Pull request: Please pull u-boot-imx-20231214
Hi Tom,
Please pull these fixes from u-boot-imx, thanks.
The following changes since commit 27089f1e4d11fd7e0619097b59258d0428cde2ac:
Merge branch '2023-12-13-assorted-minor-fixes' (2023-12-13 09:57:28 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-20231214
for you to fetch changes up to 4f7122ca1580602399afc30f94f4b37f79e4d662:
imx8mp-venice: update DRAM config for 2000MHz (2023-12-14 15:34:12 -0300)
u-boot-imx-20231214 -------------------
CI: https://source.denx.de/u-boot/custodians/u-boot-imx/-/pipelines/18937
- Fix for i.MX8M Plus eDM SBC DDR timings with inlinc ECC - Switch to FPWM mode on Data Modul i.MX8M Plus eDM SBC so that DRAM EDAC detects more correctable errors - Fix for imx8mp-venice board DDR initialization
---------------------------------------------------------------- Marek Vasut (7): arm64: imx8mp: Inhibit DTC warning on DH i.MX8MP DHCOM rev.100 DTO ddr: imx: Handle 3734 in addition to 3733 and 3732 MTps rates ddr: imx: Add 3600 MTps rate support ARM: imx: Enable CAAM on Data Modul i.MX8M Mini/Plus eDM SBC ARM: imx: Enable CAAM on DH i.MX8M Plus DHCOM ARM: imx: Force DRAM regulators into FPWM mode on Data Modul i.MX8M Plus eDM SBC ARM: imx: Update DRAM timings with inline ECC on Data Modul i.MX8M Plus eDM SBC
Tim Harvey (3): board: gateworks: venice: remove extra file imx8mp-venice: fix DRAM bus configuration imx8mp-venice: update DRAM config for 2000MHz
arch/arm/dts/Makefile | 2 + arch/arm/mach-imx/imx8m/clock_imx8mm.c | 1 + board/data_modul/common/common.c | 18 +- .../imx8mp_edm_sbc/lpddr4_timing_4G_32.c | 175 +- board/data_modul/imx8mp_edm_sbc/spl.c | 5 + .../gateworks/venice/lpddr4_timing_imx8mm_512mb.c | 1849 -------------------- board/gateworks/venice/lpddr4_timing_imx8mp.c | 327 ++-- configs/imx8mm_data_modul_edm_sbc_defconfig | 1 + configs/imx8mp_data_modul_edm_sbc_defconfig | 2 + configs/imx8mp_dhcom_pdk2_defconfig | 1 + configs/imx8mp_dhcom_pdk3_defconfig | 1 + drivers/ddr/imx/phy/ddrphy_utils.c | 5 + 12 files changed, 301 insertions(+), 2086 deletions(-) delete mode 100644 board/gateworks/venice/lpddr4_timing_imx8mm_512mb.c
On Fri, Dec 15, 2023 at 10:07:07AM -0300, Fabio Estevam wrote:
Hi Tom,
u-boot-imx-20231214
Fabio Estevam
