[PATCH V2 00/17] imx: patches in queue
Stefano, Is there a chance to get this into your next branch, then into Tom's next branch? There are often conflicts when applying after pending some time.
V2: Rebased on Tom's next branch. Drop the imx8m.h patches, since Tom already migrated most Kconfig Merge the verdi SPL_DM_SERIAL convertion patch to patch 1
Peng Fan (17): imx: drop CONFIG_MXC_UART_BASE imx: imx8m[m/n]_beacon: Enable SPL_DM_SERIAL imx: imx8mm-cl-iot-gate: Enable DM_SERIAL imx: imx8mm_icore: Enable SPL_DM_SERIAL imx: imx8m[m/p]_phycore: Enable DM_SERIAL imx: imx8mn_var_som: enable DM_SERIAL imx: kontron-sl-mx8mm: enable DM_SERIAL configs: drop CONFIG_SPL_ABORT_ON_RAW_IMAGE imx: imx8mm_beacon: enable pinctrl_wdog in SPL imx: imx8mm-cl-iot-gate: enable pinctrl_wdog in SPL imx: engicam-imx8mm: drop unused macro imx: imx8mm/n/p-venice: enable pinctrl_wdog in SPL imx: imx8mn-beacon: enable pinctrl_wdog in SPL imx: imx8mn_var_som: clean up board watchdog code imx: imx8mp_rsb7320a1: enable wdog driver model in SPL imx: imx8mn-kontron-n801x: enable pinctrl_wdog in SPL imx: phycore_imx8mm/p: clean up board watchdog code
arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi | 4 +++ arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi | 4 +++ arch/arm/dts/imx8mm-kontron-n801x-u-boot.dtsi | 4 +++ arch/arm/dts/imx8mm-venice-u-boot.dtsi | 4 +++ arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi | 4 +++ arch/arm/dts/imx8mn-venice-u-boot.dtsi | 4 +++ arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi | 8 +++++ arch/arm/dts/imx8mp-venice-u-boot.dtsi | 4 +++ .../imx8mp_rsb3720a1/imx8mp_rsb3720a1.c | 12 ------- board/beacon/imx8mm/spl.c | 31 ++----------------- board/beacon/imx8mn/spl.c | 21 ++----------- board/compulab/imx8mm-cl-iot-gate/spl.c | 31 ++----------------- board/engicam/imx8mm/spl.c | 16 ++-------- board/gateworks/venice/spl.c | 29 ----------------- board/kontron/sl-mx8mm/spl.c | 30 ++---------------- board/phytec/phycore_imx8mm/spl.c | 31 ++----------------- board/phytec/phycore_imx8mp/spl.c | 27 ---------------- board/variscite/imx8mn_var_som/spl.c | 22 ++----------- configs/imx8mm-cl-iot-gate-optee_defconfig | 1 + configs/imx8mm-cl-iot-gate_defconfig | 1 + configs/imx8mm-icore-mx8mm-ctouch2_defconfig | 1 - configs/imx8mm-icore-mx8mm-edimm2.2_defconfig | 1 - configs/imx8mm_beacon_defconfig | 1 - configs/imx8mn_beacon_2g_defconfig | 1 - configs/imx8mn_beacon_defconfig | 1 - configs/imx8mn_var_som_defconfig | 1 + configs/kontron-sl-mx8mm_defconfig | 1 + configs/phycore-imx8mm_defconfig | 1 + configs/phycore-imx8mp_defconfig | 1 + include/configs/aristainetos2.h | 2 -- include/configs/capricorn-common.h | 1 - include/configs/cgtqmx8.h | 1 - include/configs/imx8mm-cl-iot-gate.h | 3 -- include/configs/imx8mm_beacon.h | 3 -- include/configs/imx8mm_data_modul_edm_sbc.h | 1 - include/configs/imx8mm_evk.h | 3 -- include/configs/imx8mm_icore_mx8mm.h | 4 --- include/configs/imx8mm_venice.h | 4 --- include/configs/imx8mn_beacon.h | 3 -- include/configs/imx8mn_bsh_smm_s2_common.h | 4 --- include/configs/imx8mn_evk.h | 3 -- include/configs/imx8mn_var_som.h | 2 -- include/configs/imx8mn_venice.h | 4 --- include/configs/imx8mp_evk.h | 3 -- include/configs/imx8mp_rsb3720.h | 1 - include/configs/imx8mp_venice.h | 4 --- include/configs/imx8mq_cm.h | 1 - include/configs/imx8mq_evk.h | 1 - include/configs/imx8mq_phanbell.h | 1 - include/configs/imx8qm_mek.h | 1 - include/configs/imx8qxp_mek.h | 1 - include/configs/imx8ulp_evk.h | 1 - include/configs/kontron-sl-mx8mm.h | 1 - include/configs/kontron_pitx_imx8m.h | 1 - include/configs/mx7dsabresd.h | 1 - include/configs/phycore_imx8mm.h | 4 --- include/configs/phycore_imx8mp.h | 4 --- include/configs/pico-imx8mq.h | 1 - include/configs/somlabs_visionsom_6ull.h | 1 - include/configs/tbs2910.h | 3 -- include/configs/verdin-imx8mm.h | 4 --- include/configs/verdin-imx8mp.h | 4 --- 62 files changed, 57 insertions(+), 316 deletions(-)
Yes, I will do in this way.
Stefano
Since these boards has CONFIG_DM_SERIAL and/or CONFIG_SPL_DM_SERIAL, the legacy macro no need to be defined.
