[U-Boot] [PATCH v2] powerpc: mpc8xx: remove hermes board support
This board sprinkles #ifdef(CONFIG_HERMES) over various global files such as include/common.h, common/board_r.c, common/cmd_bdinfo.c. Let's zap such an ill-behaved board.
It has not been converted to generic board yet and mpc8xx is old enough.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de ---
Changes in v2: - fix a grammatical mistake the commit description
arch/powerpc/cpu/mpc8xx/Kconfig | 4 - arch/powerpc/cpu/mpc8xx/cpu_init.c | 3 +- arch/powerpc/lib/board.c | 12 - board/hermes/Kconfig | 9 - board/hermes/MAINTAINERS | 6 - board/hermes/Makefile | 8 - board/hermes/flash.c | 444 ---------------------------- board/hermes/hermes.c | 590 ------------------------------------- board/hermes/u-boot.lds | 88 ------ board/hermes/u-boot.lds.debug | 121 -------- common/board_r.c | 24 -- common/cmd_bdinfo.c | 3 - configs/hermes_defconfig | 3 - doc/README.scrapyard | 5 +- include/common.h | 5 - include/commproc.h | 28 -- include/configs/hermes.h | 315 -------------------- 17 files changed, 4 insertions(+), 1664 deletions(-) delete mode 100644 board/hermes/Kconfig delete mode 100644 board/hermes/MAINTAINERS delete mode 100644 board/hermes/Makefile delete mode 100644 board/hermes/flash.c delete mode 100644 board/hermes/hermes.c delete mode 100644 board/hermes/u-boot.lds delete mode 100644 board/hermes/u-boot.lds.debug delete mode 100644 configs/hermes_defconfig delete mode 100644 include/configs/hermes.h
diff --git a/arch/powerpc/cpu/mpc8xx/Kconfig b/arch/powerpc/cpu/mpc8xx/Kconfig index e447748e..99420ab 100644 --- a/arch/powerpc/cpu/mpc8xx/Kconfig +++ b/arch/powerpc/cpu/mpc8xx/Kconfig @@ -13,9 +13,6 @@ config TARGET_COGENT_MPC8XX config TARGET_ESTEEM192E bool "Support ESTEEM192E"
-config TARGET_HERMES - bool "Support hermes" - config TARGET_IP860 bool "Support IP860"
@@ -112,7 +109,6 @@ source "board/LEOX/elpt860/Kconfig" source "board/RRvision/Kconfig" source "board/cogent/Kconfig" source "board/esteem192e/Kconfig" -source "board/hermes/Kconfig" source "board/ip860/Kconfig" source "board/ivm/Kconfig" source "board/kup/kup4k/Kconfig" diff --git a/arch/powerpc/cpu/mpc8xx/cpu_init.c b/arch/powerpc/cpu/mpc8xx/cpu_init.c index 60c401e..6a1cd46 100644 --- a/arch/powerpc/cpu/mpc8xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc8xx/cpu_init.c @@ -125,8 +125,7 @@ void cpu_init_f (volatile immap_t * immr) * I owe him a free beer. - wd] */
-#if defined(CONFIG_HERMES) || \ - defined(CONFIG_IP860) || \ +#if defined(CONFIG_IP860) || \ defined(CONFIG_IVML24) || \ defined(CONFIG_IVMS8) || \ defined(CONFIG_LWMON) || \ diff --git a/arch/powerpc/lib/board.c b/arch/powerpc/lib/board.c index 6eaab88..e6d5355 100644 --- a/arch/powerpc/lib/board.c +++ b/arch/powerpc/lib/board.c @@ -820,13 +820,6 @@ void board_init_r(gd_t *id, ulong dest_addr) mac_read_from_eeprom(); #endif
-#ifdef CONFIG_HERMES - if ((gd->board_type >> 16) == 2) - bd->bi_ethspeed = gd->board_type & 0xFFFF; - else - bd->bi_ethspeed = 0xFFFF; -#endif - #ifdef CONFIG_CMD_NET /* kept around for legacy kernels only ... ignore the next section */ eth_getenv_enetaddr("ethaddr", bd->bi_enetaddr); @@ -876,11 +869,6 @@ void board_init_r(gd_t *id, ulong dest_addr) misc_init_r(); #endif
-#ifdef CONFIG_HERMES - if (bd->bi_ethspeed != 0xFFFF) - hermes_start_lxt980((int) bd->bi_ethspeed); -#endif - #if defined(CONFIG_CMD_KGDB) WATCHDOG_RESET(); puts("KGDB: "); diff --git a/board/hermes/Kconfig b/board/hermes/Kconfig deleted file mode 100644 index deb37fd..0000000 --- a/board/hermes/Kconfig +++ /dev/null @@ -1,9 +0,0 @@ -if TARGET_HERMES - -config SYS_BOARD - default "hermes" - -config SYS_CONFIG_NAME - default "hermes" - -endif diff --git a/board/hermes/MAINTAINERS b/board/hermes/MAINTAINERS deleted file mode 100644 index a596dad..0000000 --- a/board/hermes/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -HERMES BOARD -M: Wolfgang Denk wd@denx.de -S: Maintained -F: board/hermes/ -F: include/configs/hermes.h -F: configs/hermes_defconfig diff --git a/board/hermes/Makefile b/board/hermes/Makefile deleted file mode 100644 index ccca520..0000000 --- a/board/hermes/Makefile +++ /dev/null @@ -1,8 +0,0 @@ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -obj-y = hermes.o flash.o diff --git a/board/hermes/flash.c b/board/hermes/flash.c deleted file mode 100644 index 38d3cd3..0000000 --- a/board/hermes/flash.c +++ /dev/null @@ -1,444 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <mpc8xx.h> - -flash_info_t flash_info[CONFIG_SYS_MAX_FLASH_BANKS]; /* info for FLASH chips */ - -/*----------------------------------------------------------------------- - * Functions - */ -static ulong flash_get_size (vu_long *addr, flash_info_t *info); -static int write_byte (flash_info_t *info, ulong dest, uchar data); -static void flash_get_offsets (ulong base, flash_info_t *info); - -/*----------------------------------------------------------------------- - */ - -unsigned long flash_init (void) -{ - volatile immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - unsigned long size; - int i; - - /* Init: no FLASHes known */ - for (i=0; i<CONFIG_SYS_MAX_FLASH_BANKS; ++i) { - flash_info[i].flash_id = FLASH_UNKNOWN; - } - - /* Static FLASH Bank configuration here - FIXME XXX */ - - size = flash_get_size((vu_long *)FLASH_BASE0_PRELIM, &flash_info[0]); - - if (flash_info[0].flash_id == FLASH_UNKNOWN) { - printf ("## Unknown FLASH on Bank 0 - Size = 0x%08lx = %ld MB\n", - size, size<<20); - } - - /* Remap FLASH according to real size */ - memctl->memc_or0 = CONFIG_SYS_OR_TIMING_FLASH | (-size & 0xFFFF8000); - memctl->memc_br0 = (CONFIG_SYS_FLASH_BASE & BR_BA_MSK) | - (memctl->memc_br0 & ~(BR_BA_MSK)); - - /* Re-do sizing to get full correct info */ - size = flash_get_size((vu_long *)CONFIG_SYS_FLASH_BASE, &flash_info[0]); - - flash_get_offsets (CONFIG_SYS_FLASH_BASE, &flash_info[0]); - -#if CONFIG_SYS_MONITOR_BASE >= CONFIG_SYS_FLASH_BASE - /* monitor protection ON by default */ - flash_protect(FLAG_PROTECT_SET, - CONFIG_SYS_MONITOR_BASE, - CONFIG_SYS_MONITOR_BASE+monitor_flash_len-1, - &flash_info[0]); -#endif - - flash_info[0].size = size; - - return (size); -} - -/*----------------------------------------------------------------------- - */ -static void flash_get_offsets (ulong base, flash_info_t *info) -{ - int i; - - /* set up sector start address table */ - if (info->flash_id & FLASH_BTYPE) { - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00004000; - info->start[2] = base + 0x00006000; - info->start[3] = base + 0x00008000; - for (i = 4; i < info->sector_count; i++) { - info->start[i] = base + (i * 0x00010000) - 0x00030000; - } - } else { - /* set sector offsets for top boot block type */ - i = info->sector_count - 1; - info->start[i--] = base + info->size - 0x00004000; - info->start[i--] = base + info->size - 0x00006000; - info->start[i--] = base + info->size - 0x00008000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00010000; - } - } - -} - -/*----------------------------------------------------------------------- - */ -void flash_print_info (flash_info_t *info) -{ - int i; - - if (info->flash_id == FLASH_UNKNOWN) { - printf ("missing or unknown FLASH type\n"); - return; - } - - switch (info->flash_id & FLASH_VENDMASK) { - case FLASH_MAN_AMD: printf ("AMD "); break; - case FLASH_MAN_FUJ: printf ("FUJITSU "); break; - default: printf ("Unknown Vendor "); break; - } - - switch (info->flash_id & FLASH_TYPEMASK) { - case FLASH_AM400B: printf ("AM29LV400B (4 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM400T: printf ("AM29LV400T (4 Mbit, top boot sector)\n"); - break; - case FLASH_AM800B: printf ("AM29LV800B (8 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM800T: printf ("AM29LV800T (8 Mbit, top boot sector)\n"); - break; - case FLASH_AM160B: printf ("AM29LV160B (16 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM160T: printf ("AM29LV160T (16 Mbit, top boot sector)\n"); - break; - case FLASH_AM320B: printf ("AM29LV320B (32 Mbit, bottom boot sect)\n"); - break; - case FLASH_AM320T: printf ("AM29LV320T (32 Mbit, top boot sector)\n"); - break; - default: printf ("Unknown Chip Type\n"); - break; - } - - printf (" Size: %ld MB in %d Sectors\n", - info->size >> 20, info->sector_count); - - printf (" Sector Start Addresses:"); - for (i=0; i<info->sector_count; ++i) { - if ((i % 5) == 0) - printf ("\n "); - printf (" %08lX%s", - info->start[i], - info->protect[i] ? " (RO)" : " " - ); - } - printf ("\n"); - return; -} - -/*----------------------------------------------------------------------- - */ - - -/*----------------------------------------------------------------------- - */ - -/* - * The following code cannot be run from FLASH! - */ - -static ulong flash_get_size (vu_long *addr, flash_info_t *info) -{ - short i; - uchar value; - vu_char *caddr = (vu_char *)addr; - ulong base = (ulong)addr; - - - /* Write auto select command: read Manufacturer ID */ - caddr[0x0AAA] = 0xAA; - caddr[0x0555] = 0x55; - caddr[0x0AAA] = 0x90; - - value = caddr[0]; - switch (value) { - case (AMD_MANUFACT & 0xFF): - info->flash_id = FLASH_MAN_AMD; - break; - case (FUJ_MANUFACT & 0xFF): - info->flash_id = FLASH_MAN_FUJ; - break; - default: - info->flash_id = FLASH_UNKNOWN; - info->sector_count = 0; - info->size = 0; - return (0); /* no or unknown flash */ - } - - value = caddr[2]; /* device ID */ - - switch (value) { - case (AMD_ID_LV400T & 0xFF): - info->flash_id += FLASH_AM400T; - info->sector_count = 11; - info->size = 0x00080000; - break; /* => 512 kB */ - - case (AMD_ID_LV400B & 0xFF): - info->flash_id += FLASH_AM400B; - info->sector_count = 11; - info->size = 0x00080000; - break; /* => 512 kB */ - - case (AMD_ID_LV800T & 0xFF): - info->flash_id += FLASH_AM800T; - info->sector_count = 19; - info->size = 0x00100000; - break; /* => 1 MB */ - - case (AMD_ID_LV800B & 0xFF): - info->flash_id += FLASH_AM800B; - info->sector_count = 19; - info->size = 0x00100000; - break; /* => 1 MB */ - - case (AMD_ID_LV160T & 0xFF): - info->flash_id += FLASH_AM160T; - info->sector_count = 35; - info->size = 0x00200000; - break; /* => 2 MB */ - - case (AMD_ID_LV160B & 0xFF): - info->flash_id += FLASH_AM160B; - info->sector_count = 35; - info->size = 0x00200000; - break; /* => 2 MB */ -#if 0 /* enable when device IDs are available */ - case (AMD_ID_LV320T & 0xFF): - info->flash_id += FLASH_AM320T; - info->sector_count = 67; - info->size = 0x00400000; - break; /* => 4 MB */ - - case (AMD_ID_LV320B & 0xFF): - info->flash_id += FLASH_AM320B; - info->sector_count = 67; - info->size = 0x00400000; - break; /* => 4 MB */ -#endif - default: - info->flash_id = FLASH_UNKNOWN; - return (0); /* => no or unknown flash */ - - } - - /* set up sector start address table */ - if (info->flash_id & FLASH_BTYPE) { - /* set sector offsets for bottom boot block type */ - info->start[0] = base + 0x00000000; - info->start[1] = base + 0x00004000; - info->start[2] = base + 0x00006000; - info->start[3] = base + 0x00008000; - for (i = 4; i < info->sector_count; i++) { - info->start[i] = base + (i * 0x00010000) - 0x00030000; - } - } else { - /* set sector offsets for top boot block type */ - i = info->sector_count - 1; - info->start[i--] = base + info->size - 0x00004000; - info->start[i--] = base + info->size - 0x00006000; - info->start[i--] = base + info->size - 0x00008000; - for (; i >= 0; i--) { - info->start[i] = base + i * 0x00010000; - } - } - - /* check for protected sectors */ - for (i = 0; i < info->sector_count; i++) { - /* read sector protection: D0 = 1 if protected */ - caddr = (volatile unsigned char *)(info->start[i]); - info->protect[i] = caddr[4] & 1; - } - - /* - * Prevent writes to uninitialized FLASH. - */ - if (info->flash_id != FLASH_UNKNOWN) { - caddr = (vu_char *)info->start[0]; - - *caddr = 0xF0; /* reset bank */ - } - - return (info->size); -} - - -/*----------------------------------------------------------------------- - */ - -int flash_erase (flash_info_t *info, int s_first, int s_last) -{ - vu_char *addr = (vu_char*)(info->start[0]); - int flag, prot, sect, l_sect; - ulong start, now, last; - - if ((s_first < 0) || (s_first > s_last)) { - if (info->flash_id == FLASH_UNKNOWN) { - printf ("- missing\n"); - } else { - printf ("- no sectors to erase\n"); - } - return 1; - } - - if ((info->flash_id == FLASH_UNKNOWN) || - (info->flash_id > FLASH_AMD_COMP)) { - printf ("Can't erase unknown flash type %08lx - aborted\n", - info->flash_id); - return 1; - } - - prot = 0; - for (sect=s_first; sect<=s_last; ++sect) { - if (info->protect[sect]) { - prot++; - } - } - - if (prot) { - printf ("- Warning: %d protected sectors will not be erased!\n", - prot); - } else { - printf ("\n"); - } - - l_sect = -1; - - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[0x0AAA] = 0xAA; - addr[0x0555] = 0x55; - addr[0x0AAA] = 0x80; - addr[0x0AAA] = 0xAA; - addr[0x0555] = 0x55; - - /* Start erase on unprotected sectors */ - for (sect = s_first; sect<=s_last; sect++) { - if (info->protect[sect] == 0) { /* not protected */ - addr = (vu_char*)(info->start[sect]); - addr[0] = 0x30; - l_sect = sect; - } - } - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* wait at least 80us - let's wait 1 ms */ - udelay (1000); - - /* - * We wait for the last triggered sector - */ - if (l_sect < 0) - goto DONE; - - start = get_timer (0); - last = start; - addr = (vu_char*)(info->start[l_sect]); - while ((addr[0] & 0x80) != 0x80) { - if ((now = get_timer(start)) > CONFIG_SYS_FLASH_ERASE_TOUT) { - printf ("Timeout\n"); - return 1; - } - /* show that we're waiting */ - if ((now - last) > 1000) { /* every second */ - putc ('.'); - last = now; - } - } - -DONE: - /* reset to read mode */ - addr = (vu_char *)info->start[0]; - addr[0] = 0xF0; /* reset bank */ - - printf (" done\n"); - return 0; -} - -/*----------------------------------------------------------------------- - * Copy memory to flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ - -int write_buff (flash_info_t *info, uchar *src, ulong addr, ulong cnt) -{ - int rc; - - while (cnt > 0) { - if ((rc = write_byte(info, addr++, *src++)) != 0) { - return (rc); - } - --cnt; - } - - return (0); -} - -/*----------------------------------------------------------------------- - * Write a word to Flash, returns: - * 0 - OK - * 1 - write timeout - * 2 - Flash not erased - */ -static int write_byte (flash_info_t *info, ulong dest, uchar data) -{ - vu_char *addr = (vu_char*)(info->start[0]); - ulong start; - int flag; - - /* Check if Flash is (sufficiently) erased */ - if ((*((vu_char *)dest) & data) != data) { - return (2); - } - /* Disable interrupts which might cause a timeout here */ - flag = disable_interrupts(); - - addr[0x0AAA] = 0xAA; - addr[0x0555] = 0x55; - addr[0x0AAA] = 0xA0; - - *((vu_char *)dest) = data; - - /* re-enable interrupts if necessary */ - if (flag) - enable_interrupts(); - - /* data polling for D7 */ - start = get_timer (0); - while ((*((vu_char *)dest) & 0x80) != (data & 0x80)) { - if (get_timer(start) > CONFIG_SYS_FLASH_WRITE_TOUT) { - return (1); - } - } - return (0); -} - -/*----------------------------------------------------------------------- - */ diff --git a/board/hermes/hermes.c b/board/hermes/hermes.c deleted file mode 100644 index 6126b73..0000000 --- a/board/hermes/hermes.c +++ /dev/null @@ -1,590 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <commproc.h> -#include <mpc8xx.h> - -#ifdef CONFIG_SHOW_BOOT_PROGRESS -# include <status_led.h> -# define SHOW_BOOT_PROGRESS(arg) bootstage_mark(arg) -#else -# define SHOW_BOOT_PROGRESS(arg) -#endif - -DECLARE_GLOBAL_DATA_PTR; - -/* ------------------------------------------------------------------------- */ - -static long int dram_size (long int, long int *, long int); -static ulong board_init (void); -static void send_smi_frame (volatile scc_t * sp, volatile cbd_t * bd, - uchar * msg); - -/* ------------------------------------------------------------------------- */ - -#define _NOT_USED_ 0xFFFFFFFF - -const uint sdram_table[] = { - /* - * Single Read. (Offset 0 in UPMA RAM) - */ - 0x1f07fc04, 0xeeaefc04, 0x11adfc04, 0xefbbbc00, - 0x1ff77c47, /* last */ - /* - * SDRAM Initialization (offset 5 in UPMA RAM) - * - * This is no UPM entry point. The following definition uses - * the remaining space to establish an initialization - * sequence, which is executed by a RUN command. - * - */ - 0x1fe77c35, 0xffaffc34, 0x1fa57c35, /* last */ - /* - * Burst Read. (Offset 8 in UPMA RAM) - */ - 0x1f07fc04, 0xeeaefc04, 0x10adfc04, 0xf0affc00, - 0xf0affc00, 0xf1affc00, 0xefbbbc00, 0x1ff77c47, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Single Write. (Offset 18 in UPMA RAM) - */ - 0x1f27fc04, 0xeeaebc00, 0x01b93c04, 0x1ff77c47, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Burst Write. (Offset 20 in UPMA RAM) - */ - 0x1f07fc04, 0xeeaebc00, 0x10ad4c00, 0xf0afcc00, - 0xf0afcc00, 0xe1bb8c06, 0x1ff77c47, /* last */ - _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Refresh (Offset 30 in UPMA RAM) - */ - 0x1ff5fc84, 0xfffffc04, 0xfffffc04, 0xfffffc04, - 0xfffffc84, 0xfffffc07, /* last */ - _NOT_USED_, _NOT_USED_, - _NOT_USED_, _NOT_USED_, _NOT_USED_, _NOT_USED_, - /* - * Exception. (Offset 3c in UPMA RAM) - */ - 0x7ffffc07, /* last */ - _NOT_USED_, _NOT_USED_, _NOT_USED_, -}; - -/* ------------------------------------------------------------------------- */ - - -/* - * Check Board Identity: - * - * Test