[PATCH 1/5] ARM: board: warp: Import dts files
Import the i.MX6 based Warp dts files from Linux 5.12-rc1.
Signed-off-by: Peter Robinson pbrobinson@gmail.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/dts/Makefile | 4 +- arch/arm/dts/imx6sl-warp.dts | 234 +++++++++++++++++++++++++++++++++++ 2 files changed, 237 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx6sl-warp.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 116f75192f..1481a6ec46 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -734,7 +734,9 @@ dtb-y += \
endif
-dtb-$(CONFIG_MX6SL) += imx6sl-evk.dtb +dtb-$(CONFIG_MX6SL) += \ + imx6sl-evk.dtb \ + imx6sl-warp.dtb
dtb-$(CONFIG_MX6SLL) += imx6sll-evk.dtb
diff --git a/arch/arm/dts/imx6sl-warp.dts b/arch/arm/dts/imx6sl-warp.dts new file mode 100644 index 0000000000..9d7c888489 --- /dev/null +++ b/arch/arm/dts/imx6sl-warp.dts @@ -0,0 +1,234 @@ +/* + * Copyright 2014, 2015 O.S. Systems Software LTDA. + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public + * License along with this file; if not, write to the Free + * Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, + * MA 02110-1301 USA + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; + +#include <dt-bindings/gpio/gpio.h> +#include "imx6sl.dtsi" + +/ { + model = "Revotics WaRP Board"; + compatible = "revotics,imx6sl-warp", "fsl,imx6sl"; + + memory@80000000 { + device_type = "memory"; + reg = <0x80000000 0x20000000>; + }; + + usdhc3_pwrseq: usdhc3_pwrseq { + compatible = "mmc-pwrseq-simple"; + reset-gpios = <&gpio4 5 GPIO_ACTIVE_LOW>, /* WL_REG_ON */ + <&gpio4 7 GPIO_ACTIVE_LOW>, /* WL_HOSTWAKE */ + <&gpio3 25 GPIO_ACTIVE_LOW>, /* BT_REG_ON */ + <&gpio3 27 GPIO_ACTIVE_LOW>, /* BT_HOSTWAKE */ + <&gpio4 4 GPIO_ACTIVE_LOW>, /* BT_WAKE */ + <&gpio4 6 GPIO_ACTIVE_LOW>; /* BT_RST_N */ + }; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1>; + status = "okay"; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart3>; + status = "okay"; +}; + +&uart5 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart5>; + uart-has-rtscts; + status = "okay"; +}; + +&usbotg1 { + dr_mode = "peripheral"; + disable-over-current; + status = "okay"; +}; + +&usbotg2 { + dr_mode = "host"; + disable-over-current; + status = "okay"; +}; + +&usdhc2 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc2>; + pinctrl-1 = <&pinctrl_usdhc2_100mhz>; + pinctrl-2 = <&pinctrl_usdhc2_200mhz>; + bus-width = <8>; + non-removable; + status = "okay"; +}; + +&usdhc3 { + pinctrl-names = "default", "state_100mhz", "state_200mhz"; + pinctrl-0 = <&pinctrl_usdhc3>; + pinctrl-1 = <&pinctrl_usdhc3_100mhz>; + pinctrl-2 = <&pinctrl_usdhc3_200mhz>; + bus-width = <4>; + non-removable; + keep-power-in-suspend; + wakeup-source; + mmc-pwrseq = <&usdhc3_pwrseq>; + status = "okay"; +}; + +&iomuxc { + imx6sl-warp { + pinctrl_uart1: uart1grp { + fsl,pins = < + MX6SL_PAD_UART1_RXD__UART1_RX_DATA 0x41b0b1 + MX6SL_PAD_UART1_TXD__UART1_TX_DATA 