Reviewed-by: Heiko Schocher hs@denx.de Reviewed-by: Fabio Estevam festevam@denx.de Signed-off-by: Peng Fan peng.fan@nxp.com Acked-by: Soeren Moch smoch@web.de Acked-by: Tim Harvey tharvey@gateworks.com --- include/configs/aristainetos2.h | 2 -- include/configs/imx8mm_evk.h | 2 -- include/configs/imx8mm_venice.h | 3 --- include/configs/imx8mn_bsh_smm_s2_common.h | 4 ---- include/configs/imx8mn_evk.h | 2 -- include/configs/imx8mn_venice.h | 3 --- include/configs/imx8mp_evk.h | 2 -- include/configs/imx8mp_venice.h | 3 --- include/configs/mx7dsabresd.h | 1 - include/configs/somlabs_visionsom_6ull.h | 1 - include/configs/tbs2910.h | 3 --- include/configs/verdin-imx8mm.h | 3 --- include/configs/verdin-imx8mp.h | 3 --- 13 files changed, 32 deletions(-)
diff --git a/include/configs/aristainetos2.h b/include/configs/aristainetos2.h index 026775de7c5..de4f4407abb 100644 --- a/include/configs/aristainetos2.h +++ b/include/configs/aristainetos2.h @@ -14,10 +14,8 @@ #define CONFIG_HOSTNAME "aristainetos2"
#if (CONFIG_SYS_BOARD_VERSION == 5) -#define CONFIG_MXC_UART_BASE UART2_BASE #define CONSOLE_DEV "ttymxc1" #elif (CONFIG_SYS_BOARD_VERSION == 6) -#define CONFIG_MXC_UART_BASE UART1_BASE #define CONSOLE_DEV "ttymxc0" #endif
diff --git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h index 983743b5093..6da09deba85 100644 --- a/include/configs/imx8mm_evk.h +++ b/include/configs/imx8mm_evk.h @@ -57,8 +57,6 @@ #define PHYS_SDRAM 0x40000000 #define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */
-#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(2) - #define CONFIG_FEC_MXC_PHYADDR 0
#endif diff --git a/include/configs/imx8mm_venice.h b/include/configs/imx8mm_venice.h index 595c1074966..7a2ef8f533b 100644 --- a/include/configs/imx8mm_venice.h +++ b/include/configs/imx8mm_venice.h @@ -90,9 +90,6 @@ #define PHYS_SDRAM_SIZE SZ_4G #define CONFIG_SYS_BOOTM_LEN SZ_256M
-/* UART */ -#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(2) - /* FEC */ #define CONFIG_FEC_MXC_PHYADDR 0 #define FEC_QUIRK_ENET_MAC diff --git a/include/configs/imx8mn_bsh_smm_s2_common.h b/include/configs/imx8mn_bsh_smm_s2_common.h index 5bdbd37e9cb..63f7da740ef 100644 --- a/include/configs/imx8mn_bsh_smm_s2_common.h +++ b/include/configs/imx8mn_bsh_smm_s2_common.h @@ -32,8 +32,4 @@ #define CONFIG_SYS_SDRAM_BASE 0x40000000 #define PHYS_SDRAM 0x40000000
-#define CONFIG_MXC_UART_BASE UART4_BASE_ADDR - -/* I2C */ - #endif /* __IMX8MN_BSH_SMM_S2_COMMON_H */ diff --git a/include/configs/imx8mn_evk.h b/include/configs/imx8mn_evk.h index 73ba49b0d8f..506d1ffd5a6 100644 --- a/include/configs/imx8mn_evk.h +++ b/include/configs/imx8mn_evk.h @@ -64,6 +64,4 @@ #define PHYS_SDRAM 0x40000000 #define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */
-#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(2) - #endif diff --git a/include/configs/imx8mn_venice.h b/include/configs/imx8mn_venice.h index 8565ba7fdb1..8c45c8462c2 100644 --- a/include/configs/imx8mn_venice.h +++ b/include/configs/imx8mn_venice.h @@ -86,9 +86,6 @@ #define PHYS_SDRAM_SIZE SZ_4G #define CONFIG_SYS_BOOTM_LEN SZ_256M
-/* UART */ -#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(2) - /* FEC */ #define CONFIG_FEC_MXC_PHYADDR 0 #define FEC_QUIRK_ENET_MAC diff --git a/include/configs/imx8mp_evk.h b/include/configs/imx8mp_evk.h index 65c1616bca7..465e1cb4a7e 100644 --- a/include/configs/imx8mp_evk.h +++ b/include/configs/imx8mp_evk.h @@ -69,6 +69,4 @@ #define PHYS_SDRAM_2 0x100000000 #define PHYS_SDRAM_2_SIZE 0xC0000000 /* 3 GB */
-#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(2) - #endif diff --git a/include/configs/imx8mp_venice.h b/include/configs/imx8mp_venice.h index e1d33553956..d9baffb3a24 100644 --- a/include/configs/imx8mp_venice.h +++ b/include/configs/imx8mp_venice.h @@ -86,9 +86,6 @@ #define PHYS_SDRAM_SIZE SZ_4G #define CONFIG_SYS_BOOTM_LEN SZ_256M
-/* UART */ -#define CONFIG_MXC_UART_BASE UART2_BASE_ADDR - /* FEC */ #define FEC_QUIRK_ENET_MAC
diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index 36cef252ea2..a6b8c275fe7 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -12,7 +12,6 @@
#define PHYS_SDRAM_SIZE SZ_1G
-#define CONFIG_MXC_UART_BASE UART1_IPS_BASE_ADDR
#ifdef CONFIG_IMX_BOOTAUX /* Set to QSPI1 A flash at default */ diff --git a/include/configs/somlabs_visionsom_6ull.h b/include/configs/somlabs_visionsom_6ull.h index 98966cfeb91..f1886cb2145 100644 --- a/include/configs/somlabs_visionsom_6ull.h +++ b/include/configs/somlabs_visionsom_6ull.h @@ -16,7 +16,6 @@ /* SPL options */ #include "imx6_spl.h"
/* MMC Configs */ #ifdef CONFIG_FSL_USDHC diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index 1ebe28b7c1b..c355083519f 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -20,9 +20,6 @@
#define CONFIG_SYS_BOOTMAPSZ 0x10000000
-/* Serial console */ -#define CONFIG_MXC_UART_BASE UART1_BASE /* select UART1/UART2 */ - /* Framebuffer */ #define CONFIG_IMX_HDMI #define CONFIG_IMX_VIDEO_SKIP diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index 8f464dd39f0..4fb0d69f579 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -72,9 +72,6 @@ #define PHYS_SDRAM 0x40000000 #define PHYS_SDRAM_SIZE SZ_2G /* 2GB DDR */
-/* UART */ -#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(1) - /* ENET */ #define CONFIG_FEC_MXC_PHYADDR 7
diff --git a/include/configs/verdin-imx8mp.h b/include/configs/verdin-imx8mp.h index 906a20fd840..704a0538a9c 100644 --- a/include/configs/verdin-imx8mp.h +++ b/include/configs/verdin-imx8mp.h @@ -89,7 +89,4 @@ #define PHYS_SDRAM_2 0x100000000 #define PHYS_SDRAM_2_SIZE (SZ_4G + SZ_1G)
-/* UART */ -#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(3) - #endif /* __VERDIN_IMX8MP_H */
Enable CONFIG_SPL_DM_SERIAL. uart2 and its pinmux was already marked with u-boot,dm-spl. Move preloader_console_init after spl_init to make sure driver model work.
Signed-off-by: Peng Fan peng.fan@nxp.com Tested-by: Adam Ford aford173@gmail.com #imx8mm_beacon Reviewed-by: Fabio Estevam festevam@denx.de --- board/beacon/imx8mm/spl.c | 12 ++---------- board/beacon/imx8mn/spl.c | 11 ++--------- configs/imx8mm_beacon_defconfig | 1 - configs/imx8mn_beacon_2g_defconfig | 1 - configs/imx8mn_beacon_defconfig | 1 - include/configs/imx8mm_beacon.h | 2 -- include/configs/imx8mn_beacon.h | 2 -- 7 files changed, 4 insertions(+), 26 deletions(-)
diff --git a/board/beacon/imx8mm/spl.c b/board/beacon/imx8mm/spl.c index 12266b22a42..f92b4c3ed0a 100644 --- a/board/beacon/imx8mm/spl.c +++ b/board/beacon/imx8mm/spl.c @@ -59,14 +59,8 @@ int board_fit_config_name_match(const char *name) } #endif
-#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) #define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE)
-static iomux_v3_cfg_t const uart_pads[] = { - IMX8MM_PAD_UART2_RXD_UART2_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - IMX8MM_PAD_UART2_TXD_UART2_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - static iomux_v3_cfg_t const wdog_pads[] = { IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), }; @@ -79,8 +73,6 @@ int board_early_init_f(void)
