[U-Boot] [PATCH v3 01/27] sf: Simplify fastest read cmd code
Fastest read command code look for fastest read command taking inputs from spi->mode_rx and flags from param table and controller mode_rx is always been a priority.
Since mode_rx is always set from controller side this optimized code doesn't require much and this code required exctra overhead like 1) Maintain e_rx_cmd in param table 2) Maintain mode_rx in spi_slave {}
Hence removed this code, and look for read command from normal spi->mode from spi_slave{} and params->flags
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf_internal.h | 4 ++++ drivers/mtd/spi/spi_flash.c | 28 ++++++++++------------------ 2 files changed, 14 insertions(+), 18 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index da2bb7b..c5cb791 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -46,6 +46,10 @@ enum { E_FSR = BIT(2), SST_WR = BIT(3), WR_QPP = BIT(4), + RD_QUAD = BIT(5), + RD_DUAL = BIT(6), + RD_QUADIO = BIT(7), + RD_DUALIO = BIT(8), };
enum spi_nor_option_flags { diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 64d4e0f..5fd408c 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1013,15 +1013,8 @@ int spi_flash_scan(struct spi_flash *flash) struct spi_slave *spi = flash->spi; const struct spi_flash_params *params; u16 jedec, ext_jedec; - u8 cmd, idcode[5]; + u8 idcode[5]; int ret; - static u8 spi_read_cmds_array[] = { - CMD_READ_ARRAY_SLOW, - CMD_READ_ARRAY_FAST, - CMD_READ_DUAL_OUTPUT_FAST, - CMD_READ_QUAD_OUTPUT_FAST, - CMD_READ_DUAL_IO_FAST, - CMD_READ_QUAD_IO_FAST };
/* Read the ID codes */ ret = spi_flash_cmd(spi, CMD_READ_ID, idcode, sizeof(idcode)); @@ -1177,17 +1170,16 @@ int spi_flash_scan(struct spi_flash *flash) /* Now erase size becomes valid sector size */ flash->sector_size = flash->erase_size;
- /* Look for the fastest read cmd */ - cmd = fls(params->e_rd_cmd & spi->mode_rx); - if (cmd) { - cmd = spi_read_cmds_array[cmd - 1]; - flash->read_cmd = cmd; - } else { - /* Go for default supported read cmd */ - flash->read_cmd = CMD_READ_ARRAY_FAST; - } + /* Look for read commands */ + flash->read_cmd = CMD_READ_ARRAY_FAST; + if (spi->mode_rx & SPI_RX_SLOW) + flash->read_cmd = CMD_READ_ARRAY_SLOW; + else if (spi->mode_rx & SPI_RX_QUAD && params->flags & RD_QUAD) + flash->read_cmd = CMD_READ_QUAD_OUTPUT_FAST; + else if (spi->mode_rx & SPI_RX_DUAL && params->flags & RD_DUAL) + flash->read_cmd = CMD_READ_DUAL_OUTPUT_FAST;
- /* Not require to look for fastest only two write cmds yet */ + /* Look for write commands */ if (params->flags & WR_QPP && spi->mode & SPI_TX_QUAD) flash->write_cmd = CMD_QUAD_PAGE_PROGRAM; else
e_rd_cmd is maintained separately for fastest read command code, since the read commands are computed normally this e_rd_cmd is not required in spi_flash_params table.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf_internal.h | 18 +--- drivers/mtd/spi/sf_params.c | 200 +++++++++++++++++++++--------------------- 2 files changed, 101 insertions(+), 117 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index c5cb791..71ba1a6 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -20,21 +20,6 @@ enum spi_dual_flash { SF_DUAL_PARALLEL_FLASH = BIT(1), };
-/* Enum list - Full read commands */ -enum spi_read_cmds { - ARRAY_SLOW = BIT(0), - ARRAY_FAST = BIT(1), - DUAL_OUTPUT_FAST = BIT(2), - QUAD_OUTPUT_FAST = BIT(3), - DUAL_IO_FAST = BIT(4), - QUAD_IO_FAST = BIT(5), -}; - -/* Normal - Extended - Full command set */ -#define RD_NORM (ARRAY_SLOW | ARRAY_FAST) -#define RD_EXTN (RD_NORM | DUAL_OUTPUT_FAST | DUAL_IO_FAST) -#define RD_FULL (RD_EXTN | QUAD_OUTPUT_FAST | QUAD_IO_FAST) - /* sf param flags */ enum { #ifndef CONFIG_SPI_FLASH_USE_4K_SECTORS @@ -51,6 +36,7 @@ enum { RD_QUADIO = BIT(7), RD_DUALIO = BIT(8), }; +#define RD_FULL RD_QUAD | RD_DUAL | RD_QUADIO | RD_DUALIO
enum spi_nor_option_flags { SNOR_F_SST_WR = BIT(0), @@ -145,7 +131,6 @@ int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, * @sector_size: Isn't necessarily a sector size from vendor, * the size listed here is what works with CMD_ERASE_64K * @nr_sectors: No.of sectors on this device - * @e_rd_cmd: Enum list for read commands * @flags: Important param, for flash specific behaviour */ struct spi_flash_params { @@ -154,7 +139,6 @@ struct spi_flash_params { u16 ext_jedec; u32 sector_size; u32 nr_sectors; - u8 e_rd_cmd; u16 flags; };
diff --git a/drivers/mtd/spi/sf_params.c b/drivers/mtd/spi/sf_params.c index 70ca236..5b50114 100644 --- a/drivers/mtd/spi/sf_params.c +++ b/drivers/mtd/spi/sf_params.c @@ -15,122 +15,122 @@ /* SPI/QSPI flash device params structure */ const struct spi_flash_params spi_flash_params_table[] = { #ifdef CONFIG_SPI_FLASH_ATMEL /* ATMEL */ - {"AT45DB011D", 0x1f2200, 0x0, 64 * 1024, 4, RD_NORM, SECT_4K}, - {"AT45DB021D", 0x1f2300, 0x0, 64 * 1024, 8, RD_NORM, SECT_4K}, - {"AT45DB041D", 0x1f2400, 0x0, 64 * 1024, 8, RD_NORM, SECT_4K}, - {"AT45DB081D", 0x1f2500, 0x0, 64 * 1024, 16, RD_NORM, SECT_4K}, - {"AT45DB161D", 0x1f2600, 0x0, 64 * 1024, 32, RD_NORM, SECT_4K}, - {"AT45DB321D", 0x1f2700, 0x0, 64 * 1024, 64, RD_NORM, SECT_4K}, - {"AT45DB641D", 0x1f2800, 0x0, 64 * 1024, 128, RD_NORM, SECT_4K}, - {"AT25DF321A", 0x1f4701, 0x0, 64 * 1024, 64, RD_NORM, SECT_4K}, - {"AT25DF321", 0x1f4700, 0x0, 64 * 1024, 64, RD_NORM, SECT_4K}, - {"AT26DF081A", 0x1f4501, 0x0, 64 * 1024, 16, RD_NORM, SECT_4K}, + {"AT45DB011D", 0x1f2200, 0x0, 64 * 1024, 4, SECT_4K}, + {"AT45DB021D", 0x1f2300, 0x0, 64 * 1024, 8, SECT_4K}, + {"AT45DB041D", 0x1f2400, 0x0, 64 * 1024, 8, SECT_4K}, + {"AT45DB081D", 0x1f2500, 0x0, 64 * 1024, 16, SECT_4K}, + {"AT45DB161D", 0x1f2600, 0x0, 64 * 1024, 32, SECT_4K}, + {"AT45DB321D", 0x1f2700, 0x0, 64 * 1024, 64, SECT_4K}, + {"AT45DB641D", 0x1f2800, 0x0, 64 * 1024, 128, SECT_4K}, + {"AT25DF321A", 0x1f4701, 0x0, 64 * 1024, 64, SECT_4K}, + {"AT25DF321", 0x1f4700, 0x0, 64 * 1024, 64, SECT_4K}, + {"AT26DF081A", 0x1f4501, 0x0, 64 * 1024, 16, SECT_4K}, #endif #ifdef CONFIG_SPI_FLASH_EON /* EON */ - {"EN25Q32B", 0x1c3016, 0x0, 64 * 1024, 64, RD_NORM, 0}, - {"EN25Q64", 0x1c3017, 0x0, 64 * 1024, 128, RD_NORM, SECT_4K}, - {"EN25Q128B", 0x1c3018, 0x0, 64 * 1024, 256, RD_NORM, 0}, - {"EN25S64", 0x1c3817, 0x0, 64 * 1024, 128, RD_NORM, 0}, + {"EN25Q32B", 0x1c3016, 0x0, 64 * 1024, 64, 0}, + {"EN25Q64", 0x1c3017, 0x0, 64 * 1024, 128, SECT_4K}, + {"EN25Q128B", 0x1c3018, 0x0, 64 * 1024, 256, 0}, + {"EN25S64", 0x1c3817, 0x0, 64 * 1024, 128, 0}, #endif #ifdef CONFIG_SPI_FLASH_GIGADEVICE /* GIGADEVICE */ - {"GD25Q64B", 0xc84017, 0x0, 64 * 1024, 128, RD_NORM, SECT_4K}, - {"GD25LQ32", 0xc86016, 0x0, 64 * 1024, 64, RD_NORM, SECT_4K}, + {"GD25Q64B", 0xc84017, 0x0, 64 * 1024, 128, SECT_4K}, + {"GD25LQ32", 0xc86016, 0x0, 64 * 1024, 64, SECT_4K}, #endif #ifdef CONFIG_SPI_FLASH_ISSI /* ISSI */ - {"IS25LP032", 0x9d6016, 0x0, 64 * 1024, 64, RD_NORM, 0}, - {"IS25LP064", 0x9d6017, 0x0, 64 * 1024, 128, RD_NORM, 0}, - {"IS25LP128", 0x9d6018, 0x0, 64 * 1024, 256, RD_NORM, 0}, + {"IS25LP032", 0x9d6016, 0x0, 64 * 1024, 64, 0}, + {"IS25LP064", 0x9d6017, 0x0, 64 * 1024, 128, 0}, + {"IS25LP128", 0x9d6018, 0x0, 64 * 1024, 256, 0}, #endif #ifdef CONFIG_SPI_FLASH_MACRONIX /* MACRONIX */ - {"MX25L2006E", 0xc22012, 0x0, 64 * 1024, 4, RD_NORM, 0}, - {"MX25L4005", 0xc22013, 0x0, 64 * 1024, 8, RD_NORM, 0}, - {"MX25L8005", 0xc22014, 0x0, 64 * 1024, 16, RD_NORM, 0}, - {"MX25L1605D", 0xc22015, 0x0, 64 * 1024, 32, RD_NORM, 0}, - {"MX25L3205D", 0xc22016, 0x0, 64 * 1024, 64, RD_NORM, 0}, - {"MX25L6405D", 0xc22017, 0x0, 64 * 1024, 128, RD_NORM, 0}, - {"MX25L12805", 0xc22018, 0x0, 64 * 1024, 256, RD_FULL, WR_QPP}, - {"MX25L25635F", 0xc22019, 0x0, 64 * 1024, 512, RD_FULL, WR_QPP}, - {"MX25L51235F", 0xc2201a, 0x0, 64 * 1024, 1024, RD_FULL, WR_QPP}, - {"MX25L12855E", 0xc22618, 0x0, 64 * 1024, 256, RD_FULL, WR_QPP}, + {"MX25L2006E", 0xc22012, 0x0, 64 * 1024, 4, 0}, + {"MX25L4005", 0xc22013, 0x0, 64 * 1024, 8, 0}, + {"MX25L8005", 0xc22014, 0x0, 64 * 1024, 16, 0}, + {"MX25L1605D", 0xc22015, 0x0, 64 * 1024, 32, 0}, + {"MX25L3205D", 0xc22016, 0x0, 64 * 1024, 64, 0}, + {"MX25L6405D", 0xc22017, 0x0, 64 * 1024, 128, 0}, + {"MX25L12805", 0xc22018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP}, + {"MX25L25635F", 0xc22019, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP}, + {"MX25L51235F", 0xc2201a, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP}, + {"MX25L12855E", 0xc22618, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP}, #endif #ifdef CONFIG_SPI_FLASH_SPANSION /* SPANSION */ - {"S25FL008A", 0x010213, 0x0, 64 * 1024, 16, RD_NORM, 0}, - {"S25FL016A", 0x010214, 0x0, 64 * 1024, 32, RD_NORM, 0}, - {"S25FL032A", 0x010215, 0x0, 64 * 1024, 64, RD_NORM, 0}, - {"S25FL064A", 0x010216, 0x0, 64 * 1024, 128, RD_NORM, 0}, - {"S25FL116K", 0x014015, 0x0, 64 * 1024, 128, RD_NORM, 0}, - {"S25FL164K", 0x014017, 0x0140, 64 * 1024, 128, RD_NORM, 0}, - {"S25FL128P_256K", 0x012018, 0x0300, 256 * 1024, 64, RD_FULL, WR_QPP}, - {"S25FL128P_64K", 0x012018, 0x0301, 64 * 1024, 256, RD_FULL, WR_QPP}, - {"S25FL032P", 0x010215, 0x4d00, 64 * 1024, 64, RD_FULL, WR_QPP}, - {"S25FL064P", 0x010216, 0x4d00, 64 * 1024, 128, RD_FULL, WR_QPP}, - {"S25FL128S_256K", 0x012018, 0x4d00, 256 * 1024, 64, RD_FULL, WR_QPP}, - {"S25FL128S_64K", 0x012018, 0x4d01, 64 * 1024, 256, RD_FULL, WR_QPP}, - {"S25FL256S_256K", 0x010219, 0x4d00, 256 * 1024, 128, RD_FULL, WR_QPP}, - {"S25FL256S_64K", 0x010219, 0x4d01, 64 * 1024, 512, RD_FULL, WR_QPP}, - {"S25FS512S", 0x010220, 0x4D00, 128 * 1024, 512, RD_FULL, WR_QPP}, - {"S25FL512S_256K", 0x010220, 0x4d00, 256 * 1024, 256, RD_FULL, WR_QPP}, - {"S25FL512S_64K", 0x010220, 0x4d01, 64 * 1024, 1024, RD_FULL, WR_QPP}, - {"S25FL512S_512K", 0x010220, 0x4f00, 256 * 1024, 256, RD_FULL, WR_QPP}, + {"S25FL008A", 0x010213, 0x0, 64 * 1024, 16, 0}, + {"S25FL016A", 0x010214, 0x0, 64 * 1024, 32, 0}, + {"S25FL032A", 0x010215, 0x0, 64 * 1024, 64, 0}, + {"S25FL064A", 0x010216, 0x0, 64 * 1024, 128, 0}, + {"S25FL116K", 0x014015, 0x0, 64 * 1024, 128, 0}, + {"S25FL164K", 0x014017, 0x0140, 64 * 1024, 128, 0}, + {"S25FL128P_256K", 0x012018, 0x0300, 256 * 1024, 64, RD_FULL | WR_QPP}, + {"S25FL128P_64K", 0x012018, 0x0301, 64 * 1024, 256, RD_FULL | WR_QPP}, + {"S25FL032P", 0x010215, 0x4d00, 64 * 1024, 64, RD_FULL | WR_QPP}, + {"S25FL064P", 0x010216, 0x4d00, 64 * 1024, 128, RD_FULL | WR_QPP}, + {"S25FL128S_256K", 0x012018, 0x4d00, 256 * 1024, 64, RD_FULL | WR_QPP}, + {"S25FL128S_64K", 0x012018, 0x4d01, 64 * 1024, 256, RD_FULL | WR_QPP}, + {"S25FL256S_256K", 0x010219, 0x4d00, 256 * 1024, 128, RD_FULL | WR_QPP}, + {"S25FL256S_64K", 0x010219, 0x4d01, 64 * 1024, 512, RD_FULL | WR_QPP}, + {"S25FS512S", 0x010220, 0x4D00, 128 * 1024, 512, RD_FULL | WR_QPP}, + {"S25FL512S_256K", 0x010220, 0x4d00, 256 * 1024, 256, RD_FULL | WR_QPP}, + {"S25FL512S_64K", 0x010220, 0x4d01, 64 * 1024, 1024, RD_FULL | WR_QPP}, + {"S25FL512S_512K", 0x010220, 0x4f00, 256 * 1024, 256, RD_FULL | WR_QPP}, #endif #ifdef CONFIG_SPI_FLASH_STMICRO /* STMICRO */ - {"M25P10", 0x202011, 0x0, 32 * 1024, 4, RD_NORM, 0}, - {"M25P20", 0x202012, 0x0, 64 * 1024, 4, RD_NORM, 0}, - {"M25P40", 0x202013, 0x0, 64 * 1024, 8, RD_NORM, 0}, - {"M25P80", 0x202014, 0x0, 64 * 1024, 16, RD_NORM, 0}, - {"M25P16", 0x202015, 0x0, 64 * 1024, 32, RD_NORM, 0}, - {"M25PE16", 0x208015, 0x1000, 64 * 1024, 32, RD_NORM, 0}, - {"M25PX16", 0x207115, 0x1000, 64 * 1024, 32, RD_EXTN, 0}, - {"M25P32", 0x202016, 0x0, 64 * 1024, 64, RD_NORM, 0}, - {"M25P64", 0x202017, 0x0, 64 * 1024, 128, RD_NORM, 0}, - {"M25P128", 0x202018, 0x0, 256 * 1024, 64, RD_NORM, 0}, - {"M25PX64", 0x207117, 0x0, 64 * 1024, 128, RD_NORM, SECT_4K}, - {"N25Q016A", 0x20bb15, 0x0, 64 * 1024, 32, RD_NORM, SECT_4K}, - {"N25Q32", 0x20ba16, 0x0, 64 * 1024, 64, RD_FULL, WR_QPP | SECT_4K}, - {"N25Q32A", 0x20bb16, 0x0, 64 * 1024, 64, RD_FULL, WR_QPP | SECT_4K}, - {"N25Q64", 0x20ba17, 0x0, 64 * 1024, 128, RD_FULL, WR_QPP | SECT_4K}, - {"N25Q64A", 0x20bb17, 0x0, 64 * 1024, 128, RD_FULL, WR_QPP | SECT_4K}, - {"N25Q128", 0x20ba18, 0x0, 64 * 1024, 256, RD_FULL, WR_QPP}, - {"N25Q128A", 0x20bb18, 0x0, 64 * 1024, 256, RD_FULL, WR_QPP}, - {"N25Q256", 0x20ba19, 0x0, 64 * 1024, 512, RD_FULL, WR_QPP | SECT_4K}, - {"N25Q256A", 0x20bb19, 0x0, 64 * 1024, 512, RD_FULL, WR_QPP | SECT_4K}, - {"N25Q512", 0x20ba20, 0x0, 64 * 1024, 1024, RD_FULL, WR_QPP | E_FSR | SECT_4K}, - {"N25Q512A", 0x20bb20, 0x0, 64 * 1024, 1024, RD_FULL, WR_QPP | E_FSR | SECT_4K}, - {"N25Q1024", 0x20ba21, 0x0, 64 * 1024, 2048, RD_FULL, WR_QPP | E_FSR | SECT_4K}, - {"N25Q1024A", 0x20bb21, 0x0, 64 * 1024, 2048, RD_FULL, WR_QPP | E_FSR | SECT_4K}, + {"M25P10", 0x202011, 0x0, 32 * 1024, 4, 0}, + {"M25P20", 0x202012, 0x0, 64 * 1024, 4, 0}, + {"M25P40", 0x202013, 0x0, 64 * 1024, 8, 0}, + {"M25P80", 0x202014, 0x0, 64 * 1024, 16, 0}, + {"M25P16", 0x202015, 0x0, 64 * 1024, 32, 0}, + {"M25PE16", 0x208015, 0x1000, 64 * 1024, 32, 0}, + {"M25PX16", 0x207115, 0x1000, 64 * 1024, 32, RD_QUAD | RD_DUAL}, + {"M25P32", 0x202016, 0x0, 64 * 1024, 64, 0}, + {"M25P64", 0x202017, 0x0, 64 * 1024, 128, 0}, + {"M25P128", 0x202018, 0x0, 256 * 1024, 64, 0}, + {"M25PX64", 0x207117, 0x0, 64 * 1024, 128, SECT_4K}, + {"N25Q016A", 0x20bb15, 0x0, 64 * 1024, 32, SECT_4K}, + {"N25Q32", 0x20ba16, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K}, + {"N25Q32A", 0x20bb16, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K}, + {"N25Q64", 0x20ba17, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K}, + {"N25Q64A", 0x20bb17, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K}, + {"N25Q128", 0x20ba18, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP}, + {"N25Q128A", 0x20bb18, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP}, + {"N25Q256", 0x20ba19, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K}, + {"N25Q256A", 0x20bb19, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K}, + {"N25Q512", 0x20ba20, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP | E_FSR | SECT_4K}, + {"N25Q512A", 0x20bb20, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP | E_FSR | SECT_4K}, + {"N25Q1024", 0x20ba21, 0x0, 64 * 1024, 2048, RD_FULL | WR_QPP | E_FSR | SECT_4K}, + {"N25Q1024A", 0x20bb21, 0x0, 64 * 1024, 2048, RD_FULL | WR_QPP | E_FSR | SECT_4K}, #endif #ifdef CONFIG_SPI_FLASH_SST /* SST */ - {"SST25VF040B", 0xbf258d, 0x0, 64 * 1024, 8, RD_NORM, SECT_4K | SST_WR}, - {"SST25VF080B", 0xbf258e, 0x0, 64 * 1024, 16, RD_NORM, SECT_4K | SST_WR}, - {"SST25VF016B", 0xbf2541, 0x0, 64 * 1024, 32, RD_NORM, SECT_4K | SST_WR}, - {"SST25VF032B", 0xbf254a, 0x0, 64 * 1024, 64, RD_NORM, SECT_4K | SST_WR}, - {"SST25VF064C", 