[U-Boot] [PATCH 1/1] efi_selftest: events unit test, check return values
For some API calls checks for the return values are missing.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_selftest/efi_selftest_events.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/lib/efi_selftest/efi_selftest_events.c b/lib/efi_selftest/efi_selftest_events.c index ed99a53804..1077cbdf9e 100644 --- a/lib/efi_selftest/efi_selftest_events.c +++ b/lib/efi_selftest/efi_selftest_events.c @@ -147,20 +147,20 @@ static int execute(void) return EFI_ST_FAILURE; } ret = boottime->set_timer(event_notify, EFI_TIMER_STOP, 0); - if (index != 0) { + if (ret != EFI_SUCCESS) { efi_st_error("Could not cancel timer\n"); return EFI_ST_FAILURE; } /* Set 10 ms timer */ timer_ticks = 0; ret = boottime->set_timer(event_notify, EFI_TIMER_RELATIVE, 100000); - if (index != 0) { + if (ret != EFI_SUCCESS) { efi_st_error("Could not set timer\n"); return EFI_ST_FAILURE; } /* Set 100 ms timer */ ret = boottime->set_timer(event_wait, EFI_TIMER_PERIODIC, 1000000); - if (index != 0) { + if (ret != EFI_SUCCESS) { efi_st_error("Could not set timer\n"); return EFI_ST_FAILURE; }
