[PATCH v3 1/4] imx: Remove CFG_MXC_USB_FLAGS
CFG_MXC_USB_FLAGS is only used for drivers/usb/host/ehci-mx5.c, so it can be removed from all the imx6/imx7/imx8m board config files.
mx51evk.h is the only place CFG_MXC_USB_FLAGS is not set to 0.
Suggested-by: Tim Harvey tharvey@gateworks.com Signed-off-by: Fabio Estevam festevam@denx.de Reviewed-by: Marek Vasut marex@denx.de Reviewed-by: Peng Fan peng.fan@nxp.com --- Changes since v2: - None.
include/configs/apalis_imx6.h | 1 - include/configs/aristainetos2.h | 1 - include/configs/cl-som-imx7.h | 1 - include/configs/cm_fx6.h | 1 - include/configs/colibri-imx6ull.h | 1 - include/configs/colibri_imx6.h | 1 - include/configs/colibri_imx7.h | 1 - include/configs/dart_6ul.h | 1 - include/configs/dh_imx6.h | 1 - include/configs/embestmx6boards.h | 1 - include/configs/ge_b1x5v2.h | 1 - include/configs/gw_ventana.h | 1 - include/configs/imx6_logic.h | 1 - include/configs/imx6dl-mamoj.h | 1 - include/configs/imx6q-bosch-acc.h | 1 - include/configs/kontron-sl-mx6ul.h | 1 - include/configs/kontron-sl-mx8mm.h | 1 - include/configs/kp_imx53.h | 1 - include/configs/kp_imx6q_tpc.h | 1 - include/configs/liteboard.h | 1 - include/configs/m53menlo.h | 1 - include/configs/mx53cx9020.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx53ppd.h | 1 - include/configs/mx6sabreauto.h | 1 - include/configs/mx6sabresd.h | 1 - include/configs/mx6slevk.h | 1 - include/configs/mx6sxsabreauto.h | 1 - include/configs/mx6sxsabresd.h | 1 - include/configs/mx6ul_14x14_evk.h | 1 - include/configs/mys_6ulx.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/novena.h | 1 - include/configs/npi_imx6ull.h | 1 - include/configs/opos6uldev.h | 1 - include/configs/pcl063.h | 1 - include/configs/pcl063_ull.h | 1 - include/configs/pico-imx6.h | 1 - include/configs/pico-imx6ul.h | 1 - include/configs/pico-imx7d.h | 1 - include/configs/somlabs_visionsom_6ull.h | 1 - include/configs/usbarmory.h | 1 - include/configs/vining_2000.h | 1 - include/configs/wandboard.h | 1 - include/configs/xpress.h | 1 - 45 files changed, 45 deletions(-)
diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 6fd43511ee4..097f819e44a 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -26,7 +26,6 @@ /* USB Configs */ /* Host */ #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CFG_MXC_USB_FLAGS 0
/* Framebuffer and LCD */
diff --git a/include/configs/aristainetos2.h b/include/configs/aristainetos2.h index 9d4a4bbdf43..120ff9284ef 100644 --- a/include/configs/aristainetos2.h +++ b/include/configs/aristainetos2.h @@ -413,7 +413,6 @@
/* USB Configs */ #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CFG_MXC_USB_FLAGS 0
/* UBI support */
diff --git a/include/configs/cl-som-imx7.h b/include/configs/cl-som-imx7.h index 280ae1e9cca..96058d48148 100644 --- a/include/configs/cl-som-imx7.h +++ b/include/configs/cl-som-imx7.h @@ -97,6 +97,5 @@
#endif /* __CONFIG_H */ diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index 7d0f2b6dc13..fc2d59751c4 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -136,7 +136,6 @@
/* USB */ #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CFG_MXC_USB_FLAGS 0
/* Boot */ #define CFG_SYS_BOOTMAPSZ (8 << 20) diff --git a/include/configs/colibri-imx6ull.h b/include/configs/colibri-imx6ull.h index 8860ceec1a0..c896a897cbf 100644 --- a/include/configs/colibri-imx6ull.h +++ b/include/configs/colibri-imx6ull.h @@ -120,7 +120,6 @@ /* USB Configs */
/* USB Device Firmware Update support */ #define DFU_DEFAULT_POLL_TIMEOUT 300 diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index 79e5b870b81..87c973883c3 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -24,7 +24,6 @@ /* USB Configs */ /* Host */ #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CFG_MXC_USB_FLAGS 0
/* Command definition */
diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 33133a0b96e..0e0665038b1 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -162,6 +162,5 @@ /* USB Configs */
#endif diff --git a/include/configs/dart_6ul.h b/include/configs/dart_6ul.h index c5781670864..4d715d4f425 100644 --- a/include/configs/dart_6ul.h +++ b/include/configs/dart_6ul.h @@ -48,7 +48,6 @@
#define ENV_MMC \ "mmcdev=" __stringify(MMC_ROOTFS_DEV) "\0" \ diff --git a/include/configs/dh_imx6.h b/include/configs/dh_imx6.h index 4b5ef4ad510..dc5ca9fc60c 100644 --- a/include/configs/dh_imx6.h +++ b/include/configs/dh_imx6.h @@ -32,7 +32,6 @@
/* USB Gadget (DFU, UMS) */ #if defined(CONFIG_CMD_DFU) || defined(CONFIG_CMD_USB_MASS_STORAGE) diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 31c7e104f6b..e378374a004 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -19,7 +19,6 @@
/* MMC Configs */ #define CFG_SYS_FSL_ESDHC_ADDR 0 diff --git a/include/configs/ge_b1x5v2.h b/include/configs/ge_b1x5v2.h index 49b058cb10d..0bf31897a74 100644 --- a/include/configs/ge_b1x5v2.h +++ b/include/configs/ge_b1x5v2.h @@ -25,7 +25,6 @@
/* Memory */ #define PHYS_SDRAM MMDC0_ARB_BASE_ADDR diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index ebc5d03d0d5..f884d74d9ca 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -37,7 +37,6 @@
/* Miscellaneous configurable options */
