[U-Boot-Users] [RFC][WIP] ePAPR boot and provide a mechanism to disable ft board setup
Is this something we'd be willing to put into mainline?
- k
diff --git a/lib_ppc/bootm.c b/lib_ppc/bootm.c index a872d31..3ebddd3 100644 --- a/lib_ppc/bootm.c +++ b/lib_ppc/bootm.c @@ -192,7 +192,8 @@ do_bootm_linux(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[], } #ifdef CONFIG_OF_BOARD_SETUP /* Call the board-specific fixup routine */ - ft_board_setup(of_flat_tree, gd->bd); + if (!getenv_yesno("disable_fdt_boardsetup")) + ft_board_setup(of_flat_tree, gd->bd); #endif }
@@ -821,3 +822,67 @@ error: return 1; } #endif + +/*******************************************************************/ +/* boote - boot ePAPR */ +/*******************************************************************/ +#if defined(CONFIG_CMD_BOOT_EPAPR) +int do_boot_epapr (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + void (*kernel)(ulong r3, ulong r4, ulong r5, ulong r6, + ulong r7, ulong r8, ulong r9); + ulong kern, of_flat_tree, epapr_magic; + + if (argc != 3) { + printf ("Usage:\n%s\n", cmdtp->usage); + return 1; + } + + kern = simple_strtoul (argv[1], NULL, 16); + of_flat_tree = simple_strtoul (argv[2], NULL, 16); + + if (kern & 0x3) { + printf ("kernel address 0x%lx is not 4-byte aligned\n", kern); + return 1; + } + + if (of_flat_tree & 0x7) { + printf ("Flat device tree address 0x%lx is not 8-byte aligned\n", of_flat_tree); + return 1; + } + + if (!getenv_yesno ("autostart")) + return 0; + + kernel = (void (*)(ulong, ulong, ulong, ulong, + ulong, ulong, ulong))kern; + + /* + * Linux Kernel Parameters (passing device tree): + * r3: pointer to the fdt + * r4: 0 + * r5: 0 + * r6: epapr magic + * r7: 0 + * r8: 0 + * r9: 0 + */ +#if defined(CONFIG_85xx) || defined(CONFIG_440) + epapr_magic = 0x45504150; +#else + epapr_magic = 0x65504150; +#endif + + debug (" Booting using OF flat tree...\n"); + (*kernel) (of_flat_tree, 0, 0, epapr_magic, 0, 0, 0); + /* does not return */ + + return 0; +} + +U_BOOT_CMD( + bootepapr, 3, 1, do_boot_epapr, + "bootepapr - boot according to ePAPR client interface\n", + "<entry point> <device tree address>\n" +); +#endif
In message Pine.LNX.4.64.0808051811060.6430@blarg.am.freescale.net you wrote:
Definitely not as is.
These are two unrelated changes, so please split this up into two separate patches so we can decide independently.
Kumar Gala