set_wdog_reset(wdog);
- imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); - return 0; }
@@ -128,8 +120,6 @@ void board_init_f(ulong dummy)
timer_init();
- preloader_console_init(); - /* Clear the BSS. */ memset(__bss_start, 0, __bss_end - __bss_start);
@@ -139,6 +129,8 @@ void board_init_f(ulong dummy) hang(); }
+ preloader_console_init(); + ret = uclass_get_device_by_name(UCLASS_CLK, "clock-controller@30380000", &dev); diff --git a/board/beacon/imx8mn/spl.c b/board/beacon/imx8mn/spl.c index bb51be01c52..4563446db19 100644 --- a/board/beacon/imx8mn/spl.c +++ b/board/beacon/imx8mn/spl.c @@ -68,7 +68,6 @@ int board_fit_config_name_match(const char *name) } #endif
-#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) #define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) #define PWM1_PAD_CTRL (PAD_CTL_FSEL2 | PAD_CTL_DSE6)
@@ -76,11 +75,6 @@ static iomux_v3_cfg_t const pwm_pads[] = { IMX8MN_PAD_GPIO1_IO01__PWM1_OUT | MUX_PAD_CTRL(PWM1_PAD_CTRL), };
-static iomux_v3_cfg_t const uart_pads[] = { - IMX8MN_PAD_UART2_RXD__UART2_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - IMX8MN_PAD_UART2_TXD__UART2_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - static iomux_v3_cfg_t const wdog_pads[] = { IMX8MN_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), }; @@ -95,7 +89,6 @@ int board_early_init_f(void) imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); set_wdog_reset(wdog);
- imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); init_uart_clk(1);
return 0; @@ -114,14 +107,14 @@ void board_init_f(ulong dummy)
timer_init();
- preloader_console_init(); - ret = spl_init(); if (ret) { debug("spl_init() failed: %d\n", ret); hang(); }
+ preloader_console_init(); + enable_tzc380();
/* DDR initialization */ diff --git a/configs/imx8mm_beacon_defconfig b/configs/imx8mm_beacon_defconfig index 417ece1ef8c..e1acf7e8810 100644 --- a/configs/imx8mm_beacon_defconfig +++ b/configs/imx8mm_beacon_defconfig @@ -125,7 +125,6 @@ CONFIG_SPL_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_CONS_INDEX=2 CONFIG_DM_SERIAL=y -# CONFIG_SPL_DM_SERIAL is not set CONFIG_MXC_UART=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/imx8mn_beacon_2g_defconfig b/configs/imx8mn_beacon_2g_defconfig index 5b9b3715b34..cadef45028d 100644 --- a/configs/imx8mn_beacon_2g_defconfig +++ b/configs/imx8mn_beacon_2g_defconfig @@ -127,7 +127,6 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_RESET=y CONFIG_DM_SERIAL=y -# CONFIG_SPL_DM_SERIAL is not set CONFIG_MXC_UART=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/imx8mn_beacon_defconfig b/configs/imx8mn_beacon_defconfig index b296898d6db..357109e32e5 100644 --- a/configs/imx8mn_beacon_defconfig +++ b/configs/imx8mn_beacon_defconfig @@ -131,7 +131,6 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_RESET=y CONFIG_DM_SERIAL=y -# CONFIG_SPL_DM_SERIAL is not set CONFIG_MXC_UART=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/include/configs/imx8mm_beacon.h b/include/configs/imx8mm_beacon.h index 897eac66b14..899d2ec34f9 100644 --- a/include/configs/imx8mm_beacon.h +++ b/include/configs/imx8mm_beacon.h @@ -80,6 +80,4 @@ #define PHYS_SDRAM 0x40000000 #define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */
-#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(2) - #endif diff --git a/include/configs/imx8mn_beacon.h b/include/configs/imx8mn_beacon.h index 99cbc1d07c8..cadad050d07 100644 --- a/include/configs/imx8mn_beacon.h +++ b/include/configs/imx8mn_beacon.h @@ -96,6 +96,4 @@ #define PHYS_SDRAM_SIZE 0x40000000 /* 1GB DDR */ #endif
For what it's worth, the series doesn't appear to apply cleanly on the current master, but I tested a Nano in addition to the Mini that I tested before.
Tested-by: Adam Ford aford173@gmail.com #imx8mn_beacon
timer_init();
imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); init_uart_clk(1); return 0;
timer_init();
enable_tzc380(); /* DDR initialization */
#endif
2.36.0
在 2022/6/13 22:36, Adam Ford 写道:
Thanks, the patchset is based or Tom's next branch as described in cover letter.
Thanks, Peng.
}return 0;
timer_init();
timer_init();
- #endif
- #endif
-- 2.36.0
Enable CONFIG_DM_SERIAL. uart3 and its pinmux was already marked with u-boot,dm-spl. Move preloader_console_init after spl_early_init to make sure driver model work.
Signed-off-by: Peng Fan peng.fan@nxp.com Reviewed-by: Fabio Estevam festevam@denx.de --- board/compulab/imx8mm-cl-iot-gate/spl.c | 12 ++---------- configs/imx8mm-cl-iot-gate-optee_defconfig | 1 + configs/imx8mm-cl-iot-gate_defconfig | 1 + include/configs/imx8mm-cl-iot-gate.h | 2 -- 4 files changed, 4 insertions(+), 12 deletions(-)
diff --git a/board/compulab/imx8mm-cl-iot-gate/spl.c b/board/compulab/imx8mm-cl-iot-gate/spl.c index 2dc62d6682e..f183704c9d2 100644 --- a/board/compulab/imx8mm-cl-iot-gate/spl.c +++ b/board/compulab/imx8mm-cl-iot-gate/spl.c @@ -83,14 +83,8 @@ int board_fit_config_name_match(const char *name) } #endif
-static iomux_v3_cfg_t const uart_pads[] = { - IMX8MM_PAD_UART3_RXD_UART3_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - IMX8MM_PAD_UART3_TXD_UART3_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - static iomux_v3_cfg_t const wdog_pads[] = { IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), }; @@ -103,8 +97,6 @@ int board_early_init_f(void)
@@ -155,8 +147,6 @@ void board_init_f(ulong dummy)
timer_init();
@@ -166,6 +156,8 @@ void board_init_f(ulong dummy) hang(); }
+ preloader_console_init(); + ret = uclass_get_device_by_name(UCLASS_CLK, "clock-controller@30380000", &dev); diff --git a/configs/imx8mm-cl-iot-gate-optee_defconfig b/configs/imx8mm-cl-iot-gate-optee_defconfig index 57ecd7bb3b6..80055912096 100644 --- a/configs/imx8mm-cl-iot-gate-optee_defconfig +++ b/configs/imx8mm-cl-iot-gate-optee_defconfig @@ -121,6 +121,7 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_RTC=y CONFIG_RTC_ABX80X=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/imx8mm-cl-iot-gate_defconfig b/configs/imx8mm-cl-iot-gate_defconfig index 67f7576f996..dae7ddc20e0 100644 --- a/configs/imx8mm-cl-iot-gate_defconfig +++ b/configs/imx8mm-cl-iot-gate_defconfig @@ -124,6 +124,7 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_RTC=y CONFIG_RTC_ABX80X=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/include/configs/imx8mm-cl-iot-gate.h b/include/configs/imx8mm-cl-iot-gate.h index 297d56b427f..fc738ed410e 100644 --- a/include/configs/imx8mm-cl-iot-gate.h +++ b/include/configs/imx8mm-cl-iot-gate.h @@ -134,8 +134,6 @@ #define PHYS_SDRAM 0x40000000 #define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */
-#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(3) - /* USDHC */
#define CONFIG_SYS_FSL_USDHC_NUM 2
Enable CONFIG_SPL_DM_SERIAL. uart2 and its pinmux was already marked with u-boot,dm-spl. Move preloader_console_init after spl_early_init to make sure driver model work.
