[U-Boot] [PATCH 0/8] spi: Cleanup set
Cleanup set on spi_slave{}
Jagan Teki (8): spi: Remove SPI_OPM_RX_EXTN spi: Remove SPI_OPM_RX_DIO|QIOF spi: Rename SPI_OPM_RX_* to SPI_RX_* spi: Rename op_mode_rx to mode_rx spi: Move mode, mode_rx, flags macro's to structure spi: Fix bit assignment with flags spi: Use BIT macro spi: Minor cleanup
drivers/mtd/spi/spi_flash.c | 2 +- drivers/spi/ich.c | 2 +- drivers/spi/ti_qspi.c | 2 +- include/spi.h | 65 +++++++++++++++++++-------------------------- 4 files changed, 31 insertions(+), 40 deletions(-)
SPI_OPM_RX_EXTN is a combination of all rx opmode's and spi driver shall use any one of the rx mode at a time not the combination and it is true in case of flash where spi_flash_table mention combination of supported read opmodes so-that the required one will pick based on the rx mode from spi driver.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- include/spi.h | 3 --- 1 file changed, 3 deletions(-)
diff --git a/include/spi.h b/include/spi.h index b9a6e6f..bf2ed28 100644 --- a/include/spi.h +++ b/include/spi.h @@ -41,9 +41,6 @@ #define SPI_OPM_RX_DIO (1 << 3) #define SPI_OPM_RX_QOF (1 << 4) #define SPI_OPM_RX_QIOF (1 << 5) -#define SPI_OPM_RX_EXTN (SPI_OPM_RX_AS | SPI_OPM_RX_AF | SPI_OPM_RX_DOUT | \ - SPI_OPM_RX_DIO | SPI_OPM_RX_QOF | \ - SPI_OPM_RX_QIOF)
/* SPI bus connection options - see enum spi_dual_flash */ #define SPI_CONN_DUAL_SHARED (1 << 0)
Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com
SPI_OPM_RX_DIO and SPI_OPM_RX_QIOF are rx IO commands/opmodes for dual and quad. Usually IO operation's are referred to flash protocol rather with spi controller protocol, these are still present in flash side for the usage of spi-nor controllers.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- include/spi.h | 2 -- 1 file changed, 2 deletions(-)
diff --git a/include/spi.h b/include/spi.h index bf2ed28..3e3480a 100644 --- a/include/spi.h +++ b/include/spi.h @@ -38,9 +38,7 @@ #define SPI_OPM_RX_AS (1 << 0) #define SPI_OPM_RX_AF (1 << 1) #define SPI_OPM_RX_DOUT (1 << 2) -#define SPI_OPM_RX_DIO (1 << 3) #define SPI_OPM_RX_QOF (1 << 4) -#define SPI_OPM_RX_QIOF (1 << 5)
SPI_OPM_RX_AS - SPI_RX_SLOW SPI_OPM_RX_AF - SPI_RX_FAST SPI_OPM_RX_DOUT - SPI_RX_DUAL SPI_OPM_RX_QOF - SPI_RX_QUAD
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/spi/ich.c | 2 +- drivers/spi/ti_qspi.c | 2 +- include/spi.h | 8 ++++---- 3 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/spi/ich.c b/drivers/spi/ich.c index d11132c..7f41763 100644 --- a/drivers/spi/ich.c +++ b/drivers/spi/ich.c @@ -752,7 +752,7 @@ static int ich_spi_child_pre_probe(struct udevice *dev) * and byte program command for SST flash */ if (plat->ich_version == 7) { - slave->op_mode_rx = SPI_OPM_RX_AS; + slave->op_mode_rx = SPI_RX_SLOW; slave->mode = SPI_TX_BYTE; }
