[PATCH v5 0/2] add optee support for broadcom NS3 soc
This is fourth patch set series prepared on top of third patch set ("add FIT image support for broadcom NS3 soc").
This patch adds optee support.
Changes from v4: -Address review comments from Simon, Add blank line before return.
Changes from v3: -Address review comments from Simon, Rearrange code and remove while loop, Add comments for function.
Changes from v2: -Address review comments from Simon, Remove own return code and use standard error code. Take out common lines from different functions and move them into common static function. Remove include <common.h> as its not required. Move functions with printf from header file into c file.
-Address slef review comments, Remove optee dt node as this file is no longer in sync with linux.
Changes from v1: -Address review comments from Thomas Fitzsimmons, Expand the bnxt full form.
-Address review comments from Simon Glass, Move c file from board/broadcom/bcmns3/chimp_optee.c to drivers/tee/broadcom, Move header file from include/brcm/chimp.h to include/broadcom/chimp.h
Rayagonda Kokatanur (1): configs: ns3: enable tee and optee driver
Vikas Gupta (1): drivers: tee: broadcom: add optee based bnxt fw load driver
configs/bcm_ns3_defconfig | 5 +- drivers/tee/Kconfig | 1 + drivers/tee/Makefile | 1 + drivers/tee/broadcom/Kconfig | 7 ++ drivers/tee/broadcom/Makefile | 3 + drivers/tee/broadcom/chimp_optee.c | 183 +++++++++++++++++++++++++++++ include/broadcom/chimp.h | 43 +++++++ 7 files changed, 242 insertions(+), 1 deletion(-) create mode 100644 drivers/tee/broadcom/Kconfig create mode 100644 drivers/tee/broadcom/Makefile create mode 100644 drivers/tee/broadcom/chimp_optee.c create mode 100644 include/broadcom/chimp.h
Add optee based bnxt fw load driver. bnxt is Broadcom NetXtreme controller Ethernet card. This driver is used to load bnxt firmware binary using OpTEE.
Signed-off-by: Vikas Gupta vikas.gupta@broadcom.com Signed-off-by: Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes from v4: -Address review comments from Simon, Add blank line before return.
drivers/tee/Kconfig | 1 + drivers/tee/Makefile | 1 + drivers/tee/broadcom/Kconfig | 7 ++ drivers/tee/broadcom/Makefile | 3 + drivers/tee/broadcom/chimp_optee.c | 183 +++++++++++++++++++++++++++++ include/broadcom/chimp.h | 43 +++++++ 6 files changed, 238 insertions(+) create mode 100644 drivers/tee/broadcom/Kconfig create mode 100644 drivers/tee/broadcom/Makefile create mode 100644 drivers/tee/broadcom/chimp_optee.c create mode 100644 include/broadcom/chimp.h
diff --git a/drivers/tee/Kconfig b/drivers/tee/Kconfig index 5c0c89043f..5ca5a0836c 100644 --- a/drivers/tee/Kconfig +++ b/drivers/tee/Kconfig @@ -29,6 +29,7 @@ config SANDBOX_TEE "avb" commands.
