[PATCH 1/1] doc: remove illegal characters
Avoid errors when generating the HTML documentation like:
'ascii' codec can't decode byte 0xc2
Correct capitalization of 'U-Boot'.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/board/freescale/b4860qds.rst | 2 +- doc/board/microchip/mpfs_icicle.rst | 4 ++-- doc/board/sifive/fu540.rst | 2 +- doc/board/xen/xenguest_arm64.rst | 14 +++++++------- doc/driver-model/design.rst | 2 +- doc/usage/bootmenu.rst | 2 +- 6 files changed, 13 insertions(+), 13 deletions(-)
diff --git a/doc/board/freescale/b4860qds.rst b/doc/board/freescale/b4860qds.rst index de14d857b9..efb1422e1c 100644 --- a/doc/board/freescale/b4860qds.rst +++ b/doc/board/freescale/b4860qds.rst @@ -9,7 +9,7 @@ The B4860QDS is a Freescale reference board that hosts the B4860 SoC B4860 Overview -------------- The B4860 QorIQ Qonverge device is a Freescale high-end, multicore SoC based on -StarCore and Power Architecture® cores. It targets the broadband wireless +StarCore and Power Architecture cores. It targets the broadband wireless infrastructure and builds upon the proven success of the existing multicore DSPs and Power CPUs. It is designed to bolster the rapidly changing and expanding wireless markets, such as 3GLTE (FDD and TDD), LTE-Advanced, and UMTS. diff --git a/doc/board/microchip/mpfs_icicle.rst b/doc/board/microchip/mpfs_icicle.rst index c71c2f3cab..1f9ce13a3c 100644 --- a/doc/board/microchip/mpfs_icicle.rst +++ b/doc/board/microchip/mpfs_icicle.rst @@ -702,9 +702,9 @@ Sample boot log from MPFS Icicle Kit [ 2.756098] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 2.789065] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. - [ OK ] Started Dispatch Password …ts to Console Directory Watch. + [ OK ] Started Dispatch Password ..ts to Console Directory Watch. [ 2.828974] systemd[1]: Started Forward Password Requests to Wall Directory Watch. - [ OK ] Started Forward Password R…uests to Wall Directory Watch. + [ OK ] Started Forward Password R..uests to Wall Directory Watch. [ 2.869009] systemd[1]: Reached target Paths. [ OK ] Reached target Paths. [ 2.898808] systemd[1]: Reached target Remote File Systems. diff --git a/doc/board/sifive/fu540.rst b/doc/board/sifive/fu540.rst index 4e4c852ff3..c8091f6490 100644 --- a/doc/board/sifive/fu540.rst +++ b/doc/board/sifive/fu540.rst @@ -5,7 +5,7 @@ HiFive Unleashed
FU540-C000 RISC-V SoC --------------------- -The FU540-C000 is the world’s first 4+1 64-bit RISC-V SoC from SiFive. +The FU540-C000 is the world's first 4+1 64-bit RISC-V SoC from SiFive.
The HiFive Unleashed development platform is based on FU540-C000 and capable of running Linux. diff --git a/doc/board/xen/xenguest_arm64.rst b/doc/board/xen/xenguest_arm64.rst index 1327f88f99..31a5c23dfd 100644 --- a/doc/board/xen/xenguest_arm64.rst +++ b/doc/board/xen/xenguest_arm64.rst @@ -6,17 +6,17 @@ Xen guest ARM64 board This board specification ------------------------
-This board is to be run as a virtual Xen [1] guest with U-boot as its primary +This board is to be run as a virtual Xen [1] guest with U-Boot as its primary bootloader. Xen is a type 1 hypervisor that allows multiple operating systems to run simultaneously on a single physical server. Xen is capable of running virtual machines in both full virtualization and para-virtualization (PV) -modes. Xen runs virtual machines, which are called “domains”. +modes. Xen runs virtual machines, which are called "domains".
Paravirtualized drivers are a special type of device drivers that are used in a guest system in the Xen domain and perform I/O operations using a special interface provided by the virtualization system and the host system.
-Xen support for U-boot is implemented by introducing a new Xen guest ARM64 +Xen support for U-Boot is implemented by introducing a new Xen guest ARM64 board and porting essential drivers from MiniOS [3] as well as some of the work previously done by NXP [4]:
@@ -39,7 +39,7 @@ previously done by NXP [4]: Board limitations -----------------
-1. U-boot runs without MMU enabled at the early stages. +1. U-Boot runs without MMU enabled at the early stages. According to Xen on ARM ABI (xen/include/public/arch-arm.h): all memory which is shared with other entities in the system (including the hypervisor and other guests) must reside in memory which is mapped as Normal Inner @@ -54,14 +54,14 @@ Board limitations 2. No serial console until MMU is up. Because data cache maintenance is required until the MMU setup the early/debug serial console is not implemented. Therefore, we do not have - usual prints like U-boot’s banner etc. until the serial driver is + usual prints like U-Boot's banner etc. until the serial driver is initialized.