diff --git a/drivers/spi/ti_qspi.c b/drivers/spi/ti_qspi.c index 5747ed1..366243c 100644 --- a/drivers/spi/ti_qspi.c +++ b/drivers/spi/ti_qspi.c @@ -115,7 +115,7 @@ static void ti_spi_setup_spi_register(struct ti_qspi_slave *qslave) QSPI_SETUP0_NUM_D_BYTES_8_BITS | QSPI_SETUP0_READ_QUAD | QSPI_CMD_WRITE | QSPI_NUM_DUMMY_BITS); - slave->op_mode_rx = SPI_OPM_RX_QOF; + slave->op_mode_rx = SPI_RX_QUAD; #else memval |= QSPI_CMD_READ | QSPI_SETUP0_NUM_A_BYTES | QSPI_SETUP0_NUM_D_BYTES_NO_BITS | diff --git a/include/spi.h b/include/spi.h index 3e3480a..fd09502 100644 --- a/include/spi.h +++ b/include/spi.h @@ -35,10 +35,10 @@ #define SPI_XFER_U_PAGE (1 << 5)
/* SPI RX operation modes */ -#define SPI_OPM_RX_AS (1 << 0) -#define SPI_OPM_RX_AF (1 << 1) -#define SPI_OPM_RX_DOUT (1 << 2) -#define SPI_OPM_RX_QOF (1 << 4) +#define SPI_RX_SLOW (1 << 0) +#define SPI_RX_FAST (1 << 1) +#define SPI_RX_DUAL (1 << 2) +#define SPI_RX_QUAD (1 << 4)
Since spi rx mode macro's are renamed to simple and meaninfull in below patch, this patch will rename the respective structure member. "spi: Rename SPI_OPM_RX_* to SPI_RX_*" (sha1: 5e9ffbc5376616449beaaf2bc100f579f12291cf)
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/spi_flash.c | 2 +- drivers/spi/ich.c | 2 +- drivers/spi/ti_qspi.c | 2 +- include/spi.h | 4 ++-- 4 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 1ba6222..51f94a7 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1098,7 +1098,7 @@ int spi_flash_scan(struct spi_flash *flash) flash->sector_size = flash->erase_size;
/* Look for the fastest read cmd */ - cmd = fls(params->e_rd_cmd & spi->op_mode_rx); + cmd = fls(params->e_rd_cmd & spi->mode_rx); if (cmd) { cmd = spi_read_cmds_array[cmd - 1]; flash->read_cmd = cmd; diff --git a/drivers/spi/ich.c b/drivers/spi/ich.c index 7f41763..59eaaea 100644 --- a/drivers/spi/ich.c +++ b/drivers/spi/ich.c @@ -752,7 +752,7 @@ static int ich_spi_child_pre_probe(struct udevice *dev) * and byte program command for SST flash */ if (plat->ich_version == 7) { - slave->op_mode_rx = SPI_RX_SLOW; + slave->mode_rx = SPI_RX_SLOW; slave->mode = SPI_TX_BYTE; }
diff --git a/drivers/spi/ti_qspi.c b/drivers/spi/ti_qspi.c index 366243c..26616eb 100644 --- a/drivers/spi/ti_qspi.c +++ b/drivers/spi/ti_qspi.c @@ -115,7 +115,7 @@ static void ti_spi_setup_spi_register(struct ti_qspi_slave *qslave) QSPI_SETUP0_NUM_D_BYTES_8_BITS | QSPI_SETUP0_READ_QUAD | QSPI_CMD_WRITE | QSPI_NUM_DUMMY_BITS); - slave->op_mode_rx = SPI_RX_QUAD; + slave->mode_rx = SPI_RX_QUAD; #else memval |= QSPI_CMD_READ | QSPI_SETUP0_NUM_A_BYTES | QSPI_SETUP0_NUM_D_BYTES_NO_BITS | diff --git a/include/spi.h b/include/spi.h index fd09502..48a78dc 100644 --- a/include/spi.h +++ b/include/spi.h @@ -99,7 +99,7 @@ struct dm_spi_slave_platdata { * bus (bus->seq) so does not need to be stored * @cs: ID of the chip select connected to the slave. * @mode: SPI mode to use for this slave (see SPI mode flags) - * @op_mode_rx: SPI RX operation mode. + * @mode_rx: SPI RX mode to use for this slave * @wordlen: Size of SPI word in number of bits * @max_write_size: If non-zero, the maximum number of bytes which can * be written at once, excluding command bytes. @@ -117,7 +117,7 @@ struct spi_slave { unsigned int cs; #endif uint mode; - u8 op_mode_rx; + u8 mode_rx; unsigned int wordlen; unsigned int max_write_size; void *memory_map;
Hi Jagan,
I don't see this commit id in the origin/master. Can you please double check?
