[U-Boot] [PATCH 1/2] arm: atmel: at91sam9n12ek: add usb host support
Add usb host support for at91sam9n12ek board.
Signed-off-by: Bo Shen voice.shen@atmel.com --- arch/arm/include/asm/arch-at91/at91_pmc.h | 2 ++ board/atmel/at91sam9n12ek/at91sam9n12ek.c | 11 +++++++++++ drivers/usb/host/ohci-at91.c | 11 +++++++++-- include/configs/at91sam9n12ek.h | 12 ++++++++++++ 4 files changed, 34 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-at91/at91_pmc.h b/arch/arm/include/asm/arch-at91/at91_pmc.h index 003920c..7b36f74 100644 --- a/arch/arm/include/asm/arch-at91/at91_pmc.h +++ b/arch/arm/include/asm/arch-at91/at91_pmc.h @@ -233,6 +233,8 @@ typedef struct at91_pmc { #endif #define AT91_PMC_USBS_USB_PLLA (0x0) /* USB Clock Input is PLLA */ #define AT91_PMC_USBS_USB_UPLL (0x1) /* USB Clock Input is UPLL */ +#define AT91_PMC_USBS_USB_PLLB (0x1) /* USB Clock Input is PLLB, AT91SAM9N12 only */ +#define AT91_PMC_USB_DIV_2 (0x1 << 8) /* USB Clock divided by 2 */ #define AT91_PMC_USBDIV_8 (0x7 << 8) /* USB Clock divided by 8 */ #define AT91_PMC_USBDIV_10 (0x9 << 8) /* USB Clock divided by 10 */
diff --git a/board/atmel/at91sam9n12ek/at91sam9n12ek.c b/board/atmel/at91sam9n12ek/at91sam9n12ek.c index 2ec32eb..9adc992 100644 --- a/board/atmel/at91sam9n12ek/at91sam9n12ek.c +++ b/board/atmel/at91sam9n12ek/at91sam9n12ek.c @@ -199,6 +199,13 @@ void at91sam9n12ek_ks8851_hw_init(void) } #endif
+#ifdef CONFIG_USB_ATMEL +void at91sam9n12ek_usb_hw_init(void) +{ + at91_set_pio_output(AT91_PIO_PORTB, 7, 0); +} +#endif + int board_early_init_f(void) { /* Enable clocks for all PIOs */ @@ -230,6 +237,10 @@ int board_init(void) at91sam9n12ek_ks8851_hw_init(); #endif
+#ifdef CONFIG_USB_ATMEL + at91sam9n12ek_usb_hw_init(); +#endif + return 0; }
diff --git a/drivers/usb/host/ohci-at91.c b/drivers/usb/host/ohci-at91.c index 9e90d59..05d6ff2 100644 --- a/drivers/usb/host/ohci-at91.c +++ b/drivers/usb/host/ohci-at91.c @@ -20,11 +20,14 @@ int usb_cpu_init(void)
#if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) || \ defined(CONFIG_AT91SAM9263) || defined(CONFIG_AT91SAM9G20) || \ - defined(CONFIG_AT91SAM9261) + defined(CONFIG_AT91SAM9261) || defined(CONFIG_AT91SAM9N12) /* Enable PLLB */ writel(get_pllb_init(), &pmc->pllbr); while ((readl(&pmc->sr) & AT91_PMC_LOCKB) != AT91_PMC_LOCKB) ; +#ifdef CONFIG_AT91SAM9N12 + writel(AT91_PMC_USBS_USB_PLLB | AT91_PMC_USB_DIV_2, &pmc->usb); +#endif #elif defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) || \ defined(CONFIG_AT91SAM9X5) || defined(CONFIG_SAMA5D3) /* Enable UPLL */ @@ -71,7 +74,11 @@ int usb_cpu_stop(void) #endif
#if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) || \ - defined(CONFIG_AT91SAM9263) || defined(CONFIG_AT91SAM9G20) + defined(CONFIG_AT91SAM9263) || defined(CONFIG_AT91SAM9G20) || \ + defined(CONFIG_AT91SAM9N12) +#ifdef CONFIG_AT91SAM9N12 + writel(0, &pmc->usb); +#endif /* Disable PLLB */ writel(0, &pmc->pllbr); while ((readl(&pmc->sr) & AT91_PMC_LOCKB) != 0) diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 28a7925..cc79f8b 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -83,6 +83,7 @@ #define CONFIG_CMD_SF #define CONFIG_CMD_MMC #define CONFIG_CMD_FAT +#define CONFIG_CMD_USB
#define CONFIG_NR_DRAM_BANKS 1 #define CONFIG_SYS_SDRAM_BASE 0x20000000 @@ -163,6 +164,17 @@ #define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_MEMTEST_END 0x26e00000