diff --git a/include/configs/imx6_logic.h b/include/configs/imx6_logic.h index 66004a6eb2a..19613e838fb 100644 --- a/include/configs/imx6_logic.h +++ b/include/configs/imx6_logic.h @@ -117,7 +117,6 @@ /* USB Configs */ #ifdef CONFIG_CMD_USB #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CFG_MXC_USB_FLAGS 0 #endif
/* Falcon Mode */ diff --git a/include/configs/imx6dl-mamoj.h b/include/configs/imx6dl-mamoj.h index 6c61b3f4480..6651653d5e9 100644 --- a/include/configs/imx6dl-mamoj.h +++ b/include/configs/imx6dl-mamoj.h @@ -44,7 +44,6 @@
/* Falcon */
diff --git a/include/configs/imx6q-bosch-acc.h b/include/configs/imx6q-bosch-acc.h index 2c998cdcfc7..aa365dc9a79 100644 --- a/include/configs/imx6q-bosch-acc.h +++ b/include/configs/imx6q-bosch-acc.h @@ -111,6 +111,5 @@ #endif
#endif /* __IMX6Q_ACC_H */ diff --git a/include/configs/kontron-sl-mx6ul.h b/include/configs/kontron-sl-mx6ul.h index 1c92cd78767..e68c667c505 100644 --- a/include/configs/kontron-sl-mx6ul.h +++ b/include/configs/kontron-sl-mx6ul.h @@ -26,7 +26,6 @@
#ifdef CONFIG_USB_EHCI_HCD #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CFG_MXC_USB_FLAGS 0 #endif
/* Boot order for distro boot */ diff --git a/include/configs/kontron-sl-mx8mm.h b/include/configs/kontron-sl-mx8mm.h index eee3d2ddb03..be1f70a9a59 100644 --- a/include/configs/kontron-sl-mx8mm.h +++ b/include/configs/kontron-sl-mx8mm.h @@ -26,7 +26,6 @@
/* GUID for capsule updatable firmware image */ diff --git a/include/configs/kp_imx53.h b/include/configs/kp_imx53.h index 6e383cbe75f..91caf03091c 100644 --- a/include/configs/kp_imx53.h +++ b/include/configs/kp_imx53.h @@ -12,7 +12,6 @@
diff --git a/include/configs/kp_imx6q_tpc.h b/include/configs/kp_imx6q_tpc.h index 1aa4b8ab598..74f6e4e9f96 100644 --- a/include/configs/kp_imx6q_tpc.h +++ b/include/configs/kp_imx6q_tpc.h @@ -19,7 +19,6 @@ /* USB Configs */ #ifdef CONFIG_CMD_USB #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CFG_MXC_USB_FLAGS 0 #endif
#define CFG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/liteboard.h b/include/configs/liteboard.h index 5811059c8e2..25c30e6c6a5 100644 --- a/include/configs/liteboard.h +++ b/include/configs/liteboard.h @@ -96,7 +96,6 @@ /* USB Configs */ #ifdef CONFIG_CMD_USB #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CFG_MXC_USB_FLAGS 0 #endif
#ifdef CONFIG_CMD_NET diff --git a/include/configs/m53menlo.h b/include/configs/m53menlo.h index 9cf46b2c362..1491c509820 100644 --- a/include/configs/m53menlo.h +++ b/include/configs/m53menlo.h @@ -72,7 +72,6 @@ #ifdef CONFIG_CMD_USB #define CFG_MXC_USB_PORT 1 #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CFG_MXC_USB_FLAGS 0 #endif
/* LVDS display */ diff --git a/include/configs/mx53cx9020.h b/include/configs/mx53cx9020.h index dccfdc3a15d..ab6b0b65556 100644 --- a/include/configs/mx53cx9020.h +++ b/include/configs/mx53cx9020.h @@ -24,7 +24,6 @@ /* USB Configs */ #define CFG_MXC_USB_PORT 1 #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CFG_MXC_USB_FLAGS 0
diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 7398804e6b5..04f4b723209 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -19,7 +19,6 @@ /* USB Configs */ #define CFG_MXC_USB_PORT 1 #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CFG_MXC_USB_FLAGS 0
/* PMIC Controller */ #define CFG_SYS_DIALOG_PMIC_I2C_ADDR 0x48 diff --git a/include/configs/mx53ppd.h b/include/configs/mx53ppd.h index df65dbeea41..3c9a9fb045b 100644 --- a/include/configs/mx53ppd.h +++ b/include/configs/mx53ppd.h @@ -14,7 +14,6 @@ /* USB Configs */ #define CFG_MXC_USB_PORT 1 #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CFG_MXC_USB_FLAGS 0
diff --git a/include/configs/mx6sabreauto.h b/include/configs/mx6sabreauto.h index 91544c8a0e2..eb963cbb0b3 100644 --- a/include/configs/mx6sabreauto.h +++ b/include/configs/mx6sabreauto.h @@ -13,7 +13,6 @@
#define CFG_SYS_I2C_PCA953X_WIDTH { {0x30, 8}, {0x32, 8}, {0x34, 8} }
diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index 844f10e4229..9160f878f4b 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -27,7 +27,6 @@ /* USB Configs */ #ifdef CONFIG_CMD_USB #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CFG_MXC_USB_FLAGS 0 #endif
#endif /* __MX6SABRESD_CONFIG_H */ diff --git a/include/configs/mx6slevk.h b/include/configs/mx6slevk.h index 490d9feb805..65c6cdd4b87 100644 --- a/include/configs/mx6slevk.h +++ b/include/configs/mx6slevk.h @@ -91,7 +91,6 @@ /* USB Configs */ #ifdef CONFIG_CMD_USB #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CFG_MXC_USB_FLAGS 0 #endif
#define CFG_SYS_FSL_USDHC_NUM 3 diff --git a/include/configs/mx6sxsabreauto.h b/include/configs/mx6sxsabreauto.h index 1c14a6beb0a..4e163d28e63 100644 --- a/include/configs/mx6sxsabreauto.h +++ b/include/configs/mx6sxsabreauto.h @@ -97,7 +97,6 @@
#define CFG_SYS_FSL_USDHC_NUM 2 diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index fe0ad34ef9c..b43a1d81315 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -119,7 +119,6 @@
#ifdef CONFIG_CMD_PCI diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 98b743b9364..fd0c87ffb01 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -117,7 +117,6 @@ /* USB Configs */ #ifdef CONFIG_CMD_USB #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CFG_MXC_USB_FLAGS 0 #endif