3. Single RAM bank supported. If a Xen guest is given much memory it is possible that Xen allocates two memory banks for it. The first one is allocated under 4GB address space and - in some cases may represent the whole guest’s memory. It is assumed that - U-boot most likely won’t require high memory bank for its work andlaunching + in some cases may represent the whole guest's memory. It is assumed that + U-Boot most likely won't require high memory bank for its work andlaunching OS, so it is enough to take the first one.
diff --git a/doc/driver-model/design.rst b/doc/driver-model/design.rst index ffed7d5f79..93a9f3dc41 100644 --- a/doc/driver-model/design.rst +++ b/doc/driver-model/design.rst @@ -10,7 +10,7 @@ by:
* Marek Vasut marex@denx.de * Pavel Herrmann morpheus.ibis@gmail.com - * Viktor Křivák viktor.krivak@gmail.com + * Viktor Krivak viktor.krivak@gmail.com * Tomas Hlavacek tmshlvck@gmail.com
This has been both simplified and extended into the current implementation diff --git a/doc/usage/bootmenu.rst b/doc/usage/bootmenu.rst index 1f094ad6ed..44654acced 100644 --- a/doc/usage/bootmenu.rst +++ b/doc/usage/bootmenu.rst @@ -1,5 +1,5 @@ .. SPDX-License-Identifier: GPL-2.0+ -.. (C) Copyright 2011-2012 Pali Rohár pali@kernel.org +.. (C) Copyright 2011-2012 Pali Rohar pali@kernel.org
bootmenu command ================ -- 2.29.2
Hello Heinrich!
Does this change mean that UTF-8 is now disallowed in U-Boot?
This sounds like an incorrect configuration of tool which is generating HTML documentation.
- [ OK ] Started Dispatch Password ..ts to Console Directory Watch. [ 2.828974] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
- [ OK ] Started Forward Password R..uests to Wall Directory Watch. [ 2.869009] systemd[1]: Reached target Paths. [ OK ] Reached target Paths. [ 2.898808] systemd[1]: Reached target Remote File Systems.
- usual prints like U-Boot's banner etc. until the serial driver is initialized.
- Single RAM bank supported. If a Xen guest is given much memory it is possible that Xen allocates two memory banks for it. The first one is allocated under 4GB address space and
- in some cases may represent the whole guest's memory. It is assumed that
- U-Boot most likely won't require high memory bank for its work andlaunching OS, so it is enough to take the first one.
* Marek Vasut <marex@denx.de> * Pavel Herrmann <morpheus.ibis@gmail.com>
- Viktor Křivák viktor.krivak@gmail.com
- Viktor Krivak viktor.krivak@gmail.com
- Tomas Hlavacek tmshlvck@gmail.com
bootmenu command
-- 2.29.2
On 1/25/21 11:13 PM, Pali Rohár wrote:
Hello Heinrich!
Sphinx uses as default:
source_encoding = 'utf-8-sig'
With Sphinx 3 on my machine I have no problem. But with Sphinx 2 on Gitlab an error is ejected for Unicode letters.
I do not know if elder Sphinx versions require a BOM to mark a file as UTF-8 when using utf-8-sig.
Best regards
Heinrich
bootmenu command
-- 2.29.2
Hello Heinrich!
utf-8-sig is IIRC UTF-8 encoding with leading BOM.
According to UNICODE standards, it is not required and moreover it is not recommended to use BOM in UTF-8.
So if some tool requires BOM in UTF-8 then it not compliant to UNICODE standard and I do not think it is a good idea to stop using UNICODE just because some tool cannot process UTF-8... But this is just my opinion and I do not know how Sphinx 2 works or how it is configured.
Maybe... can you check if it is possible to reconfigure Sphinx 2 to use UTF-8 without BOM? Is not there just option source_encoding = 'utf-8' ?
Hello Heinrich!
The problem is caused by doc/sphinx/automarkup.py inherited from Linux. The initial commit for the module says:
"Rather than fill our text files with :c:func:`function()` syntax, just do the markup via a hook into the sphinx build process."
I am not able to reproduce the problem locally.
We can deactivate this module. Anyway the module would have to be adjusted to match U-Boots file structure.
Best regards
Heinrich
Why do we use the ascii codec (instead of e.g. UTF-8)?
--Sean
bootmenu command
-- 2.29.2
Pali Rohár
Sean Anderson
