[U-Boot] upstream Arndale support
I cannot get upstream u-boot to run on an Arndale board. Everything works when I use the Linaro branch. But this tree is old and carries a whole different set of patches for Arndale. Is the Arndale upstream support supposed to work? If yes, is there a different recipe for populating the uSD card?
What works is the following: $ git checkout linaro $ make arndale5250_config && make -j arndale5250 $ dd if=/tmp/arndale-bl1.bin of=/dev/sdb seek=1 $ dd if=spl/smdk5250-spl.bin of=/dev/sdb seek=17 $ dd if=u-boot.bin of=/dev/sdb seek=49
Transferring this to upstream I get the following: $ git checkout master $ make arndale_config && make -j arndale $ dd if=/tmp/arndale-bl1.bin of=/dev/sdb seek=1 $ dd if=spl/arndale-spl.bin of=/dev/sdb seek=17 $ dd if=u-boot.bin of=/dev/sdb seek=49
However while the Linaro based build works fine, I don't get any serial output on the upstream build.
Can someone give any hints?
Thanks, Andre.
Hi Andre,
dd if=u-boot-dtb.bin of=/dev/sdb seek=49
Thanks, Andre.
On 12/04/2013 01:14 PM, Chander Kashyap wrote:
Hi Andre,
Indeed! That works!
Thanks a lot!
Andre.
Thanks, Andre.
Andre Przywara
Chander Kashyap
