SDR0_PFC1_U1ME_CTS_RTS 0x02000000 /* UART1 in CTS/RTS Mode */ -#define SDR0_PFC1_U0ME_MASK 0x00080000 /* UART0 Mode Enable */ -#define SDR0_PFC1_U0ME_DSR_DTR 0x00000000 /* UART0 in DSR/DTR Mode */ -#define SDR0_PFC1_U0ME_CTS_RTS 0x00080000 /* UART0 in CTS/RTS Mode */ -#define SDR0_PFC1_U0IM_MASK 0x00040000 /* UART0 Interface Mode */ -#define SDR0_PFC1_U0IM_8PINS 0x00000000 /* UART0 Interface Mode 8 pins */ -#define SDR0_PFC1_U0IM_4PINS 0x00040000 /* UART0 Interface Mode 4 pins */ -#define SDR0_PFC1_SIS_MASK 0x00020000 /* SCP or IIC1 Selection */ -#define SDR0_PFC1_SIS_SCP_SEL 0x00000000 /* SCP Selected */ -#define SDR0_PFC1_SIS_IIC1_SEL 0x00020000 /* IIC1 Selected */ -#define SDR0_PFC1_UES_MASK 0x00010000 /* USB2D_RX_Active / EBC_Hold Req Selection */ -#define SDR0_PFC1_UES_USB2D_SEL 0x00000000 /* USB2D_RX_Active Selected */ -#define SDR0_PFC1_UES_EBCHR_SEL 0x00010000 /* EBC_Hold Req Selected */ -#define SDR0_PFC1_DIS_MASK 0x00008000 /* DMA_Req(1) / UIC_IRQ(5) Selection */ -#define SDR0_PFC1_DIS_DMAR_SEL 0x00000000 /* DMA_Req(1) Selected */ -#define SDR0_PFC1_DIS_UICIRQ5_SEL 0x00008000 /* UIC_IRQ(5) Selected */ -#define SDR0_PFC1_ERE_MASK 0x00004000 /* EBC Mast.Ext.Req.En./GPIO0(27) Selection */ -#define SDR0_PFC1_ERE_EXTR_SEL 0x00000000 /* EBC Mast.Ext.Req.En. Selected */ -#define SDR0_PFC1_ERE_GPIO0_27_SEL 0x00004000 /* GPIO0(27) Selected */ -#define SDR0_PFC1_UPR_MASK 0x00002000 /* USB2 Device Packet Reject Selection */ -#define SDR0_PFC1_UPR_DISABLE 0x00000000 /* USB2 Device Packet Reject Disable */ -#define SDR0_PFC1_UPR_ENABLE 0x00002000 /* USB2 Device Packet Reject Enable */ - -#define SDR0_PFC1_PLB_PME_MASK 0x00001000 /* PLB3/PLB4 Perf. Monitor En. Selection */ -#define SDR0_PFC1_PLB_PME_PLB3_SEL 0x00000000 /* PLB3 Performance Monitor Enable */ -#define SDR0_PFC1_PLB_PME_PLB4_SEL 0x00001000 /* PLB3 Performance Monitor Enable */ -#define SDR0_PFC1_GFGGI_MASK 0x0000000F /* GPT Frequency Generation Gated In */ + /* CUST1 Customer Configuration Register1 */ +#define SDR0_CUST1 0x4002 +#define SDR0_CUST1_NDRSC_MASK 0xFFFF0000 /* NDRSC Device Read Count */ +#define SDR0_CUST1_NDRSC_ENCODE(n) ((((unsigned long)(n))&0xFFFF)<<16) +#define SDR0_CUST1_NDRSC_DECODE(n) ((((unsigned long)(n))>>16)&0xFFFF) + + /* Pin Function Control Register 0 */ +#define SDR0_PFC0 0x4100 +#define SDR0_PFC0_CPU_TR_EN_MASK 0x00000100 /* CPU Trace Enable Mask */ +#define SDR0_PFC0_CPU_TRACE_EN 0x00000100 /* CPU Trace Enable */ +#define SDR0_PFC0_CPU_TRACE_DIS 0x00000100 /* CPU Trace Disable */ +#define SDR0_PFC0_CTE_ENCODE(n) ((((unsigned long)(n))&0x01)<<8) +#define SDR0_PFC0_CTE_DECODE(n) ((((unsigned long)(n))>>8)&0x01) + + /* Pin Function Control Register 1 */ +#define SDR0_PFC1 0x4101 +#define SDR0_PFC1_U1ME_MASK 0x02000000 /* UART1 Mode Enable */ +#define SDR0_PFC1_U1ME_DSR_DTR 0x00000000 /* UART1 in DSR/DTR Mode */ +#define SDR0_PFC1_U1ME_CTS_RTS 0x02000000 /* UART1 in CTS/RTS Mode */ +#define SDR0_PFC1_U0ME_MASK 0x00080000 /* UART0 Mode Enable */ +#define SDR0_PFC1_U0ME_DSR_DTR 0x00000000 /* UART0 in DSR/DTR Mode */ +#define SDR0_PFC1_U0ME_CTS_RTS 0x00080000 /* UART0 in CTS/RTS Mode */ +#define SDR0_PFC1_U0IM_MASK 0x00040000 /* UART0 Interface Mode */ +#define SDR0_PFC1_U0IM_8PINS 0x00000000 /* UART0 Interface Mode 8 pins */ +#define SDR0_PFC1_U0IM_4PINS 0x00040000 /* UART0 Interface Mode 4 pins */ +#define SDR0_PFC1_SIS_MASK 0x00020000 /* SCP or IIC1 Selection */ +#define SDR0_PFC1_SIS_SCP_SEL 0x00000000 /* SCP Selected */ +#define SDR0_PFC1_SIS_IIC1_SEL 0x00020000 /* IIC1 Selected */ +#define SDR0_PFC1_UES_MASK 0x00010000 /* USB2D_RX_Active / EBC_Hold Req + Selection */ +#define SDR0_PFC1_UES_USB2D_SEL 0x00000000 /* USB2D_RX_Active Selected */ +#define SDR0_PFC1_UES_EBCHR_SEL 0x00010000 /* EBC_Hold Req Selected */ +#define SDR0_PFC1_DIS_MASK 0x00008000 /* DMA_Req(1) / UIC_IRQ(5) + Selection */ +#define SDR0_PFC1_DIS_DMAR_SEL 0x00000000 /* DMA_Req(1) Selected */ +#define SDR0_PFC1_DIS_UICIRQ5_SEL 0x00008000 /* UIC_IRQ(5) Selected */ +#define SDR0_PFC1_ERE_MASK 0x00004000 /* EBC Mast.Ext.Req.En./GPIO0(27) + Selection */ +#define SDR0_PFC1_ERE_EXTR_SEL 0x00000000 /* EBC Mast.Ext.Req.En. Selected */ +#define SDR0_PFC1_ERE_GPIO0_27_SEL 0x00004000 /* GPIO0(27) Selected */ +#define SDR0_PFC1_UPR_MASK 0x00002000 /* USB2 Device Packet Reject + Selection */ +#define SDR0_PFC1_UPR_DISABLE 0x00000000 /* USB2 Device Packet Reject + Disable */ +#define SDR0_PFC1_UPR_ENABLE 0x00002000 /* USB2 Device Packet Reject + Enable */ + +#define SDR0_PFC1_PLB_PME_MASK 0x00001000 /* PLB3/PLB4 Perf. Monitor En. + Selection */ +#define SDR0_PFC1_PLB_PME_PLB3_SEL 0x00000000 /* PLB3 Performance Monitor + Enable */ +#define SDR0_PFC1_PLB_PME_PLB4_SEL 0x00001000 /* PLB3 Performance Monitor + Enable */ +#define SDR0_PFC1_GFGGI_MASK 0x0000000F /* GPT Frequency Generation + Gated In */
#endif /* 440EP || 440GR || 440EPX || 440GRX */
#if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) -/* CUST0 Customer Configuration Register0 */ -#define SDR0_CUST0 0x4000 -#define SDR0_CUST0_MUX_E_N_G_MASK 0xC0000000 /* Mux_Emac_NDFC_GPIO */ -#define SDR0_CUST0_MUX_EMAC_SEL 0x40000000 /* Emac Selection */ -#define SDR0_CUST0_MUX_NDFC_SEL 0x80000000 /* NDFC Selection */ -#define SDR0_CUST0_MUX_GPIO_SEL 0xC0000000 /* GPIO Selection */ - -#define SDR0_CUST0_NDFC_EN_MASK 0x20000000 /* NDFC Enable Mask */ -#define SDR0_CUST0_NDFC_ENABLE 0x20000000 /* NDFC Enable */ -#define SDR0_CUST0_NDFC_DISABLE 0x00000000 /* NDFC Disable */ - -#define SDR0_CUST0_NDFC_BW_MASK 0x10000000 /* NDFC Boot Width */ -#define SDR0_CUST0_NDFC_BW_16_BIT 0x10000000 /* NDFC Boot Width = 16 Bit */ -#define SDR0_CUST0_NDFC_BW_8_BIT 0x00000000 /* NDFC Boot Width = 8 Bit */ - -#define SDR0_CUST0_NDFC_BP_MASK 0x0F000000 /* NDFC Boot Page */ -#define SDR0_CUST0_NDFC_BP_ENCODE(n) ((((unsigned long)(n))&0xF)<<24) -#define SDR0_CUST0_NDFC_BP_DECODE(n) ((((unsigned long)(n))>>24)&0x0F) - -#define SDR0_CUST0_NDFC_BAC_MASK 0x00C00000 /* NDFC Boot Address Cycle */ -#define SDR0_CUST0_NDFC_BAC_ENCODE(n) ((((unsigned long)(n))&0x3)<<22) -#define SDR0_CUST0_NDFC_BAC_DECODE(n) ((((unsigned long)(n))>>22)&0x03) - -#define SDR0_CUST0_NDFC_ARE_MASK 0x00200000 /* NDFC Auto Read Enable */ -#define SDR0_CUST0_NDFC_ARE_ENABLE 0x00200000 /* NDFC Auto Read Enable */ -#define SDR0_CUST0_NDFC_ARE_DISABLE 0x00000000 /* NDFC Auto Read Disable */ - -#define SDR0_CUST0_NRB_MASK 0x00100000 /* NDFC Ready / Busy */ -#define SDR0_CUST0_NRB_BUSY 0x00100000 /* Busy */ -#define SDR0_CUST0_NRB_READY 0x00000000 /* Ready */ - -#define SDR0_CUST0_NDRSC_MASK 0x0000FFF0 /* NDFC Device Reset Count Mask */ -#define SDR0_CUST0_NDRSC_ENCODE(n) ((((unsigned long)(n))&0xFFF)<<4) -#define SDR0_CUST0_NDRSC_DECODE(n) ((((unsigned long)(n))>>4)&0xFFF) - -#define SDR0_CUST0_CHIPSELGAT_MASK 0x0000000F /* Chip Select Gating Mask */ -#define SDR0_CUST0_CHIPSELGAT_DIS 0x00000000 /* Chip Select Gating Disable */ -#define SDR0_CUST0_CHIPSELGAT_ENALL 0x0000000F /* All Chip Select Gating Enable */ -#define SDR0_CUST0_CHIPSELGAT_EN0 0x00000008 /* Chip Select0 Gating Enable */ -#define SDR0_CUST0_CHIPSELGAT_EN1 0x00000004 /* Chip Select1 Gating Enable */ -#define SDR0_CUST0_CHIPSELGAT_EN2 0x00000002 /* Chip Select2 Gating Enable */ -#define SDR0_CUST0_CHIPSELGAT_EN3 0x00000001 /* Chip Select3 Gating Enable */ + /* CUST0 Customer Configuration Register0 */ +#define SDR0_CUST0 0x4000 +#define SDR0_CUST0_MUX_E_N_G_MASK 0xC0000000 /* Mux_Emac_NDFC_GPIO */ +#define SDR0_CUST0_MUX_EMAC_SEL 0x40000000 /* Emac Selection */ +#define SDR0_CUST0_MUX_NDFC_SEL 0x80000000 /* NDFC Selection */ +#define SDR0_CUST0_MUX_GPIO_SEL 0xC0000000 /* GPIO Selection */ + +#define SDR0_CUST0_NDFC_EN_MASK 0x20000000 /* NDFC Enable Mask */ +#define SDR0_CUST0_NDFC_ENABLE 0x20000000 /* NDFC Enable */ +#define SDR0_CUST0_NDFC_DISABLE 0x00000000 /* NDFC Disable */ + +#define SDR0_CUST0_NDFC_BW_MASK 0x10000000 /* NDFC Boot Width */ +#define SDR0_CUST0_NDFC_BW_16_BIT 0x10000000 /* NDFC Boot Width = 16 Bit */ +#define SDR0_CUST0_NDFC_BW_8_BIT 0x00000000 /* NDFC Boot Width = 8 Bit */ + +#define SDR0_CUST0_NDFC_BP_MASK 0x0F000000 /* NDFC Boot Page */ +#define SDR0_CUST0_NDFC_BP_ENCODE(n) ((((unsigned long)(n))&0xF)<<24) +#define SDR0_CUST0_NDFC_BP_DECODE(n) ((((unsigned long)(n))>>24)&0x0F) + +#define SDR0_CUST0_NDFC_BAC_MASK 0x00C00000 /* NDFC Boot Address Cycle */ +#define SDR0_CUST0_NDFC_BAC_ENCODE(n) ((((unsigned long)(n))&0x3)<<22) +#define SDR0_CUST0_NDFC_BAC_DECODE(n) ((((unsigned long)(n))>>22)&0x03) + +#define SDR0_CUST0_NDFC_ARE_MASK 0x00200000 /* NDFC Auto Read Enable */ +#define SDR0_CUST0_NDFC_ARE_ENABLE 0x00200000 /* NDFC Auto Read Enable */ +#define SDR0_CUST0_NDFC_ARE_DISABLE 0x00000000 /* NDFC Auto Read Disable */ + +#define SDR0_CUST0_NRB_MASK 0x00100000 /* NDFC Ready / Busy */ +#define SDR0_CUST0_NRB_BUSY 0x00100000 /* Busy */ +#define SDR0_CUST0_NRB_READY 0x00000000 /* Ready */ + +#define SDR0_CUST0_NDRSC_MASK 0x0000FFF0 /* NDFC Device Reset Count Mask */ +#define SDR0_CUST0_NDRSC_ENCODE(n) ((((unsigned long)(n))&0xFFF)<<4) +#define SDR0_CUST0_NDRSC_DECODE(n) ((((unsigned long)(n))>>4)&0xFFF) + +#define SDR0_CUST0_CHIPSELGAT_MASK 0x0000000F /* Chip Select Gating Mask */ +#define SDR0_CUST0_CHIPSELGAT_DIS 0x00000000 /* Chip Select Gating Disable */ +#define SDR0_CUST0_CHIPSELGAT_ENALL 0x0000000F /*All Chip Select Gating Enable*/ +#define SDR0_CUST0_CHIPSELGAT_EN0 0x00000008 /* Chip Select0 Gating Enable */ +#define SDR0_CUST0_CHIPSELGAT_EN1 0x00000004 /* Chip Select1 Gating Enable */ +#define SDR0_CUST0_CHIPSELGAT_EN2 0x00000002 /* Chip Select2 Gating Enable */ +#define SDR0_CUST0_CHIPSELGAT_EN3 0x00000001 /* Chip Select3 Gating Enable */ #endif
/*----------------------------------------------------------------------------- @@ -534,16 +596,16 @@ #define CNTRL_DCR_BASE 0x0b0 #endif
-#define CPC0_SYS0 (CNTRL_DCR_BASE+0x30) /* System configuration reg 0 */ -#define CPC0_SYS1 (CNTRL_DCR_BASE+0x31) /* System configuration reg 1 */ +#define CPC0_SYS0 (CNTRL_DCR_BASE+0x30) /* System configuration reg 0 */ +#define CPC0_SYS1 (CNTRL_DCR_BASE+0x31) /* System configuration reg 1 */
-#define CPC0_STRP0 (CNTRL_DCR_BASE+0x34) /* Power-on config reg 0 (RO) */ -#define CPC0_STRP1 (CNTRL_DCR_BASE+0x35) /* Power-on config reg 1 (RO) */ +#define CPC0_STRP0 (CNTRL_DCR_BASE+0x34) /* Power-on config reg 0 (RO) */ +#define CPC0_STRP1 (CNTRL_DCR_BASE+0x35) /* Power-on config reg 1 (RO) */
-#define CPC0_GPIO (CNTRL_DCR_BASE+0x38) /* GPIO config reg (440GP) */ +#define CPC0_GPIO (CNTRL_DCR_BASE+0x38) /* GPIO config reg (440GP) */
-#define CPC0_CR0 (CNTRL_DCR_BASE+0x3b) /* Control 0 register */ -#define CPC0_CR1 (CNTRL_DCR_BASE+0x3a) /* Control 1 register */ +#define CPC0_CR0 (CNTRL_DCR_BASE+0x3b) /* Control 0 register */ +#define CPC0_CR1 (CNTRL_DCR_BASE+0x3a) /* Control 1 register */
/*----------------------------------------------------------------------------- | DMA @@ -572,12 +634,12 @@ #define MAL0_IER (MAL_DCR_BASE + 0x02) /* Interrupt enable */ #define MAL0_TXCASR (MAL_DCR_BASE + 0x04) /* TX Channel active (set) */ #define MAL0_TXCARR (MAL_DCR_BASE + 0x05) /* TX Channel active (reset) */ -#define MAL0_TXEOBISR (MAL_DCR_BASE + 0x06) /* TX End of buffer int status */ +#define MAL0_TXEOBISR (MAL_DCR_BASE + 0x06) /* TX End of buffer int status*/ #define MAL0_TXDEIR (MAL_DCR_BASE + 0x07) /* TX Descr. Error Int */ #define MAL0_TXBADDR (MAL_DCR_BASE + 0x09) /* TX descriptor base addr*/ #define MAL0_RXCASR (MAL_DCR_BASE + 0x10) /* RX Channel active (set) */ #define MAL0_RXCARR (MAL_DCR_BASE + 0x11) /* RX Channel active (reset) */ -#define MAL0_RXEOBISR (MAL_DCR_BASE + 0x12) /* RX End of buffer int status */ +#define MAL0_RXEOBISR (MAL_DCR_BASE + 0x12) /* RX End of buffer int status*/ #define MAL0_RXDEIR (MAL_DCR_BASE + 0x13) /* RX Descr. Error Int */ #define MAL0_RXBADDR (MAL_DCR_BASE + 0x15) /* RX descriptor base addr */ #define MAL0_TXCTP0R (MAL_DCR_BASE + 0x20) /* TX 0 Channel table pointer */ @@ -658,7 +720,7 @@ #define SDR0_SDSTP0_TUNE_DECODE(n) ((((unsigned long)(n))>>17)&0x3FF) #define SDR0_SDSTP0_FBDV_MASK 0x0001F000 #define SDR0_SDSTP0_FBDV_ENCODE(n) ((((unsigned long)(n))&0x1F)<<12) -#define SDR0_SDSTP0_FBDV_DECODE(n) ((((((unsigned long)(n))>>12)-1)&0x1F)+1) +#define SDR0_SDSTP0_FBDV_DECODE(n) ((((((unsigned long)(n))>>12)-1)&0x1F)+1) #define SDR0_SDSTP0_FWDVA_MASK 0x00000F00 #define SDR0_SDSTP0_FWDVA_ENCODE(n) ((((unsigned long)(n))&0x0F)<<8) #define SDR0_SDSTP0_FWDVA_DECODE(n) ((((((unsigned long)(n))>>8)-1)&0x0F)+1) @@ -732,8 +794,8 @@ #define SDR0_SDSTP1_DBGEN_MASK 0x00000030 /* $218C */ #define SDR0_SDSTP1_DBGEN_FUNC 0x00000000 #define SDR0_SDSTP1_DBGEN_TRACE 0x00000010 -#define SDR0_SDSTP1_DBGEN_ENCODE(n) ((((unsigned long)(n))&0x03)<<4) /* $218C */ -#define SDR0_SDSTP1_DBGEN_DECODE(n) ((((unsigned long)(n))>>4)&0x03) /* $218C */ +#define SDR0_SDSTP1_DBGEN_ENCODE(n) ((((unsigned long)(n))&0x03)<<4) /* $218C */ +#define SDR0_SDSTP1_DBGEN_DECODE(n) ((((unsigned long)(n))>>4)&0x03) /* $218C */ #define SDR0_SDSTP1_ETH_MASK 0x00000004 #define SDR0_SDSTP1_ETH_10_100 0x00000000 #define SDR0_SDSTP1_ETH_GIGA 0x00000004 @@ -816,10 +878,14 @@
#define SDR0_PINSTP 0x0040 #define SDR0_PINSTP_BOOTSTRAP_MASK 0xC0000000 /* Strap Bits */ -#define SDR0_PINSTP_BOOTSTRAP_SETTINGS0 0x00000000 /* Default strap settings 0 (EBC boot) */ -#define SDR0_PINSTP_BOOTSTRAP_SETTINGS1 0x40000000 /* Default strap settings 1 (PCI boot) */ -#define SDR0_PINSTP_BOOTSTRAP_IIC_54_EN 0x80000000 /* Serial Device Enabled - Addr = 0x54 */ -#define SDR0_PINSTP_BOOTSTRAP_IIC_50_EN 0xC0000000 /* Serial Device Enabled - Addr = 0x50 */ +#define SDR0_PINSTP_BOOTSTRAP_SETTINGS0 0x00000000 /* Default strap settings 0 + (EBC boot) */ +#define SDR0_PINSTP_BOOTSTRAP_SETTINGS1 0x40000000 /* Default strap settings 1 + (PCI boot) */ +#define SDR0_PINSTP_BOOTSTRAP_IIC_54_EN 0x80000000 /* Serial Device Enabled - + Addr = 0x54 */ +#define SDR0_PINSTP_BOOTSTRAP_IIC_50_EN 0xC0000000 /* Serial Device Enabled - + Addr = 0x50 */ #define SDR0_SDCS 0x0060 #define SDR0_ECID0 0x0080 #define SDR0_ECID1 0x0081 @@ -960,8 +1026,10 @@ #define SDR0_PFC1_CPU_TRACE_MASK 0x00180000 /* $218C */ #define SDR0_PFC1_CPU_NO_TRACE 0x00000000 #define SDR0_PFC1_CPU_TRACE 0x00080000 -#define SDR0_PFC1_CPU_TRACE_ENCODE(n) ((((unsigned long)(n))&0x3)<<19) /* $218C */ -#define SDR0_PFC1_CPU_TRACE_DECODE(n) ((((unsigned long)(n))>>19)&0x03) /* $218C */ +#define SDR0_PFC1_CPU_TRACE_ENCODE(n) ((((unsigned long)(n))&0x3)<<19) + /* $218C */ +#define SDR0_PFC1_CPU_TRACE_DECODE(n) ((((unsigned long)(n))>>19)&0x03) + /* $218C */
#define SDR0_MFR 0x4300 #endif /* CONFIG_440SPE */ @@ -1023,34 +1091,43 @@
