[PATCH] toradex: tdx-cfg-block: rework modules pid4 handling
The module pid4 currently corresponds to the index of the toradex_module array. If a new pid4 is introduced that does not follow the sequence of the previous entries, it will create a gap in the array.
To address this, embed pid4 within the toradex_som structure and implement a function to retrieve the index corresponding to pid4.
Signed-off-by: Vitor Soares vitor.soares@toradex.com --- board/toradex/common/tdx-cfg-block.c | 204 ++++++++++++++------------- board/toradex/common/tdx-cfg-block.h | 2 + board/toradex/common/tdx-common.c | 4 +- 3 files changed, 114 insertions(+), 96 deletions(-)
diff --git a/board/toradex/common/tdx-cfg-block.c b/board/toradex/common/tdx-cfg-block.c index a6e3c6afae80..e909cc33fb23 100644 --- a/board/toradex/common/tdx-cfg-block.c +++ b/board/toradex/common/tdx-cfg-block.c @@ -70,97 +70,95 @@ struct toradex_hw tdx_car_hw_tag; #define TARGET_IS_ENABLED(x) IS_ENABLED(CONFIG_TARGET_ ## x)
const struct toradex_som toradex_modules[] = { - [0] = { "UNKNOWN MODULE", 0 }, - [1] = { "Colibri PXA270 312MHz", 0 }, - [2] = { "Colibri PXA270 520MHz", 0 }, - [3] = { "Colibri PXA320 806MHz", 0 }, - [4] = { "Colibri PXA300 208MHz", 0 }, - [5] = { "Colibri PXA310 624MHz", 0 }, - [6] = { "Colibri PXA320IT 806MHz", 0 }, - [7] = { "Colibri PXA300 208MHz XT", 0 }, - [8] = { "Colibri PXA270 312MHz", 0 }, - [9] = { "Colibri PXA270 520MHz", 0 }, - [10] = { "Colibri VF50 128MB", TARGET_IS_ENABLED(COLIBRI_VF) }, - [11] = { "Colibri VF61 256MB", TARGET_IS_ENABLED(COLIBRI_VF) }, - [12] = { "Colibri VF61 256MB IT", TARGET_IS_ENABLED(COLIBRI_VF) }, - [13] = { "Colibri VF50 128MB IT", TARGET_IS_ENABLED(COLIBRI_VF) }, - [14] = { "Colibri iMX6S 256MB", TARGET_IS_ENABLED(COLIBRI_IMX6) }, - [15] = { "Colibri iMX6DL 512MB", TARGET_IS_ENABLED(COLIBRI_IMX6) }, - [16] = { "Colibri iMX6S 256MB IT", TARGET_IS_ENABLED(COLIBRI_IMX6) }, - [17] = { "Colibri iMX6DL 512MB IT", TARGET_IS_ENABLED(COLIBRI_IMX6) }, - [18] = { "UNKNOWN MODULE", 0 }, - [19] = { "UNKNOWN MODULE", 0 }, - [20] = { "Colibri T20 256MB", TARGET_IS_ENABLED(COLIBRI_T20) }, - [21] = { "Colibri T20 512MB", TARGET_IS_ENABLED(COLIBRI_T20) }, - [22] = { "Colibri T20 512MB IT", TARGET_IS_ENABLED(COLIBRI_T20) }, - [23] = { "Colibri T30 1GB", TARGET_IS_ENABLED(COLIBRI_T30) }, - [24] = { "Colibri T20 256MB IT", TARGET_IS_ENABLED(COLIBRI_T20) }, - [25] = { "Apalis T30 2GB", TARGET_IS_ENABLED(APALIS_T30) }, - [26] = { "Apalis T30 1GB", TARGET_IS_ENABLED(APALIS_T30) }, - [27] = { "Apalis iMX6Q 1GB", TARGET_IS_ENABLED(APALIS_IMX6) }, - [28] = { "Apalis iMX6Q 2GB IT", TARGET_IS_ENABLED(APALIS_IMX6) }, - [29] = { "Apalis iMX6D 512MB", TARGET_IS_ENABLED(APALIS_IMX6) }, - [30] = { "Colibri T30 1GB IT", TARGET_IS_ENABLED(COLIBRI_T30) }, - [31] = { "Apalis T30 1GB IT", TARGET_IS_ENABLED(APALIS_T30) }, - [32] = { "Colibri iMX7S 256MB", TARGET_IS_ENABLED(COLIBRI_IMX7) }, - [33] = { "Colibri iMX7D 512MB", TARGET_IS_ENABLED(COLIBRI_IMX7) }, - [34] = { "Apalis TK1 2GB", TARGET_IS_ENABLED(APALIS_TK1) }, - [35] = { "Apalis iMX6D 1GB IT", TARGET_IS_ENABLED(APALIS_IMX6) }, - [36] = { "Colibri iMX6ULL 256MB", TARGET_IS_ENABLED(COLIBRI_IMX6ULL) }, - [37] = { "Apalis iMX8QM 4GB WB IT", TARGET_IS_ENABLED(APALIS_IMX8) }, - [38] = { "Colibri iMX8QXP 2GB WB IT", TARGET_IS_ENABLED(COLIBRI_IMX8X) }, - [39] = { "Colibri iMX7D 1GB", TARGET_IS_ENABLED(COLIBRI_IMX7) }, - [40] = { "Colibri iMX6ULL 512MB WB IT", TARGET_IS_ENABLED(COLIBRI_IMX6ULL) }, - [41] = { "Colibri iMX7D 512MB EPDC", TARGET_IS_ENABLED(COLIBRI_IMX7) }, - [42] = { "Apalis TK1 4GB", TARGET_IS_ENABLED(APALIS_TK1) }, - [43] = { "Colibri T20 512MB IT SETEK", TARGET_IS_ENABLED(COLIBRI_T20) }, - [44] = { "Colibri iMX6ULL 512MB IT", TARGET_IS_ENABLED(COLIBRI_IMX6ULL) }, - [45] = { "Colibri iMX6ULL 512MB WB", TARGET_IS_ENABLED(COLIBRI_IMX6ULL) }, - [46] = { "Apalis iMX8QXP 2GB WB IT", 0 }, - [47] = { "Apalis iMX8QM 4GB IT", TARGET_IS_ENABLED(APALIS_IMX8) }, - [48] = { "Apalis iMX8QP 2GB WB", TARGET_IS_ENABLED(APALIS_IMX8) }, - [49] = { "Apalis iMX8QP 2GB", TARGET_IS_ENABLED(APALIS_IMX8) }, - [50] = { "Colibri iMX8QXP 2GB IT", TARGET_IS_ENABLED(COLIBRI_IMX8X) }, - [51] = { "Colibri iMX8DX 1GB WB", TARGET_IS_ENABLED(COLIBRI_IMX8X) }, - [52] = { "Colibri iMX8DX 1GB", TARGET_IS_ENABLED(COLIBRI_IMX8X) }, - [53] = { "Apalis iMX8QXP 2GB ECC IT", 0 }, - [54] = { "Apalis iMX8DXP 