Signed-off-by: Peng Fan peng.fan@nxp.com Reviewed-by: Fabio Estevam festevam@denx.de --- board/engicam/imx8mm/spl.c | 14 +++----------- configs/imx8mm-icore-mx8mm-ctouch2_defconfig | 1 - configs/imx8mm-icore-mx8mm-edimm2.2_defconfig | 1 - include/configs/imx8mm_icore_mx8mm.h | 3 --- 4 files changed, 3 insertions(+), 16 deletions(-)
diff --git a/board/engicam/imx8mm/spl.c b/board/engicam/imx8mm/spl.c index f9be769ec59..f75f2dc634c 100644 --- a/board/engicam/imx8mm/spl.c +++ b/board/engicam/imx8mm/spl.c @@ -54,19 +54,11 @@ int board_fit_config_name_match(const char *name) } #endif
-static iomux_v3_cfg_t const uart_pads[] = { - IMX8MM_PAD_UART2_RXD_UART2_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - IMX8MM_PAD_UART2_TXD_UART2_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - int board_early_init_f(void) { - imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); - - return 0; + return 0; }
void board_init_f(ulong dummy) @@ -81,8 +73,6 @@ void board_init_f(ulong dummy)
timer_init();
@@ -92,6 +82,8 @@ void board_init_f(ulong dummy) hang(); }
/* DDR initialization */ diff --git a/configs/imx8mm-icore-mx8mm-ctouch2_defconfig b/configs/imx8mm-icore-mx8mm-ctouch2_defconfig index c95ff3e74fb..b831adb1121 100644 --- a/configs/imx8mm-icore-mx8mm-ctouch2_defconfig +++ b/configs/imx8mm-icore-mx8mm-ctouch2_defconfig @@ -87,7 +87,6 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_CONS_INDEX=2 CONFIG_DM_SERIAL=y -# CONFIG_SPL_DM_SERIAL is not set CONFIG_MXC_UART=y CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y diff --git a/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig b/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig index 62d23949969..614bacbfbf2 100644 --- a/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig +++ b/configs/imx8mm-icore-mx8mm-edimm2.2_defconfig @@ -87,7 +87,6 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_CONS_INDEX=2 CONFIG_DM_SERIAL=y -# CONFIG_SPL_DM_SERIAL is not set CONFIG_MXC_UART=y CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y diff --git a/include/configs/imx8mm_icore_mx8mm.h b/include/configs/imx8mm_icore_mx8mm.h index e6642936cba..a3db85004e2 100644 --- a/include/configs/imx8mm_icore_mx8mm.h +++ b/include/configs/imx8mm_icore_mx8mm.h @@ -54,9 +54,6 @@ #define PHYS_SDRAM_SIZE SZ_2G /* 2GB DDR */ #define CONFIG_SYS_BOOTM_LEN SZ_256M
-/* UART */ -#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(2) - /* USDHC */ #define CONFIG_SYS_FSL_USDHC_NUM 2 #define CONFIG_SYS_FSL_ESDHC_ADDR 0
Enable CONFIG_DM_SERIAL. uart and its pinmux was already marked with u-boot,dm-spl. Move preloader_console_init after spl_early_init to make sure driver model work.
Signed-off-by: Peng Fan peng.fan@nxp.com Tested-by: Teresa Remmet t.remmet@phytec.de Reviewed-by: Fabio Estevam festevam@denx.de --- board/phytec/phycore_imx8mm/spl.c | 12 ++---------- board/phytec/phycore_imx8mp/spl.c | 8 -------- configs/phycore-imx8mm_defconfig | 1 + configs/phycore-imx8mp_defconfig | 1 + include/configs/phycore_imx8mm.h | 3 --- include/configs/phycore_imx8mp.h | 3 --- 6 files changed, 4 insertions(+), 24 deletions(-)
diff --git a/board/phytec/phycore_imx8mm/spl.c b/board/phytec/phycore_imx8mm/spl.c index d54145ef995..7f24a3affc8 100644 --- a/board/phytec/phycore_imx8mm/spl.c +++ b/board/phytec/phycore_imx8mm/spl.c @@ -57,14 +57,8 @@ int board_fit_config_name_match(const char *name) return 0; }
-#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) #define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE)
-static iomux_v3_cfg_t const uart_pads[] = { - IMX8MM_PAD_UART3_RXD_UART3_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - IMX8MM_PAD_UART3_TXD_UART3_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - static iomux_v3_cfg_t const wdog_pads[] = { IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), }; @@ -77,8 +71,6 @@ int board_early_init_f(void)
@@ -92,8 +84,6 @@ void board_init_f(ulong dummy)
board_early_init_f();
@@ -103,6 +93,8 @@ void board_init_f(ulong dummy) hang(); }
/* DDR initialization */ diff --git a/board/phytec/phycore_imx8mp/spl.c b/board/phytec/phycore_imx8mp/spl.c index 19c486e5517..38a581bef57 100644 --- a/board/phytec/phycore_imx8mp/spl.c +++ b/board/phytec/phycore_imx8mp/spl.c @@ -89,14 +89,8 @@ int board_fit_config_name_match(const char *name) return 0; }
-static iomux_v3_cfg_t const uart_pads[] = { - MX8MP_PAD_UART1_RXD__UART1_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - MX8MP_PAD_UART1_TXD__UART1_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - static iomux_v3_cfg_t const wdog_pads[] = { MX8MP_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), }; @@ -109,8 +103,6 @@ int board_early_init_f(void)
diff --git a/configs/phycore-imx8mm_defconfig b/configs/phycore-imx8mm_defconfig index b8cda9f64f2..0316d45caeb 100644 --- a/configs/phycore-imx8mm_defconfig +++ b/configs/phycore-imx8mm_defconfig @@ -120,6 +120,7 @@ CONFIG_PINCTRL_IMX8M=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/configs/phycore-imx8mp_defconfig b/configs/phycore-imx8mp_defconfig index d10ab2a22c1..2c53a5ff8c6 100644 --- a/configs/phycore-imx8mp_defconfig +++ b/configs/phycore-imx8mp_defconfig @@ -111,6 +111,7 @@ CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_SPL_POWER_I2C=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y diff --git a/include/configs/phycore_imx8mm.h b/include/configs/phycore_imx8mm.h index 1d01104cfe8..a14a076172c 100644 --- a/include/configs/phycore_imx8mm.h +++ b/include/configs/phycore_imx8mm.h @@ -72,7 +72,4 @@ #define PHYS_SDRAM 0x40000000 #define PHYS_SDRAM_SIZE SZ_2G /* 2GB DDR */
-/* UART */ -#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(3) - #endif /* __PHYCORE_IMX8MM_H */ diff --git a/include/configs/phycore_imx8mp.h b/include/configs/phycore_imx8mp.h index 75ddcf465f9..9c7331a4167 100644 --- a/include/configs/phycore_imx8mp.h +++ b/include/configs/phycore_imx8mp.h @@ -72,7 +72,4 @@ #define PHYS_SDRAM 0x40000000 #define PHYS_SDRAM_SIZE 0x80000000
-/* UART */ -#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(1) - #endif /* __PHYCORE_IMX8MP_H */
Enable CONFIG_DM_SERIAL. uart and its pinmux was already marked with u-boot,dm-spl. Move preloader_console_init after spl_init to make sure driver model work.
