Re: [PATCH v2 09/11] net: dwc_eth_qos: Add DT parsing for STM32MP13xx platform
-----Original Message----- From: Marek Vasutmarex@denx.de Sent: Tuesday, March 26, 2024 1:08 PM To:u-boot@lists.denx.de Cc: Christophe ROULLIERchristophe.roullier@st.com; Marek Vasutmarex@denx.de; Joe Hershbergerjoe.hershberger@ni.com; Patrice CHOTARD - fosspatrice.chotard@foss.st.com; Patrick DELAUNAY - fosspatrick.delaunay@foss.st.com; Ramon Friedrfried.dev@gmail.com;u-boot@dh-electronics.com;uboot-stm32@st-md-mailman.stormreply.com Subject: [PATCH v2 09/11] net: dwc_eth_qos: Add DT parsing for STM32MP13xx platform
From: Christophe Roullierchristophe.roullier@st.com
Manage 2 ethernet instances, select which instance to configure with mask If mask is not present in DT, it is stm32mp15 platform.
Signed-off-by: Christophe Roullierchristophe.roullier@st.com Signed-off-by: Marek Vasutmarex@denx.de # Rework the code
Cc: Christophe Roullierchristophe.roullier@st.com Cc: Joe Hershbergerjoe.hershberger@ni.com Cc: Patrice Chotardpatrice.chotard@foss.st.com Cc: Patrick Delaunaypatrick.delaunay@foss.st.com Cc: Ramon Friedrfried.dev@gmail.com Cc:u-boot@dh-electronics.com Cc:uboot-stm32@st-md-mailman.stormreply.com
V2: - Drop unrelated clock frequency validation - Move "st,ext-phyclk" property support into separate patch - This leaves only the regmap parts here
drivers/net/dwc_eth_qos_stm32.c | 41 ++++++++++++++++++++++----------- 1 file changed, 28 insertions(+), 13 deletions(-)
diff --git a/drivers/net/dwc_eth_qos_stm32.c b/drivers/net/dwc_eth_qos_stm32.c index 0b13d01346b..5a20fe5bea2 100644 --- a/drivers/net/dwc_eth_qos_stm32.c +++ b/drivers/net/dwc_eth_qos_stm32.c @@ -23,6 +23,7 @@ #include <net.h> #include <netdev.h> #include <phy.h> +#include <regmap.h> #include <reset.h> #include <syscon.h> #include <wait_bit.h> @@ -33,11 +34,16 @@
/* SYSCFG registers */ #define SYSCFG_PMCSETR 0x04 -#define SYSCFG_PMCCLRR 0x44 +#define SYSCFG_PMCCLRR_MP13 0x08 +#define SYSCFG_PMCCLRR_MP15 0x44
+#define SYSCFG_PMCSETR_ETH1_MASK GENMASK(23, 16) +#define SYSCFG_PMCSETR_ETH2_MASK GENMASK(31, 24)
#define SYSCFG_PMCSETR_ETH_CLK_SEL BIT(16) #define SYSCFG_PMCSETR_ETH_REF_CLK_SEL BIT(17)
+/* STM32MP15xx specific bit */ #define SYSCFG_PMCSETR_ETH_SELMII BIT(20)
#define SYSCFG_PMCSETR_ETH_SEL_MASK GENMASK(23, 21) @@ -130,23 +136,30 @@ static int eqos_probe_syscfg_stm32(struct udevice *dev, { /* Ethernet 50MHz RMII clock selection. */ const bool eth_ref_clk_sel = dev_read_bool(dev, "st,eth-ref-clk-sel");
/* SoC is STM32MP13xx with two ethernet MACs */
const bool is_mp13 = device_is_compatible(dev, "st,stm32mp13-dwmac"); /* Gigabit Ethernet 125MHz clock selection. */ const bool eth_clk_sel = dev_read_bool(dev, "st,eth-clk-sel");
u8 *syscfg;
struct regmap *regmap;
u32 regmap_mask; u32 value;
syscfg = (u8 *)syscon_get_first_range(STM32MP_SYSCON_SYSCFG);
if (!syscfg)
return -ENODEV;
regmap = syscon_regmap_lookup_by_phandle(dev, "st,syscon");
if (IS_ERR(regmap))
return PTR_ERR(regmap);
regmap_mask = dev_read_u32_index_default(dev, "st,syscon", 2,
SYSCFG_PMCSETR_ETH1_MASK); switch (interface_type) { case PHY_INTERFACE_MODE_MII: dev_dbg(dev, "PHY_INTERFACE_MODE_MII\n"); value = FIELD_PREP(SYSCFG_PMCSETR_ETH_SEL_MASK, SYSCFG_PMCSETR_ETH_SEL_GMII_MII);
value |= SYSCFG_PMCSETR_ETH_REF_CLK_SEL;
if (!is_mp13) /* Select MII mode on STM32MP15xx */
value |= SYSCFG_PMCSETR_ETH_SELMII; break;
case PHY_INTERFACE_MODE_GMII:
case PHY_INTERFACE_MODE_GMII: /* STM32MP15xx only */ dev_dbg(dev, "PHY_INTERFACE_MODE_GMII\n"); value = FIELD_PREP(SYSCFG_PMCSETR_ETH_SEL_MASK, SYSCFG_PMCSETR_ETH_SEL_GMII_MII); @@ -177,13 +190,15 @@ static int eqos_probe_syscfg_stm32(struct udevice *dev, return -EINVAL; }
/* clear and set ETH configuration bits */
writel(SYSCFG_PMCSETR_ETH_SEL_MASK | SYSCFG_PMCSETR_ETH_SELMII |
SYSCFG_PMCSETR_ETH_REF_CLK_SEL | SYSCFG_PMCSETR_ETH_CLK_SEL,
syscfg + SYSCFG_PMCCLRR);
writel(value, syscfg + SYSCFG_PMCSETR);
/* Shift value at correct ethernet MAC offset in SYSCFG_PMCSETR */
value <<= ffs(regmap_mask) - ffs(SYSCFG_PMCSETR_ETH1_MASK);
/* Update PMCCLRR (clear register) */
regmap_write(regmap, is_mp13 ?