1GB", TARGET_IS_ENABLED(APALIS_IMX8) }, - [55] = { "Verdin iMX8M Mini Quad 2GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, - [56] = { "Verdin iMX8M Nano Quad 1GB WB", 0 }, - [57] = { "Verdin iMX8M Mini DualLite 1GB", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, - [58] = { "Verdin iMX8M Plus Quad 4GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, - [59] = { "Verdin iMX8M Mini Quad 2GB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, - [60] = { "Verdin iMX8M Mini DualLite 1GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, - [61] = { "Verdin iMX8M Plus Quad 2GB", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, - [62] = { "Colibri iMX6ULL 1GB IT", TARGET_IS_ENABLED(COLIBRI_IMX6ULL) }, - [63] = { "Verdin iMX8M Plus Quad 4GB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, - [64] = { "Verdin iMX8M Plus Quad 2GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, - [65] = { "Verdin iMX8M Plus QuadLite 1GB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, - [66] = { "Verdin iMX8M Plus Quad 8GB WB", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, - [67] = { "Apalis iMX8QM 8GB WB IT", TARGET_IS_ENABLED(APALIS_IMX8) }, - [68] = { "Verdin iMX8M Mini Quad 2GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, - [69] = { "Verdin AM62 Quad 1GB WB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, - [70] = { "Verdin iMX8M Plus Quad 8GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, - [71] = { "Verdin AM62 Solo 512MB", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, - [72] = { "Verdin AM62 Solo 512MB WB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, - [73] = { "Verdin AM62 Dual 1GB ET", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, - [74] = { "Verdin AM62 Dual 1GB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, - [75] = { "Verdin AM62 Dual 1GB WB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, - [76] = { "Verdin AM62 Quad 2GB WB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, - [77] = { "Colibri iMX6S 256MB", TARGET_IS_ENABLED(COLIBRI_IMX6) }, - [78] = { "Colibri iMX6S 256MB IT", TARGET_IS_ENABLED(COLIBRI_IMX6) }, - [79] = { "Colibri iMX6DL 512MB", TARGET_IS_ENABLED(COLIBRI_IMX6) }, - [80] = { "Colibri iMX6DL 512MB IT", TARGET_IS_ENABLED(COLIBRI_IMX6) }, - [81] = { "Colibri iMX7D 512MB", TARGET_IS_ENABLED(COLIBRI_IMX7) }, - [82] = { "Apalis iMX6D 512MB", TARGET_IS_ENABLED(APALIS_IMX6) }, - [83] = { "Apalis iMX6Q 1GB", TARGET_IS_ENABLED(APALIS_IMX6) }, - [84] = { "Apalis iMX6D 1GB IT", TARGET_IS_ENABLED(APALIS_IMX6) }, - [85] = { "Apalis iMX6Q 2GB IT", TARGET_IS_ENABLED(APALIS_IMX6) }, - [86] = { "Verdin iMX8M Mini DualLite 2GB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, - [87] = { "Verdin iMX8M Mini Quad 2GB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, - [88] = { "Aquila AM69 Octa 32GB WB IT", TARGET_IS_ENABLED(AQUILA_AM69_A72) }, - [89] = { "Verdin iMX95 Hexa 16GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX95) }, - [90] = { "Verdin iMX8M Mini Quad 4GB WB ET", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, + { 0, "UNKNOWN MODULE", 0 }, + { COLIBRI_PXA270_V1_312MHZ, "Colibri PXA270 312MHz", 0 }, + { COLIBRI_PXA270_V1_520MHZ, "Colibri PXA270 520MHz", 0 }, + { COLIBRI_PXA320, "Colibri PXA320 806MHz", 0 }, + { COLIBRI_PXA300, "Colibri PXA300 208MHz", 0 }, + { COLIBRI_PXA310, "Colibri PXA310 624MHz", 0 }, + { COLIBRI_PXA320_IT, "Colibri PXA320IT 806MHz", 0 }, + { COLIBRI_PXA300_XT, "Colibri PXA300 208MHz XT", 0 }, + { COLIBRI_PXA270_312MHZ, "Colibri PXA270 312MHz", 0 }, + { COLIBRI_PXA270_520MHZ, "Colibri PXA270 520MHz", 0 }, + { COLIBRI_VF50, "Colibri VF50 128MB", TARGET_IS_ENABLED(COLIBRI_VF) }, + { COLIBRI_VF61, "Colibri VF61 256MB", TARGET_IS_ENABLED(COLIBRI_VF) }, + { COLIBRI_VF61_IT, "Colibri VF61 256MB IT", TARGET_IS_ENABLED(COLIBRI_VF) }, + { COLIBRI_VF50_IT, "Colibri VF50 128MB IT", TARGET_IS_ENABLED(COLIBRI_VF) }, + { COLIBRI_IMX6S, "Colibri iMX6S 256MB", TARGET_IS_ENABLED(COLIBRI_IMX6) }, + { COLIBRI_IMX6DL, "Colibri iMX6DL 512MB", TARGET_IS_ENABLED(COLIBRI_IMX6) }, + { COLIBRI_IMX6S_IT, "Colibri iMX6S 256MB IT", TARGET_IS_ENABLED(COLIBRI_IMX6) }, + { COLIBRI_IMX6DL_IT, "Colibri iMX6DL 512MB IT", TARGET_IS_ENABLED(COLIBRI_IMX6) }, + { COLIBRI_T20_256MB, "Colibri T20 256MB", TARGET_IS_ENABLED(COLIBRI_T20) }, + { COLIBRI_T20_512MB, "Colibri T20 