[U-Boot-Users] [PATCH 3/3] drivers: code clean up
Signed-off-by: Dave Liu daveliu@freescale.com --- drivers/block/libata.c | 36 ++++++++++++++++++------------------ include/sata.h | 5 +++++ 2 files changed, 23 insertions(+), 18 deletions(-)
diff --git a/drivers/block/libata.c b/drivers/block/libata.c index bbe16a2..90e9a43 100644 --- a/drivers/block/libata.c +++ b/drivers/block/libata.c @@ -109,39 +109,39 @@ void ata_dump_id(u16 *id) n_sectors = ata_id_n_sectors(id); printf("Capablity: %d sectors\n\r", n_sectors);
- printf ("id[49]: capabilities ==0x%04x\n" - "id[53]: field valid ==0x%04x\n" - "id[63]: mwdma ==0x%04x\n" - "id[64]: pio ==0x%04x\n" - "id[75]: queue depth ==0x%04x\n", + printf ("id[49]: capabilities = 0x%04x\n" + "id[53]: field valid = 0x%04x\n" + "id[63]: mwdma = 0x%04x\n" + "id[64]: pio = 0x%04x\n" + "id[75]: queue depth = 0x%04x\n", id[49], id[53], id[63], id[64], id[75]);
- printf ("id[76]: sata capablity ==0x%04x\n" - "id[78]: sata features supported ==0x%04x\n" - "id[79]: sata features enable ==0x%04x\n", + printf ("id[76]: sata capablity = 0x%04x\n" + "id[78]: sata features supported = 0x%04x\n" + "id[79]: sata features enable = 0x%04x\n", id[76], id[78], id[79]);
- printf ("id[80]: major version ==0x%04x\n" - "id[81]: minor version ==0x%04x\n" - "id[82]: command set supported 1 ==0x%04x\n" - "id[83]: command set supported 2 ==0x%04x\n" - "id[84]: command set extension ==0x%04x\n", + printf ("id[80]: major version = 0x%04x\n" + "id[81]: minor version = 0x%04x\n" + "id[82]: command set supported 1 = 0x%04x\n" + "id[83]: command set supported 2 = 0x%04x\n" + "id[84]: command set extension = 0x%04x\n", id[80], id[81], id[82], id[83], id[84]); - printf ("id[85]: command set enable 1 ==0x%04x\n" - "id[86]: command set enable 2 ==0x%04x\n" - "id[87]: command set default ==0x%04x\n" - "id[88]: udma ==0x%04x\n" - "id[93]: hardware reset result ==0x%04x\n", + printf ("id[85]: command set enable 1 = 0x%04x\n" + "id[86]: command set enable 2 = 0x%04x\n" + "id[87]: command set default = 0x%04x\n" + "id[88]: udma = 0x%04x\n" + "id[93]: hardware reset result = 0x%04x\n", id[85], id[86], id[87], diff --git a/include/sata.h b/include/sata.h index b4b7029..57ee9ac 100644 --- a/include/sata.h +++ b/include/sata.h @@ -1,6 +1,11 @@ +#ifndef __SATA_H__ +#define __SATA_H__ + int init_sata(int dev); int scan_sata(int dev); ulong sata_read(int dev, ulong blknr, ulong blkcnt, void *buffer); ulong sata_write(int dev, ulong blknr, ulong blkcnt, const void *buffer);
int sata_initialize(void); + +#endif
Applied, thanks.
Dave Liu