ID string (HERMES...) - * - * Return code for board revision and network speed - */ - -int checkboard (void) -{ - char buf[64]; - int i; - int l = getenv_f("serial#", buf, sizeof(buf)); - - puts ("Board: "); - - if (l < 0 || strncmp(buf, "HERMES", 6)) { - puts ("### No HW ID - assuming HERMES-PRO"); - } else { - for (i = 0; i < l; i++) { - if (buf[i] == ' ') - break; - putc (buf[i]); - } - } - - gd->board_type = board_init (); - - printf (" Rev. %ld.x\n", (gd->board_type >> 16)); - - return (0); -} - -/* ------------------------------------------------------------------------- */ - -phys_size_t initdram (int board_type) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - long int size, size8, size9; - - upmconfig (UPMA, (uint *) sdram_table, - sizeof (sdram_table) / sizeof (uint)); - - /* - * Preliminary prescaler for refresh - */ - memctl->memc_mptpr = 0x0400; - - memctl->memc_mar = 0x00000088; - - /* - * Map controller banks 1 to the SDRAM banks at preliminary address - */ - memctl->memc_or1 = CONFIG_SYS_OR1_PRELIM; - memctl->memc_br1 = CONFIG_SYS_BR1_PRELIM; - - /* HERMES-PRO boards have only one bank SDRAM */ - - - udelay (200); - - /* perform SDRAM initializsation sequence */ - - memctl->memc_mamr = 0xD0802114; - memctl->memc_mcr = 0x80002105; - udelay (1); - memctl->memc_mamr = 0xD0802118; - memctl->memc_mcr = 0x80002130; - udelay (1); - memctl->memc_mamr = 0xD0802114; - memctl->memc_mcr = 0x80002106; - - udelay (1000); - - /* - * Check Bank 0 Memory Size for re-configuration - * - * try 8 column mode - */ - size8 = dram_size (CONFIG_SYS_MAMR_8COL, (long *) SDRAM_BASE_PRELIM, - SDRAM_MAX_SIZE); - - udelay (1000); - - /* - * try 9 column mode - */ - size9 = dram_size (CONFIG_SYS_MAMR_9COL, (long *) SDRAM_BASE_PRELIM, - SDRAM_MAX_SIZE); - - if (size8 < size9) { /* leave configuration at 9 columns */ - size = size9; -/* debug ("SDRAM Bank 0 in 9 column mode: %ld MB\n", size >> 20); */ - } else { /* back to 8 columns */ - size = size8; - memctl->memc_mamr = CONFIG_SYS_MAMR_8COL; - udelay (500); -/* debug ("SDRAM Bank 0 in 8 column mode: %ld MB\n", size >> 20); */ - } - - udelay (1000); - - memctl->memc_or1 = ((-size) & 0xFFFF0000) | SDRAM_TIMING; - memctl->memc_br1 = (CONFIG_SYS_SDRAM_BASE & BR_BA_MSK) | BR_MS_UPMA | BR_V; - - udelay (10000); - - return (size); -} - -/* ------------------------------------------------------------------------- */ - -/* - * Check memory range for valid RAM. A simple memory test determines - * the actually available RAM size between addresses `base' and - * `base + maxsize'. Some (not all) hardware errors are detected: - * - short between address lines - * - short between data lines - */ - -static long int dram_size (long int mamr_value, long int *base, - long int maxsize) -{ - volatile immap_t *immap = (immap_t *) CONFIG_SYS_IMMR; - volatile memctl8xx_t *memctl = &immap->im_memctl; - - memctl->memc_mamr = mamr_value; - - return (get_ram_size(base, maxsize)); -} - -/* ------------------------------------------------------------------------- */ - -#define PB_LED_3 0x00020000 /* Status LED's */ -#define PB_LED_2 0x00010000 -#define PB_LED_1 0x00008000 -#define PB_LED_0 0x00004000 - -#define PB_LED_ALL (PB_LED_0 | PB_LED_1 | PB_LED_2 | PB_LED_3) - -#define PC_REP_SPD1 0x00000800 -#define PC_REP_SPD0 0x00000400 - -#define PB_RESET_2081 0x00000020 /* Reset PEB2081 */ - -#define PB_MAI_4 0x00000010 /* Configuration */ -#define PB_MAI_3 0x00000008 -#define PB_MAI_2 0x00000004 -#define PB_MAI_1 0x00000002 -#define PB_MAI_0 0x00000001 - -#define PB_MAI_ALL (PB_MAI_0 | PB_MAI_1 | PB_MAI_2 | PB_MAI_3 | PB_MAI_4) - - -#define PC_REP_MGRPRS 0x0200 -#define PC_REP_SPD 0x0040 /* Select 100 Mbps */ -#define PC_REP_RES 0x0004 -#define PC_BIT14 0x0002 /* ??? */ -#define PC_BIT15 0x0001 /* ??? ENDSL ?? */ - -/* ------------------------------------------------------------------------- */ - -static ulong board_init (void) -{ - volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; - ulong reg, revision, speed = 100; - int ethspeed; - char *s; - - if ((s = getenv ("ethspeed")) != NULL) { - if (strcmp (s, "100") == 0) { - ethspeed = 100; - } else if (strcmp (s, "10") == 0) { - ethspeed = 10; - } else { - ethspeed = 0; - } - } else { - ethspeed = 0; - } - - /* Configure Port B Output Pins => 0x0003cc3F */ - reg = PB_LED_ALL | PC_REP_SPD1 | PC_REP_SPD0 | PB_RESET_2081 | - PB_MAI_ALL; - immr->im_cpm.cp_pbpar &= ~reg; - immr->im_cpm.cp_pbodr &= ~reg; - immr->im_cpm.cp_pbdat &= ~reg; /* all 0 */ - immr->im_cpm.cp_pbdir |= reg; - - /* Check hardware revision */ - if ((immr->im_ioport.iop_pcdat & 0x0003) == 0x0003) { - /* - * Revision 3.x hardware - */ - revision = 3; - - immr->im_ioport.iop_pcdat = 0x0240; - immr->im_ioport.iop_pcdir = (PC_REP_MGRPRS | PC_REP_SPD | PC_REP_RES | PC_BIT14); /* = 0x0246 */ - immr->im_ioport.iop_pcdat |= PC_REP_RES; - } else { - immr->im_ioport.iop_pcdat = 0x0002; - immr->im_ioport.iop_pcdir = (PC_REP_MGRPRS | PC_REP_RES | PC_BIT14 | PC_BIT15); /* = 0x0207 */ - - if ((immr->im_ioport.iop_pcdat & PC_REP_SPD) == 0) { - /* - * Revision 2.x hardware: PC9 connected to PB21 - */ - revision = 2; - - if (ethspeed == 0) { - /* both 10 and 100 Mbps allowed: - * select 10 Mbps and autonegotiation - */ - puts (" [10+100]"); - immr->im_cpm.cp_pbdat = 0; /* SPD1:SPD0 = 0:0 - autonegot. */ - speed = 10; - } else if (ethspeed == 10) { - /* we are asked for 10 Mbps, - * so select 10 Mbps - */ - puts (" [10]"); - immr->im_cpm.cp_pbdat = 0; /* ??? */ - speed = 10; - } else { - /* anything else: - * select 100 Mbps - */ - puts (" [100]"); - immr->im_cpm.cp_pbdat = PC_REP_SPD0 | PC_REP_SPD1; - /* SPD1:SPD0 = 1:1 - 100 Mbps */ - speed = 100; - } - immr->im_ioport.iop_pcdat |= (PC_REP_RES | PC_BIT14); - - /* must be run from RAM */ - /* start_lxt980 (speed); */ - /*************************/ - } else { - /* - * Revision 1.x hardware - */ - revision = 1; - - immr->im_ioport.iop_pcdat = PC_REP_MGRPRS | PC_BIT14; /* = 0x0202 */ - immr->im_ioport.iop_pcdir = (PC_REP_MGRPRS | PC_REP_SPD | PC_REP_RES | PC_BIT14 | PC_BIT15); /* = 0x0247 */ - - if (ethspeed == 0) { - /* both 10 and 100 Mbps allowed: - * select 100 Mbps and autonegotiation - */ - puts (" [10+100]"); - immr->im_cpm.cp_pbdat = 0; /* SPD1:SPD0 = 0:0 - autonegot. */ - immr->im_ioport.iop_pcdat |= PC_REP_SPD; - } else if (ethspeed == 10) { - /* we are asked for 10 Mbps, - * so select 10 Mbps - */ - puts (" [10]"); - immr->im_cpm.cp_pbdat = PC_REP_SPD0; /* SPD1:SPD0 = 0:1 - 10 Mbps */ - } else { - /* anything else: - * select 100 Mbps - */ - puts (" [100]"); - immr->im_cpm.cp_pbdat = PC_REP_SPD0 | PC_REP_SPD1; - /* SPD1:SPD0 = 1:1 - 100 Mbps */ - immr->im_ioport.iop_pcdat |= PC_REP_SPD; - } - - immr->im_ioport.iop_pcdat |= PC_REP_RES; - } - } - SHOW_BOOT_PROGRESS(BOOTSTAGE_ID_CHECK_MAGIC); - - return ((revision << 16) | (speed & 0xFFFF)); -} - -/* ------------------------------------------------------------------------- */ - -#define SCC_SM 1 /* Index => SCC2 */ -#define PROFF PROFF_SCC2 - -#define SMI_MSGLEN 8 /* Length of SMI Messages */ - -#define PHYGPCR_ADDR 0x109 /* Port Enable */ -#define PHYPCR_ADDR 0x132 /* PHY Port Control Reg. (port 1) */ -#define LEDPCR_ADDR 0x141 /* LED Port Control Reg. */ -#define RPRESET_ADDR 0x144 /* Repeater Reset */ - -#define PHYPCR_SPEED 0x2000 /* on for 100 Mbps, off for 10 Mbps */ -#define PHYPCR_AN 0x1000 /* on to enable Auto-Negotiation */ -#define PHYPCR_REST_AN 0x0200 /* on to restart Auto-Negotiation */ -#define PHYPCR_FDX 0x0100 /* on for Full Duplex, off for HDX */ -#define PHYPCR_COLT 0x0080 /* on to enable COL signal test */ - -/* ------------------------------------------------------------------------- */ - -/* - * Must run from RAM: - * uses parameter RAM area which is used for stack while running from ROM - */ -void hermes_start_lxt980 (int speed) -{ - volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; - volatile cpm8xx_t *cp = (cpm8xx_t *) & (immr->im_cpm); - volatile scc_t *sp = (scc_t *) & (cp->cp_scc[SCC_SM]); - volatile cbd_t *bd; - volatile hdlc_pram_t *hp; - uchar smimsg[SMI_MSGLEN]; - ushort phypcrval; - uint bd_off; - int pnr; - - printf ("LXT9880: %3d Mbps\n", speed); - - immr->im_ioport.iop_paodr |= 0x0008; /* init PAODR: PA12 (TXD2) open drain */ - immr->im_ioport.iop_papar |= 0x400c; /* init PAPAR: TXD2, RXD2, BRGO4 */ - immr->im_ioport.iop_padir &= 0xbff3; /* init PADIR: BRGO4 */ - immr->im_ioport.iop_padir |= 0x4000; - - /* get temporary BD; no need for permanent alloc */ - bd_off = dpram_base_align (8); - - bd = (cbd_t *) (immr->im_cpm.cp_dpmem + bd_off); - - bd->cbd_bufaddr = 0; - bd->cbd_datlen = 0; - bd->cbd_sc = BD_SC_WRAP | BD_SC_LAST | BD_SC_INTRPT | BD_SC_TC; - - /* init. baudrate generator BRG4 */ - cp->cp_brgc4 = (0x00010000 | (50 << 1)); /* output 1 MHz */ - - cp->cp_sicr &= 0xFFFF00FF; /* SICR: mask SCC2 */ - cp->cp_sicr |= 0x00001B00; /* SICR: SCC2 clk BRG4 */ - - /* init SCC_SM register */ - sp->scc_psmr = 0x0000; /* init PSMR: no additional flags */ - sp->scc_todr = 0x0000; - sp->scc_dsr = 0x7e7e; - - /* init. SCC_SM parameter area */ - hp = (hdlc_pram_t *) & cp->cp_dparam[PROFF]; - - hp->tbase = bd_off; /* offset from beginning of DPRAM */ - - hp->rfcr = 0x18; - hp->tfcr = 0x18; - hp->mrblr = 10; - - hp->c_mask = 0x0000f0b8; - hp->c_pres = 0x0000ffff; - - hp->disfc = 0; - hp->crcec = 0; - hp->abtsc = 0; - hp->nmarc = 0; - hp->retrc = 0; - - hp->mflr = 10; - - hp->rfthr = 1; - - hp->hmask = 0; - hp->haddr1 = 0; - hp->haddr2 = 0; - hp->haddr3 = 0; - hp->haddr4 = 0; - - cp->cp_cpcr = SCC_SM << 6 | 0x0001; /* SCC_SM: init TX/RX params */ - while (cp->cp_cpcr & CPM_CR_FLG); - - /* clear all outstanding SCC events */ - sp->scc_scce = ~0; - - /* enable transmitter: GSMR_L: TPL=2(16bits), TPP=3(all ones), ENT */ - sp->scc_gsmrh = 0; - sp->scc_gsmrl |= SCC_GSMRL_TPL_16 | SCC_GSMRL_TPP_ALL1 | - SCC_GSMRL_ENT | SCC_GSMRL_MODE_HDLC; - -#if 0 - smimsg[0] = 0x00; /* CHIP/HUB ID */ - smimsg[1] = 0x38; /* WRITE CMD */ - smimsg[2] = (RPRESET_ADDR << 4) & 0xf0; - smimsg[3] = RPRESET_ADDR >> 4; - smimsg[4] = 0x01; - smimsg[5] = 0x00; - smimsg[6] = 0x00; - smimsg[7] = 0x00; - - send_smi_frame (sp, bd, smimsg); -#endif - - smimsg[0] = 0x7f; /* BROADCAST */ - smimsg[1] = 0x34; /* ASSIGN HUB ID */ - smimsg[2] = 0x00; - smimsg[3] = 0x00; - smimsg[4] = 0x00; /* HUB ID = 0 */ - smimsg[5] = 0x00; - smimsg[6] = 0x00; - smimsg[7] = 0x00; - - send_smi_frame (sp, bd, smimsg); - - smimsg[0] = 0x7f; /* BROADCAST */ - smimsg[1] = 0x3c; /* SET ARBOUT TO 0 */ - smimsg[2] = 0x00; /* ADDRESS = 0 */ - smimsg[3] = 0x00; - smimsg[4] = 0x00; /* DATA = 0 */ - smimsg[5] = 0x00; - smimsg[6] = 0x00; - smimsg[7] = 0x00; - - send_smi_frame (sp, bd, smimsg); - - if (speed == 100) { - phypcrval = PHYPCR_SPEED; /* 100 MBIT, disable autoneg. */ - } else { - phypcrval = 0; /* 10 MBIT, disable autoneg. */ - } - - /* send MSGs */ - for (pnr = 0; pnr < 8; pnr++) { - smimsg[0] = 0x00; /* CHIP/HUB ID */ - smimsg[1] = 0x38; /* WRITE CMD */ - smimsg[2] = ((PHYPCR_ADDR + pnr) << 4) & 0xf0; - smimsg[3] = (PHYPCR_ADDR + pnr) >> 4; - smimsg[4] = (unsigned char) (phypcrval & 0xff); - smimsg[5] = (unsigned char) (phypcrval >> 8); - smimsg[6] = 0x00; - smimsg[7] = 0x00; - - send_smi_frame (sp, bd, smimsg); - } - - smimsg[0] = 0x00; /* CHIP/HUB ID */ - smimsg[1] = 0x38; /* WRITE CMD */ - smimsg[2] = (PHYGPCR_ADDR << 4) & 0xf0; - smimsg[3] = PHYGPCR_ADDR >> 4; - smimsg[4] = 0xff; /* enable port 1-8 */ - smimsg[5] = 0x01; /* enable MII1 (0x01) */ - smimsg[6] = 0x00; - smimsg[7] = 0x00; - - send_smi_frame (sp, bd, smimsg); - - smimsg[0] = 0x00; /* CHIP/HUB ID */ - smimsg[1] = 