Other than that,
Regards, Bin
Hi Bin,
On 21 December 2015 at 11:58, Bin Meng bmeng.cn@gmail.com wrote:
Hi Jagan,
This sha1 is from 3/4 - OK I will skip this details on commit message looks confusing.
Other than that,
thanks!
Hi Jagan,
On Wed, Dec 23, 2015 at 2:36 PM, Jagan Teki jteki@openedev.com wrote:
Hi Bin,
Hi Jagan,
Unless the commit id is already in u-boot/master, I doubt your local commit id will become invalid when it merges to mainstream.
Regards, Bin
On 23 December 2015 at 12:53, Bin Meng bmeng.cn@gmail.com wrote:
Hi Jagan,
Hi Bin,
Hi Jagan,
OK, I will remove the commit id while applying.
thanks!
This patch moves mode, mode_rx, flags macro's to respective member position on spi_slave{}, for better readabilty and finding the respective member macro's easily.
This patch fix's the tab space on mode macro's as well.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- include/spi.h | 56 ++++++++++++++++++++++++++------------------------------ 1 file changed, 26 insertions(+), 30 deletions(-)
diff --git a/include/spi.h b/include/spi.h index 48a78dc..9e1fe3f 100644 --- a/include/spi.h +++ b/include/spi.h @@ -10,36 +10,6 @@ #ifndef _SPI_H_ #define _SPI_H_
-/* SPI mode flags */ -#define SPI_CPHA 0x01 /* clock phase */ -#define SPI_CPOL 0x02 /* clock polarity */ -#define SPI_MODE_0 (0|0) /* (original MicroWire) */ -#define SPI_MODE_1 (0|SPI_CPHA) -#define SPI_MODE_2 (SPI_CPOL|0) -#define SPI_MODE_3 (SPI_CPOL|SPI_CPHA) -#define SPI_CS_HIGH 0x04 /* CS active high */ -#define SPI_LSB_FIRST 0x08 /* per-word bits-on-wire */ -#define SPI_3WIRE 0x10 /* SI/SO signals shared */ -#define SPI_LOOP 0x20 /* loopback mode */ -#define SPI_SLAVE 0x40 /* slave mode */ -#define SPI_PREAMBLE 0x80 /* Skip preamble bytes */ -#define SPI_TX_BYTE 0x100 /* transmit with 1 wire byte */ -#define SPI_TX_QUAD 0x200 /* transmit with 4 wires */ - -/* SPI transfer flags */ -#define SPI_XFER_BEGIN 0x01 /* Assert CS before transfer */ -#define SPI_XFER_END 0x02 /* Deassert CS after transfer */ -#define SPI_XFER_MMAP 0x08 /* Memory Mapped start */ -#define SPI_XFER_MMAP_END 0x10 /* Memory Mapped End */ -#define SPI_XFER_ONCE (SPI_XFER_BEGIN | SPI_XFER_END) -#define SPI_XFER_U_PAGE (1 << 5) - -/* SPI RX operation modes */ -#define SPI_RX_SLOW (1 << 0) -#define SPI_RX_FAST (1 << 1) -#define SPI_RX_DUAL (1 << 2) -#define SPI_RX_QUAD (1 << 4) - /* SPI bus connection options - see enum spi_dual_flash */ #define SPI_CONN_DUAL_SHARED (1 << 0) #define SPI_CONN_DUAL_SEPARATED (1 << 1) @@ -117,12 +87,38 @@ struct spi_slave { unsigned int cs; #endif uint mode; +#define SPI_CPHA 0x01 /* clock phase */ +#define SPI_CPOL 0x02 /* clock polarity */ +#define SPI_MODE_0 (0|0) /* (original MicroWire) */ +#define SPI_MODE_1 (0|SPI_CPHA) +#define SPI_MODE_2 (SPI_CPOL|0) +#define SPI_MODE_3 (SPI_CPOL|SPI_CPHA) +#define SPI_CS_HIGH 0x04 /* CS active high */ +#define SPI_LSB_FIRST 0x08 /* per-word bits-on-wire */ +#define SPI_3WIRE 0x10 /* SI/SO signals shared */ +#define SPI_LOOP 0x20 /* loopback mode */ +#define SPI_SLAVE 0x40 /* slave mode */ +#define SPI_PREAMBLE 0x80 /* Skip preamble bytes */ +#define SPI_TX_BYTE 0x100 /* transmit with 1 wire byte */ +#define SPI_TX_QUAD 0x200 /* transmit with 4 wires */ u8 mode_rx; +#define SPI_RX_SLOW (1 << 0) +#define SPI_RX_FAST (1 << 1) +#define SPI_RX_DUAL (1 << 2) +#define SPI_RX_QUAD (1 << 4) + unsigned int wordlen; unsigned int max_write_size; void *memory_map; u8 option; + u8 flags; +#define SPI_XFER_BEGIN 0x01 /* Assert CS before transfer */ +#define SPI_XFER_END 0x02 /* Deassert CS after transfer */ +#define SPI_XFER_MMAP 0x08 /* Memory Mapped start */ +#define SPI_XFER_MMAP_END 0x10 /* Memory Mapped End */ +#define SPI_XFER_ONCE (SPI_XFER_BEGIN | SPI_XFER_END) +#define SPI_XFER_U_PAGE (1 << 5) };
Hi Jagan,
I am not in favor of mixing macros along with the structure members. This looks to me not clearer than before. Do we have some guideline anywhere?