0xbf254b, 0x0, 64 * 1024, 128, RD_NORM, SECT_4K}, - {"SST25WF512", 0xbf2501, 0x0, 64 * 1024, 1, RD_NORM, SECT_4K | SST_WR}, - {"SST25WF010", 0xbf2502, 0x0, 64 * 1024, 2, RD_NORM, SECT_4K | SST_WR}, - {"SST25WF020", 0xbf2503, 0x0, 64 * 1024, 4, RD_NORM, SECT_4K | SST_WR}, - {"SST25WF040", 0xbf2504, 0x0, 64 * 1024, 8, RD_NORM, SECT_4K | SST_WR}, - {"SST25WF040B", 0x621613, 0x0, 64 * 1024, 8, RD_NORM, SECT_4K}, - {"SST25WF080", 0xbf2505, 0x0, 64 * 1024, 16, RD_NORM, SECT_4K | SST_WR}, + {"SST25VF040B", 0xbf258d, 0x0, 64 * 1024, 8, SECT_4K | SST_WR}, + {"SST25VF080B", 0xbf258e, 0x0, 64 * 1024, 16, SECT_4K | SST_WR}, + {"SST25VF016B", 0xbf2541, 0x0, 64 * 1024, 32, SECT_4K | SST_WR}, + {"SST25VF032B", 0xbf254a, 0x0, 64 * 1024, 64, SECT_4K | SST_WR}, + {"SST25VF064C", 0xbf254b, 0x0, 64 * 1024, 128, SECT_4K}, + {"SST25WF512", 0xbf2501, 0x0, 64 * 1024, 1, SECT_4K | SST_WR}, + {"SST25WF010", 0xbf2502, 0x0, 64 * 1024, 2, SECT_4K | SST_WR}, + {"SST25WF020", 0xbf2503, 0x0, 64 * 1024, 4, SECT_4K | SST_WR}, + {"SST25WF040", 0xbf2504, 0x0, 64 * 1024, 8, SECT_4K | SST_WR}, + {"SST25WF040B", 0x621613, 0x0, 64 * 1024, 8, SECT_4K}, + {"SST25WF080", 0xbf2505, 0x0, 64 * 1024, 16, SECT_4K | SST_WR}, #endif #ifdef CONFIG_SPI_FLASH_WINBOND /* WINBOND */ - {"W25P80", 0xef2014, 0x0, 64 * 1024, 16, RD_NORM, 0}, - {"W25P16", 0xef2015, 0x0, 64 * 1024, 32, RD_NORM, 0}, - {"W25P32", 0xef2016, 0x0, 64 * 1024, 64, RD_NORM, 0}, - {"W25X40", 0xef3013, 0x0, 64 * 1024, 8, RD_NORM, SECT_4K}, - {"W25X16", 0xef3015, 0x0, 64 * 1024, 32, RD_NORM, SECT_4K}, - {"W25X32", 0xef3016, 0x0, 64 * 1024, 64, RD_NORM, SECT_4K}, - {"W25X64", 0xef3017, 0x0, 64 * 1024, 128, RD_NORM, SECT_4K}, - {"W25Q80BL", 0xef4014, 0x0, 64 * 1024, 16, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q16CL", 0xef4015, 0x0, 64 * 1024, 32, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q32BV", 0xef4016, 0x0, 64 * 1024, 64, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q64CV", 0xef4017, 0x0, 64 * 1024, 128, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q128BV", 0xef4018, 0x0, 64 * 1024, 256, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q256", 0xef4019, 0x0, 64 * 1024, 512, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q80BW", 0xef5014, 0x0, 64 * 1024, 16, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q16DW", 0xef6015, 0x0, 64 * 1024, 32, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q32DW", 0xef6016, 0x0, 64 * 1024, 64, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q64DW", 0xef6017, 0x0, 64 * 1024, 128, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q128FW", 0xef6018, 0x0, 64 * 1024, 256, RD_FULL, WR_QPP | SECT_4K}, + {"W25P80", 0xef2014, 0x0, 64 * 1024, 16, 0}, + {"W25P16", 0xef2015, 0x0, 64 * 1024, 32, 0}, + {"W25P32", 0xef2016, 0x0, 64 * 1024, 64, 0}, + {"W25X40", 0xef3013, 0x0, 64 * 1024, 8, SECT_4K}, + {"W25X16", 0xef3015, 0x0, 64 * 1024, 32, SECT_4K}, + {"W25X32", 0xef3016, 0x0, 64 * 1024, 64, SECT_4K}, + {"W25X64", 0xef3017, 0x0, 64 * 1024, 128, SECT_4K}, + {"W25Q80BL", 0xef4014, 0x0, 64 * 1024, 16, RD_FULL | WR_QPP | SECT_4K}, + {"W25Q16CL", 0xef4015, 0x0, 64 * 1024, 32, RD_FULL | WR_QPP | SECT_4K}, + {"W25Q32BV", 0xef4016, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K}, + {"W25Q64CV", 0xef4017, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K}, + {"W25Q128BV", 0xef4018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K}, + {"W25Q256", 0xef4019, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K}, + {"W25Q80BW", 0xef5014, 0x0, 64 * 1024, 16, RD_FULL | WR_QPP | SECT_4K}, + {"W25Q16DW", 0xef6015, 0x0, 64 * 1024, 32, RD_FULL | WR_QPP | SECT_4K}, + {"W25Q32DW", 0xef6016, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K}, + {"W25Q64DW", 0xef6017, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K}, + {"W25Q128FW", 0xef6018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K}, #endif {}, /* Empty entry to terminate the list */ /*
Make rx mode flags as generic to spi, earlier mode_rx is maintained separately because of some flash specific code.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/spi_flash.c | 6 +++--- drivers/spi/cadence_qspi.c | 2 +- drivers/spi/ich.c | 6 ++---- drivers/spi/spi-uclass.c | 11 ++++------- drivers/spi/ti_qspi.c | 6 +++--- include/spi.h | 14 ++++---------- 6 files changed, 17 insertions(+), 28 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 5fd408c..041b64f 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1172,11 +1172,11 @@ int spi_flash_scan(struct spi_flash *flash)
/* Look for read commands */ flash->read_cmd = CMD_READ_ARRAY_FAST; - if (spi->mode_rx & SPI_RX_SLOW) + if (spi->mode & SPI_RX_SLOW) flash->read_cmd = CMD_READ_ARRAY_SLOW; - else if (spi->mode_rx & SPI_RX_QUAD && params->flags & RD_QUAD) + else if (spi->mode & SPI_RX_QUAD && params->flags & RD_QUAD) flash->read_cmd = CMD_READ_QUAD_OUTPUT_FAST; - else if (spi->mode_rx & SPI_RX_DUAL && params->flags & RD_DUAL) + else if (spi->mode & SPI_RX_DUAL && params->flags & RD_DUAL) flash->read_cmd = CMD_READ_DUAL_OUTPUT_FAST;
/* Look for write commands */ diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index a5244ff..1d50f13 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -251,7 +251,7 @@ static int cadence_spi_xfer(struct udevice *dev, unsigned int bitlen, break; case CQSPI_INDIRECT_READ: err = cadence_qspi_apb_indirect_read_setup(plat, - priv->cmd_len, dm_plat->mode_rx, cmd_buf); + priv->cmd_len, dm_plat->mode, cmd_buf); if (!err) { err = cadence_qspi_apb_indirect_read_execute (plat, data_bytes, din); diff --git a/drivers/spi/ich.c b/drivers/spi/ich.c index 00b2fed..caf0103 100644 --- a/drivers/spi/ich.c +++ b/drivers/spi/ich.c @@ -649,10 +649,8 @@ static int ich_spi_child_pre_probe(struct udevice *dev) * ICH 7 SPI controller only supports array read command * and byte program command for SST flash */ - if (plat->ich_version == ICHV_7) { - slave->mode_rx = SPI_RX_SLOW; - slave->mode = SPI_TX_BYTE; - } + if (plat->ich_version == ICHV_7) + slave->mode = SPI_RX_SLOW | SPI_TX_BYTE;
return 0; } diff --git a/drivers/spi/spi-uclass.c b/drivers/spi/spi-uclass.c index 247abfa..d9c49e4 100644 --- a/drivers/spi/spi-uclass.c +++ b/drivers/spi/spi-uclass.c @@ -164,7 +164,6 @@ static int spi_child_pre_probe(struct udevice *dev)
slave->max_hz = plat->max_hz; slave->mode = plat->mode; - slave->mode_rx = plat->mode_rx; slave->wordlen = SPI_DEFAULT_WORDLEN;
return 0; @@ -381,7 +380,7 @@ void spi_free_slave(struct spi_slave *slave) int spi_slave_ofdata_to_platdata(const void *blob, int node, struct dm_spi_slave_platdata *plat) { - int mode = 0, mode_rx = 0; + int mode = 0; int value;
plat->cs = fdtdec_get_int(blob, node, "reg", -1); @@ -413,24 +412,22 @@ int spi_slave_ofdata_to_platdata(const void *blob, int node, break; }
- plat->mode = mode; - value = fdtdec_get_uint(blob, node, "spi-rx-bus-width", 1); switch (value) { case 1: break; case 2: - mode_rx |= SPI_RX_DUAL; + mode |= SPI_RX_DUAL; break; case 4: - mode_rx |= SPI_RX_QUAD; + mode |= SPI_RX_QUAD; break; default: error("spi-rx-bus-width %d not supported\n", value); break; }
- plat->mode_rx = mode_rx; + plat->mode = mode;
return 0; } diff --git a/drivers/spi/ti_qspi.c b/drivers/spi/ti_qspi.c index bb72cb0..e51cbd0 100644 --- a/drivers/spi/ti_qspi.c +++ b/drivers/spi/ti_qspi.c @@ -336,7 +336,7 @@ static void ti_spi_setup_spi_register(struct ti_qspi_priv *priv) QSPI_SETUP0_NUM_D_BYTES_8_BITS | QSPI_SETUP0_READ_QUAD | QSPI_CMD_WRITE | QSPI_NUM_DUMMY_BITS); - slave->mode_rx = SPI_RX_QUAD; + slave->mode |= SPI_RX_QUAD; #else memval |= QSPI_CMD_READ | QSPI_SETUP0_NUM_A_BYTES | QSPI_SETUP0_NUM_D_BYTES_NO_BITS | @@ -422,7 +422,7 @@ static void __ti_qspi_setup_memorymap(struct ti_qspi_priv *priv, bool enable) { u32 memval; - u32 mode = slave->mode_rx & (SPI_RX_QUAD | SPI_RX_DUAL); + u32 mode = slave->mode & (SPI_RX_QUAD | SPI_RX_DUAL);
if (!enable) { writel(0, &priv->base->setup0); @@ -436,7 +436,7 @@ static void __ti_qspi_setup_memorymap(struct ti_qspi_priv *priv, memval |= QSPI_CMD_READ_QUAD; memval |= QSPI_SETUP0_NUM_D_BYTES_8_BITS; memval |= QSPI_SETUP0_READ_QUAD; - slave->mode_rx = SPI_RX_QUAD; + slave->mode |= SPI_RX_QUAD; break; case SPI_RX_DUAL: memval |= QSPI_CMD_READ_DUAL; diff --git a/include/spi.h b/include/spi.h index ca96fa4..b262e06 100644 --- a/include/spi.h +++ b/include/spi.h @@ -26,12 +26,10 @@ #define SPI_TX_BYTE BIT(8) /* transmit with 1 wire byte */ #define SPI_TX_DUAL BIT(9) /* transmit with 2 wires */ #define SPI_TX_QUAD BIT(10) /* transmit with 4 wires */ - -/* SPI mode_rx flags */ -#define SPI_RX_SLOW BIT(0) /* receive with 1 wire slow */ -#define SPI_RX_FAST BIT(1) /* receive with 1 wire fast */ -#define SPI_RX_DUAL BIT(2) /* receive with 2 wires */ -#define SPI_RX_QUAD BIT(3) /* receive with 4 wires */ +#define SPI_RX_SLOW BIT(11) /* receive with 1 wire slow */ +#define SPI_RX_FAST BIT(12) /* receive with 1 wire fast */ +#define SPI_RX_DUAL BIT(13) /* receive with 2 wires */ +#define SPI_RX_QUAD BIT(14) /* receive with 4 wires */
/* SPI bus connection options - see enum spi_dual_flash */ #define SPI_CONN_DUAL_SHARED (1 << 0) @@ -61,13 +59,11 @@ struct dm_spi_bus { * @cs: Chip select number (0..n-1) * @max_hz: Maximum bus speed that this slave can tolerate * @mode: SPI mode to use for this device (see SPI mode flags) - * @mode_rx: SPI RX mode to use for this slave (see SPI mode_rx flags) */ struct dm_spi_slave_platdata { unsigned int cs; uint max_hz; uint mode; - u8 mode_rx; };
#endif /* CONFIG_DM_SPI */ @@ -94,7 +90,6 @@ struct dm_spi_slave_platdata { * bus (bus->seq) so does not need to be stored * @cs: ID of the chip select connected to the slave. * @mode: SPI mode to use for this slave (see SPI mode flags) - * @mode_rx: SPI RX mode to use for this slave (see SPI mode_rx flags) * @wordlen: Size of SPI word in number of bits * @max_write_size: If non-zero, the maximum number of bytes which can * be written at once, excluding command bytes. @@ -112,7 +107,6 @@ struct spi_slave { unsigned int cs; #endif uint mode; - u8 mode_rx; unsigned int wordlen; unsigned int max_write_size; void *memory_map;
Removed SPI_RX_FAST since default read for spi slaves are always 1-wire fast read.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Signed-off-by: Jagan Teki jteki@openedev.com --- include/spi.h | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/include/spi.h b/include/spi.h index b262e06..4c17983 100644 --- a/include/spi.h +++ b/include/spi.h @@ -27,9 +27,8 @@ #define SPI_TX_DUAL BIT(9) /* transmit with 2 wires */ #define SPI_TX_QUAD BIT(10) /* transmit with 4 wires */ #define SPI_RX_SLOW BIT(11) /* receive with 1 wire slow */ -#define SPI_RX_FAST BIT(12) /* receive with 1 wire fast */ -#define SPI_RX_DUAL BIT(13) /* receive with 2 wires */ -#define SPI_RX_QUAD BIT(14) /* receive with 4 wires */ +#define SPI_RX_DUAL BIT(12) /* receive with 2 wires */ +#define SPI_RX_QUAD BIT(13) /* receive with 4 wires */
SECT_32K never used anywhere in the code.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sandbox.c | 5 +---- drivers/mtd/spi/sf_internal.h | 16 +++++++--------- drivers/mtd/spi/spi_flash.c | 3 --- 3 files changed, 8 insertions(+), 16 deletions(-)
diff --git a/drivers/mtd/spi/sandbox.c b/drivers/mtd/spi/sandbox.c index 53470b9..f59134f 100644 --- a/drivers/mtd/spi/sandbox.c +++ b/drivers/mtd/spi/sandbox.c @@ -292,10 +292,7 @@ static int sandbox_sf_process_cmd(struct sandbox_spi_flash *sbsf, const u8 *rx, sbsf->data->nr_sectors; } else if (sbsf->cmd == CMD_ERASE_4K && (flags & SECT_4K)) { sbsf->erase_size = 4 << 10; - } else if (sbsf->cmd == CMD_ERASE_32K && (flags & SECT_32K)) { - sbsf->erase_size = 32 << 10; - } else if (sbsf->cmd == CMD_ERASE_64K && - !(flags & (SECT_4K | SECT_32K))) { + } else if (sbsf->cmd == CMD_ERASE_64K && !(flags & SECT_4K)) { sbsf->erase_size = 64 << 10; } else { debug(" cmd unknown: %#x\n", sbsf->cmd); diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 71ba1a6..9eb0b84 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -27,14 +27,13 @@ enum { #else SECT_4K = BIT(0), #endif - SECT_32K = BIT(1), - E_FSR = BIT(2), - SST_WR = BIT(3), - WR_QPP = BIT(4), - RD_QUAD = BIT(5), - RD_DUAL = BIT(6), - RD_QUADIO = BIT(7), - RD_DUALIO = BIT(8), + E_FSR = BIT(1), + SST_WR = BIT(2), + WR_QPP = BIT(3), + RD_QUAD = BIT(4), + RD_DUAL = BIT(5), + RD_QUADIO = BIT(6), + RD_DUALIO = BIT(7), }; #define RD_FULL RD_QUAD | RD_DUAL | RD_QUADIO | RD_DUALIO
@@ -57,7 +56,6 @@ enum spi_nor_option_flags {
/* Erase commands */ #define CMD_ERASE_4K 0x20 -#define CMD_ERASE_32K 0x52 #define CMD_ERASE_CHIP 0xc7 #define CMD_ERASE_64K 0xd8
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 041b64f..2b2a409 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1159,9 +1159,6 @@ int spi_flash_scan(struct spi_flash *flash) if (params->flags & SECT_4K) { flash->erase_cmd = CMD_ERASE_4K; flash->erase_size = 4096 << flash->shift; - } else if (params->flags & SECT_32K) { - flash->erase_cmd = CMD_ERASE_32K; - flash->erase_size = 32768 << flash->shift; } else { flash->erase_cmd = CMD_ERASE_64K; flash->erase_size = flash->sector_size;
Add CONFIG_SPI_FLASH_USE_4K_SECTORS in spi_flash code from header file.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf_internal.h | 4 ---- drivers/mtd/spi/spi_flash.c | 5 ++++- 2 files changed, 4 insertions(+), 5 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 9eb0b84..1301e48 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -22,11 +22,7 @@ enum spi_dual_flash {
/* sf param flags */ enum { -#ifndef CONFIG_SPI_FLASH_USE_4K_SECTORS - SECT_4K = 0, -#else SECT_4K = BIT(0), -#endif E_FSR = BIT(1), SST_WR = BIT(2), WR_QPP = BIT(3), diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 2b2a409..7f6e9ae 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1155,11 +1155,14 @@ int spi_flash_scan(struct spi_flash *flash) flash->size <<= 1; #endif
+#ifdef CONFIG_SPI_FLASH_USE_4K_SECTORS /* Compute erase sector and command */ if (params->flags & SECT_4K) { flash->erase_cmd = CMD_ERASE_4K; flash->erase_size = 4096 << flash->shift; - } else { + } else +#endif + { flash->erase_cmd = CMD_ERASE_64K; flash->erase_size = flash->sector_size; }
This patch moves flags macro's to respective member position on spi_flash_params{}, for better readabilty and finding the respective member macro's easily.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf_internal.h | 23 ++++++++++------------- 1 file changed, 10 insertions(+), 13 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 1301e48..cde4cfb 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -20,19 +20,6 @@ enum spi_dual_flash { SF_DUAL_PARALLEL_FLASH = BIT(1), };