/* Ethernet Configuration Register (SDR0_ETH_CFG) */ #define SDR0_ETH_CFG 0x4103 -#define SDR0_ETH_CFG_SGMII3_LPBK 0x00800000 /* SGMII3 port loopback enable */ -#define SDR0_ETH_CFG_SGMII2_LPBK 0x00400000 /* SGMII2 port loopback enable */ -#define SDR0_ETH_CFG_SGMII1_LPBK 0x00200000 /* SGMII1 port loopback enable */ -#define SDR0_ETH_CFG_SGMII0_LPBK 0x00100000 /* SGMII0 port loopback enable */ -#define SDR0_ETH_CFG_SGMII_MASK 0x00070000 /* SGMII Mask */ -#define SDR0_ETH_CFG_SGMII2_ENABLE 0x00040000 /* SGMII2 port enable */ -#define SDR0_ETH_CFG_SGMII1_ENABLE 0x00020000 /* SGMII1 port enable */ -#define SDR0_ETH_CFG_SGMII0_ENABLE 0x00010000 /* SGMII0 port enable */ -#define SDR0_ETH_CFG_TAHOE1_BYPASS 0x00002000 /* TAHOE1 Bypass selector */ -#define SDR0_ETH_CFG_TAHOE0_BYPASS 0x00001000 /* TAHOE0 Bypass selector */ -#define SDR0_ETH_CFG_EMAC3_PHY_CLK_SEL 0x00000800 /* EMAC 3 PHY clock selector */ -#define SDR0_ETH_CFG_EMAC2_PHY_CLK_SEL 0x00000400 /* EMAC 2 PHY clock selector */ -#define SDR0_ETH_CFG_EMAC1_PHY_CLK_SEL 0x00000200 /* EMAC 1 PHY clock selector */ -#define SDR0_ETH_CFG_EMAC0_PHY_CLK_SEL 0x00000100 /* EMAC 0 PHY clock selector */ -#define SDR0_ETH_CFG_EMAC_2_1_SWAP 0x00000080 /* Swap EMAC2 with EMAC1 */ -#define SDR0_ETH_CFG_EMAC_0_3_SWAP 0x00000040 /* Swap EMAC0 with EMAC3 */ -#define SDR0_ETH_CFG_MDIO_SEL_MASK 0x00000030 /* MDIO source selector mask */ -#define SDR0_ETH_CFG_MDIO_SEL_EMAC0 0x00000000 /* MDIO source - EMAC0 */ -#define SDR0_ETH_CFG_MDIO_SEL_EMAC1 0x00000010 /* MDIO source - EMAC1 */ -#define SDR0_ETH_CFG_MDIO_SEL_EMAC2 0x00000020 /* MDIO source - EMAC2 */ -#define SDR0_ETH_CFG_MDIO_SEL_EMAC3 0x00000030 /* MDIO source - EMAC3 */ -#define SDR0_ETH_CFG_ZMII_MODE_MASK 0x0000000C /* ZMII bridge mode selector mask */ -#define SDR0_ETH_CFG_ZMII_SEL_MII 0x00000000 /* ZMII bridge mode - MII */ -#define SDR0_ETH_CFG_ZMII_SEL_SMII 0x00000004 /* ZMII bridge mode - SMII */ -#define SDR0_ETH_CFG_ZMII_SEL_RMII_10 0x00000008 /* ZMII bridge mode - RMII (10 Mbps) */ -#define SDR0_ETH_CFG_ZMII_SEL_RMII_100 0x0000000C /* ZMII bridge mode - RMII (100 Mbps) */ -#define SDR0_ETH_CFG_GMC1_BRIDGE_SEL 0x00000002 /* GMC Port 1 bridge selector */ -#define SDR0_ETH_CFG_GMC0_BRIDGE_SEL 0x00000001 /* GMC Port 0 bridge selector */ +#define SDR0_ETH_CFG_SGMII3_LPBK 0x00800000 /*SGMII3 port loopback + enable */ +#define SDR0_ETH_CFG_SGMII2_LPBK 0x00400000 /*SGMII2 port loopback + enable */ +#define SDR0_ETH_CFG_SGMII1_LPBK 0x00200000 /*SGMII1 port loopback + enable */ +#define SDR0_ETH_CFG_SGMII0_LPBK 0x00100000 /*SGMII0 port loopback + enable */ +#define SDR0_ETH_CFG_SGMII_MASK 0x00070000 /*SGMII Mask */ +#define SDR0_ETH_CFG_SGMII2_ENABLE 0x00040000 /*SGMII2 port enable */ +#define SDR0_ETH_CFG_SGMII1_ENABLE 0x00020000 /*SGMII1 port enable */ +#define SDR0_ETH_CFG_SGMII0_ENABLE 0x00010000 /*SGMII0 port enable */ +#define SDR0_ETH_CFG_TAHOE1_BYPASS 0x00002000 /*TAHOE1 Bypass selector */ +#define SDR0_ETH_CFG_TAHOE0_BYPASS 0x00001000 /*TAHOE0 Bypass selector */ +#define SDR0_ETH_CFG_EMAC3_PHY_CLK_SEL 0x00000800 /*EMAC 3 PHY clock selector*/ +#define SDR0_ETH_CFG_EMAC2_PHY_CLK_SEL 0x00000400 /*EMAC 2 PHY clock selector*/ +#define SDR0_ETH_CFG_EMAC1_PHY_CLK_SEL 0x00000200 /*EMAC 1 PHY clock selector*/ +#define SDR0_ETH_CFG_EMAC0_PHY_CLK_SEL 0x00000100 /*EMAC 0 PHY clock selector*/ +#define SDR0_ETH_CFG_EMAC_2_1_SWAP 0x00000080 /*Swap EMAC2 with EMAC1 */ +#define SDR0_ETH_CFG_EMAC_0_3_SWAP 0x00000040 /*Swap EMAC0 with EMAC3 */ +#define SDR0_ETH_CFG_MDIO_SEL_MASK 0x00000030 /*MDIO source selector mask*/ +#define SDR0_ETH_CFG_MDIO_SEL_EMAC0 0x00000000 /*MDIO source - EMAC0 */ +#define SDR0_ETH_CFG_MDIO_SEL_EMAC1 0x00000010 /*MDIO source - EMAC1 */ +#define SDR0_ETH_CFG_MDIO_SEL_EMAC2 0x00000020 /*MDIO source - EMAC2 */ +#define SDR0_ETH_CFG_MDIO_SEL_EMAC3 0x00000030 /*MDIO source - EMAC3 */ +#define SDR0_ETH_CFG_ZMII_MODE_MASK 0x0000000C /*ZMII bridge mode selector + mask */ +#define SDR0_ETH_CFG_ZMII_SEL_MII 0x00000000 /*ZMII bridge mode - MII */ +#define SDR0_ETH_CFG_ZMII_SEL_SMII 0x00000004 /*ZMII bridge mode - SMII */ +#define SDR0_ETH_CFG_ZMII_SEL_RMII_10 0x00000008 /*ZMII bridge mode - RMII + (10 Mbps) */ +#define SDR0_ETH_CFG_ZMII_SEL_RMII_100 0x0000000C /*ZMII bridge mode - RMII + (100 Mbps) */ +#define SDR0_ETH_CFG_GMC1_BRIDGE_SEL 0x00000002 /*GMC Port 1 bridge + selector */ +#define SDR0_ETH_CFG_GMC0_BRIDGE_SEL 0x00000001 /*GMC Port 0 bridge + selector */
#define SDR0_ETH_CFG_ZMII_MODE_SHIFT 4 #define SDR0_ETH_CFG_ZMII_MII_MODE 0x00 @@ -1063,26 +1140,46 @@
/* Miscealleneaous Function Reg. (SDR0_MFR) */ #define SDR0_MFR 0x4300 -#define SDR0_MFR_T0TxFL 0x00800000 /* force parity error TAHOE0 Tx FIFO bits 0:63 */ -#define SDR0_MFR_T0TxFH 0x00400000 /* force parity error TAHOE0 Tx FIFO bits 64:127 */ -#define SDR0_MFR_T1TxFL 0x00200000 /* force parity error TAHOE1 Tx FIFO bits 0:63 */ -#define SDR0_MFR_T1TxFH 0x00100000 /* force parity error TAHOE1 Tx FIFO bits 64:127 */ -#define SDR0_MFR_E0TxFL 0x00008000 /* force parity error EMAC0 Tx FIFO bits 0:63 */ -#define SDR0_MFR_E0TxFH 0x00004000 /* force parity error EMAC0 Tx FIFO bits 64:127 */ -#define SDR0_MFR_E0RxFL 0x00002000 /* force parity error EMAC0 Rx FIFO bits 0:63 */ -#define SDR0_MFR_E0RxFH 0x00001000 /* force parity error EMAC0 Rx FIFO bits 64:127 */ -#define SDR0_MFR_E1TxFL 0x00000800 /* force parity error EMAC1 Tx FIFO bits 0:63 */ -#define SDR0_MFR_E1TxFH 0x00000400 /* force parity error EMAC1 Tx FIFO bits 64:127 */ -#define SDR0_MFR_E1RxFL 0x00000200 /* force parity error EMAC1 Rx FIFO bits 0:63 */ -#define SDR0_MFR_E1RxFH 0x00000100 /* force parity error EMAC1 Rx FIFO bits 64:127 */ -#define SDR0_MFR_E2TxFL 0x00000080 /* force parity error EMAC2 Tx FIFO bits 0:63 */ -#define SDR0_MFR_E2TxFH 0x00000040 /* force parity error EMAC2 Tx FIFO bits 64:127 */ -#define SDR0_MFR_E2RxFL 0x00000020 /* force parity error EMAC2 Rx FIFO bits 0:63 */ -#define SDR0_MFR_E2RxFH 0x00000010 /* force parity error EMAC2 Rx FIFO bits 64:127 */ -#define SDR0_MFR_E3TxFL 0x00000008 /* force parity error EMAC3 Tx FIFO bits 0:63 */ -#define SDR0_MFR_E3TxFH 0x00000004 /* force parity error EMAC3 Tx FIFO bits 64:127 */ -#define SDR0_MFR_E3RxFL 0x00000002 /* force parity error EMAC3 Rx FIFO bits 0:63 */ -#define SDR0_MFR_E3RxFH 0x00000001 /* force parity error EMAC3 Rx FIFO bits 64:127 */ +#define SDR0_MFR_T0TxFL 0x00800000 /* force parity error TAHOE0 Tx + FIFO bits 0:63 */ +#define SDR0_MFR_T0TxFH 0x00400000 /* force parity error TAHOE0 Tx + FIFO bits 64:127 */ +#define SDR0_MFR_T1TxFL 0x00200000 /* force parity error TAHOE1 Tx + FIFO bits 0:63 */ +#define SDR0_MFR_T1TxFH 0x00100000 /* force parity error TAHOE1 Tx + FIFO bits 64:127 */ +#define SDR0_MFR_E0TxFL 0x00008000 /* force parity error EMAC0 Tx + FIFO bits 0:63 */ +#define SDR0_MFR_E0TxFH 0x00004000 /* force parity error EMAC0 Tx + FIFO bits 64:127 */ +#define SDR0_MFR_E0RxFL 0x00002000 /* force parity error EMAC0 Rx + FIFO bits 0:63 */ +#define SDR0_MFR_E0RxFH 0x00001000 /* force parity error EMAC0 Rx + FIFO bits 64:127 */ +#define SDR0_MFR_E1TxFL 0x00000800 /* force parity error EMAC1 Tx + FIFO bits 0:63 */ +#define SDR0_MFR_E1TxFH 0x00000400 /* force parity error EMAC1 Tx + FIFO bits 64:127 */ +#define SDR0_MFR_E1RxFL 0x00000200 /* force parity error EMAC1 Rx + FIFO bits 0:63 */ +#define SDR0_MFR_E1RxFH 0x00000100 /* force parity error EMAC1 Rx + FIFO bits 64:127 */ +#define SDR0_MFR_E2TxFL 0x00000080 /* force parity error EMAC2 Tx + FIFO bits 0:63 */ +#define SDR0_MFR_E2TxFH 0x00000040 /* force parity error EMAC2 Tx + FIFO bits 64:127 */ +#define SDR0_MFR_E2RxFL 0x00000020 /* force parity error EMAC2 Rx + FIFO bits 0:63 */ +#define SDR0_MFR_E2RxFH 0x00000010 /* force parity error EMAC2 Rx + FIFO bits 64:127 */ +#define SDR0_MFR_E3TxFL 0x00000008 /* force parity error EMAC3 Tx + FIFO bits 0:63 */ +#define SDR0_MFR_E3TxFH 0x00000004 /* force parity error EMAC3 Tx + FIFO bits 64:127 */ +#define SDR0_MFR_E3RxFL 0x00000002 /* force parity error EMAC3 Rx + FIFO bits 0:63 */ +#define SDR0_MFR_E3RxFH 0x00000001 /* force parity error EMAC3 Rx + FIFO bits 64:127 */
/* EMACx TX Status Register (SDR0_EMACxTXST)*/ #define SDR0_EMAC0TXST 0x4400 @@ -1090,30 +1187,30 @@ #define SDR0_EMAC2TXST 0x4402 #define SDR0_EMAC3TXST 0x4403
