[U-Boot] [PATCH u-boot v2] ARM: arch-meson: build memory banks using reported memory from registers
As discussed at [1], the Amlogic Meson GX SoCs can embed a BL31 firmware and a secondary BL32 firmware. Since mid-2017, the reserved memory address of the BL31 firmware was moved and grown for security reasons.
But mainline U-Boot and Linux has the old address and size fixed.
These SoCs have a register interface to get the two firmware reserved memory start and sizes.
This patch adds a dynamic reservation of the memory zones in the device tree bootmem reserved memory zone used by the kernel in early boot. To be complete, the memory zones are also added to the EFI reserved zones.
Depends on patchset "Add support for Amlogic GXL Based SBCs" at [2].
[1] http://lists.infradead.org/pipermail/linux-amlogic/2017-October/004860.html [2] http://lists.infradead.org/pipermail/linux-amlogic/2017-November/005410.html
Changes since v1: - switched the #if to if(IS_ENABLED()) to compile all code paths - renamed function to meson_board_add_reserved_memory() - added a mem.h header with comment - updated all boards ft_board_setup()
Changes since RFC v2: - reduced preprocessor load - kept Odroid-C2 static memory mapping as exception
Changes since RFC v1: - switch to fdt rsv mem table and efi reserve memory - replaced in_le32 by readl()
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- arch/arm/include/asm/arch-meson/gxbb.h | 17 +++++++ arch/arm/include/asm/arch-meson/mem.h | 16 +++++++ arch/arm/mach-meson/board.c | 74 +++++++++++++++++++++++++++---- board/amlogic/khadas-vim/khadas-vim.c | 7 +++ board/amlogic/libretech-cc/libretech-cc.c | 8 ++++ board/amlogic/odroid-c2/odroid-c2.c | 8 ++++ board/amlogic/p212/p212.c | 8 ++++ configs/khadas-vim_defconfig | 1 + configs/libretech-cc_defconfig | 1 + configs/odroid-c2_defconfig | 1 + configs/p212_defconfig | 1 + include/configs/meson-gxbb-common.h | 2 +- 12 files changed, 135 insertions(+), 9 deletions(-) create mode 100644 arch/arm/include/asm/arch-meson/mem.h
diff --git a/arch/arm/include/asm/arch-meson/gxbb.h b/arch/arm/include/asm/arch-meson/gxbb.h index 95a6fe6..ef63dea 100644 --- a/arch/arm/include/asm/arch-meson/gxbb.h +++ b/arch/arm/include/asm/arch-meson/gxbb.h @@ -7,10 +7,27 @@ #ifndef __GXBB_H__ #define __GXBB_H__
+#define GXBB_FIRMWARE_MEM_SIZE 0x1000000 + +#define GXBB_AOBUS_BASE 0xc8100000 #define GXBB_PERIPHS_BASE 0xc8834400 #define GXBB_HIU_BASE 0xc883c000 #define GXBB_ETH_BASE 0xc9410000
+/* Always-On Peripherals registers */ +#define GXBB_AO_ADDR(off) (GXBB_AOBUS_BASE + ((off) << 2)) + +#define GXBB_AO_SEC_GP_CFG0 GXBB_AO_ADDR(0x90) +#define GXBB_AO_SEC_GP_CFG3 GXBB_AO_ADDR(0x93) +#define GXBB_AO_SEC_GP_CFG4 GXBB_AO_ADDR(0x94) +#define GXBB_AO_SEC_GP_CFG5 GXBB_AO_ADDR(0x95) + +#define GXBB_AO_MEM_SIZE_MASK 0xFFFF0000 +#define GXBB_AO_MEM_SIZE_SHIFT 16 +#define GXBB_AO_BL31_RSVMEM_SIZE_MASK 0xFFFF0000 +#define GXBB_AO_BL31_RSVMEM_SIZE_SHIFT 16 +#define GXBB_AO_BL32_RSVMEM_SIZE_MASK 0xFFFF + /* Peripherals registers */ #define GXBB_PERIPHS_ADDR(off) (GXBB_PERIPHS_BASE + ((off) << 2))