Signed-off-by: Peng Fan peng.fan@nxp.com Reviewed-by: Ariel D'Alessandro ariel.dalessandro@collabora.com Reviewed-by: Fabio Estevam festevam@denx.de --- board/variscite/imx8mn_var_som/spl.c | 11 ++--------- configs/imx8mn_var_som_defconfig | 1 + include/configs/imx8mn_var_som.h | 2 -- 3 files changed, 3 insertions(+), 11 deletions(-)
diff --git a/board/variscite/imx8mn_var_som/spl.c b/board/variscite/imx8mn_var_som/spl.c index 32703c5f0b3..1a8b64fc0a9 100644 --- a/board/variscite/imx8mn_var_som/spl.c +++ b/board/variscite/imx8mn_var_som/spl.c @@ -40,14 +40,8 @@ void spl_board_init(void) puts("Failed to find clock node. Check device tree\n"); }
-static const iomux_v3_cfg_t uart_pads[] = { - IMX8MN_PAD_UART4_RXD__UART4_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - IMX8MN_PAD_UART4_TXD__UART4_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - static const iomux_v3_cfg_t wdog_pads[] = { IMX8MN_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), }; @@ -59,7 +53,6 @@ int board_early_init_f(void) imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); set_wdog_reset(wdog);
- imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); init_uart_clk(3);
return 0; @@ -78,14 +71,14 @@ void board_init_f(ulong dummy)
timer_init();
+ preloader_console_init(); + /* DDR initialization */ spl_dram_init();
diff --git a/configs/imx8mn_var_som_defconfig b/configs/imx8mn_var_som_defconfig index 898f3f2f9f6..889bcf7dc58 100644 --- a/configs/imx8mn_var_som_defconfig +++ b/configs/imx8mn_var_som_defconfig @@ -96,6 +96,7 @@ CONFIG_SPL_DM_PMIC_BD71837=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SYSRESET=y CONFIG_SYSRESET_PSCI=y diff --git a/include/configs/imx8mn_var_som.h b/include/configs/imx8mn_var_som.h index ce679098e5c..ccf83128f28 100644 --- a/include/configs/imx8mn_var_som.h +++ b/include/configs/imx8mn_var_som.h @@ -53,8 +53,6 @@ #define PHYS_SDRAM 0x40000000 #define PHYS_SDRAM_SIZE SZ_1G /* 1GB DDR */
-#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(4) - /* USDHC */ #define CONFIG_SYS_FSL_ESDHC_ADDR 0
Signed-off-by: Peng Fan peng.fan@nxp.com Acked-by: Frieder Schrempf frieder.schrempf@kontron.de Reviewed-by: Fabio Estevam festevam@denx.de --- board/kontron/sl-mx8mm/spl.c | 12 ++---------- configs/kontron-sl-mx8mm_defconfig | 1 + include/configs/kontron-sl-mx8mm.h | 1 - 3 files changed, 3 insertions(+), 11 deletions(-)
diff --git a/board/kontron/sl-mx8mm/spl.c b/board/kontron/sl-mx8mm/spl.c index 4ef03c8c172..a58a75dc958 100644 --- a/board/kontron/sl-mx8mm/spl.c +++ b/board/kontron/sl-mx8mm/spl.c @@ -32,7 +32,6 @@ enum {
#define GPIO_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) #define I2C_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE) -#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) #define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE)
#define TOUCH_RESET_GPIO IMX_GPIO_NR(3, 23) @@ -51,11 +50,6 @@ static iomux_v3_cfg_t const touch_gpio[] = { IMX8MM_PAD_SAI5_RXD2_GPIO3_IO23 | MUX_PAD_CTRL(GPIO_PAD_CTRL) };
-static iomux_v3_cfg_t const uart_pads[] = { - IMX8MM_PAD_UART3_RXD_UART3_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - IMX8MM_PAD_UART3_TXD_UART3_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - static iomux_v3_cfg_t const wdog_pads[] = { IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), }; @@ -230,8 +224,6 @@ int board_early_init_f(void)
@@ -273,8 +265,6 @@ void board_init_f(ulong dummy)
timer_init();
@@ -284,6 +274,8 @@ void board_init_f(ulong dummy) hang(); }
/* PMIC initialization */ diff --git a/configs/kontron-sl-mx8mm_defconfig b/configs/kontron-sl-mx8mm_defconfig index 0fceb60c612..d508bcbd61e 100644 --- a/configs/kontron-sl-mx8mm_defconfig +++ b/configs/kontron-sl-mx8mm_defconfig @@ -114,6 +114,7 @@ CONFIG_DM_REGULATOR=y CONFIG_DM_RTC=y CONFIG_RTC_RV8803=y CONFIG_CONS_INDEX=2 +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SPI=y CONFIG_DM_SPI=y diff --git a/include/configs/kontron-sl-mx8mm.h b/include/configs/kontron-sl-mx8mm.h index 95b836c5470..c4be62c3721 100644 --- a/include/configs/kontron-sl-mx8mm.h +++ b/include/configs/kontron-sl-mx8mm.h @@ -23,7 +23,6 @@ #define CONFIG_SYS_INIT_RAM_SIZE 0x200000
/* Board and environment settings */ -#define CONFIG_MXC_UART_BASE UART_BASE_ADDR(3) #define CONFIG_HOSTNAME "kontron-mx8mm"
#ifdef CONFIG_USB_EHCI_HCD
Am 11.06.22 um 14:21 schrieb Peng Fan (OSS):
Tested-by: Frieder Schrempf frieder.schrempf@kontron.de
CONFIG_SPL_RAW_IMAGE_SUPPORT default y has been used to replace CONFIG_SPL_ABORT_ON_RAW_IMAGE for quite some time, so drop CONFIG_SPL_ABORT_ON_RAW_IMAGE.
Signed-off-by: Peng Fan peng.fan@nxp.com --- include/configs/capricorn-common.h | 1 - include/configs/cgtqmx8.h | 1 - include/configs/imx8mm-cl-iot-gate.h | 1 - include/configs/imx8mm_beacon.h | 1 - include/configs/imx8mm_data_modul_edm_sbc.h | 1 - include/configs/imx8mm_evk.h | 1 - include/configs/imx8mm_icore_mx8mm.h | 1 - include/configs/imx8mm_venice.h | 1 - include/configs/imx8mn_beacon.h | 1 - include/configs/imx8mn_evk.h | 1 - include/configs/imx8mn_venice.h | 1 - include/configs/imx8mp_evk.h | 1 - include/configs/imx8mp_rsb3720.h | 1 - include/configs/imx8mp_venice.h | 1 - include/configs/imx8mq_cm.h | 1 - include/configs/imx8mq_evk.h | 1 - include/configs/imx8mq_phanbell.h | 1 - include/configs/imx8qm_mek.h | 1 - include/configs/imx8qxp_mek.h | 1 - include/configs/imx8ulp_evk.h | 1 - include/configs/kontron_pitx_imx8m.h | 1 - include/configs/phycore_imx8mm.h | 1 - include/configs/phycore_imx8mp.h | 1 - include/configs/pico-imx8mq.h | 1 - include/configs/verdin-imx8mm.h | 1 - include/configs/verdin-imx8mp.h | 1 - 26 files changed, 26 deletions(-)
diff --git a/include/configs/capricorn-common.h b/include/configs/capricorn-common.h index 933fcfcfd28..0bbfe0c2174 100644 --- a/include/configs/capricorn-common.h +++ b/include/configs/capricorn-common.h @@ -20,7 +20,6 @@ #define CONFIG_MALLOC_F_ADDR 0x00120000
#define CONFIG_SPL_RAW_IMAGE_ARM_TRUSTED_FIRMWARE -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
#endif /* CONFIG_SPL_BUILD */
diff --git a/include/configs/cgtqmx8.h b/include/configs/cgtqmx8.h index 0266d6988ce..a8ff0a1317d 100644 --- a/include/configs/cgtqmx8.h +++ b/include/configs/cgtqmx8.h @@ -19,7 +19,6 @@
-#define CONFIG_SPL_ABORT_ON_RAW_IMAGE #endif
/* Flat Device Tree Definitions */ diff --git a/include/configs/imx8mm-cl-iot-gate.h b/include/configs/imx8mm-cl-iot-gate.h index fc738ed410e..7135a83e042 100644 --- a/include/configs/imx8mm-cl-iot-gate.h +++ b/include/configs/imx8mm-cl-iot-gate.h @@ -20,7 +20,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x912000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
#endif
diff --git a/include/configs/imx8mm_beacon.h b/include/configs/imx8mm_beacon.h index 899d2ec34f9..79ed3971225 100644 --- a/include/configs/imx8mm_beacon.h +++ b/include/configs/imx8mm_beacon.h @@ -17,7 +17,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x930000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
#endif