-#define SDR0_EMACxTXST_FUR 0x02000000 /* TX FIFO underrun */ -#define SDR0_EMACxTXST_BC 0x01000000 /* broadcase address */ -#define SDR0_EMACxTXST_MC 0x00800000 /* multicast address */ -#define SDR0_EMACxTXST_UC 0x00400000 /* unicast address */ -#define SDR0_EMACxTXST_FP 0x00200000 /* frame paused by control packet */ -#define SDR0_EMACxTXST_BFCS 0x00100000 /* bad FCS in the transmitted frame */ -#define SDR0_EMACxTXST_CPF 0x00080000 /* TX control pause frame */ -#define SDR0_EMACxTXST_CF 0x00040000 /* TX control frame */ -#define SDR0_EMACxTXST_MSIZ 0x00020000 /* 1024-maxsize bytes transmitted */ -#define SDR0_EMACxTXST_1023 0x00010000 /* 512-1023 bytes transmitted */ -#define SDR0_EMACxTXST_511 0x00008000 /* 256-511 bytes transmitted */ -#define SDR0_EMACxTXST_255 0x00004000 /* 128-255 bytes transmitted */ -#define SDR0_EMACxTXST_127 0x00002000 /* 65-127 bytes transmitted */ -#define SDR0_EMACxTXST_64 0x00001000 /* 64 bytes transmitted */ -#define SDR0_EMACxTXST_SQE 0x00000800 /* SQE indication */ -#define SDR0_EMACxTXST_LOC 0x00000400 /* loss of carrier sense */ -#define SDR0_EMACxTXST_IERR 0x00000080 /* EMAC internal error */ -#define SDR0_EMACxTXST_EDF 0x00000040 /* excessive deferral */ -#define SDR0_EMACxTXST_ECOL 0x00000020 /* excessive collisions */ -#define SDR0_EMACxTXST_LCOL 0x00000010 /* late collision */ -#define SDR0_EMACxTXST_DFFR 0x00000008 /* deferred frame */ -#define SDR0_EMACxTXST_MCOL 0x00000004 /* multiple collision frame */ -#define SDR0_EMACxTXST_SCOL 0x00000002 /* single collision frame */ -#define SDR0_EMACxTXST_TXOK 0x00000001 /* transmit OK */ +#define SDR0_EMACxTXST_FUR 0x02000000 /*TX FIFO underrun */ +#define SDR0_EMACxTXST_BC 0x01000000 /*broadcase address */ +#define SDR0_EMACxTXST_MC 0x00800000 /*multicast address */ +#define SDR0_EMACxTXST_UC 0x00400000 /*unicast address */ +#define SDR0_EMACxTXST_FP 0x00200000 /*frame paused by control packet */ +#define SDR0_EMACxTXST_BFCS 0x00100000 /*bad FCS in the transmitted frame */ +#define SDR0_EMACxTXST_CPF 0x00080000 /*TX control pause frame */ +#define SDR0_EMACxTXST_CF 0x00040000 /*TX control frame */ +#define SDR0_EMACxTXST_MSIZ 0x00020000 /* 1024-maxsize bytes transmitted */ +#define SDR0_EMACxTXST_1023 0x00010000 /*512-1023 bytes transmitted */ +#define SDR0_EMACxTXST_511 0x00008000 /*256-511 bytes transmitted */ +#define SDR0_EMACxTXST_255 0x00004000 /*128-255 bytes transmitted */ +#define SDR0_EMACxTXST_127 0x00002000 /*65-127 bytes transmitted */ +#define SDR0_EMACxTXST_64 0x00001000 /*64 bytes transmitted */ +#define SDR0_EMACxTXST_SQE 0x00000800 /*SQE indication */ +#define SDR0_EMACxTXST_LOC 0x00000400 /*loss of carrier sense */ +#define SDR0_EMACxTXST_IERR 0x00000080 /*EMAC internal error */ +#define SDR0_EMACxTXST_EDF 0x00000040 /*excessive deferral */ +#define SDR0_EMACxTXST_ECOL 0x00000020 /*excessive collisions */ +#define SDR0_EMACxTXST_LCOL 0x00000010 /*late collision */ +#define SDR0_EMACxTXST_DFFR 0x00000008 /*deferred frame */ +#define SDR0_EMACxTXST_MCOL 0x00000004 /*multiple collision frame */ +#define SDR0_EMACxTXST_SCOL 0x00000002 /*single collision frame */ +#define SDR0_EMACxTXST_TXOK 0x00000001 /*transmit OK */
/* EMACx RX Status Register (SDR0_EMACxRXST)*/ #define SDR0_EMAC0RXST 0x4404 @@ -1146,8 +1243,9 @@ #define SDR0_EMACxRXST_F2L 0x00000020 /* frame is to long */ #define SDR0_EMACxRXST_OERR 0x00000010 /* out of range length error */ #define SDR0_EMACxRXST_IERR 0x00000008 /* in range length error */ -#define SDR0_EMACxRXST_LOST 0x00000004 /* frame lost due to internal EMAC receive error */ -#define SDR0_EMACxRXST_BFCS 0x00000002 /* bad FCS in the recieved frame */ +#define SDR0_EMACxRXST_LOST 0x00000004 /* frame lost due to internal + EMAC receive error */ +#define SDR0_EMACxRXST_BFCS 0x00000002 /* bad FCS in the recieved frame */ #define SDR0_EMACxRXST_RXOK 0x00000001 /* Recieve OK */
/* EMACx TX Status Register (SDR0_EMACxREJCNT)*/ @@ -1300,23 +1398,24 @@ #define SDR0_MFR_ECS_MASK 0x10000000 #define SDR0_MFR_ECS_INTERNAL 0x10000000
-#define SDR0_MFR_ETH0_CLK_SEL 0x08000000 /* Ethernet0 Clock Select */ -#define SDR0_MFR_ETH1_CLK_SEL 0x04000000 /* Ethernet1 Clock Select */ -#define SDR0_MFR_ZMII_MODE_MASK 0x03000000 /* ZMII Mode Mask */ -#define SDR0_MFR_ZMII_MODE_MII 0x00000000 /* ZMII Mode MII */ -#define SDR0_MFR_ZMII_MODE_SMII 0x01000000 /* ZMII Mode SMII */ -#define SDR0_MFR_ZMII_MODE_RMII_10M 0x02000000 /* ZMII Mode RMII - 10 Mbs */ -#define SDR0_MFR_ZMII_MODE_RMII_100M 0x03000000 /* ZMII Mode RMII - 100 Mbs */ -#define SDR0_MFR_ZMII_MODE_BIT0 0x02000000 /* ZMII Mode Bit0 */ -#define SDR0_MFR_ZMII_MODE_BIT1 0x01000000 /* ZMII Mode Bit1 */ -#define SDR0_MFR_ERRATA3_EN0 0x00800000 -#define SDR0_MFR_ERRATA3_EN1 0x00400000 +#define SDR0_MFR_ETH0_CLK_SEL 0x08000000 /* Ethernet0 Clock Select */ +#define SDR0_MFR_ETH1_CLK_SEL 0x04000000 /* Ethernet1 Clock Select */ +#define SDR0_MFR_ZMII_MODE_MASK 0x03000000 /* ZMII Mode Mask */ +#define SDR0_MFR_ZMII_MODE_MII 0x00000000 /* ZMII Mode MII */ +#define SDR0_MFR_ZMII_MODE_SMII 0x01000000 /* ZMII Mode SMII */ +#define SDR0_MFR_ZMII_MODE_RMII_10M 0x02000000 /* ZMII Mode RMII - 10 Mbs */ +#define SDR0_MFR_ZMII_MODE_RMII_100M 0x03000000 /* ZMII Mode RMII - 100 Mbs*/ +#define SDR0_MFR_ZMII_MODE_BIT0 0x02000000 /* ZMII Mode Bit0 */ +#define SDR0_MFR_ZMII_MODE_BIT1 0x01000000 /* ZMII Mode Bit1 */ +#define SDR0_MFR_ERRATA3_EN0 0x00800000 +#define SDR0_MFR_ERRATA3_EN1 0x00400000 #if defined(CONFIG_440GX) /* test-only: only 440GX or 440SPE??? */ -#define SDR0_MFR_PKT_REJ_MASK 0x00300000 /* Pkt Rej. Enable Mask */ -#define SDR0_MFR_PKT_REJ_EN 0x00300000 /* Pkt Rej. Enable on both EMAC3 0-1 */ -#define SDR0_MFR_PKT_REJ_EN0 0x00200000 /* Pkt Rej. Enable on EMAC3(0) */ -#define SDR0_MFR_PKT_REJ_EN1 0x00100000 /* Pkt Rej. Enable on EMAC3(1) */ -#define SDR0_MFR_PKT_REJ_POL 0x00080000 /* Packet Reject Polarity */ +#define SDR0_MFR_PKT_REJ_MASK 0x00300000 /* Pkt Rej. Enable Mask */ +#define SDR0_MFR_PKT_REJ_EN 0x00300000 /* Pkt Rej. Enable on both EMAC3 + 0-1 */ +#define SDR0_MFR_PKT_REJ_EN0 0x00200000 /* Pkt Rej. Enable on EMAC3(0) */ +#define SDR0_MFR_PKT_REJ_EN1 0x00100000 /* Pkt Rej. Enable on EMAC3(1) */ +#define SDR0_MFR_PKT_REJ_POL 0x00080000 /* Packet Reject Polarity */ #endif
@@ -1343,60 +1442,67 @@ #define SDR0_MFR_ECS_INTERNAL 0x10000000
#if defined(CONFIG_440EPX) || defined(CONFIG_440GRX) -#define SDR0_SRST0 0x200 -#define SDR0_SRST0_BGO 0x80000000 /* PLB to OPB bridge */ -#define SDR0_SRST0_PLB4 0x40000000 /* PLB4 arbiter */ -#define SDR0_SRST0_EBC 0x20000000 /* External bus controller */ -#define SDR0_SRST0_OPB 0x10000000 /* OPB arbiter */ -#define SDR0_SRST0_UART0 0x08000000 /* Universal asynchronous receiver/transmitter 0 */ -#define SDR0_SRST0_UART1 0x04000000 /* Universal asynchronous receiver/transmitter 1 */ -#define SDR0_SRST0_IIC0 0x02000000 /* Inter integrated circuit 0 */ -#define SDR0_SRST0_USB2H 0x01000000 /* USB2.0 Host */ -#define SDR0_SRST0_GPIO 0x00800000 /* General purpose I/O */ -#define SDR0_SRST0_GPT 0x00400000 /* General purpose timer */ -#define SDR0_SRST0_DMC 0x00200000 /* DDR SDRAM memory controller */ -#define SDR0_SRST0_PCI 0x00100000 /* PCI */ -#define SDR0_SRST0_EMAC0 0x00080000 /* Ethernet media access controller 0 */ -#define SDR0_SRST0_EMAC1 0x00040000 /* Ethernet media access controller 1 */ -#define SDR0_SRST0_CPM0 0x00020000 /* Clock and power management */ -#define SDR0_SRST0_ZMII 0x00010000 /* ZMII bridge */ -#define SDR0_SRST0_UIC0 0x00008000 /* Universal interrupt controller 0 */ -#define SDR0_SRST0_UIC1 0x00004000 /* Universal interrupt controller 1 */ -#define SDR0_SRST0_IIC1 0x00002000 /* Inter integrated circuit 1 */ -#define SDR0_SRST0_SCP 0x00001000 /* Serial communications port */ -#define SDR0_SRST0_BGI 0x00000800 /* OPB to PLB bridge */ -#define SDR0_SRST0_DMA 0x00000400 /* Direct memory access controller */ -#define SDR0_SRST0_DMAC 0x00000200 /* DMA channel */ -#define SDR0_SRST0_MAL 0x00000100 /* Media access layer */ -#define SDR0_SRST0_USB2D 0x00000080 /* USB2.0 device */ -#define SDR0_SRST0_GPTR 0x00000040 /* General purpose timer */ -#define SDR0_SRST0_P4P3 0x00000010 /* PLB4 to PLB3 bridge */ -#define SDR0_SRST0_P3P4 0x00000008 /* PLB3 to PLB4 bridge */ -#define SDR0_SRST0_PLB3 0x00000004 /* PLB3 arbiter */ -#define SDR0_SRST0_UART2 0x00000002 /* Universal asynchronous receiver/transmitter 2 */ -#define SDR0_SRST0_UART3 0x00000001 /* Universal asynchronous