[U-Boot] Pull request: u-boot-arm/master
Hi Tom,
The following changes since commit ba9b42c81b0734d53edfbb1fe4a6ded7de78c5ab:
Merge branch 'sandbox' of git://git.denx.de/u-boot-x86 (2014-06-24 14:06:22 -0400)
git://git.denx.de/u-boot-arm master
for you to fetch changes up to 304f936aeaab0c3cc9d5af438fd3498ac7682991:
Merge remote-tracking branch 'u-boot-samsung/master' (2014-07-01 20:52:51 +0200)
Akshay Saraswat (9): Exynos5: DMC: Modify the definition of ddr3_mem_ctrl_init Exynos5420: Remove code for enabling read leveling Exynos5420: DMC: Add software read leveling Exynos: SPI: Fix reading data from SPI flash Exynos5420: Let macros be used for exynos5420 Exynos5420: Introduce support for the Peach-Pit board Exynos5: Config: Place environment at the end of SPI flash Exynos5: Config: Increase SPL footprint for Exynos5420 Exynos5: Config: Enable USB boot mode for all Exynos5 SoCs
Albert ARIBAUD (8): Merge branch 'u-boot-atmel/master' into 'u-boot-arm/master' Merge branch 'u-boot/master' into 'u-boot-arm/master' Merge branch 'u-boot-microblaze/zynq' into 'u-boot-arm/master' Merge branch 'u-boot-sh/rmobile' into 'u-boot-arm/master' Merge branch 'u-boot-imx/master' into 'u-boot-arm/master' Merge branch 'u-boot-ti/master' into 'u-boot-arm/master' Merge branch 'u-boot-tegra/master' into 'u-boot-arm/master' Merge remote-tracking branch 'u-boot-samsung/master'
Alison Wang (2): arm: vf610: Add QSPI driver support arm: imx: Add two macros for VF610 in IOMUX_PAD structure
Andreas Bießmann (2): avr32: migrate cache functions macb: make checkpatch clean
Ash Charles (3): omap: Don't enable GPMC CS0 with nothing attached omap4: duovero: Correct name of default device tree omap3: overo: Select fdtfile for expansion board
Axel Lin (1): spi: davinci: Fix register address for SPI1_BUS
Chao Fu (1): arm: vf610: Add QSPI support for VF610TWR
Doug Anderson (1): DMC: exynos5420: Gate CLKM to when reading PHY_CON13
Eric Nelson (1): serial_mxc: disable new features of autobaud detection
Fabio Estevam (10): mx6sabreauto: Add the mx6dual-lite variant mx6sabred: Add PFUZE100 PMIC support mx25pdk: Add generic board support mx6: Fix definition of IOMUXC_GPR12_DEVICE_TYPE_RC embestmx6boards: Fix CONFIG_CONSOLE_DEV embestmx6boards: Fix the dtb file name for riotboard mx28evk: Fix warning when CONFIG_ENV_IS_IN_SPI_FLASH is selected mx28evk: Add a target for SPI NOR boot mx28evk: Add documentation on how to boot from SPI NOR mx25pdk: Remove CONFIG_SYS_GENERIC_BOARD
Felipe Balbi (5): board: ti: am43xx: print unsupported board name cpu: armv7: am33x: ddr: write emif ref_ctrl_shadow register board: ti: am43xx: add support for AM43xx Starter Kit board: ti: am43xx: add AM437x SK PHY Address board: ti: am43xx: enable QSPI and Gbit Ethernet on AM437x SK
Jeroen Hofstee (4): tegra20: display: fix checking of return value ARM: tegra: fix include guard omap3: board: trivial: add void for no args PMIC: MAX77686: fix invalid bus check
Khoronzhuk, Ivan (2): mtd: nand: davinci: add header file for driver definitions ARM: keystone: aemif: move aemif driver to drivers/memory/ti-aemif.c
Marek Vasut (1): arm: mx5: Enable CONFIG_SYS_GENERIC_BOARD on M53EVK
Mark Rutland (1): arm64: zero cntvoff_el2
Masahiro Yamada (3): spl: consolidate arch/arm/include/asm/arch-*/spl.h arm: fix a double-definition error of _start symbol arm: zynq: fix a bug in Zynq linker script