-/* sf param flags */ -enum { - SECT_4K = BIT(0), - E_FSR = BIT(1), - SST_WR = BIT(2), - WR_QPP = BIT(3), - RD_QUAD = BIT(4), - RD_DUAL = BIT(5), - RD_QUADIO = BIT(6), - RD_DUALIO = BIT(7), -}; -#define RD_FULL RD_QUAD | RD_DUAL | RD_QUADIO | RD_DUALIO - enum spi_nor_option_flags { SNOR_F_SST_WR = BIT(0), SNOR_F_USE_FSR = BIT(1), @@ -133,7 +120,17 @@ struct spi_flash_params { u16 ext_jedec; u32 sector_size; u32 nr_sectors; + u16 flags; +#define SECT_4K BIT(0) +#define E_FSR BIT(1) +#define SST_WR BIT(2) +#define WR_QPP BIT(3) +#define RD_QUAD BIT(4) +#define RD_DUAL BIT(5) +#define RD_QUADIO BIT(6) +#define RD_DUALIO BIT(7) +#define RD_FULL (RD_QUAD | RD_DUAL | RD_QUADIO | RD_DUALIO) };
extern const struct spi_flash_params spi_flash_params_table[];
INFO macro make flash table entries more adjustable like adding new flash_info attributes, update ID length bytes and so on and more over it will sync to Linux way of defining flash_info attributes.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: York Sun york.sun@nxp.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf_internal.h | 15 ++- drivers/mtd/spi/sf_params.c | 215 ++++++++++++++++++++++-------------------- drivers/mtd/spi/spi_flash.c | 61 ++++++------ include/linux/err.h | 5 + 4 files changed, 160 insertions(+), 136 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index cde4cfb..e6cd6da 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -107,8 +107,6 @@ int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, * struct spi_flash_params - SPI/QSPI flash device params structure * * @name: Device name ([MANUFLETTER][DEVTYPE][DENSITY][EXTRAINFO]) - * @jedec: Device jedec ID (0x[1byte_manuf_id][2byte_dev_id]) - * @ext_jedec: Device ext_jedec ID * @sector_size: Isn't necessarily a sector size from vendor, * the size listed here is what works with CMD_ERASE_64K * @nr_sectors: No.of sectors on this device @@ -116,11 +114,20 @@ int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, */ struct spi_flash_params { const char *name; - u32 jedec; - u16 ext_jedec; + + /* + * This array stores the ID bytes. + * The first three bytes are the JEDIC ID. + * JEDEC ID zero means "no ID" (mostly older chips). + */ + u8 id[5]; + u8 id_len; + u32 sector_size; u32 nr_sectors;
+ u16 page_size; + u16 flags; #define SECT_4K BIT(0) #define E_FSR BIT(1) diff --git a/drivers/mtd/spi/sf_params.c b/drivers/mtd/spi/sf_params.c index 5b50114..70d9e18 100644 --- a/drivers/mtd/spi/sf_params.c +++ b/drivers/mtd/spi/sf_params.c @@ -12,125 +12,140 @@
#include "sf_internal.h"
+/* Used when the "_ext_id" is two bytes at most */ +#define INFO(_jedec_id, _ext_id, _sector_size, _n_sectors, _flags) \ + .id = { \ + ((_jedec_id) >> 16) & 0xff, \ + ((_jedec_id) >> 8) & 0xff, \ + (_jedec_id) & 0xff, \ + ((_ext_id) >> 8) & 0xff, \ + (_ext_id) & 0xff, \ + }, \ + .id_len = (!(_jedec_id) ? 0 : (3 + ((_ext_id) ? 2 : 0))), \ + .sector_size = (_sector_size), \ + .nr_sectors = (_n_sectors), \ + .page_size = 256, \ + .flags = (_flags), + /* SPI/QSPI flash device params structure */ const struct spi_flash_params spi_flash_params_table[] = { #ifdef CONFIG_SPI_FLASH_ATMEL /* ATMEL */ - {"AT45DB011D", 0x1f2200, 0x0, 64 * 1024, 4, SECT_4K}, - {"AT45DB021D", 0x1f2300, 0x0, 64 * 1024, 8, SECT_4K}, - {"AT45DB041D", 0x1f2400, 0x0, 64 * 1024, 8, SECT_4K}, - {"AT45DB081D", 0x1f2500, 0x0, 64 * 1024, 16, SECT_4K}, - {"AT45DB161D", 0x1f2600, 0x0, 64 * 1024, 32, SECT_4K}, - {"AT45DB321D", 0x1f2700, 0x0, 64 * 1024, 64, SECT_4K}, - {"AT45DB641D", 0x1f2800, 0x0, 64 * 1024, 128, SECT_4K}, - {"AT25DF321A", 0x1f4701, 0x0, 64 * 1024, 64, SECT_4K}, - {"AT25DF321", 0x1f4700, 0x0, 64 * 1024, 64, SECT_4K}, - {"AT26DF081A", 0x1f4501, 0x0, 64 * 1024, 16, SECT_4K}, + {"AT45DB011D", INFO(0x1f2200, 0x0, 64 * 1024, 4, SECT_4K) }, + {"AT45DB021D", INFO(0x1f2300, 0x0, 64 * 1024, 8, SECT_4K) }, + {"AT45DB041D", INFO(0x1f2400, 0x0, 64 * 1024, 8, SECT_4K) }, + {"AT45DB081D", INFO(0x1f2500, 0x0, 64 * 1024, 16, SECT_4K) }, + {"AT45DB161D", INFO(0x1f2600, 0x0, 64 * 1024, 32, SECT_4K) }, + {"AT45DB321D", INFO(0x1f2700, 0x0, 64 * 1024, 64, SECT_4K) }, + {"AT45DB641D", INFO(0x1f2800, 0x0, 64 * 1024, 128, SECT_4K) }, + {"AT25DF321A", INFO(0x1f4701, 0x0, 64 * 1024, 64, SECT_4K) }, + {"AT25DF321", INFO(0x1f4700, 0x0, 64 * 1024, 64, SECT_4K) }, + {"AT26DF081A", INFO(0x1f4501, 0x0, 64 * 1024, 16, SECT_4K) }, #endif #ifdef CONFIG_SPI_FLASH_EON /* EON */ - {"EN25Q32B", 0x1c3016, 0x0, 64 * 1024, 64, 0}, - {"EN25Q64", 0x1c3017, 0x0, 64 * 1024, 128, SECT_4K}, - {"EN25Q128B", 0x1c3018, 0x0, 64 * 1024, 256, 0}, - {"EN25S64", 0x1c3817, 0x0, 64 * 1024, 128, 0}, + {"EN25Q32B", INFO(0x1c3016, 0x0, 64 * 1024, 64, 0) }, + {"EN25Q64", INFO(0x1c3017, 0x0, 64 * 1024, 128, SECT_4K) }, + {"EN25Q128B", INFO(0x1c3018, 0x0, 64 * 1024, 256, 0) }, + {"EN25S64", INFO(0x1c3817, 0x0, 64 * 1024, 128, 0) }, #endif #ifdef CONFIG_SPI_FLASH_GIGADEVICE /* GIGADEVICE */ - {"GD25Q64B", 0xc84017, 0x0, 64 * 1024, 128, SECT_4K}, - {"GD25LQ32", 0xc86016, 0x0, 64 * 1024, 64, SECT_4K}, + {"GD25Q64B", INFO(0xc84017, 0x0, 64 * 1024, 128, SECT_4K) }, + {"GD25LQ32", INFO(0xc86016, 0x0, 64 * 1024, 64, SECT_4K) }, #endif #ifdef CONFIG_SPI_FLASH_ISSI /* ISSI */ - {"IS25LP032", 0x9d6016, 0x0, 64 * 1024, 64, 0}, - {"IS25LP064", 0x9d6017, 0x0, 64 * 1024, 128, 0}, - {"IS25LP128", 0x9d6018, 0x0, 64 * 1024, 256, 0}, + {"IS25LP032", INFO(0x9d6016, 0x0, 64 * 1024, 64, 0) }, + {"IS25LP064", INFO(0x9d6017, 0x0, 64 * 1024, 128, 0) }, + {"IS25LP128", INFO(0x9d6018, 0x0, 64 * 1024, 256, 0) }, #endif #ifdef CONFIG_SPI_FLASH_MACRONIX /* MACRONIX */ - {"MX25L2006E", 0xc22012, 0x0, 64 * 1024, 4, 0}, - {"MX25L4005", 0xc22013, 0x0, 64 * 1024, 8, 0}, - {"MX25L8005", 0xc22014, 0x0, 64 * 1024, 16, 0}, - {"MX25L1605D", 0xc22015, 0x0, 64 * 1024, 32, 0}, - {"MX25L3205D", 0xc22016, 0x0, 64 * 1024, 64, 0}, - {"MX25L6405D", 0xc22017, 0x0, 64 * 1024, 128, 0}, - {"MX25L12805", 0xc22018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP}, - {"MX25L25635F", 0xc22019, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP}, - {"MX25L51235F", 0xc2201a, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP}, - {"MX25L12855E", 0xc22618, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP}, + {"MX25L2006E", INFO(0xc22012, 0x0, 64 * 1024, 4, 0) }, + {"MX25L4005", INFO(0xc22013, 0x0, 64 * 1024, 8, 0) }, + {"MX25L8005", INFO(0xc22014, 0x0, 64 * 1024, 16, 0) }, + {"MX25L1605D", INFO(0xc22015, 0x0, 64 * 1024, 32, 0) }, + {"MX25L3205D", INFO(0xc22016, 0x0, 64 * 1024, 64, 0) }, + {"MX25L6405D", INFO(0xc22017, 0x0, 64 * 1024, 128, 0) }, + {"MX25L12805", INFO(0xc22018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP) }, + {"MX25L25635F", INFO(0xc22019, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP) }, + {"MX25L51235F", INFO(0xc2201a, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP) }, + {"MX25L12855E", INFO(0xc22618, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP) }, #endif #ifdef CONFIG_SPI_FLASH_SPANSION /* SPANSION */ - {"S25FL008A", 0x010213, 0x0, 64 * 1024, 16, 0}, - {"S25FL016A", 0x010214, 0x0, 64 * 1024, 32, 0}, - {"S25FL032A", 0x010215, 0x0, 64 * 1024, 64, 0}, - {"S25FL064A", 0x010216, 0x0, 64 * 1024, 128, 0}, - {"S25FL116K", 0x014015, 0x0, 64 * 1024, 128, 0}, - {"S25FL164K", 0x014017, 0x0140, 64 * 1024, 128, 0}, - {"S25FL128P_256K", 0x012018, 0x0300, 256 * 1024, 64, RD_FULL | WR_QPP}, - {"S25FL128P_64K", 0x012018, 0x0301, 64 * 1024, 256, RD_FULL | WR_QPP}, - {"S25FL032P", 0x010215, 0x4d00, 64 * 1024, 64, RD_FULL | WR_QPP}, - {"S25FL064P", 0x010216, 0x4d00, 64 * 1024, 128, RD_FULL | WR_QPP}, - {"S25FL128S_256K", 0x012018, 0x4d00, 256 * 1024, 64, RD_FULL | WR_QPP}, - {"S25FL128S_64K", 0x012018, 0x4d01, 64 * 1024, 256, RD_FULL | WR_QPP}, - {"S25FL256S_256K", 0x010219, 0x4d00, 256 * 1024, 128, RD_FULL | WR_QPP}, - {"S25FL256S_64K", 0x010219, 0x4d01, 64 * 1024, 512, RD_FULL | WR_QPP}, - {"S25FS512S", 0x010220, 0x4D00, 128 * 1024, 512, RD_FULL | WR_QPP}, - {"S25FL512S_256K", 0x010220, 0x4d00, 256 * 1024, 256, RD_FULL | WR_QPP}, - {"S25FL512S_64K", 0x010220, 0x4d01, 64 * 1024, 1024, RD_FULL | WR_QPP}, - {"S25FL512S_512K", 0x010220, 0x4f00, 256 * 1024, 256, RD_FULL | WR_QPP}, + {"S25FL008A", INFO(0x010213, 0x0, 64 * 1024, 16, 0) }, + {"S25FL016A", INFO(0x010214, 0x0, 64 * 1024, 32, 0) }, + {"S25FL032A", INFO(0x010215, 0x0, 64 * 1024, 64, 0) }, + {"S25FL064A", INFO(0x010216, 0x0, 64 * 1024, 128, 0) }, + {"S25FL116K", INFO(0x014015, 0x0, 64 * 1024, 128, 0) }, + {"S25FL164K", INFO(0x014017, 0x0140, 64 * 1024, 128, 0) }, + {"S25FL128P_256K", INFO(0x012018, 0x0300, 256 * 1024, 64, RD_FULL | WR_QPP) }, + {"S25FL128P_64K", INFO(0x012018, 0x0301, 64 * 1024, 256, RD_FULL | WR_QPP) }, + {"S25FL032P", INFO(0x010215, 0x4d00, 64 * 1024, 64, RD_FULL | WR_QPP) }, + {"S25FL064P", INFO(0x010216, 0x4d00, 64 * 1024, 128, RD_FULL | WR_QPP) }, + {"S25FL128S_256K", INFO(0x012018, 0x4d00, 256 * 1024, 64, RD_FULL | WR_QPP) }, + {"S25FL128S_64K", INFO(0x012018, 0x4d01, 64 * 1024, 256, RD_FULL | WR_QPP) }, + {"S25FL256S_256K", INFO(0x010219, 0x4d00, 256 * 1024, 128, RD_FULL | WR_QPP) }, + {"S25FL256S_64K", INFO(0x010219, 0x4d01, 64 * 1024, 512, RD_FULL | WR_QPP) }, + {"S25FS512S", INFO(0x010220, 0x4D00, 128 * 1024, 512, RD_FULL | WR_QPP) }, + {"S25FL512S_256K", INFO(0x010220, 0x4d00, 256 * 1024, 256, RD_FULL | WR_QPP) }, + {"S25FL512S_64K", INFO(0x010220, 0x4d01, 64 * 1024, 1024, RD_FULL | WR_QPP) }, + {"S25FL512S_512K", INFO(0x010220, 0x4f00, 256 * 1024, 256, RD_FULL | WR_QPP) }, #endif #ifdef CONFIG_SPI_FLASH_STMICRO /* STMICRO */ - {"M25P10", 0x202011, 0x0, 32 * 1024, 4, 0}, - {"M25P20", 0x202012, 0x0, 64 * 1024, 4, 0}, - {"M25P40", 0x202013, 0x0, 64 * 1024, 8, 0}, - {"M25P80", 0x202014, 0x0, 64 * 1024, 16, 0}, - {"M25P16", 0x202015, 0x0, 64 * 1024, 32, 0}, - {"M25PE16", 0x208015, 0x1000, 64 * 1024, 32, 0}, - {"M25PX16", 0x207115, 0x1000, 64 * 1024, 32, RD_QUAD | RD_DUAL}, - {"M25P32", 0x202016, 0x0, 64 * 1024, 64, 0}, - {"M25P64", 0x202017, 0x0, 64 * 1024, 128, 0}, - {"M25P128", 0x202018, 0x0, 256 * 1024, 64, 0}, - {"M25PX64", 0x207117, 0x0, 64 * 1024, 128, SECT_4K}, - {"N25Q016A", 0x20bb15, 0x0, 64 * 1024, 32, SECT_4K}, - {"N25Q32", 0x20ba16, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K}, - {"N25Q32A", 0x20bb16, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K}, - {"N25Q64", 0x20ba17, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K}, - {"N25Q64A", 0x20bb17, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K}, - {"N25Q128", 0x20ba18, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP}, - {"N25Q128A", 0x20bb18, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP}, - {"N25Q256", 0x20ba19, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K}, - {"N25Q256A", 0x20bb19, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K}, - {"N25Q512", 0x20ba20, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP | E_FSR | SECT_4K}, - {"N25Q512A", 0x20bb20, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP | E_FSR | SECT_4K}, - {"N25Q1024", 0x20ba21, 0x0, 64 * 1024, 2048, RD_FULL | WR_QPP | E_FSR | SECT_4K}, - {"N25Q1024A", 0x20bb21, 0x0, 64 * 1024, 2048, RD_FULL | WR_QPP | E_FSR | SECT_4K}, + {"M25P10", INFO(0x202011, 0x0, 32 * 1024, 4, 0) }, + {"M25P20", INFO(0x202012, 0x0, 64 * 1024, 4, 0) }, + {"M25P40", INFO(0x202013, 0x0, 64 * 1024, 8, 0) }, + {"M25P80", INFO(0x202014, 0x0, 64 * 1024, 16, 0) }, + {"M25P16", INFO(0x202015, 0x0, 64 * 1024, 32, 0) }, + {"M25PE16", INFO(0x208015, 0x1000, 64 * 1024, 32, 0) }, + {"M25PX16", INFO(0x207115, 0x1000, 64 * 1024, 32, RD_QUAD | RD_DUAL) }, + {"M25P32", INFO(0x202016, 0x0, 64 * 1024, 64, 0) }, + {"M25P64", INFO(0x202017, 0x0, 64 * 1024, 128, 0) }, + {"M25P128", INFO(0x202018, 0x0, 256 * 1024, 64, 0) }, + {"M25PX64", INFO(0x207117, 0x0, 64 * 1024, 128, SECT_4K) }, + {"N25Q016A", INFO(0x20bb15, 0x0, 64 * 1024, 32, SECT_4K) }, + {"N25Q32", INFO(0x20ba16, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, + {"N25Q32A", INFO(0x20bb16, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, + {"N25Q64", INFO(0x20ba17, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, + {"N25Q64A", INFO(0x20bb17, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, + {"N25Q128", INFO(0x20ba18, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP) }, + {"N25Q128A", INFO(0x20bb18, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP) }, + {"N25Q256", INFO(0x20ba19, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, + {"N25Q256A", INFO(0x20bb19, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, + {"N25Q512", INFO(0x20ba20, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, + {"N25Q512A", INFO(0x20bb20, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, + {"N25Q1024", INFO(0x20ba21, 0x0, 64 * 1024, 2048, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, + {"N25Q1024A", INFO(0x20bb21, 0x0, 64 * 1024, 2048, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, #endif #ifdef CONFIG_SPI_FLASH_SST /* SST */ - {"SST25VF040B", 0xbf258d, 0x0, 64 * 1024, 8, SECT_4K | SST_WR}, - {"SST25VF080B", 0xbf258e, 0x0, 64 * 1024, 16, SECT_4K | SST_WR}, - {"SST25VF016B", 0xbf2541, 0x0, 64 * 1024, 32, SECT_4K | SST_WR}, - {"SST25VF032B", 0xbf254a, 0x0, 64 * 1024, 64, SECT_4K | SST_WR}, - {"SST25VF064C", 0xbf254b, 0x0, 64 * 1024, 128, SECT_4K}, - {"SST25WF512", 0xbf2501, 0x0, 64 * 1024, 1, SECT_4K | SST_WR}, - {"SST25WF010", 0xbf2502, 0x0, 64 * 1024, 2, SECT_4K | SST_WR}, - {"SST25WF020", 0xbf2503, 0x0, 64 * 1024, 4, SECT_4K | SST_WR}, - {"SST25WF040", 0xbf2504, 0x0, 64 * 1024, 8, SECT_4K | SST_WR}, - {"SST25WF040B", 0x621613, 0x0, 64 * 1024, 8, SECT_4K}, - {"SST25WF080", 0xbf2505, 0x0, 64 * 1024, 16, SECT_4K | SST_WR}, + {"SST25VF040B", INFO(0xbf258d, 0x0, 64 * 1024, 8, SECT_4K | SST_WR) }, + {"SST25VF080B", INFO(0xbf258e, 0x0, 64 * 1024, 16, SECT_4K | SST_WR) }, + {"SST25VF016B", INFO(0xbf2541, 0x0, 64 * 1024, 32, SECT_4K | SST_WR) }, + {"SST25VF032B", INFO(0xbf254a, 0x0, 64 * 1024, 64, SECT_4K | SST_WR) }, + {"SST25VF064C", INFO(0xbf254b, 0x0, 64 * 1024, 128, SECT_4K) }, + {"SST25WF512", INFO(0xbf2501, 0x0, 64 * 1024, 1, SECT_4K | SST_WR) }, + {"SST25WF010", INFO(0xbf2502, 0x0, 64 * 1024, 2, SECT_4K | SST_WR) }, + {"SST25WF020", INFO(0xbf2503, 0x0, 64 * 1024, 4, SECT_4K | SST_WR) }, + {"SST25WF040", INFO(0xbf2504, 0x0, 64 * 1024, 8, SECT_4K | SST_WR) }, + {"SST25WF040B", INFO(0x621613, 0x0, 64 * 1024, 8, SECT_4K) }, + {"SST25WF080", INFO(0xbf2505, 0x0, 