diff --git a/include/configs/imx8mm_data_modul_edm_sbc.h b/include/configs/imx8mm_data_modul_edm_sbc.h index bb19aa292b8..282b295497c 100644 --- a/include/configs/imx8mm_data_modul_edm_sbc.h +++ b/include/configs/imx8mm_data_modul_edm_sbc.h @@ -18,7 +18,6 @@ #define CONFIG_MALLOC_F_ADDR 0x930000
#endif
diff --git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h index 6da09deba85..e4b2544410b 100644 --- a/include/configs/imx8mm_evk.h +++ b/include/configs/imx8mm_evk.h @@ -19,7 +19,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x930000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
#endif
diff --git a/include/configs/imx8mm_icore_mx8mm.h b/include/configs/imx8mm_icore_mx8mm.h index a3db85004e2..dfe6966c462 100644 --- a/include/configs/imx8mm_icore_mx8mm.h +++ b/include/configs/imx8mm_icore_mx8mm.h @@ -18,7 +18,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ # define CONFIG_MALLOC_F_ADDR 0x930000 /* For RAW image gives a error info not panic */ -# define CONFIG_SPL_ABORT_ON_RAW_IMAGE #endif /* CONFIG_SPL_BUILD */
#ifndef CONFIG_SPL_BUILD diff --git a/include/configs/imx8mm_venice.h b/include/configs/imx8mm_venice.h index 7a2ef8f533b..8a6cc69b5eb 100644 --- a/include/configs/imx8mm_venice.h +++ b/include/configs/imx8mm_venice.h @@ -17,7 +17,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x930000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
#endif
diff --git a/include/configs/imx8mn_beacon.h b/include/configs/imx8mn_beacon.h index cadad050d07..6faecbde776 100644 --- a/include/configs/imx8mn_beacon.h +++ b/include/configs/imx8mn_beacon.h @@ -18,7 +18,6 @@ #define CONFIG_MALLOC_F_ADDR 0x184000
diff --git a/include/configs/imx8mn_evk.h b/include/configs/imx8mn_evk.h index 506d1ffd5a6..1396ae1422e 100644 --- a/include/configs/imx8mn_evk.h +++ b/include/configs/imx8mn_evk.h @@ -18,7 +18,6 @@
#ifdef CONFIG_SPL_BUILD /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
#endif
diff --git a/include/configs/imx8mn_venice.h b/include/configs/imx8mn_venice.h index 8c45c8462c2..8ef55aa6eba 100644 --- a/include/configs/imx8mn_venice.h +++ b/include/configs/imx8mn_venice.h @@ -15,7 +15,6 @@
#ifdef CONFIG_SPL_BUILD /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE #endif
#define MEM_LAYOUT_ENV_SETTINGS \ diff --git a/include/configs/imx8mp_evk.h b/include/configs/imx8mp_evk.h index 465e1cb4a7e..618010db9fb 100644 --- a/include/configs/imx8mp_evk.h +++ b/include/configs/imx8mp_evk.h @@ -18,7 +18,6 @@ #ifdef CONFIG_SPL_BUILD /*#define CONFIG_ENABLE_DDR_TRAINING_DEBUG*/
#define CONFIG_POWER_PCA9450
diff --git a/include/configs/imx8mp_rsb3720.h b/include/configs/imx8mp_rsb3720.h index efff6b95553..1d4c057ccc0 100644 --- a/include/configs/imx8mp_rsb3720.h +++ b/include/configs/imx8mp_rsb3720.h @@ -32,7 +32,6 @@ * set \ */
#if defined(CONFIG_NAND_BOOT) #define CONFIG_SPL_NAND_MXS diff --git a/include/configs/imx8mp_venice.h b/include/configs/imx8mp_venice.h index d9baffb3a24..fce87b1657d 100644 --- a/include/configs/imx8mp_venice.h +++ b/include/configs/imx8mp_venice.h @@ -15,7 +15,6 @@
#define MEM_LAYOUT_ENV_SETTINGS \ diff --git a/include/configs/imx8mq_cm.h b/include/configs/imx8mq_cm.h index a242d5e3e8e..a5d6adfaa4c 100644 --- a/include/configs/imx8mq_cm.h +++ b/include/configs/imx8mq_cm.h @@ -20,7 +20,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x182000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
#endif
diff --git a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h index 98ddb06fe33..182f45bb74d 100644 --- a/include/configs/imx8mq_evk.h +++ b/include/configs/imx8mq_evk.h @@ -21,7 +21,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x182000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
#define CONFIG_POWER_PFUZE100 #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08 diff --git a/include/configs/imx8mq_phanbell.h b/include/configs/imx8mq_phanbell.h index 1b3c0493ebd..97bd5044501 100644 --- a/include/configs/imx8mq_phanbell.h +++ b/include/configs/imx8mq_phanbell.h @@ -18,7 +18,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x182000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE #endif
/* ENET Config */ diff --git a/include/configs/imx8qm_mek.h b/include/configs/imx8qm_mek.h index f4d19f87312..b59502e5895 100644 --- a/include/configs/imx8qm_mek.h +++ b/include/configs/imx8qm_mek.h @@ -20,7 +20,6 @@
#ifdef CONFIG_AHAB_BOOT diff --git a/include/configs/imx8qxp_mek.h b/include/configs/imx8qxp_mek.h index a6aabc7add7..511f6c8d9bb 100644 --- a/include/configs/imx8qxp_mek.h +++ b/include/configs/imx8qxp_mek.h @@ -18,7 +18,6 @@
#ifdef CONFIG_AHAB_BOOT diff --git a/include/configs/imx8ulp_evk.h b/include/configs/imx8ulp_evk.h index 987069447d5..f9080216f1f 100644 --- a/include/configs/imx8ulp_evk.h +++ b/include/configs/imx8ulp_evk.h @@ -16,7 +16,6 @@ #ifdef CONFIG_SPL_BUILD #define CONFIG_MALLOC_F_ADDR 0x22040000
-#define CONFIG_SPL_ABORT_ON_RAW_IMAGE /* For RAW image gives a error info not panic */
#endif
diff --git a/include/configs/kontron_pitx_imx8m.h b/include/configs/kontron_pitx_imx8m.h index 88aaa55bef5..bf336b99d6a 100644 --- a/include/configs/kontron_pitx_imx8m.h +++ b/include/configs/kontron_pitx_imx8m.h @@ -22,7 +22,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x182000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
#define CONFIG_POWER_PFUZE100 diff --git a/include/configs/phycore_imx8mm.h b/include/configs/phycore_imx8mm.h index a14a076172c..f8c3e1f10db 100644 --- a/include/configs/phycore_imx8mm.h +++ b/include/configs/phycore_imx8mm.h @@ -20,7 +20,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x930000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE #endif
#define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/phycore_imx8mp.h b/include/configs/phycore_imx8mp.h index 9c7331a4167..dd0b108a89f 100644 --- a/include/configs/phycore_imx8mp.h +++ b/include/configs/phycore_imx8mp.h @@ -17,7 +17,6 @@ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
#ifdef CONFIG_SPL_BUILD -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
diff --git a/include/configs/pico-imx8mq.h b/include/configs/pico-imx8mq.h index 25ad936a06b..a587570ea17 100644 --- a/include/configs/pico-imx8mq.h +++ b/include/configs/pico-imx8mq.h @@ -18,7 +18,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x182000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE #endif
/* ENET Config */ diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index 4fb0d69f579..afc507b32a3 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -19,7 +19,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x930000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE #endif
#define MEM_LAYOUT_ENV_SETTINGS \ diff --git a/include/configs/verdin-imx8mp.h b/include/configs/verdin-imx8mp.h index 704a0538a9c..97f537e8e06 100644 --- a/include/configs/verdin-imx8mp.h +++ b/include/configs/verdin-imx8mp.h @@ -19,7 +19,6 @@ /* malloc f used before GD_FLG_FULL_MALLOC_INIT set */ #define CONFIG_MALLOC_F_ADDR 0x184000 /* For RAW image gives a error info not panic */ -#define CONFIG_SPL_ABORT_ON_RAW_IMAGE