receiver/transmitter 3 */ - -#define SDR0_SRST1 0x201 -#define SDR0_SRST1_NDFC 0x80000000 /* Nand flash controller */ -#define SDR0_SRST1_OPBA1 0x40000000 /* OPB Arbiter attached to PLB4 */ -#define SDR0_SRST1_P4OPB0 0x20000000 /* PLB4 to OPB Bridge0 */ +#define SDR0_SRST0 0x200 +#define SDR0_SRST0_BGO 0x80000000 /* PLB to OPB bridge */ +#define SDR0_SRST0_PLB4 0x40000000 /* PLB4 arbiter */ +#define SDR0_SRST0_EBC 0x20000000 /* External bus controller */ +#define SDR0_SRST0_OPB 0x10000000 /* OPB arbiter */ +#define SDR0_SRST0_UART0 0x08000000 /* Universal asynchronous receiver/ + transmitter 0 */ +#define SDR0_SRST0_UART1 0x04000000 /* Universal asynchronous receiver/ + transmitter 1 */ +#define SDR0_SRST0_IIC0 0x02000000 /* Inter integrated circuit 0 */ +#define SDR0_SRST0_USB2H 0x01000000 /* USB2.0 Host */ +#define SDR0_SRST0_GPIO 0x00800000 /* General purpose I/O */ +#define SDR0_SRST0_GPT 0x00400000 /* General purpose timer */ +#define SDR0_SRST0_DMC 0x00200000 /* DDR SDRAM memory controller */ +#define SDR0_SRST0_PCI 0x00100000 /* PCI */ +#define SDR0_SRST0_EMAC0 0x00080000 /* Ethernet media access controller 0 */ +#define SDR0_SRST0_EMAC1 0x00040000 /* Ethernet media access controller 1 */ +#define SDR0_SRST0_CPM0 0x00020000 /* Clock and power management */ +#define SDR0_SRST0_ZMII 0x00010000 /* ZMII bridge */ +#define SDR0_SRST0_UIC0 0x00008000 /* Universal interrupt controller 0 */ +#define SDR0_SRST0_UIC1 0x00004000 /* Universal interrupt controller 1 */ +#define SDR0_SRST0_IIC1 0x00002000 /* Inter integrated circuit 1 */ +#define SDR0_SRST0_SCP 0x00001000 /* Serial communications port */ +#define SDR0_SRST0_BGI 0x00000800 /* OPB to PLB bridge */ +#define SDR0_SRST0_DMA 0x00000400 /* Direct memory access controller */ +#define SDR0_SRST0_DMAC 0x00000200 /* DMA channel */ +#define SDR0_SRST0_MAL 0x00000100 /* Media access layer */ +#define SDR0_SRST0_USB2D 0x00000080 /* USB2.0 device */ +#define SDR0_SRST0_GPTR 0x00000040 /* General purpose timer */ +#define SDR0_SRST0_P4P3 0x00000010 /* PLB4 to PLB3 bridge */ +#define SDR0_SRST0_P3P4 0x00000008 /* PLB3 to PLB4 bridge */ +#define SDR0_SRST0_PLB3 0x00000004 /* PLB3 arbiter */ +#define SDR0_SRST0_UART2 0x00000002 /* Universal asynchronous receiver/ + transmitter 2 */ +#define SDR0_SRST0_UART3 0x00000001 /* Universal asynchronous receiver/ + transmitter 3 */ + +#define SDR0_SRST1 0x201 +#define SDR0_SRST1_NDFC 0x80000000 /* Nand flash controller */ +#define SDR0_SRST1_OPBA1 0x40000000 /* OPB Arbiter attached to PLB4 */ +#define SDR0_SRST1_P4OPB0 0x20000000 /* PLB4 to OPB Bridge0 */ #define SDR0_SRST1_PLB42OPB0 SDR0_SRST1_P4OPB0 -#define SDR0_SRST1_DMA4 0x10000000 /* DMA to PLB4 */ -#define SDR0_SRST1_DMA4CH 0x08000000 /* DMA Channel to PLB4 */ -#define SDR0_SRST1_OPBA2 0x04000000 /* OPB Arbiter attached to PLB4 USB 2.0 Host */ -#define SDR0_SRST1_OPB2PLB40 0x02000000 /* OPB to PLB4 Bridge attached to USB 2.0 Host */ -#define SDR0_SRST1_PLB42OPB1 0x01000000 /* PLB4 to OPB Bridge attached to USB 2.0 Host */ -#define SDR0_SRST1_CPM1 0x00800000 /* Clock and Power management 1 */ -#define SDR0_SRST1_UIC2 0x00400000 /* Universal Interrupt Controller 2 */ -#define SDR0_SRST1_CRYP0 0x00200000 /* Security Engine */ -#define SDR0_SRST1_USB20PHY 0x00100000 /* USB 2.0 Phy */ -#define SDR0_SRST1_USB2HUTMI 0x00080000 /* USB 2.0 Host UTMI Interface */ -#define SDR0_SRST1_USB2HPHY 0x00040000 /* USB 2.0 Host Phy Interface */ -#define SDR0_SRST1_SRAM0 0x00020000 /* Internal SRAM Controller */ -#define SDR0_SRST1_RGMII0 0x00010000 /* RGMII Bridge */ -#define SDR0_SRST1_ETHPLL 0x00008000 /* Ethernet PLL */ -#define SDR0_SRST1_FPU 0x00004000 /* Floating Point Unit */ -#define SDR0_SRST1_KASU0 0x00002000 /* Kasumi Engine */ +#define SDR0_SRST1_DMA4 0x10000000 /* DMA to PLB4 */ +#define SDR0_SRST1_DMA4CH 0x08000000 /* DMA Channel to PLB4 */ +#define SDR0_SRST1_OPBA2 0x04000000 /* OPB Arbiter attached to PLB4 + USB 2.0 Host */ +#define SDR0_SRST1_OPB2PLB40 0x02000000 /* OPB to PLB4 Bridge attached to + USB 2.0 Host */ +#define SDR0_SRST1_PLB42OPB1 0x01000000 /* PLB4 to OPB Bridge attached to + USB 2.0 Host */ +#define SDR0_SRST1_CPM1 0x00800000 /* Clock and Power management 1 */ +#define SDR0_SRST1_UIC2 0x00400000 /* Universal Interrupt Controller 2*/ +#define SDR0_SRST1_CRYP0 0x00200000 /* Security Engine */ +#define SDR0_SRST1_USB20PHY 0x00100000 /* USB 2.0 Phy */ +#define SDR0_SRST1_USB2HUTMI 0x00080000 /* USB 2.0 Host UTMI Interface */ +#define SDR0_SRST1_USB2HPHY 0x00040000 /* USB 2.0 Host Phy Interface */ +#define SDR0_SRST1_SRAM0 0x00020000 /* Internal SRAM Controller */ +#define SDR0_SRST1_RGMII0 0x00010000 /* RGMII Bridge */ +#define SDR0_SRST1_ETHPLL 0x00008000 /* Ethernet PLL */ +#define SDR0_SRST1_FPU 0x00004000 /* Floating Point Unit */ +#define SDR0_SRST1_KASU0 0x00002000 /* Kasumi Engine */
#define SDR0_EMAC0RXST 0x00004301 /* */ #define SDR0_EMAC0TXST 0x00004302 /* */ @@ -1411,8 +1517,10 @@ #define SDR0_SRST0_PLB4 0x40000000 /* PLB4 arbiter */ #define SDR0_SRST0_EBC 0x20000000 /* External bus controller */ #define SDR0_SRST0_OPB 0x10000000 /* OPB arbiter */ -#define SDR0_SRST0_UART0 0x08000000 /* Universal asynchronous receiver/transmitter 0 */ -#define SDR0_SRST0_UART1 0x04000000 /* Universal asynchronous receiver/transmitter 1 */ +#define SDR0_SRST0_UART0 0x08000000 /* Universal asynchronous receiver/ + transmitter 0 */ +#define SDR0_SRST0_UART1 0x04000000 /* Universal asynchronous receiver/ + transmitter 1 */ #define SDR0_SRST0_IIC0 0x02000000 /* Inter integrated circuit 0 */ #define SDR0_SRST0_IIC1 0x01000000 /* Inter integrated circuit 1 */ #define SDR0_SRST0_GPIO0 0x00800000 /* General purpose I/O 0 */ @@ -1427,11 +1535,13 @@ #define SDR0_SRST0_UIC2 0x00001000 /* Universal interrupt controller 2*/ #define SDR0_SRST0_UIC3 0x00000800 /* Universal interrupt controller 3*/ #define SDR0_SRST0_OCM 0x00000400 /* Universal interrupt controller 0*/ -#define SDR0_SRST0_UART2 0x00000200 /* Universal asynchronous receiver/transmitter 2 */ +#define SDR0_SRST0_UART2 0x00000200 /* Universal asynchronous receiver/ + transmitter 2 */ #define SDR0_SRST0_MAL 0x00000100 /* Media access layer */ #define SDR0_SRST0_GPTR 0x00000040 /* General purpose timer */ #define SDR0_SRST0_L2CACHE 0x00000004 /* L2 Cache */ -#define SDR0_SRST0_UART3 0x00000002 /* Universal asynchronous receiver/transmitter 3 */ +#define SDR0_SRST0_UART3 0x00000002 /* Universal asynchronous receiver/ + transmitter 3 */ #define SDR0_SRST0_GPIO1 0x00000001 /* General purpose I/O 1 */
#define SDR0_SRST1 0x201 @@ -1440,17 +1550,22 @@ #define SDR0_SRST1_PLBARB 0x20000000 /* PLB Arbiter */ #define SDR0_SRST1_EIPPKP 0x10000000 /* EIPPPKP */ #define SDR0_SRST1_EIP94 0x08000000 /* EIP 94 */ -#define SDR0_SRST1_EMAC0 0x04000000 /* Ethernet media access controller 0 */ -#define SDR0_SRST1_EMAC1 0x02000000 /* Ethernet media access controller 1 */ -#define SDR0_SRST1_EMAC2 0x01000000 /* Ethernet media access controller 2 */ -#define SDR0_SRST1_EMAC3 0x00800000 /* Ethernet media access controller 3 */ +#define SDR0_SRST1_EMAC0 0x04000000 /* Ethernet media access + controller 0 */ +#define SDR0_SRST1_EMAC1 0x02000000 /* Ethernet media access + controller 1 */ +#define SDR0_SRST1_EMAC2 0x01000000 /* Ethernet media access + controller 2 */ +#define SDR0_SRST1_EMAC3 0x00800000 /* Ethernet media access + controller 3 */ #define SDR0_SRST1_ZMII 0x00400000 /* Ethernet ZMII/RMII/SMII */ #define SDR0_SRST1_RGMII0 0x00200000 /* Ethernet RGMII/RTBI 0 */ #define SDR0_SRST1_RGMII1 0x00100000 /* Ethernet RGMII/RTBI 1 */ #define SDR0_SRST1_DMA4 0x00080000 /* DMA to PLB4 */ #define SDR0_SRST1_DMA4CH 0x00040000 /* DMA Channel to PLB4 */ #define SDR0_SRST1_SATAPHY 0x00020000 /* Serial ATA PHY */ -#define SDR0_SRST1_SRIODEV 0x00010000 /* Serial Rapid IO core, PCS, and serdes */ +#define SDR0_SRST1_SRIODEV 0x00010000 /* Serial Rapid IO core, PCS, and + serdes */ #define SDR0_SRST1_SRIOPCS 0x00008000 /* Serial Rapid IO core and PCS */ #define SDR0_SRST1_NDFC 0x00004000 /* Nand flash controller */ #define SDR0_SRST1_SRIOPLB 0x00002000 /* Serial Rapid IO PLB */ @@ -1539,7 +1654,7 @@ #else /* !CONFIG_440GX or CONFIG_440EP or CONFIG_440GR */ #define PLLSYS0_ENG_MASK 0x80000000 /* 0 = SysClk, 1 = PLL VCO */ #define PLLSYS0_SRC_MASK 0x40000000 /* 0 = PLL A, 1 = PLL B */ -#define PLLSYS0_SEL_MASK 0x38000000 /* 0 = PLL, 1 = CPU, 5 = PerClk */ +#define PLLSYS0_SEL_MASK 0x38000000 /* 0 = PLL, 1 = CPU, 5 = PerClk */ #define PLLSYS0_TUNE_MASK 0x07fe0000 /* PLL Tune bits */ #define PLLSYS0_FB_DIV_MASK 0x0001f000 /* Feedback divisor */ #define PLLSYS0_FWD_DIV_A_MASK 0x00000f00 /* Fwd Div A */ @@ -1547,7 +1662,7 @@ #define PLLSYS0_PRI_DIV_B_MASK 0x0000001c /* PLL Primary Divisor B */ #define PLLSYS0_OPB_DIV_MASK 0x00000003 /* OPB Divisor */
