[U-Boot-Users] Fix problem with get/setdcr commands introduced by cfg patches
Signed-off-by: Stefan Roese sr@denx.de
--- commit 981ee564aeea50072d23045b88918df73bb8dc37 tree 3a2d693997fad34fd049a56518dbb44195342392 parent e4dbe1b215f5c6c462e76909d240bd96472b84de author Stefan Roese sr@denx.de Fri, 06 Jul 2007 09:43:55 +0200 committer Stefan Roese sr@denx.de Fri, 06 Jul 2007 09:43:55 +0200
cpu/ppc4xx/dcr.S | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/cpu/ppc4xx/dcr.S b/cpu/ppc4xx/dcr.S index 7102364..554db1b 100644 --- a/cpu/ppc4xx/dcr.S +++ b/cpu/ppc4xx/dcr.S @@ -22,7 +22,7 @@ */ #include <config.h>
-#if defined(CONFIG_4xx) && defined(CFG_CMD_SETGETDCR) +#if defined(CONFIG_4xx) && ((CONFIG_COMMANDS & CFG_CMD_SETGETDCR) || defined(CONFIG_CMD_SETGETDCR))
#include <ppc4xx.h>
Applied to u-boot-testing
So, like, the other day Stefan Roese mumbled:
-#if defined(CONFIG_4xx) && defined(CFG_CMD_SETGETDCR) +#if defined(CONFIG_4xx) && ((CONFIG_COMMANDS & CFG_CMD_SETGETDCR) || defined(CONFIG_CMD_SETGETD CR))
#include <ppc4xx.h>
Sorry about that.
Hmmm... Something is fishy here if this is a problem...
While the above is a valid (temporary) "fix", I think rather than re-introducing this clause:
a better (long term) solution is to try and figure out why CONFIG_CMD_SETGETDCR isn't available. The goal is to eliminate the CONFIG_COMMAND symbol, so we should be able to compile this file without it.
My guesses off the top of my head:
1) I blitzed CONFIG_CMD_SETGETDCR in the 4xx.h config file 2) The 4xx board config file isn't being included here 3) Interaction with a .S file 4) Some secondary #include effect making config_cmd_default.h be not included
Please let me know if I can further here.
HTH, jdl
#include <ppc4xx.h>
Sorry about that.
No problem.
I have no problems with just using:
#if defined(CONFIG_4xx) && defined(CONFIG_CMD_SETGETDCR)
here. But we had:
So this couldn't work.
Feel free to clean this up with your next patchset.
Thanks.
Best regards, Stefan
here. But we had:
D'oh. That's just my brain-damage and late night drinking. :-)
You are in a twisty maze of #defines all alike...
I'll bet not...
Will do!
jdl
--- commit 21b5c73cf1edfe437ddd7df0c4829063600d03ea tree 2bf23095eebda168b3e4c7e3f4ad7f686342614d parent e9514751cfa5cce61ea699fa0d3eb37898a5eeb5 author Stefan Roese sr@denx.de Wed, 11 Jul 2007 12:12:25 +0200 committer Stefan Roese sr@denx.de Wed, 11 Jul 2007 12:12:25 +0200
common/cmd_flash.c | 2 +- common/cmd_nvedit.c | 5 ++--- drivers/macb.c | 2 +- net/nfs.c | 3 +-- net/sntp.c | 3 +-- 5 files changed, 6 insertions(+), 9 deletions(-)
diff --git a/common/cmd_flash.c b/common/cmd_flash.c index db38f94..11c8857 100644 --- a/common/cmd_flash.c +++ b/common/cmd_flash.c @@ -33,7 +33,7 @@
#if defined(CONFIG_CMD_FLASH)
-#if (defined(CONFIG_CMD_JFFS2) && defined(CONFIG_JFFS2_CMDLINE) +#if defined(CONFIG_CMD_JFFS2) && defined(CONFIG_JFFS2_CMDLINE) #include <jffs2/jffs2.h>
/* parition handling routines */ diff --git a/common/cmd_nvedit.c b/common/cmd_nvedit.c index e313f2c..de5a514 100644 --- a/common/cmd_nvedit.c +++ b/common/cmd_nvedit.c @@ -538,7 +538,7 @@ int getenv_r (char *name, char *buf, unsigned len) return (-1); }
-#if defined(CFG_ENV_IS_IN_NVRAM) || defined(CFG_ENV_IS_IN_EEPROM) || \ +#if defined(CFG_ENV_IS_IN_NVRAM) || defined(CFG_ENV_IS_IN_EEPROM) \ || (defined(CONFIG_CMD_ENV) && defined(CONFIG_CMD_FLASH)) \ || (defined(CONFIG_CMD_ENV) && defined(CONFIG_CMD_NAND)) int do_saveenv (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) @@ -550,7 +550,6 @@ int do_saveenv (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return (saveenv() ? 1 : 0); }
- #endif
@@ -594,7 +593,7 @@ U_BOOT_CMD( " - delete environment variable 'name'\n" );
-#if defined(CFG_ENV_IS_IN_NVRAM) || defined(CFG_ENV_IS_IN_EEPROM) || \ +#if defined(CFG_ENV_IS_IN_NVRAM) || defined(CFG_ENV_IS_IN_EEPROM) \ || (defined(CONFIG_CMD_ENV) && defined(CONFIG_CMD_FLASH)) \ || (defined(CONFIG_CMD_ENV) && defined(CONFIG_CMD_NAND)) U_BOOT_CMD( diff --git a/drivers/macb.c b/drivers/macb.c index ffb5f74..bf7853a 100644 --- a/drivers/macb.c +++ b/drivers/macb.c @@ -18,7 +18,7 @@ #include <common.h>
#if defined(CONFIG_MACB) \ - && (defined(CONFIG_CMD_NET) || defined(CONFIG_CMD_MII))) + && (defined(CONFIG_CMD_NET) || defined(CONFIG_CMD_MII))
/* * The u-boot networking stack is a little weird. It seems like the diff --git a/net/nfs.c b/net/nfs.c index 30a897d..df2caac 100644 --- a/net/nfs.c +++ b/net/nfs.c @@ -31,8 +31,7 @@
/*#define NFS_DEBUG*/
-#if (defined(CONFIG_CMD_NET) \ - && defined(CONFIG_CMD_NFS) +#if defined(CONFIG_CMD_NET) && defined(CONFIG_CMD_NFS)
#define HASHES_PER_LINE 65 /* Number of "loading" hashes per line */ #define NFS_TIMEOUT 60 diff --git a/net/sntp.c b/net/sntp.c index 0a7f478..95e7542 100644 --- a/net/sntp.c +++ b/net/sntp.c @@ -12,8 +12,7 @@
#include "sntp.h"
-#if (defined(CONFIG_CMD_NET) \ - && defined(CONFIG_CMD_SNTP) +#if defined(CONFIG_CMD_NET) && defined(CONFIG_CMD_SNTP)
#define SNTP_TIMEOUT 10
this and everything in u-boot-testing are:
Acked-by: Kim Phillips kim.phillips@freescale.com
Kim
Jon Loeliger
Kim Phillips
Stefan Roese