64 * 1024, 16, SECT_4K | SST_WR) }, #endif #ifdef CONFIG_SPI_FLASH_WINBOND /* WINBOND */ - {"W25P80", 0xef2014, 0x0, 64 * 1024, 16, 0}, - {"W25P16", 0xef2015, 0x0, 64 * 1024, 32, 0}, - {"W25P32", 0xef2016, 0x0, 64 * 1024, 64, 0}, - {"W25X40", 0xef3013, 0x0, 64 * 1024, 8, SECT_4K}, - {"W25X16", 0xef3015, 0x0, 64 * 1024, 32, SECT_4K}, - {"W25X32", 0xef3016, 0x0, 64 * 1024, 64, SECT_4K}, - {"W25X64", 0xef3017, 0x0, 64 * 1024, 128, SECT_4K}, - {"W25Q80BL", 0xef4014, 0x0, 64 * 1024, 16, RD_FULL | WR_QPP | SECT_4K}, - {"W25Q16CL", 0xef4015, 0x0, 64 * 1024, 32, RD_FULL | WR_QPP | SECT_4K}, - {"W25Q32BV", 0xef4016, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K}, - {"W25Q64CV", 0xef4017, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K}, - {"W25Q128BV", 0xef4018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K}, - {"W25Q256", 0xef4019, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K}, - {"W25Q80BW", 0xef5014, 0x0, 64 * 1024, 16, RD_FULL | WR_QPP | SECT_4K}, - {"W25Q16DW", 0xef6015, 0x0, 64 * 1024, 32, RD_FULL | WR_QPP | SECT_4K}, - {"W25Q32DW", 0xef6016, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K}, - {"W25Q64DW", 0xef6017, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K}, - {"W25Q128FW", 0xef6018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K}, + {"W25P80", INFO(0xef2014, 0x0, 64 * 1024, 16, 0) }, + {"W25P16", INFO(0xef2015, 0x0, 64 * 1024, 32, 0) }, + {"W25P32", INFO(0xef2016, 0x0, 64 * 1024, 64, 0) }, + {"W25X40", INFO(0xef3013, 0x0, 64 * 1024, 8, SECT_4K) }, + {"W25X16", INFO(0xef3015, 0x0, 64 * 1024, 32, SECT_4K) }, + {"W25X32", INFO(0xef3016, 0x0, 64 * 1024, 64, SECT_4K) }, + {"W25X64", INFO(0xef3017, 0x0, 64 * 1024, 128, SECT_4K) }, + {"W25Q80BL", INFO(0xef4014, 0x0, 64 * 1024, 16, RD_FULL | WR_QPP | SECT_4K) }, + {"W25Q16CL", INFO(0xef4015, 0x0, 64 * 1024, 32, RD_FULL | WR_QPP | SECT_4K) }, + {"W25Q32BV", INFO(0xef4016, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, + {"W25Q64CV", INFO(0xef4017, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, + {"W25Q128BV", INFO(0xef4018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K) }, + {"W25Q256", INFO(0xef4019, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, + {"W25Q80BW", INFO(0xef5014, 0x0, 64 * 1024, 16, RD_FULL | WR_QPP | SECT_4K) }, + {"W25Q16DW", INFO(0xef6015, 0x0, 64 * 1024, 32, RD_FULL | WR_QPP | SECT_4K) }, + {"W25Q32DW", INFO(0xef6016, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, + {"W25Q64DW", INFO(0xef6017, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, + {"W25Q128FW", INFO(0xef6018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K) }, #endif {}, /* Empty entry to terminate the list */ /* diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 7f6e9ae..680d1dc 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -924,6 +924,31 @@ static int micron_quad_enable(struct spi_flash *flash) } #endif
+static const struct spi_flash_params *spi_flash_read_id(struct spi_flash *flash) +{ + int tmp; + u8 id[5]; + const struct spi_flash_params *params; + + tmp = spi_flash_cmd(flash->spi, CMD_READ_ID, id, 5); + if (tmp < 0) { + printf("SF: error %d reading JEDEC ID\n", tmp); + return ERR_PTR(tmp); + } + + params = spi_flash_params_table; + for (; params->name != NULL; params++) { + if (params->id_len) { + if (!memcmp(params->id, id, params->id_len)) + return params; + } + } + + printf("SF: unrecognized JEDEC id bytes: %02x, %02x, %02x\n", + id[0], id[1], id[2]); + return ERR_PTR(-ENODEV); +} + static int set_quad_mode(struct spi_flash *flash, u8 idcode0) { switch (idcode0) { @@ -1011,46 +1036,18 @@ static int spansion_s25fss_disable_4KB_erase(struct spi_slave *spi) int spi_flash_scan(struct spi_flash *flash) { struct spi_slave *spi = flash->spi; - const struct spi_flash_params *params; + const struct spi_flash_params *params = NULL; u16 jedec, ext_jedec; u8 idcode[5]; int ret;
- /* Read the ID codes */ - ret = spi_flash_cmd(spi, CMD_READ_ID, idcode, sizeof(idcode)); - if (ret) { - printf("SF: Failed to get idcodes\n"); - return ret; - } - -#ifdef DEBUG - printf("SF: Got idcodes\n"); - print_buffer(0, idcode, 1, sizeof(idcode), 0); -#endif + params = spi_flash_read_id(flash); + if (IS_ERR_OR_NULL(params)) + return -ENOENT;
jedec = idcode[1] << 8 | idcode[2]; ext_jedec = idcode[3] << 8 | idcode[4];
- /* Validate params from spi_flash_params table */ - params = spi_flash_params_table; - for (; params->name != NULL; params++) { - if ((params->jedec >> 16) == idcode[0]) { - if ((params->jedec & 0xFFFF) == jedec) { - if (params->ext_jedec == 0) - break; - else if (params->ext_jedec == ext_jedec) - break; - } - } - } - - if (!params->name) { - printf("SF: Unsupported flash IDs: "); - printf("manuf %02x, jedec %04x, ext_jedec %04x\n", - idcode[0], jedec, ext_jedec); - return -EPROTONOSUPPORT; - } - #ifdef CONFIG_SPI_FLASH_SPANSION /* * The S25FS-S family physical sectors may be configured as a diff --git a/include/linux/err.h b/include/linux/err.h index 5b3c8bc..1bba498 100644 --- a/include/linux/err.h +++ b/include/linux/err.h @@ -36,6 +36,11 @@ static inline long IS_ERR(const void *ptr) return IS_ERR_VALUE((unsigned long)ptr); }
+static inline bool IS_ERR_OR_NULL(const void *ptr) +{ + return !ptr || IS_ERR_VALUE((unsigned long)ptr); +} + /** * ERR_CAST - Explicitly cast an error-valued pointer to another pointer type * @ptr: The pointer to cast.
Few of the flash families with different ext_jedec have changes in page_size so these macros check these ext_jedec and assign page_size accordingly
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: York Sun york.sun@nxp.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf_internal.h | 4 ++++ drivers/mtd/spi/spi_flash.c | 10 ++++------ 2 files changed, 8 insertions(+), 6 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index e6cd6da..966fd21 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -103,6 +103,10 @@ int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, #define CMD_SPANSION_RDAR 0x65 /* Read any device register */ #define CMD_SPANSION_WRAR 0x71 /* Write any device register */ #endif + +#define JEDEC_ID(params) (((params)->id[1]) << 8 | ((params)->id[2])) +#define JEDEC_EXT(params) (((params)->id[3]) << 8 | ((params)->id[4])) + /** * struct spi_flash_params - SPI/QSPI flash device params structure * diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 680d1dc..e979b8e 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1130,19 +1130,17 @@ int spi_flash_scan(struct spi_flash *flash)
/* Compute the flash size */ flash->shift = (flash->dual_flash & SF_DUAL_PARALLEL_FLASH) ? 1 : 0; + flash->page_size = params->page_size; /* * The Spansion S25FL032P and S25FL064P have 256b pages, yet use the * 0x4d00 Extended JEDEC code. The rest of the Spansion flashes with * the 0x4d00 Extended JEDEC code have 512b pages. All of the others * have 256b pages. */ - if (ext_jedec == 0x4d00) { - if ((jedec == 0x0215) || (jedec == 0x216) || (jedec == 0x220)) - flash->page_size = 256; - else + if (JEDEC_EXT(params) == 0x4d00) { + if ((JEDEC_ID(params) != 0x0215) && + (JEDEC_ID(params) != 0x0216)) flash->page_size = 512; - } else { - flash->page_size = 256; } flash->page_size <<= flash->shift; flash->sector_size = params->sector_size << flash->shift;
Renamed for more readability - spi_flash_params => spi_flash_info - params => info
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: York Sun york.sun@nxp.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sandbox.c | 6 +++--- drivers/mtd/spi/sf_internal.h | 10 +++++----- drivers/mtd/spi/sf_params.c | 2 +- drivers/mtd/spi/spi_flash.c | 46 +++++++++++++++++++++---------------------- 4 files changed, 32 insertions(+), 32 deletions(-)
diff --git a/drivers/mtd/spi/sandbox.c b/drivers/mtd/spi/sandbox.c index f59134f..cecebb0 100644 --- a/drivers/mtd/spi/sandbox.c +++ b/drivers/mtd/spi/sandbox.c @@ -88,7 +88,7 @@ struct sandbox_spi_flash { /* The current flash status (see STAT_XXX defines above) */ u16 status; /* Data describing the flash we're emulating */ - const struct spi_flash_params *data; + const struct spi_flash_info *data; /* The file on disk to serv up data from */ int fd; }; @@ -112,7 +112,7 @@ static int sandbox_sf_probe(struct udevice *dev) struct sandbox_spi_flash *sbsf = dev_get_priv(dev); const char *file; size_t len, idname_len; - const struct spi_flash_params *data; + const struct spi_flash_info *data; struct sandbox_spi_flash_plat_data *pdata = dev_get_platdata(dev); struct sandbox_state *state = state_get_current(); struct udevice *bus = dev->parent; @@ -168,7 +168,7 @@ static int sandbox_sf_probe(struct udevice *dev) } debug("%s: device='%s'\n", __func__, spec);
- for (data = spi_flash_params_table; data->name; data++) { + for (data = spi_flash_ids; data->name; data++) { len = strlen(data->name); if (idname_len != len) continue; diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 966fd21..bb5251d 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -104,11 +104,11 @@ int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, #define CMD_SPANSION_WRAR 0x71 /* Write any device register */ #endif
-#define JEDEC_ID(params) (((params)->id[1]) << 8 | ((params)->id[2])) -#define JEDEC_EXT(params) (((params)->id[3]) << 8 | ((params)->id[4])) +#define JEDEC_ID(info) (((info)->id[1]) << 8 | ((info)->id[2])) +#define JEDEC_EXT(info) (((info)->id[3]) << 8 | ((info)->id[4]))
/** - * struct spi_flash_params - SPI/QSPI flash device params structure + * struct spi_flash_info - SPI/QSPI flash device params structure * * @name: Device name ([MANUFLETTER][DEVTYPE][DENSITY][EXTRAINFO]) * @sector_size: Isn't necessarily a sector size from vendor, @@ -116,7 +116,7 @@ int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, * @nr_sectors: No.of sectors on this device * @flags: Important param, for flash specific behaviour */ -struct spi_flash_params { +struct spi_flash_info { const char *name;
/* @@ -144,7 +144,7 @@ struct spi_flash_params { #define RD_FULL (RD_QUAD | RD_DUAL | RD_QUADIO | RD_DUALIO) };
-extern const struct spi_flash_params spi_flash_params_table[]; +extern const struct spi_flash_info spi_flash_ids[];
/* Send a single-byte command to the device and read the response */ int spi_flash_cmd(struct spi_slave *spi, u8 cmd, void *response, size_t len); diff --git a/drivers/mtd/spi/sf_params.c b/drivers/mtd/spi/sf_params.c index 70d9e18..7fcc3bc 100644 --- a/drivers/mtd/spi/sf_params.c +++ b/drivers/mtd/spi/sf_params.c @@ -28,7 +28,7 @@ .flags = (_flags),
/* SPI/QSPI flash device params structure */ -const struct spi_flash_params spi_flash_params_table[] = { +const struct spi_flash_info spi_flash_ids[] = { #ifdef CONFIG_SPI_FLASH_ATMEL /* ATMEL */ {"AT45DB011D", INFO(0x1f2200, 0x0, 64 * 1024, 4, SECT_4K) }, {"AT45DB021D", INFO(0x1f2300, 0x0, 64 * 1024, 8, SECT_4K) }, diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index e979b8e..099714e 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -924,11 +924,11 @@ static int micron_quad_enable(struct spi_flash *flash) } #endif
-static const struct spi_flash_params *spi_flash_read_id(struct spi_flash *flash) +static const struct spi_flash_info *spi_flash_read_id(struct spi_flash *flash) { int tmp; u8 id[5]; - const struct spi_flash_params *params; + const struct spi_flash_info *info;
tmp = spi_flash_cmd(flash->spi, CMD_READ_ID, id, 5); if (tmp < 0) { @@ -936,11 +936,11 @@ static const struct spi_flash_params *spi_flash_read_id(struct spi_flash *flash) return ERR_PTR(tmp); }
- params = spi_flash_params_table; - for (; params->name != NULL; params++) { - if (params->id_len) { - if (!memcmp(params->id, id, params->id_len)) - return params; + info = spi_flash_ids; + for (; info->name != NULL; info++) { + if (info->id_len) { + if (!memcmp(info->id, id, info->id_len)) + return info; } }
@@ -1036,13 +1036,13 @@ static int spansion_s25fss_disable_4KB_erase(struct spi_slave *spi) int spi_flash_scan(struct spi_flash *flash) { struct spi_slave *spi = flash->spi; - const struct spi_flash_params *params = NULL; + const struct spi_flash_info *info = NULL; u16 jedec, ext_jedec; u8 idcode[5]; int ret;
- params = spi_flash_read_id(flash); - if (IS_ERR_OR_NULL(params)) + info = spi_flash_read_id(flash); + if (IS_ERR_OR_NULL(info)) return -ENOENT;
jedec = idcode[1] << 8 | idcode[2]; @@ -1091,12 +1091,12 @@ int spi_flash_scan(struct spi_flash *flash) write_sr(flash, 0);
/* Assign spi data */ - flash->name = params->name; + flash->name = info->name; flash->memory_map = spi->memory_map; flash->dual_flash = spi->option;
/* Assign spi flash flags */ - if (params->flags & SST_WR) + if (info->flags & SST_WR) flash->flags |= SNOR_F_SST_WR;
/* Assign spi_flash ops */ @@ -1130,21 +1130,21 @@ int spi_flash_scan(struct spi_flash *flash)
/* Compute the flash size */ flash->shift = (flash->dual_flash & SF_DUAL_PARALLEL_FLASH) ? 1 : 0; - flash->page_size = params->page_size; + flash->page_size = info->page_size; /* * The Spansion S25FL032P and S25FL064P have 256b pages, yet use the * 0x4d00 Extended JEDEC code. The rest of the Spansion flashes with * the 0x4d00 Extended JEDEC code have 512b pages. All of the others * have 256b pages. */ - if (JEDEC_EXT(params) == 0x4d00) { - if ((JEDEC_ID(params) != 0x0215) && - (JEDEC_ID(params) != 0x0216)) + if (JEDEC_EXT(info) == 0x4d00) { + if ((JEDEC_ID(info) != 0x0215) && + (JEDEC_ID(info) != 0x0216)) flash->page_size = 512; } flash->page_size <<= flash->shift; - flash->sector_size = params->sector_size << flash->shift; - flash->size = flash->sector_size * params->nr_sectors << flash->shift; + flash->sector_size = info->sector_size << flash->shift; + flash->size = flash->sector_size * info->nr_sectors << flash->shift; #ifdef CONFIG_SF_DUAL_FLASH if (flash->dual_flash & SF_DUAL_STACKED_FLASH) flash->size <<= 1; @@ -1152,7 +1152,7 @@ int spi_flash_scan(struct spi_flash *flash)
#ifdef CONFIG_SPI_FLASH_USE_4K_SECTORS /* Compute erase sector and command */ - if (params->flags & SECT_4K) { + if (info->flags & SECT_4K) { flash->erase_cmd = CMD_ERASE_4K; flash->erase_size = 4096 << flash->shift; } else @@ -1169,13 +1169,13 @@ int spi_flash_scan(struct spi_flash *flash) flash->read_cmd = CMD_READ_ARRAY_FAST; if (spi->mode & SPI_RX_SLOW) flash->read_cmd = CMD_READ_ARRAY_SLOW; - else if (spi->mode & SPI_RX_QUAD && params->flags & RD_QUAD) + else if (spi->mode & SPI_RX_QUAD && info->flags & RD_QUAD) flash->read_cmd = CMD_READ_QUAD_OUTPUT_FAST; - else if (spi->mode & SPI_RX_DUAL && params->flags & RD_DUAL) + else if (spi->mode & SPI_RX_DUAL && info->flags & RD_DUAL) flash->read_cmd = CMD_READ_DUAL_OUTPUT_FAST;