Regards, Bin
Hi Bin,
On 21 December 2015 at 11:18, Bin Meng bmeng.cn@gmail.com wrote:
Hi Jagan,
Looks better readable and easily find the respective member macro's ie the reason I have placed and I took the idea from Linux SPI core.
thanks!
Fixed bit assignment with flags members on spi_slave{}
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- include/spi.h | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/spi.h b/include/spi.h index 9e1fe3f..526e870 100644 --- a/include/spi.h +++ b/include/spi.h @@ -115,10 +115,10 @@ struct spi_slave { u8 flags; #define SPI_XFER_BEGIN 0x01 /* Assert CS before transfer */ #define SPI_XFER_END 0x02 /* Deassert CS after transfer */ -#define SPI_XFER_MMAP 0x08 /* Memory Mapped start */ -#define SPI_XFER_MMAP_END 0x10 /* Memory Mapped End */ #define SPI_XFER_ONCE (SPI_XFER_BEGIN | SPI_XFER_END) -#define SPI_XFER_U_PAGE (1 << 5) +#define SPI_XFER_MMAP 0x04 /* Memory Mapped start */ +#define SPI_XFER_MMAP_END 0x08 /* Memory Mapped End */ +#define SPI_XFER_U_PAGE 0x10 };
Used BIT macro like 1 << nr as BIT(nr) where nr is 0...n
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- include/spi.h | 38 +++++++++++++++++++------------------- 1 file changed, 19 insertions(+), 19 deletions(-)
diff --git a/include/spi.h b/include/spi.h index 526e870..ca1ea3b 100644 --- a/include/spi.h +++ b/include/spi.h @@ -87,25 +87,25 @@ struct spi_slave { unsigned int cs; #endif uint mode; -#define SPI_CPHA 0x01 /* clock phase */ -#define SPI_CPOL 0x02 /* clock polarity */ +#define SPI_CPHA BIT(0) /* clock phase */ +#define SPI_CPOL BIT(1) /* clock polarity */ #define SPI_MODE_0 (0|0) /* (original MicroWire) */ #define SPI_MODE_1 (0|SPI_CPHA) #define SPI_MODE_2 (SPI_CPOL|0) #define SPI_MODE_3 (SPI_CPOL|SPI_CPHA) -#define SPI_CS_HIGH 0x04 /* CS active high */ -#define SPI_LSB_FIRST 0x08 /* per-word bits-on-wire */ -#define SPI_3WIRE 0x10 /* SI/SO signals shared */ -#define SPI_LOOP 0x20 /* loopback mode */ -#define SPI_SLAVE 0x40 /* slave mode */ -#define SPI_PREAMBLE 0x80 /* Skip preamble bytes */ -#define SPI_TX_BYTE 0x100 /* transmit with 1 wire byte */ -#define SPI_TX_QUAD 0x200 /* transmit with 4 wires */ +#define SPI_CS_HIGH BIT(2) /* CS active high */ +#define SPI_LSB_FIRST BIT(3) /* per-word bits-on-wire */ +#define SPI_3WIRE BIT(4) /* SI/SO signals shared */ +#define SPI_LOOP BIT(5) /* loopback mode */ +#define SPI_SLAVE BIT(6) /* slave mode */ +#define SPI_PREAMBLE BIT(7) /* Skip preamble bytes */ +#define SPI_TX_BYTE BIT(8) /* transmit with 1 wire byte */ +#define SPI_TX_QUAD BIT(9) /* transmit with 4 wires */ u8 mode_rx; -#define SPI_RX_SLOW (1 << 0) -#define SPI_RX_FAST (1 << 1) -#define SPI_RX_DUAL (1 << 2) -#define SPI_RX_QUAD (1 << 4) +#define SPI_RX_SLOW BIT(0) +#define SPI_RX_FAST BIT(1) +#define SPI_RX_DUAL BIT(2) +#define SPI_RX_QUAD BIT(4)
