[PATCH] Make the sandbox board_run_command the default
If CONFIG_CMDLINE=n, common/cli.c calls board_run_command. This fails to link on most architectures. However, the sandbox architecture has an implementation which we can use.
Signed-off-by: Sean Anderson seanga2@gmail.com --- arch/sandbox/cpu/start.c | 7 ------- common/cli.c | 7 +++++++ 2 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/arch/sandbox/cpu/start.c b/arch/sandbox/cpu/start.c index fff9cbdd79..5b7d54869d 100644 --- a/arch/sandbox/cpu/start.c +++ b/arch/sandbox/cpu/start.c @@ -319,13 +319,6 @@ static int sandbox_cmdline_cb_show_of_platdata(struct sandbox_state *state, } SANDBOX_CMDLINE_OPT(show_of_platdata, 0, "Show of-platdata in SPL");
-int board_run_command(const char *cmdline) -{ - printf("## Commands are disabled. Please enable CONFIG_CMDLINE.\n"); - - return 1; -} - static void setup_ram_buf(struct sandbox_state *state) { /* Zero the RAM buffer if we didn't read it, to keep valgrind happy */ diff --git a/common/cli.c b/common/cli.c index 67ceb635a6..59551ef40b 100644 --- a/common/cli.c +++ b/common/cli.c @@ -70,6 +70,13 @@ int run_command_repeatable(const char *cmd, int flag) return 0; #endif } +#else +__weak int board_run_command(const char *cmdline) +{ + printf("## Commands are disabled. Please enable CONFIG_CMDLINE.\n"); + + return 1; +} #endif /* CONFIG_CMDLINE */
int run_command_list(const char *cmd, int len, int flag)
Hi Sean,
Somehow this patch is showing as corrupted. Did you create it with patman?
Signed-off-by: Sean Anderson seanga2@gmail.com --- Changes for v2: - Sent without any word wrap afaik - Rebased onto v2020.01
Changes for v2:
Changes for v2:
Applied to u-boot-dm, thanks!
Bin Meng
Sean Anderson
sjg@google.com
