[U-Boot] [PATCH 0/7] Add Intel Arria 10 SoC FPGA driver
This patchset adds FPGA driver to Intel Arria 10 SoC.
This series is working on top of u-boot-socfpga-next branch http://git.denx.de/?p=u-boot/u-boot-socfpga.git;a=shortlog;h=refs/heads/next.
Tien Fong Chee (7): arm: socfpga: Remove unused passing parameter of socfpga_bridges_reset arm: socfpga: Convert FPGA configuration to Kconfig method. arm: socfpga: Restructure FPGA driver in the preparation to support A10. arm: socfpga: Move FPGA manager driver to FPGA driver arm: socfpga: Move the FPGA driver header from arch to include directory arm: socfpga: Add Arria10 FPGA manager program assembly driver arm: socfpga: Add FPGA driver support for Arria 10
arch/arm/mach-socfpga/Makefile | 2 +- arch/arm/mach-socfpga/fpga_manager.c | 78 --- arch/arm/mach-socfpga/include/mach/fpga_manager.h | 65 +--- .../mach/{fpga_manager.h => fpga_manager_gen5.h} | 69 ++-- .../include/mach/reset_manager_arria10.h | 2 +- arch/arm/mach-socfpga/lowlevel_init.S | 48 ++ arch/arm/mach-socfpga/reset_manager_arria10.c | 6 +- arch/arm/mach-socfpga/reset_manager_gen5.c | 5 +- arch/arm/mach-socfpga/system_manager_gen5.c | 2 +- drivers/Makefile | 1 + drivers/ddr/altera/sdram.c | 7 +- drivers/fpga/Kconfig | 5 +- drivers/fpga/Makefile | 5 +- drivers/fpga/socfpga.c | 269 +----------- drivers/fpga/socfpga_arria10.c | 490 ++++++++++++++++++++ drivers/fpga/{socfpga.c => socfpga_gen5.c} | 75 ++- include/altera.h | 2 +- include/configs/socfpga_common.h | 3 - include/intel_socfpga/fpga_manager.h | 38 ++ include/intel_socfpga/fpga_manager_arria10.h | 107 +++++ .../intel_socfpga/fpga_manager_gen5.h | 69 ++-- 21 files changed, 831 insertions(+), 517 deletions(-) delete mode 100644 arch/arm/mach-socfpga/fpga_manager.c copy arch/arm/mach-socfpga/include/mach/{fpga_manager.h => fpga_manager_gen5.h} (57%) create mode 100644 arch/arm/mach-socfpga/lowlevel_init.S create mode 100644 drivers/fpga/socfpga_arria10.c copy drivers/fpga/{socfpga.c => socfpga_gen5.c} (86%) create mode 100644 include/intel_socfpga/fpga_manager.h create mode 100644 include/intel_socfpga/fpga_manager_arria10.h copy arch/arm/mach-socfpga/include/mach/fpga_manager.h => include/intel_socfpga/fpga_manager_gen5.h (57%)
Remove unused passing parameter of socfpga_bridges_reset function in SoCFPGA Arria10.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- .../include/mach/reset_manager_arria10.h | 2 +- arch/arm/mach-socfpga/reset_manager_arria10.c | 4 ++-- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h b/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h index 7922db8..b6d7f4f 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h @@ -17,7 +17,7 @@ int socfpga_reset_deassert_bridges_handoff(void); void socfpga_reset_assert_fpga_connected_peripherals(void); void socfpga_reset_deassert_osc1wd0(void); void socfpga_reset_uart(int assert); -int socfpga_bridges_reset(int enable); +int socfpga_bridges_reset(void);
struct socfpga_reset_manager { u32 stat; diff --git a/arch/arm/mach-socfpga/reset_manager_arria10.c b/arch/arm/mach-socfpga/reset_manager_arria10.c index d8c858c..66f1ec2 100644 --- a/arch/arm/mach-socfpga/reset_manager_arria10.c +++ b/arch/arm/mach-socfpga/reset_manager_arria10.c @@ -318,13 +318,13 @@ void socfpga_per_reset_all(void) }
#if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) -int socfpga_bridges_reset(int enable) +int socfpga_bridges_reset(void) { /* For SoCFPGA-VT, this is NOP. */ return 0; } #else -int socfpga_bridges_reset(int enable) +int socfpga_bridges_reset(void) { int ret;
So how do you un-reset the bridges if you drop this $enable argument ?
This socfpga_reset_deassert_bridges_handoff() would be called, bridges are released based on DTS.
diff --git a/arch/arm/mach- socfpga/include/mach/reset_manager_arria10.h b/arch/arm/mach- socfpga/include/mach/reset_manager_arria10.h index 7922db8..b6d7f4f 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h @@ -17,7 +17,7 @@ int socfpga_reset_deassert_bridges_handoff(void); void socfpga_reset_assert_fpga_connected_peripherals(void); void socfpga_reset_deassert_osc1wd0(void); void socfpga_reset_uart(int assert); -int socfpga_bridges_reset(int enable); +int socfpga_bridges_reset(void); struct socfpga_reset_manager { u32 stat; diff --git a/arch/arm/mach-socfpga/reset_manager_arria10.c b/arch/arm/mach-socfpga/reset_manager_arria10.c index d8c858c..66f1ec2 100644 --- a/arch/arm/mach-socfpga/reset_manager_arria10.c +++ b/arch/arm/mach-socfpga/reset_manager_arria10.c @@ -318,13 +318,13 @@ void socfpga_per_reset_all(void) } #if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) -int socfpga_bridges_reset(int enable) +int socfpga_bridges_reset(void) { /* For SoCFPGA-VT, this is NOP. */ return 0; } #else -int socfpga_bridges_reset(int enable) +int socfpga_bridges_reset(void) { int ret;
Seems the naming needs some work, it's quite chaotic and inobvious then.
It is okay for "socfpga_bridges_unreset_byfdt()?
diff --git a/arch/arm/mach- socfpga/include/mach/reset_manager_arria10.h b/arch/arm/mach- socfpga/include/mach/reset_manager_arria10.h index 7922db8..b6d7f4f 100644 --- a/arch/arm/mach- socfpga/include/mach/reset_manager_arria10.h +++ b/arch/arm/mach- socfpga/include/mach/reset_manager_arria10.h @@ -17,7 +17,7 @@ int socfpga_reset_deassert_bridges_handoff(void); void socfpga_reset_assert_fpga_connected_peripherals(void); void socfpga_reset_deassert_osc1wd0(void); void socfpga_reset_uart(int assert); -int socfpga_bridges_reset(int enable); +int socfpga_bridges_reset(void); struct socfpga_reset_manager { u32 stat; diff --git a/arch/arm/mach-socfpga/reset_manager_arria10.c b/arch/arm/mach-socfpga/reset_manager_arria10.c index d8c858c..66f1ec2 100644 --- a/arch/arm/mach-socfpga/reset_manager_arria10.c +++ b/arch/arm/mach-socfpga/reset_manager_arria10.c @@ -318,13 +318,13 @@ void socfpga_per_reset_all(void) } #if defined(CONFIG_SOCFPGA_VIRTUAL_TARGET) -int socfpga_bridges_reset(int enable) +int socfpga_bridges_reset(void) { /* For SoCFPGA-VT, this is NOP. */ return 0; } #else -int socfpga_bridges_reset(int enable) +int socfpga_bridges_reset(void) { int ret;
Just keep it as-is for now ...
Okay.
Convert Macro #define configuration to Kconfig method. All FPGA devices enable configuration based on CONFIG_FPGA_ALTERA.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- drivers/fpga/Kconfig | 5 ++++- drivers/fpga/Makefile | 3 +-- include/altera.h | 2 +- include/configs/socfpga_common.h | 3 --- 4 files changed, 6 insertions(+), 7 deletions(-)
diff --git a/drivers/fpga/Kconfig b/drivers/fpga/Kconfig index a760944..fc4ea0d 100644 --- a/drivers/fpga/Kconfig +++ b/drivers/fpga/Kconfig @@ -2,12 +2,15 @@ menu "FPGA support"
config FPGA bool + help + Enable FPGA driver build.
config FPGA_ALTERA bool "Enable Altera FPGA drivers" + default y if TARGET_SOCFPGA_GEN5 && CMD_FPGA select FPGA help - Say Y here to enable the Altera FPGA driver + Default Y here to enable the Altera FPGA driver
This provides basic infrastructure to support Altera FPGA devices. Enable Altera FPGA specific functions which includes bitstream diff --git a/drivers/fpga/Makefile b/drivers/fpga/Makefile index 777706f..84e7605 100644 --- a/drivers/fpga/Makefile +++ b/drivers/fpga/Makefile @@ -14,10 +14,9 @@ obj-$(CONFIG_FPGA_ZYNQMPPL) += zynqmppl.o obj-$(CONFIG_FPGA_XILINX) += xilinx.o obj-$(CONFIG_FPGA_LATTICE) += ivm_core.o lattice.o ifdef CONFIG_FPGA_ALTERA -obj-y += altera.o +obj-y += altera.o socfpga.o obj-$(CONFIG_FPGA_ACEX1K) += ACEX1K.o obj-$(CONFIG_FPGA_CYCLON2) += cyclon2.o obj-$(CONFIG_FPGA_STRATIX_II) += stratixII.o obj-$(CONFIG_FPGA_STRATIX_V) += stratixv.o -obj-$(CONFIG_FPGA_SOCFPGA) += socfpga.o endif diff --git a/include/altera.h b/include/altera.h index 48d3eb7..a627b37 100644 --- a/include/altera.h +++ b/include/altera.h @@ -109,7 +109,7 @@ typedef struct { Altera_post_fn post; } altera_board_specific_func;
-#ifdef CONFIG_FPGA_SOCFPGA +#ifdef CONFIG_FPGA_ALTERA int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size); #endif
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index da7e4ad..1b79c03 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -107,9 +107,6 @@ */ #ifdef CONFIG_TARGET_SOCFPGA_GEN5 #ifdef CONFIG_CMD_FPGA -#define CONFIG_FPGA -#define CONFIG_FPGA_ALTERA -#define CONFIG_FPGA_SOCFPGA #define CONFIG_FPGA_COUNT 1 #endif #endif
config FPGA bool
- help
Separate patch please , also this is not driver, but framework . There's not just drivers here IMO.
- default y if TARGET_SOCFPGA_GEN5 && CMD_FPGA
Should be selected by arch code, drop this.
select FPGA help
Keep as is, it's up to user to decide.
Now all the ancient systems which had the ancient Altera FPGAs will build-in the socfpga stuff too . That cannot work.
diff --git a/drivers/fpga/Kconfig b/drivers/fpga/Kconfig index a760944..fc4ea0d 100644 --- a/drivers/fpga/Kconfig +++ b/drivers/fpga/Kconfig @@ -2,12 +2,15 @@ menu "FPGA support" config FPGA bool
- help
- Enable FPGA driver build.
ohh...okay, so you prefer i revert the changes, or better explanation in separate patch? if for later,what is your suggestion? Thanks.
just for clarity, are you means defconfig == "selected by arch code"?
select FPGA help
- Default Y here to enable the Altera FPGA driver
I found that all users enable it, so that is why i set this as default, otherwise i have to add this into their defconfig one by one. Users who don't want enable it, they can set "N" in their defconfig. What do you think?
Okay, i will revert the changes.
obj-$(CONFIG_FPGA_ACEX1K) += ACEX1K.o obj-$(CONFIG_FPGA_CYCLON2) += cyclon2.o obj-$(CONFIG_FPGA_STRATIX_II) += stratixII.o obj-$(CONFIG_FPGA_STRATIX_V) += stratixv.o -obj-$(CONFIG_FPGA_SOCFPGA) += socfpga.o endif diff --git a/include/altera.h b/include/altera.h index 48d3eb7..a627b37 100644 --- a/include/altera.h +++ b/include/altera.h @@ -109,7 +109,7 @@ typedef struct { Altera_post_fn post; } altera_board_specific_func; -#ifdef CONFIG_FPGA_SOCFPGA +#ifdef CONFIG_FPGA_ALTERA int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size); #endif diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index da7e4ad..1b79c03 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -107,9 +107,6 @@ */ #ifdef CONFIG_TARGET_SOCFPGA_GEN5 #ifdef CONFIG_CMD_FPGA -#define CONFIG_FPGA -#define CONFIG_FPGA_ALTERA -#define CONFIG_FPGA_SOCFPGA #define CONFIG_FPGA_COUNT 1 #endif #endif
config FPGA bool
- help
Turning this whole FPGA subsystem into Kconfig should be a separate patch. There's a script for that too and you need to convert and build test all the boards which define CONFIG_FPGA .
