Re: [PATCH v7 8/8] drivers: net: macb: add fu740 support
(resending to list after subscribing)
On Thu, Apr 22, 2021 at 10:15 AM Green Wan green.wan@sifive.com wrote:
From: David Abdurachmanov david.abdurachmanov@sifive.com
Add fu740 support to macb ethernet driver
There is a PLL HW quirk in FU740. The VSC8541XMV-02 specification requires 125 +/-0.0125 Mhz. But the most close value can be output by PLL is 125.125 MHz and out of VSC8541XMV-02 spec.
In the Linux kernel driver for this drivers/net/ethernet/cadence/macb_main.c it is not marked as compatible with "sifive,fu740-c000-gem" and it does not have a similar fix (and appears to use 125.0 MHz). Should a similar fix be contributed to the Linux kernel?
As otherwise at the moment, one cannot pass the dtb from u-boot to linux, as that leads to loss of network since the kernel doesn't know about "sifive,fu740-c000-gem". If linux kernel contribution is not forthcoming, would it be possible to have u-boot dtb to be compatible with _both_ "sifive,fu540-c000-gem" and "sifive,fu740-c000-gem" on unmatched boards, such that if one (mistakenly) uses u-boots dtb with vanilla linux kernel networking still works? And then adjust the test to check for "sifive,fu740-c000-gem" compatible string first.
Signed-off-by: David Abdurachmanov david.abdurachmanov@sifive.com Signed-off-by: Green Wan green.wan@sifive.com Reviewed-by: Ramon Fried rfried.dev@gmail.com Reviewed-by: Bin Meng bmeng.cn@gmail.com
drivers/net/macb.c | 13 ++++++++++++- 1 file changed, 12 insertions(+), 1 deletion(-)
diff --git a/drivers/net/macb.c b/drivers/net/macb.c index 57ea45e2dc..bf70525c54 100644 --- a/drivers/net/macb.c +++ b/drivers/net/macb.c @@ -591,8 +591,17 @@ static int macb_sifive_clk_init(struct udevice *dev, ulong rate) * 0 = GMII mode. Use 125 MHz gemgxlclk from PRCI in TX logic * and output clock on GMII output signal GTX_CLK * 1 = MII mode. Use MII input signal TX_CLK in TX logic
* FU740 have a PLL HW quirk. The 125.125 Mhz is actually out of
* VSC8541XMV-02 specification. The tolerance level is +/-100ppm.
* Which means the range should be in between 125MHz +/-0.0125.
* But the most close value can be output by PLL is 125.125 MHz. */
writel(rate != 125000000, gemgxl_regs);
if (device_is_compatible(dev, "sifive,fu540-c000-gem"))
else if (device_is_compatible(dev, "sifive,fu740-c000-gem"))
writel(rate != 125125000, gemgxl_regs);
@@ -1507,6 +1516,8 @@ static const struct udevice_id macb_eth_ids[] = { { .compatible = "cdns,zynq-gem" }, { .compatible = "sifive,fu540-c000-gem", .data = (ulong)&sifive_config },
{ .compatible = "sifive,fu740-c000-gem",
.data = (ulong)&sifive_config }, { .compatible = "microchip,mpfs-mss-gem", .data = (ulong)µchip_config }, { }
-- 2.31.0
-- Regards,
Dimitri.
Dimitri John Ledkov