0x41b0b1 + >; + }; + + + pinctrl_uart3: uart3grp { + fsl,pins = < + MX6SL_PAD_AUD_RXC__UART3_RX_DATA 0x41b0b1 + MX6SL_PAD_AUD_RXC__UART3_TX_DATA 0x41b0b1 + >; + }; + + pinctrl_uart5: uart5grp { + fsl,pins = < + MX6SL_PAD_ECSPI1_SCLK__UART5_RX_DATA 0x41b0b1 + MX6SL_PAD_ECSPI1_MOSI__UART5_TX_DATA 0x41b0b1 + MX6SL_PAD_ECSPI1_MISO__UART5_RTS_B 0x4130b1 + MX6SL_PAD_ECSPI1_SS0__UART5_CTS_B 0x4130b1 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX6SL_PAD_SD2_CMD__SD2_CMD 0x417059 + MX6SL_PAD_SD2_CLK__SD2_CLK 0x410059 + MX6SL_PAD_SD2_DAT0__SD2_DATA0 0x417059 + MX6SL_PAD_SD2_DAT1__SD2_DATA1 0x417059 + MX6SL_PAD_SD2_DAT2__SD2_DATA2 0x417059 + MX6SL_PAD_SD2_DAT3__SD2_DATA3 0x417059 + MX6SL_PAD_SD2_DAT4__SD2_DATA4 0x417059 + MX6SL_PAD_SD2_DAT5__SD2_DATA5 0x417059 + MX6SL_PAD_SD2_DAT6__SD2_DATA6 0x417059 + MX6SL_PAD_SD2_DAT7__SD2_DATA7 0x417059 + MX6SL_PAD_SD2_RST__SD2_RESET 0x417059 + >; + }; + + pinctrl_usdhc2_100mhz: usdhc2grp100mhz { + fsl,pins = < + MX6SL_PAD_SD2_CMD__SD2_CMD 0x4170b9 + MX6SL_PAD_SD2_CLK__SD2_CLK 0x4100b9 + MX6SL_PAD_SD2_DAT0__SD2_DATA0 0x4170b9 + MX6SL_PAD_SD2_DAT1__SD2_DATA1 0x4170b9 + MX6SL_PAD_SD2_DAT2__SD2_DATA2 0x4170b9 + MX6SL_PAD_SD2_DAT3__SD2_DATA3 0x4170b9 + MX6SL_PAD_SD2_DAT4__SD2_DATA4 0x4170b9 + MX6SL_PAD_SD2_DAT5__SD2_DATA5 0x4170b9 + MX6SL_PAD_SD2_DAT6__SD2_DATA6 0x4170b9 + MX6SL_PAD_SD2_DAT7__SD2_DATA7 0x4170b9 + MX6SL_PAD_SD2_RST__SD2_RESET 0x4170b9 + >; + }; + + pinctrl_usdhc2_200mhz: usdhc2grp200mhz { + fsl,pins = < + MX6SL_PAD_SD2_CMD__SD2_CMD 0x4170f9 + MX6SL_PAD_SD2_CLK__SD2_CLK 0x4100f9 + MX6SL_PAD_SD2_DAT0__SD2_DATA0 0x4170f9 + MX6SL_PAD_SD2_DAT1__SD2_DATA1 0x4170f9 + MX6SL_PAD_SD2_DAT2__SD2_DATA2 0x4170f9 + MX6SL_PAD_SD2_DAT3__SD2_DATA3 0x4170f9 + MX6SL_PAD_SD2_DAT4__SD2_DATA4 0x4170f9 + MX6SL_PAD_SD2_DAT5__SD2_DATA5 0x4170f9 + MX6SL_PAD_SD2_DAT6__SD2_DATA6 0x4170f9 + MX6SL_PAD_SD2_DAT7__SD2_DATA7 0x4170f9 + MX6SL_PAD_SD2_RST__SD2_RESET 0x4170f9 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX6SL_PAD_SD3_CMD__SD3_CMD 0x417059 + MX6SL_PAD_SD3_CLK__SD3_CLK 0x410059 + MX6SL_PAD_SD3_DAT0__SD3_DATA0 0x417059 + MX6SL_PAD_SD3_DAT1__SD3_DATA1 0x417059 + MX6SL_PAD_SD3_DAT2__SD3_DATA2 0x417059 + MX6SL_PAD_SD3_DAT3__SD3_DATA3 0x417059 + >; + }; + + pinctrl_usdhc3_100mhz: usdhc3grp100mhz { + fsl,pins = < + MX6SL_PAD_SD3_CMD__SD3_CMD 0x4170b9 + MX6SL_PAD_SD3_CLK__SD3_CLK 0x4100b9 + MX6SL_PAD_SD3_DAT0__SD3_DATA0 0x4170b9 + MX6SL_PAD_SD3_DAT1__SD3_DATA1 0x4170b9 + MX6SL_PAD_SD3_DAT2__SD3_DATA2 0x4170b9 + MX6SL_PAD_SD3_DAT3__SD3_DATA3 0x4170b9 + >; + }; + + pinctrl_usdhc3_200mhz: usdhc3grp200mhz { + fsl,pins = < + MX6SL_PAD_SD3_CMD__SD3_CMD 0x4170f9 + MX6SL_PAD_SD3_CLK__SD3_CLK 0x4100f9 + MX6SL_PAD_SD3_DAT0__SD3_DATA0 0x4170f9 + MX6SL_PAD_SD3_DAT1__SD3_DATA1 0x4170f9 + MX6SL_PAD_SD3_DAT2__SD3_DATA2 0x4170f9 + MX6SL_PAD_SD3_DAT3__SD3_DATA3 0x4170f9 + >; + }; + }; +};
Enable OF_CONTROL and DM for gpio and pin control support on the i.MX6SL based Warp.