512MB", TARGET_IS_ENABLED(COLIBRI_T20) }, + { COLIBRI_T20_512MB_IT, "Colibri T20 512MB IT", TARGET_IS_ENABLED(COLIBRI_T20) }, + { COLIBRI_T30, "Colibri T30 1GB", TARGET_IS_ENABLED(COLIBRI_T30) }, + { COLIBRI_T20_256MB_IT, "Colibri T20 256MB IT", TARGET_IS_ENABLED(COLIBRI_T20) }, + { APALIS_T30_2GB, "Apalis T30 2GB", TARGET_IS_ENABLED(APALIS_T30) }, + { APALIS_T30_1GB, "Apalis T30 1GB", TARGET_IS_ENABLED(APALIS_T30) }, + { APALIS_IMX6Q, "Apalis iMX6Q 1GB", TARGET_IS_ENABLED(APALIS_IMX6) }, + { APALIS_IMX6Q_IT, "Apalis iMX6Q 2GB IT", TARGET_IS_ENABLED(APALIS_IMX6) }, + { APALIS_IMX6D, "Apalis iMX6D 512MB", TARGET_IS_ENABLED(APALIS_IMX6) }, + { COLIBRI_T30_IT, "Colibri T30 1GB IT", TARGET_IS_ENABLED(COLIBRI_T30) }, + { APALIS_T30_IT, "Apalis T30 1GB IT", TARGET_IS_ENABLED(APALIS_T30) }, + { COLIBRI_IMX7S, "Colibri iMX7S 256MB", TARGET_IS_ENABLED(COLIBRI_IMX7) }, + { COLIBRI_IMX7D, "Colibri iMX7D 512MB", TARGET_IS_ENABLED(COLIBRI_IMX7) }, + { APALIS_TK1_2GB, "Apalis TK1 2GB", TARGET_IS_ENABLED(APALIS_TK1) }, + { APALIS_IMX6D_IT, "Apalis iMX6D 1GB IT", TARGET_IS_ENABLED(APALIS_IMX6) }, + { COLIBRI_IMX6ULL, "Colibri iMX6ULL 256MB", TARGET_IS_ENABLED(COLIBRI_IMX6ULL) }, + { APALIS_IMX8QM_WIFI_BT_IT, "Apalis iMX8QM 4GB WB IT", TARGET_IS_ENABLED(APALIS_IMX8) }, + { COLIBRI_IMX8QXP_WIFI_BT_IT, "Colibri iMX8QXP 2GB WB IT", TARGET_IS_ENABLED(COLIBRI_IMX8X) }, + { COLIBRI_IMX7D_EMMC, "Colibri iMX7D 1GB", TARGET_IS_ENABLED(COLIBRI_IMX7) }, + { COLIBRI_IMX6ULL_WIFI_BT_IT, "Colibri iMX6ULL 512MB WB IT", TARGET_IS_ENABLED(COLIBRI_IMX6ULL) }, + { COLIBRI_IMX7D_EPDC, "Colibri iMX7D 512MB EPDC", TARGET_IS_ENABLED(COLIBRI_IMX7) }, + { APALIS_TK1_4GB, "Apalis TK1 4GB", TARGET_IS_ENABLED(APALIS_TK1) }, + { COLIBRI_T20_512MB_IT_SETEK, "Colibri T20 512MB IT SETEK", TARGET_IS_ENABLED(COLIBRI_T20) }, + { COLIBRI_IMX6ULL_IT, "Colibri iMX6ULL 512MB IT", TARGET_IS_ENABLED(COLIBRI_IMX6ULL) }, + { COLIBRI_IMX6ULL_WIFI_BT, "Colibri iMX6ULL 512MB WB", TARGET_IS_ENABLED(COLIBRI_IMX6ULL) }, + { APALIS_IMX8QXP_WIFI_BT_IT, "Apalis iMX8QXP 2GB WB IT", 0 }, + { APALIS_IMX8QM_IT, "Apalis iMX8QM 4GB IT", TARGET_IS_ENABLED(APALIS_IMX8) }, + { APALIS_IMX8QP_WIFI_BT, "Apalis iMX8QP 2GB WB", TARGET_IS_ENABLED(APALIS_IMX8) }, + { APALIS_IMX8QP, "Apalis iMX8QP 2GB", TARGET_IS_ENABLED(APALIS_IMX8) }, + { COLIBRI_IMX8QXP_IT, "Colibri iMX8QXP 2GB IT", TARGET_IS_ENABLED(COLIBRI_IMX8X) }, + { COLIBRI_IMX8DX_WIFI_BT, "Colibri iMX8DX 1GB WB", TARGET_IS_ENABLED(COLIBRI_IMX8X) }, + { COLIBRI_IMX8DX, "Colibri iMX8DX 1GB", TARGET_IS_ENABLED(COLIBRI_IMX8X) }, + { APALIS_IMX8QXP, "Apalis iMX8QXP 2GB ECC IT", 0 }, + { APALIS_IMX8DXP, "Apalis iMX8DXP 1GB", TARGET_IS_ENABLED(APALIS_IMX8) }, + { VERDIN_IMX8MMQ_WIFI_BT_IT, "Verdin iMX8M Mini Quad 2GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, + { VERDIN_IMX8MNQ_WIFI_BT, "Verdin iMX8M Nano Quad 1GB WB", 0 }, + { VERDIN_IMX8MMDL, "Verdin iMX8M Mini DualLite 1GB", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, + { VERDIN_IMX8MPQ_WIFI_BT_IT, "Verdin iMX8M Plus Quad 4GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, + { VERDIN_IMX8MMQ_IT, "Verdin iMX8M Mini Quad 2GB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, + { VERDIN_IMX8MMDL_WIFI_BT_IT, "Verdin iMX8M Mini DualLite 1GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, + { VERDIN_IMX8MPQ, "Verdin iMX8M Plus Quad 2GB", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, + { COLIBRI_IMX6ULL_IT_EMMC, "Colibri iMX6ULL 1GB IT", TARGET_IS_ENABLED(COLIBRI_IMX6ULL) }, + { VERDIN_IMX8MPQ_IT, "Verdin iMX8M Plus Quad 4GB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, + { VERDIN_IMX8MPQ_2GB_WIFI_BT_IT, "Verdin iMX8M Plus Quad 2GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, + { VERDIN_IMX8MPQL_IT, "Verdin iMX8M Plus QuadLite 1GB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, + { VERDIN_IMX8MPQ_8GB_WIFI_BT, "Verdin iMX8M Plus Quad 8GB WB", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, + { APALIS_IMX8QM_8GB_WIFI_BT_IT, "Apalis iMX8QM 8GB WB IT", TARGET_IS_ENABLED(APALIS_IMX8) }, + { VERDIN_IMX8MMQ_WIFI_BT_IT_NO_CAN, "Verdin iMX8M Mini Quad 2GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, + { VERDIN_AM62Q_WIFI_BT_IT, "Verdin AM62 Quad 1GB WB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, + { VERDIN_IMX8MPQ_8GB_WIFI_BT_IT, "Verdin iMX8M Plus Quad 8GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, + { VERDIN_AM62S_512MB, "Verdin