0x38; /* WRITE CMD */ - smimsg[2] = (LEDPCR_ADDR << 4) & 0xf0; - smimsg[3] = LEDPCR_ADDR >> 4; - smimsg[4] = 0xaa; /* Port 1-8 Conf.bits = 10 (Hardware control) */ - smimsg[5] = 0xaa; - smimsg[6] = 0x00; - smimsg[7] = 0x00; - - send_smi_frame (sp, bd, smimsg); - - /* - * Disable Transmitter (so that we can free the BD, too) - */ - sp->scc_gsmrl &= ~SCC_GSMRL_ENT; -} - -/* ------------------------------------------------------------------------- */ - -static void send_smi_frame (volatile scc_t * sp, volatile cbd_t * bd, - uchar * msg) -{ -#ifdef DEBUG - unsigned hub, chip, cmd, length, addr; - - hub = msg[0] & 0x1F; - chip = msg[0] >> 5; - cmd = msg[1] & 0x1F; - length = (msg[1] >> 5) | ((msg[2] & 0x0F) << 3); - addr = (msg[2] >> 4) | (msg[3] << 4); - - printf ("SMI send: Hub %02x Chip %x Cmd %02x Len %d Addr %03x: " - "%02x %02x %02x %02x\n", - hub, chip, cmd, length, addr, msg[4], msg[5], msg[6], msg[7]); -#endif /* DEBUG */ - - bd->cbd_bufaddr = (uint) msg; - bd->cbd_datlen = SMI_MSGLEN; - bd->cbd_sc |= BD_SC_READY; - - /* wait for msg transmitted */ - while ((sp->scc_scce & 0x0002) == 0); - /* clear all events */ - sp->scc_scce = ~0; -} - -/* ------------------------------------------------------------------------- */ - -void show_boot_progress (int status) -{ - volatile immap_t *immr = (immap_t *) CONFIG_SYS_IMMR; - - /* let things compatible */ - if (status < -BOOTSTAGE_ID_POST_FAIL_R) - status = -1; - status ^= 0x0F; - status = (status & 0x0F) << 14; - immr->im_cpm.cp_pbdat = (immr->im_cpm.cp_pbdat & ~PB_LED_ALL) | status; -} - -/* ------------------------------------------------------------------------- */ diff --git a/board/hermes/u-boot.lds b/board/hermes/u-boot.lds deleted file mode 100644 index 0309860..0000000 --- a/board/hermes/u-boot.lds +++ /dev/null @@ -1,88 +0,0 @@ -/* - * (C) Copyright 2000-2010 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -OUTPUT_ARCH(powerpc) - -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .text : - { - /* WARNING - the following is hand-optimized to fit within */ - /* the sector layout of our flash chips! XXX FIXME XXX */ - arch/powerpc/cpu/mpc8xx/start.o (.text*) - arch/powerpc/cpu/mpc8xx/traps.o (.text*) - board/hermes/built-in.o (.text*) - - . = env_offset; - common/env_embedded.o (.text*) - - *(.text*) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) - } - - /* Read-write section, merged into data segment: */ - . = (. + 0x00FF) & 0xFFFFFF00; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - _GOT2_TABLE_ = .; - KEEP(*(.got2)) - KEEP(*(.got)) - PROVIDE(_GLOBAL_OFFSET_TABLE_ = . + 4); - _FIXUP_TABLE_ = .; - KEEP(*(.fixup)) - } - __got2_entries = ((_GLOBAL_OFFSET_TABLE_ - _GOT2_TABLE_) >> 2) - 1; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data*) - *(.sdata*) - } - _edata = .; - PROVIDE (edata = .); - - . = .; - - . = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - - . = .; - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(256); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(256); - __init_end = .; - - __bss_start = .; - .bss (NOLOAD) : - { - *(.bss*) - *(.sbss*) - *(COMMON) - . = ALIGN(4); - } - __bss_end = . ; - PROVIDE (end = .); -} diff --git a/board/hermes/u-boot.lds.debug b/board/hermes/u-boot.lds.debug deleted file mode 100644 index f34c07b..0000000 --- a/board/hermes/u-boot.lds.debug +++ /dev/null @@ -1,121 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -OUTPUT_ARCH(powerpc) -/* Do we need any of these for elf? - __DYNAMIC = 0; */ -SECTIONS -{ - /* Read-only sections, merged into text segment: */ - . = + SIZEOF_HEADERS; - .interp : { *(.interp) } - .hash : { *(.hash) } - .dynsym : { *(.dynsym) } - .dynstr : { *(.dynstr) } - .rel.text : { *(.rel.text) } - .rela.text : { *(.rela.text) } - .rel.data : { *(.rel.data) } - .rela.data : { *(.rela.data) } - .rel.rodata : { *(.rel.rodata) } - .rela.rodata : { *(.rela.rodata) } - .rel.got : { *(.rel.got) } - .rela.got : { *(.rela.got) } - .rel.ctors : { *(.rel.ctors) } - .rela.ctors : { *(.rela.ctors) } - .rel.dtors : { *(.rel.dtors) } - .rela.dtors : { *(.rela.dtors) } - .rel.bss : { *(.rel.bss) } - .rela.bss : { *(.rela.bss) } - .rel.plt : { *(.rel.plt) } - .rela.plt : { *(.rela.plt) } - .init : { *(.init) } - .plt : { *(.plt) } - .text : - { - /* WARNING - the following is hand-optimized to fit within */ - /* the sector layout of our flash chips! XXX FIXME XXX */ - - arch/powerpc/cpu/mpc8xx/start.o (.text) - arch/powerpc/lib/ppcstring.o (.text) - arch/powerpc/cpu/mpc8xx/interrupts.o (.text) - arch/powerpc/lib/time.o (.text) - arch/powerpc/lib/ticks.o (.text) - . = env_offset; - common/env_embedded.o(.text) - - *(.text) - *(.got1) - } - _etext = .; - PROVIDE (etext = .); - .rodata : - { - *(.rodata) - *(.rodata1) - *(.rodata.str1.4) - *(.eh_frame) - } - .fini : { *(.fini) } =0 - .ctors : { *(.ctors) } - .dtors : { *(.dtors) } - - /* Read-write section, merged into data segment: */ - . = (. + 0x0FFF) & 0xFFFFF000; - _erotext = .; - PROVIDE (erotext = .); - .reloc : - { - *(.got) - _GOT2_TABLE_ = .; - *(.got2) - _FIXUP_TABLE_ = .; - *(.fixup) - } - __got2_entries = (_FIXUP_TABLE_ - _GOT2_TABLE_) >>2; - __fixup_entries = (. - _FIXUP_TABLE_)>>2; - - .data : - { - *(.data) - *(.data1) - *(.sdata) - *(.sdata2) - *(.dynamic) - CONSTRUCTORS - } - _edata = .; - PROVIDE (edata = .); - - - . = ALIGN(4); - .u_boot_list : { - KEEP(*(SORT(.u_boot_list*))); - } - - - __start___ex_table = .; - __ex_table : { *(__ex_table) } - __stop___ex_table = .; - - . = ALIGN(4096); - __init_begin = .; - .text.init : { *(.text.init) } - .data.init : { *(.data.init) } - . = ALIGN(4096); - __init_end = .; - - __bss_start = .; - .bss : - { - *(.sbss) *(.scommon) - *(.dynbss) - *(.bss) - *(COMMON) - } - __bss_end = . ; - PROVIDE (end = .); -} diff --git a/common/board_r.c b/common/board_r.c index 7c33900..862dcf3 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -453,24 +453,6 @@ static int initr_env(void) return 0; }
