[U-Boot] [PATCH 00/12] SPI flash STM32 MCU's fixes
This series update MCU's DT in order to fix SPI flash configuration: - Adds MPU region dedicated for SPI flash used in memory mapped mode. - Fixes compatible string. - Fixes memory map size. - Updates spi-tx-bus-width and spi-rx-bus-width property values. - Adds QSPI flash support for STM32F469-disco board
Patrice Chotard (12): mach-stm32: Add MPU region for spi-nor memory mapped region ARM: dts: stm32: Fix qspi memory map size for stm32f7 boards ARM: dts: stm32: add qspi flash compatible string for stm32f769-disco ARM: dts: stm32: add qspi flash compatible string for stm32f746-eval ARM: dts: stm32: Set spi-rx/tx-bus-width to 4 for stm32f746-eval ARM: dts: stm32: Set spi-rx/tx-bus-width to 4 for stm32f746-disco ARM: dts: stm32: Remove useless spi-nor compatible string ARM: dts: stm32: Set spi-rx/tx-bus-width to 4 for stm32f769-disco ARM: dts: stm32: Add qspi support for stm32f469-disco board spi: Kconfig: Add STM32F4 support for STM32_QSPI driver configs: stm32f469-disco: Enable QSPI relative flags configs: stm32f469-disco: Disable PINCTRL_FULL flag
arch/arm/dts/stm32746g-eval-u-boot.dtsi | 6 +++-- arch/arm/dts/stm32f469-disco-u-boot.dtsi | 39 ++++++++++++++++++++++++++++++++ arch/arm/dts/stm32f746-disco-u-boot.dtsi | 8 +++---- arch/arm/dts/stm32f769-disco-u-boot.dtsi | 3 +++ arch/arm/mach-stm32/soc.c | 3 +++ configs/stm32f469-discovery_defconfig | 9 ++++++++ drivers/spi/Kconfig | 2 +- 7 files changed, 63 insertions(+), 7 deletions(-)
The Quad-SPI interface is able to manage up to 256Mbytes Flash memory starting from 0x90000000 to 0x9FFFFFFF in the memory mapped mode. Add a dedicated MPU region into stm32_region_config.
See application note AN4760 available at www.st.com
Signed-off-by: Patrice Chotard patrice.chotard@st.com ---
arch/arm/mach-stm32/soc.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/mach-stm32/soc.c b/arch/arm/mach-stm32/soc.c index 738305c..6ae31d3 100644 --- a/arch/arm/mach-stm32/soc.c +++ b/arch/arm/mach-stm32/soc.c @@ -21,6 +21,9 @@ int arch_cpu_init(void) O_I_WB_RD_WR_ALLOC, REGION_16MB }, #endif
+ { 0x90000000, REGION_1, XN_DIS, PRIV_RW_USR_RW, + SHARED_WRITE_BUFFERED, REGION_256MB }, + #if defined(CONFIG_STM32F7) || defined(CONFIG_STM32H7) { 0xC0000000, REGION_0, XN_DIS, PRIV_RW_USR_RW, O_I_WB_RD_WR_ALLOC, REGION_512MB },
stm32f746-disco embeds a 16Mb qspi flash, stm32f746-eval and stm32f769-disco embeds a 64Mb qspi flash. Update the reg property accordingly
Remove deprecated memory-map property.
arch/arm/dts/stm32746g-eval-u-boot.dtsi | 1 + arch/arm/dts/stm32f746-disco-u-boot.dtsi | 2 +- arch/arm/dts/stm32f769-disco-u-boot.dtsi | 1 + 3 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/stm32746g-eval-u-boot.dtsi b/arch/arm/dts/stm32746g-eval-u-boot.dtsi index 9b55bb7..935d44d 100644 --- a/arch/arm/dts/stm32746g-eval-u-boot.dtsi +++ b/arch/arm/dts/stm32746g-eval-u-boot.dtsi @@ -177,6 +177,7 @@ };
&qspi { + reg = <0xA0001000 0x1000>, <0x90000000 0x4000000>; qflash0: n25q512a { #address-cells = <1>; #size-cells = <1>; diff --git a/arch/arm/dts/stm32f746-disco-u-boot.dtsi b/arch/arm/dts/stm32f746-disco-u-boot.dtsi index bc337b1..a6799be 100644 --- a/arch/arm/dts/stm32f746-disco-u-boot.dtsi +++ b/arch/arm/dts/stm32f746-disco-u-boot.dtsi @@ -234,6 +234,7 @@ };
&qspi { + reg = <0xA0001000 0x1000>, <0x90000000 0x1000000>; qflash0: n25q128a { #address-cells = <1>; #size-cells = <1>; @@ -241,7 +242,6 @@ spi-max-frequency = <108000000>; spi-tx-bus-width = <1>; spi-rx-bus-width = <1>; - memory-map = <0x90000000 0x1000000>; reg = <0>; }; }; diff --git a/arch/arm/dts/stm32f769-disco-u-boot.dtsi b/arch/arm/dts/stm32f769-disco-u-boot.dtsi index e9e43cb..96770da 100644 --- a/arch/arm/dts/stm32f769-disco-u-boot.dtsi +++ b/arch/arm/dts/stm32f769-disco-u-boot.dtsi @@ -155,6 +155,7 @@ };
&qspi { + reg = <0xA0001000 0x1000>, <0x90000000 0x4000000>; flash0: mx66l51235l { #address-cells = <1>; #size-cells = <1>;
Add missing flash compatible string to be able to read/write into qspi flash.