Michael Pratt (1): Exynos: Split 5250 and 5420 memory bank configuration
Minkyu Kang (1): Revert "exynos: Enable PSHOLD in SPL"
Nobuhiro Iwamatsu (2): arm: rmobile: koelsch: Remove NOR-Flash support from boards.cfg arm: rmobile: lager: Remove NOR-Flash support from boards.cfg
Przemyslaw Marczak (2): trats/trats2: exynos_power_init: return 0 if no battery detected. Samsung: Goni: change maintainer to Robert Baldyga
Shawn Guo (1): mx6: drop ARM errata 742230
Stefano Babic (4): MX25: fix build due to missing sys_proto.h imx: correct HAB status for new chip TO OMAP: disable gpmc timeout safely for reenabling vf610: fix build due to missing sys_proto.h
Stephen Warren (2): ARM: tegra: fix extlinux.conf search location ARM: tegra: set initrd_high so boot scripts work
Steve Rae (1): arm: bcm281xx: Add CONFIG_SYS_GENERIC_BOARD
Tim Harvey (12): spl: nand: add support for mxs nand mx6: add common SPL configuration mx6: add boot device support for SPL imx: add comments and remove unused struct fields mx6: add structs for mmdc and ddr iomux registers mx6: add mmdc configuration for MX6Q/MX6DL imx: iomux: add macros to setup iomux for multiple SoC types imx: ventana: split read_eeprom into standalone file imx: ventana: auto-configure for IMX6Q vs IMX6DL imx: ventana: switch to SPL dwc_ahsata: return failure for MX6 if not IMX6Q/IMX6D imx: sata: return failure if not IMX6Q/IMX6D
Tim Schendekehl (1): arm: ethernut5: convert to generic board
Tushar Behera (1): Arndale: Enable preboot support
Wu, Josh (3): net: macb: enable dcache in macb video: atmel_hlcdfb: enable dcache support ARMv7: at91: enable ICache and DCache.
Łukasz Majewski (2): FIX: config: goni: Change goni configuration to use Tizen's THOR downlodader FIX: config: goni: Change goni configuration to store envs at eMMC
arch/arm/cpu/arm720t/tegra-common/spl.c | 2 +- arch/arm/cpu/arm926ejs/davinci/da850_lowlevel.c | 2 +- arch/arm/cpu/arm926ejs/davinci/dm365_lowlevel.c | 1 + arch/arm/cpu/armv7/am33xx/ddr.c | 1 + arch/arm/cpu/armv7/at91/cpu.c | 2 + arch/arm/cpu/armv7/exynos/dmc_common.c | 2 +- arch/arm/cpu/armv7/exynos/dmc_init_ddr3.c | 369 +++++++++++++++++++++++++++++++++++++++++------------- arch/arm/cpu/armv7/exynos/exynos5_setup.h | 21 ++-- arch/arm/cpu/armv7/exynos/lowlevel_init.c | 2 - arch/arm/cpu/armv7/keystone/Makefile | 1 - arch/arm/cpu/armv7/mx6/Makefile | 1 + arch/arm/cpu/armv7/mx6/ddr.c | 490 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/cpu/armv7/mx6/hab.c | 73 +++++++++-- arch/arm/cpu/armv7/omap-common/mem-common.c | 6 +- arch/arm/cpu/armv7/omap3/board.c | 4 +- arch/arm/cpu/armv7/tegra20/display.c | 2 +- arch/arm/cpu/armv7/zynq/u-boot.lds | 1 + arch/arm/cpu/armv8/transition.S | 2 +- arch/arm/dts/Makefile | 3 +- arch/arm/dts/exynos5420-peach-pit.dts | 127 +++++++++++++++++++ arch/arm/dts/exynos5420-smdk5420.dts | 23 +--- arch/arm/dts/exynos5420.dtsi | 70 ----------- arch/arm/dts/exynos54xx.dtsi | 151 +++++++++++++++++++++++ arch/arm/imx-common/Makefile | 1 + arch/arm/imx-common/cpu.c | 16 ++- arch/arm/imx-common/iomux-v3.c | 18 ++- arch/arm/imx-common/sata.c | 7 +- arch/arm/imx-common/spl.c | 81 ++++++++++++ arch/arm/include/asm/arch-at91/spl.h | 24 ---- arch/arm/include/asm/arch-davinci/emif_defs.h | 72 ----------- arch/arm/include/asm/arch-davinci/hardware.h | 1 - arch/arm/include/asm/arch-davinci/nand_defs.h | 38 ------ arch/arm/include/asm/arch-davinci/spl.h | 16 --- arch/arm/include/asm/arch-exynos/dmc.h | 3 + arch/arm/include/asm/arch-exynos/power.h | 4 +- arch/arm/include/asm/arch-keystone/hardware-k2hk.h | 7 -- arch/arm/include/asm/arch-keystone/hardware.h | 30 +---- arch/arm/include/asm/arch-keystone/nand_defs.h | 23 ---- arch/arm/include/asm/arch-mx35/spl.h | 22 ---- arch/arm/include/asm/arch-mx5/spl.h | 13 -- arch/arm/include/asm/arch-mx6/hab.h | 17 ++- arch/arm/include/asm/arch-mx6/imx-regs.h | 2 + arch/arm/include/asm/arch-mx6/iomux.h | 2 +- arch/arm/include/asm/arch-mx6/mx6-ddr.h | 231 ++++++++++++++++++++++++++++++++++ arch/arm/include/asm/arch-mx6/sys_proto.h | 4 +- arch/arm/include/asm/arch-tegra114/spl.h | 22 ---- arch/arm/include/asm/arch-tegra124/spl.h | 13 -- arch/arm/include/asm/arch-tegra20/spl.h | 12 -- arch/arm/include/asm/arch-tegra30/spl.h | 12 -- arch/arm/include/asm/arch-tnetv107x/emif_defs.h | 1 - arch/arm/include/asm/arch-tnetv107x/hardware.h | 2 + arch/arm/include/asm/arch-tnetv107x/nand_defs.h | 23 ---- arch/arm/include/asm/arch-vf610/crm_regs.h | 11 +- arch/arm/include/asm/arch-vf610/imx-regs.h | 4 +- arch/arm/include/asm/arch-vf610/iomux-vf610.h | 17 ++- arch/arm/include/asm/imx-common/iomux-v3.h | 27 ++++ arch/arm/include/asm/spl.h | 20 +++ arch/arm/include/asm/{arch-keystone/emif_defs.h => ti-common/davinci_nand.h} | 55 ++++++--- arch/arm/include/asm/ti-common/ti-aemif.h | 39 ++++++ arch/arm/lib/vectors.S | 2 - arch/avr32/cpu/cache.c | 20 +-- arch/avr32/include/asm/arch-at32ap700x/cacheflush.h | 2 - arch/avr32/include/asm/dma-mapping.h | 6 +- arch/avr32/lib/board.c | 4 +- board/Barix/ipam390/ipam390.c | 2 +- board/ait/cam_enc_4xx/cam_enc_4xx.c | 2 +- board/davinci/da8xxevm/da830evm.c | 3 +- board/davinci/da8xxevm/da850evm.c | 2 +- board/davinci/dm355evm/dm355evm.c | 3 +- board/davinci/dm355leopard/dm355leopard.c | 2 +- board/davinci/dm365evm/dm365evm.c | 3 +- board/davinci/dm6467evm/dm6467evm.c | 3 +- board/davinci/ea20/ea20.c | 2 +- board/davinci/sonata/sonata.c | 2 +- board/denx/m53evk/m53evk.c | 2 +- board/enbw/enbw_cmc/enbw_cmc.c | 2 +- board/freescale/mx28evk/README | 22 +++- board/freescale/mx6qsabreauto/mx6dl.cfg | 130 +++++++++++++++++++ board/freescale/mx6sabresd/mx6sabresd.c | 84 +++++++++++++ board/freescale/vf610twr/vf610twr.c | 29 ++++- board/gateworks/gw_ventana/Makefile | 3 +- board/gateworks/gw_ventana/README | 92 +++++++++----- board/gateworks/gw_ventana/eeprom.c | 89 +++++++++++++ board/gateworks/gw_ventana/gw_ventana.c | 597 +++++++++++++++++++++++++++++++++++++++++++++++----------------------------------------- board/gateworks/gw_ventana/gw_ventana.cfg | 15 --- board/gateworks/gw_ventana/gw_ventana_spl.c | 419 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/gateworks/gw_ventana/ventana_eeprom.h | 11 ++ board/omicron/calimain/calimain.c | 2 +- board/overo/overo.c | 14 +++ board/samsung/trats/trats.c | 2 +- board/samsung/trats2/trats2.c | 2 +- board/ti/am43xx/board.c | 79 +++++++++++- board/ti/am43xx/board.h | 5 + board/ti/am43xx/mux.c | 3 + board/ti/k2hk_evm/board.c | 10 +- board/ti/tnetv107xevm/sdb_board.c | 2 +- boards.cfg | 13 +- doc/README.mxs | 26 ++++ drivers/Makefile | 1 + drivers/block/dwc_ahsata.c | 5 + drivers/memory/Makefile | 1 + arch/arm/cpu/armv7/keystone/aemif.c => drivers/memory/ti-aemif.c | 37 +++--- drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/davinci_nand.c | 3 +- drivers/mtd/nand/mxs_nand_spl.c | 231 ++++++++++++++++++++++++++++++++++ drivers/net/macb.c | 113 ++++++++++++----- drivers/power/pmic/pmic_max77686.c | 13 +- drivers/serial/serial_mxc.c | 4 +- drivers/spi/Makefile | 1 + drivers/spi/davinci_spi.c | 2 +- drivers/spi/exynos_spi.c | 5 +- drivers/spi/fsl_qspi.c | 482 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/spi/fsl_qspi.h | 127 +++++++++++++++++++ drivers/video/atmel_hlcdfb.c | 6 + include/configs/am43xx_evm.h | 2 + include/configs/arndale.h | 2 + include/configs/bcm28155_ap.h | 1 + include/configs/davinci_dm6467evm.h | 2 + include/configs/embestmx6boards.h | 4 +- include/configs/ethernut5.h | 2 + include/configs/exynos5-dt.h | 15 ++- include/configs/exynos5250-dt.h | 13 +- include/configs/exynos5420.h | 52 ++++++++ include/configs/gw_ventana.h | 11 ++ include/configs/imx6_spl.h | 71 +++++++++++ include/configs/k2hk_evm.h | 6 + include/configs/m53evk.h | 1 + include/configs/mx28evk.h | 5 +- include/configs/mx6_common.h | 1 - include/configs/mx6qsabreauto.h | 4 + include/configs/mx6sabresd.h | 12 ++ include/configs/omap3_overo.h | 10 +- include/configs/peach-pit.h | 25 ++++ include/configs/s5p_goni.h | 17 ++- include/configs/smdk5420.h | 49 ++------ include/configs/tegra-common-post.h | 9 +- include/configs/tegra-common-ums.h | 2 +- include/configs/ti_omap4_common.h | 2 +- include/configs/vf610twr.h | 12 ++ include/power/pfuze100_pmic.h | 4 + 140 files changed, 4245 insertions(+), 1078 deletions(-) create mode 100644 arch/arm/cpu/armv7/mx6/ddr.c create mode 100644 arch/arm/dts/exynos5420-peach-pit.dts delete mode 100644 arch/arm/dts/exynos5420.dtsi create mode 100644 arch/arm/dts/exynos54xx.dtsi create mode 100644 arch/arm/imx-common/spl.c delete mode 100644 arch/arm/include/asm/arch-at91/spl.h delete mode 100644 arch/arm/include/asm/arch-davinci/emif_defs.h delete mode 100644 arch/arm/include/asm/arch-davinci/nand_defs.h delete mode 100644 arch/arm/include/asm/arch-davinci/spl.h delete mode 100644 arch/arm/include/asm/arch-keystone/nand_defs.h delete mode 100644 arch/arm/include/asm/arch-mx35/spl.h delete mode 100644 arch/arm/include/asm/arch-mx5/spl.h delete mode 100644 arch/arm/include/asm/arch-tegra114/spl.h delete mode 100644 arch/arm/include/asm/arch-tegra124/spl.h delete mode 100644 arch/arm/include/asm/arch-tegra20/spl.h delete mode 100644 arch/arm/include/asm/arch-tegra30/spl.h delete mode 100644 arch/arm/include/asm/arch-tnetv107x/emif_defs.h delete mode 100644 arch/arm/include/asm/arch-tnetv107x/nand_defs.h rename arch/arm/include/asm/{arch-keystone/emif_defs.h => ti-common/davinci_nand.h} (56%) create mode 100644 arch/arm/include/asm/ti-common/ti-aemif.h create mode 100644 board/freescale/mx6qsabreauto/mx6dl.cfg create mode 100644 board/gateworks/gw_ventana/eeprom.c create mode 100644 board/gateworks/gw_ventana/gw_ventana_spl.c create mode 100644 drivers/memory/Makefile rename arch/arm/cpu/armv7/keystone/aemif.c => drivers/memory/ti-aemif.c (63%) create mode 100644 drivers/mtd/nand/mxs_nand_spl.c create mode 100644 drivers/spi/fsl_qspi.c create mode 100644 drivers/spi/fsl_qspi.h create mode 100644 include/configs/exynos5420.h create mode 100644 include/configs/imx6_spl.h create mode 100644 include/configs/peach-pit.h
Amicalement,
On Wed, Jul 02, 2014 at 10:33:16PM +0200, Albert ARIBAUD wrote:
Hi Tom,
Albert ARIBAUD