#ifdef CONFIG_CMD_NET diff --git a/include/configs/mys_6ulx.h b/include/configs/mys_6ulx.h index 2571098d06c..8defdfc4fda 100644 --- a/include/configs/mys_6ulx.h +++ b/include/configs/mys_6ulx.h @@ -31,7 +31,6 @@
#define CFG_EXTRA_ENV_SETTINGS \ "console=ttymxc0,115200n8\0" \ diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index c03d11dcdae..a8ad85050f7 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -20,7 +20,6 @@
#ifdef CONFIG_CMD_MMC #define DISTRO_BOOT_DEV_MMC(func) func(MMC, mmc, 0) func(MMC, mmc, 1) diff --git a/include/configs/novena.h b/include/configs/novena.h index 39d3afd1c8e..144cf1b4a4b 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -54,7 +54,6 @@ /* USB Configs */ #ifdef CONFIG_CMD_USB #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CFG_MXC_USB_FLAGS 0 #endif
/* Extra U-Boot environment. */ diff --git a/include/configs/npi_imx6ull.h b/include/configs/npi_imx6ull.h index 5f933391cc0..f71e2657076 100644 --- a/include/configs/npi_imx6ull.h +++ b/include/configs/npi_imx6ull.h @@ -30,7 +30,6 @@
#ifdef CONFIG_CMD_NET #define CFG_FEC_MXC_PHYADDR 0x1 diff --git a/include/configs/opos6uldev.h b/include/configs/opos6uldev.h index 1edb1826c4e..12020d31e1c 100644 --- a/include/configs/opos6uldev.h +++ b/include/configs/opos6uldev.h @@ -20,7 +20,6 @@ /* USB */ #ifdef CONFIG_USB_EHCI_MX6 #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CFG_MXC_USB_FLAGS 0 #endif
/* LCD */ diff --git a/include/configs/pcl063.h b/include/configs/pcl063.h index 38dcee05359..2a729c3e454 100644 --- a/include/configs/pcl063.h +++ b/include/configs/pcl063.h @@ -43,7 +43,6 @@
#define CFG_EXTRA_ENV_SETTINGS \ "console=ttymxc0,115200n8\0" \ diff --git a/include/configs/pcl063_ull.h b/include/configs/pcl063_ull.h index d742201ce43..afa8e7aeb71 100644 --- a/include/configs/pcl063_ull.h +++ b/include/configs/pcl063_ull.h @@ -45,7 +45,6 @@
#define ENV_MMC \ "mmcdev=" __stringify(MMC_ROOTFS_DEV) "\0" \ diff --git a/include/configs/pico-imx6.h b/include/configs/pico-imx6.h index d806d7d9c57..6ccb3dc1902 100644 --- a/include/configs/pico-imx6.h +++ b/include/configs/pico-imx6.h @@ -17,7 +17,6 @@
diff --git a/include/configs/pico-imx6ul.h b/include/configs/pico-imx6ul.h index 8a22f0134b3..ef8281440e5 100644 --- a/include/configs/pico-imx6ul.h +++ b/include/configs/pico-imx6ul.h @@ -23,7 +23,6 @@
diff --git a/include/configs/pico-imx7d.h b/include/configs/pico-imx7d.h index e7a8cb20dff..21ec7fd3362 100644 --- a/include/configs/pico-imx7d.h +++ b/include/configs/pico-imx7d.h @@ -107,6 +107,5 @@
#endif diff --git a/include/configs/somlabs_visionsom_6ull.h b/include/configs/somlabs_visionsom_6ull.h index 041a83b057d..aa09528acd9 100644 --- a/include/configs/somlabs_visionsom_6ull.h +++ b/include/configs/somlabs_visionsom_6ull.h @@ -62,7 +62,6 @@ /* USB Configs */ #ifdef CONFIG_CMD_USB #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CFG_MXC_USB_FLAGS 0 #endif
#ifdef CONFIG_CMD_NET diff --git a/include/configs/usbarmory.h b/include/configs/usbarmory.h index 27e61f5b8f4..28d86a26362 100644 --- a/include/configs/usbarmory.h +++ b/include/configs/usbarmory.h @@ -25,7 +25,6 @@ /* USB */ #define CFG_MXC_USB_PORT 1 #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#define CFG_MXC_USB_FLAGS 0
/* Linux boot */
diff --git a/include/configs/vining_2000.h b/include/configs/vining_2000.h index 30654191a26..3c2d7e66891 100644 --- a/include/configs/vining_2000.h +++ b/include/configs/vining_2000.h @@ -37,7 +37,6 @@ #define CFG_FEC_MXC_PHYADDR 0x0
#ifdef CONFIG_CMD_PCI #define CFG_PCIE_IMX_PERST_GPIO IMX_GPIO_NR(4, 6) diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index 7b8c5cbe7a8..d64c4262bd6 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -18,7 +18,6 @@
#define CFG_EXTRA_ENV_SETTINGS \ "console=ttymxc0\0" \ diff --git a/include/configs/xpress.h b/include/configs/xpress.h index a2aa31008ec..bb0a30c4344 100644 --- a/include/configs/xpress.h +++ b/include/configs/xpress.h @@ -29,7 +29,6 @@
#define CFG_FEC_ENET_DEV 0 #define CFG_FEC_MXC_PHYADDR 0x0
Just like drivers/usb/host/ehci-mx6.c, add a default for drivers/usb/host/ehci-mx5.c.
The motivation for doing this is to remove CFG_MXC_USB_PORTSC from board config files.
All the mx5 boards, with the exeption of mx51evk, define CFG_MXC_USB_PORTSC as:
So move this definition as a default into ehci-mx5.c.
Signed-off-by: Fabio Estevam festevam@denx.de Reviewed-by: Peng Fan peng.fan@nxp.com --- Changes since v2: - None.
drivers/usb/host/ehci-mx5.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/usb/host/ehci-mx5.c b/drivers/usb/host/ehci-mx5.c index 44912de7787..d8f521befe1 100644 --- a/drivers/usb/host/ehci-mx5.c +++ b/drivers/usb/host/ehci-mx5.c @@ -79,6 +79,10 @@ /* USB_CTRL_1 */ #define MXC_USB_CTRL_UH1_EXT_CLK_EN (1 << 25)
+#ifndef CFG_MXC_USB_PORTSC +#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) +#endif + int mxc_set_usbcontrol(int port, unsigned int flags) { unsigned int v;
CFG_MXC_USB_PORT is not used anywhere, so remove this unused symbol.