arch/arm/dts/stm32f769-disco-u-boot.dtsi | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/stm32f769-disco-u-boot.dtsi b/arch/arm/dts/stm32f769-disco-u-boot.dtsi index 96770da..1e8cd6d 100644 --- a/arch/arm/dts/stm32f769-disco-u-boot.dtsi +++ b/arch/arm/dts/stm32f769-disco-u-boot.dtsi @@ -159,6 +159,7 @@ flash0: mx66l51235l { #address-cells = <1>; #size-cells = <1>; + compatible = "jedec,spi-nor"; spi-max-frequency = <108000000>; spi-rx-bus-width = <4>; reg = <0>;
arch/arm/dts/stm32746g-eval-u-boot.dtsi | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/stm32746g-eval-u-boot.dtsi b/arch/arm/dts/stm32746g-eval-u-boot.dtsi index 935d44d..58c6adb 100644 --- a/arch/arm/dts/stm32746g-eval-u-boot.dtsi +++ b/arch/arm/dts/stm32746g-eval-u-boot.dtsi @@ -181,6 +181,7 @@ qflash0: n25q512a { #address-cells = <1>; #size-cells = <1>; + compatible = "jedec,spi-nor"; spi-max-frequency = <108000000>; spi-tx-bus-width = <1>; spi-rx-bus-width = <1>;
As n25q512a qspi flash supports quad input fast program and quad input fast read, set spi-tx_bus-width and spi-rx_bus-width to 4.
arch/arm/dts/stm32746g-eval-u-boot.dtsi | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/stm32746g-eval-u-boot.dtsi b/arch/arm/dts/stm32746g-eval-u-boot.dtsi index 58c6adb..d5fb927 100644 --- a/arch/arm/dts/stm32746g-eval-u-boot.dtsi +++ b/arch/arm/dts/stm32746g-eval-u-boot.dtsi @@ -183,8 +183,8 @@ #size-cells = <1>; compatible = "jedec,spi-nor"; spi-max-frequency = <108000000>; - spi-tx-bus-width = <1>; - spi-rx-bus-width = <1>; + spi-tx-bus-width = <4>; + spi-rx-bus-width = <4>; reg = <0>; }; };
As n25q128 qspi flash supports quad input fast program and quad input fast read, set spi-tx_bus-width and spi-rx_bus-width to 4.
arch/arm/dts/stm32f746-disco-u-boot.dtsi | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/stm32f746-disco-u-boot.dtsi b/arch/arm/dts/stm32f746-disco-u-boot.dtsi index a6799be..bbe90fa 100644 --- a/arch/arm/dts/stm32f746-disco-u-boot.dtsi +++ b/arch/arm/dts/stm32f746-disco-u-boot.dtsi @@ -240,8 +240,8 @@ #size-cells = <1>; compatible = "micron,n25q128a13", "jedec,spi-nor"; spi-max-frequency = <108000000>; - spi-tx-bus-width = <1>; - spi-rx-bus-width = <1>; + spi-tx-bus-width = <4>; + spi-rx-bus-width = <4>; reg = <0>; }; };
Compatible string "micron,n25q128a13" is useless, remove it.
arch/arm/dts/stm32f746-disco-u-boot.dtsi | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/stm32f746-disco-u-boot.dtsi b/arch/arm/dts/stm32f746-disco-u-boot.dtsi index bbe90fa..ade7285 100644 --- a/arch/arm/dts/stm32f746-disco-u-boot.dtsi +++ b/arch/arm/dts/stm32f746-disco-u-boot.dtsi @@ -238,7 +238,7 @@ qflash0: n25q128a { #address-cells = <1>; #size-cells = <1>; - compatible = "micron,n25q128a13", "jedec,spi-nor"; + compatible = "jedec,spi-nor"; spi-max-frequency = <108000000>; spi-tx-bus-width = <4>; spi-rx-bus-width = <4>;
As mx66l512 qspi flash supports quad input fast program and quad input fast read, set spi-tx_bus-width and spi-rx_bus-width to 4.