-#define PLLC_ENG_MASK 0x20000000 /* PLL primary forward divisor source */ +#define PLLC_ENG_MASK 0x20000000 /* PLL primary forward divisor source */ #define PLLC_SRC_MASK 0x20000000 /* PLL feedback source */ #define PLLD_FBDV_MASK 0x1f000000 /* PLL Feedback Divisor */ #define PLLD_FWDVA_MASK 0x000f0000 /* PLL Forward Divisor A */ @@ -1624,27 +1739,30 @@
/* PCI Local Configuration Registers --------------------------------- */ -#define PCI_MMIO_LCR_BASE (CONFIG_SYS_PCI_BASE + 0x0f400000) /* Real => 0x0EF400000 */ +#define PCI_MMIO_LCR_BASE (CONFIG_SYS_PCI_BASE + 0x0f400000) /* Real => + 0x0EF400000 */
/* PCI Master Local Configuration Registers */ -#define PCIL0_PMM0LA (PCI_MMIO_LCR_BASE + 0x00) /* PMM0 Local Address */ -#define PCIL0_PMM0MA (PCI_MMIO_LCR_BASE + 0x04) /* PMM0 Mask/Attribute */ -#define PCIL0_PMM0PCILA (PCI_MMIO_LCR_BASE + 0x08) /* PMM0 PCI Low Address */ -#define PCIL0_PMM0PCIHA (PCI_MMIO_LCR_BASE + 0x0C) /* PMM0 PCI High Address */ -#define PCIL0_PMM1LA (PCI_MMIO_LCR_BASE + 0x10) /* PMM1 Local Address */ -#define PCIL0_PMM1MA (PCI_MMIO_LCR_BASE + 0x14) /* PMM1 Mask/Attribute */ -#define PCIL0_PMM1PCILA (PCI_MMIO_LCR_BASE + 0x18) /* PMM1 PCI Low Address */ -#define PCIL0_PMM1PCIHA (PCI_MMIO_LCR_BASE + 0x1C) /* PMM1 PCI High Address */ -#define PCIL0_PMM2LA (PCI_MMIO_LCR_BASE + 0x20) /* PMM2 Local Address */ -#define PCIL0_PMM2MA (PCI_MMIO_LCR_BASE + 0x24) /* PMM2 Mask/Attribute */ -#define PCIL0_PMM2PCILA (PCI_MMIO_LCR_BASE + 0x28) /* PMM2 PCI Low Address */ -#define PCIL0_PMM2PCIHA (PCI_MMIO_LCR_BASE + 0x2C) /* PMM2 PCI High Address */ +#define PCIL0_PMM0LA (PCI_MMIO_LCR_BASE + 0x00) /* PMM0 Local Address */ +#define PCIL0_PMM0MA (PCI_MMIO_LCR_BASE + 0x04) /* PMM0 Mask/Attribute */ +#define PCIL0_PMM0PCILA (PCI_MMIO_LCR_BASE + 0x08) /* PMM0 PCI Low Address */ +#define PCIL0_PMM0PCIHA (PCI_MMIO_LCR_BASE + 0x0C) /* PMM0 PCI High Address */ +#define PCIL0_PMM1LA (PCI_MMIO_LCR_BASE + 0x10) /* PMM1 Local Address */ +#define PCIL0_PMM1MA (PCI_MMIO_LCR_BASE + 0x14) /* PMM1 Mask/Attribute */ +#define PCIL0_PMM1PCILA (PCI_MMIO_LCR_BASE + 0x18) /* PMM1 PCI Low Address */ +#define PCIL0_PMM1PCIHA (PCI_MMIO_LCR_BASE + 0x1C) /* PMM1 PCI High Address */ +#define PCIL0_PMM2LA (PCI_MMIO_LCR_BASE + 0x20) /* PMM2 Local Address */ +#define PCIL0_PMM2MA (PCI_MMIO_LCR_BASE + 0x24) /* PMM2 Mask/Attribute */ +#define PCIL0_PMM2PCILA (PCI_MMIO_LCR_BASE + 0x28) /* PMM2 PCI Low Address */ +#define PCIL0_PMM2PCIHA (PCI_MMIO_LCR_BASE + 0x2C) /* PMM2 PCI High Address */
/* PCI Target Local Configuration Registers */ -#define PCIL0_PTM1MS (PCI_MMIO_LCR_BASE + 0x30) /* PTM1 Memory Size/Attribute */ -#define PCIL0_PTM1LA (PCI_MMIO_LCR_BASE + 0x34) /* PTM1 Local Addr. Reg */ -#define PCIL0_PTM2MS (PCI_MMIO_LCR_BASE + 0x38) /* PTM2 Memory Size/Attribute */ -#define PCIL0_PTM2LA (PCI_MMIO_LCR_BASE + 0x3C) /* PTM2 Local Addr. Reg */ +#define PCIL0_PTM1MS (PCI_MMIO_LCR_BASE + 0x30) /* PTM1 Memory Size/ + Attribute */ +#define PCIL0_PTM1LA (PCI_MMIO_LCR_BASE + 0x34) /* PTM1 Local Addr. Reg */ +#define PCIL0_PTM2MS (PCI_MMIO_LCR_BASE + 0x38) /* PTM2 Memory Size/ + Attribute */ +#define PCIL0_PTM2LA (PCI_MMIO_LCR_BASE + 0x3C) /* PTM2 Local Addr. Reg */
#else
@@ -1674,6 +1792,31 @@ #define PCIL0_RES2 (PCIL0_CFGBASE + 0x0038 ) #define PCIL0_INTLN (PCIL0_CFGBASE + PCI_INTERRUPT_LINE ) #define PCIL0_INTPN (PCIL0_CFGBASE + PCI_INTERRUPT_PIN ) +#define SDR0_EMACxTXST_FUR 0x02000000 /* TX FIFO underrun */ +#define SDR0_EMACxTXST_BC 0x01000000 /* broadcase address */ +#define SDR0_EMACxTXST_MC 0x00800000 /* multicast address */ +#define SDR0_EMACxTXST_UC 0x00400000 /* unicast address */ +#define SDR0_EMACxTXST_FP 0x00200000 /* frame paused by control packet */ +#define SDR0_EMACxTXST_BFCS 0x00100000 /* bad FCS in the transmitted frame*/ +#define SDR0_EMACxTXST_CPF 0x00080000 /* TX control pause frame */ +#define SDR0_EMACxTXST_CF 0x00040000 /* TX control frame */ +#define SDR0_EMACxTXST_MSIZ 0x00020000 /* 1024-maxsize bytes transmitted */ +#define SDR0_EMACxTXST_1023 0x00010000 /* 512-1023 bytes transmitted */ +#define SDR0_EMACxTXST_511 0x00008000 /* 256-511 bytes transmitted */ +#define SDR0_EMACxTXST_255 0x00004000 /* 128-255 bytes transmitted */ +#define SDR0_EMACxTXST_127 0x00002000 /* 65-127 bytes transmitted */ +#define SDR0_EMACxTXST_64 0x00001000 /* 64 bytes transmitted */ +#define SDR0_EMACxTXST_SQE 0x00000800 /* SQE indication */ +#define SDR0_EMACxTXST_LOC 0x00000400 /* loss of carrier sense */ +#define SDR0_EMACxTXST_IERR 0x00000080 /* EMAC internal error */ +#define SDR0_EMACxTXST_EDF 0x00000040 /* excessive deferral */ +#define SDR0_EMACxTXST_ECOL 0x00000020 /* excessive collisions */ +#define SDR0_EMACxTXST_LCOL 0x00000010 /* late collision */ +#define SDR0_EMACxTXST_DFFR 0x00000008 /* deferred frame */ +#define SDR0_EMACxTXST_MCOL 0x00000004 /* multiple collision frame */ +#define SDR0_EMACxTXST_SCOL 0x00000002 /* single collision frame */ +#define SDR0_EMACxTXST_TXOK 0x00000001 /* transmit OK */ + #define PCIL0_MINGNT (PCIL0_CFGBASE + PCI_MIN_GNT ) #define PCIL0_MAXLTNCY (PCIL0_CFGBASE + PCI_MAX_LAT )
@@ -1713,24 +1856,41 @@
#define USB2D0_INTRIN (USB2D0_BASE + 0x00000000)
-#define USB2D0_INTRIN (USB2D0_BASE + 0x00000000) /* Interrupt register for Endpoint 0 plus IN Endpoints 1 to 3 */ -#define USB2D0_POWER (USB2D0_BASE + 0x00000000) /* Power management register */ -#define USB2D0_FADDR (USB2D0_BASE + 0x00000000) /* Function address register */ -#define USB2D0_INTRINE (USB2D0_BASE + 0x00000000) /* Interrupt enable register for USB2D0_INTRIN */ -#define USB2D0_INTROUT (USB2D0_BASE + 0x00000000) /* Interrupt register for OUT Endpoints 1 to 3 */ -#define USB2D0_INTRUSBE (USB2D0_BASE + 0x00000000) /* Interrupt enable register for USB2D0_INTRUSB */ -#define USB2D0_INTRUSB (USB2D0_BASE + 0x00000000) /* Interrupt register for common USB interrupts */ -#define USB2D0_INTROUTE (USB2D0_BASE + 0x00000000) /* Interrupt enable register for IntrOut */ -#define USB2D0_TSTMODE (USB2D0_BASE + 0x00000000) /* Enables the USB 2.0 test modes */ -#define USB2D0_INDEX (USB2D0_BASE + 0x00000000) /* Index register for selecting the Endpoint status/control registers */ +#define USB2D0_INTRIN (USB2D0_BASE + 0x00000000) /* Interrupt register for + Endpoint 0 plus IN Endpoints 1 to 3 */ +#define USB2D0_POWER (USB2D0_BASE + 0x00000000) /* Power management + register */ +#define USB2D0_FADDR (USB2D0_BASE + 0x00000000) /* Function address + register */ +#define USB2D0_INTRINE (USB2D0_BASE + 0x00000000) /* Interrupt enable + register for USB2D0_INTRIN */ +#define USB2D0_INTROUT (USB2D0_BASE + 0x00000000) /* Interrupt register for + OUT Endpoints 1 to 3 */ +#define USB2D0_INTRUSBE (USB2D0_BASE + 0x00000000) /* Interrupt enable + register for USB2D0_INTRUSB */ +#define USB2D0_INTRUSB (USB2D0_BASE + 0x00000000) /* Interrupt register for + common USB interrupts */ +#define USB2D0_INTROUTE (USB2D0_BASE + 0x00000000) /* Interrupt enable + register for IntrOut */ +#define USB2D0_TSTMODE (USB2D0_BASE + 0x00000000) /* Enables the USB 2.0 + test modes */ +#define USB2D0_INDEX (USB2D0_BASE + 0x00000000) /* Index register for + selecting the Endpoint status/control registers */ #define USB2D0_FRAME (USB2D0_BASE + 0x00000000) /* Frame number */ -#define USB2D0_INCSR0 (USB2D0_BASE + 0x00000000) /* Control Status register for Endpoint 0. (Index register set to select Endpoint 0) */ -#define USB2D0_INCSR (USB2D0_BASE + 0x00000000) /* Control Status register for IN Endpoint. (Index register set to select Endpoints 13) */ -#define USB2D0_INMAXP (USB2D0_BASE + 0x00000000) /* Maximum packet size for IN Endpoint. (Index register set to select Endpoints 13) */ -#define USB2D0_OUTCSR (USB2D0_BASE + 0x00000000) /* Control Status register for OUT Endpoint. (Index register set to select Endpoints 13) */ -#define USB2D0_OUTMAXP (USB2D0_BASE + 0x00000000) /* Maximum packet size for OUT Endpoint. (Index register set to select Endpoints 13) */ -#define USB2D0_OUTCOUNT0 (USB2D0_BASE + 0x00000000) /* Number of received bytes in Endpoint 0 FIFO. (Index register set to select Endpoint 0) */ -#define USB2D0_OUTCOUNT (USB2D0_BASE + 0x00000000) /* Number of bytes in OUT Endpoint FIFO. (Index register set to select Endpoints 13) */ +#define USB2D0_INCSR0 (USB2D0_BASE + 0x00000000) /* Control Status + register for Endpoint 0. (Index register set to select Endpoint 0) */ +#define USB2D0_INCSR (USB2D0_BASE + 0x00000000) /* Control Status + register for IN Endpoint. (Index register set to select Endpoints 13) */ +#define USB2D0_INMAXP (USB2D0_BASE + 0x00000000) /* Maximum packet + size for IN Endpoint. (Index register set to select Endpoints 13) */ +#define USB2D0_OUTCSR (USB2D0_BASE + 0x00000000) /* Control Status + register for OUT Endpoint. (Index register set to select Endpoints 13) */ +#define USB2D0_OUTMAXP (USB2D0_BASE + 0x00000000) /* Maximum packet + size for OUT Endpoint. (Index register set to select Endpoints 13) */ +#define USB2D0_OUTCOUNT0 (USB2D0_BASE + 0x00000000) /* Number of received + bytes in Endpoint 0 FIFO. (Index register set to select Endpoint 0) */ +#define USB2D0_OUTCOUNT (USB2D0_BASE + 0x00000000) /* Number of bytes in + OUT Endpoint FIFO. (Index register set to select Endpoints 13) */ #endif
/****************************************************************************** @@ -1739,55 +1899,55 @@ #if defined(CONFIG_440GP) || defined(CONFIG_440GX) || \ defined(CONFIG_440SP) || defined(CONFIG_440SPE) || \ defined(CONFIG_460SX) -#define GPIO0_BASE (CONFIG_SYS_PERIPHERAL_BASE+0x00000700) +#define GPIO0_BASE (CONFIG_SYS_PERIPHERAL_BASE+0x00000700)
-#define GPIO0_OR (GPIO0_BASE+0x0) -#define GPIO0_TCR (GPIO0_BASE+0x4) -#define GPIO0_ODR (GPIO0_BASE+0x18) -#define GPIO0_IR (GPIO0_BASE+0x1C) +#define GPIO0_OR (GPIO0_BASE+0x0) +#define GPIO0_TCR (GPIO0_BASE+0x4) +#define GPIO0_ODR (GPIO0_BASE+0x18) +#define GPIO0_IR (GPIO0_BASE+0x1C) #endif /* CONFIG_440GP */
#if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ defined(CONFIG_460EX) || defined(CONFIG_460GT) -#define GPIO0_BASE (CONFIG_SYS_PERIPHERAL_BASE+0x00000B00) -#define GPIO1_BASE (CONFIG_SYS_PERIPHERAL_BASE+0x00000C00) - -#define GPIO0_OR (GPIO0_BASE+0x0) -#define GPIO0_TCR (GPIO0_BASE+0x4) -#define GPIO0_OSRL (GPIO0_BASE+0x8) -#define GPIO0_OSRH (GPIO0_BASE+0xC) -#define GPIO0_TSRL (GPIO0_BASE+0x10) -#define GPIO0_TSRH (GPIO0_BASE+0x14) -#define GPIO0_ODR (GPIO0_BASE+0x18) -#define GPIO0_IR (GPIO0_BASE+0x1C) -#define GPIO0_RR1 (GPIO0_BASE+0x20) -#define GPIO0_RR2 (GPIO0_BASE+0x24) -#define GPIO0_RR3 (GPIO0_BASE+0x28) -#define GPIO0_ISR1L (GPIO0_BASE+0x30) -#define GPIO0_ISR1H (GPIO0_BASE+0x34) -#define GPIO0_ISR2L (GPIO0_BASE+0x38) -#define GPIO0_ISR2H (GPIO0_BASE+0x3C) -#define GPIO0_ISR3L (GPIO0_BASE+0x40) -#define GPIO0_ISR3H (GPIO0_BASE+0x44) - -#define GPIO1_OR (GPIO1_BASE+0x0) -#define GPIO1_TCR (GPIO1_BASE+0x4) -#define GPIO1_OSRL (GPIO1_BASE+0x8) -#define GPIO1_OSRH (GPIO1_BASE+0xC) -#define GPIO1_TSRL (GPIO1_BASE+0x10) -#define GPIO1_TSRH (GPIO1_BASE+0x14) -#define GPIO1_ODR (GPIO1_BASE+0x18) -#define GPIO1_IR (GPIO1_BASE+0x1C) -#define GPIO1_RR1 (GPIO1_BASE+0x20) -#define GPIO1_RR2 (GPIO1_BASE+0x24) -#define GPIO1_RR3 (GPIO1_BASE+0x28) -#define GPIO1_ISR1L (GPIO1_BASE+0x30) -#define GPIO1_ISR1H (GPIO1_BASE+0x34) -#define GPIO1_ISR2L (GPIO1_BASE+0x38) -#define GPIO1_ISR2H (GPIO1_BASE+0x3C) -#define GPIO1_ISR3L (GPIO1_BASE+0x40) -#define GPIO1_ISR3H (GPIO1_BASE+0x44) +#define GPIO0_BASE (CONFIG_SYS_PERIPHERAL_BASE+0x00000B00) +#define GPIO1_BASE (CONFIG_SYS_PERIPHERAL_BASE+0x00000C00) + +#define GPIO0_OR (GPIO0_BASE+0x0) +#define GPIO0_TCR (GPIO0_BASE+0x4) +#define GPIO0_OSRL (GPIO0_BASE+0x8) +#define GPIO0_OSRH (GPIO0_BASE+0xC) +#define GPIO0_TSRL (GPIO0_BASE+0x10) +#define GPIO0_TSRH (GPIO0_BASE+0x14) +#define GPIO0_ODR (GPIO0_BASE+0x18) +#define GPIO0_IR (GPIO0_BASE+0x1C) +#define GPIO0_RR1 (GPIO0_BASE+0x20) +#define GPIO0_RR2 (GPIO0_BASE+0x24) +#define GPIO0_RR3 (GPIO0_BASE+0x28) +#define GPIO0_ISR1L (GPIO0_BASE+0x30) +#define GPIO0_ISR1H (GPIO0_BASE+0x34) +#define GPIO0_ISR2L (GPIO0_BASE+0x38) +#define GPIO0_ISR2H (GPIO0_BASE+0x3C) +#define GPIO0_ISR3L (GPIO0_BASE+0x40) +#define GPIO0_ISR3H (GPIO0_BASE+0x44) + +#define GPIO1_OR (GPIO1_BASE+0x0) +#define GPIO1_TCR (GPIO1_BASE+0x4) +#define GPIO1_OSRL (GPIO1_BASE+0x8) +#define GPIO1_OSRH (GPIO1_BASE+0xC) +#define GPIO1_TSRL (GPIO1_BASE+0x10) +#define GPIO1_TSRH (GPIO1_BASE+0x14) +#define GPIO1_ODR (GPIO1_BASE+0x18) +#define GPIO1_IR (GPIO1_BASE+0x1C) +#define GPIO1_RR1 (GPIO1_BASE+0x20) +#define GPIO1_RR2 (GPIO1_BASE+0x24) +#define GPIO1_RR3 (GPIO1_BASE+0x28) +#define GPIO1_ISR1L (GPIO1_BASE+0x30) +#define GPIO1_ISR1H (GPIO1_BASE+0x34) +#define GPIO1_ISR2L (GPIO1_BASE+0x38) +#define GPIO1_ISR2H (GPIO1_BASE+0x3C) +#define GPIO1_ISR3L (GPIO1_BASE+0x40) +#define GPIO1_ISR3H (GPIO1_BASE+0x44) #endif
#ifndef __ASSEMBLY__ diff --git a/include/ppc4xx.h b/include/ppc4xx.h index 086f8fb..3bff00a 100644 --- a/include/ppc4xx.h +++ b/include/ppc4xx.h @@ -136,12 +136,12 @@ * Common stuff for 4xx (405 and 440) */
-#define EXC_OFF_SYS_RESET 0x0100 /* System reset */ +#define EXC_OFF_SYS_RESET 0x0100 /* System reset */ #define _START_OFFSET (EXC_OFF_SYS_RESET + 0x2000)
#define RESET_VECTOR 0xfffffffc -#define CACHELINE_MASK (CONFIG_SYS_CACHELINE_SIZE - 1) /* Address mask for cache - line aligned data. */ +#define CACHELINE_MASK (CONFIG_SYS_CACHELINE_SIZE - 1) /* Address mask for + cache line aligned data. */
#define CPR0_DCR_BASE 0x0C #define CPR0_CFGADDR (CPR0_DCR_BASE + 0x0) @@ -162,17 +162,25 @@ /* * Macros for indirect DCR access */ -#define mtcpr(reg, d) do { mtdcr(CPR0_CFGADDR,reg);mtdcr(CPR0_CFGDATA,d); } while (0) -#define mfcpr(reg, d) do { mtdcr(CPR0_CFGADDR,reg);d = mfdcr(CPR0_CFGDATA); } while (0) - -#define mtebc(reg, d) do { mtdcr(EBC0_CFGADDR,reg);mtdcr(EBC0_CFGDATA,d); } while (0) -#define mfebc(reg, d) do { mtdcr(EBC0_CFGADDR,reg);d = mfdcr(EBC0_CFGDATA); } while (0) - -#define mtsdram(reg, d) do { mtdcr(SDRAM0_CFGADDR,reg);mtdcr(SDRAM0_CFGDATA,d); } while (0) -#define mfsdram(reg, d) do { mtdcr(SDRAM0_CFGADDR,reg);d = mfdcr(SDRAM0_CFGDATA); } while (0) - -#define mtsdr(reg, d) do { mtdcr(SDR0_CFGADDR,reg);mtdcr(SDR0_CFGDATA,d); } while (0) -#define mfsdr(reg, d) do { mtdcr(SDR0_CFGADDR,reg);d = mfdcr(SDR0_CFGDATA); } while (0) +#define mtcpr(reg, d) \ + do { mtdcr(CPR0_CFGADDR, reg); mtdcr(CPR0_CFGDATA, d); } while (0) +#define mfcpr(reg, d) \ + do { mtdcr(CPR0_CFGADDR, reg); d = mfdcr(CPR0_CFGDATA); } while (0) + +#define mtebc(reg, d) \ + do { mtdcr(EBC0_CFGADDR, reg); mtdcr(EBC0_CFGDATA, d); } while (0) +#define mfebc(reg, d) \ + do { mtdcr(EBC0_CFGADDR, reg); d = mfdcr(EBC0_CFGDATA); } while (0) + +#define mtsdram(reg, d) \ + do { mtdcr(SDRAM0_CFGADDR, reg); mtdcr(SDRAM0_CFGDATA, d); } while (0) +#define mfsdram(reg, d) \ + do { mtdcr(SDRAM0_CFGADDR, reg); d = mfdcr(SDRAM0_CFGDATA); } while (0) + +#define mtsdr(reg, d) \ + do { mtdcr(SDR0_CFGADDR, reg); mtdcr(SDR0_CFGDATA, d); } while (0) +#define mfsdr(reg, d) \ + do { mtdcr(SDR0_CFGADDR, reg); d = mfdcr(SDR0_CFGDATA); } while (0)
