[PATCH] smegw01: Remove misuse of CONFIG_ENV_IS_NOWHERE
When using a list of writeable variables, the initial values come from the built-in default environment since commit 5ab81058364b ("env: Complete generic support for writable list").
Remove unnecessary misuse of CONFIG_ENV_IS_NOWHERE as default environment.
Based on the fix done by commit b16fd7f75f6d ("imx6q: acc: Remove misuse of env is nowhere driver").
Signed-off-by: Eduard Strehlau eduard@lionizers.com Signed-off-by: Fabio Estevam festevam@denx.de --- board/storopack/smegw01/smegw01.c | 15 --------------- configs/smegw01_defconfig | 1 - 2 files changed, 16 deletions(-)
diff --git a/board/storopack/smegw01/smegw01.c b/board/storopack/smegw01/smegw01.c index 7b2c50a61e..345191b31c 100644 --- a/board/storopack/smegw01/smegw01.c +++ b/board/storopack/smegw01/smegw01.c @@ -111,18 +111,3 @@ uint mmc_get_env_part(struct mmc *mmc) return part; }
-enum env_location env_get_location(enum env_operation op, int prio) -{ - if (op == ENVOP_SAVE || op == ENVOP_ERASE) - return ENVL_MMC; - - switch (prio) { - case 0: - return ENVL_NOWHERE; - - case 1: - return ENVL_MMC; - } - - return ENVL_UNKNOWN; -} diff --git a/configs/smegw01_defconfig b/configs/smegw01_defconfig index 5cfd3d2715..13665ecfd3 100644 --- a/configs/smegw01_defconfig +++ b/configs/smegw01_defconfig @@ -48,7 +48,6 @@ CONFIG_CMD_SQUASHFS=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_NOWHERE=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_DEV=1
From: Eduard Strehlau eduard@lionizers.com When using a list of writeable variables, the initial values come from the built-in default environment since commit 5ab81058364b ("env: Complete generic support for writable list"). Remove unnecessary misuse of CONFIG_ENV_IS_NOWHERE as default environment. Based on the fix done by commit b16fd7f75f6d ("imx6q: acc: Remove misuse of env is nowhere driver"). Signed-off-by: Eduard Strehlau eduard@lionizers.com Signed-off-by: Fabio Estevam festevam@denx.de
Best regards, Stefano Babic
Fabio Estevam
sbabic@denx.de
