[v2, PATCH] include/configs: ls1012aqds: add default environment variable
This adds default environment variable for ls1012aqds
Signed-off-by: Biwen Li biwen.li@nxp.com --- Change in v2: - delete environment variable installer
include/configs/ls1012aqds.h | 64 ++++++++++++++++++++++++++++++++++++ 1 file changed, 64 insertions(+)
diff --git a/include/configs/ls1012aqds.h b/include/configs/ls1012aqds.h index fb0d1ba6b2..063d1a8ac7 100644 --- a/include/configs/ls1012aqds.h +++ b/include/configs/ls1012aqds.h @@ -110,5 +110,69 @@ #define CONFIG_SYS_MEMTEST_START 0x80000000 #define CONFIG_SYS_MEMTEST_END 0x9fffffff
+#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "verify=no\0" \ + "fdt_high=0xffffffffffffffff\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "fdt_addr=0x00f00000\0" \ + "kernel_addr=0x01000000\0" \ + "kernelheader_addr=0x600000\0" \ + "scriptaddr=0x80000000\0" \ + "scripthdraddr=0x80080000\0" \ + "fdtheader_addr_r=0x80100000\0" \ + "kernelheader_addr_r=0x80200000\0" \ + "kernel_addr_r=0x96000000\0" \ + "fdt_addr_r=0x90000000\0" \ + "load_addr=0xa0000000\0" \ + "kernel_size=0x2800000\0" \ + "kernelheader_size=0x40000\0" \ + "console=ttyS0,115200\0" \ + BOOTENV \ + "boot_scripts=ls1012aqds_boot.scr\0" \ + "boot_script_hdr=hdr_ls1012aqds_bs.out\0" \ + "scan_dev_for_boot_part=" \ + "part list ${devtype} ${devnum} devplist; " \ + "env exists devplist || setenv devplist 1; " \ + "for distro_bootpart in ${devplist}; do " \ + "if fstype ${devtype} " \ + "${devnum}:${distro_bootpart} " \ + "bootfstype; then " \ + "run scan_dev_for_boot; " \ + "fi; " \ + "done\0" \ + "scan_dev_for_boot=" \ + "echo Scanning ${devtype} " \ + "${devnum}:${distro_bootpart}...; " \ + "for prefix in ${boot_prefixes}; do " \ + "run scan_dev_for_scripts; " \ + "done;" \ + "\0" \ + "boot_a_script=" \ + "load ${devtype} ${devnum}:${distro_bootpart} " \ + "${scriptaddr} ${prefix}${script}; " \ + "env exists secureboot && load ${devtype} " \ + "${devnum}:${distro_bootpart} " \ + "${scripthdraddr} ${prefix}${boot_script_hdr}; " \ + "env exists secureboot " \ + "&& esbc_validate ${scripthdraddr};" \ + "source ${scriptaddr}\0" \ + "qspi_bootcmd=pfe stop; echo Trying load from qspi..;" \ + "sf probe 0:0 && sf read $load_addr " \ + "$kernel_addr $kernel_size; env exists secureboot " \ + "&& sf read $kernelheader_addr_r $kernelheader_addr " \ + "$kernelheader_size && esbc_validate ${kernelheader_addr_r}; " \ + "bootm $load_addr#$board\0" + +#undef CONFIG_BOOTCOMMAND +#ifdef CONFIG_TFABOOT +#undef QSPI_NOR_BOOTCOMMAND +#define QSPI_NOR_BOOTCOMMAND "pfe stop; run distro_bootcmd; run qspi_bootcmd; "\ + "env exists secureboot && esbc_halt;" +#else +#define CONFIG_BOOTCOMMAND "pfe stop; run distro_bootcmd; run qspi_bootcmd; "\ + "env exists secureboot && esbc_halt;" +#endif + #include <asm/fsl_secure_boot.h> #endif /* __LS1012AQDS_H__ */
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Biwen Li Sent: Monday, March 16, 2020 7:12 PM To: Jagdish Gediya jagdish.gediya@nxp.com; Priyanka Jain priyanka.jain@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com Cc: Alison Wang alison.wang@nxp.com; u-boot@lists.denx.de; Biwen Li biwen.li@nxp.com Subject: [v2, PATCH] include/configs: ls1012aqds: add default environment variable
Change in v2:
- "verify=no\0" \
- "fdt_high=0xffffffffffffffff\0" \
- "initrd_high=0xffffffffffffffff\0" \
- "fdt_addr=0x00f00000\0" \
- "kernel_addr=0x01000000\0" \
- "kernelheader_addr=0x600000\0" \
- "scriptaddr=0x80000000\0" \
- "scripthdraddr=0x80080000\0" \
- "fdtheader_addr_r=0x80100000\0" \
- "kernelheader_addr_r=0x80200000\0" \
- "kernel_addr_r=0x96000000\0" \
- "fdt_addr_r=0x90000000\0" \
- "load_addr=0xa0000000\0" \
- "kernel_size=0x2800000\0" \
- "kernelheader_size=0x40000\0" \
- "console=ttyS0,115200\0" \
- BOOTENV \
- "boot_scripts=ls1012aqds_boot.scr\0" \
- "boot_script_hdr=hdr_ls1012aqds_bs.out\0" \
- "scan_dev_for_boot_part=" \
"fi; " \
"done\0" \
- "scan_dev_for_boot=" \
"done;" \
"\0" \
- "boot_a_script=" \
- "qspi_bootcmd=pfe stop; echo Trying load from qspi..;" \
\"&& sf read $kernelheader_addr_r $kernelheader_addr "
You mentioned qspi_bootcmd in QSPI_NOR_BOOTCOMMAND. Is this correct ? Please confirm that you have tested the change for combinations of boot, secure/non-secure boot While testing do ensure to erase env and then test this change
2.17.1
Priyanka
Change in v2:
- "verify=no\0" \
- BOOTENV \
"fi; " \
"done\0" \
"done;" \
"\0" \
Sure, have tested non-secure boot.It is workable.
2.17.1
Priyanka
Biwen Li
Priyanka Jain (OSS)