diff --git a/include/ppc4xx_enet.h b/include/ppc4xx_enet.h index 9be22e7..3095aed 100644 --- a/include/ppc4xx_enet.h +++ b/include/ppc4xx_enet.h @@ -119,11 +119,11 @@ typedef struct emac_4xx_hw_st { int first_init; int tx_err_index; int rx_err_index; - int rx_slot; /* MAL Receive Slot */ - int rx_i_index; /* Receive Interrupt Queue Index */ - int rx_u_index; /* Receive User Queue Index */ - int tx_slot; /* MAL Transmit Slot */ - int tx_i_index; /* Transmit Interrupt Queue Index */ + int rx_slot; /* MAL Receive Slot */ + int rx_i_index; /* Receive Interrupt Queue Index */ + int rx_u_index; /* Receive User Queue Index */ + int tx_slot; /* MAL Transmit Slot */ + int tx_i_index; /* Transmit Interrupt Queue Index */ int tx_u_index; /* Transmit User Queue Index */ int rx_ready[NUM_RX_BUFF]; /* Receive Ready Queue */ int tx_run[NUM_TX_BUFF]; /* Transmit Running Queue */ @@ -262,16 +262,16 @@ typedef struct emac_4xx_hw_st { | TCP/IP Acceleration Hardware (TAH) 440GX Only +---------------------------------------------------------------------------*/ #if defined(CONFIG_440GX) -#define TAH_BASE (CONFIG_SYS_PERIPHERAL_BASE + 0x0B50) -#define TAH_REVID (TAH_BASE + 0x0) /* Revision ID (RO)*/ -#define TAH_MR (TAH_BASE + 0x10) /* Mode Register (R/W) */ -#define TAH_SSR0 (TAH_BASE + 0x14) /* Segment Size Reg 0 (R/W) */ -#define TAH_SSR1 (TAH_BASE + 0x18) /* Segment Size Reg 1 (R/W) */ -#define TAH_SSR2 (TAH_BASE + 0x1C) /* Segment Size Reg 2 (R/W) */ -#define TAH_SSR3 (TAH_BASE + 0x20) /* Segment Size Reg 3 (R/W) */ -#define TAH_SSR4 (TAH_BASE + 0x24) /* Segment Size Reg 4 (R/W) */ -#define TAH_SSR5 (TAH_BASE + 0x28) /* Segment Size Reg 5 (R/W) */ -#define TAH_TSR (TAH_BASE + 0x2C) /* Transmit Status Register (RO) */ +#define TAH_BASE (CONFIG_SYS_PERIPHERAL_BASE + 0x0B50) +#define TAH_REVID (TAH_BASE + 0x0) /* Revision ID (RO)*/ +#define TAH_MR (TAH_BASE + 0x10) /* Mode Register (R/W) */ +#define TAH_SSR0 (TAH_BASE + 0x14) /* Segment Size Reg 0 (R/W) */ +#define TAH_SSR1 (TAH_BASE + 0x18) /* Segment Size Reg 1 (R/W) */ +#define TAH_SSR2 (TAH_BASE + 0x1C) /* Segment Size Reg 2 (R/W) */ +#define TAH_SSR3 (TAH_BASE + 0x20) /* Segment Size Reg 3 (R/W) */ +#define TAH_SSR4 (TAH_BASE + 0x24) /* Segment Size Reg 4 (R/W) */ +#define TAH_SSR5 (TAH_BASE + 0x28) /* Segment Size Reg 5 (R/W) */ +#define TAH_TSR (TAH_BASE + 0x2C) /* Transmit Status Register (RO) */
/* TAH Revision */ #define TAH_REV_RN_M (0x000FFF00) /* Revision Number */ @@ -281,45 +281,45 @@ typedef struct emac_4xx_hw_st { #define TAH_REV_BN_V (0)
/* TAH Mode Register */ -#define TAH_MR_CVR (0x80000000) /* Checksum verification on RX */ -#define TAH_MR_SR (0x40000000) /* Software reset */ -#define TAH_MR_ST (0x3F000000) /* Send Threshold */ -#define TAH_MR_TFS (0x00E00000) /* Transmit FIFO size */ -#define TAH_MR_DTFP (0x00100000) /* Disable TX FIFO parity */ -#define TAH_MR_DIG (0x00080000) /* Disable interrupt generation */ -#define TAH_MR_RSVD (0x0007FFFF) /* Reserved */ +#define TAH_MR_CVR (0x80000000) /* Checksum verification on RX */ +#define TAH_MR_SR (0x40000000) /* Software reset */ +#define TAH_MR_ST (0x3F000000) /* Send Threshold */ +#define TAH_MR_TFS (0x00E00000) /* Transmit FIFO size */ +#define TAH_MR_DTFP (0x00100000) /* Disable TX FIFO parity */ +#define TAH_MR_DIG (0x00080000) /* Disable interrupt generation */ +#define TAH_MR_RSVD (0x0007FFFF) /* Reserved */
-#define TAH_MR_ST_V (20) -#define TAH_MR_TFS_V (17) +#define TAH_MR_ST_V (20) +#define TAH_MR_TFS_V (17)
-#define TAH_MR_TFS_2K (0x1) /* Transmit FIFO size 2Kbyte */ -#define TAH_MR_TFS_4K (0x2) /* Transmit FIFO size 4Kbyte */ -#define TAH_MR_TFS_6K (0x3) /* Transmit FIFO size 6Kbyte */ -#define TAH_MR_TFS_8K (0x4) /* Transmit FIFO size 8Kbyte */ -#define TAH_MR_TFS_10K (0x5) /* Transmit FIFO size 10Kbyte (max)*/ +#define TAH_MR_TFS_2K (0x1) /* Transmit FIFO size 2Kbyte */ +#define TAH_MR_TFS_4K (0x2) /* Transmit FIFO size 4Kbyte */ +#define TAH_MR_TFS_6K (0x3) /* Transmit FIFO size 6Kbyte */ +#define TAH_MR_TFS_8K (0x4) /* Transmit FIFO size 8Kbyte */ +#define TAH_MR_TFS_10K (0x5) /* Transmit FIFO size 10Kbyte (max)*/
/* TAH Segment Size Registers 0:5 */ -#define TAH_SSR_RSVD0 (0xC0000000) /* Reserved */ -#define TAH_SSR_SS (0x3FFE0000) /* Segment size in multiples of 2 */ -#define TAH_SSR_RSVD1 (0x0001FFFF) /* Reserved */ +#define TAH_SSR_RSVD0 (0xC0000000) /* Reserved */ +#define TAH_SSR_SS (0x3FFE0000) /* Segment size in multiples of 2 */ +#define TAH_SSR_RSVD1 (0x0001FFFF) /* Reserved */
/* TAH Transmit Status Register */ -#define TAH_TSR_TFTS (0x80000000) /* Transmit FIFO too small */ -#define TAH_TSR_UH (0x40000000) /* Unrecognized header */ -#define TAH_TSR_NIPF (0x20000000) /* Not IPv4 */ -#define TAH_TSR_IPOP (0x10000000) /* IP option present */ -#define TAH_TSR_NISF (0x08000000) /* No IEEE SNAP format */ -#define TAH_TSR_ILTS (0x04000000) /* IP length too short */ -#define TAH_TSR_IPFP (0x02000000) /* IP fragment present */ -#define TAH_TSR_UP (0x01000000) /* Unsupported protocol */ -#define TAH_TSR_TFP (0x00800000) /* TCP flags present */ -#define TAH_TSR_SUDP (0x00400000) /* Segmentation for UDP */ -#define TAH_TSR_DLM (0x00200000) /* Data length mismatch */ -#define TAH_TSR_SIEEE (0x00100000) /* Segmentation for IEEE */ -#define TAH_TSR_TFPE (0x00080000) /* Transmit FIFO parity error */ -#define TAH_TSR_SSTS (0x00040000) /* Segment size too small */ -#define TAH_TSR_RSVD (0x0003FFFF) /* Reserved */ +#define TAH_TSR_TFTS (0x80000000) /* Transmit FIFO too small */ +#define TAH_TSR_UH (0x40000000) /* Unrecognized header */ +#define TAH_TSR_NIPF (0x20000000) /* Not IPv4 */ +#define TAH_TSR_IPOP (0x10000000) /* IP option present */ +#define TAH_TSR_NISF (0x08000000) /* No IEEE SNAP format */ +#define TAH_TSR_ILTS (0x04000000) /* IP length too short */ +#define TAH_TSR_IPFP (0x02000000) /* IP fragment present */ +#define TAH_TSR_UP (0x01000000) /* Unsupported protocol */ +#define TAH_TSR_TFP (0x00800000) /* TCP flags present */ +#define TAH_TSR_SUDP (0x00400000) /* Segmentation for UDP */ +#define TAH_TSR_DLM (0x00200000) /* Data length mismatch */ +#define TAH_TSR_SIEEE (0x00100000) /* Segmentation for IEEE */ +#define TAH_TSR_TFPE (0x00080000) /* Transmit FIFO parity error */ +#define TAH_TSR_SSTS (0x00040000) /* Segment size too small */ +#define TAH_TSR_RSVD (0x0003FFFF) /* Reserved */ #endif /* CONFIG_440GX */
On Sunday 04 October 2009 20:04:22 Niklaus Giger wrote:
After running checkstyle.pl on the three previous patches I noted that in the *.h files there were a lot of long lines. This patch solves this problem.
Applied to u-boot-ppc4xx. Thanks.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
On Sunday 04 October 2009 20:04:21 Niklaus Giger wrote:
The command "reginfo" got an overhaul for the ppc4xx. It dumps all the relevant HW configuration registers (address, symbolic name, content). This allows to easily detect errors in *.h files and changes in the HW configuration.
Cheers, Stefan
On Sunday 04 October 2009 20:04:20 Niklaus Giger wrote:
Modify all existing *.c files to use the new register names as seen in the AMCC manuals.
Cheers, Stefan
On Sunday 04 October 2009 20:04:19 Niklaus Giger wrote:
Here you find all the changes in the include directory for new register names and adapting other ones to the names used by AMCC in their manuals, e.g. For 440EPx/GRPPC440EPx/GRX, Revision 1.15 – September 22, 2008 For PPC405GP Embedded Processor, Revision 1.02 – March 22, 2006
Cheers, Stefan
Niklaus Giger
Stefan Roese