SYSCFG_PMCCLRR_MP13 : SYSCFG_PMCCLRR_MP15,
regmap_mask);
return regmap_update_bits(regmap, SYSCFG_PMCSETR, regmap_mask, value);
static int eqos_probe_resources_stm32(struct udevice *dev)
-- 2.43.0
Reviewed-by: Christophe ROULLIER christophe.roullier@foss.st.com
#define SYSCFG_PMCSETR_ETH_SEL_MASK GENMASK(23, 21) @@ -130,23 +136,30 @@ static int eqos_probe_syscfg_stm32(struct udevice *dev, { /* Ethernet 50MHz RMII clock selection. */ const bool eth_ref_clk_sel = dev_read_bool(dev, "st,eth-ref-clk-sel"); + /* SoC is STM32MP13xx with two ethernet MACs */ + const bool is_mp13 = device_is_compatible(dev, "st,stm32mp13-dwmac"); /* Gigabit Ethernet 125MHz clock selection. */ const bool eth_clk_sel = dev_read_bool(dev, "st,eth-clk-sel"); - u8 *syscfg; + struct regmap *regmap; + u32 regmap_mask; u32 value;
- syscfg = (u8 *)syscon_get_first_range(STM32MP_SYSCON_SYSCFG); - if (!syscfg) - return -ENODEV; + regmap = syscon_regmap_lookup_by_phandle(dev, "st,syscon"); + if (IS_ERR(regmap)) + return PTR_ERR(regmap);
+ regmap_mask = dev_read_u32_index_default(dev, "st,syscon", 2, + SYSCFG_PMCSETR_ETH1_MASK);
switch (interface_type) { case PHY_INTERFACE_MODE_MII: dev_dbg(dev, "PHY_INTERFACE_MODE_MII\n"); value = FIELD_PREP(SYSCFG_PMCSETR_ETH_SEL_MASK, SYSCFG_PMCSETR_ETH_SEL_GMII_MII); - value |= SYSCFG_PMCSETR_ETH_REF_CLK_SEL; + if (!is_mp13) /* Select MII mode on STM32MP15xx */ + value |= SYSCFG_PMCSETR_ETH_SELMII; break; - case PHY_INTERFACE_MODE_GMII: + case PHY_INTERFACE_MODE_GMII: /* STM32MP15xx only */ dev_dbg(dev, "PHY_INTERFACE_MODE_GMII\n"); value = FIELD_PREP(SYSCFG_PMCSETR_ETH_SEL_MASK, SYSCFG_PMCSETR_ETH_SEL_GMII_MII); @@ -177,13 +190,15 @@ static int eqos_probe_syscfg_stm32(struct udevice *dev, return -EINVAL; }
- /* clear and set ETH configuration bits */ - writel(SYSCFG_PMCSETR_ETH_SEL_MASK | SYSCFG_PMCSETR_ETH_SELMII | - SYSCFG_PMCSETR_ETH_REF_CLK_SEL | SYSCFG_PMCSETR_ETH_CLK_SEL, - syscfg + SYSCFG_PMCCLRR); - writel(value, syscfg + SYSCFG_PMCSETR); + /* Shift value at correct ethernet MAC offset in SYSCFG_PMCSETR */ + value <<= ffs(regmap_mask) - ffs(SYSCFG_PMCSETR_ETH1_MASK);
- return 0; + /* Update PMCCLRR (clear register) */ + regmap_write(regmap, is_mp13 ? + SYSCFG_PMCCLRR_MP13 : SYSCFG_PMCCLRR_MP15, + regmap_mask);
+ return regmap_update_bits(regmap, SYSCFG_PMCSETR, regmap_mask, value); }
2.43.0
Applied on u-boot-stm32/master
Christophe ROULLIER
Patrice CHOTARD