diff --git a/arch/arm/include/asm/arch-meson/mem.h b/arch/arm/include/asm/arch-meson/mem.h new file mode 100644 index 0000000..86a8417 --- /dev/null +++ b/arch/arm/include/asm/arch-meson/mem.h @@ -0,0 +1,16 @@ +/* + * Copyright (C) 2016 BayLibre, SAS + * Author: Neil Armstrong narmstrong@baylibre.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __MESON_MEM_H__ +#define __MESON_MEM_H__ + +/* Configure the reserved memory zones exported by the secure registers + * into EFI and DTB reserved memory entries. + */ +void meson_gx_init_reserved_memory(void *fdt); + +#endif /* __MESON_MEM_H__ */ diff --git a/arch/arm/mach-meson/board.c b/arch/arm/mach-meson/board.c index e89c6aa..908a0ca 100644 --- a/arch/arm/mach-meson/board.c +++ b/arch/arm/mach-meson/board.c @@ -11,6 +11,9 @@ #include <asm/arch/sm.h> #include <asm/armv8/mmu.h> #include <asm/unaligned.h> +#include <linux/sizes.h> +#include <efi_loader.h> +#include <asm/io.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -34,15 +37,70 @@ int dram_init(void) return 0; }
-int dram_init_banksize(void) +phys_size_t get_effective_memsize(void) { - /* Reserve first 16 MiB of RAM for firmware */ - gd->bd->bi_dram[0].start = 0x1000000; - gd->bd->bi_dram[0].size = 0xf000000; - /* Reserve 2 MiB for ARM Trusted Firmware (BL31) */ - gd->bd->bi_dram[1].start = 0x10000000; - gd->bd->bi_dram[1].size = gd->ram_size - 0x10200000; - return 0; + /* Size is reported in MiB, convert it in bytes */ + return ((readl(GXBB_AO_SEC_GP_CFG0) & GXBB_AO_MEM_SIZE_MASK) + >> GXBB_AO_MEM_SIZE_SHIFT) * SZ_1M; +} + +static void meson_board_add_reserved_memory(void *fdt, u64 start, u64 size) +{ + int ret; + + ret = fdt_add_mem_rsv(fdt, start, size); + if (ret) + printf("Could not reserve zone @ 0x%llx\n", start); + + if (IS_ENABLED(CONFIG_EFI_LOADER)) { + efi_add_memory_map(start, + ALIGN(size, EFI_PAGE_SIZE) >> EFI_PAGE_SHIFT, + EFI_RESERVED_MEMORY_TYPE, false); + } +} + +void meson_gx_init_reserved_memory(void *fdt) +{ + u64 bl31_size, bl31_start; + u64 bl32_size, bl32_start; + u32 reg; + + /* + * Get ARM Trusted Firmware reserved memory zones in : + * - AO_SEC_GP_CFG3: bl32 & bl31 size in KiB, can be 0 + * - AO_SEC_GP_CFG5: bl31 physical start address, can be NULL + * - AO_SEC_GP_CFG4: bl32 physical start address, can be NULL + */ + + reg = readl(GXBB_AO_SEC_GP_CFG3); + + bl31_size = ((reg & GXBB_AO_BL31_RSVMEM_SIZE_MASK) + >> GXBB_AO_BL31_RSVMEM_SIZE_SHIFT) * SZ_1K; + bl32_size = (reg & GXBB_AO_BL32_RSVMEM_SIZE_MASK) * SZ_1K; + + bl31_start = readl(GXBB_AO_SEC_GP_CFG5); + bl32_start = readl(GXBB_AO_SEC_GP_CFG4); + + /* + * Early Meson GXBB Firmware revisions did not provide the reserved + * memory zones in the registers, keep fixed memory zone handling. + */ + if (IS_ENABLED(CONFIG_MESON_GXBB) && + !reg && !bl31_start && !bl32_start) { + bl31_start = 0x10000000; + bl31_size = 0x200000; + } + + /* Add first 16MiB reserved zone */ + meson_board_add_reserved_memory(fdt, 0, GXBB_FIRMWARE_MEM_SIZE); + + /* Add BL31 reserved zone */ + if (bl31_start && bl31_size) + meson_board_add_reserved_memory(fdt, bl31_start, bl31_size); + + /* Add BL32 reserved zone */ + if (bl32_start && bl32_size) + meson_board_add_reserved_memory(fdt, bl32_start, bl32_size); }
void reset_cpu(ulong addr) diff --git a/board/amlogic/khadas-vim/khadas-vim.c b/board/amlogic/khadas-vim/khadas-vim.c index db9c292..6baf322 100644 --- a/board/amlogic/khadas-vim/khadas-vim.c +++ b/board/amlogic/khadas-vim/khadas-vim.c @@ -47,3 +47,10 @@ int misc_init_r(void)