+/* USB host */ +#ifdef CONFIG_CMD_USB +#define CONFIG_USB_ATMEL +#define CONFIG_USB_OHCI_NEW +#define CONFIG_SYS_USB_OHCI_CPU_INIT +#define CONFIG_SYS_USB_OHCI_REGS_BASE ATMEL_BASE_OHCI +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9n12" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 1 +#define CONFIG_USB_STORAGE +#endif + #ifdef CONFIG_SYS_USE_SPIFLASH
/* bootstrap + u-boot + env + linux in dataflash on CS0 */
Get rid of too many ifdeffery in usb ohci driver
Add following two configuration for USB clock selecting - CONFIG_USB_ATMEL_CLK_SEL_PLLB: using PLLB as usb ohci input clock - CONFIG_USB_ATMEL_CLK_SEL_UPLL: using UPLL as usb ohci input clock
--- drivers/usb/host/ohci-at91.c | 14 ++++---------- include/configs/afeb9260.h | 1 + include/configs/at91rm9200ek.h | 1 + include/configs/at91sam9260ek.h | 1 + include/configs/at91sam9261ek.h | 1 + include/configs/at91sam9263ek.h | 1 + include/configs/at91sam9n12ek.h | 1 + include/configs/at91sam9x5ek.h | 3 ++- include/configs/cpu9260.h | 1 + include/configs/cpuat91.h | 1 + include/configs/eb_cpux9k2.h | 1 + include/configs/ethernut5.h | 1 + include/configs/meesc.h | 1 + include/configs/otc570.h | 1 + include/configs/pm9261.h | 1 + include/configs/pm9263.h | 1 + include/configs/pm9g45.h | 1 + include/configs/sama5d3xek.h | 1 + include/configs/sbc35_a9g20.h | 1 + include/configs/snapper9260.h | 1 + include/configs/stamp9g20.h | 1 + include/configs/top9000.h | 1 + include/configs/vl_ma2sc.h | 1 + 23 files changed, 27 insertions(+), 11 deletions(-)
diff --git a/drivers/usb/host/ohci-at91.c b/drivers/usb/host/ohci-at91.c index 05d6ff2..c24505e 100644 --- a/drivers/usb/host/ohci-at91.c +++ b/drivers/usb/host/ohci-at91.c @@ -18,9 +18,7 @@ int usb_cpu_init(void) { at91_pmc_t *pmc = (at91_pmc_t *)ATMEL_BASE_PMC;
-#if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) || \ - defined(CONFIG_AT91SAM9263) || defined(CONFIG_AT91SAM9G20) || \ - defined(CONFIG_AT91SAM9261) || defined(CONFIG_AT91SAM9N12) +#ifdef CONFIG_USB_ATMEL_CLK_SEL_PLLB /* Enable PLLB */ writel(get_pllb_init(), &pmc->pllbr); while ((readl(&pmc->sr) & AT91_PMC_LOCKB) != AT91_PMC_LOCKB) @@ -28,8 +26,7 @@ int usb_cpu_init(void) #ifdef CONFIG_AT91SAM9N12 writel(AT91_PMC_USBS_USB_PLLB | AT91_PMC_USB_DIV_2, &pmc->usb); #endif -#elif defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) || \ - defined(CONFIG_AT91SAM9X5) || defined(CONFIG_SAMA5D3) +#elif defined(CONFIG_USB_ATMEL_CLK_SEL_UPLL) /* Enable UPLL */ writel(readl(&pmc->uckr) | AT91_PMC_UPLLEN | AT91_PMC_BIASEN, &pmc->uckr); @@ -73,9 +70,7 @@ int usb_cpu_stop(void) writel(ATMEL_PMC_UHP, &pmc->scdr); #endif
-#if defined(CONFIG_AT91CAP9) || defined(CONFIG_AT91SAM9260) || \ - defined(CONFIG_AT91SAM9263) || defined(CONFIG_AT91SAM9G20) || \ - defined(CONFIG_AT91SAM9N12) +#ifdef CONFIG_USB_ATMEL_CLK_SEL_PLLB #ifdef CONFIG_AT91SAM9N12 writel(0, &pmc->usb); #endif @@ -83,8 +78,7 @@ int usb_cpu_stop(void) writel(0, &pmc->pllbr); while ((readl(&pmc->sr) & AT91_PMC_LOCKB) != 0) ; -#elif defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) || \ - defined(CONFIG_AT91SAM9X5) || defined(CONFIG_SAMA5D3) +#elif defined(CONFIG_USB_ATMEL_CLK_SEL_UPLL) /* Disable UPLL */ writel(readl(&pmc->uckr) & (~AT91_PMC_UPLLEN), &pmc->uckr); while ((readl(&pmc->sr) & AT91_PMC_LOCKU) == AT91_PMC_LOCKU) diff --git a/include/configs/afeb9260.h b/include/configs/afeb9260.h index be2f207..d99d671 100644 --- a/include/configs/afeb9260.h +++ b/include/configs/afeb9260.h @@ -112,6 +112,7 @@