unsigned int wordlen; unsigned int max_write_size; @@ -113,12 +113,12 @@ struct spi_slave { u8 option;
u8 flags; -#define SPI_XFER_BEGIN 0x01 /* Assert CS before transfer */ -#define SPI_XFER_END 0x02 /* Deassert CS after transfer */ +#define SPI_XFER_BEGIN BIT(0) /* Assert CS before transfer */ +#define SPI_XFER_END BIT(1) /* Deassert CS after transfer */ #define SPI_XFER_ONCE (SPI_XFER_BEGIN | SPI_XFER_END) -#define SPI_XFER_MMAP 0x04 /* Memory Mapped start */ -#define SPI_XFER_MMAP_END 0x08 /* Memory Mapped End */ -#define SPI_XFER_U_PAGE 0x10 +#define SPI_XFER_MMAP BIT(2) /* Memory Mapped start */ +#define SPI_XFER_MMAP_END BIT(3) /* Memory Mapped End */ +#define SPI_XFER_U_PAGE BIT(4) };
- Add comments on mode_rx - Tab space's
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jteki@openedev.com --- include/spi.h | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/include/spi.h b/include/spi.h index ca1ea3b..803fb40 100644 --- a/include/spi.h +++ b/include/spi.h @@ -102,10 +102,10 @@ struct spi_slave { #define SPI_TX_BYTE BIT(8) /* transmit with 1 wire byte */ #define SPI_TX_QUAD BIT(9) /* transmit with 4 wires */ u8 mode_rx; -#define SPI_RX_SLOW BIT(0) -#define SPI_RX_FAST BIT(1) -#define SPI_RX_DUAL BIT(2) -#define SPI_RX_QUAD BIT(4) +#define SPI_RX_SLOW BIT(0) /* receive with 1 wire slow */ +#define SPI_RX_FAST BIT(1) /* receive with 1 wire fast */ +#define SPI_RX_DUAL BIT(2) /* receive with 2 wires */ +#define SPI_RX_QUAD BIT(4) /* receive with 4 wires */
unsigned int wordlen; unsigned int max_write_size; @@ -113,11 +113,11 @@ struct spi_slave { u8 option;
u8 flags; -#define SPI_XFER_BEGIN BIT(0) /* Assert CS before transfer */ -#define SPI_XFER_END BIT(1) /* Deassert CS after transfer */ +#define SPI_XFER_BEGIN BIT(0) /* Assert CS before transfer */ +#define SPI_XFER_END BIT(1) /* Deassert CS after transfer */ #define SPI_XFER_ONCE (SPI_XFER_BEGIN | SPI_XFER_END) -#define SPI_XFER_MMAP BIT(2) /* Memory Mapped start */ -#define SPI_XFER_MMAP_END BIT(3) /* Memory Mapped End */ +#define SPI_XFER_MMAP BIT(2) /* Memory Mapped start */ +#define SPI_XFER_MMAP_END BIT(3) /* Memory Mapped End */ #define SPI_XFER_U_PAGE BIT(4) };
- Tab space's
Tested-by: Jagan Teki jteki@openedev.com
thanks!
Hi Bin,
Any chance to look at these?
thanks!
Hi Jagan,
On Thu, Dec 17, 2015 at 3:15 PM, Jagan Teki jteki@openedev.com wrote:
Hi Bin,
Yes, I will find some time to look at this series and give a test.
Regards, Bin
Tested the series on AM437x SK and DRA74 EVM.
Tested-by: Mugunthan V N mugunthanvnm@ti.com
Regards Mugunthan V N
Bin Meng
Jagan Teki
Mugunthan V N