return 0; } + +int ft_board_setup(void *blob, bd_t *bd) +{ + meson_gx_init_reserved_memory(blob); + + return 0; +} diff --git a/board/amlogic/libretech-cc/libretech-cc.c b/board/amlogic/libretech-cc/libretech-cc.c index 26c0e78..6be6e2a 100644 --- a/board/amlogic/libretech-cc/libretech-cc.c +++ b/board/amlogic/libretech-cc/libretech-cc.c @@ -11,6 +11,7 @@ #include <asm/arch/gxbb.h> #include <asm/arch/sm.h> #include <asm/arch/eth.h> +#include <asm/arch/mem.h>
#define EFUSE_SN_OFFSET 20 #define EFUSE_SN_SIZE 16 @@ -51,3 +52,10 @@ int misc_init_r(void)
return 0; } + +int ft_board_setup(void *blob, bd_t *bd) +{ + meson_gx_init_reserved_memory(blob); + + return 0; +} diff --git a/board/amlogic/odroid-c2/odroid-c2.c b/board/amlogic/odroid-c2/odroid-c2.c index d68d0f1..0cb5714 100644 --- a/board/amlogic/odroid-c2/odroid-c2.c +++ b/board/amlogic/odroid-c2/odroid-c2.c @@ -10,6 +10,7 @@ #include <asm/arch/gxbb.h> #include <asm/arch/sm.h> #include <asm/arch/eth.h> +#include <asm/arch/mem.h>
#define EFUSE_SN_OFFSET 20 #define EFUSE_SN_SIZE 16 @@ -54,3 +55,10 @@ int misc_init_r(void)
return 0; } + +int ft_board_setup(void *blob, bd_t *bd) +{ + meson_gx_init_reserved_memory(blob); + + return 0; +} diff --git a/board/amlogic/p212/p212.c b/board/amlogic/p212/p212.c index 2b6d88a..5fde534 100644 --- a/board/amlogic/p212/p212.c +++ b/board/amlogic/p212/p212.c @@ -11,6 +11,7 @@ #include <asm/arch/gxbb.h> #include <asm/arch/sm.h> #include <asm/arch/eth.h> +#include <asm/arch/mem.h>
#define EFUSE_SN_OFFSET 20 #define EFUSE_SN_SIZE 16 @@ -46,3 +47,10 @@ int misc_init_r(void)
return 0; } + +int ft_board_setup(void *blob, bd_t *bd) +{ + meson_gx_init_reserved_memory(blob); + + return 0; +} diff --git a/configs/khadas-vim_defconfig b/configs/khadas-vim_defconfig index dcccc69..f2a30a8 100644 --- a/configs/khadas-vim_defconfig +++ b/configs/khadas-vim_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y +CONFIG_OF_BOARD_SETUP=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_MMC_MESON_GX=y diff --git a/configs/libretech-cc_defconfig b/configs/libretech-cc_defconfig index a63e940..6583c43 100644 --- a/configs/libretech-cc_defconfig +++ b/configs/libretech-cc_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y +CONFIG_OF_BOARD_SETUP=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_MMC_MESON_GX=y diff --git a/configs/odroid-c2_defconfig b/configs/odroid-c2_defconfig index 1afd2fc..18d2b68 100644 --- a/configs/odroid-c2_defconfig +++ b/configs/odroid-c2_defconfig @@ -16,6 +16,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y +CONFIG_OF_BOARD_SETUP=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y diff --git a/configs/p212_defconfig b/configs/p212_defconfig index d4b5349..b6e788b 100644 --- a/configs/p212_defconfig +++ b/configs/p212_defconfig @@ -17,6 +17,7 @@ CONFIG_CMD_MMC=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y +CONFIG_OF_BOARD_SETUP=y CONFIG_DM_GPIO=y CONFIG_DM_MMC=y CONFIG_MMC_MESON_GX=y diff --git a/include/configs/meson-gxbb-common.h b/include/configs/meson-gxbb-common.h index d88d42d..c2b306a 100644 --- a/include/configs/meson-gxbb-common.h +++ b/include/configs/meson-gxbb-common.h @@ -10,7 +10,7 @@
#define CONFIG_CPU_ARMV8 #define CONFIG_REMAKE_ELF -#define CONFIG_NR_DRAM_BANKS 2 +#define CONFIG_NR_DRAM_BANKS 1 #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MAXARGS 32 #define CONFIG_SYS_MALLOC_LEN (32 << 20)
Changes since v1:
Seems good, so far as I understand it.
Changes since v1:
Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Neil Armstrong narmstrong@baylibre.com Reviewed-by: Simon Glass sjg@chromium.org
Neil Armstrong