/* Look for write commands */ - if (params->flags & WR_QPP && spi->mode & SPI_TX_QUAD) + if (info->flags & WR_QPP && spi->mode & SPI_TX_QUAD) flash->write_cmd = CMD_QUAD_PAGE_PROGRAM; else /* Go for default supported write cmd */ @@ -1212,7 +1212,7 @@ int spi_flash_scan(struct spi_flash *flash) }
#ifdef CONFIG_SPI_FLASH_STMICRO - if (params->flags & E_FSR) + if (info->flags & E_FSR) flash->flags |= SNOR_F_USE_FSR; #endif
Instead using idcode[0] for detecting manufacture id add JEDEC_MFR macro for code simplicity and undesirability.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: York Sun york.sun@nxp.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf_internal.h | 1 + drivers/mtd/spi/spi_flash.c | 30 +++++++++++++++++------------- 2 files changed, 18 insertions(+), 13 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index bb5251d..a9455ac 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -104,6 +104,7 @@ int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, #define CMD_SPANSION_WRAR 0x71 /* Write any device register */ #endif
+#define JEDEC_MFR(info) ((info)->id[0]) #define JEDEC_ID(info) (((info)->id[1]) << 8 | ((info)->id[2])) #define JEDEC_EXT(info) (((info)->id[3]) << 8 | ((info)->id[4]))
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 099714e..daa9014 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -165,7 +165,8 @@ bar_end: return flash->bank_curr; }
-static int spi_flash_read_bar(struct spi_flash *flash, u8 idcode0) +static int spi_flash_read_bar(struct spi_flash *flash, + const struct spi_flash_info *info) { u8 curr_bank = 0; int ret; @@ -173,7 +174,7 @@ static int spi_flash_read_bar(struct spi_flash *flash, u8 idcode0) if (flash->size <= SPI_FLASH_16MB_BOUN) goto bar_end;
- switch (idcode0) { + switch (JEDEC_MFR(info)) { case SPI_FLASH_CFI_MFR_SPANSION: flash->bank_read_cmd = CMD_BANKADDR_BRRD; flash->bank_write_cmd = CMD_BANKADDR_BRWR; @@ -949,9 +950,10 @@ static const struct spi_flash_info *spi_flash_read_id(struct spi_flash *flash) return ERR_PTR(-ENODEV); }
-static int set_quad_mode(struct spi_flash *flash, u8 idcode0) +static int set_quad_mode(struct spi_flash *flash, + const struct spi_flash_info *info) { - switch (idcode0) { + switch (JEDEC_MFR(info)) { #ifdef CONFIG_SPI_FLASH_MACRONIX case SPI_FLASH_CFI_MFR_MACRONIX: return macronix_quad_enable(flash); @@ -966,7 +968,8 @@ static int set_quad_mode(struct spi_flash *flash, u8 idcode0) return micron_quad_enable(flash); #endif default: - printf("SF: Need set QEB func for %02x flash\n", idcode0); + printf("SF: Need set QEB func for %02x flash\n", + JEDEC_MFR(info)); return -1; } } @@ -1085,9 +1088,9 @@ int spi_flash_scan(struct spi_flash *flash) } #endif /* Flash powers up read-only, so clear BP# bits */ - if (idcode[0] == SPI_FLASH_CFI_MFR_ATMEL || - idcode[0] == SPI_FLASH_CFI_MFR_MACRONIX || - idcode[0] == SPI_FLASH_CFI_MFR_SST) + if (JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_ATMEL || + JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_MACRONIX || + JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_SST) write_sr(flash, 0);
/* Assign spi data */ @@ -1115,7 +1118,7 @@ int spi_flash_scan(struct spi_flash *flash) #endif
/* lock hooks are flash specific - assign them based on idcode0 */ - switch (idcode[0]) { + switch (JEDEC_MFR(info)) { #if defined(CONFIG_SPI_FLASH_STMICRO) || defined(CONFIG_SPI_FLASH_SST) case SPI_FLASH_CFI_MFR_STMICRO: case SPI_FLASH_CFI_MFR_SST: @@ -1125,7 +1128,7 @@ int spi_flash_scan(struct spi_flash *flash) #endif break; default: - debug("SF: Lock ops not supported for %02x flash\n", idcode[0]); + debug("SF: Lock ops not supported for %02x flash\n", JEDEC_MFR(info)); }
/* Compute the flash size */ @@ -1185,9 +1188,10 @@ int spi_flash_scan(struct spi_flash *flash) if ((flash->read_cmd == CMD_READ_QUAD_OUTPUT_FAST) || (flash->read_cmd == CMD_READ_QUAD_IO_FAST) || (flash->write_cmd == CMD_QUAD_PAGE_PROGRAM)) { - ret = set_quad_mode(flash, idcode[0]); + ret = set_quad_mode(flash, info); if (ret) { - debug("SF: Fail to set QEB for %02x\n", idcode[0]); + debug("SF: Fail to set QEB for %02x\n", + JEDEC_MFR(info)); return -EINVAL; } } @@ -1218,7 +1222,7 @@ int spi_flash_scan(struct spi_flash *flash)
/* Configure the BAR - discover bank cmds and read current bank */ #ifdef CONFIG_SPI_FLASH_BAR - ret = spi_flash_read_bar(flash, idcode[0]); + ret = spi_flash_read_bar(flash, info); if (ret < 0) return ret; #endif
Simplify the flash_lock ops detection code and added meaningful comment.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: York Sun york.sun@nxp.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/spi_flash.c | 12 ++++-------- 1 file changed, 4 insertions(+), 8 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index daa9014..b92b0bf 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1117,19 +1117,15 @@ int spi_flash_scan(struct spi_flash *flash) flash->read = spi_flash_cmd_read_ops; #endif
- /* lock hooks are flash specific - assign them based on idcode0 */ - switch (JEDEC_MFR(info)) { #if defined(CONFIG_SPI_FLASH_STMICRO) || defined(CONFIG_SPI_FLASH_SST) - case SPI_FLASH_CFI_MFR_STMICRO: - case SPI_FLASH_CFI_MFR_SST: + /* NOR protection support for STmicro/Micron chips and similar */ + if (JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_STMICRO || + JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_SST) { flash->flash_lock = stm_lock; flash->flash_unlock = stm_unlock; flash->flash_is_locked = stm_is_locked; -#endif - break; - default: - debug("SF: Lock ops not supported for %02x flash\n", JEDEC_MFR(info)); } +#endif
This patch fix the id exctract from spi_flash_info ids.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sandbox.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/sandbox.c b/drivers/mtd/spi/sandbox.c index cecebb0..09ce783 100644 --- a/drivers/mtd/spi/sandbox.c +++ b/drivers/mtd/spi/sandbox.c @@ -359,7 +359,8 @@ static int sandbox_sf_xfer(struct udevice *dev, unsigned int bitlen, debug(" id: off:%u tx:", sbsf->off); if (sbsf->off < IDCODE_LEN) { /* Extract correct byte from ID 0x00aabbcc */ - id = sbsf->data->jedec >> + id = ((JEDEC_MFR(sbsf->data) << 16) | + JEDEC_ID(sbsf->data)) >> (8 * (IDCODE_LEN - 1 - sbsf->off)); } else { id = 0;
- Proper tabs spaces - Removed unnecessary - Added meaningful comments
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: York Sun york.sun@nxp.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf_internal.h | 22 ++++++++-------------- 1 file changed, 8 insertions(+), 14 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index a9455ac..71feba9 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -108,17 +108,8 @@ int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, #define JEDEC_ID(info) (((info)->id[1]) << 8 | ((info)->id[2])) #define JEDEC_EXT(info) (((info)->id[3]) << 8 | ((info)->id[4]))
-/** - * struct spi_flash_info - SPI/QSPI flash device params structure - * - * @name: Device name ([MANUFLETTER][DEVTYPE][DENSITY][EXTRAINFO]) - * @sector_size: Isn't necessarily a sector size from vendor, - * the size listed here is what works with CMD_ERASE_64K - * @nr_sectors: No.of sectors on this device - * @flags: Important param, for flash specific behaviour - */ struct spi_flash_info { - const char *name; + const char *name;
/* * This array stores the ID bytes. @@ -128,12 +119,15 @@ struct spi_flash_info { u8 id[5]; u8 id_len;
- u32 sector_size; - u32 nr_sectors; + /* The size listed here is what works with SPINOR_OP_SE, which isn't + * necessarily called a "sector" by the vendor. + */ + u32 sector_size; + u32 nr_sectors;
- u16 page_size; + u16 page_size;
- u16 flags; + u16 flags; #define SECT_4K BIT(0) #define E_FSR BIT(1) #define SST_WR BIT(2)
- Move headers froms sf_params to common header file - Removed unnecessary comment
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: York Sun york.sun@nxp.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf_internal.h | 5 +++-- drivers/mtd/spi/sf_params.c | 5 ----- 2 files changed, 3 insertions(+), 7 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 71feba9..4a88cf7 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -10,8 +10,9 @@ #ifndef _SF_INTERNAL_H_ #define _SF_INTERNAL_H_
-#include <linux/types.h> -#include <linux/compiler.h> +#include <common.h> +#include <spi.h> +#include <spi_flash.h>
/* Dual SPI flash memories - see SPI_COMM_DUAL_... */ enum spi_dual_flash { diff --git a/drivers/mtd/spi/sf_params.c b/drivers/mtd/spi/sf_params.c index 7fcc3bc..7314455 100644 --- a/drivers/mtd/spi/sf_params.c +++ b/drivers/mtd/spi/sf_params.c @@ -6,10 +6,6 @@ * SPDX-License-Identifier: GPL-2.0+ */
-#include <common.h> -#include <spi.h> -#include <spi_flash.h> - #include "sf_internal.h"
/* Used when the "_ext_id" is two bytes at most */ @@ -27,7 +23,6 @@ .page_size = 256, \ .flags = (_flags),
-/* SPI/QSPI flash device params structure */ const struct spi_flash_info spi_flash_ids[] = { #ifdef CONFIG_SPI_FLASH_ATMEL /* ATMEL */ {"AT45DB011D", INFO(0x1f2200, 0x0, 64 * 1024, 4, SECT_4K) },
Rename nr_sectors as n_sectors to sync with Linux.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: York Sun york.sun@nxp.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sandbox.c | 2 +- drivers/mtd/spi/sf_internal.h | 2 +- drivers/mtd/spi/sf_params.c | 2 +- drivers/mtd/spi/spi_flash.c | 2 +- 4 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/mtd/spi/sandbox.c b/drivers/mtd/spi/sandbox.c index 09ce783..4944059 100644 --- a/drivers/mtd/spi/sandbox.c +++ b/drivers/mtd/spi/sandbox.c @@ -289,7 +289,7 @@ static int sandbox_sf_process_cmd(struct sandbox_spi_flash *sbsf, const u8 *rx, /* we only support erase here */ if (sbsf->cmd == CMD_ERASE_CHIP) { sbsf->erase_size = sbsf->data->sector_size * - sbsf->data->nr_sectors; + sbsf->data->n_sectors; } else if (sbsf->cmd == CMD_ERASE_4K && (flags & SECT_4K)) { sbsf->erase_size = 4 << 10; } else if (sbsf->cmd == CMD_ERASE_64K && !(flags & SECT_4K)) { diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 4a88cf7..527c252 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -124,7 +124,7 @@ struct spi_flash_info { * necessarily called a "sector" by the vendor. */ u32 sector_size; - u32 nr_sectors; + u32 n_sectors;
u16 page_size;
diff --git a/drivers/mtd/spi/sf_params.c b/drivers/mtd/spi/sf_params.c index 7314455..8a2a6b2 100644 --- a/drivers/mtd/spi/sf_params.c +++ b/drivers/mtd/spi/sf_params.c @@ -19,7 +19,7 @@ }, \ .id_len = (!(_jedec_id) ? 0 : (3 + ((_ext_id) ? 2 : 0))), \ .sector_size = (_sector_size), \ - .nr_sectors = (_n_sectors), \ + .n_sectors = (_n_sectors), \ .page_size = 256, \ .flags = (_flags),
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index b92b0bf..0777bb5 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1143,7 +1143,7 @@ int spi_flash_scan(struct spi_flash *flash) } flash->page_size <<= flash->shift; flash->sector_size = info->sector_size << flash->shift; - flash->size = flash->sector_size * info->nr_sectors << flash->shift; + flash->size = flash->sector_size * info->n_sectors << flash->shift; #ifdef CONFIG_SF_DUAL_FLASH if (flash->dual_flash & SF_DUAL_STACKED_FLASH) flash->size <<= 1;
Add id length of 5 bytes numerical value to macro.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: York Sun york.sun@nxp.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf_internal.h | 3 ++- drivers/mtd/spi/spi_flash.c | 4 ++-- 2 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 527c252..437ac8a 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -108,6 +108,7 @@ int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, #define JEDEC_MFR(info) ((info)->id[0]) #define JEDEC_ID(info) (((info)->id[1]) << 8 | ((info)->id[2])) #define JEDEC_EXT(info) (((info)->id[3]) << 8 | ((info)->id[4])) +#define SPI_FLASH_MAX_ID_LEN 5
struct spi_flash_info { const char *name; @@ -117,7 +118,7 @@ struct spi_flash_info { * The first three bytes are the JEDIC ID. * JEDEC ID zero means "no ID" (mostly older chips). */ - u8 id[5]; + u8 id[SPI_FLASH_MAX_ID_LEN]; u8 id_len;
/* The size listed here is what works with SPINOR_OP_SE, which isn't diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 0777bb5..ba884d7 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -928,10 +928,10 @@ static int micron_quad_enable(struct spi_flash *flash) static const struct spi_flash_info *spi_flash_read_id(struct spi_flash *flash) { int tmp; - u8 id[5]; + u8 id[SPI_FLASH_MAX_ID_LEN]; const struct spi_flash_info *info;
- tmp = spi_flash_cmd(flash->spi, CMD_READ_ID, id, 5); + tmp = spi_flash_cmd(flash->spi, CMD_READ_ID, id, SPI_FLASH_MAX_ID_LEN); if (tmp < 0) { printf("SF: error %d reading JEDEC ID\n", tmp); return ERR_PTR(tmp);
So, now SPI_FLASH_ID_MAX_LEN is 6 bytes useful for few spansion flash families S25FS-S
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: York Sun york.sun@nxp.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf_internal.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 437ac8a..f2ea368 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -108,7 +108,7 @@ int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, #define JEDEC_MFR(info) ((info)->id[0]) #define JEDEC_ID(info) (((info)->id[1]) << 8 | ((info)->id[2])) #define JEDEC_EXT(info) (((info)->id[3]) << 8 | ((info)->id[4])) -#define SPI_FLASH_MAX_ID_LEN 5 +#define SPI_FLASH_MAX_ID_LEN 6
INFO6 is for tabulating 6 byte flash parts, Ex: S25FS256S_64K
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: York Sun york.sun@nxp.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf_params.c | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/drivers/mtd/spi/sf_params.c b/drivers/mtd/spi/sf_params.c index 8a2a6b2..344d9c9 100644 --- a/drivers/mtd/spi/sf_params.c +++ b/drivers/mtd/spi/sf_params.c @@ -23,6 +23,21 @@ .page_size = 256, \ .flags = (_flags),
+#define INFO6(_jedec_id, _ext_id, _sector_size, _n_sectors, _flags) \ + .id = { \ + ((_jedec_id) >> 16) & 0xff, \ + ((_jedec_id) >> 8) & 0xff, \ + (_jedec_id) & 0xff, \ + ((_ext_id) >> 16) & 0xff, \ + ((_ext_id) >> 8) & 0xff, \ + (_ext_id) & 0xff, \ + }, \ + .id_len = 6, \ + .sector_size = (_sector_size), \ + .n_sectors = (_n_sectors), \ + .page_size = 256, \ + .flags = (_flags), + const struct spi_flash_info spi_flash_ids[] = { #ifdef CONFIG_SPI_FLASH_ATMEL /* ATMEL */ {"AT45DB011D", INFO(0x1f2200, 0x0, 64 * 1024, 4, SECT_4K) },
Add Spansion S25FS256S_64K spi flash to the list of spi_flash_ids.