I mean arch/arm/mach-socfpga/Kconfig
select FPGA help
You set it as default in arch/arm/mach-socfpga/Kconfig , no need to modify the text.
- help
Turning this whole FPGA subsystem into Kconfig should be a separat patch. There's a script for that too and you need to convert and build test all the boards which define CONFIG_FPGA .
Okay, this patch is specific for turning whole FPGA sybsytem into Kconfig. I will use moveconfig.py for this. thanks.
With moveconfig.py, i think this change is not required.
select FPGA help
config FPGA bool
- help
So, who will enable FPGA_ALTERA ?
- help
Below boards will enable the FPGA_ALTERA, their header file include socfpga_common.h, and CONFIG_CMD_FPGA set to y by default. i believe moveconfig.py will set this FPGA_ALTERA into their defconfig respectively. config TARGET_SOCFPGA_ARRIA10_SOCDK bool "Altera SOCFPGA SoCDK (Arria 10)" select TARGET_SOCFPGA_ARRIA10
config TARGET_SOCFPGA_ARRIA5_SOCDK bool "Altera SOCFPGA SoCDK (Arria V)" select TARGET_SOCFPGA_ARRIA5
config TARGET_SOCFPGA_CYCLONE5_SOCDK bool "Altera SOCFPGA SoCDK (Cyclone V)" select TARGET_SOCFPGA_CYCLONE5
config TARGET_SOCFPGA_ARIES_MCVEVK bool "Aries MCVEVK (Cyclone V)" select TARGET_SOCFPGA_CYCLONE5
config TARGET_SOCFPGA_EBV_SOCRATES bool "EBV SoCrates (Cyclone V)" select TARGET_SOCFPGA_CYCLONE5
config TARGET_SOCFPGA_IS1 bool "IS1 (Cyclone V)" select TARGET_SOCFPGA_CYCLONE5
config TARGET_SOCFPGA_SAMTEC_VINING_FPGA bool "samtec VIN|ING FPGA (Cyclone V)" select BOARD_LATE_INIT select TARGET_SOCFPGA_CYCLONE5
config TARGET_SOCFPGA_SR1500 bool "SR1500 (Cyclone V)" select TARGET_SOCFPGA_CYCLONE5
config TARGET_SOCFPGA_TERASIC_DE0_NANO bool "Terasic DE0-Nano-Atlas (Cyclone V)" select TARGET_SOCFPGA_CYCLONE5
config TARGET_SOCFPGA_TERASIC_DE10_NANO bool "Terasic DE10-Nano (Cyclone V)" select TARGET_SOCFPGA_CYCLONE5
config TARGET_SOCFPGA_TERASIC_DE1_SOC bool "Terasic DE1-SoC (Cyclone V)" select TARGET_SOCFPGA_CYCLONE5
config TARGET_SOCFPGA_TERASIC_SOCKIT bool "Terasic SoCkit (Cyclone V)" select TARGET_SOCFPGA_CYCLONE5
On 05/05/2017 12:26 PM, tien.fong.chee@intel.com wrote: > > > > > From: Tien Fong Chee tien.fong.chee@intel.com > > Convert Macro #define configuration to Kconfig method. > All > FPGA > devices > enable configuration based on CONFIG_FPGA_ALTERA. > > Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com > --- > drivers/fpga/Kconfig | 5 ++++- > drivers/fpga/Makefile | 3 +-- > include/altera.h | 2 +- > include/configs/socfpga_common.h | 3 --- > 4 files changed, 6 insertions(+), 7 deletions(-) > > diff --git a/drivers/fpga/Kconfig b/drivers/fpga/Kconfig > index a760944..fc4ea0d 100644 > --- a/drivers/fpga/Kconfig > +++ b/drivers/fpga/Kconfig > @@ -2,12 +2,15 @@ menu "FPGA support" > > config FPGA > bool > + help > + Enable FPGA driver build. Separate patch please , also this is not driver, but framework . There's not just drivers here IMO.
> > > > config FPGA_ALTERA > bool "Enable Altera FPGA drivers" > + default y if TARGET_SOCFPGA_GEN5 && CMD_FPGA Should be selected by arch code, drop this.
convert to Kconfig take time to run, more than 1k++ defconfg need to be processed, so i plan to take out from this patch set and submiting separately after this patchset. It sounds okay for you, marek :)?
On Jum, 2017-05-05 at 13:11 +0200, Marek Vasut wrote: > > > > On 05/05/2017 12:26 PM, tien.fong.chee@intel.com wrote: >> >> >> >> >> From: Tien Fong Chee tien.fong.chee@intel.com >> >> Convert Macro #define configuration to Kconfig method. >> All >> FPGA >> devices >> enable configuration based on CONFIG_FPGA_ALTERA. >> >> Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com >> --- >> drivers/fpga/Kconfig | 5 ++++- >> drivers/fpga/Makefile | 3 +-- >> include/altera.h | 2 +- >> include/configs/socfpga_common.h | 3 --- >> 4 files changed, 6 insertions(+), 7 deletions(-) >> >> diff --git a/drivers/fpga/Kconfig b/drivers/fpga/Kconfig >> index a760944..fc4ea0d 100644 >> --- a/drivers/fpga/Kconfig >> +++ b/drivers/fpga/Kconfig >> @@ -2,12 +2,15 @@ menu "FPGA support" >> >> config FPGA >> bool >> + help >> + Enable FPGA driver build. > Separate patch please , also this is not driver, but > framework . > There's > not just drivers here IMO. > ohh...okay, so you prefer i revert the changes, or better explanation in separate patch? if for later,what is your suggestion? Thanks.
> > > >> >> >> >> config FPGA_ALTERA >> bool "Enable Altera FPGA drivers" >> + default y if TARGET_SOCFPGA_GEN5 && CMD_FPGA > Should be selected by arch code, drop this. > just for clarity, are you means defconfig == "selected by arch code"?
Yes, it takes time. That's fine.
Move FPGA driver which is Gen5 specific code into Gen5 files. No functional change.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/Makefile | 2 +- arch/arm/mach-socfpga/include/mach/fpga_manager.h | 65 +---- .../mach/{fpga_manager.h => fpga_manager_gen5.h} | 69 +++--- drivers/Makefile | 1 + drivers/fpga/Makefile | 1 + drivers/fpga/socfpga.c | 267 +------------------- drivers/fpga/{socfpga.c => socfpga_gen5.c} | 29 +-- 7 files changed, 48 insertions(+), 386 deletions(-) copy arch/arm/mach-socfpga/include/mach/{fpga_manager.h => fpga_manager_gen5.h} (57%) copy drivers/fpga/{socfpga.c => socfpga_gen5.c} (92%)
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 41b779c..286bfef 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -9,7 +9,6 @@
obj-y += board.o obj-y += clock_manager.o -obj-y += fpga_manager.o obj-y += misc.o obj-y += reset_manager.o obj-y += timer.o @@ -21,6 +20,7 @@ obj-y += reset_manager_gen5.o obj-y += scan_manager.o obj-y += system_manager_gen5.o obj-y += wrap_pll_config.o +obj-y += fpga_manager.o endif
ifdef CONFIG_TARGET_SOCFPGA_ARRIA10 diff --git a/arch/arm/mach-socfpga/include/mach/fpga_manager.h b/arch/arm/mach-socfpga/include/mach/fpga_manager.h index a077e22..69d8613 100644 --- a/arch/arm/mach-socfpga/include/mach/fpga_manager.h +++ b/arch/arm/mach-socfpga/include/mach/fpga_manager.h @@ -1,5 +1,5 @@ /* - * Copyright (C) 2012 Altera Corporation <www.altera.com> + * Copyright (C) 2012-2017 Altera Corporation <www.altera.com> * All rights reserved. * * SPDX-License-Identifier: BSD-3-Clause @@ -10,58 +10,9 @@
#include <altera.h>
-struct socfpga_fpga_manager { - /* FPGA Manager Module */ - u32 stat; /* 0x00 */ - u32 ctrl; - u32 dclkcnt; - u32 dclkstat; - u32 gpo; /* 0x10 */ - u32 gpi; - u32 misci; /* 0x18 */ - u32 _pad_0x1c_0x82c[517]; - - /* Configuration Monitor (MON) Registers */ - u32 gpio_inten; /* 0x830 */ - u32 gpio_intmask; - u32 gpio_inttype_level; - u32 gpio_int_polarity; - u32 gpio_intstatus; /* 0x840 */ - u32 gpio_raw_intstatus; - u32 _pad_0x848; - u32 gpio_porta_eoi; - u32 gpio_ext_porta; /* 0x850 */ - u32 _pad_0x854_0x85c[3]; - u32 gpio_1s_sync; /* 0x860 */ - u32 _pad_0x864_0x868[2]; - u32 gpio_ver_id_code; - u32 gpio_config_reg2; /* 0x870 */ - u32 gpio_config_reg1; -}; - -#define FPGAMGRREGS_STAT_MODE_MASK 0x7 -#define FPGAMGRREGS_STAT_MSEL_MASK 0xf8 -#define FPGAMGRREGS_STAT_MSEL_LSB 3 - -#define FPGAMGRREGS_CTRL_CFGWDTH_MASK 0x200 -#define FPGAMGRREGS_CTRL_AXICFGEN_MASK 0x100 -#define FPGAMGRREGS_CTRL_NCONFIGPULL_MASK 0x4 -#define FPGAMGRREGS_CTRL_NCE_MASK 0x2 -#define FPGAMGRREGS_CTRL_EN_MASK 0x1 -#define FPGAMGRREGS_CTRL_CDRATIO_LSB 6 - -#define FPGAMGRREGS_MON_GPIO_EXT_PORTA_CRC_MASK 0x8 -#define FPGAMGRREGS_MON_GPIO_EXT_PORTA_ID_MASK 0x4 -#define FPGAMGRREGS_MON_GPIO_EXT_PORTA_CD_MASK 0x2 -#define FPGAMGRREGS_MON_GPIO_EXT_PORTA_NS_MASK 0x1 - -/* FPGA Mode */ -#define FPGAMGRREGS_MODE_FPGAOFF 0x0 -#define FPGAMGRREGS_MODE_RESETPHASE 0x1 -#define FPGAMGRREGS_MODE_CFGPHASE 0x2 -#define FPGAMGRREGS_MODE_INITPHASE 0x3 -#define FPGAMGRREGS_MODE_USERMODE 0x4 -#define FPGAMGRREGS_MODE_UNKNOWN 0x5 +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +#include <asm/arch/fpga_manager_gen5.h> +#endif
/* FPGA CD Ratio Value */ #define CDRATIO_x1 0x0 @@ -74,4 +25,12 @@ int fpgamgr_test_fpga_ready(void); int fpgamgr_poll_fpga_ready(void); int fpgamgr_get_mode(void);
+#define FPGA_TIMEOUT_CNT 0x1000000 + +#ifndef __ASSEMBLY__ + +/* Common prototypes */ +int fpgamgr_dclkcnt_set(unsigned long cnt); + +#endif /* __ASSEMBLY__ */ #endif /* _FPGA_MANAGER_H_ */ diff --git a/arch/arm/mach-socfpga/include/mach/fpga_manager.h b/arch/arm/mach-socfpga/include/mach/fpga_manager_gen5.h similarity index 57% copy from arch/arm/mach-socfpga/include/mach/fpga_manager.h copy to arch/arm/mach-socfpga/include/mach/fpga_manager_gen5.h index a077e22..2de7a11 100644 --- a/arch/arm/mach-socfpga/include/mach/fpga_manager.h +++ b/arch/arm/mach-socfpga/include/mach/fpga_manager_gen5.h @@ -1,14 +1,38 @@ /* - * Copyright (C) 2012 Altera Corporation <www.altera.com> + * Copyright (C) 2012-2017 Altera Corporation <www.altera.com> * All rights reserved. * * SPDX-License-Identifier: BSD-3-Clause */
-#ifndef _FPGA_MANAGER_H_ -#define _FPGA_MANAGER_H_ +#ifndef _FPGA_MANAGER_GEN5_H_ +#define _FPGA_MANAGER_GEN5_H_
