[U-Boot] [PATCH v2] net: usb: r8152: Add DM support
Add support for driver model, so that CONFIG_DM_ETH can be defined and used with this driver.
This patch also adds the read_rom_hwaddr() callback so that the ROM MAC address will be used to the DM part of this driver.
Signed-off-by: Stefan Roese sr@denx.de Cc: Stephen Warren swarren@nvidia.com Cc: Ted Chen tedchen@realtek.com Reviewed-by: Simon Glass sjg@chromium.org Cc: Joe Hershberger joe.hershberger@ni.com --- v2: - Return all errors from usb_ether_receive() in r8152_eth_recv() - Use ENOSPC as error return code in r8152_eth_recv() instead of EINVAL - Return error if rtl_ops_init() fails
drivers/usb/eth/r8152.c | 237 ++++++++++++++++++++++++++++++++++++++++----- drivers/usb/eth/r8152.h | 4 + drivers/usb/eth/r8152_fw.c | 2 + 3 files changed, 221 insertions(+), 22 deletions(-)
diff --git a/drivers/usb/eth/r8152.c b/drivers/usb/eth/r8152.c index 325b70c..070aadf 100644 --- a/drivers/usb/eth/r8152.c +++ b/drivers/usb/eth/r8152.c @@ -3,9 +3,10 @@ * * SPDX-License-Identifier: GPL-2.0 * - */ + */
#include <common.h> +#include <dm.h> #include <errno.h> #include <malloc.h> #include <usb.h> @@ -15,6 +16,7 @@ #include "usb_ether.h" #include "r8152.h"
+#ifndef CONFIG_DM_ETH /* local vars */ static int curr_eth_dev; /* index for name of next device detected */
@@ -23,12 +25,6 @@ struct r8152_dongle { unsigned short product; };
-struct r8152_version { - unsigned short tcr; - unsigned short version; - bool gmii; -}; - static const struct r8152_dongle const r8152_dongles[] = { /* Realtek */ { 0x0bda, 0x8050 }, @@ -54,6 +50,13 @@ static const struct r8152_dongle const r8152_dongles[] = { /* Nvidia */ { 0x0955, 0x09ff }, }; +#endif + +struct r8152_version { + unsigned short tcr; + unsigned short version; + bool gmii; +};
static const struct r8152_version const r8152_versions[] = { { 0x4c00, RTL_VER_01, 0 }, @@ -1176,11 +1179,8 @@ static int rtl_ops_init(struct r8152 *tp) return ret; }
-static int r8152_init(struct eth_device *eth, bd_t *bd) +static int r8152_init_common(struct r8152 *tp) { - struct ueth_data *dev = (struct ueth_data *)eth->priv; - struct r8152 *tp = (struct r8152 *)dev->dev_priv; - u8 speed; int timeout = 0; int link_detected; @@ -1210,14 +1210,11 @@ static int r8152_init(struct eth_device *eth, bd_t *bd) return 0; }
-static int r8152_send(struct eth_device *eth, void *packet, int length) +static int r8152_send_common(struct ueth_data *ueth, void *packet, int length) { - struct ueth_data *dev = (struct ueth_data *)eth->priv; - + struct usb_device *udev = ueth->pusb_dev; u32 opts1, opts2 = 0; - int err; - int actual_len; unsigned char msg[PKTSIZE + sizeof(struct tx_desc)]; struct tx_desc *tx_desc = (struct tx_desc *)msg; @@ -1231,18 +1228,31 @@ static int r8152_send(struct eth_device *eth, void *packet, int length)
memcpy(msg + sizeof(struct tx_desc), (void *)packet, length);
- err = usb_bulk_msg(dev->pusb_dev, - usb_sndbulkpipe(dev->pusb_dev, dev->ep_out), - (void *)msg, - length + sizeof(struct tx_desc), - &actual_len, - USB_BULK_SEND_TIMEOUT); + err = usb_bulk_msg(udev, usb_sndbulkpipe(udev, ueth->ep_out), + (void *)msg, length + sizeof(struct tx_desc), + &actual_len, USB_BULK_SEND_TIMEOUT); debug("Tx: len = %zu, actual = %u, err = %d\n", length + sizeof(struct tx_desc), actual_len, err);