/* USB */ #define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW #define CONFIG_DOS_PARTITION #define CONFIG_SYS_USB_OHCI_CPU_INIT diff --git a/include/configs/at91rm9200ek.h b/include/configs/at91rm9200ek.h index e158b0d..27e32e2 100644 --- a/include/configs/at91rm9200ek.h +++ b/include/configs/at91rm9200ek.h @@ -154,6 +154,7 @@ * USB Config */ #define CONFIG_USB_ATMEL 1 +#define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW 1 #define CONFIG_USB_KEYBOARD 1 #define CONFIG_USB_STORAGE 1 diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index d7fd6b0..248d6ee 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -185,6 +185,7 @@
/* USB */ #define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW 1 #define CONFIG_SYS_USB_OHCI_CPU_INIT 1 #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 /* AT91SAM9260_UHP_BASE */ diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index af56604..819ae72 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -146,6 +146,7 @@
/* USB */ #define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW #define CONFIG_DOS_PARTITION #define CONFIG_SYS_USB_OHCI_CPU_INIT diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 40e167c..e3faec7 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -279,6 +279,7 @@
/* USB */ #define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW 1 #define CONFIG_DOS_PARTITION 1 #define CONFIG_SYS_USB_OHCI_CPU_INIT 1 diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index cc79f8b..4cdaed1 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -167,6 +167,7 @@ /* USB host */ #ifdef CONFIG_CMD_USB #define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_REGS_BASE ATMEL_BASE_OHCI diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 4a2ac9a..cb57be0 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -159,13 +159,14 @@ #define CONFIG_USB_EHCI_ATMEL #define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 2 #else +#define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_UPLL #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_REGS_BASE ATMEL_BASE_OHCI #define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9x5" #define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 3 #endif -#define CONFIG_USB_ATMEL #define CONFIG_USB_STORAGE #endif
diff --git a/include/configs/cpu9260.h b/include/configs/cpu9260.h index 5b79ace..796dfc3 100644 --- a/include/configs/cpu9260.h +++ b/include/configs/cpu9260.h @@ -346,6 +346,7 @@
/* USB */ #define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW #define CONFIG_DOS_PARTITION #define CONFIG_SYS_USB_OHCI_CPU_INIT diff --git a/include/configs/cpuat91.h b/include/configs/cpuat91.h index 6742dbc..67732de 100644 --- a/include/configs/cpuat91.h +++ b/include/configs/cpuat91.h @@ -160,6 +160,7 @@
#if defined(CONFIG_CMD_USB) #define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW #define CONFIG_USB_STORAGE #define CONFIG_DOS_PARTITION diff --git a/include/configs/eb_cpux9k2.h b/include/configs/eb_cpux9k2.h index b8e672f..9d40798 100644 --- a/include/configs/eb_cpux9k2.h +++ b/include/configs/eb_cpux9k2.h @@ -162,6 +162,7 @@ * Hardware drivers */ #define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW #define CONFIG_AT91C_PQFP_UHPBUG #define CONFIG_USB_STORAGE diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index adf14be..7fd0b51 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -178,6 +178,7 @@ /* USB */ #ifdef CONFIG_CMD_USB #define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00500000 diff --git a/include/configs/meesc.h b/include/configs/meesc.h index d2ec83c..46a8e01 100644 --- a/include/configs/meesc.h +++ b/include/configs/meesc.h @@ -157,6 +157,7 @@
