[U-Boot] [PATCH v2] patman: Use the Change-Id, version, and prefix in the Message-Id
As per the centithread on ksummit-discuss [1], there are folks who feel that if a Change-Id is present in a developer's local commit that said Change-Id could be interesting to include in upstream posts. Specifically if two commits are posted with the same Change-Id there's a reasonable chance that they are either the same commit or a newer version of the same commit. Specifically this is because that's how gerrit has trained people to work.
There is much angst about Change-Id in upstream Linux, but one thing that seems safe and non-controversial is to include the Change-Id as part of the string of crud that makes up a Message-Id.
Let's give that a try.
In theory (if there is enough adoption) this could help a tool more reliably find various versions of a commit. This actually might work pretty well for U-Boot where (I believe) quite a number of developers use patman, so there could be critical mass (assuming that enough of these people also use a git hook that adds Change-Id to their commits). I was able to find this git hook by searching for "gerrit change id git hook" in my favorite search engine.
In theory one could imagine something like this could be integrated into other tools, possibly even git-send-email. Getting it into patman seems like a sane first step, though.
NOTE: this patch is being posted using a patman containing this patch, so you should be able to see the Message-Id of this patch and see that it contains my local Change-Id, which ends in 2b9 if you want to check.
[1] https://lists.linuxfoundation.org/pipermail/ksummit-discuss/2019-August/0067...
Signed-off-by: Douglas Anderson dianders@chromium.org ---
Changes in v2: - Add a "v" before the version part of the Message-Id - Reorder the parts of the Message-Id as per Johannes.
tools/patman/README | 8 +++++- tools/patman/commit.py | 3 ++ tools/patman/patchstream.py | 57 +++++++++++++++++++++++++++++++++++-- 3 files changed, 65 insertions(+), 3 deletions(-)
diff --git a/tools/patman/README b/tools/patman/README index 7917fc8bdc33..02d582974495 100644 --- a/tools/patman/README +++ b/tools/patman/README @@ -259,12 +259,18 @@ Series-process-log: sort, uniq unique entries. If omitted, no change log processing is done. Separate each tag with a comma.
+Change-Id: + This tag is stripped out but is used to generate the Message-Id + of the emails that will be sent. When you keep the Change-Id the + same you are asserting that this is a slightly different version + (but logically the same patch) as other patches that have been + sent out with the same Change-Id. + Various other tags are silently removed, like these Chrome OS and Gerrit tags:
BUG=... TEST=... -Change-Id: Review URL: Reviewed-on: Commit-xxxx: (except Commit-notes) diff --git a/tools/patman/commit.py b/tools/patman/commit.py index 2bf3a0ba5b92..48d0529c5365 100644 --- a/tools/patman/commit.py +++ b/tools/patman/commit.py @@ -21,6 +21,8 @@ class Commit: The dict is indexed by change version (an integer) cc_list: List of people to aliases/emails to cc on this commit notes: List of lines in the commit (not series) notes + change_id: the Change-Id: tag that was stripped from this commit + and can be used to generate the Message-Id. """ def __init__(self, hash): self.hash = hash @@ -30,6 +32,7 @@ class Commit: self.cc_list = [] self.signoff_set = set() self.notes = [] + self.change_id = None
def AddChange(self, version, info): """Add a new change line to the change list for a version. diff --git a/tools/patman/patchstream.py b/tools/patman/patchstream.py index b6455b0fa383..2dd6a778d4ff 100644 --- a/tools/patman/patchstream.py +++ b/tools/patman/patchstream.py @@ -2,6 +2,7 @@ # Copyright (c) 2011 The Chromium OS Authors. #
+import datetime import math import os import re @@ -14,7 +15,7 @@ import gitutil from series import Series
# Tags that we detect and remove -re_remove = re.compile('^BUG=|^TEST=|^BRANCH=|^Change-Id:|^Review URL:' +re_remove = re.compile('^BUG=|^TEST=|^BRANCH=|^Review URL:' '|Reviewed-on:|Commit-\w*:')
# Lines which are allowed after a TEST= line @@ -32,6 +33,9 @@ re_cover_cc = re.compile('^Cover-letter-cc: *(.*)') # Patch series tag re_series_tag = re.compile('^Series-([a-z-]*): *(.*)')
+# Change-Id will be used to generate the Message-Id and then be stripped +re_change_id = re.compile('^Change-Id: *(.*)') + # Commit series tag re_commit_tag = re.compile('^Commit-([a-z-]*): *(.*)')
