[RFC v2 0/2] Prevent alignment issues with "in place" FIT configurations
Looking for some feedback on whether this is a problem wanting to be solved, and if so, whether this solution would be acceptible (after some polishing).
I recently hit alignment issues on a device where U-Boot has been modified to force "in place" fdt loading regardless of the fdt_high environment variable. I realize that this is not a U-Boot problem, but I still think that it would be worthwile to make mkimage produce FIT images suitable for such devices.
This is only one of many possible solutions. The libfdt changes will obviously have to be accepted by the dtc community. I'v posted a similar request to the devicetree-compiler list with those changes. The libfdt patch is included here for convenience.
The expected impact for U-Boot is only the tools/fit_image.c patch.
Bjørn
Changes v2: - actually use the new fdt_alignprop() instead of an earlier PoC hack
Bjørn Mork (2): libfdt: add fdt_alignprop mkimage: Align fdt images in FIT to 8 bytes
scripts/dtc/libfdt/fdt_rw.c | 26 +++++++++++++++++++ scripts/dtc/libfdt/fdt_wip.c | 2 +- scripts/dtc/libfdt/libfdt.h | 30 +++++++++++++++++++++ scripts/dtc/libfdt/libfdt_internal.h | 1 + tools/fit_image.c | 39 ++++++++++++++++++++++++++++ 5 files changed, 97 insertions(+), 1 deletion(-)
Properties are sometimes used to store data with stricter alignment requirements than the 4-byte fdt tag alignment. Aligning the offset of the property data will alloe a client to directly address it, without reloaction, provided the fdt is loaded on a similarily aligned boundary.
One known use-case for this is the U-Boot FIT images, which may embed nested fdt blobs inside properties of the outer FIT fdt. Although strongly discouraged, U-Boot can be configured to use these embedded blobs "in place". This is discouraged because if only will work if the offset of the property value, i.e. the embedded fdt, happens to match the 8-byte boundary required by the devicetree spec.
Adding the ability to align property data allows U-Boot tools to reliably create FIT images for such use.
Other use cases are currently not known, but anticipated.
Signed-off-by: Bjørn Mork bjorn@mork.no --- scripts/dtc/libfdt/fdt_rw.c | 26 ++++++++++++++++++++++++ scripts/dtc/libfdt/fdt_wip.c | 2 +- scripts/dtc/libfdt/libfdt.h | 30 ++++++++++++++++++++++++++++ scripts/dtc/libfdt/libfdt_internal.h | 1 + 4 files changed, 58 insertions(+), 1 deletion(-)
diff --git a/scripts/dtc/libfdt/fdt_rw.c b/scripts/dtc/libfdt/fdt_rw.c index 2eb2b38703be..9e0e8dfeec8c 100644 --- a/scripts/dtc/libfdt/fdt_rw.c +++ b/scripts/dtc/libfdt/fdt_rw.c @@ -331,6 +331,32 @@ int fdt_delprop(void *fdt, int nodeoffset, const char *name) return fdt_splice_struct_(fdt, prop, proplen, 0); }
+int fdt_alignprop(void *fdt, int nodeoffset, const char *name, size_t align) +{ + struct fdt_property *prop; + int err, len, diff; + + FDT_RW_PROBE(fdt); + + if (align != FDT_TAGALIGN(align)) + return -FDT_ERR_BADOFFSET; + + prop = fdt_get_property_w(fdt, nodeoffset, name, &len); + if (!prop) + return len; + + diff = FDT_ALIGN((uintptr_t)prop->data, align) - (uintptr_t)prop->data; + if (!diff) + return 0; + + err = fdt_splice_struct_(fdt, prop, 0, diff); + if (err) + return err; + + fdt_nop_region_(prop, diff); + return 0; +} + int fdt_add_subnode_namelen(void *fdt, int parentoffset, const char *name, int namelen) { diff --git a/scripts/dtc/libfdt/fdt_wip.c b/scripts/dtc/libfdt/fdt_wip.c index c2d7566a67dc..10a75058f0f0 100644 --- a/scripts/dtc/libfdt/fdt_wip.c +++ b/scripts/dtc/libfdt/fdt_wip.c @@ -48,7 +48,7 @@ int fdt_setprop_inplace(void *fdt, int nodeoffset, const char *name, val, len); }
-static void fdt_nop_region_(void *start, int len) +void fdt_nop_region_(void *start, int len) { fdt32_t *p;
diff --git a/scripts/dtc/libfdt/libfdt.h b/scripts/dtc/libfdt/libfdt.h index d706f85962bd..4490f9feb7ce 100644 --- a/scripts/dtc/libfdt/libfdt.h +++ b/scripts/dtc/libfdt/libfdt.h @@ -1928,6 +1928,36 @@ int fdt_appendprop_addrrange(void *fdt, int parent, int nodeoffset, */ int fdt_delprop(void *fdt, int nodeoffset, const char *name);
