[U-Boot-Users] [PATCH] POWERPC 86xx: Move BAT setup code to C
This is needed because we will be possibly be locating devices at physical addresses above 32bits, and the asm preprocessing does not appear to deal with ULL constants properly. We now call write_bat in lib_ppc/bat_rw.c.
Signed-off-by: Becky Bruce becky.bruce@freescale.com --- cpu/mpc86xx/cpu_init.c | 25 ++++++++++ cpu/mpc86xx/start.S | 119 ------------------------------------------------ 2 files changed, 25 insertions(+), 119 deletions(-)
diff --git a/cpu/mpc86xx/cpu_init.c b/cpu/mpc86xx/cpu_init.c index 78ba1ea..1fda3fe 100644 --- a/cpu/mpc86xx/cpu_init.c +++ b/cpu/mpc86xx/cpu_init.c @@ -26,8 +26,10 @@ * cpu_init.c - low level cpu init */
+#include <config.h> #include <common.h> #include <mpc86xx.h> +#include <asm/mmu.h> #include <asm/fsl_law.h>
DECLARE_GLOBAL_DATA_PTR; @@ -121,3 +123,26 @@ int cpu_init_r(void) { return 0; } + +/* Set up BAT registers */ +void setup_bats(void) +{ + write_bat(DBAT0, CFG_DBAT0U, CFG_DBAT0L); + write_bat(IBAT0, CFG_IBAT0U, CFG_IBAT0L); + write_bat(DBAT1, CFG_DBAT1U, CFG_DBAT1L); + write_bat(IBAT1, CFG_IBAT1U, CFG_IBAT1L); + write_bat(DBAT2, CFG_DBAT2U, CFG_DBAT2L); + write_bat(IBAT2, CFG_IBAT2U, CFG_IBAT2L); + write_bat(DBAT3, CFG_DBAT3U, CFG_DBAT3L); + write_bat(IBAT3, CFG_IBAT3U, CFG_IBAT3L); + write_bat(DBAT4, CFG_DBAT4U, CFG_DBAT4L); + write_bat(IBAT4, CFG_IBAT4U, CFG_IBAT4L); + write_bat(DBAT5, CFG_DBAT5U, CFG_DBAT5L); + write_bat(IBAT5, CFG_IBAT5U, CFG_IBAT5L); + write_bat(DBAT6, CFG_DBAT6U, CFG_DBAT6L); + write_bat(IBAT6, CFG_IBAT6U, CFG_IBAT6L); + write_bat(DBAT7, CFG_DBAT7U, CFG_DBAT7L); + write_bat(IBAT7, CFG_IBAT7U, CFG_IBAT7L); + + return; +} diff --git a/cpu/mpc86xx/start.S b/cpu/mpc86xx/start.S index c39dc46..03f2128 100644 --- a/cpu/mpc86xx/start.S +++ b/cpu/mpc86xx/start.S @@ -358,125 +358,6 @@ invalidate_bats: sync blr
- - /* setup_bats - set them up to some initial state */ - /* Skip any BATS setup in early_bats */ - .globl setup_bats -setup_bats: - - addis r0, r0, 0x0000 - - /* IBAT 0 */ - addis r4, r0, CFG_IBAT0L@h - ori r4, r4, CFG_IBAT0L@l - addis r3, r0, CFG_IBAT0U@h - ori r3, r3, CFG_IBAT0U@l - mtspr IBAT0L, r4 - mtspr IBAT0U, r3 - isync - - /* DBAT 0 */ - addis r4, r0, CFG_DBAT0L@h - ori r4, r4, CFG_DBAT0L@l - addis r3, r0, CFG_DBAT0U@h - ori r3, r3, CFG_DBAT0U@l - mtspr DBAT0L, r4 - mtspr DBAT0U, r3 - isync - - /* IBAT 1 */ - addis r4, r0, CFG_IBAT1L@h - ori r4, r4, CFG_IBAT1L@l - addis r3, r0, CFG_IBAT1U@h - ori r3, r3, CFG_IBAT1U@l - mtspr IBAT1L, r4 - mtspr IBAT1U, r3 - isync - - /* DBAT 1 */ - addis r4, r0, CFG_DBAT1L@h - ori r4, r4, CFG_DBAT1L@l - addis r3, r0, CFG_DBAT1U@h - ori r3, r3, CFG_DBAT1U@l - mtspr DBAT1L, r4 - mtspr DBAT1U, r3 - isync - - /* IBAT 2 */ - addis r4, r0, CFG_IBAT2L@h - ori r4, r4, CFG_IBAT2L@l - addis r3, r0, CFG_IBAT2U@h - ori r3, r3, CFG_IBAT2U@l - mtspr IBAT2L, r4 - mtspr IBAT2U, r3 - isync - - /* DBAT 2 */ - addis r4, r0, CFG_DBAT2L@h - ori r4, r4, CFG_DBAT2L@l - addis r3, r0, CFG_DBAT2U@h - ori r3, r3, CFG_DBAT2U@l - mtspr DBAT2L, r4 - mtspr DBAT2U, r3 - isync - - /* IBAT 3 */ - addis r4, r0, CFG_IBAT3L@h - ori r4, r4, CFG_IBAT3L@l - addis r3, r0, CFG_IBAT3U@h - ori r3, r3, CFG_IBAT3U@l - mtspr IBAT3L, r4 - mtspr IBAT3U, r3 - isync - - /* DBAT 3 */ - addis r4, r0, CFG_DBAT3L@h - ori r4, r4, CFG_DBAT3L@l - addis r3, r0, CFG_DBAT3U@h - ori r3, r3, CFG_DBAT3U@l - mtspr DBAT3L, r4 - mtspr DBAT3U, r3 - isync - - /* IBAT 4 */ - addis r4, r0, CFG_IBAT4L@h - ori r4, r4, CFG_IBAT4L@l - addis r3, r0, CFG_IBAT4U@h - ori r3, r3, CFG_IBAT4U@l - mtspr IBAT4L, r4 - mtspr IBAT4U, r3 - isync - - /* DBAT 4 */ - addis r4, r0, CFG_DBAT4L@h - ori r4, r4, CFG_DBAT4L@l - addis r3, r0, CFG_DBAT4U@h - ori r3, r3, CFG_DBAT4U@l - mtspr DBAT4L, r4 - mtspr DBAT4U, r3 - isync - - /* IBAT 7 */ - addis r4, r0, CFG_IBAT7L@h - ori r4, r4, CFG_IBAT7L@l - addis r3, r0, CFG_IBAT7U@h - ori r3, r3, CFG_IBAT7U@l - mtspr IBAT7L, r4 - mtspr IBAT7U, r3 - isync - - /* DBAT 7 */ - addis r4, r0, CFG_DBAT7L@h - ori r4, r4, CFG_DBAT7L@l - addis r3, r0, CFG_DBAT7U@h - ori r3, r3, CFG_DBAT7U@l - mtspr DBAT7L, r4 - mtspr DBAT7U, r3 - isync - - sync - blr - /* * early_bats: *
Acked-by: Jon Loeliger jdl@freescale.com
jdl
Dear Becky Bruce,
In message 1217876546-4070-1-git-send-email-becky.bruce@freescale.com you wrote:
Applied, thanks.
Becky Bruce
Jon Loeliger
