RE: [U-Boot-Users] U-boot for MIPS - problem using latest gcc
My toolchain builds the latest mips kernel and the kernel runs perfectly.
If you look in start.S - there is a branch to memsetup. In start.S there is NO definition of this symbol (i.e. as an external or otherwise).
The start.S file includes some files, none of which have any reference to memsetup. Does the toolchain in ELDK assume that any symbol which is not defined as an extern, or is not defined in the file as a direct label, must be external? Makes no sense to me.
-----Original Message----- From: Wolfgang Denk [mailto:wd@denx.de] Sent: Wednesday, January 28, 2004 2:48 PM To: Jerry Walden Cc: u-boot-users@lists.sourceforge.net Subject: Re: [U-Boot-Users] U-boot for MIPS - problem using latest gcc
In message <603BA0CFF3788E46A0DB0918D9AA95100A0E2F3D@sj580004wcom.int.lantronix.com
you wrote: First - I downloaded u-boot v1.0
I could ask wy you use an old version, but it does not matter here.
Then - I changed CROSS_COMPILE to be the latest MIPS compiler
See below.
Then - I did a make dbau1x00_config Then - I did a make all. Memsetup.S is definitely in board/dbau1x00/ So - the file is not missing.
Indeed. And actually this is building fine:
-> tar jxf /opt/tarballs/u-boot-1.0.0.tar.bz2 -> cd u-boot-1.0.0 -> MAKEALL dbau1x00 rm -f include/config.h include/config.mk Configuring for dbau1x00 board... net.c: In function `NetStartAgain': net.c:492: warning: integer overflow in expression text data bss dec hex filename 112120 4760 17252 134132 20bf4 u-boot
Since it is not missing - it must be "incorrect". What would "incorrect be"?
Since all of your steps except one work fine here I can only speculate that the problem must be in the step where we do things differently: I use a working compiler.
Seems your toolchain has some problems?
Jerry Walden