AM62 Solo 512MB", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, + { VERDIN_AM62S_512MB_WIFI_BT_IT, "Verdin AM62 Solo 512MB WB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, + { VERDIN_AM62D_1G_ET, "Verdin AM62 Dual 1GB ET", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, + { VERDIN_AM62D_1G_IT, "Verdin AM62 Dual 1GB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, + { VERDIN_AM62D_1G_WIFI_BT_IT, "Verdin AM62 Dual 1GB WB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, + { VERDIN_AM62Q_2G_WIFI_BT_IT, "Verdin AM62 Quad 2GB WB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, + { COLIBRI_IMX6S_NOWINCE, "Colibri iMX6S 256MB", TARGET_IS_ENABLED(COLIBRI_IMX6) }, + { COLIBRI_IMX6S_IT_NOWINCE, "Colibri iMX6S 256MB IT", TARGET_IS_ENABLED(COLIBRI_IMX6) }, + { COLIBRI_IMX6DL_NOWINCE, "Colibri iMX6DL 512MB", TARGET_IS_ENABLED(COLIBRI_IMX6) }, + { COLIBRI_IMX6DL_IT_NOWINCE, "Colibri iMX6DL 512MB IT", TARGET_IS_ENABLED(COLIBRI_IMX6) }, + { COLIBRI_IMX7D_NOWINCE, "Colibri iMX7D 512MB", TARGET_IS_ENABLED(COLIBRI_IMX7) }, + { APALIS_IMX6D_NOWINCE, "Apalis iMX6D 512MB", TARGET_IS_ENABLED(APALIS_IMX6) }, + { APALIS_IMX6Q_NOWINCE, "Apalis iMX6Q 1GB", TARGET_IS_ENABLED(APALIS_IMX6) }, + { APALIS_IMX6D_IT_NOWINCE, "Apalis iMX6D 1GB IT", TARGET_IS_ENABLED(APALIS_IMX6) }, + { APALIS_IMX6Q_IT_NOWINCE, "Apalis iMX6Q 2GB IT", TARGET_IS_ENABLED(APALIS_IMX6) }, + { VERDIN_IMX8MMDL_2G_IT, "Verdin iMX8M Mini DualLite 2GB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, + { VERDIN_IMX8MMQ_2G_IT_NO_CAN, "Verdin iMX8M Mini Quad 2GB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, + { AQUILA_AM69O_32G_WIFI_BT_IT, "Aquila AM69 Octa 32GB WB IT", TARGET_IS_ENABLED(AQUILA_AM69_A72) }, + { VERDIN_IMX95H_16G_WIFI_BT_IT, "Verdin iMX95 Hexa 16GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX95) }, + { VERDIN_IMX8MMQ_4G_WIFI_BT_ET, "Verdin iMX8M Mini Quad 4GB WB ET", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, };
struct pid4list { @@ -188,6 +186,20 @@ const u32 toradex_ouis[] = { [1] = 0x8c06cbUL, };
+int get_toradex_modules_idx(int pid4) +{ + int i, index = 0; + + for (i = 1; i < ARRAY_SIZE(toradex_modules); i++) { + if (pid4 == toradex_modules[i].pid4) { + index = i; + break; + } + } + + return index; +} + const char * const get_toradex_carrier_boards(int pid4) { int i, index = 0; @@ -361,7 +373,7 @@ static int write_tdx_cfg_block_to_eeprom(unsigned char *config_block)
int read_tdx_cfg_block(void) { - int ret = 0; + int idx, ret = 0; u8 *config_block = NULL; struct toradex_tag *tag; size_t size = TDX_CFG_BLOCK_MAX_SIZE; @@ -430,7 +442,8 @@ int read_tdx_cfg_block(void) }
/* Cap product id to avoid issues with a yet unknown one */ - if (tdx_hw_tag.prodid >= ARRAY_SIZE(toradex_modules)) + idx = get_toradex_modules_idx(tdx_hw_tag.prodid); + if (!toradex_modules[idx].pid4) tdx_hw_tag.prodid = 0;
out: @@ -456,7 +469,7 @@ static int get_cfgblock_interactive(void) int len = 0; int ret = 0; unsigned int prodid; - int i; + int i, idx;
printf("Enabled modules:\n"); for (i = 0; i < ARRAY_SIZE(toradex_modules); i++) { @@ -468,7 +481,8 @@ static int get_cfgblock_interactive(void) len = cli_readline(message);
prodid = dectoul(console_buffer, NULL); - if (prodid >= ARRAY_SIZE(toradex_modules) || !toradex_modules[prodid].is_enabled) { + idx = get_toradex_modules_idx(prodid); + if (!toradex_modules[idx].pid4 || !toradex_modules[idx].is_enabled) { printf("Parsing module id failed\n"); return -1; } diff --git a/board/toradex/common/tdx-cfg-block.h b/board/toradex/common/tdx-cfg-block.h index 0d6dd1c3a721..937e84c3199b 100644 --- a/board/toradex/common/tdx-cfg-block.h +++ b/board/toradex/common/tdx-cfg-block.h @@ -21,6 +21,7 @@ struct toradex_eth_addr { } __attribute__((__packed__));
struct toradex_som { + int pid4; const char *name; int is_enabled; }; @@ -139,6 +140,7 @@ extern u32 tdx_car_serial;
int read_tdx_cfg_block(void); int read_tdx_cfg_block_carrier(void); +int get_toradex_modules_idx(int pid4); const char * const get_toradex_carrier_boards(int pid4); const char * const get_toradex_display_adapters(int pid4); int try_migrate_tdx_cfg_block_carrier(void); diff --git a/board/toradex/common/tdx-common.c b/board/toradex/common/tdx-common.c index a6b45cdab810..dd2d4b27cea7 100644 --- a/board/toradex/common/tdx-common.c +++ b/board/toradex/common/tdx-common.c @@ -194,10 +194,12 @@ static int tdx_get_str(struct udevice *dev, int id, size_t size, char *val)