-#ifdef CONFIG_HERMES -static int initr_hermes(void) -{ - if ((gd->board_type >> 16) == 2) - gd->bd->bi_ethspeed = gd->board_type & 0xFFFF; - else - gd->bd->bi_ethspeed = 0xFFFF; - return 0; -} - -static int initr_hermes_start(void) -{ - if (gd->bd->bi_ethspeed != 0xFFFF) - hermes_start_lxt980((int) gd->bd->bi_ethspeed); - return 0; -} -#endif - #ifdef CONFIG_SC3 /* TODO: with new initcalls, move this into the driver */ extern void sc3_read_eeprom(void); @@ -802,9 +784,6 @@ init_fnc_t init_sequence_r[] = { #ifdef CONFIG_SC3 initr_sc3_read_eeprom, #endif -#ifdef CONFIG_HERMES - initr_hermes, -#endif #if defined(CONFIG_ID_EEPROM) || defined(CONFIG_SYS_I2C_MAC_OFFSET) mac_read_from_eeprom, #endif @@ -830,9 +809,6 @@ init_fnc_t init_sequence_r[] = { #ifdef CONFIG_MISC_INIT_R misc_init_r, /* miscellaneous platform-dependent init */ #endif -#ifdef CONFIG_HERMES - initr_hermes_start, -#endif INIT_FUNC_WATCHDOG_RESET #ifdef CONFIG_CMD_KGDB initr_kgdb, diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c index 3d37a86..f0b713c 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -144,9 +144,6 @@ int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) print_eth(5); #endif
-#ifdef CONFIG_HERMES - print_mhz("ethspeed", bd->bi_ethspeed); -#endif printf("IP addr = %s\n", getenv("ipaddr")); printf("baudrate = %6u bps\n", gd->baudrate); print_num("relocaddr", gd->relocaddr); diff --git a/configs/hermes_defconfig b/configs/hermes_defconfig deleted file mode 100644 index a923a61..0000000 --- a/configs/hermes_defconfig +++ /dev/null @@ -1,3 +0,0 @@ -CONFIG_PPC=y -CONFIG_8xx=y -CONFIG_TARGET_HERMES=y diff --git a/doc/README.scrapyard b/doc/README.scrapyard index 8ba6e0a..deb4af4 100644 --- a/doc/README.scrapyard +++ b/doc/README.scrapyard @@ -12,8 +12,9 @@ The list should be sorted in reverse chronological order.
Board Arch CPU Commit Removed Last known maintainer/contact ================================================================================================= -PRS200 powerpc mpc5200 - - -MCC200 powerpc mpc5200 - - +hermes powerpc mpc8xx - - Wolfgang Denk wd@denx.de +PRS200 powerpc mpc5200 ecfdcee 2014-11-12 +MCC200 powerpc mpc5200 ecfdcee 2014-11-12 TOP5200 powerpc mpc5200 d58a945 2014-10-28 Reinhard Meyer reinhard.meyer@emk-elektronik.de TOP860 powerpc mpc860 d58a945 2014-10-28 Reinhard Meyer reinhard.meyer@emk-elektronik.de TOP9000 arm at91sam9xeXXX d58a945 2014-10-28 Reinhard Meyer reinhard.meyer@emk-elektronik.de diff --git a/include/common.h b/include/common.h index ce0a734..b0c45cd 100644 --- a/include/common.h +++ b/include/common.h @@ -438,11 +438,6 @@ extern ssize_t spi_read (uchar *, int, uchar *, int); extern ssize_t spi_write (uchar *, int, uchar *, int); #endif
-#ifdef CONFIG_HERMES -/* $(BOARD)/hermes.c */ -void hermes_start_lxt980 (int speed); -#endif - #ifdef CONFIG_EVB64260 void evb64260_init(void); void debug_led(int, int); diff --git a/include/commproc.h b/include/commproc.h index d78ab00..6875c4c 100644 --- a/include/commproc.h +++ b/include/commproc.h @@ -535,34 +535,6 @@ typedef struct scc_enet { #define SICR_ENET_CLKRT ((uint)0x00002600) #endif /* CONFIG_FPS850L, CONFIG_FPS860L */
-/*** HERMES-PRO ******************************************************/ - -/* The HERMES-PRO uses the FEC on a MPC860T for Ethernet */ - -#ifdef CONFIG_HERMES - -#define FEC_ENET /* use FEC for EThernet */ -#undef SCC_ENET - - -#define PD_MII_TXD1 ((ushort)0x1000) /* PD 3 */ -#define PD_MII_TXD2 ((ushort)0x0800) /* PD 4 */ -#define PD_MII_TXD3 ((ushort)0x0400) /* PD 5 */ -#define PD_MII_RX_DV ((ushort)0x0200) /* PD 6 */ -#define PD_MII_RX_ERR ((ushort)0x0100) /* PD 7 */ -#define PD_MII_RX_CLK ((ushort)0x0080) /* PD 8 */ -#define PD_MII_TXD0 ((ushort)0x0040) /* PD 9 */ -#define PD_MII_RXD0 ((ushort)0x0020) /* PD 10 */ -#define PD_MII_TX_ERR ((ushort)0x0010) /* PD 11 */ -#define PD_MII_MDC ((ushort)0x0008) /* PD 12 */ -#define PD_MII_RXD1 ((ushort)0x0004) /* PD 13 */ -#define PD_MII_RXD2 ((ushort)0x0002) /* PD 14 */ -#define PD_MII_RXD3 ((ushort)0x0001) /* PD 15 */ - -#define PD_MII_MASK ((ushort)0x1FFF) /* PD 3...15 */ - -#endif /* CONFIG_HERMES */ - /*** IP860 **********************************************************/
#if defined(CONFIG_IP860) diff --git a/include/configs/hermes.h b/include/configs/hermes.h deleted file mode 100644 index 736ffb61..0000000 --- a/include/configs/hermes.h +++ /dev/null @@ -1,315 +0,0 @@ -/* - * (C) Copyright 2000 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC860 1 /* This is a MPC860T CPU */ -#define CONFIG_HERMES 1 /* ...on a HERMES-PRO board */ - -#define CONFIG_SYS_TEXT_BASE 0xFE000000 - -#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ -#undef CONFIG_8xx_CONS_SMC2 -#undef CONFIG_8xx_CONS_NONE -#define CONFIG_BAUDRATE 9600 -#if 0 -#define CONFIG_BOOTDELAY -1 /* autoboot disabled */ -#else -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ -#endif - -#define CONFIG_CLOCKS_IN_MHZ 1 /* clocks passsed to Linux in MHz */ - -#define CONFIG_BOARD_TYPES 1 /* support board types */ - -#define CONFIG_SHOW_BOOT_PROGRESS 1 /* Show boot progress on LEDs */ - -#undef CONFIG_BOOTARGS -#define CONFIG_BOOTCOMMAND \ - "bootp; " \ - "setenv bootargs root=/dev/nfs rw nfsroot=${serverip}:${rootpath} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off; " \ - "bootm" - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH - - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x00100000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x00F00000 /* 1 ... 15MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x00100000 /* default load address */ - -#define CONFIG_SYS_PIO_MODE 0 /* IDE interface in PIO Mode 0 */ - -#define CONFIG_SYS_ALLOC_DPRAM 1 /* use allocation routines */ -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFF000000 /* Non-Standard value! */ - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_SIZE 0x2F00 /* Size of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0xFE000000 -#ifdef DEBUG -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#else -#define CONFIG_SYS_MONITOR_LEN (128 << 10) /* Reserve 128 kB for Monitor */ -#endif -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ -/*----------------------------------------------------------------------- - * FLASH organization - */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 124 /* max number of sectors on one chip */ - -#define CONFIG_SYS_FLASH_ERASE_TOUT 120000 /* Timeout for Flash Erase (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Timeout for Flash Write (in ms) */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_OFFSET 0x4000 /* Offset of Environment Sector */ -#define CONFIG_ENV_SIZE 0x2000 /* Total Size of Environment Sector */ -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - * +0x0004 - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI| SYPCR_SWP) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) -#endif - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * +0x0000 => 0x000000C0 - */ -#define CONFIG_SYS_SIUMCR 0 - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - * +0x0200 => 0x00C2 - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - * +0x0240 => 0x0082 - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * Reset PLL lock status sticky bit, timer expired status bit and timer - * interrupt status bit, set PLL multiplication factor ! - */ -/* +0x0286 => 0x00B0D0C0 */ -#define CONFIG_SYS_PLPRCR \ - ( (11 << PLPRCR_MF_SHIFT) | \ - PLPRCR_SPLSS | PLPRCR_TEXPS | PLPRCR_TMIST | \ - /*PLPRCR_CSRC|*/ PLPRCR_LPM_NORMAL | \ - PLPRCR_CSR | PLPRCR_LOLRE /*|PLPRCR_FIOPD*/ \ - ) - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK SCCR_EBDF11 -/* +0x0282 => 0x03800000 */ -#define CONFIG_SYS_SCCR (SCCR_COM00 | SCCR_TBS | \ - SCCR_RTDIV | SCCR_RTSEL | \ - /*SCCR_CRQEN|*/ /*SCCR_PRQEN|*/ \ - SCCR_EBDF00 | SCCR_DFSYNC00 | \ - SCCR_DFBRG00 | SCCR_DFNL000 | \ - SCCR_DFNH000) - -/*----------------------------------------------------------------------- - * RTCSC - Real-Time Clock Status and Control Register 11-27 - *----------------------------------------------------------------------- - */ -/* +0x0220 => 0x00C3 */ -#define CONFIG_SYS_RTCSC (RTCSC_SEC | RTCSC_ALR | RTCSC_RTF| RTCSC_RTE) - - -/*----------------------------------------------------------------------- - * RCCR - RISC Controller Configuration Register 19-4 - *----------------------------------------------------------------------- - */ -/* +0x09C4 => TIMEP=1 */ -#define CONFIG_SYS_RCCR 0x0100 - -/*----------------------------------------------------------------------- - * RMDS - RISC Microcode Development Support Control Register - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RMDS 0 - -/*----------------------------------------------------------------------- - * - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_DER 0 - -/* - * Init Memory Controller: - * - * BR0 and OR0 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0xFE000000 /* FLASH bank #0 */ - -/* used to re-map FLASH - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -/* allow for max 4 MB of Flash */ -#define CONFIG_SYS_REMAP_OR_AM 0xFFC00000 /* OR addr mask */ -#define CONFIG_SYS_PRELIM_OR_AM 0xFFC00000 /* OR addr mask */ - -/* FLASH timing: ACS = 11, TRLX = 1, CSNT = 1, SCY = 5, EHTR = 0 */ -#define CONFIG_SYS_OR_TIMING_FLASH ( OR_CSNT_SAM | /*OR_ACS_DIV4 |*/ OR_BI | \ - OR_SCY_5_CLK | OR_TRLX) - -#define CONFIG_SYS_OR0_REMAP (CONFIG_SYS_REMAP_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -/* 8 bit, bank valid */ -#define CONFIG_SYS_BR0_PRELIM ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_PS_8 | BR_V ) - -/* - * BR1/OR1 - SDRAM - * - * Multiplexed addresses, GPL5 output to GPL5_A (don't care) - */ -#define SDRAM_BASE_PRELIM 0x00000000 /* SDRAM bank */ -#define SDRAM_PRELIM_OR_AM 0xF8000000 /* map max. 128 MB */ -#define SDRAM_TIMING 0x00000A00 /* SDRAM-Timing */ - -#define SDRAM_MAX_SIZE 0x04000000 /* max 64 MB SDRAM */ - -#define CONFIG_SYS_OR1_PRELIM (SDRAM_PRELIM_OR_AM | SDRAM_TIMING ) -#define CONFIG_SYS_BR1_PRELIM ((SDRAM_BASE_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_V ) - -/* - * BR2/OR2 - HPRO2: PEB2256 @ 0xE0000000, 8 Bit wide - */ -#define HPRO2_BASE 0xE0000000 -#define HPRO2_OR_AM 0xFFFF8000 -#define HPRO2_TIMING 0x00000934 - -#define CONFIG_SYS_OR2 (HPRO2_OR_AM | HPRO2_TIMING) -#define CONFIG_SYS_BR2 ((HPRO2_BASE & BR_BA_MSK) | BR_PS_8 | BR_V ) - -/* - * BR3/OR3: not used - * BR4/OR4: not used - * BR5/OR5: not used - * BR6/OR6: not used - * BR7/OR7: not used - */ - -/* - * MAMR settings for SDRAM - */ - -/* periodic timer for refresh */ -#define CONFIG_SYS_MAMR_PTA 97 /* start with divider for 100 MHz */ - -/* 8 column SDRAM */ -#define CONFIG_SYS_MAMR_8COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_0 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A11 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) -/* 9 column SDRAM */ -#define CONFIG_SYS_MAMR_9COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_1 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A10 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) -#endif /* __CONFIG_H */
Dear Masahiro Yamada,
In message 1416536771-3810-1-git-send-email-yamada.m@jp.panasonic.com you wrote:
The board has long been out of production, too.
Acked-by: Wolfgang Denk wd@denx.de
Tom, can you take this directly, or shall I send a PR?
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de Acked-by: Wolfgang Denk wd@denx.de
Masahiro Yamada