@@ -156,6 +160,7 @@ class PatchStream:
# Handle state transition and skipping blank lines series_tag_match = re_series_tag.match(line) + change_id_match = re_change_id.match(line) commit_tag_match = re_commit_tag.match(line) cover_match = re_cover.match(line) cover_cc_match = re_cover_cc.match(line) @@ -177,7 +182,7 @@ class PatchStream: self.state = STATE_MSG_HEADER
# If a tag is detected, or a new commit starts - if series_tag_match or commit_tag_match or \ + if series_tag_match or commit_tag_match or change_id_match or \ cover_match or cover_cc_match or signoff_match or \ self.state == STATE_MSG_HEADER: # but we are already in a section, this means 'END' is missing @@ -275,6 +280,15 @@ class PatchStream: self.AddToSeries(line, name, value) self.skip_blank = True
+ # Detect Change-Id tags + elif change_id_match: + value = change_id_match.group(1) + if self.is_log: + if self.commit.change_id: + raise ValueError("%s: Two Change-Ids: '%s' vs. '%s'" % + (self.commit.hash, self.commit.change_id, value)) + self.commit.change_id = value + # Detect Commit-xxx tags elif commit_tag_match: name = commit_tag_match.group(1) @@ -345,6 +359,41 @@ class PatchStream: self.warn.append('Found %d lines after TEST=' % self.lines_after_test)
+ def WriteMessageId(self, outfd): + """Write the Message-Id into the output. + + This is based on the Change-Id in the original patch, the version, + and the prefix. + + Args: + outfd: Output stream file object + """ + if not self.commit.change_id: + return + + # In theory there is email.utils.make_msgid() which would be nice + # to use, but it already produces something way too long and thus + # will produce ugly commit lines if someone throws this into + # a "Link:" tag in the final commit. So (sigh) roll our own. + + # Start with the time; presumably we wouldn't send the same series + # with the same Change-Id at the exact same second. + parts = [datetime.datetime.now().strftime("%Y%m%d%H%M%S")] + + # These seem like they would be nice to include. + if 'prefix' in self.series: + parts.append(self.series['prefix']) + if 'version' in self.series: + parts.append("v%s" % self.series['version']) + + parts.append(str(self.commit.count + 1)) + + # The Change-Id must be last, right before the @ + parts.append(self.commit.change_id) + + # Join parts together with "." and write it out. + outfd.write('Message-Id: %s@changeid\n' % '.'.join(parts)) + def ProcessStream(self, infd, outfd): """Copy a stream from infd to outfd, filtering out unwanting things.
@@ -358,6 +407,9 @@ class PatchStream: fname = None last_fname = None re_fname = re.compile('diff --git a/(.*) b/.*') + + self.WriteMessageId(outfd) + while True: line = infd.readline() if not line: @@ -481,6 +533,7 @@ def FixPatches(series, fnames): for fname in fnames: commit = series.commits[count] commit.patch = fname + commit.count = count result = FixPatch(backup_dir, fname, series, commit) if result: print('%d warnings for %s:' % (len(result), fname))
It's not quite as good as this (yet), but a very simple version of it for git-send-email could be this:
--- save as .git/hooks/sendemail-validate --- #!/bin/sh
set -e
changeid=$(sed 's/^Change-Id: (I.*)$/\1/;t;d' $1) date=$(date +%s) sed 's/^Change-Id: I.*$//;T;d' -i $1 sed "s/^From: /Message-Id: $date-$changeid@changeid\nFrom: /" -i $1 #--- end script ---
It won't do the RFC/which patch of a series etc. but I consider that less interesting.
Actually, the important part for me is to be to be able to have change- ids locally (e.g. for working with gerrit), and not have that leak out to the community (that doesn't like them).
As a maintainer in the community, I'll also need to change the .git/hooks/commit-msg script that comes with gerrit to not add a Change- Id if the commit comes with a Link: tag already, but that should be easy.
johannes
This, I should mention, is for the case where I apply a patch from somebody else (and while at it I use the script that adds a Link: tag to lore.kernel.org or some other archive recording the message-id), but then I modify the commit slightly and amend it. This would invoke the commit-msg hook and add a Change-Id, but that's not desired here.
johannes
Johannes,
On Thu, Sep 5, 2019 at 12:48 PM Johannes Berg johannes@sipsolutions.net wrote:
set -e
Do you have any idea how to encourage adoption of your git hook? Would it make sense to do something like check it in to the Linux kernel somewhere?