diff --git a/arch/arm/dts/stm32f769-disco-u-boot.dtsi b/arch/arm/dts/stm32f769-disco-u-boot.dtsi index 1e8cd6d..53a645d 100644 --- a/arch/arm/dts/stm32f769-disco-u-boot.dtsi +++ b/arch/arm/dts/stm32f769-disco-u-boot.dtsi @@ -161,6 +161,7 @@ #size-cells = <1>; compatible = "jedec,spi-nor"; spi-max-frequency = <108000000>; + spi-tx-bus-width = <4>; spi-rx-bus-width = <4>; reg = <0>; };
Add device tree nodes to support qspi for stm32f469-disco board.
arch/arm/dts/stm32f469-disco-u-boot.dtsi | 39 ++++++++++++++++++++++++++++++++ 1 file changed, 39 insertions(+)
diff --git a/arch/arm/dts/stm32f469-disco-u-boot.dtsi b/arch/arm/dts/stm32f469-disco-u-boot.dtsi index a980ac4..3da308e 100644 --- a/arch/arm/dts/stm32f469-disco-u-boot.dtsi +++ b/arch/arm/dts/stm32f469-disco-u-boot.dtsi @@ -23,6 +23,7 @@ gpio8 = &gpioi; gpio9 = &gpioj; gpio10 = &gpiok; + spi0 = &qspi; };
soc { @@ -64,6 +65,19 @@ st,sdram-refcount = < 1292 >; }; }; + + qspi: quadspi@A0001000 { + compatible = "st,stm32-qspi"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0xA0001000 0x1000>, <0x90000000 0x10000000>; + reg-names = "qspi", "qspi_mm"; + interrupts = <91>; + spi-max-frequency = <108000000>; + clocks = <&rcc 0 STM32F4_AHB3_CLOCK(QSPI)>; + resets = <&rcc STM32F4_AHB3_RESET(QSPI)>; + pinctrl-0 = <&qspi_pins>; + }; }; };
@@ -205,6 +219,18 @@ }; };
+ qspi_pins: qspi@0 { + pins { + pinmux = <STM32_PINMUX('F',10, AF9)>, /* CLK */ + <STM32_PINMUX('B', 6, AF10)>, /* BK1_NCS */ + <STM32_PINMUX('F', 8, AF10)>, /* BK1_IO0 */ + <STM32_PINMUX('F', 9, AF10)>, /* BK1_IO1 */ + <STM32_PINMUX('F', 7, AF9)>, /* BK1_IO2 */ + <STM32_PINMUX('F', 6, AF9)>; /* BK1_IO3 */ + slew-rate = <2>; + }; + }; + usart3_pins_a: usart3@0 { u-boot,dm-pre-reloc; pins1 { @@ -227,3 +253,16 @@ &syscfg { u-boot,dm-pre-reloc; }; + +&qspi { + reg = <0xA0001000 0x1000>, <0x90000000 0x1000000>; + flash0: n25q128a { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <108000000>; + spi-tx-bus-width = <4>; + spi-rx-bus-width = <4>; + reg = <0>; + }; +};
Allow to select STM32_QSPI driver on STM32F4 SoCs.
drivers/spi/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index fb794ad..e9dadf0 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -222,7 +222,7 @@ config SPI_SUNXI
config STM32_QSPI bool "STM32F7 QSPI driver" - depends on STM32F7 || ARCH_STM32MP + depends on STM32F4 || STM32F7 || ARCH_STM32MP help Enable the STM32F7 Quad-SPI (QSPI) driver. This driver can be used to access the SPI NOR flash chips on platforms embedding
Enable CMD_SF, MTD, DM_SPI_FLASH, SPI_FLASH, SPI, DM_SPI and STM32_QSPI flags to be able to use the embedded n25q128a QSPI flash on stm32f469-disco board.
configs/stm32f469-discovery_defconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/configs/stm32f469-discovery_defconfig b/configs/stm32f469-discovery_defconfig index 377f19b..174f807 100644 --- a/configs/stm32f469-discovery_defconfig +++ b/configs/stm32f469-discovery_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_IMLS=y CONFIG_CMD_GPT=y # CONFIG_RANDOM_UUID is not set CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_MII is not set CONFIG_CMD_CACHE=y @@ -25,4 +26,11 @@ CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="stm32f469-disco" CONFIG_DM_MMC=y CONFIG_ARM_PL180_MMCI=y +CONFIG_MTD=y CONFIG_MTD_NOR_FLASH=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI=y +CONFIG_DM_SPI=y +CONFIG_STM32_QSPI=y
Disable unused PINCTRL_FULL flag.
configs/stm32f469-discovery_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/stm32f469-discovery_defconfig b/configs/stm32f469-discovery_defconfig index 174f807..dcd0697 100644 --- a/configs/stm32f469-discovery_defconfig +++ b/configs/stm32f469-discovery_defconfig @@ -31,6 +31,7 @@ CONFIG_MTD_NOR_FLASH=y CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y +# CONFIG_PINCTRL_FULL is not set CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_STM32_QSPI=y
Patrice Chotard