Signed-off-by: Peter Robinson pbrobinson@gmail.com Cc: Otavio Salvador otavio@ossystems.com.br Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- configs/warp_defconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/configs/warp_defconfig b/configs/warp_defconfig index 34acc9e6c8..68ad71c27c 100644 --- a/configs/warp_defconfig +++ b/configs/warp_defconfig @@ -2,10 +2,12 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_SYS_TEXT_BASE=0x87800000 CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEFAULT_DEVICE_TREE="imx6sl-warp" CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x60000 CONFIG_MX6SL=y CONFIG_TARGET_WARP=y +CONFIG_OF_CONTROL=y # CONFIG_CMD_BMODE is not set CONFIG_SUPPORT_RAW_INITRD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/warp/imximage.cfg" @@ -18,6 +20,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y +# CONFIG_CMD_PINMUX is not set CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set @@ -32,9 +35,13 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_NET is not set CONFIG_BOUNCE_BUFFER=y +CONFIG_DM=y +CONFIG_DM_GPIO=y CONFIG_DFU_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y CONFIG_MXC_UART=y CONFIG_USB=y CONFIG_USB_STORAGE=y
Enable OF_CONTROL and DM for gpio and pin control support on the i.MX6SL based Warp. Signed-off-by: Peter Robinson pbrobinson@gmail.com Cc: Otavio Salvador otavio@ossystems.com.br Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Convert Warp to use DM MMC.
Signed-off-by: Peter Robinson pbrobinson@gmail.com Cc: Otavio Salvador otavio@ossystems.com.br Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/dts/imx6sl-warp-u-boot.dtsi | 7 ++++++ board/warp/warp.c | 33 ---------------------------- configs/warp_defconfig | 1 + 3 files changed, 8 insertions(+), 33 deletions(-) create mode 100644 arch/arm/dts/imx6sl-warp-u-boot.dtsi
diff --git a/arch/arm/dts/imx6sl-warp-u-boot.dtsi b/arch/arm/dts/imx6sl-warp-u-boot.dtsi new file mode 100644 index 0000000000..daf2489cfd --- /dev/null +++ b/arch/arm/dts/imx6sl-warp-u-boot.dtsi @@ -0,0 +1,7 @@ +// SPDX-License-Identifier: GPL-2.0+ + +/ { + aliases { + mmc0 = &usdhc2; + }; +}; diff --git a/board/warp/warp.c b/board/warp/warp.c index 0f1d038fab..417f0e7507 100644 --- a/board/warp/warp.c +++ b/board/warp/warp.c @@ -21,9 +21,7 @@ #include <linux/sizes.h> #include <common.h> #include <watchdog.h> -#include <fsl_esdhc_imx.h> #include <i2c.h> -#include <mmc.h> #include <usb.h> #include <power/pmic.h> #include <power/max77696_pmic.h> @@ -62,37 +60,6 @@ static void setup_iomux_uart(void) imx_iomux_v3_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); }
-static struct fsl_esdhc_cfg usdhc_cfg[1] = { - {USDHC2_BASE_ADDR, 0, 0, 0, 1}, -}; - -int board_mmc_getcd(struct mmc *mmc) -{ - return 1; /* Assume boot SD always present */ -} - -int board_mmc_init(struct bd_info *bis) -{ - static iomux_v3_cfg_t const usdhc2_pads[] = { - MX6_PAD_SD2_CLK__USDHC2_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_CMD__USDHC2_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_RST__USDHC2_RST | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT0__USDHC2_DAT0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT1__USDHC2_DAT1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT2__USDHC2_DAT2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT3__USDHC2_DAT3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT4__USDHC2_DAT4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT5__USDHC2_DAT5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT6__USDHC2_DAT6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD2_DAT7__USDHC2_DAT7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - }; - - imx_iomux_v3_setup_multiple_pads(usdhc2_pads, ARRAY_SIZE(usdhc2_pads)); - - usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); - return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); -} - int board_usb_phy_mode(int port) { return USB_INIT_DEVICE; diff --git a/configs/warp_defconfig b/configs/warp_defconfig index 68ad71c27c..6efe400dd1 100644 --- a/configs/warp_defconfig +++ b/configs/warp_defconfig @@ -39,6 +39,7 @@ CONFIG_DM=y CONFIG_DM_GPIO=y CONFIG_DFU_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y +CONFIG_DM_MMC=y CONFIG_FSL_USDHC=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
- aliases {
mmc0 = &usdhc2;
Convert Warp to use DM MMC. Signed-off-by: Peter Robinson pbrobinson@gmail.com Cc: Otavio Salvador otavio@ossystems.com.br Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Convert Warp to use DM USB.