-Doug
Hi Doug,
Not sure, that might backfire completely into getting modified to be a hook that simply *strips* it, rather than preserving it in the message ID?
I suspect one thing that might help would be to advertise such a hook widely where the users are most likely to be, with gerrit? I for one mostly added this because I need to use gerrit sometimes, and
(1) stripping the change IDs manually is annoying, and (2) stripping the change IDs means I can't actually track my own patches
Also, I did in the end modify my commit-msg hook to abort if it finds a Link:
@@ ... @@ if grep -i '^Change-Id:' "$MSG" >/dev/null then return fi
+ if grep -i '^Link:' "$MSG" >/dev/null + then + return + fi
id=`_gen_ChangeId`
and have another hook:
$ cat .git/hooks/applypatch-msg #!/bin/sh . git-sh-setup # the sfid stuff is sometimes added by my spam filter ... perl -pi -e 's|^Message-Id:\s*<?([^>]+)>?(\s*(sfid-.*)?$|Link: https://lore.kernel.org/r/$1%7Cg;' "$1" test -x "$GIT_DIR/hooks/commit-msg" && exec "$GIT_DIR/hooks/commit-msg" ${1+"$@"} : (EOF)
that adds the link to patches I pick up from others (since I'm also a maintainer).
Combined, this means I no longer have to worry about change IDs getting upstream into my pull requests (that I send out as a kernel maintainer, if I edit patches I've applied) while I still create them for things I author locally. This relies on the fact that I even send out my own patches to the list, and then apply them from there ... at least usually, to give others any idea.
Anyway, what's the point of all that discussion? I *mostly* did this out of necessity, to avoid having to manually edit out the change-IDs when I send patches or when I push code out to kernel.org after editing patches I've applied from others, but I can still create them locally by default for the cases where I have to use gerrit.
Not sure if this is the case for many people though, I could just have used different kernel trees for all those different roles, it's just harder for me to manage.
Ultimately, to drive adoption, I see two ways
(1) convince people (other than Linus etc.) that commit tags are useful, and those who are convinced can use this stuff to maintain it across the kernel workflow (assuming the maintainer uses a script such as the apply-msg above, but that seems to be picking up adoption) (2) show it to those who have a need to work with gerrit or similar like me, for whom it covers not sending out the frowned-upon change-IDs to the Linux community.
For (1), I guess this should also come with the right commit-msg hook and the sendemail-validate, since they don't already have the commit-msg hook from gerrit.
johannes
Doug,
set -e
I still don't really know, but I wanted to post that I changed it now, because of uniqueness problems if there *isn't* a changeid, and to make the format a bit more like yours:
--- save as .git/hooks/sendemail-validate --- #!/bin/bash
set -e
changeid=$(sed 's/^Change-Id: (I.*)$/\1/;t;d' $1) # let git do its own if there's no change-id [ "$changeid" = "" ] && exit 0
commit=$(sed 's/^From.*([0-9a-fA-F]{40}).*/\1/;t;d' $1) # must have a commit ID - if this fails git changed [ "$commit" == "" ] && exit 2
commit=${commit:0:12}
date=$(date +%Y%m%d%H%M%S)
# remove change-id sed 's/^Change-Id: I.*$//;T;d' -i $1 # and add message-id sed "s/^From: /Message-Id: $date.$commit.$changeid@changeid\nFrom: /" -i $1 #--- end script ---
(also at https://p.sipsolutions.net/a1ebdd33abb598b4.txt)
johannes
Changes in v2:
Hi Doug,
Changes in v2:
Sadly this seems to cause a test failure (patman --test). Can you please check?
Regards, SImon
On Thu, Sep 26, 2019 at 6:50 PM Simon Glass sjg@chromium.org wrote:
Hi Doug,
Changes in v2:
It's been so long since I worked on patman that I totally forgot about patman --test. Doh!
I've posted v3 and tests pass now. Hopefully it looks OK?
-Doug
Doug Anderson
Douglas Anderson
Johannes Berg