/* USB */ #define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW #define CONFIG_DOS_PARTITION #define CONFIG_SYS_USB_OHCI_CPU_INIT diff --git a/include/configs/otc570.h b/include/configs/otc570.h index 543209c..d5eba58 100644 --- a/include/configs/otc570.h +++ b/include/configs/otc570.h @@ -207,6 +207,7 @@
/* USB */ #define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW #define CONFIG_DOS_PARTITION #define CONFIG_SYS_USB_OHCI_CPU_INIT diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index 67b40b2..792f4cd 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -245,6 +245,7 @@
/* USB */ #define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW 1 #define CONFIG_DOS_PARTITION 1 #define CONFIG_SYS_USB_OHCI_CPU_INIT 1 diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index 2b4335e..ff379a5 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -272,6 +272,7 @@
/* USB */ #define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW 1 #define CONFIG_DOS_PARTITION 1 #define CONFIG_SYS_USB_OHCI_CPU_INIT 1 diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index 7d16bd8..f15ae6d 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -120,6 +120,7 @@
/* USB */ #define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_UPLL #define CONFIG_USB_OHCI_NEW 1 #define CONFIG_DOS_PARTITION 1 #define CONFIG_SYS_USB_OHCI_CPU_INIT 1 diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index 79c0068..924d7fa 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -153,6 +153,7 @@
#ifdef CONFIG_CMD_USB #define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_UPLL #define CONFIG_USB_OHCI_NEW #define CONFIG_SYS_USB_OHCI_CPU_INIT #define CONFIG_SYS_USB_OHCI_REGS_BASE ATMEL_BASE_OHCI diff --git a/include/configs/sbc35_a9g20.h b/include/configs/sbc35_a9g20.h index 4ba2242..3cf693b 100644 --- a/include/configs/sbc35_a9g20.h +++ b/include/configs/sbc35_a9g20.h @@ -119,6 +119,7 @@
/* USB */ #define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW #define CONFIG_DOS_PARTITION #define CONFIG_SYS_USB_OHCI_CPU_INIT diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index 17eb5f2..c5de89e 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -65,6 +65,7 @@
/* USB */ #define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW #define CONFIG_DOS_PARTITION #define CONFIG_SYS_USB_OHCI_CPU_INIT diff --git a/include/configs/stamp9g20.h b/include/configs/stamp9g20.h index a997331..95fc26b 100644 --- a/include/configs/stamp9g20.h +++ b/include/configs/stamp9g20.h @@ -165,6 +165,7 @@
/* USB configuration */ #define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW #define CONFIG_USB_STORAGE #define CONFIG_DOS_PARTITION diff --git a/include/configs/top9000.h b/include/configs/top9000.h index a6d6928..159a8bc 100644 --- a/include/configs/top9000.h +++ b/include/configs/top9000.h @@ -174,6 +174,7 @@
/* USB */ #define CONFIG_USB_ATMEL +#define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW #define CONFIG_DOS_PARTITION #define CONFIG_SYS_USB_OHCI_CPU_INIT diff --git a/include/configs/vl_ma2sc.h b/include/configs/vl_ma2sc.h index e171ae4..f5d8564 100644 --- a/include/configs/vl_ma2sc.h +++ b/include/configs/vl_ma2sc.h @@ -116,6 +116,7 @@
Dear Bo Shen,
Bo Shen voice.shen@atmel.com writes:
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Dear Bo Shen,
Andreas Bießmann
Bo Shen