Suggested-by: Tim Harvey tharvey@gateworks.com Signed-off-by: Fabio Estevam festevam@denx.de Reviewed-by: Peng Fan peng.fan@nxp.com --- Changes since v2: - None.
include/configs/m53menlo.h | 1 - include/configs/mx51evk.h | 1 - include/configs/mx53cx9020.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx53ppd.h | 1 - include/configs/usbarmory.h | 1 - 6 files changed, 6 deletions(-)
diff --git a/include/configs/m53menlo.h b/include/configs/m53menlo.h index 1491c509820..51ce030d831 100644 --- a/include/configs/m53menlo.h +++ b/include/configs/m53menlo.h @@ -70,7 +70,6 @@ * USB */ #ifdef CONFIG_CMD_USB -#define CFG_MXC_USB_PORT 1 #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #endif
diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index dff54d04a67..6c8cb78274b 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -33,7 +33,6 @@ #define CFG_SYS_FSL_ESDHC_ADDR MMC_SDHC1_BASE_ADDR
/* USB Configs */ -#define CFG_MXC_USB_PORT 1 #define CFG_MXC_USB_PORTSC PORT_PTS_ULPI #define CFG_MXC_USB_FLAGS MXC_EHCI_POWER_PINS_ENABLED
diff --git a/include/configs/mx53cx9020.h b/include/configs/mx53cx9020.h index ab6b0b65556..38bafc5156d 100644 --- a/include/configs/mx53cx9020.h +++ b/include/configs/mx53cx9020.h @@ -22,7 +22,6 @@ /* bootz: zImage/initrd.img support */
/* USB Configs */ -#define CFG_MXC_USB_PORT 1 #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW)
/* Command definition */ diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 04f4b723209..e9340c59ae1 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -17,7 +17,6 @@ #define CFG_SYS_FSL_ESDHC_ADDR 0
/* PMIC Controller */ diff --git a/include/configs/mx53ppd.h b/include/configs/mx53ppd.h index 3c9a9fb045b..e0bfbbb459c 100644 --- a/include/configs/mx53ppd.h +++ b/include/configs/mx53ppd.h @@ -12,7 +12,6 @@ #include <asm/arch/imx-regs.h>
/* Command definition */ diff --git a/include/configs/usbarmory.h b/include/configs/usbarmory.h index 28d86a26362..1d7caaa1448 100644 --- a/include/configs/usbarmory.h +++ b/include/configs/usbarmory.h @@ -23,7 +23,6 @@ #define CFG_SYS_FSL_ESDHC_ADDR 0
/* USB */ -#define CFG_MXC_USB_PORT 1 #define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW)
/* Linux boot */
The definition of CFG_MXC_USB_PORTSC as (PORT_PTS_UTMI | PORT_PTS_PTW) can be removed from mx5/mx6/mx7/mx8m board config files as it is the default in drivers/usb/host/ehci-mx5.c and drivers/usb/host/ehci-mx6.c.
Suggested-by: Tim Harvey tharvey@gateworks.com Signed-off-by: Fabio Estevam festevam@denx.de Reviewed-by: Tim Harvey tharvey@gateworks.com --- Changes since v2: - Keep mx51evk.h intact as it uses a different CFG_MXC_USB_PORTSC definition.
include/configs/apalis_imx6.h | 4 ---- include/configs/aristainetos2.h | 3 --- include/configs/brppt2.h | 3 --- include/configs/cl-som-imx7.h | 3 --- include/configs/cm_fx6.h | 3 --- include/configs/colibri-imx6ull.h | 4 ---- include/configs/colibri_imx6.h | 4 ---- include/configs/colibri_imx7.h | 4 ---- include/configs/dart_6ul.h | 3 --- include/configs/dh_imx6.h | 3 --- include/configs/display5.h | 1 - include/configs/embestmx6boards.h | 3 --- include/configs/ge_b1x5v2.h | 3 --- include/configs/gw_ventana.h | 3 --- include/configs/imx6_logic.h | 5 ----- include/configs/imx6dl-mamoj.h | 3 --- include/configs/imx6q-bosch-acc.h | 1 - include/configs/imx7-cm.h | 3 --- include/configs/imx8mm-cl-iot-gate.h | 3 --- include/configs/kontron-sl-mx6ul.h | 4 ---- include/configs/kontron-sl-mx8mm.h | 4 ---- include/configs/kp_imx53.h | 3 --- include/configs/kp_imx6q_tpc.h | 5 ----- include/configs/liteboard.h | 5 ----- include/configs/m53menlo.h | 7 ------- include/configs/meerkat96.h | 3 --- include/configs/mx53cx9020.h | 3 --- include/configs/mx53loco.h | 3 --- include/configs/mx53ppd.h | 3 --- include/configs/mx6cuboxi.h | 3 --- include/configs/mx6memcal.h | 1 - include/configs/mx6sabreauto.h | 3 --- include/configs/mx6sabresd.h | 5 ----- include/configs/mx6slevk.h | 5 ----- include/configs/mx6sllevk.h | 5 ----- include/configs/mx6sxsabreauto.h | 4 ---- include/configs/mx6sxsabresd.h | 4 ---- include/configs/mx6ul_14x14_evk.h | 5 ----- include/configs/mx7dsabresd.h | 3 --- include/configs/mx7ulp_com.h | 1 - include/configs/mys_6ulx.h | 3 --- include/configs/nitrogen6x.h | 3 --- include/configs/novena.h | 5 ----- include/configs/npi_imx6ull.h | 3 --- include/configs/o4-imx6ull-nano.h | 4 ---- include/configs/opos6uldev.h | 5 ----- include/configs/pcl063.h | 3 --- include/configs/pcl063_ull.h | 3 --- include/configs/pico-imx6.h | 3 --- include/configs/pico-imx6ul.h | 3 --- include/configs/pico-imx7d.h | 3 --- include/configs/somlabs_visionsom_6ull.h | 5 ----- include/configs/tbs2910.h | 5 ----- include/configs/tqma6.h | 3 --- include/configs/usbarmory.h | 3 --- include/configs/verdin-imx8mm.h | 3 --- include/configs/vining_2000.h | 1 - include/configs/wandboard.h | 3 --- include/configs/warp7.h | 1 - include/configs/xpress.h | 3 --- 60 files changed, 203 deletions(-)
diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 097f819e44a4..e5df82c68301 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -23,10 +23,6 @@
/* Network */
-/* USB Configs */ -/* Host */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - /* Framebuffer and LCD */
/* Command definition */ diff --git a/include/configs/aristainetos2.h b/include/configs/aristainetos2.h index 120ff9284ef6..8a66b1275dfe 100644 --- a/include/configs/aristainetos2.h +++ b/include/configs/aristainetos2.h @@ -411,9 +411,6 @@