In spansion S25FS-S family the physical sectors are grouped as normal and parameter sectors. Parameter sectors are 4kB in size with 8 set located at the bottom or top address of a device. Normal sectors are similar to other flash family with sizes of 64kB or 32 kB.
To erase whole flash using sector erase(D8h or DCh) won't effect the parameter sectors, so in order to erase these we must use 4K sector erase commands (20h or 21h) separately.
So better to erase the whole flash using 4K sector erase instead of detecting these family parts again and do two different erase operations.
Cc: Yunhui Cui yunhui.cui@nxp.com Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: York Sun york.sun@nxp.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Michal Simek michal.simek@xilinx.com Cc: Michael Trimarchi michael@amarulasolutions.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf_params.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mtd/spi/sf_params.c b/drivers/mtd/spi/sf_params.c index 344d9c9..b029c76 100644 --- a/drivers/mtd/spi/sf_params.c +++ b/drivers/mtd/spi/sf_params.c @@ -93,6 +93,7 @@ const struct spi_flash_info spi_flash_ids[] = { {"S25FL128S_64K", INFO(0x012018, 0x4d01, 64 * 1024, 256, RD_FULL | WR_QPP) }, {"S25FL256S_256K", INFO(0x010219, 0x4d00, 256 * 1024, 128, RD_FULL | WR_QPP) }, {"S25FL256S_64K", INFO(0x010219, 0x4d01, 64 * 1024, 512, RD_FULL | WR_QPP) }, + {"S25FS256S_64K", INFO6(0x010219, 0x4d0181, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, {"S25FS512S", INFO(0x010220, 0x4D00, 128 * 1024, 512, RD_FULL | WR_QPP) }, {"S25FL512S_256K", INFO(0x010220, 0x4d00, 256 * 1024, 256, RD_FULL | WR_QPP) }, {"S25FL512S_64K", INFO(0x010220, 0x4d01, 64 * 1024, 1024, RD_FULL | WR_QPP) },
Since flash detection code is more mature to detect even with 6 bytes id length devices removed old code and related references.
Cc: Yunhui Cui yunhui.cui@nxp.com Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: York Sun york.sun@nxp.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Michal Simek michal.simek@xilinx.com Cc: Michael Trimarchi michael@amarulasolutions.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf_internal.h | 6 ---- drivers/mtd/spi/spi_flash.c | 78 ------------------------------------------- 2 files changed, 84 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index f2ea368..d50fb9a 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -99,12 +99,6 @@ int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, const void *buf); #endif
-#ifdef CONFIG_SPI_FLASH_SPANSION -/* Used for Spansion S25FS-S family flash only. */ -#define CMD_SPANSION_RDAR 0x65 /* Read any device register */ -#define CMD_SPANSION_WRAR 0x71 /* Write any device register */ -#endif - #define JEDEC_MFR(info) ((info)->id[0]) #define JEDEC_ID(info) (((info)->id[1]) << 8 | ((info)->id[2])) #define JEDEC_EXT(info) (((info)->id[3]) << 8 | ((info)->id[4])) diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index ba884d7..27b85ba 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -999,94 +999,16 @@ int spi_flash_decode_fdt(const void *blob, struct spi_flash *flash) } #endif /* CONFIG_IS_ENABLED(OF_CONTROL) */
-#ifdef CONFIG_SPI_FLASH_SPANSION -static int spansion_s25fss_disable_4KB_erase(struct spi_slave *spi) -{ - u8 cmd[4]; - u32 offset = 0x800004; /* CR3V register offset */ - u8 cr3v; - int ret; - - cmd[0] = CMD_SPANSION_RDAR; - cmd[1] = offset >> 16; - cmd[2] = offset >> 8; - cmd[3] = offset >> 0; - - ret = spi_flash_cmd_read(spi, cmd, 4, &cr3v, 1); - if (ret) - return -EIO; - /* CR3V bit3: 4-KB Erase */ - if (cr3v & 0x8) - return 0; - - cmd[0] = CMD_SPANSION_WRAR; - cr3v |= 0x8; - ret = spi_flash_cmd_write(spi, cmd, 4, &cr3v, 1); - if (ret) - return -EIO; - - cmd[0] = CMD_SPANSION_RDAR; - ret = spi_flash_cmd_read(spi, cmd, 4, &cr3v, 1); - if (ret) - return -EIO; - if (!(cr3v & 0x8)) - return -EFAULT; - - return 0; -} -#endif - int spi_flash_scan(struct spi_flash *flash) { struct spi_slave *spi = flash->spi; const struct spi_flash_info *info = NULL; - u16 jedec, ext_jedec; - u8 idcode[5]; int ret;
info = spi_flash_read_id(flash); if (IS_ERR_OR_NULL(info)) return -ENOENT;
- jedec = idcode[1] << 8 | idcode[2]; - ext_jedec = idcode[3] << 8 | idcode[4]; - -#ifdef CONFIG_SPI_FLASH_SPANSION - /* - * The S25FS-S family physical sectors may be configured as a - * hybrid combination of eight 4-kB parameter sectors - * at the top or bottom of the address space with all - * but one of the remaining sectors being uniform size. - * The Parameter Sector Erase commands (20h or 21h) must - * be used to erase the 4-kB parameter sectors individually. - * The Sector (uniform sector) Erase commands (D8h or DCh) - * must be used to erase any of the remaining - * sectors, including the portion of highest or lowest address - * sector that is not overlaid by the parameter sectors. - * The uniform sector erase command has no effect on parameter sectors. - */ - if ((jedec == 0x0219 || (jedec == 0x0220)) && - (ext_jedec & 0xff00) == 0x4d00) { - int ret; - u8 id[6]; - - /* Read the ID codes again, 6 bytes */ - ret = spi_flash_cmd(flash->spi, CMD_READ_ID, id, sizeof(id)); - if (ret) - return -EIO; - - ret = memcmp(id, idcode, 5); - if (ret) - return -EIO; - - /* 0x81: S25FS-S family 0x80: S25FL-S family */ - if (id[5] == 0x81) { - ret = spansion_s25fss_disable_4KB_erase(spi); - if (ret) - return ret; - } - } -#endif /* Flash powers up read-only, so clear BP# bits */ if (JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_ATMEL || JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_MACRONIX ||
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: York Sun york.sun@nxp.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/spi_flash.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 27b85ba..c1025c9 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1015,16 +1015,13 @@ int spi_flash_scan(struct spi_flash *flash) JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_SST) write_sr(flash, 0);
- /* Assign spi data */ flash->name = info->name; flash->memory_map = spi->memory_map; flash->dual_flash = spi->option;
- /* Assign spi flash flags */ if (info->flags & SST_WR) flash->flags |= SNOR_F_SST_WR;
- /* Assign spi_flash ops */ #ifndef CONFIG_DM_SPI_FLASH flash->write = spi_flash_cmd_write_ops; #if defined(CONFIG_SPI_FLASH_SST)
spi_flash_ids.c is more meaningful name as the flash_info table structure spi_flash_info has spi_flash_ids instance.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: York Sun york.sun@nxp.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/Makefile | 2 +- drivers/mtd/spi/spi_flash_ids.c | 176 ++++++++++++++++++++++++++++++++++++++++ 2 files changed, 177 insertions(+), 1 deletion(-) create mode 100644 drivers/mtd/spi/spi_flash_ids.c
diff --git a/drivers/mtd/spi/Makefile b/drivers/mtd/spi/Makefile index 6f47a66..6379b4b 100644 --- a/drivers/mtd/spi/Makefile +++ b/drivers/mtd/spi/Makefile @@ -13,7 +13,7 @@ obj-$(CONFIG_SPL_SPI_BOOT) += fsl_espi_spl.o obj-$(CONFIG_SPL_SPI_SUNXI) += sunxi_spi_spl.o endif
-obj-$(CONFIG_SPI_FLASH) += sf_probe.o spi_flash.o sf_params.o sf.o +obj-$(CONFIG_SPI_FLASH) += sf_probe.o spi_flash.o spi_flash_ids.o sf.o obj-$(CONFIG_SPI_FLASH_DATAFLASH) += sf_dataflash.o obj-$(CONFIG_SPI_FLASH_MTD) += sf_mtd.o obj-$(CONFIG_SPI_FLASH_SANDBOX) += sandbox.o diff --git a/drivers/mtd/spi/spi_flash_ids.c b/drivers/mtd/spi/spi_flash_ids.c new file mode 100644 index 0000000..61cac59 --- /dev/null +++ b/drivers/mtd/spi/spi_flash_ids.c @@ -0,0 +1,176 @@ +/* + * SPI Flash ID's. + * + * Copyright (C) 2016 Jagan Teki jteki@openedev.com + * Copyright (C) 2013 Jagannadha Sutradharudu Teki, Xilinx Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include "sf_internal.h" + +/* Used when the "_ext_id" is two bytes at most */ +#define INFO(_jedec_id, _ext_id, _sector_size, _n_sectors, _flags) \ + .id = { \ + ((_jedec_id) >> 16) & 0xff, \ + ((_jedec_id) >> 8) & 0xff, \ + (_jedec_id) & 0xff, \ + ((_ext_id) >> 8) & 0xff, \ + (_ext_id) & 0xff, \ + }, \ + .id_len = (!(_jedec_id) ? 0 : (3 + ((_ext_id) ? 2 : 0))), \ + .sector_size = (_sector_size), \ + .n_sectors = (_n_sectors), \ + .page_size = 256, \ + .flags = (_flags), + +#define INFO6(_jedec_id, _ext_id, _sector_size, _n_sectors, _flags) \ + .id = { \ + ((_jedec_id) >> 16) & 0xff, \ + ((_jedec_id) >> 8) & 0xff, \ + (_jedec_id) & 0xff, \ + ((_ext_id) >> 16) & 0xff, \ + ((_ext_id) >> 8) & 0xff, \ + (_ext_id) & 0xff, \ + }, \ + .id_len = 6, \ + .sector_size = (_sector_size), \ + .n_sectors = (_n_sectors), \ + .page_size = 256, \ + .flags = (_flags), + +const struct spi_flash_info spi_flash_ids[] = { +#ifdef CONFIG_SPI_FLASH_ATMEL /* ATMEL */ + {"AT45DB011D", INFO(0x1f2200, 0x0, 64 * 1024, 4, SECT_4K) }, + {"AT45DB021D", INFO(0x1f2300, 0x0, 64 * 1024, 8, SECT_4K) }, + {"AT45DB041D", INFO(0x1f2400, 0x0, 64 * 1024, 8, SECT_4K) }, + {"AT45DB081D", INFO(0x1f2500, 0x0, 64 * 1024, 16, SECT_4K) }, + {"AT45DB161D", INFO(0x1f2600, 0x0, 64 * 1024, 32, SECT_4K) }, + {"AT45DB321D", INFO(0x1f2700, 0x0, 64 * 1024, 64, SECT_4K) }, + {"AT45DB641D", INFO(0x1f2800, 0x0, 64 * 1024, 128, SECT_4K) }, + {"AT25DF321A", INFO(0x1f4701, 0x0, 64 * 1024, 64, SECT_4K) }, + {"AT25DF321", INFO(0x1f4700, 0x0, 64 * 1024, 64, SECT_4K) }, + {"AT26DF081A", INFO(0x1f4501, 0x0, 64 * 1024, 16, SECT_4K) }, +#endif +#ifdef CONFIG_SPI_FLASH_EON /* EON */ + {"EN25Q32B", INFO(0x1c3016, 0x0, 64 * 1024, 64, 0) }, + {"EN25Q64", INFO(0x1c3017, 0x0, 64 * 1024, 128, SECT_4K) }, + {"EN25Q128B", INFO(0x1c3018, 0x0, 64 * 1024, 256, 0) }, + {"EN25S64", INFO(0x1c3817, 0x0, 64 * 1024, 128, 0) }, +#endif +#ifdef CONFIG_SPI_FLASH_GIGADEVICE /* GIGADEVICE */ + {"GD25Q64B", INFO(0xc84017, 0x0, 64 * 1024, 128, SECT_4K) }, + {"GD25LQ32", INFO(0xc86016, 0x0, 64 * 1024, 64, SECT_4K) }, +#endif +#ifdef CONFIG_SPI_FLASH_ISSI /* ISSI */ + {"IS25LP032", INFO(0x9d6016, 0x0, 64 * 1024, 64, 0) }, + {"IS25LP064", INFO(0x9d6017, 0x0, 64 * 1024, 128, 0) }, + {"IS25LP128", INFO(0x9d6018, 0x0, 64 * 1024, 256, 0) }, +#endif +#ifdef CONFIG_SPI_FLASH_MACRONIX /* MACRONIX */ + {"MX25L2006E", INFO(0xc22012, 0x0, 64 * 1024, 4, 0) }, + {"MX25L4005", INFO(0xc22013, 0x0, 64 * 1024, 8, 0) }, + {"MX25L8005", INFO(0xc22014, 0x0, 64 * 1024, 16, 0) }, + {"MX25L1605D", INFO(0xc22015, 0x0, 64 * 1024, 32, 0) }, + {"MX25L3205D", INFO(0xc22016, 0x0, 64 * 1024, 64, 0) }, + {"MX25L6405D", INFO(0xc22017, 0x0, 64 * 1024, 128, 0) }, + {"MX25L12805", INFO(0xc22018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP) }, + {"MX25L25635F", INFO(0xc22019, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP) }, + {"MX25L51235F", INFO(0xc2201a, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP) }, + {"MX25L12855E", INFO(0xc22618, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP) }, +#endif +#ifdef CONFIG_SPI_FLASH_SPANSION /* SPANSION */ + {"S25FL008A", INFO(0x010213, 0x0, 64 * 1024, 16, 0) }, + {"S25FL016A", INFO(0x010214, 0x0, 64 * 1024, 32, 0) }, + {"S25FL032A", INFO(0x010215, 0x0, 64 * 1024, 64, 0) }, + {"S25FL064A", INFO(0x010216, 0x0, 64 * 1024, 128, 0) }, + {"S25FL116K", INFO(0x014015, 0x0, 64 * 1024, 128, 0) }, + {"S25FL164K", INFO(0x014017, 0x0140, 64 * 1024, 128, 0) }, + {"S25FL128P_256K", INFO(0x012018, 0x0300, 256 * 1024, 64, RD_FULL | WR_QPP) }, + {"S25FL128P_64K", INFO(0x012018, 0x0301, 64 * 1024, 256, RD_FULL | WR_QPP) }, + {"S25FL032P", INFO(0x010215, 0x4d00, 64 * 1024, 64, RD_FULL | WR_QPP) }, + {"S25FL064P", INFO(0x010216, 0x4d00, 64 * 1024, 128, RD_FULL | WR_QPP) }, + {"S25FL128S_256K", INFO(0x012018, 0x4d00, 256 * 1024, 64, RD_FULL | WR_QPP) }, + {"S25FL128S_64K", INFO(0x012018, 0x4d01, 64 * 1024, 256, RD_FULL | WR_QPP) }, + {"S25FL256S_256K", INFO(0x010219, 0x4d00, 256 * 1024, 128, RD_FULL | WR_QPP) }, + {"S25FL256S_64K", INFO(0x010219, 0x4d01, 64 * 1024, 512, RD_FULL | WR_QPP) }, + {"S25FS256S_64K", INFO6(0x010219, 0x4d0181, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, + {"S25FS512S", INFO(0x010220, 0x4D00, 128 * 1024, 512, RD_FULL | WR_QPP) }, + {"S25FL512S_256K", INFO(0x010220, 0x4d00, 256 * 1024, 256, RD_FULL | WR_QPP) }, + {"S25FL512S_64K", INFO(0x010220, 0x4d01, 64 * 1024, 1024, RD_FULL | WR_QPP) }, + {"S25FL512S_512K", INFO(0x010220, 0x4f00, 256 * 1024, 256, RD_FULL | WR_QPP) }, +#endif +#ifdef CONFIG_SPI_FLASH_STMICRO /* STMICRO */ + {"M25P10", INFO(0x202011, 0x0, 32 * 1024, 4, 0) }, + {"M25P20", INFO(0x202012, 0x0, 64 * 1024, 4, 0) }, + {"M25P40", INFO(0x202013, 0x0, 64 * 1024, 8, 0) }, + {"M25P80", INFO(0x202014, 0x0, 64 * 1024, 16, 0) }, + {"M25P16", INFO(0x202015, 0x0, 64 * 1024, 32, 0) }, + {"M25PE16", INFO(0x208015, 0x1000, 64 * 1024, 32, 0) }, + {"M25PX16", INFO(0x207115, 0x1000, 64 * 1024, 32, RD_QUAD | RD_DUAL) }, + {"M25P32", INFO(0x202016, 0x0, 64 * 1024, 64, 0) }, + {"M25P64", INFO(0x202017, 0x0, 64 * 1024, 128, 0) }, + {"M25P128", INFO(0x202018, 0x0, 256 * 1024, 64, 0) }, + {"M25PX64", INFO(0x207117, 0x0, 64 * 1024, 128, SECT_4K) }, + {"N25Q016A", INFO(0x20bb15, 0x0, 64 * 1024, 