switch (id) { case SYSINFO_ID_BOARD_MODEL: + int idx = get_toradex_modules_idx(tdx_hw_tag.prodid); + snprintf(val, size, "Toradex %04d %s %s", tdx_hw_tag.prodid, - toradex_modules[tdx_hw_tag.prodid].name, + toradex_modules[idx].name, tdx_board_rev_str);
ret = 0;
diff --git a/board/toradex/common/tdx-cfg-block.c b/board/toradex/common/tdx- cfg-block.c index a6e3c6afae80..e909cc33fb23 100644 --- a/board/toradex/common/tdx-cfg-block.c +++ b/board/toradex/common/tdx-cfg-block.c @@ -70,97 +70,95 @@ struct toradex_hw tdx_car_hw_tag; #define TARGET_IS_ENABLED(x) IS_ENABLED(CONFIG_TARGET_ ## x) const struct toradex_som toradex_modules[] = { - [0] = { "UNKNOWN MODULE", 0 }, - [1] = { "Colibri PXA270 312MHz", 0 }, - [2] = { "Colibri PXA270 520MHz", 0 }, - [3] = { "Colibri PXA320 806MHz", 0 }, - [4] = { "Colibri PXA300 208MHz", 0 }, - [5] = { "Colibri PXA310 624MHz", 0 }, - [6] = { "Colibri PXA320IT 806MHz", 0 }, - [7] = { "Colibri PXA300 208MHz XT", 0 }, - [8] = { "Colibri PXA270 312MHz", 0 }, - [9] = { "Colibri PXA270 520MHz", 0 }, - [10] = { "Colibri VF50 128MB", TARGET_IS_ENABLED(COLIBRI_VF) }, - [11] = { "Colibri VF61 256MB", TARGET_IS_ENABLED(COLIBRI_VF) }, - [12] = { "Colibri VF61 256MB IT", TARGET_IS_ENABLED(COLIBRI_VF) }, - [13] = { "Colibri VF50 128MB IT", TARGET_IS_ENABLED(COLIBRI_VF) }, - [14] = { "Colibri iMX6S 256MB", TARGET_IS_ENABLED(COLIBRI_IMX6) }, - [15] = { "Colibri iMX6DL 512MB", TARGET_IS_ENABLED(COLIBRI_IMX6) }, - [16] = { "Colibri iMX6S 256MB IT", TARGET_IS_ENABLED(COLIBRI_IMX6) }, - [17] = { "Colibri iMX6DL 512MB IT", TARGET_IS_ENABLED(COLIBRI_IMX6) }, - [18] = { "UNKNOWN MODULE", 0 }, - [19] = { "UNKNOWN MODULE", 0 }, - [20] = { "Colibri T20 256MB", TARGET_IS_ENABLED(COLIBRI_T20) }, - [21] = { "Colibri T20 512MB", TARGET_IS_ENABLED(COLIBRI_T20) }, - [22] = { "Colibri T20 512MB IT", TARGET_IS_ENABLED(COLIBRI_T20) }, - [23] = { "Colibri T30 1GB", TARGET_IS_ENABLED(COLIBRI_T30) }, - [24] = { "Colibri T20 256MB IT", TARGET_IS_ENABLED(COLIBRI_T20) }, - [25] = { "Apalis T30 2GB", TARGET_IS_ENABLED(APALIS_T30) }, - [26] = { "Apalis T30 1GB", TARGET_IS_ENABLED(APALIS_T30) }, - [27] = { "Apalis iMX6Q 1GB", TARGET_IS_ENABLED(APALIS_IMX6) }, - [28] = { "Apalis iMX6Q 2GB IT", TARGET_IS_ENABLED(APALIS_IMX6) }, - [29] = { "Apalis iMX6D 512MB", TARGET_IS_ENABLED(APALIS_IMX6) }, - [30] = { "Colibri T30 1GB IT", TARGET_IS_ENABLED(COLIBRI_T30) }, - [31] = { "Apalis T30 1GB IT", TARGET_IS_ENABLED(APALIS_T30) }, - [32] = { "Colibri iMX7S 256MB", TARGET_IS_ENABLED(COLIBRI_IMX7) }, - [33] = { "Colibri iMX7D 512MB", TARGET_IS_ENABLED(COLIBRI_IMX7) }, - [34] = { "Apalis TK1 2GB", TARGET_IS_ENABLED(APALIS_TK1) }, - [35] = { "Apalis iMX6D 1GB IT", TARGET_IS_ENABLED(APALIS_IMX6) }, - [36] = { "Colibri iMX6ULL 256MB", TARGET_IS_ENABLED(COLIBRI_IMX6ULL) }, - [37] = { "Apalis iMX8QM 4GB WB IT", TARGET_IS_ENABLED(APALIS_IMX8) }, - [38] = { "Colibri iMX8QXP 2GB WB IT", TARGET_IS_ENABLED(COLIBRI_IMX8X) }, - [39] = { "Colibri iMX7D 1GB", TARGET_IS_ENABLED(COLIBRI_IMX7) }, - [40] = { "Colibri iMX6ULL 512MB WB IT", TARGET_IS_ENABLED(COLIBRI_IMX6ULL) }, - [41] = { "Colibri iMX7D 512MB EPDC", TARGET_IS_ENABLED(COLIBRI_IMX7) }, - [42] = { "Apalis TK1 4GB", TARGET_IS_ENABLED(APALIS_TK1) }, - [43] = { "Colibri T20 512MB IT SETEK", TARGET_IS_ENABLED(COLIBRI_T20) }, - [44] = { "Colibri iMX6ULL 512MB IT", TARGET_IS_ENABLED(COLIBRI_IMX6ULL) }, - [45] = { "Colibri iMX6ULL 512MB WB", TARGET_IS_ENABLED(COLIBRI_IMX6ULL) }, - [46] = { "Apalis iMX8QXP 2GB WB IT", 0 }, - [47] = { "Apalis iMX8QM 4GB IT", TARGET_IS_ENABLED(APALIS_IMX8) }, - [48] = { "Apalis iMX8QP 2GB WB", TARGET_IS_ENABLED(APALIS_IMX8) }, - [49] = { "Apalis iMX8QP 2GB", TARGET_IS_ENABLED(APALIS_IMX8) }, - [50] = { "Colibri iMX8QXP 2GB IT", TARGET_IS_ENABLED(COLIBRI_IMX8X) }, - [51] = { "Colibri iMX8DX 1GB WB", TARGET_IS_ENABLED(COLIBRI_IMX8X) }, - [52] = { "Colibri iMX8DX 1GB", TARGET_IS_ENABLED(COLIBRI_IMX8X) }, - [53] = { "Apalis iMX8QXP 2GB ECC IT", 0 }, - [54] = { "Apalis iMX8DXP 1GB", TARGET_IS_ENABLED(APALIS_IMX8) }, - [55] = { "Verdin iMX8M Mini Quad 2GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, - [56] = { "Verdin iMX8M Nano Quad 1GB WB", 0 }, - [57] = { "Verdin iMX8M Mini DualLite 1GB", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, - [58] = { "Verdin iMX8M Plus Quad 4GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, - [59] = { "Verdin iMX8M Mini Quad 2GB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, - [60] = { "Verdin iMX8M Mini DualLite 1GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, - [61] = { "Verdin iMX8M Plus Quad 2GB", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, - [62] = { "Colibri iMX6ULL 1GB IT", TARGET_IS_ENABLED(COLIBRI_IMX6ULL) }, - [63] = { "Verdin iMX8M Plus Quad 4GB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, - [64] = { "Verdin iMX8M Plus Quad 2GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, - [65] = { "Verdin iMX8M Plus QuadLite 1GB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, - [66] = { "Verdin iMX8M Plus Quad 8GB WB", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, - [67] = { "Apalis iMX8QM 8GB WB IT", TARGET_IS_ENABLED(APALIS_IMX8) }, - [68] = { "Verdin iMX8M Mini Quad 2GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, - [69] = { "Verdin AM62 Quad 1GB WB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, - [70] = { "Verdin iMX8M Plus Quad 8GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, - [71] = { "Verdin AM62 Solo 512MB", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, - [72] = { "Verdin AM62 Solo 512MB WB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, - [73] = { "Verdin AM62 Dual 1GB ET", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, - [74] = { "Verdin AM62 Dual 1GB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, - [75] = { "Verdin AM62 Dual 1GB WB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, - [76] = { "Verdin AM62 Quad 2GB WB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, - [77] = { "Colibri iMX6S 256MB", TARGET_IS_ENABLED(COLIBRI_IMX6) }, - [78] = { "Colibri iMX6S 256MB IT", TARGET_IS_ENABLED(COLIBRI_IMX6) }, - [79] = { "Colibri iMX6DL 512MB", TARGET_IS_ENABLED(COLIBRI_IMX6) }, - [80] = { "Colibri iMX6DL 512MB IT", TARGET_IS_ENABLED(COLIBRI_IMX6) }, - [81] = { "Colibri iMX7D 512MB", TARGET_IS_ENABLED(COLIBRI_IMX7) }, - [82] = { "Apalis iMX6D 512MB", TARGET_IS_ENABLED(APALIS_IMX6) }, - [83] = { "Apalis iMX6Q 1GB", TARGET_IS_ENABLED(APALIS_IMX6) }, - [84] = { "Apalis iMX6D 1GB IT", TARGET_IS_ENABLED(APALIS_IMX6) }, - [85] = { "Apalis iMX6Q 2GB IT", TARGET_IS_ENABLED(APALIS_IMX6) }, - [86] = { "Verdin iMX8M Mini DualLite 2GB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, - [87] = { "Verdin iMX8M Mini Quad 2GB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, - [88] = { "Aquila AM69 Octa 32GB WB IT", TARGET_IS_ENABLED(AQUILA_AM69_A72) }, - [89] = { "Verdin iMX95 Hexa 16GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX95) }, - [90] = { "Verdin iMX8M Mini Quad 4GB WB ET", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, + { 0, "UNKNOWN MODULE", 0 }, + { COLIBRI_PXA270_V1_312MHZ, "Colibri PXA270 312MHz", 0 }, + { COLIBRI_PXA270_V1_520MHZ, "Colibri PXA270 520MHz", 0 }, + { COLIBRI_PXA320, "Colibri PXA320 806MHz", 0 }, + { COLIBRI_PXA300, "Colibri PXA300 208MHz", 0 }, + { COLIBRI_PXA310, "Colibri PXA310 624MHz", 0 }, + { COLIBRI_PXA320_IT, "Colibri PXA320IT 806MHz", 0 }, + { COLIBRI_PXA300_XT, "Colibri PXA300 208MHz XT", 0 }, + { COLIBRI_PXA270_312MHZ, "Colibri PXA270 312MHz", 0 }, + { COLIBRI_PXA270_520MHZ, "Colibri PXA270 520MHz", 0 }, + { COLIBRI_VF50, "Colibri VF50 128MB", TARGET_IS_ENABLED(COLIBRI_VF) }, + { COLIBRI_VF61, "Colibri VF61 256MB", TARGET_IS_ENABLED(COLIBRI_VF) }, + { COLIBRI_VF61_IT, "Colibri VF61 256MB IT", TARGET_IS_ENABLED(COLIBRI_VF) }, + { COLIBRI_VF50_IT, "Colibri VF50 128MB IT", TARGET_IS_ENABLED(COLIBRI_VF) }, + { COLIBRI_IMX6S, "Colibri iMX6S 256MB", TARGET_IS_ENABLED(COLIBRI_IMX6) }, + { COLIBRI_IMX6DL, "Colibri iMX6DL 512MB", TARGET_IS_ENABLED(COLIBRI_IMX6) }, + { COLIBRI_IMX6S_IT, "Colibri iMX6S 256MB IT", TARGET_IS_ENABLED(COLIBRI_IMX6) }, + { COLIBRI_IMX6DL_IT, "Colibri iMX6DL 512MB IT", TARGET_IS_ENABLED(COLIBRI_IMX6) }, + { COLIBRI_T20_256MB, "Colibri T20 256MB", TARGET_IS_ENABLED(COLIBRI_T20) }, + { COLIBRI_T20_512MB, "Colibri T20 512MB", TARGET_IS_ENABLED(COLIBRI_T20) }, + { COLIBRI_T20_512MB_IT, "Colibri T20 512MB IT", TARGET_IS_ENABLED(COLIBRI_T20) }, + { COLIBRI_T30, "Colibri T30 1GB", TARGET_IS_ENABLED(COLIBRI_T30) }, + { COLIBRI_T20_256MB_IT, "Colibri T20 256MB IT", TARGET_IS_ENABLED(COLIBRI_T20) }, + { APALIS_T30_2GB, "Apalis T30 2GB", TARGET_IS_ENABLED(APALIS_T30) }, + { APALIS_T30_1GB, "Apalis