Mark pinctrl_wdog as u-boot,dm-spl to clean up board code,
The set_wdog_reset() function is not necessary as this is handled by the imx_watchdog.c driver due to the 'fsl,ext-reset-output' property being set.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi | 4 ++++ board/beacon/imx8mm/spl.c | 19 ------------------- 2 files changed, 4 insertions(+), 19 deletions(-)
diff --git a/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi index e33e10ac129..c94b4ffa4c3 100644 --- a/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-beacon-kit-u-boot.dtsi @@ -73,6 +73,10 @@ u-boot,dm-spl; };
+&pinctrl_wdog { + u-boot,dm-spl; +}; + &uart2 { u-boot,dm-spl; }; diff --git a/board/beacon/imx8mm/spl.c b/board/beacon/imx8mm/spl.c index f92b4c3ed0a..a93cc938784 100644 --- a/board/beacon/imx8mm/spl.c +++ b/board/beacon/imx8mm/spl.c @@ -59,23 +59,6 @@ int board_fit_config_name_match(const char *name) } #endif
-#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) - -static iomux_v3_cfg_t const wdog_pads[] = { - IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; - -int board_early_init_f(void) -{ - struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; - - imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); - - set_wdog_reset(wdog); - - return 0; -} - static int power_init_board(void) { struct udevice *dev; @@ -116,8 +99,6 @@ void board_init_f(ulong dummy)
init_uart_clk(1);
- board_early_init_f(); - timer_init();
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi | 4 ++++ board/compulab/imx8mm-cl-iot-gate/spl.c | 19 ------------------- 2 files changed, 4 insertions(+), 19 deletions(-)
diff --git a/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi b/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi index 433b02cceee..a7044b63699 100644 --- a/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi @@ -84,6 +84,10 @@ u-boot,dm-spl; };
+&pinctrl_wdog { + u-boot,dm-spl; +}; + &uart3 { u-boot,dm-spl; }; diff --git a/board/compulab/imx8mm-cl-iot-gate/spl.c b/board/compulab/imx8mm-cl-iot-gate/spl.c index f183704c9d2..d2d20269ba0 100644 --- a/board/compulab/imx8mm-cl-iot-gate/spl.c +++ b/board/compulab/imx8mm-cl-iot-gate/spl.c @@ -83,23 +83,6 @@ int board_fit_config_name_match(const char *name) } #endif
-#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) - -static iomux_v3_cfg_t const wdog_pads[] = { - IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; - -int board_early_init_f(void) -{ - struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; - - imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); - - set_wdog_reset(wdog); - - return 0; -} - static int power_init_board(void) { struct udevice *dev; @@ -141,8 +124,6 @@ void board_init_f(ulong dummy)
arch_cpu_init();
- board_early_init_f(); - init_uart_clk(2);
timer_init();
Drop unused WDOG macro
Signed-off-by: Peng Fan peng.fan@nxp.com Reviewed-by: Michael Trimarchi michael@amarulasolutions.com --- board/engicam/imx8mm/spl.c | 2 -- 1 file changed, 2 deletions(-)
diff --git a/board/engicam/imx8mm/spl.c b/board/engicam/imx8mm/spl.c index f75f2dc634c..1846134a492 100644 --- a/board/engicam/imx8mm/spl.c +++ b/board/engicam/imx8mm/spl.c @@ -54,8 +54,6 @@ int board_fit_config_name_match(const char *name) } #endif
-#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) - int board_early_init_f(void) { return 0;
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mm-venice-u-boot.dtsi | 4 ++++ arch/arm/dts/imx8mn-venice-u-boot.dtsi | 4 ++++ arch/arm/dts/imx8mp-venice-u-boot.dtsi | 4 ++++ board/gateworks/venice/spl.c | 29 -------------------------- 4 files changed, 12 insertions(+), 29 deletions(-)
diff --git a/arch/arm/dts/imx8mm-venice-u-boot.dtsi b/arch/arm/dts/imx8mm-venice-u-boot.dtsi index c61c6de935f..68978a0413e 100644 --- a/arch/arm/dts/imx8mm-venice-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-venice-u-boot.dtsi @@ -72,3 +72,7 @@ &wdog1 { u-boot,dm-spl; }; + +&pinctrl_wdog { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx8mn-venice-u-boot.dtsi b/arch/arm/dts/imx8mn-venice-u-boot.dtsi index 4f23da35676..35819553879 100644 --- a/arch/arm/dts/imx8mn-venice-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-venice-u-boot.dtsi @@ -110,6 +110,10 @@ u-boot,dm-spl; };
+&pinctrl_wdog { + u-boot,dm-spl; +}; + &binman { u-boot-spl-ddr { align = <4>; diff --git a/arch/arm/dts/imx8mp-venice-u-boot.dtsi b/arch/arm/dts/imx8mp-venice-u-boot.dtsi index 37f3edc9817..96b9fa89cf4 100644 --- a/arch/arm/dts/imx8mp-venice-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-venice-u-boot.dtsi @@ -72,3 +72,7 @@ &wdog1 { u-boot,dm-spl; }; + +&pinctrl_wdog { + u-boot,dm-spl; +}; diff --git a/board/gateworks/venice/spl.c b/board/gateworks/venice/spl.c index 6e6ce015f28..4c0feb4381c 100644 --- a/board/gateworks/venice/spl.c +++ b/board/gateworks/venice/spl.c @@ -87,33 +87,6 @@ static void spl_dram_init(int size) ddr_init(dram_timing); }
-#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) - -#ifdef CONFIG_IMX8MM -static iomux_v3_cfg_t const wdog_pads[] = { - IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; -#elif CONFIG_IMX8MN -static const iomux_v3_cfg_t wdog_pads[] = { - IMX8MN_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; -#elif CONFIG_IMX8MP -static const iomux_v3_cfg_t wdog_pads[] = { - MX8MP_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; -#endif - -int board_early_init_f(void) -{ - struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; - - imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); - - set_wdog_reset(wdog); - - return 0; -} - /* * Model specific PMIC adjustments necessary prior to DRAM init * @@ -253,8 +226,6 @@ void board_init_f(ulong dummy)
init_uart_clk(1);
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi | 4 ++++ board/beacon/imx8mn/spl.c | 10 ---------- 2 files changed, 4 insertions(+), 10 deletions(-)
diff --git a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi index 69fd69c8d02..eb1dd8debba 100644 --- a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi @@ -132,6 +132,10 @@ u-boot,dm-spl; };
+&pinctrl_wdog { + u-boot,dm-spl; +}; + &binman { u-boot-spl-ddr { filename = "u-boot-spl-ddr.bin"; diff --git a/board/beacon/imx8mn/spl.c b/board/beacon/imx8mn/spl.c index 4563446db19..029f71bc995 100644 --- a/board/beacon/imx8mn/spl.c +++ b/board/beacon/imx8mn/spl.c @@ -68,27 +68,17 @@ int board_fit_config_name_match(const char *name) } #endif
-#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) #define PWM1_PAD_CTRL (PAD_CTL_FSEL2 | PAD_CTL_DSE6)
-static iomux_v3_cfg_t const wdog_pads[] = { - IMX8MN_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; - int board_early_init_f(void) { - struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; - /* Claiming pwm pins prevents LCD flicker during startup*/ imx_iomux_v3_setup_multiple_pads(pwm_pads, ARRAY_SIZE(pwm_pads));
- imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); - set_wdog_reset(wdog); - init_uart_clk(1);
pinctrl_wdog already marked u-boot,dm-spl, so clean up board code.