/* DMA stuff, needed for GPMI/MXS NAND support */
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - /* UBI support */
#define CFG_ENV_FLAGS_LIST_STATIC "ethaddr:mw,serial#:sw,board_type:sw," \ diff --git a/include/configs/brppt2.h b/include/configs/brppt2.h index 38c98c5e21c4..d01f0d373163 100644 --- a/include/configs/brppt2.h +++ b/include/configs/brppt2.h @@ -78,7 +78,4 @@ BUR_COMMON_ENV \ #define CFG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR #define CFG_SYS_INIT_RAM_SIZE IRAM_SIZE
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - #endif /* __CONFIG_BRPP2_IMX6_H */ diff --git a/include/configs/cl-som-imx7.h b/include/configs/cl-som-imx7.h index 96058d48148b..8c363137b4fa 100644 --- a/include/configs/cl-som-imx7.h +++ b/include/configs/cl-som-imx7.h @@ -95,7 +95,4 @@ #define CFG_SYS_FSL_USDHC_NUM 2 #endif
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - #endif /* __CONFIG_H */ diff --git a/include/configs/cm_fx6.h b/include/configs/cm_fx6.h index fc2d59751c42..f7fd4c517b4f 100644 --- a/include/configs/cm_fx6.h +++ b/include/configs/cm_fx6.h @@ -134,9 +134,6 @@ /* Ethernet */ #define CFG_FEC_MXC_PHYADDR 0
-/* USB */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - /* Boot */ #define CFG_SYS_BOOTMAPSZ (8 << 20)
diff --git a/include/configs/colibri-imx6ull.h b/include/configs/colibri-imx6ull.h index c896a897cbf4..26b29bad6a18 100644 --- a/include/configs/colibri-imx6ull.h +++ b/include/configs/colibri-imx6ull.h @@ -117,10 +117,6 @@ #define CFG_SYS_NAND_BASE -1 #endif
-/* USB Configs */ - -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - /* USB Device Firmware Update support */ #define DFU_DEFAULT_POLL_TIMEOUT 300
diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index 87c973883c33..664b7c8ce0cd 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -21,10 +21,6 @@ #define CFG_SYS_FSL_ESDHC_ADDR 0 #define CFG_SYS_FSL_USDHC_NUM 2
-/* USB Configs */ -/* Host */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - /* Command definition */
#define BOOT_TARGET_DEVICES(func) \ diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 0e0665038b1f..c340dfb11894 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -159,8 +159,4 @@ #define CFG_SYS_NAND_BASE 0x40000000 #endif
-/* USB Configs */ - -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - #endif diff --git a/include/configs/dart_6ul.h b/include/configs/dart_6ul.h index 4d715d4f425e..2b329b4065c3 100644 --- a/include/configs/dart_6ul.h +++ b/include/configs/dart_6ul.h @@ -46,9 +46,6 @@ #define CFG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR #define CFG_SYS_INIT_RAM_SIZE IRAM_SIZE
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - #define ENV_MMC \ "mmcdev=" __stringify(MMC_ROOTFS_DEV) "\0" \ "mmcpart=" __stringify(MMC_ROOTFS_PART) "\0" \ diff --git a/include/configs/dh_imx6.h b/include/configs/dh_imx6.h index dc5ca9fc60cd..9b6f03f68563 100644 --- a/include/configs/dh_imx6.h +++ b/include/configs/dh_imx6.h @@ -30,9 +30,6 @@ /* UART */ #define CFG_MXC_UART_BASE UART1_BASE
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - /* USB Gadget (DFU, UMS) */ #if defined(CONFIG_CMD_DFU) || defined(CONFIG_CMD_USB_MASS_STORAGE) #define DFU_DEFAULT_POLL_TIMEOUT 300 diff --git a/include/configs/display5.h b/include/configs/display5.h index 2005a256d6e3..51fa2b03a2e6 100644 --- a/include/configs/display5.h +++ b/include/configs/display5.h @@ -287,5 +287,4 @@ /* The 0x120000 value corresponds to above SPI-NOR memory MAP */ #endif
-#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #endif /* __CONFIG_H */ diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index e378374a004a..61c0d755a8d9 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -17,9 +17,6 @@
#define PHYS_SDRAM_SIZE (1u * 1024 * 1024 * 1024)
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - /* MMC Configs */ #define CFG_SYS_FSL_ESDHC_ADDR 0
diff --git a/include/configs/ge_b1x5v2.h b/include/configs/ge_b1x5v2.h index 0bf31897a744..f3d85c9c11e8 100644 --- a/include/configs/ge_b1x5v2.h +++ b/include/configs/ge_b1x5v2.h @@ -23,9 +23,6 @@ #define CONSOLE_DEVICE "ttymxc2" /* Base board debug connector */ #endif
-/* USB */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - /* Memory */ #define PHYS_SDRAM MMDC0_ARB_BASE_ADDR
diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index f884d74d9ca9..d112825ad1ff 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -35,9 +35,6 @@
/* Various command support */
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - /* Miscellaneous configurable options */
/* Memory configuration */ diff --git a/include/configs/imx6_logic.h b/include/configs/imx6_logic.h index 19613e838fb3..75997469cd91 100644 --- a/include/configs/imx6_logic.h +++ b/include/configs/imx6_logic.h @@ -114,11 +114,6 @@ #define CFG_SYS_NAND_BASE 0x40000000 #define CFG_SYS_NAND_U_BOOT_START CONFIG_TEXT_BASE
-/* USB Configs */ -#ifdef CONFIG_CMD_USB -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#endif - /* Falcon Mode */
/* Falcon Mode - MMC support: args@1MB kernel@2MB */ diff --git a/include/configs/imx6dl-mamoj.h b/include/configs/imx6dl-mamoj.h index 6651653d5e9c..8abb58b06918 100644 --- a/include/configs/imx6dl-mamoj.h +++ b/include/configs/imx6dl-mamoj.h @@ -42,9 +42,6 @@ /* Ethernet */ #define CFG_FEC_MXC_PHYADDR 1
-/* USB */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - /* Falcon */