-#include <altera.h> +#define FPGAMGRREGS_STAT_MODE_MASK 0x7 +#define FPGAMGRREGS_STAT_MSEL_MASK 0xf8 +#define FPGAMGRREGS_STAT_MSEL_LSB 3 + +#define FPGAMGRREGS_CTRL_CFGWDTH_MASK BIT(9) +#define FPGAMGRREGS_CTRL_AXICFGEN_MASK BIT(8) +#define FPGAMGRREGS_CTRL_NCONFIGPULL_MASK BIT(2) +#define FPGAMGRREGS_CTRL_NCE_MASK BIT(1) +#define FPGAMGRREGS_CTRL_EN_MASK BIT(0) +#define FPGAMGRREGS_CTRL_CDRATIO_LSB 6 + +#define FPGAMGRREGS_MON_GPIO_EXT_PORTA_CRC_MASK BIT(3) +#define FPGAMGRREGS_MON_GPIO_EXT_PORTA_ID_MASK BIT(2) +#define FPGAMGRREGS_MON_GPIO_EXT_PORTA_CD_MASK BIT(1) +#define FPGAMGRREGS_MON_GPIO_EXT_PORTA_NS_MASK BIT(0) + +/* FPGA Mode */ +#define FPGAMGRREGS_MODE_FPGAOFF 0x0 +#define FPGAMGRREGS_MODE_RESETPHASE 0x1 +#define FPGAMGRREGS_MODE_CFGPHASE 0x2 +#define FPGAMGRREGS_MODE_INITPHASE 0x3 +#define FPGAMGRREGS_MODE_USERMODE 0x4 +#define FPGAMGRREGS_MODE_UNKNOWN 0x5 + +#ifndef __ASSEMBLY__
struct socfpga_fpga_manager { /* FPGA Manager Module */ @@ -39,39 +63,6 @@ struct socfpga_fpga_manager { u32 gpio_config_reg1; };
-#define FPGAMGRREGS_STAT_MODE_MASK 0x7 -#define FPGAMGRREGS_STAT_MSEL_MASK 0xf8 -#define FPGAMGRREGS_STAT_MSEL_LSB 3 - -#define FPGAMGRREGS_CTRL_CFGWDTH_MASK 0x200 -#define FPGAMGRREGS_CTRL_AXICFGEN_MASK 0x100 -#define FPGAMGRREGS_CTRL_NCONFIGPULL_MASK 0x4 -#define FPGAMGRREGS_CTRL_NCE_MASK 0x2 -#define FPGAMGRREGS_CTRL_EN_MASK 0x1 -#define FPGAMGRREGS_CTRL_CDRATIO_LSB 6 - -#define FPGAMGRREGS_MON_GPIO_EXT_PORTA_CRC_MASK 0x8 -#define FPGAMGRREGS_MON_GPIO_EXT_PORTA_ID_MASK 0x4 -#define FPGAMGRREGS_MON_GPIO_EXT_PORTA_CD_MASK 0x2 -#define FPGAMGRREGS_MON_GPIO_EXT_PORTA_NS_MASK 0x1 - -/* FPGA Mode */ -#define FPGAMGRREGS_MODE_FPGAOFF 0x0 -#define FPGAMGRREGS_MODE_RESETPHASE 0x1 -#define FPGAMGRREGS_MODE_CFGPHASE 0x2 -#define FPGAMGRREGS_MODE_INITPHASE 0x3 -#define FPGAMGRREGS_MODE_USERMODE 0x4 -#define FPGAMGRREGS_MODE_UNKNOWN 0x5 - -/* FPGA CD Ratio Value */ -#define CDRATIO_x1 0x0 -#define CDRATIO_x2 0x1 -#define CDRATIO_x4 0x2 -#define CDRATIO_x8 0x3 - -/* SoCFPGA support functions */ -int fpgamgr_test_fpga_ready(void); -int fpgamgr_poll_fpga_ready(void); -int fpgamgr_get_mode(void); +#endif /* __ASSEMBLY__ */
-#endif /* _FPGA_MANAGER_H_ */ +#endif /* _FPGA_MANAGER_GEN5_H_ */ diff --git a/drivers/Makefile b/drivers/Makefile index 4a4b237..b4a2230 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -47,6 +47,7 @@ obj-$(CONFIG_OMAP_USB_PHY) += usb/phy/ obj-$(CONFIG_SPL_SATA_SUPPORT) += block/ obj-$(CONFIG_SPL_USB_HOST_SUPPORT) += block/ obj-$(CONFIG_SPL_MMC_SUPPORT) += block/ +obj-$(CONFIG_FPGA) += fpga/ endif
ifdef CONFIG_TPL_BUILD diff --git a/drivers/fpga/Makefile b/drivers/fpga/Makefile index 84e7605..649b6d1 100644 --- a/drivers/fpga/Makefile +++ b/drivers/fpga/Makefile @@ -19,4 +19,5 @@ obj-$(CONFIG_FPGA_ACEX1K) += ACEX1K.o obj-$(CONFIG_FPGA_CYCLON2) += cyclon2.o obj-$(CONFIG_FPGA_STRATIX_II) += stratixII.o obj-$(CONFIG_FPGA_STRATIX_V) += stratixv.o +obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += socfpga_gen5.o endif diff --git a/drivers/fpga/socfpga.c b/drivers/fpga/socfpga.c index f1b2f2c..30ebee8 100644 --- a/drivers/fpga/socfpga.c +++ b/drivers/fpga/socfpga.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2012 Altera Corporation <www.altera.com> + * Copyright (C) 2012-2017 Altera Corporation <www.altera.com> * All rights reserved. * * SPDX-License-Identifier: BSD-3-Clause @@ -14,23 +14,10 @@
DECLARE_GLOBAL_DATA_PTR;
-/* Timeout count */ -#define FPGA_TIMEOUT_CNT 0x1000000 - static struct socfpga_fpga_manager *fpgamgr_regs = (struct socfpga_fpga_manager *)SOCFPGA_FPGAMGRREGS_ADDRESS; -static struct socfpga_system_manager *sysmgr_regs = - (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS; - -/* Set CD ratio */ -static void fpgamgr_set_cd_ratio(unsigned long ratio) -{ - clrsetbits_le32(&fpgamgr_regs->ctrl, - 0x3 << FPGAMGRREGS_CTRL_CDRATIO_LSB, - (ratio & 0x3) << FPGAMGRREGS_CTRL_CDRATIO_LSB); -}
-static int fpgamgr_dclkcnt_set(unsigned long cnt) +int fpgamgr_dclkcnt_set(unsigned long cnt) { unsigned long i;
@@ -52,253 +39,3 @@ static int fpgamgr_dclkcnt_set(unsigned long cnt)
return -ETIMEDOUT; } - -/* Start the FPGA programming by initialize the FPGA Manager */ -static int fpgamgr_program_init(void) -{ - unsigned long msel, i; - - /* Get the MSEL value */ - msel = readl(&fpgamgr_regs->stat); - msel &= FPGAMGRREGS_STAT_MSEL_MASK; - msel >>= FPGAMGRREGS_STAT_MSEL_LSB; - - /* - * Set the cfg width - * If MSEL[3] = 1, cfg width = 32 bit - */ - if (msel & 0x8) { - setbits_le32(&fpgamgr_regs->ctrl, - FPGAMGRREGS_CTRL_CFGWDTH_MASK); - - /* To determine the CD ratio */ - /* MSEL[1:0] = 0, CD Ratio = 1 */ - if ((msel & 0x3) == 0x0) - fpgamgr_set_cd_ratio(CDRATIO_x1); - /* MSEL[1:0] = 1, CD Ratio = 4 */ - else if ((msel & 0x3) == 0x1) - fpgamgr_set_cd_ratio(CDRATIO_x4); - /* MSEL[1:0] = 2, CD Ratio = 8 */ - else if ((msel & 0x3) == 0x2) - fpgamgr_set_cd_ratio(CDRATIO_x8); - - } else { /* MSEL[3] = 0 */ - clrbits_le32(&fpgamgr_regs->ctrl, - FPGAMGRREGS_CTRL_CFGWDTH_MASK); - - /* To determine the CD ratio */ - /* MSEL[1:0] = 0, CD Ratio = 1 */ - if ((msel & 0x3) == 0x0) - fpgamgr_set_cd_ratio(CDRATIO_x1); - /* MSEL[1:0] = 1, CD Ratio = 2 */ - else if ((msel & 0x3) == 0x1) - fpgamgr_set_cd_ratio(CDRATIO_x2); - /* MSEL[1:0] = 2, CD Ratio = 4 */ - else if ((msel & 0x3) == 0x2) - fpgamgr_set_cd_ratio(CDRATIO_x4); - } - - /* To enable FPGA Manager configuration */ - clrbits_le32(&fpgamgr_regs->ctrl, FPGAMGRREGS_CTRL_NCE_MASK); - - /* To enable FPGA Manager drive over configuration line */ - setbits_le32(&fpgamgr_regs->ctrl, FPGAMGRREGS_CTRL_EN_MASK); - - /* Put FPGA into reset phase */ - setbits_le32(&fpgamgr_regs->ctrl, FPGAMGRREGS_CTRL_NCONFIGPULL_MASK); - - /* (1) wait until FPGA enter reset phase */ - for (i = 0; i < FPGA_TIMEOUT_CNT; i++) { - if (fpgamgr_get_mode() == FPGAMGRREGS_MODE_RESETPHASE) - break; - } - - /* If not in reset state, return error */ - if (fpgamgr_get_mode() != FPGAMGRREGS_MODE_RESETPHASE) { - puts("FPGA: Could not reset\n"); - return -1; - } - - /* Release FPGA from reset phase */ - clrbits_le32(&fpgamgr_regs->ctrl, FPGAMGRREGS_CTRL_NCONFIGPULL_MASK); - - /* (2) wait until FPGA enter configuration phase */ - for (i = 0; i < FPGA_TIMEOUT_CNT; i++) { - if (fpgamgr_get_mode() == FPGAMGRREGS_MODE_CFGPHASE) - break; - } - - /* If not in configuration state, return error */ - if (fpgamgr_get_mode() != FPGAMGRREGS_MODE_CFGPHASE) { - puts("FPGA: Could not configure\n"); - return -2; - } - - /* Clear all interrupts in CB Monitor */ - writel(0xFFF, &fpgamgr_regs->gpio_porta_eoi); - - /* Enable AXI configuration */ - setbits_le32(&fpgamgr_regs->ctrl, FPGAMGRREGS_CTRL_AXICFGEN_MASK); - - return 0; -} - -/* Write the RBF data to FPGA Manager */ -static void fpgamgr_program_write(const void *rbf_data, unsigned long rbf_size) -{ - uint32_t src = (uint32_t)rbf_data; - uint32_t dst = SOCFPGA_FPGAMGRDATA_ADDRESS; - - /* Number of loops for 32-byte long copying. */ - uint32_t loops32 = rbf_size / 32; - /* Number of loops for 4-byte long copying + trailing bytes */ - uint32_t loops4 = DIV_ROUND_UP(rbf_size % 32, 4); - - asm volatile( - "1: ldmia %0!, {r0-r7}\n" - " stmia %1!, {r0-r7}\n" - " sub %1, #32\n" - " subs %2, #1\n" - " bne 1b\n" - " cmp %3, #0\n" - " beq 3f\n" - "2: ldr %2, [%0], #4\n" - " str %2, [%1]\n" - " subs %3, #1\n" - " bne 2b\n" - "3: nop\n" - : "+r"(src), "+r"(dst), "+r"(loops32), "+r"(loops4) : - : "r0", "r1", "r2", "r3", "r4", "r5", "r6", "r7", "cc"); -} - -/* Ensure the FPGA entering config done */ -static int fpgamgr_program_poll_cd(void) -{ - const uint32_t mask = FPGAMGRREGS_MON_GPIO_EXT_PORTA_NS_MASK | - FPGAMGRREGS_MON_GPIO_EXT_PORTA_CD_MASK; - unsigned long reg, i; - - /* (3) wait until full config done */ - for (i = 0; i < FPGA_TIMEOUT_CNT; i++) { - reg = readl(&fpgamgr_regs->gpio_ext_porta); - - /* Config error */ - if (!(reg & mask)) { - printf("FPGA: Configuration error.\n"); - return -3; - } - - /* Config done without error */ - if (reg & mask) - break; - } - - /* Timeout happened, return error */ - if (i == FPGA_TIMEOUT_CNT) { - printf("FPGA: Timeout waiting for program.\n"); - return -4; - } - - /* Disable AXI configuration */ - clrbits_le32(&fpgamgr_regs->ctrl, FPGAMGRREGS_CTRL_AXICFGEN_MASK); - - return 0; -} - -/* Ensure the FPGA entering init phase */ -static int fpgamgr_program_poll_initphase(void) -{ - unsigned long i; - - /* Additional clocks for the CB to enter initialization phase */ - if (fpgamgr_dclkcnt_set(0x4)) - return -5; - - /* (4) wait until FPGA enter init phase or user mode */ - for (i = 0; i < FPGA_TIMEOUT_CNT; i++) { - if (fpgamgr_get_mode() == FPGAMGRREGS_MODE_INITPHASE) - break; - if (fpgamgr_get_mode() == FPGAMGRREGS_MODE_USERMODE) - break; - } - - /* If not in configuration state, return error */ - if (i == FPGA_TIMEOUT_CNT) - return -6; - - return 0; -} - -/* Ensure the FPGA entering user mode */ -static int fpgamgr_program_poll_usermode(void) -{ - unsigned long i; - - /* Additional clocks for the CB to exit initialization phase */ - if (fpgamgr_dclkcnt_set(0x5000)) - return -7; - - /* (5) wait until FPGA enter user mode */ - for (i = 0; i < FPGA_TIMEOUT_CNT; i++) { - if (fpgamgr_get_mode() == FPGAMGRREGS_MODE_USERMODE) - break; - } - /* If not in configuration state, return error */ - if (i == FPGA_TIMEOUT_CNT) - return -8; - - /* To release FPGA Manager drive over configuration line */ - clrbits_le32(&fpgamgr_regs->ctrl, FPGAMGRREGS_CTRL_EN_MASK); - - return 0; -} - -/* - * FPGA Manager to program the FPGA. This is the interface used by FPGA driver. - * Return 0 for sucess, non-zero for error. - */ -int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size) -{ - unsigned long status; - - if ((uint32_t)rbf_data & 0x3) { - puts("FPGA: Unaligned data, realign to 32bit boundary.