return err; }
+#ifndef CONFIG_DM_ETH +static int r8152_init(struct eth_device *eth, bd_t *bd) +{ + struct ueth_data *dev = (struct ueth_data *)eth->priv; + struct r8152 *tp = (struct r8152 *)dev->dev_priv; + + return r8152_init_common(tp); +} + +static int r8152_send(struct eth_device *eth, void *packet, int length) +{ + struct ueth_data *dev = (struct ueth_data *)eth->priv; + + return r8152_send_common(dev, packet, length); +} + static int r8152_recv(struct eth_device *eth) { struct ueth_data *dev = (struct ueth_data *)eth->priv; @@ -1454,3 +1464,186 @@ int r8152_eth_get_info(struct usb_device *dev, struct ueth_data *ss, debug("MAC %pM\n", eth->enetaddr); return 1; } +#endif /* !CONFIG_DM_ETH */ + +#ifdef CONFIG_DM_ETH +static int r8152_eth_start(struct udevice *dev) +{ + struct r8152 *tp = dev_get_priv(dev); + + debug("** %s (%d)\n", __func__, __LINE__); + + return r8152_init_common(tp); +} + +void r8152_eth_stop(struct udevice *dev) +{ + struct r8152 *tp = dev_get_priv(dev); + + debug("** %s (%d)\n", __func__, __LINE__); + + tp->rtl_ops.disable(tp); +} + +int r8152_eth_send(struct udevice *dev, void *packet, int length) +{ + struct r8152 *tp = dev_get_priv(dev); + + return r8152_send_common(&tp->ueth, packet, length); +} + +int r8152_eth_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct r8152 *tp = dev_get_priv(dev); + struct ueth_data *ueth = &tp->ueth; + uint8_t *ptr; + int ret, len; + struct rx_desc *rx_desc; + u16 packet_len; + + len = usb_ether_get_rx_bytes(ueth, &ptr); + debug("%s: first try, len=%d\n", __func__, len); + if (!len) { + if (!(flags & ETH_RECV_CHECK_DEVICE)) + return -EAGAIN; + ret = usb_ether_receive(ueth, RTL8152_AGG_BUF_SZ); + if (ret) + return ret; + + len = usb_ether_get_rx_bytes(ueth, &ptr); + debug("%s: second try, len=%d\n", __func__, len); + } + + rx_desc = (struct rx_desc *)ptr; + packet_len = le32_to_cpu(rx_desc->opts1) & RX_LEN_MASK; + packet_len -= CRC_SIZE; + + if (packet_len > len - (sizeof(struct rx_desc) + CRC_SIZE)) { + debug("Rx: too large packet: %d\n", packet_len); + goto err; + } + + *packetp = ptr + sizeof(struct rx_desc); + return packet_len; + +err: + usb_ether_advance_rxbuf(ueth, -1); + return -ENOSPC; +} + +static int r8152_free_pkt(struct udevice *dev, uchar *packet, int packet_len) +{ + struct r8152 *tp = dev_get_priv(dev); + + packet_len += sizeof(struct rx_desc) + CRC_SIZE; + packet_len = ALIGN(packet_len, 8); + usb_ether_advance_rxbuf(&tp->ueth, packet_len); + + return 0; +} + +static int r8152_write_hwaddr(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_platdata(dev); + struct r8152 *tp = dev_get_priv(dev); + + unsigned char enetaddr[8] = { 0 }; + + debug("** %s (%d)\n", __func__, __LINE__); + memcpy(enetaddr, pdata->enetaddr, ETH_ALEN); + + ocp_write_byte(tp, MCU_TYPE_PLA, PLA_CRWECR, CRWECR_CONFIG); + pla_ocp_write(tp, PLA_IDR, BYTE_EN_SIX_BYTES, 8, enetaddr); + ocp_write_byte(tp, MCU_TYPE_PLA, PLA_CRWECR, CRWECR_NORAML); + + debug("MAC %pM\n", pdata->enetaddr); + return 0; +} + +int r8152_read_rom_hwaddr(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_platdata(dev); + struct r8152 *tp = dev_get_priv(dev); + + debug("** %s (%d)\n", __func__, __LINE__); + r8152_read_mac(tp, pdata->enetaddr); + return 0; +} + +static int r8152_eth_probe(struct udevice *dev) +{ + struct usb_device *udev = dev_get_parent_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + struct r8152 *tp = dev_get_priv(dev); + struct ueth_data *ueth = &tp->ueth; + int ret; + + tp->udev = udev; + r8152_read_mac(tp, pdata->enetaddr); + + r8152b_get_version(tp); + + ret = rtl_ops_init(tp); + if (ret) + return ret; + + tp->rtl_ops.init(tp); + tp->rtl_ops.up(tp); + + rtl8152_set_speed(tp, AUTONEG_ENABLE, + tp->supports_gmii ? SPEED_1000 : SPEED_100, + DUPLEX_FULL); + + return usb_ether_register(dev, ueth, RTL8152_AGG_BUF_SZ); +} + +static const struct eth_ops r8152_eth_ops = { + .start = r8152_eth_start, + .send = r8152_eth_send, + .recv = r8152_eth_recv, + .free_pkt = r8152_free_pkt, + .stop = r8152_eth_stop, + .write_hwaddr = r8152_write_hwaddr, + .read_rom_hwaddr = r8152_read_rom_hwaddr, +}; + +U_BOOT_DRIVER(r8152_eth) = { + .name = "r8152_eth", + .id = UCLASS_ETH, + .probe = r8152_eth_probe, + .ops = &r8152_eth_ops, + .priv_auto_alloc_size = sizeof(struct r8152), + .platdata_auto_alloc_size = sizeof(struct eth_pdata), +}; + +static const struct usb_device_id r8152_eth_id_table[] = { + /* Realtek */ + { USB_DEVICE(0x0bda, 0x8050) }, + { USB_DEVICE(0x0bda, 0x8152) }, + { USB_DEVICE(0x0bda, 0x8153) }, + + /* Samsung */ + { USB_DEVICE(0x04e8, 0xa101) }, + + /* Lenovo */ + { USB_DEVICE(0x17ef, 0x304f) }, + { USB_DEVICE(0x17ef, 0x3052) }, + { USB_DEVICE(0x17ef, 0x3054) }, + { USB_DEVICE(0x17ef, 0x3057) }, + { USB_DEVICE(0x17ef, 0x7205) }, + { USB_DEVICE(0x17ef, 0x720a) }, + { USB_DEVICE(0x17ef, 0x720b) }, + { USB_DEVICE(0x17ef, 0x720c) }, + + /* TP-LINK */ + { USB_DEVICE(0x2357, 0x0601) }, + + /* Nvidia */ + { USB_DEVICE(0x0955, 0x09ff) }, + + { } /* Terminating entry */ +}; + +U_BOOT_USB_DEVICE(r8152_eth, r8152_eth_id_table); +#endif /* CONFIG_DM_ETH */ + diff --git a/drivers/usb/eth/r8152.h b/drivers/usb/eth/r8152.h index cd44da2..784ad99 100644 --- a/drivers/usb/eth/r8152.h +++ b/drivers/usb/eth/r8152.h @@ -594,6 +594,10 @@ struct r8152 { u16 ocp_base;
u8 version; + +#ifdef CONFIG_DM_ETH + struct ueth_data ueth; +#endif };
int generic_ocp_write(struct r8152 *tp, u16 index, u16 byteen, diff --git a/drivers/usb/eth/r8152_fw.c b/drivers/usb/eth/r8152_fw.c index f820b16..b6c8228 100644 --- a/drivers/usb/eth/r8152_fw.c +++ b/drivers/usb/eth/r8152_fw.c @@ -5,7 +5,9 @@ * */ #include <common.h> +#include <dm.h> #include <errno.h> +#include "usb_ether.h" #include "r8152.h"
static u8 r8152b_pla_patch_a[] = {
Thanks Joe. Will you pull this patch or who is responsible for those USB-ETH related patches? Marek?
Thanks, Stefan
This is not really clear to me either. I don't see the patch in my mailbox though, so either repost and CC me or wait for Joe.
Nevermind, applied to u-boot-usb/master, thanks.
Joe Hershberger
Stefan Roese