/* MMC support: args@1MB kernel@2MB */ diff --git a/include/configs/imx6q-bosch-acc.h b/include/configs/imx6q-bosch-acc.h index aa365dc9a795..fab5063b73f4 100644 --- a/include/configs/imx6q-bosch-acc.h +++ b/include/configs/imx6q-bosch-acc.h @@ -110,6 +110,5 @@ #endif #endif
#endif /* __IMX6Q_ACC_H */ diff --git a/include/configs/imx7-cm.h b/include/configs/imx7-cm.h index 131f18290b90..36c4c5b8b50a 100644 --- a/include/configs/imx7-cm.h +++ b/include/configs/imx7-cm.h @@ -77,7 +77,4 @@ #define CFG_SYS_FSL_ESDHC_ADDR USDHC1_BASE_ADDR #define CFG_SYS_FSL_USDHC_NUM 2
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - #endif /* __CONFIG_H */ diff --git a/include/configs/imx8mm-cl-iot-gate.h b/include/configs/imx8mm-cl-iot-gate.h index 6442e3d570f4..146f7945719f 100644 --- a/include/configs/imx8mm-cl-iot-gate.h +++ b/include/configs/imx8mm-cl-iot-gate.h @@ -137,7 +137,4 @@
#define CFG_FEC_MXC_PHYADDR -1 /* Auto search of PHY on MII */
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - #endif /*__IMX8MM_CL_IOT_GATE_H*/ diff --git a/include/configs/kontron-sl-mx6ul.h b/include/configs/kontron-sl-mx6ul.h index e68c667c5057..015df01db4e6 100644 --- a/include/configs/kontron-sl-mx6ul.h +++ b/include/configs/kontron-sl-mx6ul.h @@ -24,10 +24,6 @@ /* Board and environment settings */ #define CFG_MXC_UART_BASE UART4_BASE
-#ifdef CONFIG_USB_EHCI_HCD -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#endif - /* Boot order for distro boot */ #define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 1) \ diff --git a/include/configs/kontron-sl-mx8mm.h b/include/configs/kontron-sl-mx8mm.h index be1f70a9a598..3a129c5cce77 100644 --- a/include/configs/kontron-sl-mx8mm.h +++ b/include/configs/kontron-sl-mx8mm.h @@ -24,10 +24,6 @@
-#ifdef CONFIG_USB_EHCI_HCD -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#endif - /* GUID for capsule updatable firmware image */ #define KONTRON_SL_MX8MM_FIT_IMAGE_GUID \ EFI_GUID(0xd488e45a, 0x4929, 0x4b55, 0x8c, 0x14, \ diff --git a/include/configs/kp_imx53.h b/include/configs/kp_imx53.h index 91caf03091c4..48adff3f03a7 100644 --- a/include/configs/kp_imx53.h +++ b/include/configs/kp_imx53.h @@ -10,9 +10,6 @@ #include <asm/arch/imx-regs.h> #include <linux/sizes.h>
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - /* Command definition */
#define CFG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/kp_imx6q_tpc.h b/include/configs/kp_imx6q_tpc.h index 74f6e4e9f963..c0cb3db23e7a 100644 --- a/include/configs/kp_imx6q_tpc.h +++ b/include/configs/kp_imx6q_tpc.h @@ -16,11 +16,6 @@
/* FEC ethernet */
-/* USB Configs */ -#ifdef CONFIG_CMD_USB -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#endif - #define CFG_EXTRA_ENV_SETTINGS \ "console=ttymxc0,115200\0" \ "fdt_addr=0x18000000\0" \ diff --git a/include/configs/liteboard.h b/include/configs/liteboard.h index 25c30e6c6a5d..fc6bc6b28baa 100644 --- a/include/configs/liteboard.h +++ b/include/configs/liteboard.h @@ -93,11 +93,6 @@
/* FLASH and environment organization */
-/* USB Configs */ -#ifdef CONFIG_CMD_USB -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#endif - #ifdef CONFIG_CMD_NET #define CFG_FEC_ENET_DEV 0
diff --git a/include/configs/m53menlo.h b/include/configs/m53menlo.h index 51ce030d831e..b5943f48c69f 100644 --- a/include/configs/m53menlo.h +++ b/include/configs/m53menlo.h @@ -66,13 +66,6 @@ #define CFG_SYS_I2C_RTC_ADDR 0x68 #endif
-/* - * USB - */ -#ifdef CONFIG_CMD_USB -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#endif - /* LVDS display */ #define CFG_SYS_LDB_CLOCK 33260000
diff --git a/include/configs/meerkat96.h b/include/configs/meerkat96.h index 6ffc1282411a..8e248177b1ca 100644 --- a/include/configs/meerkat96.h +++ b/include/configs/meerkat96.h @@ -23,7 +23,4 @@
/* Environment configs */
-/* USB configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - #endif diff --git a/include/configs/mx53cx9020.h b/include/configs/mx53cx9020.h index 38bafc5156dd..2ee5cc40e541 100644 --- a/include/configs/mx53cx9020.h +++ b/include/configs/mx53cx9020.h @@ -21,9 +21,6 @@
#define BOOT_TARGET_DEVICES(func) \ diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index e9340c59ae1b..cec3658b1891 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -16,9 +16,6 @@ /* MMC Configs */ #define CFG_SYS_FSL_ESDHC_ADDR 0
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - /* PMIC Controller */ #define CFG_SYS_DIALOG_PMIC_I2C_ADDR 0x48 #define CFG_SYS_FSL_PMIC_I2C_ADDR 0x8 diff --git a/include/configs/mx53ppd.h b/include/configs/mx53ppd.h index e0bfbbb459cf..6e1cbec0c1f4 100644 --- a/include/configs/mx53ppd.h +++ b/include/configs/mx53ppd.h @@ -11,9 +11,6 @@
#define PPD_CONFIG_NFS \ diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index f0d6405d3012..068b9e4d25f1 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -14,9 +14,6 @@ /* MMC Configs */ #define CFG_SYS_FSL_ESDHC_ADDR USDHC2_BASE_ADDR
-/* USB */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - /* Command definition */
#define CFG_MXC_UART_BASE UART1_BASE diff --git a/include/configs/mx6memcal.h b/include/configs/mx6memcal.h index f2edd13eb881..a966c8b2a446 100644 --- a/include/configs/mx6memcal.h +++ b/include/configs/mx6memcal.h @@ -31,6 +31,5 @@ #define CFG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR #define CFG_SYS_INIT_RAM_SIZE IRAM_SIZE
-#define CFG_MXC_USB_PORTSC PORT_PTS_UTMI
#endif /* __CONFIG_H */ diff --git a/include/configs/mx6sabreauto.h b/include/configs/mx6sabreauto.h index eb963cbb0b3b..e491af3e9278 100644 --- a/include/configs/mx6sabreauto.h +++ b/include/configs/mx6sabreauto.h @@ -11,9 +11,6 @@ #define CFG_MXC_UART_BASE UART4_BASE #define CONSOLE_DEV "ttymxc3"