32, SECT_4K) }, + {"N25Q32", INFO(0x20ba16, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, + {"N25Q32A", INFO(0x20bb16, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, + {"N25Q64", INFO(0x20ba17, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, + {"N25Q64A", INFO(0x20bb17, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, + {"N25Q128", INFO(0x20ba18, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP) }, + {"N25Q128A", INFO(0x20bb18, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP) }, + {"N25Q256", INFO(0x20ba19, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, + {"N25Q256A", INFO(0x20bb19, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, + {"N25Q512", INFO(0x20ba20, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, + {"N25Q512A", INFO(0x20bb20, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, + {"N25Q1024", INFO(0x20ba21, 0x0, 64 * 1024, 2048, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, + {"N25Q1024A", INFO(0x20bb21, 0x0, 64 * 1024, 2048, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, +#endif +#ifdef CONFIG_SPI_FLASH_SST /* SST */ + {"SST25VF040B", INFO(0xbf258d, 0x0, 64 * 1024, 8, SECT_4K | SST_WR) }, + {"SST25VF080B", INFO(0xbf258e, 0x0, 64 * 1024, 16, SECT_4K | SST_WR) }, + {"SST25VF016B", INFO(0xbf2541, 0x0, 64 * 1024, 32, SECT_4K | SST_WR) }, + {"SST25VF032B", INFO(0xbf254a, 0x0, 64 * 1024, 64, SECT_4K | SST_WR) }, + {"SST25VF064C", INFO(0xbf254b, 0x0, 64 * 1024, 128, SECT_4K) }, + {"SST25WF512", INFO(0xbf2501, 0x0, 64 * 1024, 1, SECT_4K | SST_WR) }, + {"SST25WF010", INFO(0xbf2502, 0x0, 64 * 1024, 2, SECT_4K | SST_WR) }, + {"SST25WF020", INFO(0xbf2503, 0x0, 64 * 1024, 4, SECT_4K | SST_WR) }, + {"SST25WF040", INFO(0xbf2504, 0x0, 64 * 1024, 8, SECT_4K | SST_WR) }, + {"SST25WF040B", INFO(0x621613, 0x0, 64 * 1024, 8, SECT_4K) }, + {"SST25WF080", INFO(0xbf2505, 0x0, 64 * 1024, 16, SECT_4K | SST_WR) }, +#endif +#ifdef CONFIG_SPI_FLASH_WINBOND /* WINBOND */ + {"W25P80", INFO(0xef2014, 0x0, 64 * 1024, 16, 0) }, + {"W25P16", INFO(0xef2015, 0x0, 64 * 1024, 32, 0) }, + {"W25P32", INFO(0xef2016, 0x0, 64 * 1024, 64, 0) }, + {"W25X40", INFO(0xef3013, 0x0, 64 * 1024, 8, SECT_4K) }, + {"W25X16", INFO(0xef3015, 0x0, 64 * 1024, 32, SECT_4K) }, + {"W25X32", INFO(0xef3016, 0x0, 64 * 1024, 64, SECT_4K) }, + {"W25X64", INFO(0xef3017, 0x0, 64 * 1024, 128, SECT_4K) }, + {"W25Q80BL", INFO(0xef4014, 0x0, 64 * 1024, 16, RD_FULL | WR_QPP | SECT_4K) }, + {"W25Q16CL", INFO(0xef4015, 0x0, 64 * 1024, 32, RD_FULL | WR_QPP | SECT_4K) }, + {"W25Q32BV", INFO(0xef4016, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, + {"W25Q64CV", INFO(0xef4017, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, + {"W25Q128BV", INFO(0xef4018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K) }, + {"W25Q256", INFO(0xef4019, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, + {"W25Q80BW", INFO(0xef5014, 0x0, 64 * 1024, 16, RD_FULL | WR_QPP | SECT_4K) }, + {"W25Q16DW", INFO(0xef6015, 0x0, 64 * 1024, 32, RD_FULL | WR_QPP | SECT_4K) }, + {"W25Q32DW", INFO(0xef6016, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, + {"W25Q64DW", INFO(0xef6017, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, + {"W25Q128FW", INFO(0xef6018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K) }, +#endif + {}, /* Empty entry to terminate the list */ + /* + * Note: + * Below paired flash devices has similar spi_flash params. + * (S25FL129P_64K, S25FL128S_64K) + * (W25Q80BL, W25Q80BV) + * (W25Q16CL, W25Q16DV) + * (W25Q32BV, W25Q32FV_SPI) + * (W25Q64CV, W25Q64FV_SPI) + * (W25Q128BV, W25Q128FV_SPI) + * (W25Q32DW, W25Q32FV_QPI) + * (W25Q64DW, W25Q64FV_QPI) + * (W25Q128FW, W25Q128FV_QPI) + */ +};
For readability use small letter's with flash name.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: York Sun york.sun@nxp.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/spi_flash_ids.c | 220 ++++++++++++++++++++-------------------- 1 file changed, 110 insertions(+), 110 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash_ids.c b/drivers/mtd/spi/spi_flash_ids.c index 61cac59..f3c5e3f 100644 --- a/drivers/mtd/spi/spi_flash_ids.c +++ b/drivers/mtd/spi/spi_flash_ids.c @@ -41,136 +41,136 @@
const struct spi_flash_info spi_flash_ids[] = { #ifdef CONFIG_SPI_FLASH_ATMEL /* ATMEL */ - {"AT45DB011D", INFO(0x1f2200, 0x0, 64 * 1024, 4, SECT_4K) }, - {"AT45DB021D", INFO(0x1f2300, 0x0, 64 * 1024, 8, SECT_4K) }, - {"AT45DB041D", INFO(0x1f2400, 0x0, 64 * 1024, 8, SECT_4K) }, - {"AT45DB081D", INFO(0x1f2500, 0x0, 64 * 1024, 16, SECT_4K) }, - {"AT45DB161D", INFO(0x1f2600, 0x0, 64 * 1024, 32, SECT_4K) }, - {"AT45DB321D", INFO(0x1f2700, 0x0, 64 * 1024, 64, SECT_4K) }, - {"AT45DB641D", INFO(0x1f2800, 0x0, 64 * 1024, 128, SECT_4K) }, - {"AT25DF321A", INFO(0x1f4701, 0x0, 64 * 1024, 64, SECT_4K) }, - {"AT25DF321", INFO(0x1f4700, 0x0, 64 * 1024, 64, SECT_4K) }, - {"AT26DF081A", INFO(0x1f4501, 0x0, 64 * 1024, 16, SECT_4K) }, + {"at45db011d", INFO(0x1f2200, 0x0, 64 * 1024, 4, SECT_4K) }, + {"at45db021d", INFO(0x1f2300, 0x0, 64 * 1024, 8, SECT_4K) }, + {"at45db041d", INFO(0x1f2400, 0x0, 64 * 1024, 8, SECT_4K) }, + {"at45db081d", INFO(0x1f2500, 0x0, 64 * 1024, 16, SECT_4K) }, + {"at45db161d", INFO(0x1f2600, 0x0, 64 * 1024, 32, SECT_4K) }, + {"at45db321d", INFO(0x1f2700, 0x0, 64 * 1024, 64, SECT_4K) }, + {"at45db641d", INFO(0x1f2800, 0x0, 64 * 1024, 128, SECT_4K) }, + {"at25df321a", INFO(0x1f4701, 0x0, 64 * 1024, 64, SECT_4K) }, + {"at25df321", INFO(0x1f4700, 0x0, 64 * 1024, 64, SECT_4K) }, + {"at26df081a", INFO(0x1f4501, 0x0, 64 * 1024, 16, SECT_4K) }, #endif #ifdef CONFIG_SPI_FLASH_EON /* EON */ - {"EN25Q32B", INFO(0x1c3016, 0x0, 64 * 1024, 64, 0) }, - {"EN25Q64", INFO(0x1c3017, 0x0, 64 * 1024, 128, SECT_4K) }, - {"EN25Q128B", INFO(0x1c3018, 0x0, 64 * 1024, 256, 0) }, - {"EN25S64", INFO(0x1c3817, 0x0, 64 * 1024, 128, 0) }, + {"en25q32b", INFO(0x1c3016, 0x0, 64 * 1024, 64, 0) }, + {"en25q64", INFO(0x1c3017, 0x0, 64 * 1024, 128, SECT_4K) }, + {"en25q128b", INFO(0x1c3018, 0x0, 64 * 1024, 256, 0) }, + {"en25s64", INFO(0x1c3817, 0x0, 64 * 1024, 128, 0) }, #endif #ifdef CONFIG_SPI_FLASH_GIGADEVICE /* GIGADEVICE */ - {"GD25Q64B", INFO(0xc84017, 0x0, 64 * 1024, 128, SECT_4K) }, - {"GD25LQ32", INFO(0xc86016, 0x0, 64 * 1024, 64, SECT_4K) }, + {"gd25q64b", INFO(0xc84017, 0x0, 64 * 1024, 128, SECT_4K) }, + {"gd25lq32", INFO(0xc86016, 0x0, 64 * 1024, 64, SECT_4K) }, #endif #ifdef CONFIG_SPI_FLASH_ISSI /* ISSI */ - {"IS25LP032", INFO(0x9d6016, 0x0, 64 * 1024, 64, 0) }, - {"IS25LP064", INFO(0x9d6017, 0x0, 64 * 1024, 128, 0) }, - {"IS25LP128", INFO(0x9d6018, 0x0, 64 * 1024, 256, 0) }, + {"is25lp032", INFO(0x9d6016, 0x0, 64 * 1024, 64, 0) }, + {"is25lp064", INFO(0x9d6017, 0x0, 64 * 1024, 128, 0) }, + {"is25lp128", INFO(0x9d6018, 0x0, 64 * 1024, 256, 0) }, #endif #ifdef CONFIG_SPI_FLASH_MACRONIX /* MACRONIX */ - {"MX25L2006E", INFO(0xc22012, 0x0, 64 * 1024, 4, 0) }, - {"MX25L4005", INFO(0xc22013, 0x0, 64 * 1024, 8, 0) }, - {"MX25L8005", INFO(0xc22014, 0x0, 64 * 1024, 16, 0) }, - {"MX25L1605D", INFO(0xc22015, 0x0, 64 * 1024, 32, 0) }, - {"MX25L3205D", INFO(0xc22016, 0x0, 64 * 1024, 64, 0) }, - {"MX25L6405D", INFO(0xc22017, 0x0, 64 * 1024, 128, 0) }, - {"MX25L12805", INFO(0xc22018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP) }, - {"MX25L25635F", INFO(0xc22019, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP) }, - {"MX25L51235F", INFO(0xc2201a, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP) }, - {"MX25L12855E", INFO(0xc22618, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP) }, + {"mx25l2006e", INFO(0xc22012, 0x0, 64 * 1024, 4, 0) }, + {"mx25l4005", INFO(0xc22013, 0x0, 64 * 1024, 8, 0) }, + {"mx25l8005", INFO(0xc22014, 0x0, 64 * 1024, 16, 0) }, + {"mx25l1605d", INFO(0xc22015, 0x0, 64 * 1024, 32, 0) }, + {"mx25l3205d", INFO(0xc22016, 0x0, 64 * 1024, 64, 0) }, + {"mx25l6405d", INFO(0xc22017, 0x0, 64 * 1024, 128, 0) }, + {"mx25l12805", INFO(0xc22018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP) }, + {"mx25l25635f", INFO(0xc22019, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP) }, + {"mx25l51235f", INFO(0xc2201a, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP) }, + {"mx25l12855e", INFO(0xc22618, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP) }, #endif #ifdef CONFIG_SPI_FLASH_SPANSION /* SPANSION */ - {"S25FL008A", INFO(0x010213, 0x0, 64 * 1024, 16, 0) }, - {"S25FL016A", INFO(0x010214, 0x0, 64 * 1024, 32, 0) }, - {"S25FL032A", INFO(0x010215, 0x0, 64 * 1024, 64, 0) }, - {"S25FL064A", INFO(0x010216, 0x0, 64 * 1024, 128, 0) }, - {"S25FL116K", INFO(0x014015, 0x0, 64 * 1024, 128, 0) }, - {"S25FL164K", INFO(0x014017, 0x0140, 64 * 1024, 128, 0) }, - {"S25FL128P_256K", INFO(0x012018, 0x0300, 256 * 1024, 64, RD_FULL | WR_QPP) }, - {"S25FL128P_64K", INFO(0x012018, 0x0301, 64 * 1024, 256, RD_FULL | WR_QPP) }, - {"S25FL032P", INFO(0x010215, 0x4d00, 64 * 1024, 64, RD_FULL | WR_QPP) }, - {"S25FL064P", INFO(0x010216, 0x4d00, 64 * 1024, 128, RD_FULL | WR_QPP) }, - {"S25FL128S_256K", INFO(0x012018, 0x4d00, 256 * 1024, 64, RD_FULL | WR_QPP) }, - {"S25FL128S_64K", INFO(0x012018, 0x4d01, 64 * 1024, 256, RD_FULL | WR_QPP) }, - {"S25FL256S_256K", INFO(0x010219, 0x4d00, 256 * 1024, 128, RD_FULL | WR_QPP) }, - {"S25FL256S_64K", INFO(0x010219, 0x4d01, 64 * 1024, 512, RD_FULL | WR_QPP) }, - {"S25FS256S_64K", INFO6(0x010219, 0x4d0181, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, - {"S25FS512S", INFO(0x010220, 0x4D00, 128 * 1024, 512, RD_FULL | WR_QPP) }, - {"S25FL512S_256K", INFO(0x010220, 0x4d00, 256 * 1024, 256, RD_FULL | WR_QPP) }, - {"S25FL512S_64K", INFO(0x010220, 0x4d01, 64 * 1024, 1024, RD_FULL | WR_QPP) }, - {"S25FL512S_512K", INFO(0x010220, 0x4f00, 256 * 1024, 256, RD_FULL | WR_QPP) }, + {"s25fl008a", INFO(0x010213, 0x0, 64 * 1024, 16, 0) }, + {"s25fl016a", INFO(0x010214, 0x0, 64 * 1024, 32, 0) }, + {"s25fl032a", INFO(0x010215, 0x0, 64 * 1024, 64, 0) }, + {"s25fl064a", INFO(0x010216, 0x0, 64 * 1024, 128, 0) }, + {"s25fl116k", INFO(0x014015, 0x0, 64 * 1024, 128, 0) }, + {"s25fl164k", INFO(0x014017, 0x0140, 64 * 1024, 128, 0) }, + {"s25fl128p_256k", INFO(0x012018, 0x0300, 256 * 1024, 64, RD_FULL | WR_QPP) }, + {"s25fl128p_64k", INFO(0x012018, 0x0301, 64 * 1024, 256, RD_FULL | WR_QPP) }, + {"s25fl032p", INFO(0x010215, 0x4d00, 64 * 1024, 64, RD_FULL | WR_QPP) }, + {"s25fl064p", INFO(0x010216, 0x4d00, 64 * 1024, 128, RD_FULL | WR_QPP) }, + {"s25fl128s_256k", INFO(0x012018, 0x4d00, 256 * 1024, 64, RD_FULL | WR_QPP) }, + {"s25fl128s_64k", INFO(0x012018, 0x4d01, 64 * 1024, 256, RD_FULL | WR_QPP) }, + {"s25fl256s_256k", INFO(0x010219, 0x4d00, 256 * 1024, 128, RD_FULL | WR_QPP) }, + {"s25fl256s_64k", INFO(0x010219, 0x4d01, 64 * 1024, 512, RD_FULL | WR_QPP) }, + {"s25s256s_64k", INFO6(0x010219, 0x4d0181, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, + {"s25s512s", INFO(0x010220, 0x4D00, 128 * 1024, 512, RD_FULL | WR_QPP) }, + {"s25fl512s_256k", INFO(0x010220, 0x4d00, 256 * 1024, 256, RD_FULL | WR_QPP) }, + {"s25fl512s_64k", INFO(0x010220, 0x4d01, 64 * 1024, 1024, RD_FULL | WR_QPP) }, + {"s25fl512s_512k", INFO(0x010220, 0x4f00, 256 * 1024, 256, RD_FULL | WR_QPP) }, #endif #ifdef CONFIG_SPI_FLASH_STMICRO /* STMICRO */ - {"M25P10", INFO(0x202011, 0x0, 32 * 1024, 4, 0) }, - {"M25P20", INFO(0x202012, 0x0, 64 * 1024, 4, 0) }, - {"M25P40", INFO(0x202013, 0x0, 64 * 1024, 8, 0) }, - {"M25P80", INFO(0x202014, 0x0, 64 * 1024, 16, 0) }, - {"M25P16", INFO(0x202015, 0x0, 64 * 1024, 32, 0) }, - {"M25PE16", INFO(0x208015, 0x1000, 64 * 1024, 32, 0) }, - {"M25PX16", INFO(0x207115, 0x1000, 64 * 1024, 32, RD_QUAD | RD_DUAL) }, - {"M25P32", INFO(0x202016, 0x0, 64 * 1024, 64, 0) }, - {"M25P64", INFO(0x202017, 0x0, 64 * 1024, 128, 0) }, - {"M25P128", INFO(0x202018, 0x0, 256 * 1024, 64, 0) }, - {"M25PX64", INFO(0x207117, 0x0, 64 * 1024, 128, SECT_4K) }, - {"N25Q016A", INFO(0x20bb15, 0x0, 64 * 1024, 32, SECT_4K) }, - {"N25Q32", INFO(0x20ba16, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, - {"N25Q32A", INFO(0x20bb16, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, - {"N25Q64", INFO(0x20ba17, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, - {"N25Q64A", INFO(0x20bb17, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, - {"N25Q128", INFO(0x20ba18, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP) }, - {"N25Q128A", INFO(0x20bb18, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP) }, - {"N25Q256", INFO(0x20ba19, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, - {"N25Q256A", INFO(0x20bb19, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, - {"N25Q512", INFO(0x20ba20, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, - {"N25Q512A", INFO(0x20bb20, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, - {"N25Q1024", INFO(0x20ba21, 0x0, 64 * 1024, 2048, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, - {"N25Q1024A", INFO(0x20bb21, 0x0, 64 * 1024, 2048, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, + {"m25p10", INFO(0x202011, 0x0, 32 * 1024, 4, 0) }, + {"m25p20", INFO(0x202012, 0x0, 64 * 1024, 4, 0) }, + {"m25p40", INFO(0x202013, 0x0, 64 * 1024, 8, 0) }, + {"m25p80", INFO(0x202014, 0x0, 64 * 1024, 16, 0) }, + {"m25p16", INFO(0x202015, 0x0, 64 * 1024, 32, 0) }, + {"m25pE16", INFO(0x208015, 0x1000, 64 * 1024, 32, 0) }, + {"m25pX16", INFO(0x207115, 0x1000, 64 * 1024, 32, RD_QUAD | RD_DUAL) }, + {"m25p32", INFO(0x202016, 0x0, 64 * 1024, 64, 0) }, + {"m25p64", INFO(0x202017, 0x0, 64 * 1024, 128, 0) }, + {"m25p128", INFO(0x202018, 0x0, 256 * 1024, 64, 0) }, + {"m25pX64", INFO(0x207117, 0x0, 64 * 1024, 128, SECT_4K) }, + {"n25q016a", INFO(0x20bb15, 