+/** + * fdt_alignprop - align property data to a given boundary + * @fdt: pointer to the device tree blob + * @nodeoffset: offset of the node whose property to nop + * @name: name of the property to nop + * @align: requested alignment boundary in bytes (must be multiple of 4) + * + * fdt_alignprop() will align the property data to a chosen boundary + * by injecting nop tags in front of the given property. The + * alignment must be a multiple of 4. + * + * This function may insert nop tags in the blob, and will therefore + * change the offsets of some existing nodes. + * + * returns: + * 0, on success + * -FDT_ERR_NOSPACE, there is insufficient free space in the blob to + * move the property to the new boundary + * -FDT_ERR_NOTFOUND, node does not have the named property + * -FDT_ERR_BADOFFSET, nodeoffset did not point to FDT_BEGIN_NODE tag + * or the requested alignment was not a multiple of 4 + * -FDT_ERR_BADLAYOUT, + * -FDT_ERR_BADMAGIC, + * -FDT_ERR_BADVERSION, + * -FDT_ERR_BADSTATE, + * -FDT_ERR_BADSTRUCTURE, + * -FDT_ERR_TRUNCATED, standard meanings + */ +int fdt_alignprop(void *fdt, int nodeoffset, const char *name, size_t align); + /** * fdt_add_subnode_namelen - creates a new node based on substring * @fdt: pointer to the device tree blob diff --git a/scripts/dtc/libfdt/libfdt_internal.h b/scripts/dtc/libfdt/libfdt_internal.h index 5436e2ceeacf..7abee9c21057 100644 --- a/scripts/dtc/libfdt/libfdt_internal.h +++ b/scripts/dtc/libfdt/libfdt_internal.h @@ -25,6 +25,7 @@ int fdt_check_node_offset_(const void *fdt, int offset); int fdt_check_prop_offset_(const void *fdt, int offset); const char *fdt_find_string_(const char *strtab, int tabsize, const char *s); int fdt_node_end_offset_(void *fdt, int nodeoffset); +void fdt_nop_region_(void *start, int len);
static inline const void *fdt_offset_ptr_(const void *fdt, int offset) {
Hi Bjørn,
Can you use an external FIT?
Simon Glass sjg@chromium.org writes:
Maybe. I couldn't make that work in a quick test, but that is probably just me doing something wrong.
But there are other workarounds for this specific device, yes. Appending the DTB to the kernel image is verified to work. So it is possible to create a bootable image.
It's also possible to build a working FIT image with embedded fdt blobs using existing tools, provided that you are willing to run a few iterations while adjusting e.g. descriptions. I just believe it's unecessarily hard, resulting in complicated build rules when a simple call to mkimage should have been enough.
Bjørn
"In place" configurations are strongly discouraged, but known to be used. This can cause hard to debug alignment problems since the value of the "data" property only is guaranteed to be 4-byte aligned.
Unconditionally aligning fdt images to 8 byte boundaries will prevent these problems, at the maximum price of 4 bytes per fdt.
Signed-off-by: Bjørn Mork bjorn@mork.no --- tools/fit_image.c | 39 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 39 insertions(+)
diff --git a/tools/fit_image.c b/tools/fit_image.c index 923a9755b709..1e060784895d 100644 --- a/tools/fit_image.c +++ b/tools/fit_image.c @@ -24,6 +24,41 @@
static struct legacy_img_hdr header;
+/** + * fit_align_fdt_images() - Align all fdt images in the FIT to 8 bytes + * + * An fdt blob must be placed at an 8 byte aligned offset if it is to + * be used "in place". This will not be verified by U-Boot. Simply align + * all IH_TYPE_FLATDT images to prevent problems. + */ +static int fit_align_fdt_images(void *fit) +{ + int images_noffset, noffset, ret; + uint8_t type; + size_t size; + const void *ptr; + + images_noffset = fdt_path_offset(fit, FIT_IMAGES_PATH); + if (images_noffset < 0) { + printf("Can't find images parent node '%s' (%s)\n", + FIT_IMAGES_PATH, fdt_strerror(images_noffset)); + return images_noffset; + } + + for (noffset = fdt_first_subnode(fit, images_noffset); + noffset >= 0; + noffset = fdt_next_subnode(fit, noffset)) { + fit_image_get_type(fit, noffset, &type); + if (type != IH_TYPE_FLATDT) + continue; + + ret = fdt_alignprop(fit, noffset, FIT_DATA_PROP, 8); + if (ret < 0) + return ret; + } + return 0; +} + static int fit_add_file_data(struct image_tool_params *params, size_t size_inc, const char *tmpfile) { @@ -81,6 +116,10 @@ static int fit_add_file_data(struct image_tool_params *params, size_t size_inc, ¶ms->summary); }
+ if (!ret) { + ret = fit_align_fdt_images(ptr); + } + if (dest_blob) { munmap(dest_blob, destfd_size); close(destfd);
So if anyone looked at this, then you've noticed that it fails to consider signing.
The design makes it hard to support the combination. Algnment must run last since signing may inject variable sized nodes before the fdt data properties. Signing must run last since it hashes the blob as it is, inluding FDT_NOP tags and property order.
But we can trick this int working by signing before aligning to create the signature nodes with their proper size and position, and then sign again as a final step if we had to inject any FDT_NOP tags.
The attached fix works for me, creating valid signatures with aligned images no matter how many times I re-sign the FIT with different length signature comments.
Downsides is the obvious double signing, which we already accept for resizing, and a build-up of FDT_NOP tags. The latter is only an issue if you re-sign with signature node size changes. And there's at most one tag added per fdt node per signature update, so it's hardly a major problem.
Bjørn
Bjørn Mork