Signed-off-by: Peng Fan peng.fan@nxp.com Tested-by: Ariel D'Alessandro ariel.dalessandro@collabora.com --- board/variscite/imx8mn_var_som/spl.c | 11 ----------- 1 file changed, 11 deletions(-)
diff --git a/board/variscite/imx8mn_var_som/spl.c b/board/variscite/imx8mn_var_som/spl.c index 1a8b64fc0a9..41e70505774 100644 --- a/board/variscite/imx8mn_var_som/spl.c +++ b/board/variscite/imx8mn_var_som/spl.c @@ -40,19 +40,8 @@ void spl_board_init(void) puts("Failed to find clock node. Check device tree\n"); }
-#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) - -static const iomux_v3_cfg_t wdog_pads[] = { - IMX8MN_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; - int board_early_init_f(void) { - struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; - - imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); - set_wdog_reset(wdog); - init_uart_clk(3);
Mark wdog1/pinctrl_wdog as u-boot,dm-spl to clean up board code,
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi | 8 ++++++++ board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c | 12 ------------ 2 files changed, 8 insertions(+), 12 deletions(-)
diff --git a/arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi b/arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi index 2848b24f655..4419967ee42 100644 --- a/arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-rsb3720-a1-u-boot.dtsi @@ -89,6 +89,14 @@ u-boot,dm-spl; };
+&wdog1 { + u-boot,dm-spl; +}; + +&pinctrl_wdog { + u-boot,dm-spl; +}; + &pinctrl_i2c1 { u-boot,dm-spl; }; diff --git a/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c b/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c index f129ebd429b..0a1b2c94161 100644 --- a/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c +++ b/board/advantech/imx8mp_rsb3720a1/imx8mp_rsb3720a1.c @@ -28,12 +28,6 @@
DECLARE_GLOBAL_DATA_PTR;
-#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) - -static const iomux_v3_cfg_t wdog_pads[] = { - MX8MP_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; - #ifdef CONFIG_NAND_MXS static void setup_gpmi_nand(void) { @@ -69,12 +63,6 @@ u8 num_image_type_guids = ARRAY_SIZE(fw_images);
int board_early_init_f(void) { - struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; - - imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); - - set_wdog_reset(wdog); - init_uart_clk(2);
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mm-kontron-n801x-u-boot.dtsi | 4 ++++ board/kontron/sl-mx8mm/spl.c | 18 ------------------ 2 files changed, 4 insertions(+), 18 deletions(-)
diff --git a/arch/arm/dts/imx8mm-kontron-n801x-u-boot.dtsi b/arch/arm/dts/imx8mm-kontron-n801x-u-boot.dtsi index 22d18e6f1cf..6882513f161 100644 --- a/arch/arm/dts/imx8mm-kontron-n801x-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-kontron-n801x-u-boot.dtsi @@ -126,3 +126,7 @@ &wdog1 { u-boot,dm-spl; }; + +&pinctrl_wdog { + u-boot,dm-spl; +}; diff --git a/board/kontron/sl-mx8mm/spl.c b/board/kontron/sl-mx8mm/spl.c index a58a75dc958..63361f1d2ab 100644 --- a/board/kontron/sl-mx8mm/spl.c +++ b/board/kontron/sl-mx8mm/spl.c @@ -32,7 +32,6 @@ enum {
#define GPIO_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) #define I2C_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE) -#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE)
@@ -50,10 +49,6 @@ static iomux_v3_cfg_t const touch_gpio[] = { IMX8MM_PAD_SAI5_RXD2_GPIO3_IO23 | MUX_PAD_CTRL(GPIO_PAD_CTRL) };
-static iomux_v3_cfg_t const wdog_pads[] = { - IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; - int spl_board_boot_device(enum boot_device boot_dev_spl) { switch (boot_dev_spl) { @@ -216,17 +211,6 @@ void spl_board_init(void) printf("Failed to find clock node. Check device tree\n"); }
-int board_early_init_f(void) -{ - struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; - - imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); - - set_wdog_reset(wdog); - - return 0; -} - static int power_init_board(void) { struct udevice *dev; @@ -261,8 +245,6 @@ void board_init_f(ulong dummy)
init_uart_clk(2);
Thanks for the cleanup!!!
The subject line should probably be:
imx: kontron-sl-mx8mm: enable pinctrl_wdog in SPL
Otherwise:
Reviewed-by: Frieder Schrempf frieder.schrempf@kontron.de Tested-by: Frieder Schrempf frieder.schrempf@kontron.de
+&pinctrl_wdog {
- u-boot,dm-spl;
init_uart_clk(2);
timer_init();
Am 14.06.22 um 12:18 schrieb Frieder Schrempf:
Otherwise:
Stefano, I see that my tags have been picked up in next, but the subject line hasn't been fixed. Especially mx8mm instead of mx8mn would be a meaningful correction.
Just for your information. If this is difficult to fix before merging to master, then it's probably fine to leave it as it is.
在 2022/6/22 22:25, Frieder Schrempf 写道:
Otherwise:
oops, I overlooked your reply.
Regards, Peng.
Signed-off-by: Peng Fan peng.fan@nxp.com Tested-by: Teresa Remmet t.remmet@phytec.de --- board/phytec/phycore_imx8mm/spl.c | 19 ------------------- board/phytec/phycore_imx8mp/spl.c | 19 ------------------- 2 files changed, 38 deletions(-)
diff --git a/board/phytec/phycore_imx8mm/spl.c b/board/phytec/phycore_imx8mm/spl.c index 7f24a3affc8..d87ab6d4497 100644 --- a/board/phytec/phycore_imx8mm/spl.c +++ b/board/phytec/phycore_imx8mm/spl.c @@ -57,23 +57,6 @@ int board_fit_config_name_match(const char *name) return 0; }
-#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE) - -static iomux_v3_cfg_t const wdog_pads[] = { - IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; - -int board_early_init_f(void) -{ - struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; - - imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); - - set_wdog_reset(wdog); - - return 0; -} - void board_init_f(ulong dummy) { int ret; @@ -82,8 +65,6 @@ void board_init_f(ulong dummy)
init_uart_clk(2);
- board_early_init_f(); - /* Clear the BSS. */ memset(__bss_start, 0, __bss_end - __bss_start);
diff --git a/board/phytec/phycore_imx8mp/spl.c b/board/phytec/phycore_imx8mp/spl.c index 38a581bef57..faed6fc3b76 100644 --- a/board/phytec/phycore_imx8mp/spl.c +++ b/board/phytec/phycore_imx8mp/spl.c @@ -89,23 +89,6 @@ int board_fit_config_name_match(const char *name) return 0; }
-#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE) - -static iomux_v3_cfg_t const wdog_pads[] = { - MX8MP_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), -}; - -int board_early_init_f(void) -{ - struct wdog_regs *wdog = (struct wdog_regs *)WDOG1_BASE_ADDR; - - imx_iomux_v3_setup_multiple_pads(wdog_pads, ARRAY_SIZE(wdog_pads)); - - set_wdog_reset(wdog); - - return 0; -} - void board_init_f(ulong dummy) { int ret; @@ -114,8 +97,6 @@ void board_init_f(ulong dummy)
init_uart_clk(0);
- board_early_init_f(); - ret = spl_early_init(); if (ret) { debug("spl_early_init() failed: %d\n", ret);
Series is merged into u-boot-imx, -next branch. PR will follow.
Best regards, Stefano
Adam Ford
Frieder Schrempf
Peng Fan (OSS)
Stefano Babic