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - #define CFG_SYS_I2C_PCA953X_WIDTH { {0x30, 8}, {0x32, 8}, {0x34, 8} }
#include "mx6sabre_common.h" diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index 9160f878f4b3..e34947c94d00 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -24,9 +24,4 @@ #define CFG_PCIE_IMX_POWER_GPIO IMX_GPIO_NR(3, 19) #endif
-/* USB Configs */ -#ifdef CONFIG_CMD_USB -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#endif - #endif /* __MX6SABRESD_CONFIG_H */ diff --git a/include/configs/mx6slevk.h b/include/configs/mx6slevk.h index 65c6cdd4b87b..d4e66a39882c 100644 --- a/include/configs/mx6slevk.h +++ b/include/configs/mx6slevk.h @@ -88,11 +88,6 @@
/* Environment organization */
-/* USB Configs */ -#ifdef CONFIG_CMD_USB -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#endif - #define CFG_SYS_FSL_USDHC_NUM 3
#endif /* __CONFIG_H */ diff --git a/include/configs/mx6sllevk.h b/include/configs/mx6sllevk.h index 290996b51bc7..0ba4054bbe4a 100644 --- a/include/configs/mx6sllevk.h +++ b/include/configs/mx6sllevk.h @@ -92,10 +92,5 @@ #define CFG_SYS_FSL_ESDHC_ADDR USDHC1_BASE_ADDR #define CFG_SYS_FSL_USDHC_NUM 3
-/* USB Configs */ -#ifdef CONFIG_CMD_USB -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#endif - #include <linux/stringify.h> #endif /* __CONFIG_H */ diff --git a/include/configs/mx6sxsabreauto.h b/include/configs/mx6sxsabreauto.h index 4e163d28e63d..36d82e81d5dd 100644 --- a/include/configs/mx6sxsabreauto.h +++ b/include/configs/mx6sxsabreauto.h @@ -95,10 +95,6 @@ #define IMX_FEC_BASE ENET2_BASE_ADDR #define CFG_FEC_MXC_PHYADDR 0x0
-#ifdef CONFIG_CMD_USB -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#endif - #define CFG_SYS_FSL_USDHC_NUM 2
#endif /* __CONFIG_H */ diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index b43a1d813151..844becbfd2ce 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -117,10 +117,6 @@
-#ifdef CONFIG_CMD_USB -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#endif - #ifdef CONFIG_CMD_PCI #define CFG_PCIE_IMX_PERST_GPIO IMX_GPIO_NR(2, 0) #define CFG_PCIE_IMX_POWER_GPIO IMX_GPIO_NR(2, 1) diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index fd0c87ffb012..3716dc75b966 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -114,11 +114,6 @@
/* environment organization */
-/* USB Configs */ -#ifdef CONFIG_CMD_USB -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#endif - #ifdef CONFIG_CMD_NET #define CFG_FEC_ENET_DEV 1
diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index 94bee75fdea5..f5ab47207504 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -98,7 +98,4 @@ /* DMA stuff, needed for GPMI/MXS NAND support */ #endif
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - #endif /* __CONFIG_H */ diff --git a/include/configs/mx7ulp_com.h b/include/configs/mx7ulp_com.h index a310c64e7948..f8e3950fa321 100644 --- a/include/configs/mx7ulp_com.h +++ b/include/configs/mx7ulp_com.h @@ -51,5 +51,4 @@ #define CFG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR #define CFG_SYS_INIT_RAM_SIZE SZ_256K
-#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #endif /* __CONFIG_H */ diff --git a/include/configs/mys_6ulx.h b/include/configs/mys_6ulx.h index 8defdfc4fda6..ddd46c8f945b 100644 --- a/include/configs/mys_6ulx.h +++ b/include/configs/mys_6ulx.h @@ -29,9 +29,6 @@ /* NAND */ #define CFG_SYS_NAND_BASE 0x40000000
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - #define CFG_EXTRA_ENV_SETTINGS \ "console=ttymxc0,115200n8\0" \ "fdt_addr_r=0x82000000\0" \ diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index a8ad85050f79..23eefaffc721 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -18,9 +18,6 @@ #define IMX_FEC_BASE ENET_BASE_ADDR #define CFG_FEC_MXC_PHYADDR 6
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - #ifdef CONFIG_CMD_MMC #define DISTRO_BOOT_DEV_MMC(func) func(MMC, mmc, 0) func(MMC, mmc, 1) #else diff --git a/include/configs/novena.h b/include/configs/novena.h index 144cf1b4a4b8..059b8104e4b4 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -51,11 +51,6 @@ /* UART */ #define CFG_MXC_UART_BASE UART2_BASE
-/* USB Configs */ -#ifdef CONFIG_CMD_USB -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#endif - /* Extra U-Boot environment. */ #define CFG_EXTRA_ENV_SETTINGS \ "fdt_high=0xffffffff\0" \ diff --git a/include/configs/npi_imx6ull.h b/include/configs/npi_imx6ull.h index f71e2657076b..1caa63f0227b 100644 --- a/include/configs/npi_imx6ull.h +++ b/include/configs/npi_imx6ull.h @@ -28,9 +28,6 @@ /* NAND */ #define CFG_SYS_NAND_BASE 0x40000000
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - #ifdef CONFIG_CMD_NET #define CFG_FEC_MXC_PHYADDR 0x1 #endif diff --git a/include/configs/o4-imx6ull-nano.h b/include/configs/o4-imx6ull-nano.h index 9050da8738b1..f5a4898f90e6 100644 --- a/include/configs/o4-imx6ull-nano.h +++ b/include/configs/o4-imx6ull-nano.h @@ -11,10 +11,6 @@ #define CFG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR #define CFG_SYS_INIT_RAM_SIZE IRAM_SIZE
-#if IS_ENABLED(CONFIG_CMD_USB) -# define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#endif /* CONFIG_CMD_USB */ - #define CFG_EXTRA_ENV_SETTINGS \ "mmcdev=0\0" \ "mmcpart=2\0" \ diff --git a/include/configs/opos6uldev.h b/include/configs/opos6uldev.h index 12020d31e1c7..fd945235af37 100644 --- a/include/configs/opos6uldev.h +++ b/include/configs/opos6uldev.h @@ -17,11 +17,6 @@ #define CFG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR #define CFG_SYS_INIT_RAM_SIZE IRAM_SIZE