\n"); - return -EINVAL; - } - - /* Prior programming the FPGA, all bridges need to be shut off */ - - /* Disable all signals from hps peripheral controller to fpga */ - writel(0, &sysmgr_regs->fpgaintfgrp_module); - - /* Disable all signals from FPGA to HPS SDRAM */ -#define SDR_CTRLGRP_FPGAPORTRST_ADDRESS 0x5080 - writel(0, SOCFPGA_SDR_ADDRESS + SDR_CTRLGRP_FPGAPORTRST_ADDRESS); - - /* Disable all axi bridge (hps2fpga, lwhps2fpga & fpga2hps) */ - socfpga_bridges_reset(1); - - /* Unmap the bridges from NIC-301 */ - writel(0x1, SOCFPGA_L3REGS_ADDRESS); - - /* Initialize the FPGA Manager */ - status = fpgamgr_program_init(); - if (status) - return status; - - /* Write the RBF data to FPGA Manager */ - fpgamgr_program_write(rbf_data, rbf_size); - - /* Ensure the FPGA entering config done */ - status = fpgamgr_program_poll_cd(); - if (status) - return status; - - /* Ensure the FPGA entering init phase */ - status = fpgamgr_program_poll_initphase(); - if (status) - return status; - - /* Ensure the FPGA entering user mode */ - return fpgamgr_program_poll_usermode(); -} diff --git a/drivers/fpga/socfpga.c b/drivers/fpga/socfpga_gen5.c similarity index 92% copy from drivers/fpga/socfpga.c copy to drivers/fpga/socfpga_gen5.c index f1b2f2c..6992d83 100644 --- a/drivers/fpga/socfpga.c +++ b/drivers/fpga/socfpga_gen5.c @@ -1,5 +1,5 @@ /* - * Copyright (C) 2012 Altera Corporation <www.altera.com> + * Copyright (C) 2012-2017 Altera Corporation <www.altera.com> * All rights reserved. * * SPDX-License-Identifier: BSD-3-Clause @@ -14,9 +14,6 @@
-/* Timeout count */ -#define FPGA_TIMEOUT_CNT 0x1000000 - static struct socfpga_fpga_manager *fpgamgr_regs = (struct socfpga_fpga_manager *)SOCFPGA_FPGAMGRREGS_ADDRESS; static struct socfpga_system_manager *sysmgr_regs = @@ -30,29 +27,6 @@ static void fpgamgr_set_cd_ratio(unsigned long ratio) (ratio & 0x3) << FPGAMGRREGS_CTRL_CDRATIO_LSB); }
-static int fpgamgr_dclkcnt_set(unsigned long cnt) -{ - unsigned long i; - - /* Clear any existing done status */ - if (readl(&fpgamgr_regs->dclkstat)) - writel(0x1, &fpgamgr_regs->dclkstat); - - /* Write the dclkcnt */ - writel(cnt, &fpgamgr_regs->dclkcnt); - - /* Wait till the dclkcnt done */ - for (i = 0; i < FPGA_TIMEOUT_CNT; i++) { - if (!readl(&fpgamgr_regs->dclkstat)) - continue; - - writel(0x1, &fpgamgr_regs->dclkstat); - return 0; - } - - return -ETIMEDOUT; -} - /* Start the FPGA programming by initialize the FPGA Manager */ static int fpgamgr_program_init(void) { @@ -267,7 +241,6 @@ int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size) }
/* Prior programming the FPGA, all bridges need to be shut off */ - /* Disable all signals from hps peripheral controller to fpga */ writel(0, &sysmgr_regs->fpgaintfgrp_module);
It's a driver, so it should stay in drivers/ . If you need to split it, split it in drivers/fpga/ and add Kconfig option(s)
- Copyright (C) 2012 Altera Corporation <www.altera.com>
- Copyright (C) 2012-2017 Altera Corporation <www.altera.com>
- All rights reserved.
- SPDX-License-Identifier: BSD-3-Clause
@@ -10,58 +10,9 @@
#include <altera.h>
- u32 ctrl;
- u32 dclkcnt;
- u32 dclkstat;
- u32 gpi;
- u32 gpio_intmask;
- u32 _pad_0x848;
@@ -14,23 +14,10 @@
* Set the cfg width
- if (msel & 0x8) {
break;
return -1;
break;
return -2;
- asm volatile(
" sub %1, #32\n"
" subs %2, #1\n"
" bne 1b\n"
" cmp %3, #0\n"
" beq 3f\n"
" str %2, [%1]\n"
" subs %3, #1\n"
" bne 2b\n"
"3: nop\n"
/* Config error */
return -3;
if (reg & mask)
break;
return -4;
- unsigned long i;
return -5;
break;
break;
return -6;
- unsigned long i;
return -7;
break;
return -8;
- FPGA Manager to program the FPGA. This is the interface used by FPGA driver.
- Return 0 for sucess, non-zero for error.
return -EINVAL;
- if (status)
return status;
- if (status)
return status;
- if (status)
return status;
@@ -14,9 +14,6 @@
- unsigned long i;
continue;
I am confused here, all the FPGA drivers which i split into common and platform specific are still in the drivers/fpga/. Could you explain more? Thanks.
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach- socfpga/Makefile index 41b779c..286bfef 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -9,7 +9,6 @@ obj-y += board.o obj-y += clock_manager.o -obj-y += fpga_manager.o obj-y += misc.o obj-y += reset_manager.o obj-y += timer.o @@ -21,6 +20,7 @@ obj-y += reset_manager_gen5.o obj-y += scan_manager.o obj-y += system_manager_gen5.o obj-y += wrap_pll_config.o +obj-y += fpga_manager.o endif ifdef CONFIG_TARGET_SOCFPGA_ARRIA10 diff --git a/arch/arm/mach-socfpga/include/mach/fpga_manager.h b/arch/arm/mach-socfpga/include/mach/fpga_manager.h index a077e22..69d8613 100644 --- a/arch/arm/mach-socfpga/include/mach/fpga_manager.h +++ b/arch/arm/mach-socfpga/include/mach/fpga_manager.h @@ -1,5 +1,5 @@ /*
* All rights reserved. * * SPDX-License-Identifier: BSD-3-Clause @@ -10,58 +10,9 @@ #include <altera.h> -struct socfpga_fpga_manager {
- u32 ctrl;
- u32 dclkcnt;
- u32 dclkstat;
- u32 gpi;
- u32 gpio_intmask;
- u32 _pad_0x848;
-/* FPGA Mode */ -#define FPGAMGRREGS_MODE_FPGAOFF 0x0 -#define FPGAMGRREGS_MODE_RESETPHASE 0x1 -#define FPGAMGRREGS_MODE_CFGPHASE 0x2 -#define FPGAMGRREGS_MODE_INITPHASE 0x3 -#define FPGAMGRREGS_MODE_USERMODE 0x4 -#define FPGAMGRREGS_MODE_UNKNOWN 0x5 +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +#include <asm/arch/fpga_manager_gen5.h> +#endif /* FPGA CD Ratio Value */ #define CDRATIO_x1 0x0 @@ -74,4 +25,12 @@ int fpgamgr_test_fpga_ready(void); int fpgamgr_poll_fpga_ready(void); int fpgamgr_get_mode(void); +#define FPGA_TIMEOUT_CNT 0x1000000
* All rights reserved. * * SPDX-License-Identifier: BSD-3-Clause */ -#ifndef _FPGA_MANAGER_H_ -#define _FPGA_MANAGER_H_ +#ifndef _FPGA_MANAGER_GEN5_H_ +#define _FPGA_MANAGER_GEN5_H_ -#include <altera.h> +#define FPGAMGRREGS_STAT_MODE_MASK 0x7 +#define FPGAMGRREGS_STAT_MSEL_MASK 0xf8 +#define FPGAMGRREGS_STAT_MSEL_LSB 3
+#ifndef __ASSEMBLY__ struct socfpga_fpga_manager { /* FPGA Manager Module */ @@ -39,39 +63,6 @@ struct socfpga_fpga_manager { u32 gpio_config_reg1; }; -#define FPGAMGRREGS_STAT_MODE_MASK 0x7 -#define FPGAMGRREGS_STAT_MSEL_MASK 0xf8 -#define FPGAMGRREGS_STAT_MSEL_LSB 3
-/* SoCFPGA support functions */ -int fpgamgr_test_fpga_ready(void); -int fpgamgr_poll_fpga_ready(void); -int fpgamgr_get_mode(void); +#endif /* __ASSEMBLY__ */ -#endif /* _FPGA_MANAGER_H_ */ +#endif /* _FPGA_MANAGER_GEN5_H_ */ diff --git a/drivers/Makefile b/drivers/Makefile index 4a4b237..b4a2230 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -47,6 +47,7 @@ obj-$(CONFIG_OMAP_USB_PHY) += usb/phy/ obj-$(CONFIG_SPL_SATA_SUPPORT) += block/ obj-$(CONFIG_SPL_USB_HOST_SUPPORT) += block/ obj-$(CONFIG_SPL_MMC_SUPPORT) += block/ +obj-$(CONFIG_FPGA) += fpga/ endif ifdef CONFIG_TPL_BUILD diff --git a/drivers/fpga/Makefile b/drivers/fpga/Makefile index 84e7605..649b6d1 100644 --- a/drivers/fpga/Makefile +++ b/drivers/fpga/Makefile @@ -19,4 +19,5 @@ obj-$(CONFIG_FPGA_ACEX1K) += ACEX1K.o obj-$(CONFIG_FPGA_CYCLON2) += cyclon2.o obj-$(CONFIG_FPGA_STRATIX_II) += stratixII.o obj-$(CONFIG_FPGA_STRATIX_V) += stratixv.o +obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += socfpga_gen5.o endif diff --git a/drivers/fpga/socfpga.c b/drivers/fpga/socfpga.c index f1b2f2c..30ebee8 100644 --- a/drivers/fpga/socfpga.c +++ b/drivers/fpga/socfpga.c @@ -1,5 +1,5 @@ /*
* All rights reserved. * * SPDX-License-Identifier: BSD-3-Clause @@ -14,23 +14,10 @@ DECLARE_GLOBAL_DATA_PTR; -/* Timeout count */ -#define FPGA_TIMEOUT_CNT 0x1000000
(ratio & 0x3) <<
FPGAMGRREGS_CTRL_CDRATIO_LSB); -} -static int fpgamgr_dclkcnt_set(unsigned long cnt) +int fpgamgr_dclkcnt_set(unsigned long cnt) { unsigned long i; @@ -52,253 +39,3 @@ static int fpgamgr_dclkcnt_set(unsigned long cnt) return -ETIMEDOUT; }
- if (msel & 0x8) {
break;
return -1;
break;
return -2;
bytes */
- asm volatile(
" sub %1, #32\n"
" subs %2, #1\n"
" bne 1b\n"
" cmp %3, #0\n"
" beq 3f\n"
" str %2, [%1]\n"
" subs %3, #1\n"
" bne 2b\n"
"3: nop\n"
"+r"(loops4) :
"cc"); -}
SK;
/* Config error */
return -3;
if (reg & mask)
break;
return -4;
- unsigned long i;
phase */
return -5;
break;
break;
return -6;
- unsigned long i;
phase */
return -7;
break;
return -8;
FPGA driver.
