[U-Boot] [PATCH 1/3] x86: theadorable-x86-common: Add further pci hotplug cmdline parameters
This is needed for the PCIe hotplug to work correctly on some boards.
Signed-off-by: Stefan Roese sr@denx.de Cc: Bin Meng bmeng.cn@gmail.com --- include/configs/theadorable-x86-common.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/include/configs/theadorable-x86-common.h b/include/configs/theadorable-x86-common.h index 238056a65f..7621385fa2 100644 --- a/include/configs/theadorable-x86-common.h +++ b/include/configs/theadorable-x86-common.h @@ -58,7 +58,8 @@ "addmtd=setenv bootargs ${bootargs} ${mtdparts}\0" \ "addmisc=setenv bootargs ${bootargs} " \ "intel-spi.writeable=1 vmalloc=300M " \ - "pci=realloc=on,hpmemsize=0x12000000\0" \ + "pci=realloc=on,hpmemsize=0x12000000," \ + "hpmemprefsize=0,hpiosize=0\0" \ "bootcmd=if env exists recovery_status;" \ "then run swupdate;" \ "else run yocto_boot;run swupdate;" \
This enables the easier usage of "-custom" kernel versions as well.
Signed-off-by: Stefan Roese sr@denx.de Cc: Bin Meng bmeng.cn@gmail.com --- include/configs/theadorable-x86-common.h | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/include/configs/theadorable-x86-common.h b/include/configs/theadorable-x86-common.h index 7621385fa2..c20803c535 100644 --- a/include/configs/theadorable-x86-common.h +++ b/include/configs/theadorable-x86-common.h @@ -46,7 +46,7 @@ "yocto_tty=" __stringify(DEF_ENV_YOCTO_TTY) "\0" \ "start_eth=if test -n "${eth_init}";" \ "then run eth_init;else sleep 0;fi\0" \ - "kernel-ver=4.8.0-54\0" \ + "kernel-ver=4.8.0-54-generic\0" \ "boot=zboot 03000000 0 04000000 ${filesize}\0" \ "mtdparts=mtdparts=intel-spi:4k(descriptor),7084k(me)," \ "8k(env1),8k(env2),64k(mrc),640k(u-boot)," \ @@ -69,9 +69,9 @@ "ubuntu_args_quiet=setenv bootargs " \ "root=/dev/sda${ubuntu_part} ro quiet\0" \ "ubuntu_load=load scsi 0:${ubuntu_part} 03000000 " \ - "/boot/vmlinuz-${kernel-ver}-generic;" \ + "/boot/vmlinuz-${kernel-ver};" \ "load scsi 0:${ubuntu_part} 04000000 " \ - "/boot/initrd.img-${kernel-ver}-generic\0" \ + "/boot/initrd.img-${kernel-ver}\0" \ "ubuntu_boot=run ubuntu_args_quiet addmtd addmisc " \ "ubuntu_load boot\0" \ "ubuntu_boot_console=run ubuntu_args addtty_ubuntu " \ @@ -80,7 +80,7 @@ "net_boot=run start_eth net_args addtty_yocto addmtd addmisc;" \ "tftp 03000000 ${tftpdir}/bzImage;" \ "load scsi 0:${ubuntu_part} 04000000 " \ - "/boot/initrd.img-${kernel-ver}-generic;" \ + "/boot/initrd.img-${kernel-ver};" \ "run boot\0" \ "yocto_args=setenv bootargs root=/dev/sda${yocto_part} " \ "panic=1\0" \
applied to u-boot-x86, thanks!
The setexpr command is useful for scripting, lets enable it for all x86 based theadorable platforms.
Signed-off-by: Stefan Roese sr@denx.de Cc: Bin Meng bmeng.cn@gmail.com --- configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig | 1 - configs/theadorable-x86-conga-qa3-e3845_defconfig | 1 - configs/theadorable-x86-dfi-bt700_defconfig | 1 - 3 files changed, 3 deletions(-)
diff --git a/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig b/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig index 1888f08928..344a8f25c2 100644 --- a/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig +++ b/configs/theadorable-x86-conga-qa3-e3845-pcie-x4_defconfig @@ -27,7 +27,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y diff --git a/configs/theadorable-x86-conga-qa3-e3845_defconfig b/configs/theadorable-x86-conga-qa3-e3845_defconfig index 4c9492cf1f..84a92c54da 100644 --- a/configs/theadorable-x86-conga-qa3-e3845_defconfig +++ b/configs/theadorable-x86-conga-qa3-e3845_defconfig @@ -26,7 +26,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y diff --git a/configs/theadorable-x86-dfi-bt700_defconfig b/configs/theadorable-x86-dfi-bt700_defconfig index 348d917b3b..d42798e8e9 100644 --- a/configs/theadorable-x86-dfi-bt700_defconfig +++ b/configs/theadorable-x86-dfi-bt700_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_PART=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y
Bin Meng
Stefan Roese