-/* USB */ -#ifdef CONFIG_USB_EHCI_MX6 -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#endif - /* LCD */ #define MXS_LCDIF_BASE MX6UL_LCDIF1_BASE_ADDR
diff --git a/include/configs/pcl063.h b/include/configs/pcl063.h index 2a729c3e4544..0c96506b5fbe 100644 --- a/include/configs/pcl063.h +++ b/include/configs/pcl063.h @@ -41,9 +41,6 @@ /* NAND */ #define CFG_SYS_NAND_BASE 0x40000000
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - #define CFG_EXTRA_ENV_SETTINGS \ "console=ttymxc0,115200n8\0" \ "fdt_addr_r=0x82000000\0" \ diff --git a/include/configs/pcl063_ull.h b/include/configs/pcl063_ull.h index afa8e7aeb716..0f265adc5dca 100644 --- a/include/configs/pcl063_ull.h +++ b/include/configs/pcl063_ull.h @@ -43,9 +43,6 @@ /* NAND */ #define CFG_SYS_NAND_BASE 0x40000000
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - #define ENV_MMC \ "mmcdev=" __stringify(MMC_ROOTFS_DEV) "\0" \ "mmcpart=" __stringify(MMC_ROOTFS_PART) "\0" \ diff --git a/include/configs/pico-imx6.h b/include/configs/pico-imx6.h index 6ccb3dc19021..500dd8c069ae 100644 --- a/include/configs/pico-imx6.h +++ b/include/configs/pico-imx6.h @@ -15,9 +15,6 @@ /* MMC Configuration */ #define CFG_SYS_FSL_ESDHC_ADDR USDHC3_BASE_ADDR
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - #define DFU_DEFAULT_POLL_TIMEOUT 300
#define CFG_DFU_ENV_SETTINGS \ diff --git a/include/configs/pico-imx6ul.h b/include/configs/pico-imx6ul.h index ef8281440e5d..37f4c7d8a098 100644 --- a/include/configs/pico-imx6ul.h +++ b/include/configs/pico-imx6ul.h @@ -21,9 +21,6 @@ /* MMC Configs */ #define CFG_SYS_FSL_ESDHC_ADDR USDHC1_BASE_ADDR
#define CFG_DFU_ENV_SETTINGS \ diff --git a/include/configs/pico-imx7d.h b/include/configs/pico-imx7d.h index 21ec7fd3362c..89850d8e4a7e 100644 --- a/include/configs/pico-imx7d.h +++ b/include/configs/pico-imx7d.h @@ -105,7 +105,4 @@
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - #endif diff --git a/include/configs/somlabs_visionsom_6ull.h b/include/configs/somlabs_visionsom_6ull.h index aa09528acd97..c8fdb40d011b 100644 --- a/include/configs/somlabs_visionsom_6ull.h +++ b/include/configs/somlabs_visionsom_6ull.h @@ -59,11 +59,6 @@
-/* USB Configs */ -#ifdef CONFIG_CMD_USB -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#endif - #ifdef CONFIG_CMD_NET #define CFG_FEC_MXC_PHYADDR 0x1 #endif diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 256331ae1733..9ef774afd0f9 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -25,11 +25,6 @@ #define CFG_PCIE_IMX_PERST_GPIO IMX_GPIO_NR(7, 12) #endif
-/* USB */ -#ifdef CONFIG_CMD_USB -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) -#endif /* CONFIG_CMD_USB */ - #define CFG_EXTRA_ENV_SETTINGS \ BOOTENV \ "bootargs_mmc1=console=ttymxc0,115200 di0_primary console=tty1\0" \ diff --git a/include/configs/tqma6.h b/include/configs/tqma6.h index b4a06a75c538..e85c801e4fbe 100644 --- a/include/configs/tqma6.h +++ b/include/configs/tqma6.h @@ -29,9 +29,6 @@ /* MMC Configs */ #define CFG_SYS_FSL_ESDHC_ADDR 0
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - #if defined(CONFIG_TQMA6X_MMC_BOOT)
#define TQMA6_UBOOT_OFFSET SZ_1K diff --git a/include/configs/usbarmory.h b/include/configs/usbarmory.h index 1d7caaa1448f..b895022ee9cc 100644 --- a/include/configs/usbarmory.h +++ b/include/configs/usbarmory.h @@ -22,9 +22,6 @@ /* SD/MMC */ #define CFG_SYS_FSL_ESDHC_ADDR 0
-/* USB */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - /* Linux boot */
#define BOOT_TARGET_DEVICES(func) func(MMC, mmc, 0) diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index 12d2b6823058..b018bbe29dd1 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -63,7 +63,4 @@ #define PHYS_SDRAM_2 0x100000000 #define PHYS_SDRAM_2_SIZE (long)(SZ_1G)
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - #endif /* __VERDIN_IMX8MM_H */ diff --git a/include/configs/vining_2000.h b/include/configs/vining_2000.h index 3c2d7e668917..2cf7bc70d8de 100644 --- a/include/configs/vining_2000.h +++ b/include/configs/vining_2000.h @@ -36,7 +36,6 @@ /* Network */ #define CFG_FEC_MXC_PHYADDR 0x0
#ifdef CONFIG_CMD_PCI #define CFG_PCIE_IMX_PERST_GPIO IMX_GPIO_NR(4, 6) diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index d64c4262bd69..b5b342b35383 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -16,9 +16,6 @@ #define CFG_SYS_FSL_USDHC_NUM 2 #define CFG_SYS_FSL_ESDHC_ADDR 0
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - #define CFG_EXTRA_ENV_SETTINGS \ "console=ttymxc0\0" \ "splashpos=m,m\0" \ diff --git a/include/configs/warp7.h b/include/configs/warp7.h index 0da9250c3b78..a5278d1cb9b8 100644 --- a/include/configs/warp7.h +++ b/include/configs/warp7.h @@ -92,7 +92,6 @@
#define CFG_SYS_FSL_USDHC_NUM 1
/* USB Device Firmware Update support */ #define DFU_DEFAULT_POLL_TIMEOUT 300 diff --git a/include/configs/xpress.h b/include/configs/xpress.h index bb0a30c4344f..8efebf77c3d6 100644 --- a/include/configs/xpress.h +++ b/include/configs/xpress.h @@ -27,9 +27,6 @@
/* Environment is in stored in the eMMC boot partition */
-/* USB Configs */ -#define CFG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) - #define CFG_FEC_ENET_DEV 0 #define CFG_FEC_MXC_PHYADDR 0x0
Changes since v2:
definition.
Reviewed-by: Soeren Moch smoch@web.de
Thanks, Soeren
I kept the mx5 lines and applied all, thanks.
Fabio Estevam
Soeren Moch