boundary.\n");
return -EINVAL;
off */
fpga */
fpga2hps) */
- if (status)
return status;
- if (status)
return status;
- if (status)
return status;
* All rights reserved. * * SPDX-License-Identifier: BSD-3-Clause @@ -14,9 +14,6 @@ DECLARE_GLOBAL_DATA_PTR; -/* Timeout count */ -#define FPGA_TIMEOUT_CNT 0x1000000
static struct socfpga_fpga_manager *fpgamgr_regs = (struct socfpga_fpga_manager *)SOCFPGA_FPGAMGRREGS_ADDRESS; static struct socfpga_system_manager *sysmgr_regs = @@ -30,29 +27,6 @@ static void fpgamgr_set_cd_ratio(unsigned long ratio) (ratio & 0x3) << FPGAMGRREGS_CTRL_CDRATIO_LSB); } -static int fpgamgr_dclkcnt_set(unsigned long cnt) -{
- unsigned long i;
continue;
/* Start the FPGA programming by initialize the FPGA Manager */ static int fpgamgr_program_init(void) { @@ -267,7 +241,6 @@ int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size) } /* Prior programming the FPGA, all bridges need to be shut off */
The driver code should be in drivers/fpga/ , so unless there's a good reason, don't move any of it into arch/arm/
@@ -10,58 +10,9 @@
#include <altera.h>
- u32 ctrl;
- u32 dclkcnt;
- u32 dclkstat;
- u32 gpi;
- u32 gpio_intmask;
- u32 _pad_0x848;
@@ -14,23 +14,10 @@
(ratio & 0x3) <<
* Set the cfg width
- if (msel & 0x8) {
break;
return -1;
break;
return -2;
bytes */
- asm volatile(
" sub %1, #32\n"
" subs %2, #1\n"
" bne 1b\n"
" cmp %3, #0\n"
" beq 3f\n"
" str %2, [%1]\n"
" subs %3, #1\n"
" bne 2b\n"
"3: nop\n"
"+r"(loops4) :
"cc"); -}
SK;
/* Config error */
return -3;
if (reg & mask)
break;
return -4;
- unsigned long i;
phase */
return -5;
break;
break;
return -6;
- unsigned long i;
phase */
return -7;
break;
return -8;
FPGA driver.
boundary.\n");
return -EINVAL;
off */
fpga */
fpga2hps) */
- if (status)
return status;
- if (status)
return status;
- if (status)
return status;
@@ -14,9 +14,6 @@
- unsigned long i;
continue;
Yeah, i agree with you. Hence, the patch 3, patch 4 and patch 5 are for moving all fpga drivers into drivers/fpga/, and header files into include/intel_socfpga/ .
- u32 ctrl;
- u32 dclkcnt;
- u32 dclkstat;
- u32 gpi;
- u32 gpio_intmask;
- u32 _pad_0x848;
(ratio & 0x3) <<
- if (msel & 0x8) {
line */
break;
return -1;
break;
return -2;
bytes */
- asm volatile(
" sub %1, #32\n"
" subs %2, #1\n"
" bne 1b\n"
" cmp %3, #0\n"
" beq 3f\n"
"2: ldr %2, [%0],
#4\n "
" str %2, [%1]\n"
" subs %3, #1\n"
" bne 2b\n"
"3: nop\n"
"+r"(loops4) :
"r7", "cc"); -}
D_MA SK;
/* Config error */
error.\n");
return -3;
if (reg & mask)
break;
program.\n");
return -4;
- unsigned long i;
return -5;
break;
break;
return -6;
- unsigned long i;
phase */
return -7;
break;
return -8;
line */
boundary.\n");
return -EINVAL;
shut off */
to fpga */
fpga2hps) */
- if (status)
return status;
- if (status)
return status;
- if (status)
return status;
- unsigned long i;
continue;
Move FPGA manager driver which is Gen5 specific code into FPGA driver. No functional change.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/Makefile | 1 - arch/arm/mach-socfpga/fpga_manager.c | 78 ---------------------------------- drivers/fpga/socfpga_gen5.c | 54 +++++++++++++++++++++++ 3 files changed, 54 insertions(+), 79 deletions(-) delete mode 100644 arch/arm/mach-socfpga/fpga_manager.c
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 286bfef..824cd8e 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -20,7 +20,6 @@ obj-y += reset_manager_gen5.o obj-y += scan_manager.o obj-y += system_manager_gen5.o obj-y += wrap_pll_config.o -obj-y += fpga_manager.o endif
ifdef CONFIG_TARGET_SOCFPGA_ARRIA10 diff --git a/arch/arm/mach-socfpga/fpga_manager.c b/arch/arm/mach-socfpga/fpga_manager.c deleted file mode 100644 index f909573..0000000 --- a/arch/arm/mach-socfpga/fpga_manager.c +++ /dev/null @@ -1,78 +0,0 @@ -/* - * Copyright (C) 2012 Altera Corporation <www.altera.com> - * All rights reserved. - * - * This file contains only support functions used also by the SoCFPGA - * platform code, the real meat is located in drivers/fpga/socfpga.c . - * - * SPDX-License-Identifier: BSD-3-Clause - */ - -#include <common.h> -#include <asm/io.h> -#include <linux/errno.h> -#include <asm/arch/fpga_manager.h> -#include <asm/arch/reset_manager.h> -#include <asm/arch/system_manager.h> - -DECLARE_GLOBAL_DATA_PTR; - -/* Timeout count */ -#define FPGA_TIMEOUT_CNT 0x1000000 - -static struct socfpga_fpga_manager *fpgamgr_regs = - (struct socfpga_fpga_manager *)SOCFPGA_FPGAMGRREGS_ADDRESS; - -/* Check whether FPGA Init_Done signal is high */ -static int is_fpgamgr_initdone_high(void) -{ - unsigned long val; - - val = readl(&fpgamgr_regs->gpio_ext_porta); - return val & FPGAMGRREGS_MON_GPIO_EXT_PORTA_ID_MASK; -} - -/* Get the FPGA mode */ -int fpgamgr_get_mode(void) -{ - unsigned long val; - - val = readl(&fpgamgr_regs->stat); - return val & FPGAMGRREGS_STAT_MODE_MASK; -} - -/* Check whether FPGA is ready to be accessed */ -int fpgamgr_test_fpga_ready(void) -{ - /* Check for init done signal */ - if (!is_fpgamgr_initdone_high()) - return 0; - - /* Check again to avoid false glitches */ - if (!is_fpgamgr_initdone_high()) - return 0; - - if (fpgamgr_get_mode() != FPGAMGRREGS_MODE_USERMODE) - return 0; - - return 1; -} - -/* Poll until FPGA is ready to be accessed or timeout occurred */ -int fpgamgr_poll_fpga_ready(void) -{ - unsigned long i; - - /* If FPGA is blank, wait till WD invoke warm reset */ - for (i = 0; i < FPGA_TIMEOUT_CNT; i++) { - /* check for init done signal */ - if (!is_fpgamgr_initdone_high()) - continue; - /* check again to avoid false glitches */ - if (!is_fpgamgr_initdone_high()) - continue; - return 1; - } - - return 0; -} diff --git a/drivers/fpga/socfpga_gen5.c b/drivers/fpga/socfpga_gen5.c index 6992d83..892a8e4 100644 --- a/drivers/fpga/socfpga_gen5.c +++ b/drivers/fpga/socfpga_gen5.c @@ -19,6 +19,60 @@ static struct socfpga_fpga_manager *fpgamgr_regs = static struct socfpga_system_manager *sysmgr_regs = (struct socfpga_system_manager *)SOCFPGA_SYSMGR_ADDRESS;
+/* Check whether FPGA Init_Done signal is high */ +static int is_fpgamgr_initdone_high(void) +{ + unsigned long val; + + val = readl(&fpgamgr_regs->gpio_ext_porta); + return val & FPGAMGRREGS_MON_GPIO_EXT_PORTA_ID_MASK; +} + +/* Get the FPGA mode */ +int fpgamgr_get_mode(void) +{ + unsigned long val; + + val = readl(&fpgamgr_regs->stat); + return val & FPGAMGRREGS_STAT_MODE_MASK; +} + +/* Check whether FPGA is ready to be accessed */ +int fpgamgr_test_fpga_ready(void) +{ + /* Check for init done signal */ + if (!is_fpgamgr_initdone_high()) + return 0; + + /* Check again to avoid false glitches */ + if (!is_fpgamgr_initdone_high()) + return 0; + + if (fpgamgr_get_mode() != FPGAMGRREGS_MODE_USERMODE) + return 0; + + return 1; +} + +/* Poll until FPGA is ready to be accessed or timeout occurred */ +int fpgamgr_poll_fpga_ready(void) +{ + unsigned long i; + + /* If FPGA is blank, wait till WD invoke warm reset */ + for (i = 0; i < FPGA_TIMEOUT_CNT; i++) { + /* check for init done signal */ + if (!is_fpgamgr_initdone_high()) + continue; + /* check again to avoid false glitches */ + if (!is_fpgamgr_initdone_high()) + continue; + return 1; + } + + return 0; +} + /* Set CD ratio */ static void fpgamgr_set_cd_ratio(unsigned long ratio) {
Move FPGA driver header to include directory which would be shared between arch platform drivers and FPGA drivers.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/reset_manager_arria10.c | 2 +- arch/arm/mach-socfpga/reset_manager_gen5.c | 5 +- arch/arm/mach-socfpga/system_manager_gen5.c | 2 +- drivers/ddr/altera/sdram.c | 7 ++- drivers/fpga/socfpga.c | 2 +- drivers/fpga/socfpga_gen5.c | 2 +- include/intel_socfpga/fpga_manager.h | 36 +++++++++++++ include/intel_socfpga/fpga_manager_gen5.h | 68 +++++++++++++++++++++++++ 8 files changed, 115 insertions(+), 9 deletions(-) create mode 100644 include/intel_socfpga/fpga_manager.h create mode 100644 include/intel_socfpga/fpga_manager_gen5.h
diff --git a/arch/arm/mach-socfpga/reset_manager_arria10.c b/arch/arm/mach-socfpga/reset_manager_arria10.c index 66f1ec2..bfc375e 100644 --- a/arch/arm/mach-socfpga/reset_manager_arria10.c +++ b/arch/arm/mach-socfpga/reset_manager_arria10.c @@ -5,13 +5,13 @@ */
#include <asm/io.h> -#include <asm/arch/fpga_manager.h> #include <asm/arch/misc.h> #include <asm/arch/reset_manager.h> #include <asm/arch/system_manager.h> #include <common.h> #include <errno.h> #include <fdtdec.h> +#include <intel_socfpga/fpga_manager.h> #include <wait_bit.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/arch/arm/mach-socfpga/reset_manager_gen5.c b/arch/arm/mach-socfpga/reset_manager_gen5.c index aa88adb..3d76913 100644 --- a/arch/arm/mach-socfpga/reset_manager_gen5.c +++ b/arch/arm/mach-socfpga/reset_manager_gen5.c @@ -1,13 +1,12 @@ /* - * Copyright (C) 2013 Altera Corporation <www.altera.com> + * Copyright (C) 2013-2017 Altera Corporation <www.altera.com> * * SPDX-License-Identifier: GPL-2.0+ */
