Re: [U-Boot] JFFS2 with NAND flash is very SLOW ...
On Tuesday 02 June 2009 15:23:57 Pierre Savary wrote:
Is it better to use or not D-cache and I-cache?
Depends a bit on the "application". From my experience I-Cache is most important. But for memory intensive applications (JFFS2 might be such a beast) D-cache could be very helpful as well. Best is to have both enabled of course.
Currently, in my config file, I have only #define CONFIG_CMD_CACHE What do I have to add?
Defining the cache commands doesn't insure that caches are really enabled. Some platforms don't support I- and/or D-cache in U-Boot. I can only speak for PPC4xx which has I-cache enabled and "usually" D-cache disabled (because of cache-coherency issues). This might be different on your platform. Again, just enabling the cache commands will most likely not help here.
Best regards, Stefan
In fact it is not better with this config: #define CONFIG_ICACHE_ON #define CONFIG_DCACHE_ON #define CONFIG_SYS_DCACHE_SIZE 32768 #define CONFIG_SYS_ICACHE_SIZE 32768 #define CONFIG_SYS_CACHELINE_SIZE 32
My architecture is arm926ejs and it seems that CACHE management is not implemented...
I just measure a load of uImage (2MB) ... it takes more than 2 minutes :-(
Pierre
-----Message d'origine----- De : u-boot-bounces@lists.denx.de [mailto:u-boot-bounces@lists.denx.de] De la part de Stefan Roese Envoyé : mardi 2 juin 2009 15:32 À : u-boot@lists.denx.de Cc : Pierre Savary; 'Cote, Sylvain' Objet : Re: [U-Boot] JFFS2 with NAND flash is very SLOW ...
===================================================================== DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de ===================================================================== _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Pierre Savary
Stefan Roese