T30 1GB", TARGET_IS_ENABLED(APALIS_T30) }, + { APALIS_IMX6Q, "Apalis iMX6Q 1GB", TARGET_IS_ENABLED(APALIS_IMX6) }, + { APALIS_IMX6Q_IT, "Apalis iMX6Q 2GB IT", TARGET_IS_ENABLED(APALIS_IMX6) }, + { APALIS_IMX6D, "Apalis iMX6D 512MB", TARGET_IS_ENABLED(APALIS_IMX6) }, + { COLIBRI_T30_IT, "Colibri T30 1GB IT", TARGET_IS_ENABLED(COLIBRI_T30) }, + { APALIS_T30_IT, "Apalis T30 1GB IT", TARGET_IS_ENABLED(APALIS_T30) }, + { COLIBRI_IMX7S, "Colibri iMX7S 256MB", TARGET_IS_ENABLED(COLIBRI_IMX7) }, + { COLIBRI_IMX7D, "Colibri iMX7D 512MB", TARGET_IS_ENABLED(COLIBRI_IMX7) }, + { APALIS_TK1_2GB, "Apalis TK1 2GB", TARGET_IS_ENABLED(APALIS_TK1) }, + { APALIS_IMX6D_IT, "Apalis iMX6D 1GB IT", TARGET_IS_ENABLED(APALIS_IMX6) }, + { COLIBRI_IMX6ULL, "Colibri iMX6ULL 256MB", TARGET_IS_ENABLED(COLIBRI_IMX6ULL) }, + { APALIS_IMX8QM_WIFI_BT_IT, "Apalis iMX8QM 4GB WB IT", TARGET_IS_ENABLED(APALIS_IMX8) }, + { COLIBRI_IMX8QXP_WIFI_BT_IT, "Colibri iMX8QXP 2GB WB IT", TARGET_IS_ENABLED(COLIBRI_IMX8X) }, + { COLIBRI_IMX7D_EMMC, "Colibri iMX7D 1GB", TARGET_IS_ENABLED(COLIBRI_IMX7) }, + { COLIBRI_IMX6ULL_WIFI_BT_IT, "Colibri iMX6ULL 512MB WB IT", TARGET_IS_ENABLED(COLIBRI_IMX6ULL) }, + { COLIBRI_IMX7D_EPDC, "Colibri iMX7D 512MB EPDC", TARGET_IS_ENABLED(COLIBRI_IMX7) }, + { APALIS_TK1_4GB, "Apalis TK1 4GB", TARGET_IS_ENABLED(APALIS_TK1) }, + { COLIBRI_T20_512MB_IT_SETEK, "Colibri T20 512MB IT SETEK", TARGET_IS_ENABLED(COLIBRI_T20) }, + { COLIBRI_IMX6ULL_IT, "Colibri iMX6ULL 512MB IT", TARGET_IS_ENABLED(COLIBRI_IMX6ULL) }, + { COLIBRI_IMX6ULL_WIFI_BT, "Colibri iMX6ULL 512MB WB", TARGET_IS_ENABLED(COLIBRI_IMX6ULL) }, + { APALIS_IMX8QXP_WIFI_BT_IT, "Apalis iMX8QXP 2GB WB IT", 0 }, + { APALIS_IMX8QM_IT, "Apalis iMX8QM 4GB IT", TARGET_IS_ENABLED(APALIS_IMX8) }, + { APALIS_IMX8QP_WIFI_BT, "Apalis iMX8QP 2GB WB", TARGET_IS_ENABLED(APALIS_IMX8) }, + { APALIS_IMX8QP, "Apalis iMX8QP 2GB", TARGET_IS_ENABLED(APALIS_IMX8) }, + { COLIBRI_IMX8QXP_IT, "Colibri iMX8QXP 2GB IT", TARGET_IS_ENABLED(COLIBRI_IMX8X) }, + { COLIBRI_IMX8DX_WIFI_BT, "Colibri iMX8DX 1GB WB", TARGET_IS_ENABLED(COLIBRI_IMX8X) }, + { COLIBRI_IMX8DX, "Colibri iMX8DX 1GB", TARGET_IS_ENABLED(COLIBRI_IMX8X) }, + { APALIS_IMX8QXP, "Apalis iMX8QXP 2GB ECC IT", 0 }, + { APALIS_IMX8DXP, "Apalis iMX8DXP 1GB", TARGET_IS_ENABLED(APALIS_IMX8) }, + { VERDIN_IMX8MMQ_WIFI_BT_IT, "Verdin iMX8M Mini Quad 2GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, + { VERDIN_IMX8MNQ_WIFI_BT, "Verdin iMX8M Nano Quad 1GB WB", 0 }, + { VERDIN_IMX8MMDL, "Verdin iMX8M Mini DualLite 1GB", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, + { VERDIN_IMX8MPQ_WIFI_BT_IT, "Verdin iMX8M Plus Quad 4GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, + { VERDIN_IMX8MMQ_IT, "Verdin iMX8M Mini Quad 2GB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, + { VERDIN_IMX8MMDL_WIFI_BT_IT, "Verdin iMX8M Mini DualLite 1GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, + { VERDIN_IMX8MPQ, "Verdin iMX8M Plus Quad 2GB", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, + { COLIBRI_IMX6ULL_IT_EMMC, "Colibri iMX6ULL 1GB IT", TARGET_IS_ENABLED(COLIBRI_IMX6ULL) }, + { VERDIN_IMX8MPQ_IT, "Verdin iMX8M Plus Quad 4GB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, + { VERDIN_IMX8MPQ_2GB_WIFI_BT_IT, "Verdin iMX8M Plus Quad 2GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, + { VERDIN_IMX8MPQL_IT, "Verdin iMX8M Plus QuadLite 1GB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, + { VERDIN_IMX8MPQ_8GB_WIFI_BT, "Verdin iMX8M Plus Quad 8GB WB", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, + { APALIS_IMX8QM_8GB_WIFI_BT_IT, "Apalis iMX8QM 8GB WB IT", TARGET_IS_ENABLED(APALIS_IMX8) }, + { VERDIN_IMX8MMQ_WIFI_BT_IT_NO_CAN, "Verdin iMX8M Mini Quad 2GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, + { VERDIN_AM62Q_WIFI_BT_IT, "Verdin AM62 Quad 1GB WB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, + { VERDIN_IMX8MPQ_8GB_WIFI_BT_IT, "Verdin iMX8M Plus Quad 8GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX8MP) }, + { VERDIN_AM62S_512MB, "Verdin AM62 Solo 512MB", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, + { VERDIN_AM62S_512MB_WIFI_BT_IT, "Verdin AM62 Solo 512MB WB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, + { VERDIN_AM62D_1G_ET, "Verdin AM62 Dual 1GB ET", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, + { VERDIN_AM62D_1G_IT, "Verdin