- #include <common.h> #include <asm/io.h> -#include <asm/arch/fpga_manager.h> +#include <intel_socfpga/fpga_manager.h> #include <asm/arch/reset_manager.h> #include <asm/arch/system_manager.h>
diff --git a/arch/arm/mach-socfpga/system_manager_gen5.c b/arch/arm/mach-socfpga/system_manager_gen5.c index 3588a57..a32250b 100644 --- a/arch/arm/mach-socfpga/system_manager_gen5.c +++ b/arch/arm/mach-socfpga/system_manager_gen5.c @@ -7,7 +7,7 @@ #include <common.h> #include <asm/io.h> #include <asm/arch/system_manager.h> -#include <asm/arch/fpga_manager.h> +#include <intel_socfpga/fpga_manager.h>
diff --git a/drivers/ddr/altera/sdram.c b/drivers/ddr/altera/sdram.c index e74c5b0..22dba3c 100644 --- a/drivers/ddr/altera/sdram.c +++ b/drivers/ddr/altera/sdram.c @@ -1,17 +1,20 @@ /* - * Copyright Altera Corporation (C) 2014-2015 + * Copyright Altera Corporation (C) 2014-2017 * * SPDX-License-Identifier: GPL-2.0+ */ + #include <common.h> #include <errno.h> #include <div64.h> #include <watchdog.h> -#include <asm/arch/fpga_manager.h> +#include <intel_socfpga/fpga_manager.h> #include <asm/arch/sdram.h> #include <asm/arch/system_manager.h> #include <asm/io.h>
+ + DECLARE_GLOBAL_DATA_PTR;
struct sdram_prot_rule { diff --git a/drivers/fpga/socfpga.c b/drivers/fpga/socfpga.c index 30ebee8..c37e7cf 100644 --- a/drivers/fpga/socfpga.c +++ b/drivers/fpga/socfpga.c @@ -8,7 +8,7 @@ #include <common.h> #include <asm/io.h> #include <linux/errno.h> -#include <asm/arch/fpga_manager.h> +#include <intel_socfpga/fpga_manager.h> #include <asm/arch/reset_manager.h> #include <asm/arch/system_manager.h>
diff --git a/drivers/fpga/socfpga_gen5.c b/drivers/fpga/socfpga_gen5.c index 892a8e4..3348475 100644 --- a/drivers/fpga/socfpga_gen5.c +++ b/drivers/fpga/socfpga_gen5.c @@ -8,7 +8,7 @@ #include <common.h> #include <asm/io.h> #include <linux/errno.h> -#include <asm/arch/fpga_manager.h> +#include <intel_socfpga/fpga_manager.h> #include <asm/arch/reset_manager.h> #include <asm/arch/system_manager.h>
diff --git a/include/intel_socfpga/fpga_manager.h b/include/intel_socfpga/fpga_manager.h new file mode 100644 index 0000000..8dbf369 --- /dev/null +++ b/include/intel_socfpga/fpga_manager.h @@ -0,0 +1,36 @@ +/* + * Copyright (C) 2012-2017 Altera Corporation <www.altera.com> + * All rights reserved. + * + * SPDX-License-Identifier: BSD-3-Clause + */ + +#ifndef _FPGA_MANAGER_H_ +#define _FPGA_MANAGER_H_ + +#include <altera.h> + +#if defined(CONFIG_TARGET_SOCFPGA_GEN5) +#include <intel_socfpga/fpga_manager_gen5.h> +#endif + +/* FPGA CD Ratio Value */ +#define CDRATIO_x1 0x0 +#define CDRATIO_x2 0x1 +#define CDRATIO_x4 0x2 +#define CDRATIO_x8 0x3 + +/* SoCFPGA support functions */ +int fpgamgr_test_fpga_ready(void); +int fpgamgr_poll_fpga_ready(void); +int fpgamgr_get_mode(void); + +#define FPGA_TIMEOUT_CNT 0x1000000 + +#ifndef __ASSEMBLY__ + +/* Common prototypes */ +int fpgamgr_dclkcnt_set(unsigned long cnt); + +#endif /* __ASSEMBLY__ */ +#endif /* _FPGA_MANAGER_H_ */ diff --git a/include/intel_socfpga/fpga_manager_gen5.h b/include/intel_socfpga/fpga_manager_gen5.h new file mode 100644 index 0000000..2de7a11 --- /dev/null +++ b/include/intel_socfpga/fpga_manager_gen5.h @@ -0,0 +1,68 @@ +/* + * Copyright (C) 2012-2017 Altera Corporation <www.altera.com> + * All rights reserved. + * + * SPDX-License-Identifier: BSD-3-Clause + */ + +#ifndef _FPGA_MANAGER_GEN5_H_ +#define _FPGA_MANAGER_GEN5_H_ + +#define FPGAMGRREGS_STAT_MODE_MASK 0x7 +#define FPGAMGRREGS_STAT_MSEL_MASK 0xf8 +#define FPGAMGRREGS_STAT_MSEL_LSB 3 + +#define FPGAMGRREGS_CTRL_CFGWDTH_MASK BIT(9) +#define FPGAMGRREGS_CTRL_AXICFGEN_MASK BIT(8) +#define FPGAMGRREGS_CTRL_NCONFIGPULL_MASK BIT(2) +#define FPGAMGRREGS_CTRL_NCE_MASK BIT(1) +#define FPGAMGRREGS_CTRL_EN_MASK BIT(0) +#define FPGAMGRREGS_CTRL_CDRATIO_LSB 6 + +#define FPGAMGRREGS_MON_GPIO_EXT_PORTA_CRC_MASK BIT(3) +#define FPGAMGRREGS_MON_GPIO_EXT_PORTA_ID_MASK BIT(2) +#define FPGAMGRREGS_MON_GPIO_EXT_PORTA_CD_MASK BIT(1) +#define FPGAMGRREGS_MON_GPIO_EXT_PORTA_NS_MASK BIT(0) + +/* FPGA Mode */ +#define FPGAMGRREGS_MODE_FPGAOFF 0x0 +#define FPGAMGRREGS_MODE_RESETPHASE 0x1 +#define FPGAMGRREGS_MODE_CFGPHASE 0x2 +#define FPGAMGRREGS_MODE_INITPHASE 0x3 +#define FPGAMGRREGS_MODE_USERMODE 0x4 +#define FPGAMGRREGS_MODE_UNKNOWN 0x5 + +#ifndef __ASSEMBLY__ + +struct socfpga_fpga_manager { + /* FPGA Manager Module */ + u32 stat; /* 0x00 */ + u32 ctrl; + u32 dclkcnt; + u32 dclkstat; + u32 gpo; /* 0x10 */ + u32 gpi; + u32 misci; /* 0x18 */ + u32 _pad_0x1c_0x82c[517]; + + /* Configuration Monitor (MON) Registers */ + u32 gpio_inten; /* 0x830 */ + u32 gpio_intmask; + u32 gpio_inttype_level; + u32 gpio_int_polarity; + u32 gpio_intstatus; /* 0x840 */ + u32 gpio_raw_intstatus; + u32 _pad_0x848; + u32 gpio_porta_eoi; + u32 gpio_ext_porta; /* 0x850 */ + u32 _pad_0x854_0x85c[3]; + u32 gpio_1s_sync; /* 0x860 */ + u32 _pad_0x864_0x868[2]; + u32 gpio_ver_id_code; + u32 gpio_config_reg2; /* 0x870 */ + u32 gpio_config_reg1; +}; + +#endif /* __ASSEMBLY__ */ + +#endif /* _FPGA_MANAGER_GEN5_H_ */
Adding the Arria10 FPGA manager program assembly driver which can be used to feed bitstream into FPGA manager for configuring FPGA.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- arch/arm/mach-socfpga/Makefile | 1 + arch/arm/mach-socfpga/lowlevel_init.S | 48 +++++++++++++++++++++++++++++++++ 2 files changed, 49 insertions(+), 0 deletions(-) create mode 100644 arch/arm/mach-socfpga/lowlevel_init.S
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach-socfpga/Makefile index 824cd8e..8b86dc7 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -24,6 +24,7 @@ endif
ifdef CONFIG_TARGET_SOCFPGA_ARRIA10 obj-y += clock_manager_arria10.o +obj-y += lowlevel_init.o obj-y += misc_arria10.o obj-y += pinmux_arria10.o obj-y += reset_manager_arria10.o diff --git a/arch/arm/mach-socfpga/lowlevel_init.S b/arch/arm/mach-socfpga/lowlevel_init.S new file mode 100644 index 0000000..79e9d07 --- /dev/null +++ b/arch/arm/mach-socfpga/lowlevel_init.S @@ -0,0 +1,48 @@ +/* + * Copyright (C) 2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <asm-offsets.h> +#include <config.h> +#include <linux/linkage.h> + +/* + * Write RBF data in burst form to FPGA Manager + * [r0] RBF binary source address + * [r1] FPGA Manager data address + * [r2] RBF data length + */ + +ENTRY(fpgamgr_axi_write) + PUSH {r4-r11, lr} /* save registers per AAPCS */ + +write_burst: + cmp r2,#32 + beq write_burst_cont + bls write_word +write_burst_cont: + ldmia r0!, {r4-r11} + stmia r1, {r4-r11} + subs r2, r2, #32 + b write_burst + +write_word: + cmp r2,#4 + beq write_word_cont + bls write_byte +write_word_cont: + ldmia r0!, {r4} + stmia r1, {r4} + subs r2, r2, #4 + b write_word + +write_byte: + cmp r2,#0 + beq write_end + ldr r3, [r0] + str r3, [r1] +write_end: + POP {r4-r11, pc} +ENDPROC(fpgamgr_axi_write)
- Copyright (C) 2017 Intel Corporation <www.intel.com>
- SPDX-License-Identifier: GPL-2.0
- Write RBF data in burst form to FPGA Manager
- [r0] RBF binary source address
- [r1] FPGA Manager data address
- [r2] RBF data length
We do the same for Gen5 in C code with a bit of assembly, so do the same.
- PUSH {r4-r11, lr} /* save registers per AAPCS */
+write_burst:
- cmp r2,#32
- beq write_burst_cont
- bls write_word
+write_burst_cont:
- ldmia r0!, {r4-r11}
- stmia r1, {r4-r11}
- subs r2, r2, #32
- b write_burst
+write_word:
- cmp r2,#4
- beq write_word_cont
- bls write_byte
+write_word_cont:
- ldmia r0!, {r4}
- stmia r1, {r4}
- subs r2, r2, #4
- b write_word
+write_byte:
- cmp r2,#0
- beq write_end
- ldr r3, [r0]
- str r3, [r1]
+write_end:
- POP {r4-r11, pc}
diff --git a/arch/arm/mach-socfpga/Makefile b/arch/arm/mach- socfpga/Makefile index 824cd8e..8b86dc7 100644 --- a/arch/arm/mach-socfpga/Makefile +++ b/arch/arm/mach-socfpga/Makefile @@ -24,6 +24,7 @@ endif ifdef CONFIG_TARGET_SOCFPGA_ARRIA10 obj-y += clock_manager_arria10.o +obj-y += lowlevel_init.o obj-y += misc_arria10.o obj-y += pinmux_arria10.o obj-y += reset_manager_arria10.o diff --git a/arch/arm/mach-socfpga/lowlevel_init.S b/arch/arm/mach- socfpga/lowlevel_init.S new file mode 100644 index 0000000..79e9d07 --- /dev/null +++ b/arch/arm/mach-socfpga/lowlevel_init.S @@ -0,0 +1,48 @@ +/*
Okay, i just saw it, thanks for pointing out.