0x0, 64 * 1024, 32, SECT_4K) }, + {"n25q32", INFO(0x20ba16, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, + {"n25q32a", INFO(0x20bb16, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, + {"n25q64", INFO(0x20ba17, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, + {"n25q64a", INFO(0x20bb17, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, + {"n25q128", INFO(0x20ba18, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP) }, + {"n25q128a", INFO(0x20bb18, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP) }, + {"n25q256", INFO(0x20ba19, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, + {"n25q256a", INFO(0x20bb19, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, + {"n25q512", INFO(0x20ba20, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, + {"n25q512a", INFO(0x20bb20, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, + {"n25q1024", INFO(0x20ba21, 0x0, 64 * 1024, 2048, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, + {"n25q1024a", INFO(0x20bb21, 0x0, 64 * 1024, 2048, RD_FULL | WR_QPP | E_FSR | SECT_4K) }, #endif #ifdef CONFIG_SPI_FLASH_SST /* SST */ - {"SST25VF040B", INFO(0xbf258d, 0x0, 64 * 1024, 8, SECT_4K | SST_WR) }, - {"SST25VF080B", INFO(0xbf258e, 0x0, 64 * 1024, 16, SECT_4K | SST_WR) }, - {"SST25VF016B", INFO(0xbf2541, 0x0, 64 * 1024, 32, SECT_4K | SST_WR) }, - {"SST25VF032B", INFO(0xbf254a, 0x0, 64 * 1024, 64, SECT_4K | SST_WR) }, - {"SST25VF064C", INFO(0xbf254b, 0x0, 64 * 1024, 128, SECT_4K) }, - {"SST25WF512", INFO(0xbf2501, 0x0, 64 * 1024, 1, SECT_4K | SST_WR) }, - {"SST25WF010", INFO(0xbf2502, 0x0, 64 * 1024, 2, SECT_4K | SST_WR) }, - {"SST25WF020", INFO(0xbf2503, 0x0, 64 * 1024, 4, SECT_4K | SST_WR) }, - {"SST25WF040", INFO(0xbf2504, 0x0, 64 * 1024, 8, SECT_4K | SST_WR) }, - {"SST25WF040B", INFO(0x621613, 0x0, 64 * 1024, 8, SECT_4K) }, - {"SST25WF080", INFO(0xbf2505, 0x0, 64 * 1024, 16, SECT_4K | SST_WR) }, + {"sst25vf040b", INFO(0xbf258d, 0x0, 64 * 1024, 8, SECT_4K | SST_WR) }, + {"sst25vf080b", INFO(0xbf258e, 0x0, 64 * 1024, 16, SECT_4K | SST_WR) }, + {"sst25vf016b", INFO(0xbf2541, 0x0, 64 * 1024, 32, SECT_4K | SST_WR) }, + {"sst25vf032b", INFO(0xbf254a, 0x0, 64 * 1024, 64, SECT_4K | SST_WR) }, + {"sst25vf064c", INFO(0xbf254b, 0x0, 64 * 1024, 128, SECT_4K) }, + {"sst25wf512", INFO(0xbf2501, 0x0, 64 * 1024, 1, SECT_4K | SST_WR) }, + {"sst25wf010", INFO(0xbf2502, 0x0, 64 * 1024, 2, SECT_4K | SST_WR) }, + {"sst25wf020", INFO(0xbf2503, 0x0, 64 * 1024, 4, SECT_4K | SST_WR) }, + {"sst25wf040", INFO(0xbf2504, 0x0, 64 * 1024, 8, SECT_4K | SST_WR) }, + {"sst25wf040b", INFO(0x621613, 0x0, 64 * 1024, 8, SECT_4K) }, + {"sst25wf080", INFO(0xbf2505, 0x0, 64 * 1024, 16, SECT_4K | SST_WR) }, #endif #ifdef CONFIG_SPI_FLASH_WINBOND /* WINBOND */ - {"W25P80", INFO(0xef2014, 0x0, 64 * 1024, 16, 0) }, - {"W25P16", INFO(0xef2015, 0x0, 64 * 1024, 32, 0) }, - {"W25P32", INFO(0xef2016, 0x0, 64 * 1024, 64, 0) }, - {"W25X40", INFO(0xef3013, 0x0, 64 * 1024, 8, SECT_4K) }, - {"W25X16", INFO(0xef3015, 0x0, 64 * 1024, 32, SECT_4K) }, - {"W25X32", INFO(0xef3016, 0x0, 64 * 1024, 64, SECT_4K) }, - {"W25X64", INFO(0xef3017, 0x0, 64 * 1024, 128, SECT_4K) }, - {"W25Q80BL", INFO(0xef4014, 0x0, 64 * 1024, 16, RD_FULL | WR_QPP | SECT_4K) }, - {"W25Q16CL", INFO(0xef4015, 0x0, 64 * 1024, 32, RD_FULL | WR_QPP | SECT_4K) }, - {"W25Q32BV", INFO(0xef4016, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, - {"W25Q64CV", INFO(0xef4017, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, - {"W25Q128BV", INFO(0xef4018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K) }, - {"W25Q256", INFO(0xef4019, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, - {"W25Q80BW", INFO(0xef5014, 0x0, 64 * 1024, 16, RD_FULL | WR_QPP | SECT_4K) }, - {"W25Q16DW", INFO(0xef6015, 0x0, 64 * 1024, 32, RD_FULL | WR_QPP | SECT_4K) }, - {"W25Q32DW", INFO(0xef6016, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, - {"W25Q64DW", INFO(0xef6017, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, - {"W25Q128FW", INFO(0xef6018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K) }, + {"w25p80", INFO(0xef2014, 0x0, 64 * 1024, 16, 0) }, + {"w25p16", INFO(0xef2015, 0x0, 64 * 1024, 32, 0) }, + {"w25p32", INFO(0xef2016, 0x0, 64 * 1024, 64, 0) }, + {"w25x40", INFO(0xef3013, 0x0, 64 * 1024, 8, SECT_4K) }, + {"w25x16", INFO(0xef3015, 0x0, 64 * 1024, 32, SECT_4K) }, + {"w25x32", INFO(0xef3016, 0x0, 64 * 1024, 64, SECT_4K) }, + {"w25x64", INFO(0xef3017, 0x0, 64 * 1024, 128, SECT_4K) }, + {"w25q80bl", INFO(0xef4014, 0x0, 64 * 1024, 16, RD_FULL | WR_QPP | SECT_4K) }, + {"w25q16cl", INFO(0xef4015, 0x0, 64 * 1024, 32, RD_FULL | WR_QPP | SECT_4K) }, + {"w25q32bv", INFO(0xef4016, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, + {"w25q64cv", INFO(0xef4017, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, + {"w25q128bv", INFO(0xef4018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K) }, + {"w25q256", INFO(0xef4019, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, + {"w25q80bw", INFO(0xef5014, 0x0, 64 * 1024, 16, RD_FULL | WR_QPP | SECT_4K) }, + {"w25q16dw", INFO(0xef6015, 0x0, 64 * 1024, 32, RD_FULL | WR_QPP | SECT_4K) }, + {"w25q32dw", INFO(0xef6016, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K) }, + {"w25q64dw", INFO(0xef6017, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K) }, + {"w25q128fw", INFO(0xef6018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K) }, #endif {}, /* Empty entry to terminate the list */ /* * Note: * Below paired flash devices has similar spi_flash params. - * (S25FL129P_64K, S25FL128S_64K) - * (W25Q80BL, W25Q80BV) - * (W25Q16CL, W25Q16DV) - * (W25Q32BV, W25Q32FV_SPI) - * (W25Q64CV, W25Q64FV_SPI) - * (W25Q128BV, W25Q128FV_SPI) - * (W25Q32DW, W25Q32FV_QPI) - * (W25Q64DW, W25Q64FV_QPI) - * (W25Q128FW, W25Q128FV_QPI) + * (s25fl129p_64k, s25fl128s_64k) + * (w25q80bl, w25q80bv) + * (w25q16cl, w25q16dv) + * (w25q32bv, w25q32fv_spi) + * (w25q64cv, w25q64fv_spi) + * (w25q128bv, w25q128fv_spi) + * (w25q32dw, w25q32fv_qpi) + * (w25q64dw, w25q64fv_qpi) + * (w25q128fw, w25q128fv_qpi) */ };
Use small 'd' in s25s512s ext_jedec
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: York Sun york.sun@nxp.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/spi_flash_ids.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/spi_flash_ids.c b/drivers/mtd/spi/spi_flash_ids.c index f3c5e3f..9c3a450 100644 --- a/drivers/mtd/spi/spi_flash_ids.c +++ b/drivers/mtd/spi/spi_flash_ids.c @@ -95,7 +95,7 @@ const struct spi_flash_info spi_flash_ids[] = { {"s25fl256s_256k", INFO(0x010219, 0x4d00, 256 * 1024, 128, RD_FULL | WR_QPP) }, {"s25fl256s_64k", INFO(0x010219, 0x4d01, 64 * 1024, 512, RD_FULL | WR_QPP) }, {"s25s256s_64k", INFO6(0x010219, 0x4d0181, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, - {"s25s512s", INFO(0x010220, 0x4D00, 128 * 1024, 512, RD_FULL | WR_QPP) }, + {"s25s512s", INFO(0x010220, 0x4d00, 128 * 1024, 512, RD_FULL | WR_QPP) }, {"s25fl512s_256k", INFO(0x010220, 0x4d00, 256 * 1024, 256, RD_FULL | WR_QPP) }, {"s25fl512s_64k", INFO(0x010220, 0x4d01, 64 * 1024, 1024, RD_FULL | WR_QPP) }, {"s25fl512s_512k", INFO(0x010220, 0x4f00, 256 * 1024, 256, RD_FULL | WR_QPP) },
spi_flash_write_bar-> write_bar spi_flash_write_bar -> read_bar spi_flash_cmd_wait_ready -> spi_flash_wait_till_ready
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: York Sun york.sun@nxp.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf_internal.h | 2 +- drivers/mtd/spi/spi_flash.c | 23 +++++++++++------------ 2 files changed, 12 insertions(+), 13 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index d50fb9a..2feb3b8 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -184,7 +184,7 @@ static inline int spi_flash_cmd_write_disable(struct spi_flash *flash) * - SPI claim * - spi_flash_cmd_write_enable * - spi_flash_cmd_write - * - spi_flash_cmd_wait_ready + * - spi_flash_wait_till_ready * - SPI release */ int spi_flash_write_common(struct spi_flash *flash, const u8 *cmd, diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index c1025c9..b4001a5 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -144,7 +144,7 @@ static int write_evcr(struct spi_flash *flash, u8 evcr) #endif
#ifdef CONFIG_SPI_FLASH_BAR -static int spi_flash_write_bar(struct spi_flash *flash, u32 offset) +static int write_bar(struct spi_flash *flash, u32 offset) { u8 cmd, bank_sel; int ret; @@ -165,8 +165,7 @@ bar_end: return flash->bank_curr; }
-static int spi_flash_read_bar(struct spi_flash *flash, - const struct spi_flash_info *info) +static int read_bar(struct spi_flash *flash, const struct spi_flash_info *info) { u8 curr_bank = 0; int ret; @@ -263,8 +262,8 @@ static int spi_flash_ready(struct spi_flash *flash) return sr && fsr; }
-static int spi_flash_cmd_wait_ready(struct spi_flash *flash, - unsigned long timeout) +static int spi_flash_wait_till_ready(struct spi_flash *flash, + unsigned long timeout) { unsigned long timebase; int ret; @@ -312,7 +311,7 @@ int spi_flash_write_common(struct spi_flash *flash, const u8 *cmd, return ret; }
- ret = spi_flash_cmd_wait_ready(flash, timeout); + ret = spi_flash_wait_till_ready(flash, timeout); if (ret < 0) { debug("SF: write %s timed out\n", timeout == SPI_FLASH_PROG_TIMEOUT ? @@ -354,7 +353,7 @@ int spi_flash_cmd_erase_ops(struct spi_flash *flash, u32 offset, size_t len) spi_flash_dual(flash, &erase_addr); #endif #ifdef CONFIG_SPI_FLASH_BAR - ret = spi_flash_write_bar(flash, erase_addr); + ret = write_bar(flash, erase_addr); if (ret < 0) return ret; #endif @@ -405,7 +404,7 @@ int spi_flash_cmd_write_ops(struct spi_flash *flash, u32 offset, spi_flash_dual(flash, &write_addr); #endif #ifdef CONFIG_SPI_FLASH_BAR - ret = spi_flash_write_bar(flash, write_addr); + ret = write_bar(flash, write_addr); if (ret < 0) return ret; #endif @@ -509,7 +508,7 @@ int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset, spi_flash_dual(flash, &read_addr); #endif #ifdef CONFIG_SPI_FLASH_BAR - ret = spi_flash_write_bar(flash, read_addr); + ret = write_bar(flash, read_addr); if (ret < 0) return ret; bank_sel = flash->bank_curr; @@ -561,7 +560,7 @@ static int sst_byte_write(struct spi_flash *flash, u32 offset, const void *buf) if (ret) return ret;
- return spi_flash_cmd_wait_ready(flash, SPI_FLASH_PROG_TIMEOUT); + return spi_flash_wait_till_ready(flash, SPI_FLASH_PROG_TIMEOUT); }
int sst_write_wp(struct spi_flash *flash, u32 offset, size_t len, @@ -609,7 +608,7 @@ int sst_write_wp(struct spi_flash *flash, u32 offset, size_t len, break; }
- ret = spi_flash_cmd_wait_ready(flash, SPI_FLASH_PROG_TIMEOUT); + ret = spi_flash_wait_till_ready(flash, SPI_FLASH_PROG_TIMEOUT); if (ret) break;
@@ -1137,7 +1136,7 @@ int spi_flash_scan(struct spi_flash *flash)
/* Configure the BAR - discover bank cmds and read current bank */ #ifdef CONFIG_SPI_FLASH_BAR - ret = spi_flash_read_bar(flash, info); + ret = read_bar(flash, info); if (ret < 0) return ret; #endif
Dual flash code in spi are usually take the spi controller to work with dual connected flash devices. Usually these dual connection operation's are referred to flash controller protocol rather with spi controller protocol, these are still present in flash side for the usage of spi-nor controllers.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: York Sun york.sun@nxp.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf.c | 4 ---- drivers/mtd/spi/spi_flash.c | 1 - include/spi.h | 6 ------ 3 files changed, 11 deletions(-)
diff --git a/drivers/mtd/spi/sf.c b/drivers/mtd/spi/sf.c index 664e860..d5e175c 100644 --- a/drivers/mtd/spi/sf.c +++ b/drivers/mtd/spi/sf.c @@ -18,10 +18,6 @@ static int spi_flash_read_write(struct spi_slave *spi, unsigned long flags = SPI_XFER_BEGIN; int ret;
-#ifdef CONFIG_SF_DUAL_FLASH - if (spi->flags & SPI_XFER_U_PAGE) - flags |= SPI_XFER_U_PAGE; -#endif if (data_len == 0) flags |= SPI_XFER_END;
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index b4001a5..708991c 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1016,7 +1016,6 @@ int spi_flash_scan(struct spi_flash *flash)
flash->name = info->name; flash->memory_map = spi->memory_map; - flash->dual_flash = spi->option;
if (info->flags & SST_WR) flash->flags |= SNOR_F_SST_WR; diff --git a/include/spi.h b/include/spi.h index 4c17983..deb65ef 100644 --- a/include/spi.h +++ b/include/spi.h @@ -30,10 +30,6 @@ #define SPI_RX_DUAL BIT(12) /* receive with 2 wires */ #define SPI_RX_QUAD BIT(13) /* receive with 4 wires */
-/* SPI bus connection options - see enum spi_dual_flash */ -#define SPI_CONN_DUAL_SHARED (1 << 0) -#define SPI_CONN_DUAL_SEPARATED (1 << 1) - /* Header byte that marks the start of the message */ #define SPI_PREAMBLE_END_BYTE 0xec
@@ -93,7 +89,6 @@ struct dm_spi_slave_platdata { * @max_write_size: If non-zero, the maximum number of bytes which can * be written at once, excluding command bytes. * @memory_map: Address of read-only SPI flash access. - * @option: Varies SPI bus options - separate, shared bus. * @flags: Indication of SPI flags. */ struct spi_slave { @@ -117,7 +112,6 @@ struct spi_slave { #define SPI_XFER_ONCE (SPI_XFER_BEGIN | SPI_XFER_END) #define SPI_XFER_MMAP BIT(2) /* Memory Mapped start */ #define SPI_XFER_MMAP_END BIT(3) /* Memory Mapped End */ -#define SPI_XFER_U_PAGE BIT(4) };
Jagan Teki