source "drivers/tee/optee/Kconfig" +source "drivers/tee/broadcom/Kconfig"
endmenu
diff --git a/drivers/tee/Makefile b/drivers/tee/Makefile index f72c68c09f..5c8ffdbce8 100644 --- a/drivers/tee/Makefile +++ b/drivers/tee/Makefile @@ -3,3 +3,4 @@ obj-y += tee-uclass.o obj-$(CONFIG_SANDBOX) += sandbox.o obj-$(CONFIG_OPTEE) += optee/ +obj-y += broadcom/ diff --git a/drivers/tee/broadcom/Kconfig b/drivers/tee/broadcom/Kconfig new file mode 100644 index 0000000000..ce95072d4e --- /dev/null +++ b/drivers/tee/broadcom/Kconfig @@ -0,0 +1,7 @@ +config CHIMP_OPTEE + bool "Enable secure ChiMP firmware loading" + depends on OPTEE + default y + help + This driver is used to load bnxt firmware binary using OpTEE. + bnxt is Broadcom NetXtreme controller Ethernet card. diff --git a/drivers/tee/broadcom/Makefile b/drivers/tee/broadcom/Makefile new file mode 100644 index 0000000000..cb3cef16df --- /dev/null +++ b/drivers/tee/broadcom/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y += chimp_optee.o diff --git a/drivers/tee/broadcom/chimp_optee.c b/drivers/tee/broadcom/chimp_optee.c new file mode 100644 index 0000000000..37f9b094f7 --- /dev/null +++ b/drivers/tee/broadcom/chimp_optee.c @@ -0,0 +1,183 @@ +// SPDX-License-Identifier: BSD-2-Clause +/* + * Copyright 2020 Broadcom. + */ + +#include <common.h> +#include <tee.h> +#include <broadcom/chimp.h> + +#ifdef CONFIG_CHIMP_OPTEE + +#define CHMIP_BOOT_UUID { 0x6272636D, 0x2019, 0x0716, \ + { 0x42, 0x43, 0x4D, 0x5F, 0x53, 0x43, 0x48, 0x49 } } + +enum { + TEE_CHIMP_FASTBOOT = 0, + TEE_CHIMP_HEALTH_STATUS, + TEE_CHIMP_HANDSHAKE_STATUS, +} tee_chmip_cmd; + +struct bcm_chimp_data { + struct udevice *tee; + u32 session; +} chimp_data; + +static int get_open_session(struct bcm_chimp_data *b_data) +{ + const struct tee_optee_ta_uuid uuid = CHMIP_BOOT_UUID; + struct tee_open_session_arg arg; + struct udevice *tee = NULL; + int rc; + + tee = tee_find_device(NULL, NULL, NULL, NULL); + if (!tee) + return -ENODEV; + + memset(&arg, 0, sizeof(arg)); + tee_optee_ta_uuid_to_octets(arg.uuid, &uuid); + rc = tee_open_session(tee, &arg, 0, NULL); + if (rc < 0) + return -ENODEV; + + b_data->tee = tee; + b_data->session = arg.session; + + return 0; +} + +static int init_arg(struct tee_invoke_arg *arg, u32 func) +{ + if (get_open_session(&chimp_data)) + return -EINVAL; + + memset(arg, 0, sizeof(struct tee_invoke_arg)); + arg->func = func; + arg->session = chimp_data.session; + + return 0; +} + +int chimp_handshake_status_optee(u32 timeout, u32 *hs) +{ + struct tee_invoke_arg arg; + struct tee_param param[1]; + int ret; + + ret = init_arg(&arg, TEE_CHIMP_HANDSHAKE_STATUS); + if (ret < 0) + return ret; + + param[0].attr = TEE_PARAM_ATTR_TYPE_VALUE_INOUT; + param[0].u.value.a = timeout; + + ret = tee_invoke_func(chimp_data.tee, &arg, ARRAY_SIZE(param), param); + if (ret < 0) { + printf("Handshake status command failed\n"); + goto out; + } + + switch (arg.ret) { + case TEE_SUCCESS: + *hs = param[0].u.value.a; + ret = 0; + break; + default: + ret = -EINVAL; + break; + } + +out: + tee_close_session(chimp_data.tee, chimp_data.session); + chimp_data.tee = NULL; + + return ret; +} + +int chimp_health_status_optee(u32 *health) +{ + struct tee_invoke_arg arg; + struct tee_param param[1]; + int ret; + + ret = init_arg(&arg, TEE_CHIMP_HEALTH_STATUS); + if (ret < 0) + return ret; + + param[0].attr = TEE_PARAM_ATTR_TYPE_VALUE_OUTPUT; + + ret = tee_invoke_func(chimp_data.tee, &arg, ARRAY_SIZE(param), param); + if (ret < 0) { + printf("Helath