AAPCS */
+write_burst:
- cmp r2,#32
- bls write_word
+write_burst_cont:
- subs r2, r2, #32
- b write_burst
+write_word:
- cmp r2,#4
- bls write_byte
+write_word_cont:
- ldmia r0!, {r4}
- stmia r1, {r4}
- subs r2, r2, #4
- b write_word
+write_byte:
- cmp r2,#0
- beq write_end
- ldr r3, [r0]
- str r3, [r1]
+write_end:
- POP {r4-r11, pc}
Add FPGA driver support for Arria 10.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- drivers/fpga/Kconfig | 2 +- drivers/fpga/Makefile | 1 + drivers/fpga/socfpga_arria10.c | 490 ++++++++++++++++++++++++++ include/intel_socfpga/fpga_manager.h | 2 + include/intel_socfpga/fpga_manager_arria10.h | 107 ++++++ 5 files changed, 601 insertions(+), 1 deletions(-) create mode 100644 drivers/fpga/socfpga_arria10.c create mode 100644 include/intel_socfpga/fpga_manager_arria10.h
diff --git a/drivers/fpga/Kconfig b/drivers/fpga/Kconfig index fc4ea0d..ed519d2 100644 --- a/drivers/fpga/Kconfig +++ b/drivers/fpga/Kconfig @@ -7,7 +7,7 @@ config FPGA
config FPGA_ALTERA bool "Enable Altera FPGA drivers" - default y if TARGET_SOCFPGA_GEN5 && CMD_FPGA + default y if (TARGET_SOCFPGA_GEN5 && CMD_FPGA) || TARGET_SOCFPGA_ARRIA10 select FPGA help Default Y here to enable the Altera FPGA driver diff --git a/drivers/fpga/Makefile b/drivers/fpga/Makefile index 649b6d1..ac23996 100644 --- a/drivers/fpga/Makefile +++ b/drivers/fpga/Makefile @@ -20,4 +20,5 @@ obj-$(CONFIG_FPGA_CYCLON2) += cyclon2.o obj-$(CONFIG_FPGA_STRATIX_II) += stratixII.o obj-$(CONFIG_FPGA_STRATIX_V) += stratixv.o obj-$(CONFIG_TARGET_SOCFPGA_GEN5) += socfpga_gen5.o +obj-$(CONFIG_TARGET_SOCFPGA_ARRIA10) += socfpga_arria10.o endif diff --git a/drivers/fpga/socfpga_arria10.c b/drivers/fpga/socfpga_arria10.c new file mode 100644 index 0000000..8831183 --- /dev/null +++ b/drivers/fpga/socfpga_arria10.c @@ -0,0 +1,490 @@ +/* + * Copyright (C) 2017 Intel Corporation <www.intel.com> + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <asm/io.h> +#include <intel_socfpga/fpga_manager.h> +#include <asm/arch/reset_manager.h> +#include <asm/arch/system_manager.h> +#include <asm/arch/sdram.h> +#include <asm/arch/misc.h> +#include <altera.h> +#include <common.h> +#include <errno.h> +#include <wait_bit.h> +#include <watchdog.h> + +#define CFGWDTH_32 1 +#define MIN_BITSTREAM_SIZECHECK 230 +#define ENCRYPTION_OFFSET 69 +#define COMPRESSION_OFFSET 229 + +DECLARE_GLOBAL_DATA_PTR; + +static const struct socfpga_fpga_manager *fpga_manager_base = + (void *)SOCFPGA_FPGAMGRREGS_ADDRESS; + +static const struct socfpga_system_manager *system_manager_base = + (void *)SOCFPGA_SYSMGR_ADDRESS; + +static void fpgamgr_set_cd_ratio(unsigned long ratio); + +static uint32_t fpgamgr_get_msel(void) +{ + u32 reg; + + reg = readl(&fpga_manager_base->imgcfg_stat); + reg = (reg & ALT_FPGAMGR_IMGCFG_STAT_F2S_MSEL_SET_MSD) >> + ALT_FPGAMGR_IMGCFG_STAT_F2S_MSEL0_LSB; + + return reg; +} + +static void fpgamgr_set_cfgwdth(int width) +{ + if (width) + setbits_le32(&fpga_manager_base->imgcfg_ctrl_02, + ALT_FPGAMGR_IMGCFG_CTL_02_CFGWIDTH_SET_MSK); + else + clrbits_le32(&fpga_manager_base->imgcfg_ctrl_02, + ALT_FPGAMGR_IMGCFG_CTL_02_CFGWIDTH_SET_MSK); +} + +/* Check whether FPGA Init_Done signal is high */ +int is_fpgamgr_initdone_high(void) +{ + return (readl(&fpga_manager_base->imgcfg_stat) & + ALT_FPGAMGR_IMGCFG_STAT_F2S_INITDONE_OE_SET_MSK) != 0; +} + +int is_fpgamgr_user_mode(void) +{ + return (readl(&fpga_manager_base->imgcfg_stat) & + ALT_FPGAMGR_IMGCFG_STAT_F2S_USERMODE_SET_MSK) != 0; +} + +static int wait_for_user_mode(void) +{ + return wait_for_bit(__func__, + &fpga_manager_base->imgcfg_stat, + ALT_FPGAMGR_IMGCFG_STAT_F2S_USERMODE_SET_MSK, + 1, FPGA_TIMEOUT_MSEC, false); +} + +static int is_fpgamgr_early_user_mode(void) +{ + return (readl(&fpga_manager_base->imgcfg_stat) & + ALT_FPGAMGR_IMGCFG_STAT_F2S_EARLY_USERMODE_SET_MSK) != 0; +} + +int fpgamgr_wait_early_user_mode(void) +{ + u32 sync_data = 0xffffffff; + u32 i = 0; + unsigned start = get_timer(0); + unsigned long cd_ratio; + + /* Getting existing CDRATIO */ + cd_ratio = (readl(&fpga_manager_base->imgcfg_ctrl_02) & + ALT_FPGAMGR_IMGCFG_CTL_02_CDRATIO_SET_MSK) >> + ALT_FPGAMGR_IMGCFG_CTL_02_CDRATIO_LSB; + + /* Using CDRATIO_X1 for better compatibility */ + fpgamgr_set_cd_ratio(CDRATIO_x1); + + while (!(is_fpgamgr_early_user_mode())) { + if (get_timer(start) > FPGA_TIMEOUT_MSEC) + return -ETIMEDOUT; + fpgamgr_program_write((const long unsigned int *)&sync_data, + sizeof(sync_data)); + udelay(FPGA_TIMEOUT_MSEC); + i++; + } + + debug("Additional %i sync word needed\n", i); + + /* restoring original CDRATIO */ + fpgamgr_set_cd_ratio(cd_ratio); + + return 0; +} + +/* Read f2s_nconfig_pin and f2s_nstatus_pin; loop until de-asserted */ +static int wait_for_nconfig_pin_and_nstatus_pin(void) +{ + unsigned long mask = ALT_FPGAMGR_IMGCFG_STAT_F2S_NCONFIG_PIN_SET_MSK | + ALT_FPGAMGR_IMGCFG_STAT_F2S_NSTATUS_PIN_SET_MSK; + + /* Poll until f2s_nconfig_pin and f2s_nstatus_pin; loop until de-asserted, + * timeout at 1000ms + */ + return wait_for_bit(__func__, + &fpga_manager_base->imgcfg_stat, + mask, + false, FPGA_TIMEOUT_MSEC, false); +} + +static int wait_for_f2s_nstatus_pin(unsigned long value) +{ + /* Poll until f2s to specific value, timeout at 1000ms */ + return wait_for_bit(__func__, + &fpga_manager_base->imgcfg_stat, + ALT_FPGAMGR_IMGCFG_STAT_F2S_NSTATUS_PIN_SET_MSK, + value, FPGA_TIMEOUT_MSEC, false); +} + +/* set CD ratio */ +static void fpgamgr_set_cd_ratio(unsigned long ratio) +{ + clrbits_le32(&fpga_manager_base->imgcfg_ctrl_02, + ALT_FPGAMGR_IMGCFG_CTL_02_CDRATIO_SET_MSK); + + setbits_le32(&fpga_manager_base->imgcfg_ctrl_02, + (ratio << ALT_FPGAMGR_IMGCFG_CTL_02_CDRATIO_LSB) & + ALT_FPGAMGR_IMGCFG_CTL_02_CDRATIO_SET_MSK); +} + +/* get the MSEL value, verify we are set for FPP configuration mode */ +static int fpgamgr_verify_msel(void) +{ + unsigned int msel = fpgamgr_get_msel(); + + if ((msel != 0) && (msel != 1)) { + printf("Fail: read msel=%d\n", msel); + return -EPERM; + } + + return 0; +} + +/* + * Write cdratio and cdwidth based on whether the bitstream is compressed + * and/or encoded + */ +static int fpgamgr_set_cdratio_cdwidth(unsigned int cfg_width, u32 *rbf_data, + u32 rbf_size) +{ + unsigned int cd_ratio; + bool encrypt, compress; + + /* + * According to the bitstream specification, + * both encryption and compression status are + * in location before offset 230 of the buffer. + */ + if (rbf_size < MIN_BITSTREAM_SIZECHECK) + return -EINVAL; + + encrypt = (rbf_data[ENCRYPTION_OFFSET] >> 2) & 3; + encrypt = encrypt != 0; + + compress = (rbf_data[COMPRESSION_OFFSET] >> 1) & 1; + compress = !compress; + + debug("header word %d = %08x\n", 69, rbf_data[69]); + debug("header word %d = %08x\n", 229, rbf_data[229]); + debug("read from rbf header: encrypt=%d compress=%d\n", encrypt, compress); + + /* + * from the register map description of cdratio in imgcfg_ctrl_02: + * Normal Configuration : 32bit Passive Parallel + * Partial Reconfiguration : 16bit Passive Parallel + */ + + /* + * cd ratio is dependent on cfg width and whether the bitstream + * is encrypted and/or compressed. + * + * | width | encr. | compr. | cd ratio | + * | 16 | 0 | 0 | 1 | + * | 16 | 0 | 1 | 4 | + * | 16 | 1 | 0 | 2 | + * | 16 | 1 | 1 | 4 | + * | 32 | 0 | 0 | 1 | + * | 32 | 0 | 1 | 8 | + * | 32 | 1 | 0 | 4 | + * | 32 | 1 | 1 | 8 | + */ + if (!compress && !encrypt) { + cd_ratio = CDRATIO_x1; + } else { + if (compress) + cd_ratio = CDRATIO_x4; + else + cd_ratio = CDRATIO_x2; + + /* if 32 bit, double the cd ratio (so register + field setting is incremented) */ + if (cfg_width == CFGWDTH_32) + cd_ratio += 1; + } + + fpgamgr_set_cfgwdth(cfg_width); + fpgamgr_set_cd_ratio(cd_ratio); + + return 0; +} + +static int fpgamgr_reset(void) +{ + unsigned long reg; + + /* S2F_NCONFIG = 0 */ + clrbits_le32(&fpga_manager_base->imgcfg_ctrl_00, + ALT_FPGAMGR_IMGCFG_CTL_00_S2F_NCONFIG_SET_MSK); + + /* Wait for f2s_nstatus == 0 */ + if (wait_for_f2s_nstatus_pin(0)) + return -ETIME; + + /* S2F_NCONFIG = 1 */ + setbits_le32(&fpga_manager_base->imgcfg_ctrl_00, + ALT_FPGAMGR_IMGCFG_CTL_00_S2F_NCONFIG_SET_MSK); + + /* Wait for f2s_nstatus == 1 */ + if (wait_for_f2s_nstatus_pin(1)) + return -ETIME; + + /* read and confirm f2s_condone_pin = 0 and f2s_condone_oe = 1 */ + reg = readl(&fpga_manager_base->imgcfg_stat); + if ((reg & ALT_FPGAMGR_IMGCFG_STAT_F2S_CONDONE_PIN_SET_MSK) != 0) + return -EPERM; + + if ((reg & ALT_FPGAMGR_IMGCFG_STAT_F2S_CONDONE_OE_SET_MSK) == 0) + return -EPERM; + + return 0; +} + +/* Start the FPGA programming by initialize the FPGA Manager */ +int fpgamgr_program_init(u32 * rbf_data, u32 rbf_size) +{ + int ret; + + /* Step 1 */ + if (fpgamgr_verify_msel()) + return -EPERM; + + /* Step 2 */ + if (fpgamgr_set_cdratio_cdwidth(CFGWDTH_32, rbf_data, rbf_size)) + return -EPERM; + + /* + * Step 3: + * Make sure no other external devices are trying to interfere with + * programming: + */ + if (wait_for_nconfig_pin_and_nstatus_pin()) + return -ETIME; + + /* + * Step 4: + * Deassert the signal drives from HPS + * + * S2F_NCE = 1 + * S2F_PR_REQUEST = 0 + * EN_CFG_CTRL = 0 + * EN_CFG_DATA = 0 + * S2F_NCONFIG = 1 + * S2F_NSTATUS_OE = 0 + * S2F_CONDONE_OE = 0 + */ + setbits_le32(&fpga_manager_base->imgcfg_ctrl_01, + ALT_FPGAMGR_IMGCFG_CTL_01_S2F_NCE_SET_MSK); + + clrbits_le32(&fpga_manager_base->imgcfg_ctrl_01, + ALT_FPGAMGR_IMGCFG_CTL_01_S2F_PR_REQUEST_SET_MSK); + + clrbits_le32(&fpga_manager_base->imgcfg_ctrl_02, + ALT_FPGAMGR_IMGCFG_CTL_02_EN_CFG_DATA_SET_MSK | + ALT_FPGAMGR_IMGCFG_CTL_02_EN_CFG_CTRL_SET_MSK); + + setbits_le32(&fpga_manager_base->imgcfg_ctrl_00, + ALT_FPGAMGR_IMGCFG_CTL_00_S2F_NCONFIG_SET_MSK); + + clrbits_le32(&fpga_manager_base->imgcfg_ctrl_00, + ALT_FPGAMGR_IMGCFG_CTL_00_S2F_NSTATUS_OE_SET_MSK | + ALT_FPGAMGR_IMGCFG_CTL_00_S2F_CONDONE_OE_SET_MSK); + + /* + * Step 5: + * Enable overrides + * S2F_NENABLE_CONFIG = 0 + * S2F_NENABLE_NCONFIG = 0 + */ + clrbits_le32(&fpga_manager_base->imgcfg_ctrl_01, + ALT_FPGAMGR_IMGCFG_CTL_01_S2F_NENABLE_CONFIG_SET_MSK); + clrbits_le32(&fpga_manager_base->imgcfg_ctrl_00, + ALT_FPGAMGR_IMGCFG_CTL_00_S2F_NENABLE_NCONFIG_SET_MSK); + + /* + * Disable driving signals that HPS doesn't need to drive. + * S2F_NENABLE_NSTATUS = 1 + * S2F_NENABLE_CONDONE = 1 + */ + setbits_le32(&fpga_manager_base->imgcfg_ctrl_00, + ALT_FPGAMGR_IMGCFG_CTL_00_S2F_NENABLE_NSTATUS_SET_MSK | + ALT_FPGAMGR_IMGCFG_CTL_00_S2F_NENABLE_CONDONE_SET_MSK); + + /* + * Step 6: + * Drive chip select S2F_NCE = 0 + */ + clrbits_le32(&fpga_manager_base->imgcfg_ctrl_01, + ALT_FPGAMGR_IMGCFG_CTL_01_S2F_NCE_SET_MSK); + + /* Step 7 */ + if (wait_for_nconfig_pin_and_nstatus_pin()) + return -ETIME; + + /* Step 8 */ + ret = fpgamgr_reset(); + + if (ret) + return ret; + + /* + * Step 9: + * EN_CFG_CTRL and EN_CFG_DATA = 1 + */ + setbits_le32(&fpga_manager_base->imgcfg_ctrl_02, + ALT_FPGAMGR_IMGCFG_CTL_02_EN_CFG_DATA_SET_MSK | + ALT_FPGAMGR_IMGCFG_CTL_02_EN_CFG_CTRL_SET_MSK); + + return 0; +} + +/* Write the RBF data to FPGA Manager */ +void fpgamgr_program_write(const unsigned long *rbf_data, + unsigned long rbf_size) +{ + /* Write sof/pof data to img_data_w */ + fpgamgr_axi_write(rbf_data, SOCFPGA_FPGAMGRDATA_ADDRESS, rbf_size); +} + +/* Ensure the FPGA entering config done */ +static int fpgamgr_program_poll_cd(void) +{ + unsigned long reg, i; + + for (i = 0; i < FPGA_TIMEOUT_CNT; i++) { + reg = readl(&fpga_manager_base->imgcfg_stat); + if (reg & ALT_FPGAMGR_IMGCFG_STAT_F2S_CONDONE_PIN_SET_MSK) + return 0; + + if ((reg & ALT_FPGAMGR_IMGCFG_STAT_F2S_NSTATUS_PIN_SET_MSK) == 0) { + printf("nstatus == 0 while waiting for condone\n"); + return -EPERM; + } + } + + if (i == FPGA_TIMEOUT_CNT) + return -ETIME; + + return 0; +} + +/* Ensure the FPGA entering user mode */ +static int fpgamgr_program_poll_usermode(void) +{ + unsigned long reg; + int ret = 0; + + if (fpgamgr_dclkcnt_set(0xf)) + return -ETIME; + + ret = wait_for_user_mode(); + + if (ret < 0) { + printf("%s: Failed to enter user mode with ", __func__); + printf("error code %d\n", ret); + return ret; + } + + /* + * Step 14: + * Stop DATA path and Dclk + * EN_CFG_CTRL and EN_CFG_DATA = 0 + */ + clrbits_le32(&fpga_manager_base->imgcfg_ctrl_02, + ALT_FPGAMGR_IMGCFG_CTL_02_EN_CFG_DATA_SET_MSK | + ALT_FPGAMGR_IMGCFG_CTL_02_EN_CFG_CTRL_SET_MSK); + + /* + * Step 15: + * Disable overrides + * S2F_NENABLE_CONFIG = 1 + * S2F_NENABLE_NCONFIG = 1 + */ + setbits_le32(&fpga_manager_base->imgcfg_ctrl_01, + ALT_FPGAMGR_IMGCFG_CTL_01_S2F_NENABLE_CONFIG_SET_MSK); + setbits_le32(&fpga_manager_base->imgcfg_ctrl_00, + ALT_FPGAMGR_IMGCFG_CTL_00_S2F_NENABLE_NCONFIG_SET_MSK); + + /* Disable chip select S2F_NCE = 1 */ + setbits_le32(&fpga_manager_base->imgcfg_ctrl_01, + ALT_FPGAMGR_IMGCFG_CTL_01_S2F_NCE_SET_MSK); + + /* + * Step 16: + * Final check + */ + reg = readl(&fpga_manager_base->imgcfg_stat); + if (((reg & ALT_FPGAMGR_IMGCFG_STAT_F2S_USERMODE_SET_MSK) == 0) || + ((reg & ALT_FPGAMGR_IMGCFG_STAT_F2S_CONDONE_PIN_SET_MSK) == 0) || + ((reg & ALT_FPGAMGR_IMGCFG_STAT_F2S_NSTATUS_PIN_SET_MSK) == 0)) + return -EPERM; + + return 0; +} + +int fpgamgr_program_fini(void) +{ + /* Ensure the FPGA entering config done */ + int status = fpgamgr_program_poll_cd(); + + if (status) { + printf("FPGA: Poll CD failed with error code %d\n", status); + return -EPERM; + } + WATCHDOG_RESET(); + + /* Ensure the FPGA entering user mode */ + status = fpgamgr_program_poll_usermode(); + if (status) { + printf("FPGA: Poll usermode failed with error code %d\n", + status); + return -EPERM; + } + + printf("Full Configuration Succeeded.\n"); + + return 0; +} + +/* + * FPGA Manager to program the FPGA. This is the interface used by FPGA driver. + * Return 0 for sucess, non-zero for error. + */ +int socfpga_load(Altera_desc *desc, const void *rbf_data, size_t rbf_size) +{ + unsigned long status; + + /* disable all signals from hps peripheral controller to fpga */ + writel(0, &system_manager_base->fpgaintf_en_global); + + /* disable all axi bridge (hps2fpga, lwhps2fpga & fpga2hps) */ + socfpga_bridges_reset(); + + /* Initialize the FPGA Manager */ + status = fpgamgr_program_init((u32 *)rbf_data, rbf_size); + if (status) + return status; + + /* Write the RBF data to FPGA Manager */ + fpgamgr_program_write(rbf_data, rbf_size); + + return fpgamgr_program_fini(); +} diff --git a/include/intel_socfpga/fpga_manager.h b/include/intel_socfpga/fpga_manager.h index 8dbf369..a4bfda6 100644 --- a/include/intel_socfpga/fpga_manager.h +++ b/include/intel_socfpga/fpga_manager.h @@ -12,6 +12,8 @@
#if defined(CONFIG_TARGET_SOCFPGA_GEN5) #include <intel_socfpga/fpga_manager_gen5.h> +#elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) +#include <intel_socfpga/fpga_manager_arria10.h> #endif
/* FPGA CD Ratio Value */ diff --git a/include/intel_socfpga/fpga_manager_arria10.h b/include/intel_socfpga/fpga_manager_arria10.h new file mode 100644 index 0000000..3fb4aed --- /dev/null +++ b/include/intel_socfpga/fpga_manager_arria10.h @@ -0,0 +1,107 @@ +/* + * Copyright (C) 2017 Intel Corporation <www.intel.com> + * All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#ifndef _FPGA_MANAGER_ARRIA10_H_ +#define _FPGA_MANAGER_ARRIA10_H_ + +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_CRC_ERROR_SET_MSK BIT(0) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_EARLY_USERMODE_SET_MSK BIT(1) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_USERMODE_SET_MSK BIT(2) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_INITDONE_OE_SET_MSK BIT(3) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_NSTATUS_PIN_SET_MSK BIT(4) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_NSTATUS_OE_SET_MSK BIT(5) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_CONDONE_PIN_SET_MSK BIT(6) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_CONDONE_OE_SET_MSK BIT(7) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_CVP_CONF_DONE_SET_MSK BIT(8) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_PR_READY_SET_MSK BIT(9) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_PR_DONE_SET_MSK BIT(10) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_PR_ERROR_SET_MSK BIT(11) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_NCONFIG_PIN_SET_MSK BIT(12) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_NCEO_OE_SET_MSK BIT(13) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_MSEL0_SET_MSK BIT(16) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_MSEL1_SET_MSK BIT(17) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_MSEL2_SET_MSK BIT(18) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_MSEL_SET_MSD (\ + ALT_FPGAMGR_IMGCFG_STAT_F2S_MSEL0_SET_MSK |\ + ALT_FPGAMGR_IMGCFG_STAT_F2S_MSEL1_SET_MSK |\ + ALT_FPGAMGR_IMGCFG_STAT_F2S_MSEL2_SET_MSK) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_IMGCFG_FIFOEMPTY_SET_MSK BIT(24) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_IMGCFG_FIFOFULL_SET_MSK BIT(25) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_JTAGM_SET_MSK BIT(28) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_EMR_SET_MSK BIT(29) +#define ALT_FPGAMGR_IMGCFG_STAT_F2S_MSEL0_LSB 16 + +#define ALT_FPGAMGR_IMGCFG_CTL_00_S2F_NENABLE_NCONFIG_SET_MSK BIT(0) +#define ALT_FPGAMGR_IMGCFG_CTL_00_S2F_NENABLE_NSTATUS_SET_MSK BIT(1) +#define ALT_FPGAMGR_IMGCFG_CTL_00_S2F_NENABLE_CONDONE_SET_MSK BIT(2) +#define ALT_FPGAMGR_IMGCFG_CTL_00_S2F_NCONFIG_SET_MSK BIT(8) +#define ALT_FPGAMGR_IMGCFG_CTL_00_S2F_NSTATUS_OE_SET_MSK BIT(16) +#define ALT_FPGAMGR_IMGCFG_CTL_00_S2F_CONDONE_OE_SET_MSK BIT(24) + +#define ALT_FPGAMGR_IMGCFG_CTL_01_S2F_NENABLE_CONFIG_SET_MSK BIT(0) +#define ALT_FPGAMGR_IMGCFG_CTL_01_S2F_PR_REQUEST_SET_MSK BIT(16) +#define ALT_FPGAMGR_IMGCFG_CTL_01_S2F_NCE_SET_MSK BIT(24) + +#define ALT_FPGAMGR_IMGCFG_CTL_02_EN_CFG_CTRL_SET_MSK BIT(0) +#define ALT_FPGAMGR_IMGCFG_CTL_02_EN_CFG_DATA_SET_MSK BIT(8) +#define ALT_FPGAMGR_IMGCFG_CTL_02_CDRATIO_SET_MSK 0x00030000 +#define ALT_FPGAMGR_IMGCFG_CTL_02_CFGWIDTH_SET_MSK BIT(24) +#define ALT_FPGAMGR_IMGCFG_CTL_02_CDRATIO_LSB 16 + +/* Timeout counter */ +#define FPGA_TIMEOUT_MSEC 1000 /* timeout in ms */ + +#ifndef __ASSEMBLY__ + +struct socfpga_fpga_manager { + u32 _pad_0x0_0x7[2]; + u32 dclkcnt; + u32 dclkstat; + u32 gpo; + u32 gpi; + u32 misci; + u32 _pad_0x1c_0x2f[5]; + u32 emr_data0; + u32 emr_data1; + u32 emr_data2; + u32 emr_data3; + u32 emr_data4; + u32 emr_data5; + u32 emr_valid; + u32 emr_en; + u32 jtag_config; + u32 jtag_status; + u32 jtag_kick; + u32 _pad_0x5c_0x5f; + u32 jtag_data_w; + u32 jtag_data_r; + u32 _pad_0x68_0x6f[2]; + u32 imgcfg_ctrl_00; + u32 imgcfg_ctrl_01; + u32 imgcfg_ctrl_02; + u32 _pad_0x7c_0x7f; + u32 imgcfg_stat; + u32 intr_masked_status; + u32 intr_mask; + u32 intr_polarity; + u32 dma_config; + u32 imgcfg_fifo_status; +}; + +/* Functions */ +void fpgamgr_axi_write(const unsigned long *rbf_data, + const unsigned long fpgamgr_data_addr, unsigned long rbf_size); +int fpgamgr_program_init(u32 * rbf_data, u32 rbf_size); +int fpgamgr_program_fini(void); +int is_fpgamgr_user_mode(void); +void fpgamgr_program_write(const unsigned long *rbf_data, + unsigned long rbf_size); +int fpgamgr_wait_early_user_mode(void); + +#endif /* __ASSEMBLY__ */ + +#endif /* _FPGA_MANAGER_ARRIA10_H_ */
Chee, Tien Fong
