[U-Boot] [PATCH] igep00x0: enable CONFIG_FDT_FIXUP_PARTITIONS
SPL partition size depends on sector size and we want kernel to use the same layout, so let U-Boot modify FDT accordingly.
Signed-off-by: Ladislav Michl ladis@linux-mips.org --- board/isee/igep00x0/igep00x0.c | 17 +++++++++++++++++ configs/igep0020_defconfig | 2 ++ configs/igep0030_defconfig | 2 ++ configs/igep0032_defconfig | 2 ++ 4 files changed, 23 insertions(+)
diff --git a/board/isee/igep00x0/igep00x0.c b/board/isee/igep00x0/igep00x0.c index 669f3dde7f..ae7959b1eb 100644 --- a/board/isee/igep00x0/igep00x0.c +++ b/board/isee/igep00x0/igep00x0.c @@ -23,6 +23,8 @@ #include <linux/mtd/nand.h> #include <linux/mtd/onenand.h> #include <jffs2/load_kernel.h> +#include <mtd_node.h> +#include <fdt_support.h> #include "igep00x0.h"
DECLARE_GLOBAL_DATA_PTR; @@ -210,6 +212,21 @@ void board_mmc_power_init(void) } #endif
+#ifdef CONFIG_OF_BOARD_SETUP +int ft_board_setup(void *blob, bd_t *bd) +{ +#ifdef CONFIG_FDT_FIXUP_PARTITIONS + static struct node_info nodes[] = { + { "ti,omap2-nand", MTD_DEV_TYPE_NAND, }, + { "ti,omap2-onenand", MTD_DEV_TYPE_ONENAND, }, + }; + + fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes)); +#endif + return 0; +} +#endif + void set_fdt(void) { switch (gd->bd->bi_arch_number) { diff --git a/configs/igep0020_defconfig b/configs/igep0020_defconfig index c25b6b85a3..9e99c0c10a 100644 --- a/configs/igep0020_defconfig +++ b/configs/igep0020_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_TARGET_OMAP3_IGEP00X0=y +CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0020" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y @@ -35,3 +36,4 @@ CONFIG_CMD_UBI=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y +CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/configs/igep0030_defconfig b/configs/igep0030_defconfig index 925c42fd44..3478d4dd74 100644 --- a/configs/igep0030_defconfig +++ b/configs/igep0030_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_DISTRO_DEFAULTS=y +CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0030" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y @@ -27,3 +28,4 @@ CONFIG_CMD_UBI=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y +CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/configs/igep0032_defconfig b/configs/igep0032_defconfig index dad8dfaf0c..c72fb58e3b 100644 --- a/configs/igep0032_defconfig +++ b/configs/igep0032_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_DISTRO_DEFAULTS=y +CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0032" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y @@ -27,3 +28,4 @@ CONFIG_CMD_UBI=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y +CONFIG_FDT_FIXUP_PARTITIONS=y
Signed-off-by: Ladislav Michl ladis@linux-mips.org --- Changes: -v2 rebased against current git as it no longer applies
+#ifdef CONFIG_OF_BOARD_SETUP +int ft_board_setup(void *blob, bd_t *bd) +{ +#ifdef CONFIG_FDT_FIXUP_PARTITIONS + static struct node_info nodes[] = { + { "ti,omap2-nand", MTD_DEV_TYPE_NAND, }, + { "ti,omap2-onenand", MTD_DEV_TYPE_ONENAND, }, + }; + + fdt_fixup_mtdparts(blob, nodes, ARRAY_SIZE(nodes)); +#endif + return 0; +} +#endif + void set_fdt(void) { switch (gd->bd->bi_arch_number) { diff --git a/configs/igep0020_defconfig b/configs/igep0020_defconfig index 0dd244efc9..50bb4acf57 100644 --- a/configs/igep0020_defconfig +++ b/configs/igep0020_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_TARGET_OMAP3_IGEP00X0=y +CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0020" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y @@ -36,3 +37,4 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y +CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/configs/igep0030_defconfig b/configs/igep0030_defconfig index 72fb874b87..42bd6fc3dc 100644 --- a/configs/igep0030_defconfig +++ b/configs/igep0030_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_DISTRO_DEFAULTS=y +CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0030" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y @@ -28,3 +29,4 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y +CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/configs/igep0032_defconfig b/configs/igep0032_defconfig index 1318e5b2d0..01adb2032b 100644 --- a/configs/igep0032_defconfig +++ b/configs/igep0032_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y # CONFIG_SPL_EXT_SUPPORT is not set CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_DISTRO_DEFAULTS=y +CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -27,3 +28,4 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y +CONFIG_FDT_FIXUP_PARTITIONS=y
I ended up rebasing myself when applying as it was an easy fixup, JFYI.
Ladislav Michl
