[PATCH] arm: mvebu: Enable gpio-fan for Thecus N2350 board
Add gpio-fan in the DTS and enable the GPIO in board file to start the fan during boot.
Note that this patch depends on https://patchwork.ozlabs.org/project/uboot/patch/20230606214539.4229-1-mibod...
Signed-off-by: Tony Dinh mibodhi@gmail.com ---
arch/arm/dts/armada-385-thecus-n2350.dts | 15 +++++++++++++++ board/thecus/n2350/n2350.c | 2 +- 2 files changed, 16 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/armada-385-thecus-n2350.dts b/arch/arm/dts/armada-385-thecus-n2350.dts index 2ad5158c0c..253cf01130 100644 --- a/arch/arm/dts/armada-385-thecus-n2350.dts +++ b/arch/arm/dts/armada-385-thecus-n2350.dts @@ -140,6 +140,16 @@ }; };
+ fan { + compatible = "gpio-fan"; + gpios = <&gpio1 16 GPIO_ACTIVE_HIGH>; + gpio-fan,speed-map = < 0 0 + 600 1 + 3000 2 >; + pinctrl-0 = <&pmx_fan>; + pinctrl-names = "default"; + }; + usb3_0_power: v5-vbus0 { compatible = "regulator-fixed"; regulator-name = "USB3_0_Power"; @@ -378,6 +388,11 @@ marvell,pins = "mpp17"; marvell,function = "gpio"; }; + + pmx_fan: pmx-fan { + marvell,pins = "mpp48"; + marvell,function = "gpio"; + }; };
&sdhci { diff --git a/board/thecus/n2350/n2350.c b/board/thecus/n2350/n2350.c index fd8f95f944..05b125fd7f 100644 --- a/board/thecus/n2350/n2350.c +++ b/board/thecus/n2350/n2350.c @@ -25,7 +25,7 @@ DECLARE_GLOBAL_DATA_PTR; #define N2350_GPP_OUT_ENA_LOW (~(BIT(20) | BIT(21) | BIT(24))) #define N2350_GPP_OUT_ENA_MID (~(BIT(12) | BIT(13) | BIT(16) | BIT(19) | BIT(22))) #define N2350_GPP_OUT_VAL_LOW (BIT(21) | BIT(24)) -#define N2350_GPP_OUT_VAL_MID (BIT(0) | BIT(12) | BIT(13)) +#define N2350_GPP_OUT_VAL_MID (BIT(0) | BIT(12) | BIT(13) | BIT(16)) #define N2350_GPP_POL_LOW 0x0 #define N2350_GPP_POL_MID 0x0
Thanks, Stefan
- fan {
600 1
3000 2 >;
- usb3_0_power: v5-vbus0 { compatible = "regulator-fixed"; regulator-name = "USB3_0_Power";
pmx_fan: pmx-fan {
&sdhci {
Viele Grüße, Stefan Roese
Applied to u-boot-marvell/master
Thanks, Stefan
- fan {
600 1
3000 2 >;
pmx_fan: pmx-fan {
&sdhci {
Stefan Roese
Tony Dinh