status command failed\n"); + goto out; + } + + switch (arg.ret) { + case TEE_SUCCESS: + *health = param[0].u.value.a; + ret = 0; + break; + default: + ret = -EINVAL; + break; + } + +out: + tee_close_session(chimp_data.tee, chimp_data.session); + chimp_data.tee = NULL; + + return ret; +} + +int chimp_fastboot_optee(void) +{ + struct tee_invoke_arg arg; + int ret; + + ret = init_arg(&arg, TEE_CHIMP_FASTBOOT); + if (ret < 0) + return ret; + + ret = tee_invoke_func(chimp_data.tee, &arg, 0, NULL); + if (ret < 0) { + printf("Chimp boot_fail\n"); + goto out; + } + + switch (arg.ret) { + case TEE_SUCCESS: + ret = 0; + break; + default: + ret = -EINVAL; + break; + } + +out: + tee_close_session(chimp_data.tee, chimp_data.session); + chimp_data.tee = NULL; + + return ret; +} +#else +int chimp_handshake_status_optee(u32 timeout, u32 *status) +{ + printf("ChiMP handshake status fail (OPTEE not enabled)\n"); + + return -EINVAL; +} + +int chimp_health_status_optee(u32 *status) +{ + printf("ChiMP health status fail (OPTEE not enabled)\n"); + + return -EINVAL; +} + +int chimp_fastboot_optee(void) +{ + printf("ChiMP secure boot fail (OPTEE not enabled)\n"); + + return -EINVAL; +} +#endif /* CONFIG_CHIMP_OPTEE */ diff --git a/include/broadcom/chimp.h b/include/broadcom/chimp.h new file mode 100644 index 0000000000..7f64152913 --- /dev/null +++ b/include/broadcom/chimp.h @@ -0,0 +1,43 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2020 Broadcom. + * + */ + +#ifndef __CHIMP_H__ +#define __CHIMP_H__ + +#include <linux/compiler.h> + +/** + * chimp_fastboot_optee() - api to load bnxt firmware + * + * @return: 0 on success and -ve on failure + */ +int chimp_fastboot_optee(void); + +/** + * chimp_health_status_optee() - get chimp health status + * + * Chimp health status could be firmware is in good condition or + * bad condition because of crash/hang. + * + * @status: pointer to get chimp health status + * + * @return: 0 on success and -ve on failure + */ +int chimp_health_status_optee(u32 *status); + +/** + * chimp_handshake_status_optee() - get chimp handshake status. + * + * To know firmware is loaded and running. + * + * @timeout: timeout value, if 0 then default timeout is considered by op-tee + * @hstatus: pointer to chimp handshake status + * + * @return: 0 on success and -ve on failure + */ +int chimp_handshake_status_optee(u32 timeout, u32 *hstatus); + +#endif
Enable tee and optee drivers.
Signed-off-by: Vikas Gupta vikas.gupta@broadcom.com Signed-off-by: Rayagonda Kokatanur rayagonda.kokatanur@broadcom.com Reviewed-by: Simon Glass sjg@chromium.org --- configs/bcm_ns3_defconfig | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/configs/bcm_ns3_defconfig b/configs/bcm_ns3_defconfig index 0e078f3244..72015c6596 100644 --- a/configs/bcm_ns3_defconfig +++ b/configs/bcm_ns3_defconfig @@ -4,12 +4,12 @@ CONFIG_TARGET_BCMNS3=y CONFIG_SYS_TEXT_BASE=0xFF000000 CONFIG_ENV_SIZE=0x80000 CONFIG_NR_DRAM_BANKS=2 -CONFIG_OF_BOARD_SETUP=y CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_SIGNATURE_MAX_SIZE=0x20000000 CONFIG_FIT_VERBOSE=y CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_OF_BOARD_SETUP=y CONFIG_LOGLEVEL=7 CONFIG_SILENT_CONSOLE=y CONFIG_SILENT_U_BOOT_ONLY=y @@ -42,6 +42,9 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_SINGLE=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y +CONFIG_TEE=y +CONFIG_OPTEE=y +# CONFIG_OPTEE_TA_AVB is not set CONFIG_WDT=y CONFIG_WDT_SP805=y CONFIG_FAT_WRITE=y
Rayagonda Kokatanur
