[U-Boot] [PATCH v4] arm: cache: always flush cache line size for page table
The page table is maintained by the CPU, hence it is safe to always align cache flush to a whole cache line size. This allows to use mmu_page_table_flush for a single page table, e.g. when configure only small regions through mmu_set_region_dcache_behaviour.
Signed-off-by: Stefan Agner stefan.agner@toradex.com Tested-by: Fabio Estevam fabio.estevam@nxp.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v4: - Fixed spelling misstake for real
Changes in v3: - Fixed spelling misstake
Changes in v2: - Move cache line alignment from mmu_page_table_flush to mmu_set_region_dcache_behaviour
arch/arm/lib/cache-cp15.c | 13 ++++++++++++- 1 file changed, 12 insertions(+), 1 deletion(-)
diff --git a/arch/arm/lib/cache-cp15.c b/arch/arm/lib/cache-cp15.c index 1121dc3..488094e 100644 --- a/arch/arm/lib/cache-cp15.c +++ b/arch/arm/lib/cache-cp15.c @@ -62,6 +62,7 @@ void mmu_set_region_dcache_behaviour(phys_addr_t start, size_t size, enum dcache_option option) { u32 *page_table = (u32 *)gd->arch.tlb_addr; + phys_addr_t startpt, stoppt; unsigned long upto, end;
end = ALIGN(start + size, MMU_SECTION_SIZE) >> MMU_SECTION_SHIFT; @@ -70,7 +71,17 @@ void mmu_set_region_dcache_behaviour(phys_addr_t start, size_t size, option); for (upto = start; upto < end; upto++) set_section_dcache(upto, option); - mmu_page_table_flush((u32)&page_table[start], (u32)&page_table[end]); + + /* + * Make sure range is cache line aligned + * Only CPU maintains page tables, hence it is safe to always + * flush complete cache lines... + */ + startpt = (phys_addr_t)&page_table[start]; + startpt &= ~(CONFIG_SYS_CACHELINE_SIZE - 1); + stoppt = (phys_addr_t)&page_table[end]; + stoppt = ALIGN(stoppt, CONFIG_SYS_CACHELINE_SIZE); + mmu_page_table_flush(startpt, stoppt); }
__weak void dram_bank_mmu_setup(int bank)
Hello Stefan,
Am 07.08.2016 um 19:43 schrieb Stefan Agner:
Changes in v4:
Changes in v3:
Changes in v2:
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
I get the following warning when CONFIG_PHYS_64BIT is enabled on arm platforms(dra7xx_evm_defconfig):
arch/arm/lib/cache-cp15.c: In function 'mmu_set_region_dcache_behaviour': arch/arm/lib/cache-cp15.c:80:12: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] startpt = (phys_addr_t)&page_table[start]; ^ arch/arm/lib/cache-cp15.c:82:11: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] stoppt = (phys_addr_t)&page_table[end]; ^ arch/arm/lib/cache-cp15.c: In function 'mmu_set_region_dcache_behaviour': arch/arm/lib/cache-cp15.c:80:12: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] startpt = (phys_addr_t)&page_table[start]; ^ arch/arm/lib/cache-cp15.c:82:11: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast] stoppt = (phys_addr_t)&page_table[end];
Thanks and regards, Lokesh
Changes in v4:
Changes in v3:
Changes in v2:
- startpt = (phys_addr_t)&page_table[start];
- startpt &= ~(CONFIG_SYS_CACHELINE_SIZE - 1);
- stoppt = (phys_addr_t)&page_table[end];
- stoppt = ALIGN(stoppt, CONFIG_SYS_CACHELINE_SIZE);
- mmu_page_table_flush(startpt, stoppt);
Hm, do I see things right, this is otherwise a 32-bit architecture? Does that work without LPAE? What is the page table size in this case?
Hm, maybe we should keep using unsigned long then inside this function. Added Thierry to CC since he introduced phys_addr_t to the function signature.
-- Stefan
Changes in v4:
Changes in v3:
Changes in v2:
It's a 32bit architecture with LPAE, iirc, yes.
Hm, when looking at other functions such as set_section_dcache, page_table is casted to a u64* type, hence I guess this is wrong in mmu_set_region_dcache_behaviour. In fact, that makes it seem unsafe to use this function as is...
-- Stefan
Heiko Schocher
Lokesh Vutla
Stefan Agner