Signed-off-by: Peter Robinson pbrobinson@gmail.com Cc: Otavio Salvador otavio@ossystems.com.br Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- configs/warp_defconfig | 1 + include/configs/warp.h | 1 - 2 files changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/warp_defconfig b/configs/warp_defconfig index 6efe400dd1..223436c86e 100644 --- a/configs/warp_defconfig +++ b/configs/warp_defconfig @@ -45,6 +45,7 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_MXC_UART=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="FSL" diff --git a/include/configs/warp.h b/include/configs/warp.h index f17eea117f..8cde52f634 100644 --- a/include/configs/warp.h +++ b/include/configs/warp.h @@ -45,7 +45,6 @@ #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_MXC_USB_PORTSC (PORT_PTS_UTMI | PORT_PTS_PTW) #define CONFIG_MXC_USB_FLAGS 0 -#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 /* Only OTG2 port enabled */ #endif
#define CONFIG_USBD_HS
Hi Peter,
I get warnings after applying this series:
arm: + warp7 +(warp7) board/warp7/warp7.c: In function 'board_eth_init': +(warp7) board/warp7/warp7.c:94:8: error: implicit declaration of function 'usb_eth_initialize'; did you mean 'sh_eth_initialize'? [-Werror=implicit-function-declaration] +(warp7) 94 | ret = usb_eth_initialize(bis); +(warp7) | ^~~~~~~~~~~~~~~~~~ +(warp7) | sh_eth_initialize
Same for warp7_bl33. Can you check, please ? Thanks !
Convert Warp to use DM USB. Signed-off-by: Peter Robinson pbrobinson@gmail.com Cc: Otavio Salvador otavio@ossystems.com.br Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de
We don't need a random MAC as the only network that's supported is over USB and that has a hardcoded MAC, enable DM_ETH for the USB, and the device doesn't have MTD storage so drop that.
Signed-off-by: Peter Robinson pbrobinson@gmail.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de --- configs/warp7_bl33_defconfig | 3 +-- configs/warp7_defconfig | 3 +-- 2 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/configs/warp7_bl33_defconfig b/configs/warp7_bl33_defconfig index 4b45fcd50a..98d370754a 100644 --- a/configs/warp7_bl33_defconfig +++ b/configs/warp7_bl33_defconfig @@ -32,14 +32,13 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y CONFIG_BOUNCE_BUFFER=y CONFIG_DFU_MMC=y +CONFIG_DM_ETH=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y -CONFIG_MTD=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y CONFIG_DM_PMIC=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index 3d11196080..8fa1981207 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -38,14 +38,13 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_NET_RANDOM_ETHADDR=y CONFIG_BOUNCE_BUFFER=y CONFIG_DFU_MMC=y +CONFIG_DM_ETH=y CONFIG_DM_I2C=y CONFIG_DM_MMC=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y -CONFIG_MTD=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX7=y CONFIG_DM_PMIC=y
We don't need a random MAC as the only network that's supported is over USB and that has a hardcoded MAC, enable DM_ETH for the USB, and the device doesn't have MTD storage so drop that. Signed-off-by: Peter Robinson pbrobinson@gmail.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de
Hi Peter,
series was lost, sorry.
I have picked them up and rebased on current master. Anyway, build fails (warning) due to
+board/warp7/warp7.c: In function 'board_eth_init': +board/warp7/warp7.c:94:15: error: implicit declaration of function 'usb_eth_initialize'; did you mean 'sh_eth_initialize'? [-Werror=implicit-function-declaration] + 94 | ret = usb_eth_initialize(bis); + | ^~~~~~~~~~~~~~~~~~
But as board already switched to CONFIG_DM_USB and CONFIG_DM_ETH, do we still need to call this function ?
For the series:
Reviewed-by: Fabio Estevam festevam@gmail.com
Import the i.MX6 based Warp dts files from Linux 5.12-rc1. Signed-off-by: Peter Robinson pbrobinson@gmail.com Cc: Fabio Estevam fabio.estevam@nxp.com Cc: Stefano Babic sbabic@denx.de Reviewed-by: Fabio Estevam festevam@gmail.com
participants (5)
Fabio Estevam
Jaehoon Chung
Peter Robinson
sbabic@denx.de
Stefano Babic