AM62 Dual 1GB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, + { VERDIN_AM62D_1G_WIFI_BT_IT, "Verdin AM62 Dual 1GB WB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, + { VERDIN_AM62Q_2G_WIFI_BT_IT, "Verdin AM62 Quad 2GB WB IT", TARGET_IS_ENABLED(VERDIN_AM62_A53) }, + { COLIBRI_IMX6S_NOWINCE, "Colibri iMX6S 256MB", TARGET_IS_ENABLED(COLIBRI_IMX6) }, + { COLIBRI_IMX6S_IT_NOWINCE, "Colibri iMX6S 256MB IT", TARGET_IS_ENABLED(COLIBRI_IMX6) }, + { COLIBRI_IMX6DL_NOWINCE, "Colibri iMX6DL 512MB", TARGET_IS_ENABLED(COLIBRI_IMX6) }, + { COLIBRI_IMX6DL_IT_NOWINCE, "Colibri iMX6DL 512MB IT", TARGET_IS_ENABLED(COLIBRI_IMX6) }, + { COLIBRI_IMX7D_NOWINCE, "Colibri iMX7D 512MB", TARGET_IS_ENABLED(COLIBRI_IMX7) }, + { APALIS_IMX6D_NOWINCE, "Apalis iMX6D 512MB", TARGET_IS_ENABLED(APALIS_IMX6) }, + { APALIS_IMX6Q_NOWINCE, "Apalis iMX6Q 1GB", TARGET_IS_ENABLED(APALIS_IMX6) }, + { APALIS_IMX6D_IT_NOWINCE, "Apalis iMX6D 1GB IT", TARGET_IS_ENABLED(APALIS_IMX6) }, + { APALIS_IMX6Q_IT_NOWINCE, "Apalis iMX6Q 2GB IT", TARGET_IS_ENABLED(APALIS_IMX6) }, + { VERDIN_IMX8MMDL_2G_IT, "Verdin iMX8M Mini DualLite 2GB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, + { VERDIN_IMX8MMQ_2G_IT_NO_CAN, "Verdin iMX8M Mini Quad 2GB IT", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, + { AQUILA_AM69O_32G_WIFI_BT_IT, "Aquila AM69 Octa 32GB WB IT", TARGET_IS_ENABLED(AQUILA_AM69_A72) }, + { VERDIN_IMX95H_16G_WIFI_BT_IT, "Verdin iMX95 Hexa 16GB WB IT", TARGET_IS_ENABLED(VERDIN_IMX95) }, + { VERDIN_IMX8MMQ_4G_WIFI_BT_ET, "Verdin iMX8M Mini Quad 4GB WB ET", TARGET_IS_ENABLED(VERDIN_IMX8MM) }, }; struct pid4list { @@ -188,6 +186,20 @@ const u32 toradex_ouis[] = { [1] = 0x8c06cbUL, }; +int get_toradex_modules_idx(int pid4) +{ + int i, index = 0;
+ return index; +}
const char * const get_toradex_carrier_boards(int pid4) { int i, index = 0; @@ -361,7 +373,7 @@ static int write_tdx_cfg_block_to_eeprom(unsigned char *config_block) int read_tdx_cfg_block(void) { - int ret = 0; + int idx, ret = 0; u8 *config_block = NULL; struct toradex_tag *tag; size_t size = TDX_CFG_BLOCK_MAX_SIZE; @@ -430,7 +442,8 @@ int read_tdx_cfg_block(void) } /* Cap product id to avoid issues with a yet unknown one */ - if (tdx_hw_tag.prodid >= ARRAY_SIZE(toradex_modules)) + idx = get_toradex_modules_idx(tdx_hw_tag.prodid); + if (!toradex_modules[idx].pid4) tdx_hw_tag.prodid = 0; out: @@ -456,7 +469,7 @@ static int get_cfgblock_interactive(void) int len = 0; int ret = 0; unsigned int prodid; - int i; + int i, idx; printf("Enabled modules:\n"); for (i = 0; i < ARRAY_SIZE(toradex_modules); i++) { @@ -468,7 +481,8 @@ static int get_cfgblock_interactive(void) len = cli_readline(message); prodid = dectoul(console_buffer, NULL); - if (prodid >= ARRAY_SIZE(toradex_modules) || !toradex_modules[prodid].is_enabled) { + idx = get_toradex_modules_idx(prodid); + if (!toradex_modules[idx].pid4 || !toradex_modules[idx].is_enabled) { printf("Parsing module id failed\n"); return -1; } diff --git a/board/toradex/common/tdx-cfg-block.h b/board/toradex/common/tdx- cfg-block.h index 0d6dd1c3a721..937e84c3199b 100644 --- a/board/toradex/common/tdx-cfg-block.h +++ b/board/toradex/common/tdx-cfg-block.h @@ -21,6 +21,7 @@ struct toradex_eth_addr { } __attribute__((__packed__)); struct toradex_som { + int pid4; const char *name; int is_enabled; }; @@ -139,6 +140,7 @@ extern u32 tdx_car_serial; int read_tdx_cfg_block(void); int read_tdx_cfg_block_carrier(void); +int get_toradex_modules_idx(int pid4); const char * const get_toradex_carrier_boards(int pid4); const char * const get_toradex_display_adapters(int pid4); int try_migrate_tdx_cfg_block_carrier(void); diff --git a/board/toradex/common/tdx-common.c b/board/toradex/common/tdx- common.c index a6b45cdab810..dd2d4b27cea7 100644 --- a/board/toradex/common/tdx-common.c +++ b/board/toradex/common/tdx-common.c @@ -194,10 +194,12 @@ static int tdx_get_str(struct udevice *dev, int id, size_t size, char *val) switch (id) { case SYSINFO_ID_BOARD_MODEL: + int idx = get_toradex_modules_idx(tdx_hw_tag.prodid);
snprintf(val, size, "Toradex %04d %s %s", tdx_hw_tag.prodid, - toradex_modules[tdx_hw_tag.prodid].name, + toradex_modules[idx].name, tdx_board_rev_str); ret = 0;
I have found an issue during the config block creation in interactive mode. Please ignore this patch, I will send a v2.
Best regards, vitor Soares
Vitor Soares
